Video resolution issues following yesterday's upgrade
OS: Manjaro Linux x86_64
Host: X570M Pro4
Kernel: Linux 7.0.3-1-MANJARO
Uptime: 46 seconds
Packages: 1754 (pacman) [stable]
Shell: zsh 5.9
!!!!! Display (NVD0000): 640x480 @ 1.25x, 60 Hz [External]
DE: KDE Plasma 6.6.4
WM: KWin (X11)
WM Theme: Breeze
Theme: Breeze (BreathDark) [Qt], Breeze-Dark [GTK2], Breeze [G]
Icons: breeze [Qt], breeze [GTK2/3/4]
Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
Cursor: breeze (24px)
Terminal: konsole 26.4.0
Terminal Font: Hack Nerd Font Mono (11pt)
CPU: AMD Ryzen 5 3600 (12) @ 4.21 GHz
GPU: NVIDIA GeForce GTX 1650 [Discrete]
Memory: 2.56 GiB / 15.54 GiB (16%)
Swap: Disabled
Disk (/): 268.31 GiB / 492.32 GiB (55%) - btrfs
Disk (/home): 60.51 GiB / 95.56 GiB (63%) - ext4
Disk (/home/francesco/DATA): 698.89 GiB / 1.82 TiB (38%) - fusk
Disk (/home/francesco/Sabrent): 335.79 GiB / 465.76 GiB (72%)
Local IP (enp4s0):
Locale: it_IT.UTF-8
Monitor: Asus OLED 26.5" XG27AQDMG
Previous resolution: 2560 x 1440
The PC is set up in dual boot with Windows 11 (Secure Boot enabled), and the boot manager is rEFInd. I am using refind-btrfs, so I have the option to roll back to the system state prior to yesterday’s upgrade by loading a snapshot (not yet tested).
I was using the latest available kernel, but kernel 6.18 had not been removed, even though it was not in use. The NVIDIA GPU was previously running with the open driver, without DKMS.
After the upgrade, immediately after the rEFInd menu (which appears normal), when selecting Manjaro, the login screen already shows a resolution of 640x480, and it remains the same once the desktop loads.
Audio also seems to be affected, but I would like to fix the video resolution first, as in this state it is impossible to work. The issue occurs both with X11 and Wayland.
Can you help me?
Please provide the output of:
inxi --filter --verbosity=8
inxi -zv8
Running `inxi` in `chroot`
Providing `inxi` when you cannot access your desktop environment
Note that any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions: :point_down:
[MiniHowTo] Present code or command output
  • for example, typing: `code here` will display the text as code here.
What is a Quark?
I can use the desktop for simple tasks without using ‘chroot’. The output of
inxi -zv8
Is
  Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: root=PARTUUID=27b5d630-c73e-4124-819a-27772127130a rw
    rootflags=subvol=@ udev.log_priority=3
    initrd=@\boot\initramfs-7.0-x86_64.img
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
  Type: Desktop Mobo: ASRock model: X570M Pro4 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends
    v: P5.50 date: 10/17/2023
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  System RAM: total: 16 GiB available: 15.54 GiB used: 2.11 GiB (13.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2B3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 1724 min/max: 558/4208 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1724 2: 1724 3: 1724
    4: 1724 5: 1724 6: 1724 7: 1724 8: 1724 9: 1724 10: 1724 11: 1724 12: 1724
    bogomips: 86240
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: ASUSTeK driver: nvidia
    v: 595.71.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-1
    empty: DVI-D-1,HDMI-A-1 bus-ID: 09:00.0 chip-ID: 10de:1f82 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.22 with: Xwayland v: 24.1.11
    compositor: kwin_x11 driver: X: loaded: nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa gpu: nv_platform,nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 640x480 s-dpi: 75 s-size: 217x163mm (8.54x6.42")
    s-diag: 271mm (10.69")
  Monitor-1: DP-1 mapped: DP-0 note: disabled model: Nvidia built: 1990 res:
    mode: 640x480 hz: 60 scale: 100% (1) gamma: 1.2 chroma: red: x: 0.329
    y: 0.298 green: x: 0.600 y: 0.149 blue: x: 0.059 y: 0.314 white: x: 0.329
    y: 0 size: N/A modes: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 595.71.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.4.341 layers: 4 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 driver: nvidia v: 595.71.05
    device-ID: 10de:1f82 surfaces: N/A
  Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:10fa
    class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k7.0.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
  Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Local Storage: total: 4.09 TiB used: 1.6 TiB (39.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 32.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.2 temp: 32.9 C
