Video issue : Intel Arc Graphics 130V / 140V
Lucky owner of a LENOVO ThinkPad X1 Carbon Gen 13, I’m having a big problem with the display, while all the rest of the hardware is correctly handled.
In other words, instead of running at 120Hz, glxgears gives me 6/7 fps maximized window.
Where it becomes incomprehensible is that as soon as I connect an external monitor via hdmi, the display frequency correctly switches to 120Hz on the built-in screen and 60Hz on the external monitor. And it works so well that if I move the glxgears window from one screen to the other, the display frequency in glxgears automatically adapts with no side effects.
But also, without plugging in an external screen, sometimes (rare), the frequency ends up back at 120Hz. But never as soon as you log on, only after a few iterations of glxgears.
This randomness leaves me speechless…
I’ve tried every type of logon, every combination of cold start or reboot, and no logic…
The only thing that will restore the frequency to 120Hz is plugging in an external monitor.
On the downside, once the frequency has stabilized at 120Hz, there are lags at more or less regular intervals that can be felt in the movement of the mouse cursor.
You can understand my distress: as it stands, this computer is unusable, unless I carry around an external screen (LoL), which would cancel out the benefits of a machine weighing 989 grams.
Computer:      LENOVO ThinkPad X1 Carbon Gen 13
CPU:           Intel Core Ultra 7 258V (Lunar Lake, B0)
               3300 MHz (33.00x100.0) @ 1700 MHz (17.00x100.0)
Motherboard:   LENOVO 21NS000YFR
BIOS:          N4BET34W (1.06 ), 10/21/2024
Chipset:
Memory:        32768 MBytes @ 1200 MHz, 92-80-80-180
Graphics:      Intel Lunar Lake - Integrated Graphics [Lenovo]
               Intel Arc 140V, 2097148 KB
Graphics:      Intel Lunar Lake - Neural Processing Unit (NPU) [Lenovo]
               Intel NPU4, 0 MB
Drive:         SKHynix_HFS001TFM9X179N, 1000.2 GB, NVMe
Sound:         Intel Lunar Lake SOC - cAVS (Audio, Voice, Speech)
Network:       Intel Wi-Fi 7 BE201 320MHz
OS:            Microsoft Windows 11 Professional (x64) Build 26100.2161 (24H2)
inxi -GAC
  Info: 8-core model: Intel Core Ultra 7 258V bits: 64 type: MCP cache: 12 MiB
    note: check
  Speed (MHz): avg: 400 min/max: 400/4700:4800:3700 cores: 1: 400 2: 400
    3: 400 4: 400 5: 400 6: 400 7: 400 8: 400
  Device-1: Intel Lunar Lake [Intel Arc Graphics 130V / 140V] driver: xe
    v: kernel
  Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
  Device-3: Logic3 / SpectraVideo plc LG Optical Mouse 3D-310
    driver: hid-generic,usbhid type: USB
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell v: 47.2 driver: X: loaded: modesetting dri: iris
    gpu: xe resolution: 2880x1800~120Hz
  API: EGL v: 1.5 drivers: iris,swrast
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    renderer: Mesa Intel Graphics (LNL)
  Device-1: Intel Lunar Lake-M HD Audio driver: sof-audio-pci-intel-lnl
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.2.7 status: active
lshw
computer-laptop
    description: Ordinateur Bloc-notes
    produit: 21NS000YFR (LENOVO_MT_21NS_BU_Think_FM_ThinkPad X1 Carbon Gen 13)
    fabriquant: LENOVO
    version: ThinkPad X1 Carbon Gen 13
    numéro de série: PF5DALXH
    bits: 64 bits
    fonctionnalités: smbios-3.8.0 dmi-3.8.0 smp vsyscall32
    configuration: administrator_password=disabled chassis=notebook family=ThinkPad X1 Carbon Gen 13 power-on_password=disabled sku=LENOVO_MT_21NS_BU_Think_FM_ThinkPad X1 Carbon Gen 13 uuid=bebb71ab-4441-410a-8607-c4efbbcacfd0
  *-core
       description: Carte mère
       produit: 21NS000YFR
       fabriquant: LENOVO
       identifiant matériel: 0
       version: SDK0T76576 WIN
       numéro de série: L1HF4BT01MY
       emplacement: Not Available
     *-memory
          description: Mémoire Système
          identifiant matériel: 2
          emplacement: Carte mère
          taille: 32GiB
        *-bank:0
             description: Série de composants Synchrone 8533 MHz (0,1 ns)
             fabriquant: Micron Technology
             numéro de série: 20000000
             emplacement: Controller0-ChannelA
             taille: 4GiB
             bits: 16 bits
             horloge: 4238MHz (0.2ns)
        *-bank:1
             identifiant matériel: 1
             emplacement: Controller0-ChannelB
             taille: 4GiB
             bits: 16 bits
        *-bank:2
             emplacement: Controller0-ChannelC
             taille: 4GiB
             bits: 16 bits
        *-bank:3
             identifiant matériel: 3
             emplacement: Controller0-ChannelD
             taille: 4GiB
             bits: 16 bits
        *-bank:4
             identifiant matériel: 4
             emplacement: Controller1-ChannelA
             taille: 4GiB
             bits: 16 bits
        *-bank:5
             identifiant matériel: 5
             emplacement: Controller1-ChannelB
             taille: 4GiB
             bits: 16 bits
        *-bank:6
             identifiant matériel: 6
             emplacement: Controller1-ChannelC
             taille: 4GiB
             bits: 16 bits
        *-bank:7
             identifiant matériel: 7
             emplacement: Controller1-ChannelD
             taille: 4GiB
             bits: 16 bits
     *-cache:0
          description: L1 cache
          identifiant matériel: 13
          emplacement: L1 Cache
          taille: 192KiB
          capacité: 192KiB
          fonctionnalités: synchronous internal write-back data
          configuration: level=1
     *-cache:1
          identifiant matériel: 14
          taille: 256KiB
          capacité: 256KiB
          fonctionnalités: synchronous internal write-back instruction
     *-cache:2
          description: L2 cache
          identifiant matériel: 15
          emplacement: L2 Cache
          taille: 10MiB
          capacité: 10MiB
          fonctionnalités: synchronous internal write-back unified
          configuration: level=2
     *-cache:3
          description: L3 cache
          identifiant matériel: 16
          emplacement: L3 Cache
          taille: 12MiB
          capacité: 12MiB
          configuration: level=3
     *-cache:4
          identifiant matériel: 17
          taille: 128KiB
          capacité: 128KiB
     *-cache:5
          identifiant matériel: 18
          taille: 256KiB
          capacité: 256KiB
     *-cache:6
          identifiant matériel: 19
          taille: 4MiB
          capacité: 4MiB
     *-cpu
          description: CPU
          produit: Intel(R) Core(TM) Ultra 7 258V
          fabriquant: Intel Corp.
          identifiant matériel: 1a
          information bus: cpu@0
          version: 6.189.1
          numéro de série: None
          emplacement: U3E1
          taille: 884MHz
          capacité: 4700MHz
          bits: 64 bits
          horloge: 100MHz
          fonctionnalités: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdt_a rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect user_shstk avx_vnni lam wbnoinvd dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi vnmi umip pku ospke waitpkg gfni vaes vpclmulqdq rdpid bus_lock_detect movdiri movdir64b fsrm md_clear serialize pconfig arch_lbr ibt flush_l1d arch_capabilities intel_ppin cpufreq
          configuration: cores=8 enabledcores=8 microcode=278 threads=8
     *-firmware
          description: BIOS
          fabriquant: LENOVO
          identifiant matériel: 1b
          version: N4BET34W (1.06 )
          date: 10/21/2024
          taille: 128KiB
          capacité: 32MiB
          fonctionnalités: pci pnp upgrade shadowing cdboot bootselect edd int13floppy720 int5printscreen int9keyboard int14serial int17printer int10video acpi usb biosbootspecification uefi
     *-pci
          description: Host bridge
          produit: Intel Corporation
          fabriquant: Intel Corporation
          identifiant matériel: 100
          information bus: pci@0000:00:00.0
          version: 04
          bits: 32 bits
          horloge: 33MHz
        *-display
             description: VGA compatible controller
             produit: Lunar Lake [Intel Arc Graphics 130V / 140V]
             information bus: pci@0000:00:02.0
             nom logique: /dev/fb0
             version: 04
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pciexpress msi pm vga_controller bus_master cap_list rom fb
             configuration: depth=32 driver=xe latency=0 mode=2880x1800 resolution=2880,1800 visual=truecolor xres=2880 yres=1800
             ressources: mémoireE/S:200-1ff mémoireE/S:200-1ff irq:149 mémoire:204e000000-204effffff mémoire:2000000000-200fffffff mémoire:c0000-dffff
        *-generic:0
             description: Signal processing controller
             information bus: pci@0000:00:04.0
             version: 04
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: msi pm bus_master cap_list
             configuration: driver=proc_thermal_pci latency=0
             ressources: mémoireE/S:200-1ff irq:194 mémoire:204fd00000-204fd1ffff
        *-pci:0
             description: PCI bridge
             produit: Lunar Lake-M Thunderbolt 4 PCI Express Root Port #0
             information bus: pci@0000:00:07.0
             version: 10
             bits: 32 bits
             horloge: 33MHz
             fonctionnalités: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             ressources: irq:120 portE/S:2000(taille=4096) mémoire:b0000000-bc1fffff portE/S:2010000000(taille=469762048)
        *-pci:1
             produit: Lunar Lake-M Thunderbolt 4 PCI Express Root Port #2
             identifiant matériel: 7.2
             information bus: pci@0000:00:07.2
             version: 10
             bits: 32 bits
             horloge: 33MHz
             ressources: irq:121 portE/S:3000(taille=4096) mémoire:a2000000-ae1fffff portE/S:2030000000(taille=469762048)
        *-generic:1
             identifiant matériel: a
             information bus: pci@0000:00:0a.0
             version: 04
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pciexpress msi pm cap_list
             configuration: driver=intel_vsec latency=0
             ressources: mémoireE/S:200-1ff irq:0 mémoire:204fd40000-204fd4ffff
        *-generic:2 NON-RÉCLAMÉ
             description: Processing accelerators
             produit: Lunar Lake NPU
             identifiant matériel: b
             information bus: pci@0000:00:0b.0
             version: 04
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi pciexpress cap_list
             configuration: latency=0
             ressources: mémoireE/S:200-1ff mémoireE/S:200-1ff mémoire:204c000000-204dffffff mémoire:204fd68000-204fd68fff
        *-usb:0
             description: USB controller
             produit: Lunar Lake-M Thunderbolt 4 USB Controller
             identifiant matériel: d
             information bus: pci@0000:00:0d.0
             version: 10
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             ressources: mémoireE/S:200-1ff irq:124 mémoire:204fd30000-204fd3ffff
           *-usbhost:0
                produit: xHCI Host Controller
                fabriquant: Linux 6.12.4-1-MANJARO xhci-hcd
                information bus: usb@1
                nom logique: usb1
                version: 6.12
                fonctionnalités: usb-2.00
                configuration: driver=hub slots=1 speed=480Mbit/s
           *-usbhost:1
                information bus: usb@2
                nom logique: usb2
                version: 6.12
                fonctionnalités: usb-3.10
                configuration: driver=hub slots=3 speed=10000Mbit/s
        *-usb:1
             produit: Lunar Lake-M Thunderbolt 4 NHI #0
             identifiant matériel: d.2
             information bus: pci@0000:00:0d.2
             version: 10
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi msix usb4_host_interface bus_master cap_list
             configuration: driver=thunderbolt latency=0
             ressources: mémoireE/S:200-1ff mémoireE/S:200-1ff irq:16 mémoire:204fcc0000-204fcfffff mémoire:204fd67000-204fd67fff
        *-usb:2
             produit: Lunar Lake-M Thunderbolt 4 NHI #1
             identifiant matériel: d.3
             information bus: pci@0000:00:0d.3
             version: 10
             bits: 64 bits
             horloge: 33MHz
             ressources: mémoireE/S:200-1ff mémoireE/S:200-1ff irq:16 mémoire:204fc80000-204fcbffff mémoire:204fd66000-204fd66fff
        *-communication:0 NON-RÉCLAMÉ
             description: Communication controller
             information bus: pci@0000:00:13.0
             version: 10
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi cap_list
             ressources: mémoireE/S:200-1ff mémoire:204fd65000-204fd65fff
        *-usb:3
             produit: Lunar Lake-M USB 3.2 Gen 2x1 xHCI Host Controller
             information bus: pci@0000:00:14.0
             version: 10
             bits: 64 bits
             horloge: 33MHz
             ressources: mémoireE/S:200-1ff irq:132 mémoire:204fd20000-204fd2ffff
           *-usbhost:0
                information bus: usb@3
                nom logique: usb3
                version: 6.12
                configuration: driver=hub slots=8 speed=480Mbit/s
              *-usb:0
                   description: Vidéo
                   produit: Integrated Camera
                   fabriquant: 8SSC21K64613V1SR48S10PL
                   information bus: usb@3:4
                   version: 10.18
                   numéro de série: 0001
                   fonctionnalités: usb-2.01
                   configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
              *-usb:1
                   description: USB hub
                   produit: USB2.0 Hub
                   fabriquant: Genesys Logic, Inc.
                   information bus: usb@3:5
                   version: 60.60
                   configuration: driver=hub maxpower=100mA slots=3 speed=480Mbit/s
                 *-usb NON-RÉCLAMÉ
                      description: Périphérique USB générique
                      produit: Goodix USB2.0 MISC
                      fabriquant: Goodix Technology Co., Ltd.
