Video-hybrid-intel-nvidia-prime leads to no graphical session starting
I have been trying to use the mhwd (gui and cli) to install the intel/nvidia prime drivers on my system. The installer dose not report any problems but when the system reboots, it gets stuck at a Manjaro Linux <number and some other fluff> but never the SDDM greeter screen.
From running journalctl -xr I would see this message commonly
Mar 15 16:04:55 JBox-Mjlx sddm[908]: Could not start Display server on vt 2
Mar 15 16:04:55 JBox-Mjlx sddm[908]: Attempt 3 starting the Display server on vt 2 failed
Mar 15 16:04:55 JBox-Mjlx sddm[908]: Display server stopping...
Mar 15 16:04:55 JBox-Mjlx sddm[908]: Failed to read display number from pipe
Mar 15 16:04:54 JBox-Mjlx sddm[908]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_KliILC -noreset -displayfd>
Mar 15 16:04:54 JBox-Mjlx sddm[908]: Writing cookie to "/run/sddm/xauth_KliILC"
Mar 15 16:04:54 JBox-Mjlx sddm[908]: Display server starting...
Mar 15 16:04:52 JBox-Mjlx NetworkManager[807]: <info>  [1710533092.6410] manager: startup complete
Mar 15 16:04:52 JBox-Mjlx sddm[908]: Attempt 2 starting the Display server on vt 2 failed
Mar 15 16:04:52 JBox-Mjlx sddm[908]: Display server stopping...
Mar 15 16:04:52 JBox-Mjlx sddm[908]: Failed to read display number from pipe
I have tried switching kernels from linux67, linux68, and linux66 but they all yeild the same problem.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Since you haven’t been around for awhile, you might not have noticed we have many more fancy Tutorials.
Unfortunately, your small snippet from whatever log that was from is not helpful at all. We have no idea what happened.
Please see:
…and notice I fixed your formatting—this time. :wink:
So that code snippet came from the journalctl run that I did. It was the only thing that I could find pointing towards a problem. I have the xorg log file form the boot session
[   971.108] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[   971.108] _XSERVTransMakeAllCOTSServerListeners: server already running
[   971.108] (--) Log file renamed from "/var/log/Xorg.pid-15209.log" to "/var/log/Xorg.1.log"
[   971.108]
X.Org X Server 1.21.1.8
[   971.108] Current Operating System: Linux JBox-Mjlx 6.5.5-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sat Sep 23 12:48:15 UTC 2023 x86_64
[   971.108] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64 root=UUID=d1d66216-feae-4034-9e33-5ce2444de038 rw quiet udev.log_priority=3
[   971.108]
[   971.108] Current version of pixman: 0.42.2
[   971.108] 	Before reporting problems, check http://wiki.x.org
[   971.108] Markers: (--) probed, (**) from config file, (==) default setting,
[   971.108] (==) Log file: "/var/log/Xorg.1.log", Time: Fri Oct 13 01:17:50 2023
[   971.108] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   971.108] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   971.108] (==) ServerLayout "layout"
[   971.108] (**) |-->Screen "Screen0" (0)
[   971.108] (**) |   |-->Monitor "Monitor0"
[   971.109] (**) |   |-->Device "Device0"
[   971.109] (==) Automatically adding devices
[   971.109] (==) Automatically enabling devices
[   971.109] (==) Automatically adding GPU devices
[   971.109] (==) Automatically binding GPU devices
[   971.109] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   971.109] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[   971.109] 	Entry deleted from font path.
[   971.109] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   971.109] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   971.109] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   971.109] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[   971.109] (==) ModulePath set to "/usr/lib/xorg/modules"
[   971.109] (**) Extension "COMPOSITE" is enabled
[   971.109] (II) The server relies on udev to provide the list of input devices.