    scheme: MBR
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
  ID-1: / raw-size: 492.32 GiB size: 492.32 GiB (100.00%)
    used: 267.8 GiB (54.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:7
    label: MYVOL uuid: 9e061b12-f290-4137-986b-6d5d803427da
  ID-2: /boot/efi raw-size: 2.68 GiB size: 96 MiB (3.49%)
    used: 91.2 MiB (95.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
    label: N/A uuid: 16DE-B966
  ID-3: /home raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
    used: 60.51 GiB (63.3%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:8
    label: N/A uuid: 78c272bf-202c-4264-90d1-1f8373a394e9
  ID-4: /home/<filter>/DATA raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 698.89 GiB (37.5%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: DATA
    uuid: 01D4BEC452A4DA70
  ID-5: /home/<filter>/Sabrent raw-size: 465.76 GiB
    size: 465.76 GiB (100.00%) used: 335.79 GiB (72.1%) fs: ntfs
    dev: /dev/nvme1n1p1 maj-min: 259:1 label: Sabrent uuid: 0757D4537B3131FF
  ID-6: /home/<filter>/drop1 raw-size: N/A size: 2.75 GiB
    used: 858 MiB (30.5%) fs: fuse.rclone remote: drop:
  ID-7: /home/<filter>/hetzner raw-size: N/A size: 1023.73 GiB
    used: 157.02 GiB (15.3%) fs: cifs dev: /dev/backup
  ID-8: /home/<filter>/kdrive raw-size: N/A size: 3 TiB used: 280 GiB (9.1%)
    fs: fuse remote: https://1478324.connect.kdrive.infomaniak.com
  ID-9: /home/<filter>/manzinilinux1 raw-size: N/A size: 15 GiB
    used: 2.94 GiB (19.6%) fs: fuse.rclone remote: manzinilinux:
  ID-10: /var/cache raw-size: 492.32 GiB size: 492.32 GiB (100.00%)
  ID-11: /var/log raw-size: 492.32 GiB size: 492.32 GiB (100.00%)
  ID-1: /dev/nvme0n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:5 size: 1.24 TiB fs: ntfs label: N/A
    uuid: E25EDFDA5EDFA597
  ID-3: /dev/nvme0n1p4 maj-min: 259:6 size: 780 MiB fs: ntfs label: N/A
    uuid: 3C7666B176666B98
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-1:2 info: American Power Conversion Uninterruptible Supply
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 2mA
    chip-ID: 051d:0002 class-ID: 0300 serial: <filter>
  Hub-4: 3-2:3 info: ASUSTek USB2.1 Hub ports: 3 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0b05:1ba7
  Device-1: 3-2.3:5 info: ASUSTek ROG Gaming Display Aura Device type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1ba3 class-ID: 0300
    serial: <filter>
  Device-2: 3-3:4 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-2:2 info: ASUSTek USB3.2 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0b05:0ba7
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 34.6 C mobo: N/A gpu: nvidia temp: 30 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 27%
  Packages: pm: pacman pkgs: 1754 libs: 433 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    4: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    5: https://mirror.23m.com/manjaro/stable/$repo/$arch
    6: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    7: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    8: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 369
  1: cpu: 6.0% command: baloo_file pid: 1145 mem: 538.2 MiB (3.3%)
  2: cpu: 2.7% command: plasmashell pid: 1234 mem: 378.1 MiB (2.3%)
  3: cpu: 2.4% command: Xorg pid: 839 mem: 90.1 MiB (0.5%)
  4: cpu: 2.1% command: flatpak-system-helper pid: 1692 mem: 23.0 MiB (0.1%)
  5: cpu: 1.8% command: konsole pid: 2359 mem: 139.1 MiB (0.8%)
  Memory top: 5 of 369
  1: mem: 538.2 MiB (3.3%) command: baloo_file pid: 1145 cpu: 6.0%
  2: mem: 378.1 MiB (2.3%) command: plasmashell pid: 1234 cpu: 2.7%
  3: mem: 200.7 MiB (1.2%) command: kwin_x11 pid: 1190 cpu: 1.4%
  4: mem: 147.4 MiB (0.9%) command: clamav-gui pid: 1416 cpu: 0.6%
  5: mem: 145.7 MiB (0.9%) command: kded6 pid: 1189 cpu: 0.3%
  Processes: 369 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.9 running-in: konsole inxi: 3.3.40
I’ve had a possibly related issue where my laptop with an NVIDIA gpu wouldn’t recognize an external monitor after this update. I tried switching from video-nvidia-580xx to video-hybrid-intel-nvidia-580xx-prime drivers, which made things worse: Now the built-in laptop screen remained black, too. After rebooting with the older installed linux kernel, I installed video-nvidia-580xx again, and rebooting into linux kernel 7 now seems fine and my external monitor appears to work again.