                      information bus: usb@3:5.3
                      version: 1.00
                      numéro de série: UID24B392BE_XXXX_MOC_B0
                      configuration: maxpower=100mA speed=12Mbit/s
              *-usb:2
                   description: Souris
                   produit: PS/2+USB Mouse
                   fabriquant: Logic3 / SpectraVideo plc
                   information bus: usb@3:6
                   nom logique: input20
                   nom logique: /dev/input/event15
                   nom logique: /dev/input/mouse3
                   version: 22.70
                   fonctionnalités: usb-1.10 usb
                   configuration: driver=usbhid maxpower=100mA speed=1Mbit/s
           *-usbhost:1
                information bus: usb@4
                nom logique: usb4
                version: 6.12
                configuration: driver=hub slots=2 speed=10000Mbit/s
        *-memory NON-RÉCLAMÉ
             description: RAM memory
             identifiant matériel: 14.2
             information bus: pci@0000:00:14.2
             version: 10
             bits: 64 bits
             horloge: 33MHz (30.3ns)
             fonctionnalités: pm cap_list
             ressources: mémoireE/S:200-1ff mémoireE/S:200-1ff mémoire:204fd50000-204fd57fff mémoire:204fd64000-204fd64fff
        *-network
             description: Ethernet interface
             identifiant matériel: 14.3
             information bus: pci@0000:00:14.3
             nom logique: wlp0s20f3
             version: 10
             numéro de série: 88:f4:da:d7:66:c6
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi pciexpress msix bus_master cap_list ethernet physical
             configuration: broadcast=yes driver=iwlwifi driverversion=6.12.4-1-MANJARO firmware=92.67ce4588.0 bz-b0-fm-c0-92.uc ip=192.168.1.126 latency=0 link=yes multicast=yes
             ressources: mémoireE/S:200-1ff irq:18 mémoire:204fd5c000-204fd5ffff
        *-generic:3
             description: Bluetooth
             identifiant matériel: 14.7
             information bus: pci@0000:00:14.7
             version: 10
             bits: 64 bits
             horloge: 33MHz
             configuration: driver=btintel_pcie latency=0
             ressources: mémoireE/S:200-1ff irq:19 mémoire:204fd58000-204fd5bfff
        *-serial:0
             description: Serial bus controller
             produit: Lunar Lake-M Serial IO I2C Controller #0
             information bus: pci@0000:00:15.0
             version: 10
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm bus_master cap_list
             configuration: driver=intel-lpss latency=0
             ressources: mémoireE/S:200-1ff irq:27 mémoire:202c000000-202c000fff
        *-serial:1
             produit: Lunar Lake-M Serial IO I2C Controller #3
             identifiant matériel: 15.3
             information bus: pci@0000:00:15.3
             version: 10
             bits: 64 bits
             horloge: 33MHz
             ressources: irq:30 mémoire:202c001000-202c001fff
        *-communication:1
             information bus: pci@0000:00:16.0
             version: 10
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi bus_master cap_list
             configuration: driver=mei_me latency=0
             ressources: mémoireE/S:200-1ff irq:166 mémoire:204fd61000-204fd61fff
        *-pci:2
             produit: Lunar Lake-M PCI Express Root Port #1
             identifiant matériel: 1c
             information bus: pci@0000:00:1c.0
             version: 10
             bits: 32 bits
             horloge: 33MHz
             fonctionnalités: pci pciexpress msi normal_decode bus_master cap_list
             ressources: irq:122 portE/S:4000(taille=4096) mémoire:bc500000-bcefffff portE/S:204f200000(taille=10485760)
        *-pci:3
             produit: Lunar Lake-M PCI Express Root Port #5
             identifiant matériel: 1c.4
             information bus: pci@0000:00:1c.4
             version: 10
             bits: 32 bits
             horloge: 33MHz
             ressources: irq:123 mémoire:bc400000-bc4fffff
           *-nvme
                description: NVMe device
                produit: SKHynix_HFS001TFM9X179N
                fabriquant: SK hynix
                information bus: pci@0000:04:00.0
                nom logique: /dev/nvme0
                version: 61710A20
                numéro de série: BSDBN41021120B46F
                bits: 64 bits
                horloge: 33MHz
                fonctionnalités: nvme pm msi msix pciexpress nvm_express bus_master cap_list
                configuration: driver=nvme latency=0 nqn=nqn.2024-11.com.skhynix:nvme:nvm-subsystem-sn-BSDBN41021120B46F state=live
                ressources: irq:16 mémoire:bc400000-bc403fff
              *-namespace:0
                   description: NVMe disk
                   nom logique: hwmon3
              *-namespace:1
                   nom logique: /dev/ng0n1
              *-namespace:2
                   information bus: nvme@0:1
                   nom logique: /dev/nvme0n1
                   taille: 953GiB (1024GB)
                   fonctionnalités: gpt-1.00 partitioned partitioned:gpt
                   configuration: guid=bd472b94-0c51-4c83-9d78-0cd8bc48aab1 logicalsectorsize=512 sectorsize=512 wwid=eui.ace42e00457f07ee
                 *-volume:0 NON-RÉCLAMÉ
                      description: Windows FAT volume
                      fabriquant: mkfs.fat
                      information bus: nvme@0:1,1
                      version: FAT32
                      numéro de série: 2d49-f093
                      taille: 297MiB
                      capacité: 299MiB
                      fonctionnalités: boot fat initialized
                      configuration: FATs=2 filesystem=fat
                 *-volume:1
                      description: EXT4 volume
                      fabriquant: Linux
                      information bus: nvme@0:1,2
                      nom logique: /dev/nvme0n1p2
                      nom logique: /
                      version: 1.0
                      numéro de série: 9e9a5fbb-9508-44e7-a5a3-836879849d55
                      taille: 953GiB
                      capacité: 953GiB
                      fonctionnalités: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
                      configuration: created=2024-12-21 15:38:14 filesystem=ext4 lastmountpoint=/ modified=2025-01-06 12:40:19 mount.fstype=ext4 mount.options=rw,relatime,stripe=256 mounted=2025-01-06 12:40:19 name=root state=mounted
        *-isa
             description: ISA bridge
             identifiant matériel: 1f
             information bus: pci@0000:00:1f.0
             version: 10
             bits: 32 bits
             horloge: 33MHz
             fonctionnalités: isa bus_master
           *-pnp00:00
                produit: Motherboard registers
                fonctionnalités: pnp
                configuration: driver=system
           *-pnp00:01
                produit: PnP device LEN0071
                fabriquant: Lenovo Group Limited
                configuration: driver=i8042 kbd
           *-pnp00:02
                produit: PnP device LEN0327
                configuration: driver=i8042 aux
           *-pnp00:03
           *-pnp00:04
           *-pnp00:05
           *-pnp00:06
           *-pnp00:07
           *-pnp00:08
                produit: System Board
                identifiant matériel: 8
        *-multimedia
             description: Multimedia audio controller
             produit: Lunar Lake-M HD Audio Controller
             identifiant matériel: 1f.3
             information bus: pci@0000:00:1f.3
             nom logique: card0
             nom logique: /dev/snd/controlC0
             nom logique: /dev/snd/hwC0D2
             nom logique: /dev/snd/pcmC0D0p
             nom logique: /dev/snd/pcmC0D10c
             nom logique: /dev/snd/pcmC0D1c
             nom logique: /dev/snd/pcmC0D2p
             nom logique: /dev/snd/pcmC0D31p
             nom logique: /dev/snd/pcmC0D5p
             nom logique: /dev/snd/pcmC0D6p
             nom logique: /dev/snd/pcmC0D7p
             version: 10
             bits: 64 bits
             horloge: 33MHz
             configuration: driver=sof-audio-pci-intel-lnl latency=64
             ressources: mémoireE/S:200-1ff mémoireE/S:200-1ff irq:198 mémoire:204fc00000-204fc7ffff mémoire:204f000000-204f1fffff
        *-serial:2 NON-RÉCLAMÉ
             description: SMBus
             produit: Lunar Lake-M SMbus Controller
             identifiant matériel: 1f.4
             information bus: pci@0000:00:1f.4
             version: 10
             bits: 64 bits
             horloge: 33MHz
             ressources: mémoireE/S:200-1ff mémoire:204fd60000-204fd600ff portE/S:efa0(taille=32)
        *-serial:3
             produit: Lunar Lake-M SPI Controller
             identifiant matériel: 1f.5
             information bus: pci@0000:00:1f.5
             version: 10
             bits: 32 bits
             horloge: 33MHz
             configuration: driver=intel-spi latency=0
             ressources: irq:0 mémoire:a0800000-a0800fff
  *-battery
       produit: 5B11M90097
       fabriquant: SMP
       emplacement: Front
       capacité: 57030mWh
       configuration: voltage=11,7V
  *-input:0
       produit: Sleep Button
       nom logique: input0
       nom logique: /dev/input/event0
       fonctionnalités: platform
  *-input:1
       produit: Lid Switch
       nom logique: input1
  *-input:2
       produit: SNSL0028:00 2C2F:0028 Mouse
       nom logique: input13
       nom logique: /dev/input/event9
       nom logique: /dev/input/mouse1
       fonctionnalités: i2c
  *-input:3
       produit: SNSL0028:00 2C2F:0028 Touchpad
       nom logique: input14
       nom logique: /dev/input/event10
       nom logique: /dev/input/mouse2
  *-input:4
       produit: sof-soundwire Headset Jack
       nom logique: input16
       nom logique: /dev/input/event11
  *-input:5
       produit: sof-soundwire HDMI/DP,pcm=5
       nom logique: input17
       nom logique: /dev/input/event12
  *-input:6
       produit: sof-soundwire HDMI/DP,pcm=6
       nom logique: input18
       nom logique: /dev/input/event13
  *-input:7
       produit: sof-soundwire HDMI/DP,pcm=7
       identifiant matériel: 9
       nom logique: input19
       nom logique: /dev/input/event14
  *-input:8
       produit: Power Button
       nom logique: input2
       nom logique: /dev/input/event2
  *-input:9
       produit: ThinkPad Extra Buttons
       nom logique: input3
       nom logique: /dev/input/event3
  *-input:10
       produit: AT Translated Set 2 keyboard
       identifiant matériel: c
       nom logique: input4
       nom logique: /dev/input/event4
       nom logique: input4::capslock
       nom logique: input4::numlock
       nom logique: input4::scrolllock
       fonctionnalités: i8042
  *-input:11
       produit: Video Bus
       nom logique: input6
       nom logique: /dev/input/event5
  *-input:12
       produit: Intel HID events
       identifiant matériel: e
       nom logique: input7
       nom logique: /dev/input/event6
  *-input:13
       produit: PC Speaker
       identifiant matériel: f
       nom logique: input8
       nom logique: /dev/input/event7
  *-input:14
       produit: TPPS/2 Elan TrackPoint
       nom logique: input9
       nom logique: /dev/input/event8
       nom logique: /dev/input/mouse0
I forgot to specify: manjaro-gnome-24.2.1-241216-linux612
I’ve just discovered that as soon as the session is opened, forcing the PC into sleep mode and then waking it up by pressing a key causes the display to switch to 120Hz.
The mystery remains, but in the worst-case scenario, despite the intermittent lags still being there, it’s a solution that works.
So seems to be a dual-boot. Did you actually disable fast-startup on Windows and fastboot (or similiar) at the UEFI Settings? Drivers in Linux and Windows work differently. Windows saves the state of some sort in software level (especially fast-startup, what is “semi-hibernation”), while Linux always needs a full initialization. Without, you can assume problems, especially on dual-boot systems.
No dual-boot
Secure boot, fast boot and so on are disabled
Alrighty.
I think it could be VRR (formally CMRR), as you see here: https://www.phoronix.com/news/Intel-Graphics-CMRR-VRR
Your monitor must be capable to use VRR so that it gets enabled.
When you plug in another monitor, it seems to get disabled. It also seems that suspending can disable it.
I wonder if VRR is enabled on Gnome now by default? :thinking: I have no VRR monitor and not such a new GPU.
Here’s what happens when I log on, then sleep and wake up :
16:18:38 systemd: fprintd.service: Deactivated successfully.
16:18:33 gnome-logs: MESA-INTEL: warning: ../mesa-24.2.8/src/intel/vulkan/anv_formats.c:794: FINISHME: support more multi-planar formats with DRM modifiers
16:18:33 systemd: Started dbus-:1.2-org.gnome.Logs@0.service.
16:18:12 gnome-shell: libinput error: client bug: timer event11 keyboard: scheduled expiry is in the past (-66ms), your system is too slow
16:18:11 systemd: Started dbus-:1.2-org.gnome.DejaDup@0.service.
16:18:10 NetworkManager: <info>  [1736349490.5641] agent-manager: agent[ebebb7c7738a93f0,:1.81/org.gnome.Shell.NetworkAgent/1000]: agent registered
16:18:10 gnome-shell: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.Failed: Set global engine failed: L’opération a été annulée
Stack trace:
  _promisify/proto[asyncFunc]/</<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:453:45
  @resource:///org/gnome/shell/ui/init.js:21:20
  ### Promise created here: ###
  _setEngine@resource:///org/gnome/shell/misc/ibusManager.js:286:30
  setEngine@resource:///org/gnome/shell/misc/ibusManager.js:299:24
  activateInputSource@resource:///org/gnome/shell/ui/status/keyboard.js:523:27
  _callHandlers@resource:///org/gnome/gjs/modules/core/_signals.js:130:42
  _emit@resource:///org/gnome/gjs/modules/core/_signals.js:119:10
  activate@resource:///org/gnome/shell/ui/status/keyboard.js:66:14
  _inputSourcesChanged@resource:///org/gnome/shell/ui/status/keyboard.js:661:33
  reload@resource:///org/gnome/shell/ui/status/keyboard.js:394:14
  _ibusSetContentType@resource:///org/gnome/shell/ui/status/keyboard.js:736:14
  _setContentType@resource:///org/gnome/shell/misc/ibusManager.js:264:14
16:18:10 ModemManager: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
16:18:10 gdm-session-wor: gkr-pam: unlocked login keyring
16:18:08 NetworkManager: <info>  [1736349488.5127] policy: set 'Connexion filaire 1' (enp0s20f0u1) as default for IPv6 routing and DNS
16:18:08 systemd: NetworkManager-dispatcher.service: Deactivated successfully.
16:18:07 kernel: usb 3-5.3: reset full-speed USB device number 5 using xhci_hcd
16:18:06 NetworkManager: <info>  [1736349486.8291] manager: NetworkManager state is now CONNECTED_GLOBAL
16:18:06 systemd: Starting Fingerprint Authentication Daemon...
16:18:06 NetworkManager: <info>  [1736349486.7664] device (enp0s20f0u1): Activation: successful, device activated.
16:18:06 kernel: ax88179_178a 4-1:1.0 enp0s20f0u1: ax88179 - Link status is: 1
16:18:06 NetworkManager: <info>  [1736349486.5809] device (enp0s20f0u1): carrier: link connected
16:18:06 ModemManager: <msg> [sleep-monitor-systemd] system is resuming
16:18:06 NetworkManager: <info>  [1736349486.4205] device (enp0s20f0u1): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
16:18:06 systemd: Stopped target Suspend.
16:18:06 systemd-logind: Operation 'suspend' finished.
16:18:06 systemd: Reached target Suspend.
16:18:06 systemd-sleep: Successfully thawed unit 'user.slice'.
16:18:06 gnome-shell: libinput error: event2  - Power Button: client bug: event processing lagging behind by 3274ms, your system is too slow
16:18:06 bluetoothd: Controller resume with wake event 0x0
16:18:06 kernel: PM: suspend exit
16:18:06 systemd-sleep: System returned from sleep operation 'suspend'.
16:18:06 rtkit-daemon: Demoted 7 threads.
16:18:06 kernel: random: crng reseeded on system resumption
16:18:06 kernel: Restarting tasks ... done.
16:18:06 kernel: OOM killer enabled.
16:18:06 kernel: mei_gsc_proxy 0000:00:16.0-0f73db04-97ab-4125-b893-e904ad0d5464: bound 0000:00:02.0 (ops xe_gsc_proxy_component_ops [xe])
16:18:06 kernel: ---[ end trace 0000000000000000 ]---
16:18:06 kernel:  </TASK>
16:18:06 kernel: Call Trace:
16:18:06 kernel: PKRU: 55555554
16:18:06 kernel: DR3: 0000000000000000 DR6: 00000000ffff07f0 DR7: 0000000000000400
16:18:06 kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
16:18:06 kernel: CR2: 00007e7ef664a080 CR3: 00000006e6a22004 CR4: 0000000000f72ef0
16:18:06 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
16:18:06 kernel: FS:  0000000000000000(0000) GS:ffff9650ff900000(0000) knlGS:0000000000000000
16:18:06 kernel: R13: 0000000000000001 R14: 0000000000000001 R15: 0000000000000000
16:18:06 kernel: R10: ffffffffa52b54a8 R11: 0000000000000003 R12: ffff9649c639d450
16:18:06 kernel: RBP: fffffffffffffffb R08: 0000000000000000 R09: ffffaef440797ae8
16:18:06 kernel: RDX: ffff9650ff9218c8 RSI: 0000000000000001 RDI: ffff9650ff9218c0
16:18:06 kernel: RAX: 0000000000000000 RBX: ffff9649cfef8d28 RCX: 0000000000000027
16:18:06 kernel: RSP: 0018:ffffaef440797d28 EFLAGS: 00010282
16:18:06 kernel: Code: 08 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 73 f7 52 e3 49 89 e8 44 89 e9 4c 89 e2 48 89 c6 48 c7 c7 00 29 8c c0 e8 4b 42 c3 e2 <0f> 0b eb 9c 0f 1f 80 00 00 00 00 90 90 90 90 90 90 90 90 90 90 90
16:18:06 kernel: RIP: 0010:xe_guc_start+0x85/0x90 [xe]
16:18:06 kernel: Workqueue: async async_run_entry_fn
16:18:06 kernel: Hardware name: LENOVO 21NS000YFR/21NS000YFR, BIOS N4BET34W (1.06 ) 10/21/2024
16:18:06 kernel: CPU: 6 UID: 0 PID: 211 Comm: kworker/u34:3 Not tainted 6.12.4-1-MANJARO #1 c8946d09366a4632d0c132e3678c3062a6882fed
16:18:06 kernel:  crc32c_generic crc16 mbcache jbd2 hid_generic usbhid serio_raw atkbd xe libps2 nvme vivaldi_fmap drm_ttm_helper ttm i2c_algo_bit thinkpad_acpi gpu_sched drm_buddy sparse_keymap drm_suballoc_helper platform_profile drm_gpuvm snd drm_exec crc32c_intel spi_intel_pci nvme_core soundcore drm_display_helper spi_intel rfkill nvme_auth video cec i8042 serio wmi
16:18:06 kernel: Modules linked in: snd_seq_dummy snd_hrtimer rfcomm snd_seq snd_seq_device cmac algif_hash algif_skcipher af_alg qrtr intel_uncore_frequency intel_uncore_frequency_common x86_pkg_temp_thermal bnep snd_ctl_led snd_soc_sof_sdw snd_soc_intel_hda_dsp_common snd_sof_probes snd_soc_sdw_utils vfat fat joydev snd_soc_rt712_sdca snd_soc_rt1318_sdw regmap_sdw_mbq snd_hda_codec_hdmi regmap_sdw snd_soc_dmic snd_sof_pci_intel_lnl snd_sof_pci_intel_mtl snd_sof_intel_hda_generic soundwire_intel soundwire_cadence intel_powerclamp snd_sof_intel_hda_common coretemp snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda kvm_intel snd_sof_pci snd_sof_xtensa_dsp snd_sof kvm snd_sof_utils snd_hda_ext_core snd_soc_acpi_intel_match iwlmvm soundwire_generic_allocation hid_multitouch snd_soc_acpi crct10dif_pclmul soundwire_bus crc32_pclmul polyval_clmulni snd_soc_core polyval_generic mac80211 ghash_clmulni_intel sha512_ssse3 snd_compress sha256_ssse3 ac97_bus sha1_ssse3 snd_pcm_dmaengine aesni_intel gf128mul snd_hda_intel
16:18:06 kernel: WARNING: CPU: 6 PID: 211 at drivers/gpu/drm/xe/xe_guc.c:1138 xe_guc_start+0x85/0x90 [xe]
16:18:06 kernel: xe 0000:00:02.0: [drm] GT1: Failed to start GuC PC: -EIO
16:18:06 kernel: ------------[ cut here ]------------
16:18:06 kernel: xe 0000:00:02.0: [drm] *ERROR* GT1: GuC PC Start failed
16:18:06 kernel: nvme nvme0: 8/0/0 default/read/poll queues
16:18:06 kernel: pci 0000:00:0b.0: Setting to D3hot
16:18:06 kernel: ACPI: EC: interrupt unblocked
16:18:06 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
16:18:06 kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
16:18:06 kernel: OOM killer disabled.
16:18:06 kernel: Freezing user space processes completed (elapsed 0.002 seconds)
16:17:57 kernel: Filesystems sync: 0.004 seconds
16:17:57 kernel: PM: suspend entry (s2idle)
16:17:57 systemd-sleep: Performing sleep operation 'suspend'...
16:17:57 systemd: Starting System Suspend...
16:17:56 gnome-shell: Cursor update failed: drmModeAtomicCommit: Argument invalide
16:17:54 NetworkManager: <info>  [1736349474.9992] device (enp0s20f0u1): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
16:17:54 gnome-shell: Extension x11gestures@joseexposito.github.io: TypeError: obj._toucheggTracker is undefined
Stack trace:
  unhook@file:///usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/src/v40/EntryPoint40.js:167:5
  stop@file:///usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/src/v40/EntryPoint40.js:156:23
  disable@file:///usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/extension.js:67:18
  _callExtensionDisable@resource:///org/gnome/shell/ui/extensionSystem.js:215:32
  _onEnabledExtensionsChanged@resource:///org/gnome/shell/ui/extensionSystem.js:637:24
  _sessionUpdated@resource:///org/gnome/shell/ui/extensionSystem.js:824:20
  ExtensionManager/<@resource:///org/gnome/shell/ui/extensionSystem.js:46:18
  _sync@resource:///org/gnome/shell/ui/sessionMode.js:205:14
  pushMode@resource:///org/gnome/shell/ui/sessionMode.js:167:14
  activate@resource:///org/gnome/shell/ui/screenShield.js:614:34
  lock@resource:///org/gnome/shell/ui/screenShield.js:681:14
  _prepareForSleep@resource:///org/gnome/shell/ui/screenShield.js:248:22
  _prepareForSleep@resource:///org/gnome/shell/misc/loginManager.js:212:14
  _convertToNativeSignal@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:152:19
16:17:54 NetworkManager: <info>  [1736349474.8763] dhcp4 (enp0s20f0u1): state changed no lease
16:17:54 systemd: Started Network Manager Script Dispatcher Service.
16:17:54 wpa_supplicant: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
16:17:54 systemd: Starting Network Manager Script Dispatcher Service...
16:17:54 NetworkManager: <info>  [1736349474.7625] device (enp0s20f0u1): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
16:17:54 wpa_supplicant: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0
16:17:54 NetworkManager: <info>  [1736349474.7439] device (wlp0s20f3): set-hw-addr: reset MAC address to 88:F4:DA:D7:66:C6 (unmanage)
16:17:54 ModemManager: <msg> [sleep-monitor-systemd] system is about to suspend
16:17:54 NetworkManager: <info>  [1736349474.7071] manager: sleep: sleep requested (sleeping: no  enabled: yes)
16:17:54 systemd-logind: The system will suspend now!
16:17:45 kernel: xe 0000:00:02.0: [drm] GT0: Timedout job: seqno=2192, lrc_seqno=2192, guc_id=7, flags=0x0 in Xwayland [2008]
16:17:10 systemd: geoclue.service: Deactivated successfully.
16:17:10 geoclue: Service not used for 60 seconds. Shutting down..
16:17:06 systemd: Started Virtual filesystem metadata service.
16:16:41 gnome-shell: updates_checker.vala:59: check updates
16:16:24 systemd-logind: Removed session 2.
16:16:24 systemd: user-120.slice: Consumed 24.673s CPU time, 574.6M memory peak.