[   971.109] (II) Module ABI versions:
[   971.109] 	X.Org ANSI C Emulation: 0.4
[   971.109] 	X.Org Video Driver: 25.2
[   971.109] 	X.Org XInput driver : 24.4
[   971.109] 	X.Org Server Extension : 10.0
[   971.109] (++) using VT number 1
[   971.109] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   971.110] (II) xfree86: Adding drm device (/dev/dri/card1)
[   971.110] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[   971.110] (II) xfree86: Adding drm device (/dev/dri/card0)
[   971.110] (II) Platform probe for /sys/devices/platform/simple-framebuffer.0/drm/card0
[   971.112] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[   971.112] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[   971.113] (--) PCI:*(1@0:0:0) 10de:1e02:10de:12a3 rev 161, Mem @ 0xa1000000/16777216, 0x4000000000/268435456, 0x4010000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[   971.113] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   971.113] (II) LoadModule: "glx"
[   971.113] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   971.115] (II) Module glx: vendor="X.Org Foundation"
[   971.115] 	compiled for 1.21.1.8, module version = 1.0.0
[   971.115] 	ABI class: X.Org Server Extension, version 10.0
[   971.115] (II) LoadModule: "nvidia"
[   971.115] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[   971.115] (II) Module nvidia: vendor="NVIDIA Corporation"
[   971.115] 	compiled for 1.6.99.901, module version = 1.0.0
[   971.115] 	Module class: X.Org Video Driver
[   971.115] (II) NVIDIA dlloader X Driver  535.113.01  Tue Sep 12 19:49:52 UTC 2023
[   971.115] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   971.925] (II) Loading sub module "fb"
[   971.925] (II) LoadModule: "fb"
[   971.925] (II) Module "fb" already built-in
[   971.925] (II) Loading sub module "wfb"
[   971.925] (II) LoadModule: "wfb"
[   971.925] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   971.925] (II) Module wfb: vendor="X.Org Foundation"
[   971.925] 	compiled for 1.21.1.8, module version = 1.0.0
[   971.925] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   971.926] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[   971.926] (==) NVIDIA(0): RGB weight 888
[   971.926] (==) NVIDIA(0): Default visual is TrueColor
[   971.926] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   971.926] (**) Option "AllowNVIDIAGpuScreens"
[   971.926] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[   971.926] (**) NVIDIA(0): Option "Stereo" "0"
[   971.926] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[   971.926] (**) NVIDIA(0): Option "SLI" "Off"
[   971.926] (**) NVIDIA(0): Option "MultiGPU" "Off"
[   971.926] (**) NVIDIA(0): Option "BaseMosaic" "off"
[   971.926] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[   971.926] (**) NVIDIA(0): Stereo disabled by request
[   971.926] (**) NVIDIA(0): NVIDIA SLI disabled.
[   971.926] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[   971.926] (**) NVIDIA(0): Option "Coolbits" "28"
[   971.926] (**) NVIDIA(0): Option "MetaModes" "DP-0: 2560x1080_75 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, HDMI-0: 1600x900_75 +2560+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
[   971.926] (**) NVIDIA(0): Enabling 2D acceleration
[   971.926] (II) Loading sub module "glxserver_nvidia"
[   971.926] (II) LoadModule: "glxserver_nvidia"
[   971.926] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[   971.931] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[   971.931] 	compiled for 1.6.99.901, module version = 1.0.0
[   971.931] 	Module class: X.Org Server Extension
[   971.931] (II) NVIDIA GLX Module  535.113.01  Tue Sep 12 19:51:54 UTC 2023
[   971.931] (II) NVIDIA: The X server supports PRIME Render Offload.
[   971.931] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[   971.931] (--) NVIDIA(0):     DFP-0 (boot)
[   971.931] (--) NVIDIA(0):     DFP-1
[   971.931] (--) NVIDIA(0):     DFP-2
[   971.931] (--) NVIDIA(0):     DFP-3
[   971.931] (--) NVIDIA(0):     DFP-4
[   971.931] (--) NVIDIA(0):     DFP-5
[   971.931] (--) NVIDIA(0):     DFP-6
[   971.931] (--) NVIDIA(0):     DFP-7
[   971.932] (II) NVIDIA(0): NVIDIA GPU NVIDIA TITAN RTX (TU102-A) at PCI:1:0:0 (GPU-0)
[   971.932] (--) NVIDIA(0): Memory: 25165824 kBytes
[   971.932] (--) NVIDIA(0): VideoBIOS: 90.02.2e.00.0c
[   971.932] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[   971.932] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
[   971.932] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal DisplayPort
[   971.932] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 2660.0 MHz maximum pixel clock
[   971.940] (--) NVIDIA(GPU-0): DFP-1: disconnected
[   971.940] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[   971.940] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[   971.983] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-2): connected
[   971.983] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-2): Internal TMDS
[   971.983] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-2): 600.0 MHz maximum pixel clock
[   971.983] (--) NVIDIA(GPU-0): DFP-3: disconnected
[   971.983] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[   971.983] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[   971.983] (--) NVIDIA(GPU-0): DFP-4: disconnected
[   971.983] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[   971.983] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[   971.983] (--) NVIDIA(GPU-0): DFP-5: disconnected
[   971.983] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[   971.983] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[   971.984] (--) NVIDIA(GPU-0): DFP-6: disconnected
[   971.984] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[   971.984] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[   971.984] (--) NVIDIA(GPU-0): DFP-7: disconnected
[   971.984] (--) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[   971.984] (--) NVIDIA(GPU-0): DFP-7: 2660.0 MHz maximum pixel clock
[   972.087] (II) NVIDIA(0): Validated MetaModes:
[   972.087] (II) NVIDIA(0):     "DP-0:2560x1080_75+0+0{ForceCompositionPipeline=On,ForceFullCompositionPipeline=On},HDMI-0:1600x900_75+2560+0{ForceCompositionPipeline=On,ForceFullCompositionPipeline=On}"
[   972.087] (II) NVIDIA(0): Virtual screen size determined to be 4160 x 1080
[   972.140] (--) NVIDIA(0): DPI set to (81, 80); computed from "UseEdidDpi" X config
[   972.140] (--) NVIDIA(0):     option
[   972.141] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[   972.141] (II) NVIDIA:     access.
