Hi,
i have a problem with virt manager losing the connection to my vm guest os after login into the guest. It happened occasionally in the past, but now it seems to be permanent.
I followed all guides i found so far:
added my user to libvirt-qemu and kvm in addition to libvirt,
uncomment the two lines in /etc/libvirt/libvirtd.conf
keepalive_interval = 5
keepalive_count = 5
Here the output of systemclt libvirtd and inxi:
systemctl status libvirtd
● libvirtd.service - libvirt legacy monolithic daemon
Loaded: loaded (/usr/lib/systemd/system/libvirtd.service; enabled; preset: disabled)
Active: active (running) since Sat 2024-10-12 19:39:01 CEST; 1h 1min ago
Invocation: 845930430d944396bdb818196e0ab1b3
TriggeredBy: ● libvirtd-ro.socket
● libvirtd.socket
● libvirtd-admin.socket
Docs: man:libvirtd(8)
https://libvirt.org/
Main PID: 2280 (libvirtd)
Tasks: 25 (limit: 32768)
Memory: 17M (peak: 45.7M swap: 17M swap peak: 17.1M zswap: 2.5M)
CPU: 1.782s
CGroup: /system.slice/libvirtd.service
├─ 750 /usr/bin/dnsmasq --conf-file=/var/lib/libvirt/dnsmasq/default.conf --leasefile-ro --dhcp-script=/usr/lib/libvirt/libvirt_leaseshelper
├─ 751 /usr/bin/dnsmasq --conf-file=/var/lib/libvirt/dnsmasq/default.conf --leasefile-ro --dhcp-script=/usr/lib/libvirt/libvirt_leaseshelper
└─2280 /usr/bin/libvirtd --timeout 120
Okt 12 19:42:51 alexander-ms7589 libvirtd[2280]: hostname: alexander-ms7589
Okt 12 19:42:51 alexander-ms7589 libvirtd[2280]: Interner Fehler: connection closed due to keepalive timeout
Okt 12 19:51:34 alexander-ms7589 dnsmasq-dhcp[750]: DHCPDISCOVER(virbr0) 192.168.122.165 52:54:00:75:16:66
Okt 12 19:51:34 alexander-ms7589 dnsmasq-dhcp[750]: DHCPOFFER(virbr0) 192.168.122.165 52:54:00:75:16:66
Okt 12 19:51:34 alexander-ms7589 dnsmasq-dhcp[750]: DHCPREQUEST(virbr0) 192.168.122.165 52:54:00:75:16:66
Okt 12 19:51:34 alexander-ms7589 dnsmasq-dhcp[750]: DHCPACK(virbr0) 192.168.122.165 52:54:00:75:16:66 mx
Okt 12 19:54:01 alexander-ms7589 libvirtd[2280]: Interner Fehler: connection closed due to keepalive timeout
Okt 12 19:54:44 alexander-ms7589 libvirtd[2280]: Interner Fehler: connection closed due to keepalive timeout
Okt 12 20:21:34 alexander-ms7589 dnsmasq-dhcp[750]: DHCPREQUEST(virbr0) 192.168.122.165 52:54:00:75:16:66
Okt 12 20:21:34 alexander-ms7589 dnsmasq-dhcp[750]: DHCPACK(virbr0) 192.168.122.165 52:54:00:75:16:66 mx
inxi
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6 rw
resume=UUID=9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6 resume_offset=30074880
apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1
nvidia_drm.modeset=1 nvidia_drm.fbdev=1
NVreg_PreserveVideoMemoryAllocations=1 NVreg_TemporaryFilePath=/var/tmp
modprobe.blacklist=nouveau systemd.setenv=GPUMOD=nvidia nowatchdog
intel_iommu=on iommu=pt
Desktop: KDE Plasma v: 6.2.0 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop Mobo: MSI model: P55-GD55 (MS-7589) v: 1.0
serial: <superuser required> uuid: <superuser required>
BIOS: American Megatrends v: 1.9 date: 03/02/2011
System RAM: total: 8 GiB available: 7.75 GiB used: 5.34 GiB (68.9%)
Array-1: capacity: 8 GiB slots: 4 modules: 4 EC: None
max-module-size: 2 GiB note: est.
