Videos start freezing the system
I have this same problem.
inxi -zv8         ✔
  Kernel: 6.14.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=670ea355-e838-459e-8463-f5cecd84c8e4 rw quiet splash
    resume=UUID=3175c310-9581-48f4-8dff-bd2146e72e79 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.13.0
  Type: Desktop Mobo: ASRock model: X300M-STX serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: P2.10
    date: 11/21/2024
  System RAM: total: 16 GiB available: 13.51 GiB used: 3.11 GiB (23.0%)
  Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3200C20S4/8G serial: <filter>
  Info: model: AMD Ryzen 5 4600G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
    desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 2382 min/max: 400/4309 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2382 2: 2382 3: 2382
    4: 2382 5: 2382 6: 2382 7: 2382 8: 2382 9: 2382 10: 2382 11: 2382 12: 2382
    bogomips: 88633
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: DP-2,HDMI-A-1 empty: DP-1 bus-ID: 04:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 35.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
    display-ID: 0
  Monitor-1: DP-2 pos: primary,left model: Dell U2212HM serial: <filter>
    built: 2013 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 103 gamma: 1.2
    chroma: red: x: 0.639 y: 0.329 green: x: 0.306 y: 0.627 blue: x: 0.153
    y: 0.071 white: x: 0.314 y: 0.329 size: 475x267mm (18.7x10.51")
    diag: 545mm (21.5") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 640x480,
    720x400
  Monitor-2: HDMI-A-1 pos: right model: Lenovo C24-25 serial: <filter>
    built: 2021 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2
    chroma: red: x: 0.659 y: 0.329 green: x: 0.318 y: 0.616 blue: x: 0.149
    y: 0.082 white: x: 0.314 y: 0.329 size: 527x296mm (20.75x11.65")
    diag: 604mm (23.8") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
    renoir ACO DRM 3.61 6.14.6-1-MANJARO) device-ID: 1002:1636
    memory: 1.95 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 5 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.0.5-arch1.1
    device-ID: 1002:1636 surfaces: xcb,xlib,wayland
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top,radeontop
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.14.6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.1:3
    chip-ID: 8087:0aa7 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 704.25 GiB used: 194.99 GiB (27.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA G2 SSD
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFA17.1 temp: 46.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT128MX100SSD1
    size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: MU01 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT128MX100SSD1
    tech: SSD serial: <filter> fw-rev: MU01 scheme: GPT
  ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%)
    used: 87.95 GiB (19.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 670ea355-e838-459e-8463-f5cecd84c8e4
    used: 31.3 MiB (10.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 056C-54FA
  ID-3: /mnt/rpi raw-size: N/A size: 56.09 GiB used: 10.25 GiB (18.3%)
    fs: cifs dev: /dev/sdcard
  ID-4: /mnt/storage raw-size: 119.24 GiB size: 116.81 GiB (97.96%)
    used: 107.01 GiB (91.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Storage
    uuid: 08a4ec53-0c09-4a63-b729-10652bc222f4
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 3175c310-9581-48f4-8dff-bd2146e72e79
  ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sdb2 maj-min: 8:18 size: 118.59 GiB fs: ntfs label: N/A
    uuid: 505EB0615EB04210
  ID-3: /dev/sdb3 maj-min: 8:19 size: 645 MiB fs: ntfs label: N/A
    uuid: 92B480C0B480A7F5
  Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-2.1:3 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
  Device-2: 3-2.2:4 info: Shenzhen Rapoo 2.4G Wireless Device
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 24ae:2013 class-ID: 0301
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 41.5 C mobo: N/A gpu: amdgpu temp: 37.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1257 libs: 328 tools: pamac,yay
    1: https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
    2: https://mirror.futureweb.be/manjaro/testing/$repo/$arch
    3: https://mirror.vinehost.net/manjaro/testing/$repo/$arch
    4: https://mirror.hostiko.network/manjaro/testing/$repo/$arch
    5: https://ask4.mm.fcix.net/manjaro/testing/$repo/$arch
    6: https://mirror.leitecastro.com/manjaro/testing/$repo/$arch
    7: https://quantum-mirror.hu/mirrors/pub/manjaro/testing/$repo/$arch
    8: https://mirror.truenetwork.ru/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 362
  1: cpu: 16.2% command: firefox pid: 2382 mem: 450.7 MiB (3.2%)
  2: cpu: 7.1% command: jamesdsp pid: 1452 mem: 144.6 MiB (1.0%)
  3: cpu: 6.2% command: firefox pid: 2680 mem: 291.6 MiB (2.1%)
  4: cpu: 5.4% command: kwin_wayland pid: 819 mem: 215.6 MiB (1.5%)
  5: cpu: 4.0% command: WhatsApp pid: 2434 mem: 257.7 MiB (1.8%)
  Memory top: 5 of 362
  1: mem: 450.7 MiB (3.2%) command: firefox pid: 2382 cpu: 16.2%
  2: mem: 380.5 MiB (2.7%) command: plasmashell pid: 1075 cpu: 1.7%
  3: mem: 291.6 MiB (2.1%) command: firefox pid: 2680 cpu: 6.2%
  4: mem: 289.1 MiB (2.0%) command: firefox pid: 2629 cpu: 2.4%
  5: mem: 267.2 MiB (1.9%) command: dropbox pid: 1448 cpu: 1.5%
  Processes: 362 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
    image: 5.38 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
mhwd -li         ✔
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
mhwd -l         ✔
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2023.09.12                true            PCI
> 0000:04:00.0 (0300:1002:1636) Display controller ATI Technologies Inc:
Your post has been moved to a dedicated topic.
Please explain your problem with as much detail as possible, and when finished, please also rename this topic’s title to reflect your issue.
Note that posting your issue in another member’s Support topic is discouraged - it’s often referred to as hijacking. Also, saying that you have “the same problem” tends to be subjective.
To maximise your chance of receiving help from others, always create your own topic, so others can assist you directly.
I’m sure someone will help when they are able.
Well basically always after turn off screen (with power management) the videos start freezing the system. Usually that freeze lasts about a minute. Then it is quite random if that freezing continues after small delay (maybe 1 second) or the freezing stops with that video. It might be possible that other video starts that same freezing effect or not. If I am having eg. music in the backround that continues normally, but ALL visible things in the screens just freezes totally.
Mouse pointer does not move etc…
Mod edit:- The topic title has been renamed based on your description.
It’s worth having a Terminal window open monitoring RAM and swap usage; e.g.:
watch -n30 free -h
… in case it is an issue here.
See Post 5 in the thread this is linked from for more detail in case you missed it.