[   972.144] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[   972.144] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[   972.144] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[   972.144] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[   972.144] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[   972.144] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[   972.144] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[   972.144] (II) NVIDIA(0):     Config Options in the README.
[   972.158] (II) NVIDIA(0): Setting mode "DP-0:2560x1080_75+0+0{ForceCompositionPipeline=On,ForceFullCompositionPipeline=On},HDMI-0:1600x900_75+2560+0{ForceCompositionPipeline=On,ForceFullCompositionPipeline=On}"
[   972.290] (==) NVIDIA(0): Disabling shared memory pixmaps
[   972.290] (==) NVIDIA(0): Backing store enabled
[   972.290] (==) NVIDIA(0): Silken mouse enabled
[   972.290] (**) NVIDIA(0): DPMS enabled
[   972.290] (WW) NVIDIA(0): Option "NoLogo" is not used
[   972.290] (II) Loading sub module "dri2"
[   972.290] (II) LoadModule: "dri2"
[   972.290] (II) Module "dri2" already built-in
[   972.290] (II) NVIDIA(0): [DRI2] Setup complete
[   972.290] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[   972.290] (II) Initializing extension Generic Event Extension
[   972.290] (II) Initializing extension SHAPE
[   972.290] (II) Initializing extension MIT-SHM
[   972.290] (II) Initializing extension XInputExtension
[   972.290] (II) Initializing extension XTEST
[   972.290] (II) Initializing extension BIG-REQUESTS
[   972.290] (II) Initializing extension SYNC
[   972.291] (II) Initializing extension XKEYBOARD
[   972.291] (II) Initializing extension XC-MISC
[   972.291] (II) Initializing extension SECURITY
[   972.291] (II) Initializing extension XFIXES
[   972.291] (II) Initializing extension RENDER
[   972.291] (II) Initializing extension RANDR
[   972.291] (II) Initializing extension COMPOSITE
[   972.291] (II) Initializing extension DAMAGE
[   972.291] (II) Initializing extension MIT-SCREEN-SAVER
[   972.291] (II) Initializing extension DOUBLE-BUFFER
[   972.291] (II) Initializing extension RECORD
[   972.291] (II) Initializing extension DPMS
[   972.291] (II) Initializing extension Present
[   972.291] (II) Initializing extension DRI3
[   972.291] (II) Initializing extension X-Resource
[   972.291] (II) Initializing extension XVideo
[   972.291] (II) Initializing extension XVideo-MotionCompensation
[   972.291] (II) Initializing extension GLX
[   972.291] (II) Indirect GLX disabled.
[   972.291] (II) GLX: Another vendor is already registered for screen 0
[   972.291] (II) Initializing extension XFree86-VidModeExtension
[   972.291] (II) Initializing extension XFree86-DGA
[   972.291] (II) Initializing extension XFree86-DRI
[   972.291] (II) Initializing extension DRI2
[   972.291] (II) Initializing extension NV-GLX
[   972.291] (II) Initializing extension NV-CONTROL
[   972.292] (II) Initializing extension XINERAMA
[   972.324] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[   972.324] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   972.324] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   972.324] (**) Power Button: Applying InputClass "system-keyboard"
[   972.324] (**) Power Button: Applying InputClass "Keyboard Defaults"
[   972.324] (II) LoadModule: "libinput"
[   972.324] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   972.325] (II) Module libinput: vendor="X.Org Foundation"
[   972.325] 	compiled for 1.21.1.8, module version = 1.4.0
[   972.325] 	Module class: X.Org XInput Driver
[   972.325] 	ABI class: X.Org XInput driver, version 24.4
[   972.325] (II) Using input driver 'libinput' for 'Power Button'
[   972.325] (**) Power Button: always reports core events
[   972.325] (**) Option "Device" "/dev/input/event2"
[   972.326] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   972.326] (II) event2  - Power Button: device is a keyboard
[   972.326] (II) event2  - Power Button: device removed
[   972.361] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[   972.361] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   972.361] (**) Option "xkb_layout" "us"
[   972.361] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.381] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   972.381] (II) event2  - Power Button: device is a keyboard
[   972.381] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[   972.381] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   972.381] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   972.381] (**) Power Button: Applying InputClass "system-keyboard"
