VirtualBox appears to be leaking memory
I’m using the latest stable release of Manjaro, and I’ve noticed that my VirtualBox (7.2.2-1) with Windows 10 with 3D acceleration enabled slowly consumes more and more RAM. Its starting at around 200MB and eventually reaching up to 9GB. Has anyone else encountered this issue before?
It will not and cannot consume more RAM than what you assigned to that VM.
… 200 MB for a Windows 10 VM seems implausibly low in even the best of possible scenarios …
I’m not referring to the ram allocated to the virtual machine. I mean the RAM the virtualbox application itself uses on the host system, you can see it in the kde system monitor’s “applications” section . it starts at 200 and climbs so high, that i keep running out of memory.
so: how much did you allocate?
If it uses more than that, that would be a flaw in VirtualBox.
I do not use that software.
I use libvirt/VirtManager.
i gave it 12 gigs out of my 32. the first time i ran out of memory, vbox basically took ~20gigs by itself. I probably will go with kvm setup too, with it being faster and not leaking memory
Please provide system information as described (below) to help identify possible contributors.
Also provide screenshots of the VirtualBox configuration windows for System (Motherboard + Processor) and Display (Screen).
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – instead, please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
If running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
without knowing your vbox-setup but 20 GB for itself ? this is very unusual, never heard before