Device-1: DIMM1 type: SDRAM detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: N/A part-no: N/A serial: N/A
Device-2: DIMM2 type: SDRAM detail: synchronous size: 2 GiB
Device-3: DIMM3 type: SDRAM detail: synchronous size: 2 GiB
Device-4: DIMM4 type: SDRAM detail: synchronous size: 2 GiB
Info: model: Intel Core i7 860 bits: 64 type: MT MCP arch: Nehalem
gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
model-id: 0x1E (30) stepping: 5 microcode: 0xA
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1200 min/max: 1200/2801 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 1200 3: 1200
4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 bogomips: 44923
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none off: DVI-I-1 empty: DP-1,DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.20x11.50")
s-diag: 590mm (23.24")
Monitor-1: DVI-I-1 note: disabled model: Samsung SyncMaster
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.295 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 970 driver: nvidia v: 550.120 device-ID: 10de:13c2
surfaces: xcb,xlib
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d800 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet1 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
Local Storage: total: 3.18 TiB used: 220.67 GiB (6.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD103SJ size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 00E4 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDS5C3020ALA632
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5940 serial: <filter> fw-rev: A580 scheme: MBR
ID-1: / raw-size: 371.09 GiB size: 364.2 GiB (98.14%) used: 65.98 GiB (18.1%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: SSDRoot
uuid: 9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6
ID-2: /home raw-size: 489.27 GiB size: 480.51 GiB (98.21%)
used: 154.69 GiB (32.2%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: home
uuid: c5fcc6d4-1db5-4ec5-8ede-0f76cd6ee4ab
Kernel: swappiness: 50 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 11 GiB used: 2.98 GiB (27.1%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System-reserviert
uuid: 583E97273E96FD66
ID-2: /dev/sda2 maj-min: 8:2 size: 199.39 GiB fs: ntfs label: System
uuid: 0A12C25D12C24CFF
ID-3: /dev/sda3 maj-min: 8:3 size: 527 MiB fs: ntfs label: N/A
uuid: 34862028861FE95E
ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sda5 maj-min: 8:5 size: 242.25 GiB fs: ntfs label: Daten
uuid: 7024BEAB24BE73A6
ID-6: /dev/sdb2 maj-min: 8:18 size: 94.66 GiB fs: ext4 label: SSDDaten
uuid: b9358f37-9f4f-4c92-a7e7-034e046fa0f8
ID-7: /dev/sdc1 maj-min: 8:33 size: 1.15 TiB fs: ntfs label: Daten3
uuid: 86E470A6E47099DF
ID-8: /dev/sdc2 maj-min: 8:34 size: 100.18 GiB fs: ext4 label: Backup
uuid: ff56fbe9-6e09-4569-8fa8-8b97d1c923f1
ID-9: /dev/sdc3 maj-min: 8:35 size: 439.45 GiB fs: ext4
label: manjaro-gnome uuid: ba16c9d4-46e2-475f-acfb-453275b5b42a
ID-10: /dev/sdc4 maj-min: 8:36 size: 146.48 GiB fs: ext4 label: Testsys
uuid: afafb774-fda7-444d-b5f3-8ded4befe91c
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0020
Device-1: 1-1.5:3 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 2516:0042 class-ID: 0301
Device-2: 1-1.6:4 info: USB OPTICAL MOUSE type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.3:3 info: Genesys Logic USB 2.0 Card Reader
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 05e3:070e class-ID: 0806 serial: <filter>
System Temperatures: cpu: 42.0 C mobo: 34.0 C gpu: nvidia temp: 45 C
Fan Speeds (rpm): cpu: 1083 fan-1: 792 fan-3: 859 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.26
Processes: 296 Power: uptime: 56m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.08 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1908 pm: pacman pkgs: 1900 libs: 516 tools: pamac,yay pm: flatpak
pkgs: 8 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: yakuake inxi: 3.3.36
apart from that, the network widget looks weird:
but the network in system settings looks normal to me
any clues? I’m a litte desperate…