[   972.381] (**) Power Button: Applying InputClass "Keyboard Defaults"
[   972.381] (II) Using input driver 'libinput' for 'Power Button'
[   972.381] (**) Power Button: always reports core events
[   972.381] (**) Option "Device" "/dev/input/event1"
[   972.381] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   972.381] (II) event1  - Power Button: device is a keyboard
[   972.381] (II) event1  - Power Button: device removed
[   972.430] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[   972.430] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[   972.430] (**) Option "xkb_layout" "us"
[   972.430] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.431] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   972.431] (II) event1  - Power Button: device is a keyboard
[   972.431] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[   972.432] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   972.432] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[   972.432] (**) Sleep Button: Applying InputClass "system-keyboard"
[   972.432] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[   972.432] (II) Using input driver 'libinput' for 'Sleep Button'
[   972.432] (**) Sleep Button: always reports core events
[   972.432] (**) Option "Device" "/dev/input/event0"
[   972.432] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[   972.433] (II) event0  - Sleep Button: device is a keyboard
[   972.433] (II) event0  - Sleep Button: device removed
[   972.449] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[   972.449] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[   972.449] (**) Option "xkb_layout" "us"
[   972.449] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.450] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[   972.450] (II) event0  - Sleep Button: device is a keyboard
[   972.450] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event5)
[   972.450] (II) No input driver specified, ignoring this device.
[   972.450] (II) This device may have been added with another device file.
[   972.450] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event6)
[   972.451] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event7)
[   972.451] (II) No input driver specified, ignoring this device.
[   972.451] (II) This device may have been added with another device file.
[   972.451] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event8)
[   972.451] (II) config/udev: Adding input device Generic USB Audio (/dev/input/event14)
[   972.451] (**) Generic USB Audio: Applying InputClass "evdev keyboard catchall"
[   972.451] (**) Generic USB Audio: Applying InputClass "libinput keyboard catchall"
[   972.451] (**) Generic USB Audio: Applying InputClass "system-keyboard"
[   972.451] (**) Generic USB Audio: Applying InputClass "Keyboard Defaults"
[   972.451] (II) Using input driver 'libinput' for 'Generic USB Audio'
[   972.451] (**) Generic USB Audio: always reports core events
[   972.451] (**) Option "Device" "/dev/input/event14"
[   972.452] (II) event14 - Generic USB Audio: is tagged by udev as: Keyboard
[   972.452] (II) event14 - Generic USB Audio: device is a keyboard
[   972.452] (II) event14 - Generic USB Audio: device removed
[   972.509] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.3/0003:001F:0B21.0003/input/input14/event14"
[   972.509] (II) XINPUT: Adding extended input device "Generic USB Audio" (type: KEYBOARD, id 9)
[   972.509] (**) Option "xkb_layout" "us"
[   972.509] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.510] (II) event14 - Generic USB Audio: is tagged by udev as: Keyboard
[   972.510] (II) event14 - Generic USB Audio: device is a keyboard
[   972.511] (II) config/udev: Adding input device Kingston HyperX Alloy Core RGB (/dev/input/event15)
[   972.511] (**) Kingston HyperX Alloy Core RGB: Applying InputClass "evdev keyboard catchall"
[   972.511] (**) Kingston HyperX Alloy Core RGB: Applying InputClass "libinput keyboard catchall"
[   972.511] (**) Kingston HyperX Alloy Core RGB: Applying InputClass "system-keyboard"
[   972.511] (**) Kingston HyperX Alloy Core RGB: Applying InputClass "Keyboard Defaults"
[   972.511] (II) Using input driver 'libinput' for 'Kingston HyperX Alloy Core RGB'
[   972.511] (**) Kingston HyperX Alloy Core RGB: always reports core events
[   972.511] (**) Option "Device" "/dev/input/event15"
[   972.511] (II) event15 - Kingston HyperX Alloy Core RGB: is tagged by udev as: Keyboard
[   972.511] (II) event15 - Kingston HyperX Alloy Core RGB: device is a keyboard
[   972.512] (II) event15 - Kingston HyperX Alloy Core RGB: device removed