16:16:24 (sd-pam): pam_unix(systemd-user:session): session closed for user gdm
16:16:24 systemd: Reached target Exit the Session.
16:16:24 dbus-broker: Dispatched 446 messages @ 4(±10)μs / message.
16:16:24 systemd: Closed PipeWire Multimedia System Sockets.
16:16:24 wireplumber: wireplumber: disconnected from pipewire
16:16:24 systemd: Stopping Multimedia Service Session Manager...
16:16:18 mutter-x11-fram: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
16:16:18 systemd: Started Portal service.
16:16:17 rtkit-daemon: Supervising 13 threads of 7 processes of 2 users.
16:16:17 systemd: Started Portal service (GNOME implementation).
16:16:15 touchegg: New client connected
16:16:15 systemd: Reached target GNOME session X11 services.
16:16:14 gsd-xsettings: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
16:16:14 systemd-logind: Removed session 1.
16:16:14 systemd: session-1.scope: Consumed 23.890s CPU time, 542.5M memory peak.
16:16:14 xkbcomp: Errors from xkbcomp are not fatal to the X server
16:16:14 xdg-document-po: Error releasing name org.freedesktop.portal.Documents: La connexion est fermée
16:16:14 systemd: Stopping Session 1 of User gdm...
16:16:14 gnome-shell: Xwayland terminated, exiting since it was mandatory
16:16:14 systemd: Reached target GNOME session X11 services.
16:16:14 gnome-shell: Registering session with GDM
16:16:13 systemd: Reached target Current graphical user session.
16:16:11 gsd-media-keys: Failed to grab accelerator for keybinding settings:playback-repeat
16:16:11 systemd: Reached target GNOME keyboard shortcuts target.
16:16:11 wireplumber: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
16:16:11 systemd: Starting Locale Service...
16:16:11 bluetoothd: Endpoint registered: sender=:1.120 path=/MediaEndpoint/A2DPSource/opus_05_duplex
16:16:11 systemd: Reached target GNOME keyboard configuration target.
16:16:11 gnome-shell: [x11gestures@joseexposito.github.io] This extension is only for X11
16:16:10 rtkit-daemon: Supervising 14 threads of 8 processes of 2 users.
16:16:10 systemd: Started Location Lookup Service.
16:16:10 geoclue: Failed to connect to avahi service: Daemon not running
16:16:10 rtkit-daemon: Supervising 10 threads of 6 processes of 2 users.
16:16:10 wireplumber: wp-internal-comp-loader: Loading profile 'main'
16:16:10 rtkit-daemon: Supervising 8 threads of 5 processes of 2 users.
16:16:10 systemd: Starting Location Lookup Service...
16:16:10 systemd: Started PipeWire PulseAudio.
16:16:09 NetworkManager: <info>  [1736349369.5906] agent-manager: agent[f1af6195ce3f1fb3,:1.81/org.gnome.Shell.NetworkAgent/1000]: agent registered
16:16:08 gnome-shell: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
16:16:08 gsd-usb-protect: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
16:16:08 systemd: Started Virtual filesystem service - Apple File Conduit monitor.
16:16:07 udisksd: Acquired the name org.freedesktop.UDisks2 on the system message bus
16:16:07 goa-daemon: goa-daemon version 3.52.2 starting
16:16:07 systemd: Started Disk Manager.
16:16:07 kernel: rfkill: input handler disabled
16:16:07 systemd: Started Hostname Service.
16:16:07 udisksd: udisks daemon version 2.10.1 starting
16:16:07 systemd: Reached target GNOME USB protection target.
16:16:07 touchegg: Starting Touchégg in client mode
16:16:07 gnome-session-b: GnomeDesktop-WARNING: Could not create transient scope for PID 1796: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
16:16:07 systemd: Starting Disk Manager...
16:16:07 gnome-session-b: Entering running state
16:16:06 systemd: Reached target GNOME file sharing target.
16:16:05 gnome-shell: Will monitor session 3
16:16:04 at-spi2-registr: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
16:16:04 systemd: Started dbus-:1.21-org.a11y.atspi.Registry@0.service.
16:16:04 gnome-shell: Using Wayland display name 'wayland-0'
16:16:04 dbus-broker-lau: Ready
16:16:04 systemd: Started Accessibility services bus.
16:16:03 gnome-shell: Obtained a high priority EGL context
16:16:03 rtkit-daemon: Supervising 8 threads of 5 processes of 2 users.
16:16:02 gnome-shell: Running GNOME Shell (using mutter 47.3) as a Wayland display server
16:16:02 systemd: Started Virtual filesystem service.
16:16:02 gnome-keyring-d: discover_other_daemon: 1GNOME_KEYRING_CONTROL=/run/user/1000/keyring
16:16:02 gnome-session-b: WARNING: Desktop file /home/annick/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
16:16:01 systemd: Starting GNOME Session Manager (session: gnome)...
16:16:01 bluetoothd: Endpoint unregistered: sender=:1.62 path=/MediaEndpoint/A2DPSource/opus_05_duplex
16:16:01 gsd-media-keys: Unable to get default source
16:16:01 bluetoothd: Endpoint unregistered: sender=:1.62 path=/MediaEndpoint/A2DPSink/opus_05
16:16:01 kernel: rfkill: input handler enabled
16:16:00 gdm-session-wor: gkr-pam: unlocked login keyring
16:16:00 dbus-broker-lau: Ready
16:16:00 systemd: Started D-Bus User Message Bus.
16:16:00 dbus-broker-lau: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
16:16:00 systemd: Starting D-Bus User Message Bus...
16:16:00 gnome-keyring-d: GNOME_KEYRING_CONTROL=/run/user/1000/keyring
16:16:00 systemd: Startup finished in 727ms.
16:16:00 systemd-xdg-aut: /home/annick/.config/autostart/manjaro-app-folder-settings.desktop: not generating unit, executable specified in Exec= does not exist.
16:15:59 systemd-logind: New session 4 of user annick.
16:15:59 (systemd): pam_unix(systemd-user:session): session opened for user annick(uid=1000) by annick(uid=0)
16:15:59 systemd: Starting User Manager for UID 1000...
16:15:59 systemd-logind: New session 3 of user annick.
16:15:59 gdm-session-wor: pam_unix(gdm-password:session): session opened for user annick(uid=1000) by annick(uid=0)
16:15:59 systemd: geoclue.service: Deactivated successfully.
16:15:59 geoclue: Service not used for 60 seconds. Shutting down..
16:15:37 gnome-shell: libinput error: event6  - PS/2+USB Mouse: client bug: event processing lagging behind by 111ms, your system is too slow
16:15:34 systemd: Started Fingerprint Authentication Daemon.
16:15:33 kernel: usb 3-5.3: reset full-speed USB device number 5 using xhci_hcd
16:15:33 systemd: Starting Fingerprint Authentication Daemon...
16:15:25 systemd-timesyn: Initial clock synchronization to Wed 2025-01-08 16:15:25.550435 CET.
16:15:24 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.freedesktop.portal.Desktop'
16:15:24 kernel: discover_other_daemon: 1
16:15:24 xdg-desktop-por: No skeleton to export
16:15:24 mutter-x11-fram: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
16:15:05 systemd: NetworkManager-dispatcher.service: Deactivated successfully.
16:15:01 NetworkManager: <info>  [1736349301.0319] manager: startup complete
16:15:01 wpa_supplicant: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
16:15:00 systemd: systemd-rfkill.service: Deactivated successfully.
16:15:00 NetworkManager: <info>  [1736349300.1106] policy: set 'Connexion filaire 1' (enp0s20f0u1) as default for IPv6 routing and DNS
16:14:59 ModemManager: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
16:14:59 systemd: Startup finished in 14.036s (firmware) + 6.014s (loader) + 3.501s (kernel) + 5.684s (userspace) = 29.237s.
16:14:59 gnome-shell: Registering session with GDM
16:14:59 systemd: Started Fingerprint Authentication Daemon.
16:14:59 gnome-keyring-d: The Secret Service was already initialized
16:14:59 systemd: Started GNOME Keyring daemon.
16:14:59 gnome-keyring-d: GNOME_KEYRING_CONTROL=/run/user/120/keyring
16:14:59 kernel: discover_other_daemon: 1
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activating service name='org.freedesktop.secrets' requested by ':1.43' (uid=120 pid=1286 comm="/usr/lib/xdg-desktop-portal")
16:14:59 gsd-media-keys: Unable to get default sink
16:14:59 kernel: GNOME_KEYRING_CONTROL=/run/user/120/keyring
16:14:59 kernel: usb 3-5.3: reset full-speed USB device number 5 using xhci_hcd
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
16:14:59 wireplumber: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
16:14:59 bluetoothd: Endpoint registered: sender=:1.62 path=/MediaEndpoint/A2DPSource/opus_05_duplex
16:14:59 kernel: Bluetooth: RFCOMM ver 1.11
16:14:59 xdg-desktop-por: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activating service name='org.freedesktop.impl.portal.desktop.gtk' requested by ':1.43' (uid=120 pid=1286 comm="/usr/lib/xdg-desktop-portal")
16:14:59 rtkit-daemon: Supervising 7 threads of 4 processes of 1 users.
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activating service name='org.freedesktop.impl.portal.desktop.gnome' requested by ':1.43' (uid=120 pid=1286 comm="/usr/lib/xdg-desktop-portal")
16:14:59 systemd: Starting Fingerprint Authentication Daemon...
16:14:59 gsd-media-keys: Failed to grab accelerator for keybinding settings:hibernate
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activating service name='org.freedesktop.portal.Documents' requested by ':1.43' (uid=120 pid=1286 comm="/usr/lib/xdg-desktop-portal")
16:14:59 gsd-xsettings: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:59 gnome-session-b: Entering running state
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.freedesktop.portal.IBus'
16:14:59 rtkit-daemon: Supervising 5 threads of 3 processes of 1 users.
16:14:59 systemd: Started Location Lookup Service.
16:14:59 rtkit-daemon: Successfully made thread 1218 of process 1205 owned by '120' RT at priority 20.
16:14:59 geoclue: Failed to connect to avahi service: Daemon not running
16:14:59 rtkit-daemon: Supervising 4 threads of 3 processes of 1 users.
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activating service name='org.freedesktop.portal.IBus' requested by ':1.36' (uid=120 pid=1201 comm="ibus-daemon --panel disable -r --xim")
16:14:59 rtkit-daemon: Supervising 3 threads of 2 processes of 1 users.
16:14:59 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.gnome.Shell.Screencast'
16:14:59 xkbcomp: Errors from xkbcomp are not fatal to the X server
16:14:58 wireplumber: wp-internal-comp-loader: Loading profile 'main'
16:14:58 rtkit-daemon: Supervising 1 threads of 1 processes of 1 users.
16:14:58 systemd: Starting Location Lookup Service...
16:14:58 NetworkManager: <info>  [1736349298.9109] agent-manager: agent[981404d406dde2ca,:1.22/org.gnome.Shell.NetworkAgent/120]: agent registered
16:14:58 gjs: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:58 gsd-usb-protect: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.gnome.ScreenSaver'
16:14:58 gnome-shell: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
16:14:58 gsd-housekeepin: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.freedesktop.portal.IBus'
16:14:58 gsd-power: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activating service name='org.freedesktop.portal.IBus' requested by ':1.23' (uid=120 pid=1019 comm="ibus-daemon --panel disable")
16:14:58 kernel: rfkill: input handler disabled
16:14:58 gsd-sharing: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
16:14:58 gsd-usb-protect: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:58 systemd: Started Daemon for power management.
16:14:58 gsd-sharing: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.gnome.Shell.Notifications'
16:14:58 gnome-shell: Window manager warning: Failed to parse saved session file: L’ouverture du fichier « /var/lib/gdm/.config/mutter/sessions/10f0200fa3c4e88546173634929813102100000008390000.ms » a échoué : Aucun fichier ou dossier de ce nom
16:14:58 systemd: Starting Daemon for power management...
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=851 comm="/usr/bin/gnome-shell")
16:14:58 systemd: Started Locale Service.
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
16:14:58 systemd: Starting Locale Service...
16:14:58 gnome-shell: Will monitor session 1
16:14:58 dbus-broker-lau: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
16:14:58 systemd: Started Manage, Install and Generate Color Profiles.
16:14:58 at-spi2-registr: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
16:14:58 systemd: Starting Manage, Install and Generate Color Profiles...
16:14:58 dbus-daemon: dbus-daemon[905]: Successfully activated service 'org.a11y.atspi.Registry'
16:14:58 gnome-shell: Using Wayland display name 'wayland-0'
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Successfully activated service 'org.a11y.Bus'
16:14:58 at-spi-bus-laun: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
16:14:58 dbus-daemon: dbus-daemon[838]: [session uid=120 pid=838] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=851 comm="/usr/bin/gnome-shell")
16:14:58 touchegg: 	finish_threshold_vertical: 241.402
16:14:58 NetworkManager: <info>  [1736349298.4874] manager: NetworkManager state is now CONNECTED_GLOBAL
16:14:58 dbus-broker-lau: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
16:14:58 NetworkManager: <info>  [1736349298.4175] policy: set 'Connexion filaire 1' (enp0s20f0u1) as default for IPv4 routing and DNS
16:14:58 gnome-shell: Obtained a high priority EGL context
16:14:58 systemd: Started RealtimeKit Scheduling Policy Service.
16:14:58 gnome-shell: Running GNOME Shell (using mutter 47.3) as a Wayland display server
16:14:58 NetworkManager: <info>  [1736349298.2595] dhcp4 (enp0s20f0u1): state changed new lease, address=192.168.1.157, acd pending
16:14:58 kernel: ax88179_178a 4-1:1.0 enp0s20f0u1: ax88179 - Link status is: 1
16:14:58 NetworkManager: <info>  [1736349298.2533] manager: NetworkManager state is now CONNECTING
16:14:58 gnome-shell: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:58 gnome-session-b: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
16:14:58 gnome-session-b: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
16:14:58 dbus-broker-lau: Ready
16:14:58 systemd: Started D-Bus User Message Bus.
16:14:58 dbus-broker-lau: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
16:14:58 systemd: Starting D-Bus User Message Bus...
16:14:57 systemd-logind: New session 2 of user gdm.
16:14:57 (systemd): pam_unix(systemd-user:session): session opened for user gdm(uid=120) by gdm(uid=0)
16:14:57 dbus-broker-lau: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
16:14:57 systemd: Starting User Manager for UID 120...
16:14:57 systemd-logind: New session 1 of user gdm.
16:14:57 systemd: Started Accounts Service.
16:14:57 accounts-daemon: started daemon version 23.13.0
16:14:57 systemd: Starting Accounts Service...
16:14:56 NetworkManager: <info>  [1736349296.9677] device (p2p-dev-wlp0s20f3): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
16:14:56 wpa_supplicant: Successfully initialized wpa_supplicant
16:14:56 systemd: Started WPA supplicant.
16:14:56 NetworkManager: <info>  [1736349296.8035] modem-manager: ModemManager now available
16:14:56 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
16:14:56 NetworkManager: <info>  [1736349296.3095] device (wlp0s20f3): set-hw-addr: set MAC address to 66:E5:38:0A:E3:DA (scanning)
16:14:56 kernel: iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
16:14:56 systemd: Started Thunderbolt system service.
16:14:56 boltd: [ec9e8780-a1a5-Gen16                      ] dbus: exported device at /org/freedesktop/bolt/devices/ec9e8780_a1a5...
16:14:55 kernel: NET: Registered PF_ALG protocol family
16:14:55 kernel: Bluetooth: MGMT ver 1.23
16:14:55 bluetoothd: Battery Provider Manager created
16:14:55 kernel: typec port1: bound usb2-port3 (ops connector_ops)
16:14:55 kernel: Bluetooth: hci0: Fseq BT Top: 00.00.04.182
16:14:55 kernel: NET: Registered PF_QIPCRTR protocol family
16:14:55 systemd: Started Modem Manager.
16:14:55 kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0190-0291.ddc
16:14:55 systemd: Started GNOME Display Manager.
16:14:55 boltd: power: state located at: /run/boltd/power
16:14:55 ModemManager: <msg> ModemManager (version 1.22.0-1) starting in system bus...
16:14:55 systemd: Starting Hold until boot process finishes up...
16:14:55 boltd: bolt 0.9.8 starting up.
16:14:55 systemd: Starting GNOME Display Manager...
16:14:55 kernel: Bluetooth: hci0: Waiting for device to boot
16:14:55 systemd: Reached target Network.
16:14:55 NetworkManager: <info>  [1736349295.7409] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
16:14:55 systemd: Starting Thunderbolt system service...
16:14:55 kernel: iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
16:14:55 NetworkManager: <info>  [1736349295.7192] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-adsl.so)
16:14:55 polkitd: Started polkitd version 125
16:14:55 NetworkManager: <info>  [1736349295.7176] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.50.0-1/libnm-device-plugin-ovs.so)
16:14:55 systemd: Started Hostname Service.
16:14:55 kernel: ax88179_178a 4-1:1.0 enp0s20f0u1: renamed from eth0
16:14:55 NetworkManager: <info>  [1736349295.6909] manager[0x5cefbe2d78a0]: monitoring kernel firmware directory '/lib/firmware'.
16:14:55 kernel: usbcore: registered new interface driver ax88179_178a
16:14:55 kernel: ax88179_178a 4-1:1.0 eth0: register 'ax88179_178a' at usb-0000:00:14.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 7c:c2:c6:3b:dd:b8
16:14:55 systemd: Started User Login Management.
16:14:55 systemd-logind: Watching system buttons on /dev/input/event3 (ThinkPad Extra Buttons)
16:14:55 touchegg: A list of detected compatible devices will be displayed below:
16:14:55 systemd-logind: Watching system buttons on /dev/input/event2 (Power Button)
16:14:55 kernel: Bluetooth: BNEP socket layer initialized
16:14:55 bluetoothd: Bluetooth management interface 1.23 initialized
16:14:55 systemd: Starting Hostname Service...
16:14:55 NetworkManager: <info>  [1736349295.6642] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
16:14:55 systemd: Reached target Bluetooth Support.
16:14:55 bluetoothd: Starting SDP server
16:14:55 systemd: Started Bluetooth service.
16:14:55 bluetoothd: Bluetooth daemon 5.79
16:14:55 systemd: Reached target Sound Card.
16:14:55 dbus-broker-lau: Ready
16:14:55 systemd: Finished Save/Restore Sound Card State.
16:14:55 alsactl: alsa-lib main.c:2456:(set_fixedboot_user) Unable to execute force boot sequence
16:14:55 systemd: Started Touchégg Daemon.
