So, i think i broke something here, before (will list below) i made some changes to try to install windows 11 in virt-manager/qemu i was able to access the internet from my vm’s now they just don’t
What i did:
I installed ovmf-git from AUR and swtpm from extra
What i’ve done to try to resolve the issues:
- Downgraded lib-virt from 1:8.0.0-1 to 1:7.10.0-2
- Restarted my machine
- Reinstalled a fresh vm
- Attempted to roll-back ovmf from aut to manjaro’s repo version
- Revonfigured DNS/IP Settings in the VM’s Manually
- ran the following commands
sudo pacman -Syuu
sudo pacman -Syu
sudo iptables -I FORWARD -d 192.168.122.129 - ACCEPT
sudo systemctl restart libvirtd
nothing has worked
here is some outputs
ifconfig
docker0 Link encap:Ethernet HWaddr 02:42:f6:7b:af:ea
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eno1 Link encap:Ethernet HWaddr e0:d5:5e:29:64:fe
collisions:0 txqueuelen:1000
Interrupt:16 Memory:ef400000-ef420000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536
RX packets:48 errors:0 dropped:0 overruns:0 frame:0
TX packets:48 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4444 (4.3 KiB) TX bytes:4444 (4.3 KiB)
virbr0 Link encap:Ethernet HWaddr 52:54:00:38:34:9f
inet addr:192.168.122.1 Bcast:192.168.122.255 Mask:255.255.255.0
RX packets:1851 errors:0 dropped:0 overruns:0 frame:0
TX packets:195 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:483365 (472.0 KiB) TX bytes:23169 (22.6 KiB)
wlp8s0 Link encap:Ethernet HWaddr f8:34:41:a4:a2:4a
inet addr:10.0.0.115 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::5661:12d1:94e3:bcf4/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500
RX packets:138942 errors:0 dropped:0 overruns:0 frame:0
TX packets:35692 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:176397640 (168.2 MiB) TX bytes:6483405 (6.1 MiB)
iptables -L
# Warning: iptables-legacy tables present, use iptables-legacy to see them
Chain INPUT (policy ACCEPT)
target prot opt source destination
LIBVIRT_INP all -- anywhere anywhere
Chain FORWARD (policy ACCEPT)
all -- anywhere 192.168.122.15
all -- anywhere shadow-z370aorusgaming5
all -- anywhere 192.168.122.129
ACCEPT all -- anywhere shadow-z370aorusgaming5
ACCEPT all -- anywhere 192.168.122.129
LIBVIRT_FWX all -- anywhere anywhere
LIBVIRT_FWI all -- anywhere anywhere
LIBVIRT_FWO all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
LIBVIRT_OUT all -- anywhere anywhere
Chain LIBVIRT_FWI (1 references)
ACCEPT all -- anywhere 192.168.122.0/24 ctstate RELATED,ESTABLISHED
REJECT all -- anywhere anywhere reject-with icmp-port-unreachable
Chain LIBVIRT_FWO (1 references)
ACCEPT all -- 192.168.122.0/24 anywhere
Chain LIBVIRT_FWX (1 references)
ACCEPT all -- anywhere anywhere
Chain LIBVIRT_INP (1 references)
ACCEPT udp -- anywhere anywhere udp dpt:domain
ACCEPT tcp -- anywhere anywhere tcp dpt:domain
ACCEPT udp -- anywhere anywhere udp dpt:bootps
ACCEPT tcp -- anywhere anywhere tcp dpt:bootps
Chain LIBVIRT_OUT (1 references)
ACCEPT udp -- anywhere anywhere udp dpt:bootpc
ACCEPT tcp -- anywhere anywhere tcp dpt:bootpc
and
iptables -t nat -L
Chain PREROUTING (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
LIBVIRT_PRT all -- anywhere anywhere
Chain LIBVIRT_PRT (1 references)
RETURN all -- 192.168.122.0/24 base-address.mcast.net/24
RETURN all -- 192.168.122.0/24 255.255.255.255
MASQUERADE tcp -- 192.168.122.0/24 !192.168.122.0/24 masq ports: 1024-65535
MASQUERADE udp -- 192.168.122.0/24 !192.168.122.0/24 masq ports: 1024-65535
MASQUERADE all -- 192.168.122.0/24 !192.168.122.0/24
Any ideas? any more info needed?