[   972.546] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.0/0003:0951:16DD.0004/input/input15/event15"
[   972.546] (II) XINPUT: Adding extended input device "Kingston HyperX Alloy Core RGB" (type: KEYBOARD, id 10)
[   972.546] (**) Option "xkb_layout" "us"
[   972.546] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.547] (II) event15 - Kingston HyperX Alloy Core RGB: is tagged by udev as: Keyboard
[   972.547] (II) event15 - Kingston HyperX Alloy Core RGB: device is a keyboard
[   972.547] (II) config/udev: Adding input device Kingston HyperX Alloy Core RGB Mouse (/dev/input/event16)
[   972.547] (**) Kingston HyperX Alloy Core RGB Mouse: Applying InputClass "evdev pointer catchall"
[   972.547] (**) Kingston HyperX Alloy Core RGB Mouse: Applying InputClass "libinput pointer catchall"
[   972.547] (II) Using input driver 'libinput' for 'Kingston HyperX Alloy Core RGB Mouse'
[   972.547] (**) Kingston HyperX Alloy Core RGB Mouse: always reports core events
[   972.547] (**) Option "Device" "/dev/input/event16"
[   972.548] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: is tagged by udev as: Mouse
[   972.548] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: device is a pointer
[   972.548] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: device removed
[   972.586] (II) libinput: Kingston HyperX Alloy Core RGB Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[   972.586] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:0951:16DD.0005/input/input16/event16"
[   972.586] (II) XINPUT: Adding extended input device "Kingston HyperX Alloy Core RGB Mouse" (type: MOUSE, id 11)
[   972.586] (**) Option "AccelerationScheme" "none"
[   972.586] (**) Kingston HyperX Alloy Core RGB Mouse: (accel) selected scheme none/0
[   972.586] (**) Kingston HyperX Alloy Core RGB Mouse: (accel) acceleration factor: 2.000
[   972.586] (**) Kingston HyperX Alloy Core RGB Mouse: (accel) acceleration threshold: 4
[   972.587] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: is tagged by udev as: Mouse
[   972.587] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: device is a pointer
[   972.588] (II) config/udev: Adding input device Kingston HyperX Alloy Core RGB Mouse (/dev/input/mouse0)
[   972.588] (II) No input driver specified, ignoring this device.
[   972.588] (II) This device may have been added with another device file.
[   972.588] (II) config/udev: Adding input device Kingston HyperX Alloy Core RGB System Control (/dev/input/event17)
[   972.588] (**) Kingston HyperX Alloy Core RGB System Control: Applying InputClass "evdev keyboard catchall"
[   972.588] (**) Kingston HyperX Alloy Core RGB System Control: Applying InputClass "libinput keyboard catchall"
[   972.588] (**) Kingston HyperX Alloy Core RGB System Control: Applying InputClass "system-keyboard"
[   972.588] (**) Kingston HyperX Alloy Core RGB System Control: Applying InputClass "Keyboard Defaults"
[   972.588] (II) Using input driver 'libinput' for 'Kingston HyperX Alloy Core RGB System Control'
[   972.588] (**) Kingston HyperX Alloy Core RGB System Control: always reports core events
[   972.588] (**) Option "Device" "/dev/input/event17"
[   972.589] (II) event17 - Kingston HyperX Alloy Core RGB System Control: is tagged by udev as: Keyboard
[   972.589] (II) event17 - Kingston HyperX Alloy Core RGB System Control: device is a keyboard
[   972.590] (II) event17 - Kingston HyperX Alloy Core RGB System Control: device removed
[   972.626] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:0951:16DD.0005/input/input17/event17"
[   972.626] (II) XINPUT: Adding extended input device "Kingston HyperX Alloy Core RGB System Control" (type: KEYBOARD, id 12)
[   972.626] (**) Option "xkb_layout" "us"
[   972.626] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.628] (II) event17 - Kingston HyperX Alloy Core RGB System Control: is tagged by udev as: Keyboard
[   972.628] (II) event17 - Kingston HyperX Alloy Core RGB System Control: device is a keyboard
[   972.629] (II) config/udev: Adding input device Kingston HyperX Alloy Core RGB Consumer Control (/dev/input/event18)
[   972.629] (**) Kingston HyperX Alloy Core RGB Consumer Control: Applying InputClass "evdev keyboard catchall"
[   972.629] (**) Kingston HyperX Alloy Core RGB Consumer Control: Applying InputClass "libinput keyboard catchall"
[   972.629] (**) Kingston HyperX Alloy Core RGB Consumer Control: Applying InputClass "system-keyboard"
[   972.629] (**) Kingston HyperX Alloy Core RGB Consumer Control: Applying InputClass "Keyboard Defaults"
[   972.629] (II) Using input driver 'libinput' for 'Kingston HyperX Alloy Core RGB Consumer Control'