16:14:55 kernel: iwlwifi 0000:00:14.3: base HW address: 88:f4:da:d7:66:c6
16:14:55 systemd: TPM PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
16:14:55 kernel: input: sof-soundwire HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sof_sdw/sound/card0/input20
16:14:55 kernel: sof_sdw sof_sdw: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
16:14:55 kernel: iwlwifi 0000:00:14.3: Detected RF FM, rfid=0x20112200
16:14:55 kernel: sof_sdw sof_sdw: ASoC: Parent card not yet available, widget card binding deferred
16:14:55 kernel: sof-audio-pci-intel-lnl 0000:00:1f.3: Topology: ABI 3:29:1 Kernel ABI 3:23:1
16:14:55 systemd: Finished Tell Plymouth To Write Out Runtime Data.
16:14:55 kernel: iwlwifi 0000:00:14.3: loaded PNVM version 35c04ca8
16:14:55 systemd: Starting Create System Files and Directories...
16:14:55 kernel: hid-multitouch 0018:2C2F:0028.0002: input,hidraw1: I2C HID v1.00 Mouse [SNSL0028:00 2C2F:0028] on i2c-SNSL0028:00
16:14:55 kernel: input: SNSL0028:00 2C2F:0028 Touchpad as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-13/i2c-SNSL0028:00/0018:2C2F:0028.0002/input/input15
16:14:55 kernel: sof-audio-pci-intel-lnl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.11.1.1
16:14:55 systemd: Repartition Root Disk was skipped because no trigger condition checks were met.
16:14:55 kernel: input: TPPS/2 Elan TrackPoint as /devices/platform/i8042/serio1/input/input10
16:14:55 kernel: psmouse serio1: trackpoint: Elan TrackPoint firmware: 0x00, buttons: 3/3
16:14:55 systemd: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
16:14:55 kernel: typec port0: bound usb2-port1 (ops connector_ops)
16:14:55 kernel: hid-generic 0018:2C2F:0028.0002: input,hidraw1: I2C HID v1.00 Mouse [SNSL0028:00 2C2F:0028] on i2c-SNSL0028:00
16:14:55 kernel: input: SNSL0028:00 2C2F:0028 Touchpad as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-13/i2c-SNSL0028:00/0018:2C2F:0028.0002/input/input12
16:14:55 systemd: Started Load/Save RF Kill Switch Status.
16:14:55 kernel: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
16:14:55 systemd: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
16:14:55 kernel: Bluetooth: hci0: Firmware Version: 160-24.24
16:14:55 kernel: AES CTR mode by8 optimization enabled
16:14:55 kernel: snd_hda_intel 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
16:14:55 kernel: mei_gsc_proxy 0000:00:16.0-0f73db04-97ab-4125-b893-e904ad0d5464: bound 0000:00:02.0 (ops xe_gsc_proxy_component_ops [xe])
16:14:55 kernel: intel_rapl_common: Found RAPL domain psys
16:14:55 kernel: cryptd: max_cpu_qlen set to 1000
16:14:55 kernel: usbcore: registered new interface driver uvcvideo
16:14:55 kernel: PTP clock support registered
16:14:55 kernel: usb 3-4: Found UVC 1.50 device Integrated Camera (30c9:005f)
16:14:55 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
16:14:55 kernel: iwlwifi 0000:00:14.3: loaded firmware version 92.67ce4588.0 bz-b0-fm-c0-92.ucode op_mode iwlmvm
16:14:55 kernel: iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.182.4.1
16:14:55 kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
16:14:55 kernel: proc_thermal_pci 0000:00:04.0: msi enabled:1 msix enabled:0
16:14:55 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-b0-fm-c0-93.ucode failed with error -2
16:14:55 kernel: Intel(R) Wireless WiFi driver for Linux
16:14:55 kernel: intel_rapl_common: Found RAPL domain dram
16:14:55 kernel: proc_thermal_pci 0000:00:04.0: enabling device (0400 -> 0402)
16:14:55 kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
16:14:54 kernel: intel-lpss 0000:00:15.3: enabling device (0000 -> 0002)
16:14:54 kernel: spi-nor spi0.0: unrecognized JEDEC id bytes: f7 c0 30 09 03 00
16:14:54 kernel: btintel_pcie 0000:00:14.7: enabling device (0000 -> 0002)
16:14:54 kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
16:14:54 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
16:14:54 systemd: Starting Load/Save Screen Backlight Brightness of leds:tpacpi::kbd_backlight...
16:14:54 kernel: input: PC Speaker as /devices/platform/pcspkr/input/input9
16:14:54 kernel: videodev: Linux video capture interface: v2.00
16:14:54 kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
16:14:54 kernel: intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
16:14:54 kernel: Bluetooth: SCO socket layer initialized
16:14:54 kernel: NET: Registered PF_BLUETOOTH protocol family
16:14:54 kernel: Bluetooth: Core ver 2.22
16:14:54 mtp-probe: bus: 4, device: 2 was not an MTP device
16:14:54 kernel: mc: Linux media interface: v0.10
16:14:54 systemd: Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
16:14:54 mtp-probe: bus: 3, device: 5 was not an MTP device
16:14:54 systemd: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
16:14:54 kernel: bus: 3, device: 3 was not an MTP device
16:14:54 systemd: Created slice Slice /system/systemd-backlight.
16:14:54 kernel: checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
16:14:54 kernel: intel_vpu 0000:00:0b.0: probe with driver intel_vpu failed with error -2
16:14:54 kernel: ACPI: bus type thunderbolt registered
16:14:54 kernel: intel_vpu 0000:00:0b.0: enabling device (0000 -> 0002)
16:14:54 kernel: intel_pmc_core INT33A1:00:  initialized
16:14:54 kernel: pci 0000:00:0b.0: Setting to D3hot
16:14:54 systemd: Reached target Swaps.
16:14:54 fsck.vfat: /dev/nvme0n1p1: 5 files, 72/76646 clusters
16:14:54 kernel: Consider using thermal netlink events interface
16:14:54 kernel: intel_vsec 0000:00:0a.0: enabling device (0000 -> 0002)
16:14:54 kernel: mousedev: PS/2 mouse device common for all mice
16:14:54 kernel: Adding 35618888k swap on /dev/nvme0n1p3.  Priority:-2 extents:1 across:35618888k SS
16:14:54 kernel: input: Intel HID events as /devices/platform/INTC1070:00/input/input8
16:14:54 systemd: Activating swap /dev/disk/by-uuid/648bdd64-54a8-425b-b79a-30ce76ef5fde...
16:14:54 mtp-probe: bus: 3, device: 2 was not an MTP device
16:14:54 systemd: Reached target Trusted Platform Module.
16:14:54 systemd-journal: Received client request to flush runtime journal.
16:14:54 systemd: Starting Flush Journal to Persistent Storage...
16:14:54 kernel: Started Journal Service.
16:14:54 kernel: Skip starting firewall: ufw (not enabled)
16:14:54 systemd: Started User Database Manager.
16:14:54 apparmor.system: Reloading AppArmor profiles
16:14:54 kernel: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
16:14:54 kernel: Inserted module 'sg'
16:14:54 systemd-journal: Runtime Journal (/run/log/journal/5fd7397b751046788e2fd211c2919627) is 8M, max 1.5G, 1.5G free.
16:14:54 kernel: Finished CLI Netfilter Manager.
16:14:54 kernel: Starting CLI Netfilter Manager...
16:14:54 kernel: Finished Apply Kernel Variables.
16:14:54 kernel: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
16:14:54 kernel: Starting Load/Save OS Random Seed...
16:14:54 kernel: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
16:14:54 kernel: Finished Remount Root and Kernel File Systems.
16:14:54 kernel: audit: type=1400 audit(1736349294.496:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=385 comm="apparmor_parser"
16:14:54 kernel: EXT4-fs (nvme0n1p2): re-mounted 666e9e23-4fee-476f-b365-af1960b5f6f4 r/w. Quota mode: none.
16:14:54 kernel: audit: type=1400 audit(1736349294.493:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=382 comm="apparmor_parser"
16:14:54 kernel: Mounted Kernel Configuration File System.
16:14:54 kernel: audit: type=1400 audit(1736349294.493:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=379 comm="apparmor_parser"
16:14:54 systemd-journal: Collecting audit messages is disabled.
16:14:54 kernel: Mounted FUSE Control File System.
16:14:54 kernel: Starting Apply Kernel Variables...
16:14:54 kernel: Repartition Root Disk was skipped because no trigger condition checks were met.
16:14:54 kernel: Finished Virtual Console Setup.
16:14:54 kernel: modprobe@loop.service: Deactivated successfully.
16:14:54 kernel: Starting Create Static Device Nodes in /dev gracefully...
16:14:54 kernel: Mounting Kernel Configuration File System...
16:14:54 kernel: Finished Load udev Rules from Credentials.
16:14:54 kernel: loop: module loaded
16:14:54 kernel: modprobe@fuse.service: Deactivated successfully.
16:14:54 kernel: Finished Load Kernel Module drm.
16:14:54 kernel: modprobe@drm.service: Deactivated successfully.
16:14:54 kernel: Finished Load Kernel Module dm_mod.
16:14:54 kernel: modprobe@dm_mod.service: Deactivated successfully.
16:14:54 kernel: Finished Load Kernel Module configfs.
16:14:54 kernel: modprobe@configfs.service: Deactivated successfully.
16:14:54 kernel: Finished Create List of Static Device Nodes.
16:14:54 kernel: Mounted Kernel Trace File System.
16:14:54 kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
16:14:54 kernel: Starting Virtual Console Setup...
16:14:54 kernel: device-mapper: uevent: version 1.0.3
16:14:54 kernel: Starting Coldplug All udev Devices...
16:14:54 kernel: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
16:14:54 kernel: Starting Remount Root and Kernel File Systems...
16:14:54 kernel: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
16:14:54 kernel: Starting Load Kernel Modules...
16:14:54 kernel: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
16:14:54 kernel: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
16:14:54 kernel: Starting Load Kernel Module loop...
16:14:54 kernel: Mounting Kernel Trace File System...
16:14:54 kernel: Listening on User Database Manager Socket.
16:14:54 kernel: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
16:14:54 kernel: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
16:14:54 kernel: Listening on Journal Sockets.
16:14:54 kernel: Reached target Local Verity Protected Volumes.
16:14:54 kernel: Expecting device /dev/disk/by-uuid/E7A8-D76B...
16:14:54 kernel: Set up automount Arbitrary Executable File Formats File System Automount Point.
16:14:54 kernel: Started Forward Password Requests to Wall Directory Watch.
16:14:54 kernel: Created slice User and Session Slice.
16:14:54 kernel: Queued start job for default target Graphical Interface.
16:14:54 kernel: bpf-restrict-fs: LSM BPF program attached
16:14:54 kernel: Hostname set to <annick-laptop>.
16:14:54 kernel: Detected architecture x86-64.
16:14:54 kernel: systemd 256.9-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
16:14:54 kernel: EXT4-fs (nvme0n1p2): mounted filesystem 666e9e23-4fee-476f-b365-af1960b5f6f4 r/w with ordered data mode. Quota mode: none.
16:14:54 kernel: PM: Image not found (code -22)
16:14:54 kernel: xe 0000:00:02.0: [drm] Selective fetch area calculation failed in pipe A
16:14:54 kernel: usb 3-5.3: SerialNumber: UID24B392BE_XXXX_MOC_B0
16:14:54 kernel: hid-generic 0003:1267:0210.0001: input,hidraw0: USB HID v1.00 Mouse [PS/2+USB Mouse] on usb-0000:00:14.0-1/input0
16:14:54 kernel: input: PS/2+USB Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/0003:1267:0210.0001/input/input7
16:14:54 kernel: usbhid: USB HID core driver
16:14:54 kernel: usbcore: registered new interface driver usbhid
16:14:54 kernel: hub 3-5:1.0: 3 ports detected
16:14:54 kernel: usb 3-5: Product: USB2.0 Hub
16:14:54 kernel: xe 0000:00:02.0: [drm] GT1: found GSC cv104.1.0
16:14:54 kernel: usb 3-5: new high-speed USB device number 4 using xhci_hcd
16:14:54 kernel: xe 0000:00:02.0: [drm] fb0: xedrmfb frame buffer device
16:14:54 kernel: fbcon: Deferring console take-over
16:14:54 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
16:14:54 kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
16:14:54 kernel: [drm] Initialized xe 1.1.0 for 0000:00:02.0 on minor 0
16:14:54 kernel: usb 3-4: SerialNumber: 0001
16:14:54 kernel: xe 0000:00:02.0: [drm] vecs3 fused off
16:14:54 kernel: usb 3-4: new high-speed USB device number 3 using xhci_hcd
16:14:54 kernel: xe 0000:00:02.0: [drm] Finished loading DMC firmware i915/xe2lpd_dmc.bin (v2.24)
16:14:54 kernel: usb 3-1: Product: PS/2+USB Mouse
16:14:54 kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
16:14:54 kernel:  nvme0n1: p1 p2 p3
16:14:54 kernel: nvme nvme0: 8/0/0 default/read/poll queues
16:14:54 kernel: input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input3
16:14:54 kernel: ACPI: battery: new extension: ThinkPad Battery Extension
16:14:54 kernel: thinkpad_acpi: battery 1 registered (start 0, stop 100, behaviours: 0x7)
16:14:54 kernel: nvme nvme0: pci function 0000:04:00.0
16:14:54 kernel: thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
16:14:54 kernel: usb 3-1: new low-speed USB device number 2 using xhci_hcd
16:14:54 kernel: thinkpad_acpi: Lenovo ThinkPad X1 Carbon Gen 13, model 21NS000YFR
16:14:54 kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
16:14:54 kernel: i8042: Warning: Keylock active
16:14:54 kernel:     BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
16:14:54 kernel: Run /init as init process
16:14:54 kernel: rodata_test: all tests were successful
16:14:54 kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
16:14:54 kernel: Freeing unused kernel image (rodata/data gap) memory: 24K
16:14:54 kernel: Write protecting the kernel read-only data: 32768k
16:14:54 kernel: Freeing unused kernel image (initmem) memory: 4264K
16:14:54 kernel: PM: genpd: Disabling unused power domains
16:14:54 kernel: clk: Disabling unused clocks
16:14:54 kernel: RAS: Correctable Errors collector initialized.
16:14:54 kernel: memory memory112: hash matches
16:14:54 kernel: acpi device:4e: hash matches
16:14:54 kernel: PM:   Magic number: 9:328:234
16:14:54 kernel: integrity: Loaded X.509 cert 'Microsoft Corporation: Windows UEFI CA 2023: aefc5fbbbe055d8f8daa585473499417ab5a5272'
16:14:54 kernel: AppArmor: AppArmor sha256 policy hashing enabled
16:14:54 kernel: Key type fscrypt-provisioning registered
16:14:54 kernel: Demotion targets for Node 0: null
16:14:54 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 053bbeb4276ab11fcf2acd532b7ee67426dcc55d'
16:14:54 kernel: Loading compiled-in X.509 certificates
16:14:54 kernel: registered taskstats version 1
16:14:54 kernel: sched_clock: Marking stable (1030001968, 6487648)->(1076473689, -39984073)
16:14:54 kernel: IPI shorthand broadcast: enabled
16:14:54 kernel: microcode: Current revision: 0x00000116
16:14:54 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
16:14:54 kernel: NET: Registered PF_PACKET protocol family
16:14:54 kernel: In-situ OAM (IOAM) with IPv6
16:14:54 kernel: RPL Segment Routing with IPv6
16:14:54 kernel: Segment Routing with IPv6
16:14:54 kernel: NET: Registered PF_INET6 protocol family
16:14:54 kernel: drop_monitor: Initializing network drop monitor service
16:14:54 kernel: hid: raw HID events driver (C) Jiri Kosina
16:14:54 kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
16:14:54 kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
16:14:54 kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
16:14:54 kernel: Relocating firmware framebuffer to offset 0x0000000000800000[d] within [mem 0x2000000000-0x200fffffff flags 0x14220c]
16:14:54 kernel: intel_pstate: HWP enabled
16:14:54 kernel: Hybrid CPU capacity scaling enabled
16:14:54 kernel: intel_pstate: Intel P-state driver initializing
16:14:54 kernel: rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
16:14:54 kernel: usbserial: USB Serial support registered for generic
16:14:54 kernel: usbcore: registered new interface driver usbserial_generic
16:14:54 kernel: hub 4-0:1.0: 2 ports detected
16:14:54 kernel: usb usb4: SerialNumber: 0000:00:14.0
16:14:54 kernel: hub 3-0:1.0: 8 ports detected
16:14:54 kernel: usb usb3: SerialNumber: 0000:00:14.0
16:14:54 kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
16:14:54 kernel: hub 2-0:1.0: 3 ports detected
16:14:54 kernel: usb usb2: SerialNumber: 0000:00:0d.0
16:14:54 kernel: hub 1-0:1.0: 1 port detected
16:14:54 kernel: usb usb1: SerialNumber: 0000:00:0d.0
16:14:54 kernel: xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
16:14:54 kernel: ACPI: bus type drm_connector registered
16:14:54 kernel: Freeing initrd memory: 28996K
16:14:54 kernel: tpm_tis STM0925:00: 2.0 TPM (device-id 0x3, rev-id 1)
16:14:54 kernel: Linux agpgart interface v0.103
16:14:54 kernel: Non-volatile memory driver v1.3
16:14:54 kernel: hpet_acpi_add: no address or irqs in _CRS
16:14:54 kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
16:14:54 kernel: ACPI: thermal: Thermal Zone [THM0] (41 C)
16:14:54 kernel: thermal LNXTHERM:00: registered as thermal_zone0
16:14:54 kernel: ACPI: button: Power Button [PWRB]
16:14:54 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
16:14:54 kernel: ACPI: button: Lid Switch [LID]
16:14:54 kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
16:14:54 kernel: ACPI: button: Sleep Button [SLPB]
16:14:54 kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
16:14:54 kernel: ACPI: AC: AC Adapter [AC] (on-line)
16:14:54 kernel: Monitor-Mwait will be used to enter C-3 state
16:14:54 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
16:14:54 kernel: pcieport 0000:00:1c.4: PME: Signaling with IRQ 123
16:14:54 kernel: ledtrig-cpu: registered to indicate activity on CPUs
16:14:54 kernel: io scheduler bfq registered
16:14:54 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
16:14:54 kernel: Asymmetric key parser 'x509' registered
16:14:54 kernel: Key type asymmetric registered
16:14:54 kernel: integrity: Machine keyring initialized
16:14:54 kernel: fuse: init (API version 7.41)
16:14:54 kernel: workingset: timestamp_bits=36 max_order=23 bucket_order=0
16:14:54 kernel: Key type blacklist registered
16:14:54 kernel: Initialise system trusted keyrings
16:14:54 kernel: platform rtc_cmos: registered platform RTC device (no PNP device found)
16:14:54 kernel: clocksource: Switched to clocksource tsc
16:14:54 kernel: Trying to unpack rootfs image as initramfs...