All this to say, maybe it’s worth trying re-installing your nvidia drivers (e.g. through Manjaro Settings Manager)?
There’s some news. I connected a much older 1920x1080 monitor—the one I’m using now is an OLED with a higher resolution—and the desktop is back to normal.
The system specifications are now:
  System RAM: total: 16 GiB available: 15.54 GiB used: 3.52 GiB (22.6%)
  Speed (MHz): avg: 3595 min/max: 558/4208 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3595 2: 3595 3: 3595
    4: 3595 5: 3595 6: 3595 7: 3595 8: 3595 9: 3595 10: 3595 11: 3595 12: 3595
    bogomips: 86236
    xtopology
    protection
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DVI-D-1
    empty: DP-1,HDMI-A-1 bus-ID: 09:00.0 chip-ID: 10de:1f82 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: DVI-D-1 model: Asus VS248 serial: <filter> built: 2014 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2 chroma: red:
    x: 0.651 y: 0.333 green: x: 0.333 y: 0.624 blue: x: 0.157 y: 0.051 white:
    x: 0.314 y: 0.329 size: 531x299mm (20.91x11.77") diag: 609mm (24")
    ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x960, 1366x768, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
    memory: 3.91 GiB display-ID: :1.0
    class-ID: 0403
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 34.9 C
    scheme: GPT
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.2 temp: 37.9 C
    scheme: MBR
    used: 267.7 GiB (54.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:7
    used: 60.5 GiB (63.3%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:8
    used: 858.3 MiB (30.5%) fs: fuse.rclone remote: drop:
  Device-1: 3-3:4 info: Logitech Nano Receiver type: keyboard,mouse
  System Temperatures: cpu: 40.4 C mobo: N/A
    pkgs: 0
Processes:
  CPU top: 5 of 353
  1: cpu: 10.8% command: firefox pid: 2320 mem: 116.9 MiB (0.7%)
  2: cpu: 9.9% command: firefox pid: 2659 mem: 320.2 MiB (2.0%)
  3: cpu: 7.4% command: firefox pid: 2205 mem: 718.8 MiB (4.5%)
  4: cpu: 3.1% command: kwin_wayland pid: 1111 mem: 224.0 MiB (1.4%)
  5: cpu: 2.6% command: baloo_file pid: 1110 mem: 549.9 MiB (3.4%)
  Memory top: 5 of 353
  1: mem: 718.8 MiB (4.5%) command: firefox pid: 2205 cpu: 7.4%
  2: mem: 549.9 MiB (3.4%) command: baloo_file pid: 1110 cpu: 2.6%
  3: mem: 532.2 MiB (3.3%) command: firefox pid: 2923 cpu: 1.2%
  4: mem: 381.1 MiB (2.3%) command: plasmashell pid: 1298 cpu: 0.8%
  5: mem: 321.6 MiB (2.0%) command: konsole pid: 3445 cpu: 2.3%
  Processes: 353 Power: uptime: 9m states: freeze,mem,disk suspend: deep
    tool: systemctl
It works on both X11 and Wayland.
What do you think?