[   972.629] (**) Kingston HyperX Alloy Core RGB Consumer Control: always reports core events
[   972.629] (**) Option "Device" "/dev/input/event18"
[   972.630] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: is tagged by udev as: Keyboard
[   972.630] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: device is a keyboard
[   972.630] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: device removed
[   972.653] (II) libinput: Kingston HyperX Alloy Core RGB Consumer Control: needs a virtual subdevice
[   972.653] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:0951:16DD.0005/input/input18/event18"
[   972.653] (II) XINPUT: Adding extended input device "Kingston HyperX Alloy Core RGB Consumer Control" (type: MOUSE, id 13)
[   972.653] (**) Option "AccelerationScheme" "none"
[   972.653] (**) Kingston HyperX Alloy Core RGB Consumer Control: (accel) selected scheme none/0
[   972.653] (**) Kingston HyperX Alloy Core RGB Consumer Control: (accel) acceleration factor: 2.000
[   972.653] (**) Kingston HyperX Alloy Core RGB Consumer Control: (accel) acceleration threshold: 4
[   972.654] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: is tagged by udev as: Keyboard
[   972.654] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: device is a keyboard
[   972.654] (II) config/udev: Adding input device Kingston HyperX Alloy Core RGB Keyboard (/dev/input/event19)
[   972.654] (**) Kingston HyperX Alloy Core RGB Keyboard: Applying InputClass "evdev keyboard catchall"
[   972.654] (**) Kingston HyperX Alloy Core RGB Keyboard: Applying InputClass "libinput keyboard catchall"
[   972.654] (**) Kingston HyperX Alloy Core RGB Keyboard: Applying InputClass "system-keyboard"
[   972.654] (**) Kingston HyperX Alloy Core RGB Keyboard: Applying InputClass "Keyboard Defaults"
[   972.654] (II) Using input driver 'libinput' for 'Kingston HyperX Alloy Core RGB Keyboard'
[   972.654] (**) Kingston HyperX Alloy Core RGB Keyboard: always reports core events
[   972.654] (**) Option "Device" "/dev/input/event19"
[   972.655] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: is tagged by udev as: Keyboard
[   972.655] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: device is a keyboard
[   972.655] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: device removed
[   972.670] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:0951:16DD.0005/input/input19/event19"
[   972.670] (II) XINPUT: Adding extended input device "Kingston HyperX Alloy Core RGB Keyboard" (type: KEYBOARD, id 14)
[   972.670] (**) Option "xkb_layout" "us"
[   972.670] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.671] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: is tagged by udev as: Keyboard
[   972.671] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: device is a keyboard
[   972.672] (II) config/udev: Adding input device Kingston HyperX Pulsefire Core (/dev/input/event20)
[   972.672] (**) Kingston HyperX Pulsefire Core: Applying InputClass "evdev pointer catchall"
[   972.672] (**) Kingston HyperX Pulsefire Core: Applying InputClass "libinput pointer catchall"
[   972.672] (II) Using input driver 'libinput' for 'Kingston HyperX Pulsefire Core'
[   972.672] (**) Kingston HyperX Pulsefire Core: always reports core events
[   972.672] (**) Option "Device" "/dev/input/event20"
[   972.727] (II) event20 - Kingston HyperX Pulsefire Core: is tagged by udev as: Mouse
[   972.727] (II) event20 - Kingston HyperX Pulsefire Core: device is a pointer
[   972.727] (II) event20 - Kingston HyperX Pulsefire Core: device removed
[   972.786] (II) libinput: Kingston HyperX Pulsefire Core: Step value 0 was provided, libinput Fallback acceleration function is used.
[   972.786] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.0/0003:0951:16DE.0006/input/input20/event20"
[   972.786] (II) XINPUT: Adding extended input device "Kingston HyperX Pulsefire Core" (type: MOUSE, id 15)
[   972.786] (**) Option "AccelerationScheme" "none"
[   972.786] (**) Kingston HyperX Pulsefire Core: (accel) selected scheme none/0
[   972.786] (**) Kingston HyperX Pulsefire Core: (accel) acceleration factor: 2.000
[   972.786] (**) Kingston HyperX Pulsefire Core: (accel) acceleration threshold: 4
[   972.843] (II) event20 - Kingston HyperX Pulsefire Core: is tagged by udev as: Mouse
[   972.844] (II) event20 - Kingston HyperX Pulsefire Core: device is a pointer
[   972.844] (II) config/udev: Adding input device Kingston HyperX Pulsefire Core (/dev/input/mouse1)
[   972.844] (II) No input driver specified, ignoring this device.
[   972.844] (II) This device may have been added with another device file.