16:14:54 kernel: software IO TLB: mapped [mem 0x000000007f765000-0x0000000083765000] (64MB)
16:14:54 kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
16:14:54 kernel: PCI: CLS 0 bytes, default 64
16:14:54 kernel: pci 0000:00:0d.0: enabling device (0000 -> 0002)
16:14:54 kernel: pci_bus 0000:04: resource 1 [mem 0xbc400000-0xbc4fffff]
16:14:54 kernel: pci 0000:00:1c.4:   bridge window [mem 0xbc400000-0xbc4fffff]
16:14:54 kernel: NET: Registered PF_XDP protocol family
16:14:54 kernel: UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
16:14:54 kernel: UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
16:14:54 kernel: MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
16:14:54 kernel: TCP: Hash tables configured (established 262144 bind 65536)
16:14:54 kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
16:14:54 kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
16:14:54 kernel: tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
16:14:54 kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
16:14:54 kernel: NET: Registered PF_INET protocol family
16:14:54 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
16:14:54 kernel: pnp: PnP ACPI: found 9 devices
16:14:54 kernel: system 00:08: [mem 0xfed4c000-0xffffffff] could not be reserved
16:14:54 kernel: pnp 00:08: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
16:14:54 kernel: system 00:07: [io  0x1854-0x1857] has been reserved
16:14:54 kernel: pnp: PnP ACPI init
16:14:54 kernel: AppArmor: AppArmor Filesystem Enabled
16:14:54 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
16:14:54 kernel: clocksource: Switched to clocksource tsc-early
16:14:54 kernel: vgaarb: loaded
16:14:54 kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=mem,locks=none
16:14:54 kernel: e820: reserve RAM buffer [mem 0x85f800000-0x85fffffff]
16:14:54 kernel: pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]: can't claim; no compatible bridge window
16:14:54 kernel: PCI: pci_cache_line_size set to 64 bytes
16:14:54 kernel: NET: Registered PF_MCTP protocol family
16:14:54 kernel: mctp: management component transport protocol core
16:14:54 kernel: NetLabel:  unlabeled traffic allowed by default
16:14:54 kernel: efivars: Registered efivars operations
16:14:54 kernel: EDAC MC: Ver: 3.0.0
16:14:54 kernel: usbcore: registered new device driver usb
16:14:54 kernel: ACPI: bus type USB registered
16:14:54 kernel: libata version 3.00 loaded.
16:14:54 kernel: SCSI subsystem initialized
16:14:54 kernel: iommu: DMA domain TLB invalidation policy: lazy mode
16:14:54 kernel: ACPI: \_SB_.PC00.LPCB.EC__: EC: Used to handle transactions and events
16:14:54 kernel: Low-power S0 idle used by default for system suspend
16:14:54 kernel: ACPI: \_SB_.PEPD: Duplicate LPS0 _DSM functions (mask: 0x1)
16:14:54 kernel: pci 0000:00:1c.4: PCI bridge to [bus 04]
16:14:54 kernel: pci_bus 0000:00: root bus resource [bus 00-fe]
16:14:54 kernel: PCI host bridge to bus 0000:00
16:14:54 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
16:14:54 kernel: ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
16:14:54 kernel: PCI: Ignoring E820 reservations for host bridge windows
16:14:54 kernel: ACPI: Using IOAPIC for interrupt routing
16:14:54 kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
16:14:54 kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
16:14:54 kernel: PCI: Using configuration type 1 for base access
16:14:54 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
16:14:54 kernel: cpuidle: using governor menu
16:14:54 kernel: thermal_sys: Registered thermal governor 'power_allocator'
16:14:54 kernel: audit: type=2000 audit(1736349290.013:1): state=initialized audit_enabled=0 res=1
16:14:54 kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
16:14:54 kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
16:14:54 kernel: PM: RTC time: 15:14:50, date: 2025-01-08
16:14:54 kernel: pinctrl core: initialized pinctrl subsystem
16:14:54 kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
16:14:54 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
16:14:54 kernel: ACPI: PM: Registering ACPI NVS region [mem 0x54e2f000-0x55a2efff] (12582912 bytes)
16:14:54 kernel: x86/mm: Memory block size: 128MB
16:14:54 kernel: devtmpfs: initialized
16:14:54 kernel: Memory: 32322860K/33064760K available (18432K kernel code, 2671K rwdata, 14312K rodata, 4264K init, 4032K bss, 720556K reserved, 0K cma-reserved)
16:14:54 kernel: smpboot: Total of 8 processors activated (52859.00 BogoMIPS)
16:14:54 kernel: smp: Brought up 1 node, 8 CPUs
16:14:54 kernel: ... event mask:             00000077000000ff
16:14:54 kernel: core: cpu_atom PMU driver:
16:14:54 kernel: .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
16:14:54 kernel: smpboot: x86: Booting SMP configuration:
16:14:54 kernel: smp: Bringing up secondary CPUs ...
16:14:54 kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
16:14:54 kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
16:14:54 kernel: rcu: 	Max phase no-delay instances is 1000.
16:14:54 kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1303
16:14:54 kernel: signal: max sigframe size: 3632
16:14:54 kernel: ... event mask:             0001000f000003ff
16:14:54 kernel: core: cpu_core PMU driver:
16:14:54 kernel: Performance Events: XSAVE Architectural LBR, no PEBS fmt6+,  AnyThread deprecated, Lunarlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
16:14:54 kernel: smpboot: CPU0: Intel(R) Core(TM) Ultra 7 258V (family: 0x6, model: 0xbd, stepping: 0x1)
16:14:54 kernel: Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
16:14:54 kernel: Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
16:14:54 kernel: AppArmor: AppArmor initialized
16:14:54 kernel: LSM support for eBPF active
16:14:54 kernel: Yama: becoming mindful.
16:14:54 kernel: landlock: Up and running.
16:14:54 kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
16:14:54 kernel: pid_max: default: 32768 minimum: 301
16:14:54 kernel: Freeing SMP alternatives memory: 40K
16:14:54 kernel: x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
16:14:54 kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
16:14:54 kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
16:14:54 kernel: process: using mwait in idle threads
16:14:54 kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
16:14:54 kernel: CET detected: Indirect Branch Tracking enabled
16:14:54 kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
16:14:54 kernel: CPU0: Thermal monitoring enabled (TM1)
16:14:54 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6607.00 BogoMIPS (lpj=11008000)
16:14:54 kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2f9a2767029, max_idle_ns: 440795219692 ns
16:14:54 kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
16:14:54 kernel: DMAR: SATC flags: 0x1
16:14:54 kernel: APIC: Switch to symmetric I/O mode setup
16:14:54 kernel: hpet: HPET dysfunctional in PC10. Force disabled.
16:14:54 kernel: ACPI: Core revision 20240827
16:14:54 kernel: printk: legacy console [tty0] enabled
16:14:54 kernel: Console: colour dummy device 80x25
16:14:54 kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
16:14:54 kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
16:14:54 kernel: NR_IRQS: 524544, nr_irqs: 2048, preallocated irqs: 16
16:14:54 kernel: RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
16:14:54 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
16:14:54 kernel: 	Tracing variant of Tasks RCU enabled.
16:14:54 kernel: 	Rude variant of Tasks RCU enabled.
16:14:54 kernel: 	Trampoline variant of Tasks RCU enabled.
16:14:54 kernel: rcu: 	RCU priority boosting: priority 1 delay 500 ms.
16:14:54 kernel: Dynamic Preempt: full
16:14:54 kernel: ftrace: allocated 201 pages with 4 groups
16:14:54 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
16:14:54 kernel: software IO TLB: area num 8.
16:14:54 kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
16:14:54 kernel: Policy zone: Normal
16:14:54 kernel: Built 1 zonelists, mobility grouping on.  Total pages: 8266190
16:14:54 kernel: Fallback order for Node 0: 0
16:14:54 kernel: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
16:14:54 kernel: Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
16:14:54 kernel: Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64", will be passed to user space.
16:14:54 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=666e9e23-4fee-476f-b365-af1960b5f6f4 rw quiet splash apparmor=1 security=apparmor resume=UUID=648bdd64-54a8-425b-b79a-30ce76ef5fde udev.log_priority=3
16:14:54 kernel: pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
16:14:54 kernel: percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
16:14:54 kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
16:14:54 kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
16:14:54 kernel: Booting paravirtualized kernel on bare hardware
16:14:54 kernel: [mem 0xa0800000-0xfed1ffff] available for PCI devices
16:14:54 kernel: PM: hibernation: Registered nosave memory: [mem 0x100000000-0x1043fffff]
16:14:54 kernel: CPU topo: Allowing 8 present CPUs plus 0 hotplug CPUs
16:14:54 kernel: TSC deadline timer available
16:14:54 kernel: e820: update [mem 0x83765000-0x838a9fff] usable ==> reserved
16:14:54 kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
16:14:54 kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
16:14:54 kernel: ACPI: X2APIC_NMI (uid[0xffffffff] high level lint[0x1])
16:14:54 kernel: On node 0, zone Normal: 2048 pages in unavailable ranges
16:14:54 kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000085f7fffff]
16:14:54 kernel:   node   0: [mem 0x0000000104400000-0x000000085f7fffff]
16:14:54 kernel: Early memory node ranges
16:14:54 kernel: Movable zone start for each node
16:14:54 kernel:   Device   empty
16:14:54 kernel: Zone ranges:
16:14:54 kernel: NODE_DATA(0) allocated [mem 0x85f7d42c0-0x85f7fefff]
16:14:54 kernel: Faking a node at [mem 0x0000000000000000-0x000000085f7fffff]
16:14:54 kernel: No NUMA configuration found
16:14:54 kernel: APIC: Switched APIC routing to: cluster x2apic
16:14:54 kernel: ACPI: Reserving UEFI table memory at [mem 0x5599e000-0x5599e075]
16:14:54 kernel: RAMDISK: [mem 0x4b2df000-0x4cf2ffff]
16:14:54 kernel: Secure boot disabled
16:14:54 kernel: Using GB pages for direct mapping
16:14:54 kernel: e820: update [mem 0x857eb000-0x857ebfff] usable ==> reserved
16:14:54 kernel: esrt: Reserving ESRT space from 0x00000000857eb798 to 0x00000000857eba28.
16:14:54 kernel: last_pfn = 0x8e000 max_arch_pfn = 0x400000000
16:14:54 kernel: x2apic: enabled by BIOS, switching to x2apic ops
16:14:54 kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
16:14:54 kernel: MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
16:14:54 kernel: last_pfn = 0x85f800 max_arch_pfn = 0x400000000
16:14:54 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
16:14:54 kernel: tsc: Detected 3302.400 MHz TSC
16:14:54 kernel: DMI: Memory slots populated: 8/8
16:14:54 kernel: SMBIOS 3.8.0 present.
16:14:54 kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
16:14:54 kernel: efi: Remove mem79: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
16:14:54 kernel: random: crng init done
16:14:54 kernel: efi: ACPI=0x55afe000 ACPI 2.0=0x55afe014 SMBIOS=0x5814f000 SMBIOS 3.0=0x58142000 TPMFinalLog=0x559c0000 MEMATTR=0x858bf018 ESRT=0x857eb798 INITRD=0x54e28718 RNG=0x55afc018 TPMEventLog=0x55af1018
16:14:54 kernel: APIC: Static calls initialized
16:14:54 kernel: NX (Execute Disable) protection: active
16:14:54 kernel: BIOS-e820: [mem 0x0000000104400000-0x000000085f7fffff] usable
16:14:54 kernel: BIOS-provided physical RAM map:
16:14:54 kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
16:14:54 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=666e9e23-4fee-476f-b365-af1960b5f6f4 rw quiet splash apparmor=1 security=apparmor resume=UUID=648bdd64-54a8-425b-b79a-30ce76ef5fde udev.log_priority=3
16:14:54 kernel: Linux version 6.12.4-1-MANJARO (linux612@manjaro) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.0) #1 SMP PREEMPT_DYNAMIC Mon, 09 Dec 2024 11:58:37 +0000
PS: No trace in logs of VRR or CMRR
At least there is a crash of the intel driver while starting with GuC Firmware when waking up from s2idle (“modern standby” in windows terms):
The driver must have reset something when restarting. But that would require detailed debug messages. Most likely another bug here too which is related.
In any case, at 6-7 FPS I can only imagine that the driver assumes through CMRR that little has to be rendered and therefore saves power. Try turning off a few power saving functions using the module parameters and see if it works.
Having tinkered all over the place, I reinstalled the clean system.
Same problem.
Then I switched to the experimental kernel available: 6.13.0-rc2-1
Same problem…BUT!
I no longer have display lag or mouse movement lag.
Of course, to get this result, I still have to switch to standby mode as soon as the session is opened.
The log is full of scary errors that I can’t understand.
I’ll see what I can change about the power configuration…
17:56:19 gnome-logs: MESA-INTEL: warning: ../mesa-24.2.8/src/intel/vulkan/anv_formats.c:794: FINISHME: support more multi-planar formats with DRM modifiers
17:56:19 systemd: Started dbus-:1.2-org.gnome.Logs@0.service.
17:52:30 wpa_supplicant: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-43 noise=9999 txrate=245000
17:52:30 systemd-timesyn: Initial clock synchronization to Wed 2025-01-08 17:52:30.378410 CET.
17:52:29 systemd: NetworkManager-dispatcher.service: Deactivated successfully.
17:52:29 systemd-timesyn: Timed out waiting for reply from [2001:41d0:701:1100::1ecc]:123 (2.manjaro.pool.ntp.org).
17:52:28 systemd: Started Virtual filesystem metadata service.
17:52:22 geoclue: Service not used for 60 seconds. Shutting down..
17:52:22 systemd: Starting Pamac Daemon...
17:52:22 gnome-shell: updates_checker.vala:59: check updates
17:52:21 systemd: fprintd.service: Deactivated successfully.
17:52:20 NetworkManager: <info>  [1736355140.0067] manager: NetworkManager state is now CONNECTED_GLOBAL
17:52:19 NetworkManager: <info>  [1736355139.9512] device (wlp0s20f3): Activation: successful, device activated.
17:52:19 NetworkManager: <info>  [1736355139.9493] manager: NetworkManager state is now CONNECTED_SITE
17:52:19 NetworkManager: <info>  [1736355139.9483] device (wlp0s20f3): state change: secondaries -> activated (reason 'none', managed-type: 'full')
17:52:19 NetworkManager: <info>  [1736355139.9477] device (wlp0s20f3): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
17:52:19 NetworkManager: <info>  [1736355139.9424] device (wlp0s20f3): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
17:52:19 NetworkManager: <info>  [1736355139.9254] policy: set 'PC27@DUTY50' (wlp0s20f3) as default for IPv4 routing and DNS
17:52:19 NetworkManager: <info>  [1736355139.9245] dhcp4 (wlp0s20f3): state changed new lease, address=192.168.1.126
17:52:19 NetworkManager: <info>  [1736355139.7159] dhcp4 (wlp0s20f3): state changed new lease, address=192.168.1.126, acd pending
17:52:19 systemd: Started Network Manager Script Dispatcher Service.
17:52:19 dbus-broker-lau: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
17:52:19 NetworkManager: <info>  [1736355139.2953] policy: set 'PC27@DUTY50' (wlp0s20f3) as default for IPv6 routing and DNS
17:52:17 wpa_supplicant: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-45 noise=9999 txrate=245000
17:52:17 NetworkManager: <info>  [1736355137.5295] device (p2p-dev-wlp0s20f3): supplicant management interface state: associating -> 4way_handshake
17:52:17 kernel: wlp0s20f3: associated
17:52:17 NetworkManager: <info>  [1736355137.5077] device (p2p-dev-wlp0s20f3): supplicant management interface state: authenticating -> associating
17:52:17 kernel: wlp0s20f3: associate with 64:64:4a:ba:82:24 (try 1/3)
17:52:17 NetworkManager: <info>  [1736355137.4569] device (p2p-dev-wlp0s20f3): supplicant management interface state: scanning -> authenticating
17:52:17 kernel: wlp0s20f3: authenticate with 64:64:4a:ba:82:24 (local address=88:f4:da:d7:66:c6)
17:52:17 NetworkManager: <info>  [1736355137.3472] Config: added 'psk' value '<hidden>'
17:52:17 wpa_supplicant: wlp0s20f3: WPS-CANCEL
17:52:17 NetworkManager: <info>  [1736355137.3470] Config: added 'ssid' value 'PC27@DUTY50'
17:52:04 wpa_supplicant: wlp0s20f3: WPS-PBC-ACTIVE
17:52:04 NetworkManager: <info>  [1736355124.8088] sup-iface[651df3de848a8ce8,1,wlp0s20f3]: wps: type pbc start...
17:51:53 ModemManager: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
17:51:53 NetworkManager: <info>  [1736355113.0325] agent-manager: agent[82d1dd78fb478d9a,:1.79/org.gnome.Shell.NetworkAgent/1000]: agent registered
17:51:53 gnome-shell: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.Failed: Set global engine failed: L’opération a été annulée
Stack trace:
  _promisify/proto[asyncFunc]/</<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:453:45
  @resource:///org/gnome/shell/ui/init.js:21:20
  ### Promise created here: ###
  _setEngine@resource:///org/gnome/shell/misc/ibusManager.js:286:30
  setEngine@resource:///org/gnome/shell/misc/ibusManager.js:299:24
  activateInputSource@resource:///org/gnome/shell/ui/status/keyboard.js:523:27
  _callHandlers@resource:///org/gnome/gjs/modules/core/_signals.js:130:42
  _emit@resource:///org/gnome/gjs/modules/core/_signals.js:119:10
  activate@resource:///org/gnome/shell/ui/status/keyboard.js:66:14
  _inputSourcesChanged@resource:///org/gnome/shell/ui/status/keyboard.js:661:33
  reload@resource:///org/gnome/shell/ui/status/keyboard.js:394:14
  _ibusSetContentType@resource:///org/gnome/shell/ui/status/keyboard.js:736:14
  _setContentType@resource:///org/gnome/shell/misc/ibusManager.js:264:14
17:51:52 gdm-session-wor: gkr-pam: unlocked login keyring
17:51:49 NetworkManager: <info>  [1736355109.5328] device (p2p-dev-wlp0s20f3): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
17:51:49 ModemManager: <msg> [sleep-monitor-systemd] system is resuming
17:51:49 NetworkManager: <info>  [1736355109.4250] manager: sleep: wake requested (sleeping: yes  enabled: yes)
17:51:49 systemd: Stopped target Suspend.
17:51:49 systemd-logind: Operation 'suspend' finished.
17:51:49 systemd: Reached target Suspend.
17:51:49 systemd-sleep: Successfully thawed unit 'user.slice'.
17:51:49 bluetoothd: Controller resume with wake event 0x0
17:51:49 systemd-sleep: System returned from sleep operation 'suspend'.
17:51:49 kernel: PM: suspend exit
17:51:49 kernel: random: crng reseeded on system resumption
17:51:49 kernel: Restarting tasks ... done.
17:51:49 kernel: OOM killer enabled.