[   972.845] (II) config/udev: Adding input device Kingston HyperX Pulsefire Core Keyboard (/dev/input/event21)
[   972.845] (**) Kingston HyperX Pulsefire Core Keyboard: Applying InputClass "evdev keyboard catchall"
[   972.845] (**) Kingston HyperX Pulsefire Core Keyboard: Applying InputClass "libinput keyboard catchall"
[   972.845] (**) Kingston HyperX Pulsefire Core Keyboard: Applying InputClass "system-keyboard"
[   972.845] (**) Kingston HyperX Pulsefire Core Keyboard: Applying InputClass "Keyboard Defaults"
[   972.845] (II) Using input driver 'libinput' for 'Kingston HyperX Pulsefire Core Keyboard'
[   972.845] (**) Kingston HyperX Pulsefire Core Keyboard: always reports core events
[   972.845] (**) Option "Device" "/dev/input/event21"
[   972.846] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: is tagged by udev as: Keyboard
[   972.846] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: device is a keyboard
[   972.846] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: device removed
[   972.880] (II) libinput: Kingston HyperX Pulsefire Core Keyboard: needs a virtual subdevice
[   972.880] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:0951:16DE.0007/input/input21/event21"
[   972.880] (II) XINPUT: Adding extended input device "Kingston HyperX Pulsefire Core Keyboard" (type: MOUSE, id 16)
[   972.880] (**) Option "AccelerationScheme" "none"
[   972.880] (**) Kingston HyperX Pulsefire Core Keyboard: (accel) selected scheme none/0
[   972.880] (**) Kingston HyperX Pulsefire Core Keyboard: (accel) acceleration factor: 2.000
[   972.880] (**) Kingston HyperX Pulsefire Core Keyboard: (accel) acceleration threshold: 4
[   972.880] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: is tagged by udev as: Keyboard
[   972.880] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: device is a keyboard
[   972.881] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event10)
[   972.881] (II) No input driver specified, ignoring this device.
[   972.881] (II) This device may have been added with another device file.
[   972.881] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event11)
[   972.881] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event12)
[   972.881] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event13)
[   972.881] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event9)
[   972.882] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event4)
[   972.882] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[   972.882] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[   972.882] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[   972.882] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[   972.882] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[   972.882] (**) Eee PC WMI hotkeys: always reports core events
[   972.882] (**) Option "Device" "/dev/input/event4"
[   972.882] (II) event4  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[   972.882] (II) event4  - Eee PC WMI hotkeys: device is a keyboard
[   972.882] (II) event4  - Eee PC WMI hotkeys: device removed
[   972.933] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input4/event4"
[   972.933] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 17)
[   972.933] (**) Option "xkb_layout" "us"
[   972.933] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.934] (II) event4  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[   972.934] (II) event4  - Eee PC WMI hotkeys: device is a keyboard
[   972.934] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[   972.934] (II) No input driver specified, ignoring this device.
[   972.934] (II) This device may have been added with another device file.
[   972.939] (**) Kingston HyperX Alloy Core RGB Consumer Control: Applying InputClass "evdev keyboard catchall"
[   972.939] (**) Kingston HyperX Alloy Core RGB Consumer Control: Applying InputClass "libinput keyboard catchall"
[   972.939] (**) Kingston HyperX Alloy Core RGB Consumer Control: Applying InputClass "system-keyboard"
[   972.939] (**) Kingston HyperX Alloy Core RGB Consumer Control: Applying InputClass "Keyboard Defaults"
[   972.939] (II) Using input driver 'libinput' for 'Kingston HyperX Alloy Core RGB Consumer Control'
[   972.939] (**) Kingston HyperX Alloy Core RGB Consumer Control: always reports core events
[   972.939] (**) Option "Device" "/dev/input/event18"
[   972.939] (II) libinput: Kingston HyperX Alloy Core RGB Consumer Control: is a virtual subdevice
[   972.939] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.1/0003:0951:16DD.0005/input/input18/event18"
[   972.939] (II) XINPUT: Adding extended input device "Kingston HyperX Alloy Core RGB Consumer Control" (type: KEYBOARD, id 18)
[   972.939] (**) Option "xkb_layout" "us"
[   972.939] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   972.939] (**) Kingston HyperX Pulsefire Core Keyboard: Applying InputClass "evdev keyboard catchall"
[   972.939] (**) Kingston HyperX Pulsefire Core Keyboard: Applying InputClass "libinput keyboard catchall"
[   972.939] (**) Kingston HyperX Pulsefire Core Keyboard: Applying InputClass "system-keyboard"
[   972.939] (**) Kingston HyperX Pulsefire Core Keyboard: Applying InputClass "Keyboard Defaults"
[   972.939] (II) Using input driver 'libinput' for 'Kingston HyperX Pulsefire Core Keyboard'
[   972.939] (**) Kingston HyperX Pulsefire Core Keyboard: always reports core events
[   972.939] (**) Option "Device" "/dev/input/event21"
[   972.939] (II) libinput: Kingston HyperX Pulsefire Core Keyboard: is a virtual subdevice