17:51:49 kernel: mei_gsc_proxy 0000:00:16.0-0f73db04-97ab-4125-b893-e904ad0d5464: bound 0000:00:02.0 (ops xe_gsc_proxy_component_ops [xe])
17:51:49 kernel: ---[ end trace 0000000000000000 ]---
17:51:49 kernel:  </TASK>
17:51:49 kernel: Call Trace:
17:51:49 kernel: PKRU: 55555554
17:51:49 kernel: DR3: 0000000000000000 DR6: 00000000ffff07f0 DR7: 0000000000000400
17:51:49 kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
17:51:49 kernel: CR2: 0000777699880ea4 CR3: 0000000747622005 CR4: 0000000000f72ef0
17:51:49 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
17:51:49 kernel: FS:  0000000000000000(0000) GS:ffff978abf700000(0000) knlGS:0000000000000000
17:51:49 kernel: R13: 0000000000000001 R14: 0000000000000001 R15: 0000000000000000
17:51:49 kernel: R10: ffffffff8b2b5408 R11: 0000000000000003 R12: ffff978385fb96a0
17:51:49 kernel: RBP: fffffffffffffffb R08: 0000000000000000 R09: ffffa87846e53ae0
17:51:49 kernel: RDX: ffff978abf7218c8 RSI: 0000000000000001 RDI: ffff978abf7218c0
17:51:49 kernel: RAX: 0000000000000000 RBX: ffff9783901acd78 RCX: 0000000000000027
17:51:49 kernel: RSP: 0018:ffffa87846e53d20 EFLAGS: 00010286
17:51:49 kernel: Code: 08 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 63 e5 38 c9 49 89 e8 44 89 e9 4c 89 e2 48 89 c6 48 c7 c7 d8 ed a0 c0 e8 5b d8 a7 c8 <0f> 0b eb 9c 0f 1f 80 00 00 00 00 90 90 90 90 90 90 90 90 90 90 90
17:51:49 kernel: RIP: 0010:xe_guc_start+0x85/0x90 [xe]
17:51:49 kernel: Workqueue: async async_run_entry_fn
17:51:49 kernel: Hardware name: LENOVO 21NS000YFR/21NS000YFR, BIOS N4BET34W (1.06 ) 10/21/2024
17:51:49 kernel: CPU: 2 UID: 0 PID: 2211 Comm: kworker/u33:10 Not tainted 6.13.0-rc2-1-MANJARO #1 6d43e27d429ca07d76d7976ef33956c8e42d8727
17:51:49 kernel:  ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid xe serio_raw thinkpad_acpi atkbd drm_ttm_helper libps2 vivaldi_fmap ttm sparse_keymap nvme i2c_algo_bit platform_profile gpu_sched snd drm_buddy drm_suballoc_helper soundcore drm_gpuvm rfkill crc32c_intel drm_exec nvme_core video spi_intel_pci drm_display_helper nvme_auth spi_intel cec i8042 wmi serio
17:51:49 kernel: Modules linked in: snd_seq_dummy snd_hrtimer rfcomm snd_seq snd_seq_device qrtr cmac algif_hash algif_skcipher af_alg bnep snd_ctl_led snd_soc_sof_sdw snd_soc_intel_hda_dsp_common snd_sof_probes snd_soc_sdw_utils vfat fat joydev snd_soc_rt712_sdca snd_soc_rt1318_sdw regmap_sdw_mbq snd_hda_codec_hdmi regmap_sdw snd_soc_dmic snd_sof_pci_intel_lnl snd_sof_pci_intel_mtl snd_sof_intel_hda_generic soundwire_intel intel_uncore_frequency soundwire_cadence intel_uncore_frequency_common snd_sof_intel_hda_common x86_pkg_temp_thermal intel_powerclamp snd_soc_hdac_hda snd_sof_intel_hda_mlink coretemp snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof kvm_intel snd_sof_utils snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi_intel_sdca_quirks kvm soundwire_generic_allocation iwlmvm snd_soc_acpi crct10dif_pclmul soundwire_bus crc32_pclmul hid_multitouch snd_soc_sdca polyval_clmulni polyval_generic snd_soc_core ghash_clmulni_intel snd_compress mac80211 sha512_ssse3 ac97_bus mei_gsc_proxy snd_pcm_dmaengine
17:51:49 kernel: WARNING: CPU: 2 PID: 2211 at drivers/gpu/drm/xe/xe_guc.c:1149 xe_guc_start+0x85/0x90 [xe]
17:51:49 kernel: xe 0000:00:02.0: [drm] GT1: Failed to start GuC PC: -EIO
17:51:49 kernel: ------------[ cut here ]------------
17:51:49 kernel: xe 0000:00:02.0: [drm] *ERROR* GT1: GuC PC Start failed
17:51:49 kernel: nvme nvme0: 8/0/0 default/read/poll queues
17:51:49 kernel: pci 0000:00:0b.0: Setting to D3hot
17:51:49 kernel: ACPI: EC: interrupt unblocked
17:51:49 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
17:51:49 kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
17:51:49 kernel: OOM killer disabled.
17:51:49 kernel: Freezing user space processes completed (elapsed 0.002 seconds)
17:51:44 kernel: Filesystems sync: 0.016 seconds
17:51:44 kernel: PM: suspend entry (s2idle)
17:51:44 systemd-sleep: Performing sleep operation 'suspend'...
17:51:44 systemd: Starting System Suspend...
17:51:43 gnome-shell: Cursor update failed: drmModeAtomicCommit: Argument invalide
17:51:42 wpa_supplicant: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
17:51:42 gnome-shell: Extension x11gestures@joseexposito.github.io: TypeError: obj._toucheggTracker is undefined
Stack trace:
  unhook@file:///usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/src/v40/EntryPoint40.js:167:5
  stop@file:///usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/src/v40/EntryPoint40.js:156:23
  disable@file:///usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/extension.js:67:18
  _callExtensionDisable@resource:///org/gnome/shell/ui/extensionSystem.js:215:32
  _onEnabledExtensionsChanged@resource:///org/gnome/shell/ui/extensionSystem.js:637:24
  _sessionUpdated@resource:///org/gnome/shell/ui/extensionSystem.js:824:20
  ExtensionManager/<@resource:///org/gnome/shell/ui/extensionSystem.js:46:18
  _sync@resource:///org/gnome/shell/ui/sessionMode.js:205:14
  pushMode@resource:///org/gnome/shell/ui/sessionMode.js:167:14
  activate@resource:///org/gnome/shell/ui/screenShield.js:614:34
  lock@resource:///org/gnome/shell/ui/screenShield.js:681:14
  _prepareForSleep@resource:///org/gnome/shell/ui/screenShield.js:248:22
  _prepareForSleep@resource:///org/gnome/shell/misc/loginManager.js:212:14
  _convertToNativeSignal@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:152:19
17:51:42 wpa_supplicant: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
17:51:42 NetworkManager: <info>  [1736355102.4287] manager: NetworkManager state is now ASLEEP
17:51:42 ModemManager: <msg> [sleep-monitor-systemd] system is about to suspend
17:51:42 systemd-logind: The system will suspend now!
17:51:40 systemd: user-120.slice: Consumed 4.440s CPU time, 574.5M memory peak.
17:51:40 (sd-pam): pam_unix(systemd-user:session): session closed for user gdm
17:51:39 systemd: Reached target Exit the Session.
17:51:39 dbus-broker: Dispatched 446 messages @ 4(±9)μs / message.
17:51:39 systemd: Closed PipeWire Multimedia System Sockets.
17:51:39 wireplumber: wireplumber: disconnected from pipewire
17:51:39 systemd: Stopping Multimedia Service Session Manager...
17:51:32 mutter-x11-fram: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
17:51:32 systemd: Started Portal service.
17:51:31 rtkit-daemon: Supervising 13 threads of 7 processes of 2 users.
17:51:31 systemd: Started Portal service (GNOME implementation).
17:51:30 touchegg: New client connected
17:51:30 systemd: Reached target GNOME session X11 services.
17:51:29 gsd-xsettings: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
17:51:29 systemd-logind: Removed session 1.
17:51:29 systemd: session-1.scope: Consumed 3.781s CPU time, 541.6M memory peak.
17:51:29 gnome-keyring-d: discover_other_daemon: 1
17:51:29 xdg-document-po: Error releasing name org.freedesktop.portal.Documents: La connexion est fermée
17:51:29 systemd: run-user-120-doc.mount: Deactivated successfully.
17:51:29 gnome-shell: Execution of main.js threw exception: Module resource:///org/gnome/shell/ui/init.js threw an exception
17:51:29 xkbcomp: Errors from xkbcomp are not fatal to the X server
17:51:29 systemd: Starting GNOME XSettings service...
17:51:29 gsd-media-keys: Unable to get default sink
17:51:29 systemd: Reached target Current graphical user session.
17:51:29 wireplumber: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
17:51:29 gsd-media-keys: Failed to grab accelerator for keybinding settings:hibernate
17:51:29 bluetoothd: Endpoint registered: sender=:1.116 path=/MediaEndpoint/A2DPSource/opus_05_duplex
17:51:29 systemd: Reached target GNOME keyboard shortcuts target.
17:51:28 gnome-shell: [x11gestures@joseexposito.github.io] This extension is only for X11
17:51:28 rtkit-daemon: Supervising 14 threads of 8 processes of 2 users.
17:51:28 wireplumber: wp-internal-comp-loader: Loading profile 'main'
17:51:28 rtkit-daemon: Supervising 8 threads of 5 processes of 2 users.
17:51:28 systemd: Started PipeWire PulseAudio.
17:51:28 NetworkManager: <info>  [1736355088.5071] agent-manager: agent[22e8afe03d8d7130,:1.79/org.gnome.Shell.NetworkAgent/1000]: agent registered
17:51:28 gnome-shell: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
17:51:28 gsd-usb-protect: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
17:51:28 systemd: Started Virtual filesystem service - Apple File Conduit monitor.
17:51:27 evolution-calen: e_source_unset_last_credentials_required_arguments: assertion 'E_IS_SOURCE (source)' failed
17:51:27 systemd: Started Evolution calendar service.
17:51:27 udisksd: Acquired the name org.freedesktop.UDisks2 on the system message bus
17:51:27 systemd: Started dbus-:1.2-org.gnome.Identity@0.service.
17:51:27 goa-daemon: goa-daemon version 3.52.2 starting
17:51:27 kernel: nvme nvme0: using unchecked data buffer
17:51:27 systemd: Starting Evolution calendar service...
17:51:27 udisksd: udisks daemon version 2.10.1 starting
17:51:27 systemd: Started Application launched by gnome-session-binary.
17:51:27 touchegg: Starting Touchégg in client mode
17:51:27 systemd: Started GNOME file sharing service.
17:51:27 gnome-session-b: Entering running state
17:51:27 systemd: Starting Virtual filesystem service - disk device monitor...
17:51:27 kernel: rfkill: input handler disabled
17:51:27 systemd: Started GNOME printer notifications service.
17:51:27 gnome-shell: Will monitor session 3
17:51:27 at-spi2-registr: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
17:51:27 systemd: Started dbus-:1.21-org.a11y.atspi.Registry@0.service.
17:51:27 gnome-shell: Using Wayland display name 'wayland-0'
17:51:27 dbus-broker-lau: Ready
17:51:27 systemd: Started Accessibility services bus.
17:51:27 gnome-shell: Obtained a high priority EGL context
17:51:26 rtkit-daemon: Supervising 8 threads of 5 processes of 2 users.
17:51:26 gnome-shell: Running GNOME Shell (using mutter 47.3) as a Wayland display server
17:51:26 systemd: Started Virtual filesystem service.
17:51:26 gnome-keyring-d: discover_other_daemon: 1GNOME_KEYRING_CONTROL=/run/user/1000/keyring
17:51:26 gnome-session-b: WARNING: Desktop file /home/annick/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
17:51:26 systemd: Starting GNOME Session Manager (session: gnome)...
17:51:26 bluetoothd: Endpoint unregistered: sender=:1.60 path=/MediaEndpoint/A2DPSource/opus_05_duplex
17:51:26 gsd-media-keys: Unable to get default source
17:51:26 bluetoothd: Endpoint unregistered: sender=:1.60 path=/MediaEndpoint/A2DPSource/sbc
17:51:26 kernel: rfkill: input handler enabled
17:51:26 bluetoothd: Endpoint unregistered: sender=:1.60 path=/MediaEndpoint/A2DPSink/opus_g
17:51:26 gdm-session-wor: gkr-pam: unlocked login keyring
17:51:26 dbus-broker-lau: Ready
17:51:26 systemd: Startup finished in 235ms.
17:51:26 dbus-broker-lau: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
17:51:26 systemd: Starting D-Bus User Message Bus...
17:51:26 gnome-keyring-d: GNOME_KEYRING_CONTROL=/run/user/1000/keyring
17:51:26 systemd: Started GNOME Keyring daemon.
17:51:26 systemd-xdg-aut: /home/annick/.config/autostart/manjaro-app-folder-settings.desktop: not generating unit, executable specified in Exec= does not exist.
17:51:25 systemd-logind: New session 4 of user annick.
17:51:25 (systemd): pam_unix(systemd-user:session): session opened for user annick(uid=1000) by annick(uid=0)
17:51:25 systemd: Starting User Manager for UID 1000...
17:51:25 systemd-logind: New session 3 of user annick.
17:51:25 gdm-session-wor: pam_unix(gdm-password:session): session opened for user annick(uid=1000) by annick(uid=0)
17:51:23 NetworkManager: <info>  [1736355083.1163] manager: startup complete
17:51:23 wpa_supplicant: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
17:51:22 systemd: systemd-rfkill.service: Deactivated successfully.
17:51:21 ModemManager: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
17:51:21 systemd: Startup finished in 11.960s (firmware) + 6.011s (loader) + 3.644s (kernel) + 5.698s (userspace) = 27.315s.
17:51:21 gnome-shell: Registering session with GDM
17:51:21 gnome-keyring-d: GNOME_KEYRING_CONTROL=/run/user/120/keyring
17:51:21 systemd: Started GNOME Keyring daemon.
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Activating service name='org.freedesktop.secrets' requested by ':1.45' (uid=120 pid=1315 comm="/usr/lib/xdg-desktop-portal")
17:51:21 gsd-media-keys: Unable to get default sink
17:51:21 systemd: Started Fingerprint Authentication Daemon.
17:51:21 xdg-desktop-por: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 rtkit-daemon: Supervising 7 threads of 4 processes of 1 users.
17:51:21 xdg-desktop-por: unable to open file '/etc/dconf/db/site': L’ouverture du fichier « /etc/dconf/db/site » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
17:51:21 xdg-desktop-por: unable to open file '/etc/dconf/db/gdm': L’ouverture du fichier « /etc/dconf/db/gdm » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 kernel: usb 3-5.3: reset full-speed USB device number 5 using xhci_hcd
17:51:21 kernel: Bluetooth: RFCOMM ver 1.11
17:51:21 bluetoothd: Endpoint registered: sender=:1.60 path=/MediaEndpoint/A2DPSource/opus_05_duplex
17:51:21 wireplumber: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Activating service name='org.freedesktop.impl.portal.desktop.gnome' requested by ':1.45' (uid=120 pid=1315 comm="/usr/lib/xdg-desktop-portal")
17:51:21 gsd-media-keys: Failed to grab accelerator for keybinding settings:playback-repeat
17:51:21 gsd-xsettings: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 gnome-session-b: Entering running state
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Successfully activated service 'org.freedesktop.portal.IBus'
17:51:21 xkbcomp: Errors from xkbcomp are not fatal to the X server
17:51:21 systemd: Started Location Lookup Service.
17:51:21 geoclue: Failed to connect to avahi service: Daemon not running
17:51:21 wireplumber: wp-internal-comp-loader: Loading profile 'main'
17:51:21 rtkit-daemon: Supervising 1 threads of 1 processes of 1 users.
17:51:21 systemd: Starting Location Lookup Service...
17:51:21 systemd: Started PipeWire PulseAudio.
17:51:21 NetworkManager: <info>  [1736355081.1088] agent-manager: agent[0dffc945da60d603,:1.22/org.gnome.Shell.NetworkAgent/120]: agent registered
17:51:21 systemd: Starting Fingerprint Authentication Daemon...
17:51:21 gsd-usb-protect: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
17:51:21 gnome-shell: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
17:51:21 gjs: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Successfully activated service 'org.gnome.ScreenSaver'
17:51:21 gsd-sharing: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
17:51:21 gsd-housekeepin: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 gsd-power: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Activating service name='org.freedesktop.portal.IBus' requested by ':1.22' (uid=120 pid=991 comm="ibus-daemon --panel disable")
17:51:21 gsd-media-keys: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 kernel: rfkill: input handler disabled
17:51:21 gsd-a11y-settin: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:21 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=985 comm="/usr/lib/gsd-usb-protection")
17:51:21 gsd-datetime: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:20 systemd: Started Daemon for power management.
17:51:20 gsd-keyboard: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:20 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Successfully activated service 'org.gnome.Shell.Notifications'
17:51:20 systemd: Started Locale Service.
17:51:20 gnome-shell: Window manager warning: Failed to parse saved session file: L’ouverture du fichier « /var/lib/gdm/.config/mutter/sessions/108feacbad7ae873b173635508029860800000008430000.ms » a échoué : Aucun fichier ou dossier de ce nom
17:51:20 systemd: Starting Daemon for power management...
17:51:20 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=855 comm="/usr/bin/gnome-shell")
17:51:20 systemd: Starting Locale Service...
17:51:20 dbus-broker-lau: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
17:51:20 gnome-shell: Will monitor session 1
17:51:20 systemd: Started Manage, Install and Generate Color Profiles.
17:51:20 at-spi2-registr: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
17:51:20 dbus-daemon: dbus-daemon[910]: Successfully activated service 'org.a11y.atspi.Registry'
17:51:20 systemd: Starting Manage, Install and Generate Color Profiles...
17:51:20 dbus-daemon: dbus-daemon[910]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=855 comm="/usr/bin/gnome-shell")
17:51:20 gnome-shell: Using Wayland display name 'wayland-0'
17:51:20 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Successfully activated service 'org.a11y.Bus'
17:51:20 at-spi-bus-laun: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
17:51:20 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=855 comm="/usr/bin/gnome-shell")
17:51:20 gnome-shell: Obtained a high priority EGL context
17:51:20 rtkit-daemon: Supervising 1 threads of 1 processes of 1 users.
17:51:20 systemd: Started RealtimeKit Scheduling Policy Service.
17:51:20 gnome-shell: Running GNOME Shell (using mutter 47.3) as a Wayland display server
17:51:20 gnome-session-b: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
17:51:20 dbus-daemon: dbus-daemon[842]: [session uid=120 pid=842] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
17:51:20 gnome-session-b: unable to open file '/etc/dconf/db/distro': L’ouverture du fichier « /etc/dconf/db/distro » a échoué : échec de open() : Aucun fichier ou dossier de ce nom; expect degraded performance
17:51:20 dbus-broker-lau: Ready
17:51:20 systemd: Started D-Bus User Message Bus.
17:51:20 dbus-broker-lau: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
17:51:20 systemd: Starting D-Bus User Message Bus...
17:51:20 systemd-logind: New session 2 of user gdm.
17:51:20 (systemd): pam_unix(systemd-user:session): session opened for user gdm(uid=120) by gdm(uid=0)
17:51:20 dbus-broker-lau: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
17:51:20 systemd: Starting User Manager for UID 120...
17:51:19 systemd-logind: New session 1 of user gdm.
17:51:19 systemd: Started Accounts Service.
17:51:19 accounts-daemon: started daemon version 23.13.0
17:51:19 systemd: Starting Accounts Service...
17:51:19 NetworkManager: <info>  [1736355079.0245] device (p2p-dev-wlp0s20f3): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
17:51:18 systemd: Started WPA supplicant.
17:51:18 wpa_supplicant: Successfully initialized wpa_supplicant
17:51:18 systemd: Starting WPA supplicant...
17:51:18 NetworkManager: <info>  [1736355078.9147] modem-manager: ModemManager now available
17:51:18 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
17:51:18 NetworkManager: <info>  [1736355078.4180] device (wlp0s20f3): set-hw-addr: set MAC address to 3A:0C:34:0D:CF:F5 (scanning)
17:51:18 kernel: iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
17:51:17 systemd: Started Thunderbolt system service.
17:51:17 boltd: [e71d8780-4163-Gen16                      ] dbus: exported device at /org/freedesktop/bolt/devices/e71d8780_4163...
17:51:17 touchegg: 	finish_threshold_vertical: 241.402
17:51:17 systemd: Started Modem Manager.
17:51:17 kernel: NET: Registered PF_QIPCRTR protocol family
17:51:17 systemd: Started GNOME Display Manager.
17:51:17 boltd: power: state located at: /run/boltd/power
17:51:17 ModemManager: <msg> ModemManager (version 1.22.0-1) starting in system bus...
17:51:17 systemd: Starting Hold until boot process finishes up...
17:51:17 boltd: bolt 0.9.8 starting up.
17:51:17 systemd: Started Network Manager Script Dispatcher Service.
17:51:17 NetworkManager: <info>  [1736355077.8434] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
17:51:17 systemd: Started Hostname Service.
17:51:17 kernel: iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
17:51:17 polkitd: Started polkitd version 125
17:51:17 NetworkManager: <info>  [1736355077.7962] manager[0x58e480f577b0]: monitoring kernel firmware directory '/lib/firmware'.
17:51:17 systemd: Reached target Sound Card.
17:51:17 alsactl: alsa-lib main.c:2456:(set_fixedboot_user) Unable to execute force boot sequence
17:51:17 kernel: NET: Registered PF_ALG protocol family
17:51:17 systemd: Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
17:51:17 kernel: Bluetooth: MGMT ver 1.23
17:51:17 systemd: Starting Save/Restore Sound Card State...
17:51:17 bluetoothd: Battery Provider Manager created
17:51:17 systemd: Started User Login Management.
17:51:17 systemd-logind: Watching system buttons on /dev/input/event4 (ThinkPad Extra Buttons)
17:51:17 systemd: Starting Hostname Service...
17:51:17 systemd-logind: Watching system buttons on /dev/input/event2 (Power Button)
17:51:17 systemd: Reached target Bluetooth Support.
17:51:17 systemd-logind: New seat seat0.
17:51:17 NetworkManager: <info>  [1736355077.7201] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
17:51:17 dbus-broker-lau: Ready
17:51:17 systemd: Started Touchégg Daemon.
17:51:17 bluetoothd: Bluetooth management interface 1.23 initialized
17:51:17 systemd: Started Daily rotation of log files.
17:51:17 bluetoothd: src/plugin.c:init_plugin() System does not support asha plugin
17:51:17 systemd: Started Discard unused filesystem blocks once a week.
17:51:17 bluetoothd: src/plugin.c:init_plugin() System does not support csip plugin
17:51:17 systemd: Started Discard unused blocks on a mounted filesystem.
17:51:17 bluetoothd: src/plugin.c:init_plugin() System does not support ccp plugin
17:51:17 systemd: Started Scrub btrfs filesystem, verify block checksums.
17:51:17 bluetoothd: src/plugin.c:init_plugin() System does not support micp plugin
17:51:17 touchegg: A list of detected compatible devices will be displayed below:
17:51:17 systemd: Started Balance block groups on a btrfs filesystem.
17:51:17 bluetoothd: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
17:51:17 systemd: Started Refresh existing PGP keys of archlinux-keyring regularly.
17:51:17 bluetoothd: src/plugin.c:init_plugin() System does not support vcp plugin
17:51:17 systemd: Reached target System Time Set.
17:51:17 bluetoothd: src/plugin.c:init_plugin() System does not support mcp plugin
17:51:17 systemd: Reached target Path Units.
17:51:17 bluetoothd: src/plugin.c:init_plugin() System does not support bass plugin
17:51:17 systemd: Started Daily Cleanup of Temporary Directories.
17:51:17 bluetoothd: src/plugin.c:init_plugin() System does not support bap plugin
17:51:17 systemd: Started CUPS Scheduler.
17:51:17 bluetoothd: Starting SDP server
17:51:17 systemd: Reached target System Initialization.
17:51:17 bluetoothd: Bluetooth daemon 5.79
17:51:17 systemd: Started Network Time Synchronization.
17:51:17 kernel: input: sof-soundwire HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sof_sdw/sound/card0/input20
17:51:17 kernel: iwlwifi 0000:00:14.3: base HW address: 88:f4:da:d7:66:c6
17:51:17 kernel: sof_sdw sof_sdw: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
17:51:17 kernel: Bluetooth: BNEP socket layer initialized
17:51:17 kernel: iwlwifi 0000:00:14.3: Detected RF FM, rfid=0x20112200
17:51:17 kernel: sof_sdw sof_sdw: ASoC: Parent card not yet available, widget card binding deferred
17:51:17 kernel: sof-audio-pci-intel-lnl 0000:00:1f.3: Topology: ABI 3:29:1 Kernel ABI 3:23:1
17:51:17 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
17:51:17 kernel: sof-audio-pci-intel-lnl 0000:00:1f.3: Booted firmware version: 2.11.1.1
17:51:17 systemd: Finished Record System Boot/Shutdown in UTMP.
17:51:17 kernel: typec port1: bound usb2-port3 (ops connector_ops)
17:51:17 systemd: Finished Tell Plymouth To Write Out Runtime Data.
17:51:17 kernel: hid-multitouch 0018:2C2F:0028.0002: input,hidraw1: I2C HID v1.00 Mouse [SNSL0028:00 2C2F:0028] on i2c-SNSL0028:00
17:51:17 kernel: input: SNSL0028:00 2C2F:0028 Touchpad as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-13/i2c-SNSL0028:00/0018:2C2F:0028.0002/input/input15
17:51:17 kernel: sof-audio-pci-intel-lnl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.11.1.1
17:51:17 kernel: acpi device:2c: patch_sdca_function_type: found SDCA function SmartAmp (type 1)
17:51:17 kernel: sof-audio-pci-intel-lnl 0000:00:1f.3: use msi interrupt mode
17:51:17 systemd: Repartition Root Disk was skipped because no trigger condition checks were met.
17:51:17 kernel: input: TPPS/2 Elan TrackPoint as /devices/platform/i8042/serio1/input/input10
17:51:17 kernel: psmouse serio1: trackpoint: Elan TrackPoint firmware: 0x00, buttons: 3/3
17:51:17 kernel: hid-generic 0018:2C2F:0028.0002: input,hidraw1: I2C HID v1.00 Mouse [SNSL0028:00 2C2F:0028] on i2c-SNSL0028:00
17:51:17 kernel: input: SNSL0028:00 2C2F:0028 Touchpad as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-13/i2c-SNSL0028:00/0018:2C2F:0028.0002/input/input12
17:51:17 kernel: typec port0: bound usb2-port1 (ops connector_ops)
17:51:17 kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
17:51:17 kernel: intel-lpss 0000:00:15.3: enabling device (0000 -> 0002)
17:51:17 systemd: Started Load/Save RF Kill Switch Status.
17:51:17 systemd-vconsol: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
17:51:17 systemd: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
17:51:17 kernel: Bluetooth: hci0: Firmware Version: 160-24.24
17:51:17 kernel: mei_gsc_proxy 0000:00:16.0-0f73db04-97ab-4125-b893-e904ad0d5464: bound 0000:00:02.0 (ops xe_gsc_proxy_component_ops [xe])
17:51:17 kernel: Bluetooth: hci0: Waiting for device to boot
17:51:17 kernel: snd_hda_intel 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
17:51:17 kernel: usbcore: registered new interface driver uvcvideo
17:51:17 kernel: intel_rapl_common: Found RAPL domain psys
17:51:17 kernel: usb 3-4: Found UVC 1.50 device Integrated Camera (30c9:005f)
17:51:17 kernel: PTP clock support registered
17:51:17 kernel: AES CTR mode by8 optimization enabled
17:51:17 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
17:51:17 kernel: iwlwifi 0000:00:14.3: loaded firmware version 94.62990553.0 bz-b0-fm-c0-94.ucode op_mode iwlmvm
17:51:17 kernel: cryptd: max_cpu_qlen set to 1000
17:51:17 kernel: iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
17:51:17 kernel: Intel(R) Wireless WiFi driver for Linux
17:51:17 kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
17:51:17 kernel: proc_thermal_pci 0000:00:04.0: msi enabled:1 msix enabled:0
17:51:17 kernel: btintel_pcie 0000:00:14.7: enabling device (0000 -> 0002)
17:51:17 kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
17:51:17 kernel: intel_rapl_common: Found RAPL domain dram
17:51:17 kernel: proc_thermal_pci 0000:00:04.0: enabling device (0400 -> 0402)
17:51:17 kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
17:51:16 kernel: intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
17:51:16 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
17:51:16 kernel: spi-nor spi0.0: unrecognized JEDEC id bytes: f7 c0 30 09 03 00
17:51:16 kernel: input: PC Speaker as /devices/platform/pcspkr/input/input9
17:51:16 kernel: videodev: Linux video capture interface: v2.00
17:51:16 systemd: Starting Load/Save Screen Backlight Brightness of leds:tpacpi::kbd_backlight...
17:51:16 kernel: Bluetooth: SCO socket layer initialized
17:51:16 kernel: NET: Registered PF_BLUETOOTH protocol family
17:51:16 kernel: Bluetooth: Core ver 2.22
17:51:16 kernel: mc: Linux media interface: v0.10
17:51:16 kernel: ACPI: bus type thunderbolt registered
17:51:16 kernel: intel_vpu 0000:00:0b.0: probe with driver intel_vpu failed with error -2
17:51:16 systemd: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
17:51:16 kernel: bus: 3, device: 5 was not an MTP device
17:51:16 systemd: Created slice Slice /system/systemd-backlight.
17:51:16 kernel: checking bus 3, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.3"
17:51:16 mtp-probe: bus: 3, device: 3 was not an MTP device
17:51:16 systemd: Finished Load AppArmor profiles.
17:51:16 kernel: mousedev: PS/2 mouse device common for all mice
17:51:16 kernel: intel_pmc_core INT33A1:00:  initialized
17:51:16 kernel: pci 0000:00:0b.0: Setting to D3hot
17:51:16 kernel: intel_vsec 0000:00:0a.0: enabling device (0000 -> 0002)
17:51:16 kernel: Consider using thermal netlink events interface
17:51:16 kernel: input: Intel HID events as /devices/platform/INTC1070:00/input/input8
17:51:16 systemd: Finished File System Check on /dev/disk/by-uuid/E7A8-D76B.
17:51:16 fsck.vfat: /dev/nvme0n1p1: 5 files, 72/76646 clusters
17:51:16 systemd: Starting File System Check on /dev/disk/by-uuid/E7A8-D76B...
17:51:16 kernel: bus: 3, device: 2 was not an MTP device
17:51:16 kernel: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
17:51:16 systemd: Activated swap /dev/disk/by-uuid/648bdd64-54a8-425b-b79a-30ce76ef5fde.
17:51:16 kernel: Adding 35618888k swap on /dev/nvme0n1p3.  Priority:-2 extents:1 across:35618888k SS
17:51:16 systemd: Activating swap /dev/disk/by-uuid/648bdd64-54a8-425b-b79a-30ce76ef5fde...
17:51:16 systemd-journal: Received client request to flush runtime journal.
17:51:16 ufw-init: Skip starting firewall: ufw (not enabled)
17:51:16 systemd: Started User Database Manager.
17:51:16 kernel: Started Journal Service.
17:51:16 apparmor.system: Reloading AppArmor profiles
17:51:16 kernel: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
17:51:16 kernel: Inserted module 'sg'
17:51:16 systemd-journal: Runtime Journal (/run/log/journal/5fd7397b751046788e2fd211c2919627) is 8M, max 1.5G, 1.5G free.
17:51:16 kernel: Starting CLI Netfilter Manager...
17:51:16 kernel: Finished Apply Kernel Variables.
17:51:16 kernel: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17:51:16 kernel: Starting Load/Save OS Random Seed...
17:51:16 kernel: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
17:51:16 kernel: Finished Remount Root and Kernel File Systems.
17:51:16 kernel: EXT4-fs (nvme0n1p2): re-mounted 666e9e23-4fee-476f-b365-af1960b5f6f4 r/w. Quota mode: none.
17:51:16 kernel: Starting User Database Manager...
17:51:16 kernel: audit: type=1400 audit(1736355076.546:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=392 comm="apparmor_parser"
17:51:16 kernel: Mounted Kernel Configuration File System.
17:51:16 kernel: audit: type=1400 audit(1736355076.539:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=383 comm="apparmor_parser"
17:51:16 kernel: Starting Apply Kernel Variables...
17:51:16 kernel: Repartition Root Disk was skipped because no trigger condition checks were met.
17:51:16 kernel: Mounted FUSE Control File System.
17:51:16 kernel: Finished Load Kernel Modules.
17:51:16 kernel: modprobe@dm_mod.service: Deactivated successfully.
17:51:16 kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
17:51:16 kernel: Finished Load udev Rules from Credentials.
17:51:16 kernel: Starting Create Static Device Nodes in /dev gracefully...
17:51:16 kernel: Mounting Kernel Configuration File System...
17:51:16 kernel: Finished Load Kernel Module loop.
17:51:16 kernel: modprobe@loop.service: Deactivated successfully.
17:51:16 kernel: Finished Load Kernel Module fuse.
17:51:16 kernel: modprobe@fuse.service: Deactivated successfully.
17:51:16 kernel: Finished Load Kernel Module drm.
17:51:16 kernel: modprobe@drm.service: Deactivated successfully.
17:51:16 systemd-journal: Collecting audit messages is disabled.
17:51:16 kernel: Finished Load Kernel Module configfs.
17:51:16 kernel: modprobe@configfs.service: Deactivated successfully.
17:51:16 kernel: Finished Create List of Static Device Nodes.
17:51:16 kernel: Mounted Kernel Trace File System.
17:51:16 kernel: Starting Virtual Console Setup...
17:51:16 kernel: loop: module loaded
17:51:16 kernel: Starting Coldplug All udev Devices...
17:51:16 kernel: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17:51:16 kernel: Starting Remount Root and Kernel File Systems...
17:51:16 kernel: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17:51:16 kernel: Starting Load Kernel Modules...
17:51:16 kernel: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
17:51:16 kernel: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
17:51:16 kernel: Starting Load Kernel Module loop...
17:51:16 kernel: Mounting Kernel Trace File System...
17:51:16 kernel: Listening on User Database Manager Socket.
17:51:16 kernel: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17:51:16 kernel: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17:51:16 kernel: Listening on Journal Sockets.
17:51:16 kernel: Reached target Local Verity Protected Volumes.
17:51:16 kernel: Expecting device /dev/disk/by-uuid/E7A8-D76B...
17:51:16 kernel: Set up automount Arbitrary Executable File Formats File System Automount Point.
17:51:16 kernel: Started Forward Password Requests to Wall Directory Watch.
17:51:16 kernel: Created slice User and Session Slice.
17:51:16 kernel: Queued start job for default target Graphical Interface.
17:51:16 kernel: bpf-restrict-fs: LSM BPF program attached
17:51:16 kernel: Hostname set to <annick-laptop>.
17:51:16 kernel: Detected architecture x86-64.
17:51:16 kernel: systemd 256.9-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
17:51:16 kernel: EXT4-fs (nvme0n1p2): mounted filesystem 666e9e23-4fee-476f-b365-af1960b5f6f4 r/w with ordered data mode. Quota mode: none.
17:51:16 kernel: PM: Image not found (code -22)
17:51:16 kernel: xe 0000:00:02.0: [drm] Selective fetch area calculation failed in pipe A
17:51:16 kernel: usb 3-5.3: SerialNumber: UID24B392BE_XXXX_MOC_B0
17:51:16 kernel: xe 0000:00:02.0: [drm] GT1: found GSC cv104.1.0
17:51:16 kernel: fbcon: Deferring console take-over
17:51:16 kernel: hid-generic 0003:1267:0210.0001: input,hidraw0: USB HID v1.00 Mouse [PS/2+USB Mouse] on usb-0000:00:14.0-1/input0
17:51:16 kernel: input: PS/2+USB Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/0003:1267:0210.0001/input/input7
17:51:16 kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
17:51:16 kernel: usbhid: USB HID core driver
17:51:16 kernel: usbcore: registered new interface driver usbhid
17:51:16 kernel: [drm] Initialized xe 1.1.0 for 0000:00:02.0 on minor 0
17:51:16 kernel: hub 3-5:1.0: 3 ports detected
17:51:16 kernel: usb 3-5: Product: USB2.0 Hub
17:51:16 kernel: xe 0000:00:02.0: [drm] vecs3 fused off
17:51:16 kernel: usb 3-5: new high-speed USB device number 4 using xhci_hcd
17:51:16 kernel: xe 0000:00:02.0: [drm] Finished loading DMC firmware i915/xe2lpd_dmc.bin (v2.24)
17:51:16 kernel: usb 3-4: new high-speed USB device number 3 using xhci_hcd
17:51:16 kernel: xe 0000:00:02.0: [drm] Found lunarlake (device ID 64a0) display version 20.00 stepping B0
17:51:16 kernel: usb 3-1: Product: PS/2+USB Mouse
17:51:16 kernel: input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input4
17:51:16 kernel: ACPI: battery: new extension: ThinkPad Battery Extension
17:51:16 kernel: thinkpad_acpi: battery 1 registered (start 0, stop 100, behaviours: 0x7)
17:51:16 kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
17:51:16 kernel:  nvme0n1: p1 p2 p3
17:51:16 kernel: nvme nvme0: 8/0/0 default/read/poll queues
17:51:16 kernel: usb 3-1: new low-speed USB device number 2 using xhci_hcd
17:51:16 kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
17:51:16 kernel: i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
17:51:16 kernel:     BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
17:51:16 kernel: Run /init as init process
17:51:16 kernel: rodata_test: all tests were successful
17:51:16 kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
17:51:16 kernel: Freeing unused kernel image (rodata/data gap) memory: 1944K
17:51:16 kernel: Write protecting the kernel read-only data: 34816k
17:51:16 kernel: Freeing unused kernel image (initmem) memory: 4296K
17:51:16 kernel: PM: genpd: Disabling unused power domains
17:51:16 kernel: clk: Disabling unused clocks
17:51:16 kernel: RAS: Correctable Errors collector initialized.
17:51:16 kernel: PM:   Magic number: 9:605:893
17:51:16 kernel: integrity: Loaded X.509 cert 'Microsoft Corporation: Windows UEFI CA 2023: aefc5fbbbe055d8f8daa585473499417ab5a5272'
17:51:16 kernel: AppArmor: AppArmor sha256 policy hashing enabled
17:51:16 kernel: Key type fscrypt-provisioning registered
17:51:16 kernel: Demotion targets for Node 0: null
17:51:16 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 55631fc73f03fd81fdf535fcfd4b8b871b3c8a46'
17:51:16 kernel: Loading compiled-in X.509 certificates
17:51:16 kernel: registered taskstats version 1
17:51:16 kernel: sched_clock: Marking stable (1094650447, 6522803)->(1137438104, -36264854)
17:51:16 kernel: IPI shorthand broadcast: enabled
17:51:16 kernel: microcode: Current revision: 0x00000116
17:51:16 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
17:51:16 kernel: NET: Registered PF_PACKET protocol family
17:51:16 kernel: In-situ OAM (IOAM) with IPv6
17:51:16 kernel: RPL Segment Routing with IPv6
17:51:16 kernel: Segment Routing with IPv6
17:51:16 kernel: NET: Registered PF_INET6 protocol family
17:51:16 kernel: drop_monitor: Initializing network drop monitor service
17:51:16 kernel: hid: raw HID events driver (C) Jiri Kosina
17:51:16 kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
17:51:16 kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
17:51:16 kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
17:51:16 kernel: Relocating firmware framebuffer to offset 0x0000000000800000[d] within [mem 0x2000000000-0x200fffffff flags 0x14220c]
17:51:16 kernel: intel_pstate: HWP enabled
17:51:16 kernel: Hybrid CPU capacity scaling enabled
17:51:16 kernel: intel_pstate: Intel P-state driver initializing
17:51:16 kernel: rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
17:51:16 kernel: usbserial: USB Serial support registered for generic
17:51:16 kernel: usbcore: registered new interface driver usbserial_generic
17:51:16 kernel: hub 4-0:1.0: 2 ports detected
17:51:16 kernel: usb usb4: SerialNumber: 0000:00:14.0
17:51:16 kernel: hub 3-0:1.0: 8 ports detected
17:51:16 kernel: usb usb3: SerialNumber: 0000:00:14.0
17:51:16 kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
17:51:16 kernel: hub 2-0:1.0: 3 ports detected
17:51:16 kernel: usb usb2: SerialNumber: 0000:00:0d.0
17:51:16 kernel: hub 1-0:1.0: 1 port detected
17:51:16 kernel: usb usb1: SerialNumber: 0000:00:0d.0
17:51:16 kernel: xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
17:51:16 kernel: ACPI: bus type drm_connector registered
17:51:16 kernel: Freeing initrd memory: 29080K
17:51:16 kernel: tpm_tis STM0925:00: 2.0 TPM (device-id 0x3, rev-id 1)
17:51:16 kernel: Linux agpgart interface v0.103
17:51:16 kernel: Non-volatile memory driver v1.3
17:51:16 kernel: hpet_acpi_add: no address or irqs in _CRS
17:51:16 kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
17:51:16 kernel: ACPI: thermal: Thermal Zone [THM0] (32 C)
17:51:16 kernel: thermal LNXTHERM:00: registered as thermal_zone0
17:51:16 kernel: ACPI: button: Power Button [PWRB]
17:51:16 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
17:51:16 kernel: ACPI: button: Lid Switch [LID]
17:51:16 kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
17:51:16 kernel: ACPI: button: Sleep Button [SLPB]
17:51:16 kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
17:51:16 kernel: ACPI: AC: AC Adapter [AC] (on-line)
17:51:16 kernel: Monitor-Mwait will be used to enter C-3 state
17:51:16 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
17:51:16 kernel: pcieport 0000:00:1c.4: PME: Signaling with IRQ 123
17:51:16 kernel: ledtrig-cpu: registered to indicate activity on CPUs
17:51:16 kernel: io scheduler bfq registered
17:51:16 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
17:51:16 kernel: Asymmetric key parser 'x509' registered
17:51:16 kernel: Key type asymmetric registered
17:51:16 kernel: integrity: Machine keyring initialized
17:51:16 kernel: fuse: init (API version 7.41)
17:51:16 kernel: workingset: timestamp_bits=36 max_order=23 bucket_order=0
17:51:16 kernel: Key type blacklist registered
17:51:16 kernel: Initialise system trusted keyrings
17:51:16 kernel: Trying to unpack rootfs image as initramfs...
17:51:16 kernel: platform rtc_cmos: registered platform RTC device (no PNP device found)
17:51:16 kernel: clocksource: Switched to clocksource tsc
17:51:16 kernel: software IO TLB: mapped [mem 0x000000007f765000-0x0000000083765000] (64MB)
17:51:16 kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
17:51:16 kernel: PCI: CLS 0 bytes, default 64
17:51:16 kernel: pci 0000:00:0d.0: enabling device (0000 -> 0002)
17:51:16 kernel: pci_bus 0000:04: resource 1 [mem 0xbc400000-0xbc4fffff]
17:51:16 kernel: pci 0000:00:1c.4:   bridge window [mem 0xbc400000-0xbc4fffff]
17:51:16 kernel: NET: Registered PF_XDP protocol family
17:51:16 kernel: UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
17:51:16 kernel: UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
17:51:16 kernel: MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
17:51:16 kernel: TCP: Hash tables configured (established 262144 bind 65536)
17:51:16 kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
17:51:16 kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
17:51:16 kernel: tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
17:51:16 kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
17:51:16 kernel: NET: Registered PF_INET protocol family
17:51:16 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
17:51:16 kernel: pnp: PnP ACPI: found 9 devices
17:51:16 kernel: system 00:08: [mem 0xfed4c000-0xffffffff] could not be reserved
17:51:16 kernel: pnp 00:08: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
17:51:16 kernel: system 00:07: [io  0x1854-0x1857] has been reserved
17:51:16 kernel: pnp: PnP ACPI init
17:51:16 kernel: AppArmor: AppArmor Filesystem Enabled
17:51:16 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
17:51:16 kernel: clocksource: Switched to clocksource tsc-early
17:51:16 kernel: vgaarb: loaded
17:51:16 kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=mem,locks=none
17:51:16 kernel: e820: reserve RAM buffer [mem 0x85f800000-0x85fffffff]
17:51:16 kernel: pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]: can't claim; no compatible bridge window
17:51:16 kernel: PCI: pci_cache_line_size set to 64 bytes
17:51:16 kernel: NET: Registered PF_MCTP protocol family
17:51:16 kernel: mctp: management component transport protocol core
17:51:16 kernel: NetLabel:  unlabeled traffic allowed by default
17:51:16 kernel: efivars: Registered efivars operations
17:51:16 kernel: EDAC MC: Ver: 3.0.0
17:51:16 kernel: usbcore: registered new device driver usb
17:51:16 kernel: ACPI: bus type USB registered
17:51:16 kernel: libata version 3.00 loaded.
17:51:16 kernel: SCSI subsystem initialized
17:51:16 kernel: iommu: DMA domain TLB invalidation policy: lazy mode
17:51:16 kernel: ACPI: \_SB_.PC00.LPCB.EC__: EC: Used to handle transactions and events
17:51:16 kernel: Low-power S0 idle used by default for system suspend
17:51:16 kernel: ACPI: \_SB_.PEPD: Duplicate LPS0 _DSM functions (mask: 0x1)
17:51:16 kernel: pci 0000:00:1c.4: PCI bridge to [bus 04]
17:51:16 kernel: pci_bus 0000:00: root bus resource [bus 00-fe]
17:51:16 kernel: PCI host bridge to bus 0000:00
17:51:16 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
17:51:16 kernel: ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
17:51:16 kernel: PCI: Ignoring E820 reservations for host bridge windows
17:51:16 kernel: ACPI: Using IOAPIC for interrupt routing
17:51:16 kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
17:51:16 kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
17:51:16 kernel: PCI: Using configuration type 1 for base access
17:51:16 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
17:51:16 kernel: cpuidle: using governor menu
17:51:16 kernel: thermal_sys: Registered thermal governor 'power_allocator'
17:51:16 kernel: audit: type=2000 audit(1736355073.013:1): state=initialized audit_enabled=0 res=1
17:51:16 kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
17:51:16 kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
17:51:16 kernel: PM: RTC time: 16:51:13, date: 2025-01-08
17:51:16 kernel: pinctrl core: initialized pinctrl subsystem
17:51:16 kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
17:51:16 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
17:51:16 kernel: ACPI: PM: Registering ACPI NVS region [mem 0x54e2f000-0x55a2efff] (12582912 bytes)
17:51:16 kernel: x86/mm: Memory block size: 128MB
17:51:16 kernel: devtmpfs: initialized
17:51:16 kernel: Memory: 32320708K/33064760K available (18432K kernel code, 2692K rwdata, 14440K rodata, 4296K init, 3948K bss, 722684K reserved, 0K cma-reserved)
17:51:16 kernel: smpboot: Total of 8 processors activated (52859.00 BogoMIPS)
17:51:16 kernel: smp: Brought up 1 node, 8 CPUs
17:51:16 kernel: ... event mask:             00000077000000ff
17:51:16 kernel: core: cpu_atom PMU driver:
17:51:16 kernel: .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
17:51:16 kernel: smpboot: x86: Booting SMP configuration:
17:51:16 kernel: smp: Bringing up secondary CPUs ...
17:51:16 kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
17:51:16 kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
17:51:16 kernel: rcu: 	Max phase no-delay instances is 1000.
17:51:16 kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1303
17:51:16 kernel: signal: max sigframe size: 3632
17:51:16 kernel: ... event mask:             0001000f000003ff
17:51:16 kernel: core: cpu_core PMU driver:
17:51:16 kernel: Performance Events: XSAVE Architectural LBR, no PEBS fmt6+,  AnyThread deprecated, Lunarlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
17:51:16 kernel: smpboot: CPU0: Intel(R) Core(TM) Ultra 7 258V (family: 0x6, model: 0xbd, stepping: 0x1)
17:51:16 kernel: Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
17:51:16 kernel: Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
17:51:16 kernel: AppArmor: AppArmor initialized
17:51:16 kernel: LSM support for eBPF active
17:51:16 kernel: Yama: becoming mindful.
17:51:16 kernel: landlock: Up and running.
17:51:16 kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
17:51:16 kernel: pid_max: default: 32768 minimum: 301
17:51:16 kernel: Freeing SMP alternatives memory: 40K
17:51:16 kernel: x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
17:51:16 kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
17:51:16 kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
17:51:16 kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
17:51:16 kernel: CET detected: Indirect Branch Tracking enabled
17:51:16 kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
17:51:16 kernel: CPU0: Thermal monitoring enabled (TM1)
17:51:16 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6607.00 BogoMIPS (lpj=11008000)
17:51:16 kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2f9a2767029, max_idle_ns: 440795219692 ns
17:51:16 kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
17:51:16 kernel: DMAR: SATC flags: 0x1
17:51:16 kernel: APIC: Switch to symmetric I/O mode setup
17:51:16 kernel: hpet: HPET dysfunctional in PC10. Force disabled.
17:51:16 kernel: ACPI: Core revision 20240827
17:51:16 kernel: printk: legacy console [tty0] enabled
17:51:16 kernel: Console: colour dummy device 80x25
17:51:16 kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
17:51:16 kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
17:51:16 kernel: NR_IRQS: 524544, nr_irqs: 2048, preallocated irqs: 16
17:51:16 kernel: RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
17:51:16 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
17:51:16 kernel: 	Tracing variant of Tasks RCU enabled.
17:51:16 kernel: 	Rude variant of Tasks RCU enabled.
17:51:16 kernel: 	Trampoline variant of Tasks RCU enabled.
17:51:16 kernel: rcu: 	RCU priority boosting: priority 1 delay 500 ms.
17:51:16 kernel: Dynamic Preempt: full
17:51:16 kernel: ftrace: allocated 202 pages with 4 groups
17:51:16 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
17:51:16 kernel: software IO TLB: area num 8.
17:51:16 kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
17:51:16 kernel: Policy zone: Normal
17:51:16 kernel: Built 1 zonelists, mobility grouping on.  Total pages: 8266190
17:51:16 kernel: Fallback order for Node 0: 0
17:51:16 kernel: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
17:51:16 kernel: Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
17:51:16 kernel: printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
17:51:16 kernel: Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64", will be passed to user space.
17:51:16 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64 root=UUID=666e9e23-4fee-476f-b365-af1960b5f6f4 rw quiet splash apparmor=1 security=apparmor resume=UUID=648bdd64-54a8-425b-b79a-30ce76ef5fde udev.log_priority=3
17:51:16 kernel: pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
17:51:16 kernel: percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
17:51:16 kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
17:51:16 kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
17:51:16 kernel: Booting paravirtualized kernel on bare hardware
17:51:16 kernel: [mem 0xa0800000-0xfed1ffff] available for PCI devices
17:51:16 kernel: PM: hibernation: Registered nosave memory: [mem 0x100000000-0x1043fffff]
17:51:16 kernel: CPU topo: Allowing 8 present CPUs plus 0 hotplug CPUs
17:51:16 kernel: TSC deadline timer available
17:51:16 kernel: e820: update [mem 0x83765000-0x838a9fff] usable ==> reserved
17:51:16 kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
17:51:16 kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
17:51:16 kernel: ACPI: X2APIC_NMI (uid[0xffffffff] high level lint[0x1])
17:51:16 kernel: On node 0, zone Normal: 2048 pages in unavailable ranges
17:51:16 kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000085f7fffff]
17:51:16 kernel:   node   0: [mem 0x0000000104400000-0x000000085f7fffff]
17:51:16 kernel: Early memory node ranges
17:51:16 kernel: Movable zone start for each node
17:51:16 kernel:   Device   empty
17:51:16 kernel: Zone ranges:
17:51:16 kernel: NODE_DATA(0) allocated [mem 0x85f7d42c0-0x85f7fefff]
17:51:16 kernel: Faking a node at [mem 0x0000000000000000-0x000000085f7fffff]
17:51:16 kernel: No NUMA configuration found
17:51:16 kernel: APIC: Switched APIC routing to: cluster x2apic
17:51:16 kernel: ACPI: Reserving UEFI table memory at [mem 0x5599e000-0x5599e075]
17:51:16 kernel: RAMDISK: [mem 0x4b2ca000-0x4cf2ffff]
17:51:16 kernel: Secure boot disabled
17:51:16 kernel: Using GB pages for direct mapping
17:51:16 kernel: e820: update [mem 0x857fe000-0x857fefff] usable ==> reserved
17:51:16 kernel: esrt: Reserving ESRT space from 0x00000000857fe498 to 0x00000000857fe728.
17:51:16 kernel: last_pfn = 0x8e000 max_arch_pfn = 0x400000000
17:51:16 kernel: x2apic: enabled by BIOS, switching to x2apic ops
17:51:16 kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
17:51:16 kernel: MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
17:51:16 kernel: last_pfn = 0x85f800 max_arch_pfn = 0x400000000
17:51:16 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
17:51:16 kernel: tsc: Detected 3302.400 MHz TSC
17:51:16 kernel: DMI: Memory slots populated: 8/8
17:51:16 kernel: SMBIOS 3.8.0 present.
17:51:16 kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
17:51:16 kernel: efi: Remove mem79: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
17:51:16 kernel: random: crng init done
17:51:16 kernel: efi: ACPI=0x55afe000 ACPI 2.0=0x55afe014 SMBIOS=0x5814f000 SMBIOS 3.0=0x58142000 TPMFinalLog=0x559c0000 MEMATTR=0x858c1018 ESRT=0x857fe498 INITRD=0x54e28718 RNG=0x55afc018 TPMEventLog=0x55af1018
17:51:16 kernel: APIC: Static calls initialized
17:51:16 kernel: NX (Execute Disable) protection: active
17:51:16 kernel: BIOS-e820: [mem 0x0000000104400000-0x000000085f7fffff] usable
17:51:16 kernel: BIOS-provided physical RAM map:
17:51:16 kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
17:51:16 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64 root=UUID=666e9e23-4fee-476f-b365-af1960b5f6f4 rw quiet splash apparmor=1 security=apparmor resume=UUID=648bdd64-54a8-425b-b79a-30ce76ef5fde udev.log_priority=3
17:51:16 kernel: Linux version 6.13.0-rc2-1-MANJARO (linux613@manjaro) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.0) #1 SMP PREEMPT_DYNAMIC Tue, 10 Dec 2024 02:26:31 +0000
This time, I’m totally lost…
Following megavolt’s advice, I looked for an energy setting, but nothing.
So I took the opportunity to change the mouse pointer, the screen background and set the performance to maximum(!!!). I didn’t understand why, but to validate these changes, the system asked me for my password and advised me to close my session.
Once back in the session, I had the idea of testing the webcam. The system asks me for authorization, which I validate, and then, no device! Except that I know it works correctly with the original kernel and the experimental one (previous installations).
I reboot and the webcam works, but not only that: the display runs at 120Hz!
I reboot again, hot, cold, same thing: the display runs at 120Hz without having to go into standby mode first!
Is this due to having set the performance to maximum?
Is it the fact of having validated an interface that required elevation of rights and/or that this interface has set a default value that didn’t exist before?
It works, but I don’t know why or how… :upside_down_face:
Yes, it makes sense. If you switch the CPU governor to “Performance”, this also works for the GPU, as both are on the same chipset and are heavily linked.
Just note that running the display always at 120hz increases battery consumption and that’s also the reason why there are such annoying powersave functions. I don’t think you need 120hz for doing office work. :man_shrugging:
Many thanks to you megavolt, it is indeed the performance setting that influences the refresh speed!!!
Curiously, of the 3 modes (power,balanced,economy), only the “balanced” mode drops the fps.
Another curiosity: in the control panel (top right), the power management button is illuminated only in “performance” and “economy” modes, and switched off in the problematic “balanced” mode.
One last thing: no more display lag or mouse movement.
I’m not going to close this post just yet, as I’m assuming that this is not normal behavior and that there must be some kind of setting to correct this problem.
If anyone can come up with a permanent solution, I’d love to hear about it!