[   972.939] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:0951:16DE.0007/input/input21/event21"
[   972.939] (II) XINPUT: Adding extended input device "Kingston HyperX Pulsefire Core Keyboard" (type: KEYBOARD, id 19)
[  1024.768] (II) event2  - Power Button: device removed
[  1024.806] (II) event1  - Power Button: device removed
[  1024.830] (II) event0  - Sleep Button: device removed
[  1024.853] (II) event14 - Generic USB Audio: device removed
[  1024.923] (II) event15 - Kingston HyperX Alloy Core RGB: device removed
[  1024.953] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: device removed
[  1025.003] (II) event17 - Kingston HyperX Alloy Core RGB System Control: device removed
[  1025.029] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: device removed
[  1025.056] (II) event20 - Kingston HyperX Pulsefire Core: device removed
[  1025.106] (II) event4  - Eee PC WMI hotkeys: device removed
[  1025.189] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: device removed
[  1025.213] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: device removed
[  1029.468] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
[  1029.468] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal DisplayPort
[  1029.468] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 2660.0 MHz maximum pixel clock
[  1029.475] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  1029.475] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  1029.475] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  1029.521] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-2): connected
[  1029.521] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-2): Internal TMDS
[  1029.521] (--) NVIDIA(GPU-0): Sceptre E20 (DFP-2): 600.0 MHz maximum pixel clock
[  1029.521] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  1029.521] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[  1029.521] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[  1029.522] (--) NVIDIA(GPU-0): DFP-4: disconnected
[  1029.522] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[  1029.522] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[  1029.522] (--) NVIDIA(GPU-0): DFP-5: disconnected
[  1029.522] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[  1029.522] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[  1029.522] (--) NVIDIA(GPU-0): DFP-6: disconnected
[  1029.522] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[  1029.522] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[  1029.522] (--) NVIDIA(GPU-0): DFP-7: disconnected
[  1029.522] (--) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[  1029.522] (--) NVIDIA(GPU-0): DFP-7: 2660.0 MHz maximum pixel clock
[  1029.568] (II) NVIDIA(0): Setting mode "DP-0:2560x1080_75+0+0{ForceCompositionPipeline=On,ForceFullCompositionPipeline=On},HDMI-0:1600x900_75+2560+0{ForceCompositionPipeline=On,ForceFullCompositionPipeline=On}"
[  1029.682] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  1029.682] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[  1029.682] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[  1029.682] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[  1029.682] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[  1029.682] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[  1029.682] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[  1029.682] (II) NVIDIA(0):     Config Options in the README.
[  1029.708] (II) event2  - Power Button: is tagged by udev as: Keyboard
[  1029.708] (II) event2  - Power Button: device is a keyboard
[  1029.709] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  1029.709] (II) event1  - Power Button: device is a keyboard
[  1029.710] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[  1029.710] (II) event0  - Sleep Button: device is a keyboard
[  1029.710] (II) event14 - Generic USB Audio: is tagged by udev as: Keyboard
[  1029.710] (II) event14 - Generic USB Audio: device is a keyboard
[  1029.711] (II) event15 - Kingston HyperX Alloy Core RGB: is tagged by udev as: Keyboard
[  1029.711] (II) event15 - Kingston HyperX Alloy Core RGB: device is a keyboard
[  1029.712] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: is tagged by udev as: Mouse
[  1029.712] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: device is a pointer
[  1029.712] (II) event17 - Kingston HyperX Alloy Core RGB System Control: is tagged by udev as: Keyboard
[  1029.712] (II) event17 - Kingston HyperX Alloy Core RGB System Control: device is a keyboard
[  1029.713] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: is tagged by udev as: Keyboard
[  1029.713] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: device is a keyboard
[  1029.714] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: is tagged by udev as: Keyboard
[  1029.714] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: device is a keyboard
[  1029.770] (II) event20 - Kingston HyperX Pulsefire Core: is tagged by udev as: Mouse
[  1029.770] (II) event20 - Kingston HyperX Pulsefire Core: device is a pointer
[  1029.771] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: is tagged by udev as: Keyboard
[  1029.771] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: device is a keyboard
[  1029.771] (II) event4  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[  1029.771] (II) event4  - Eee PC WMI hotkeys: device is a keyboard
[  1032.058] (II) event2  - Power Button: device removed
[  1032.079] (II) event1  - Power Button: device removed
[  1032.109] (II) event0  - Sleep Button: device removed
[  1032.133] (II) event14 - Generic USB Audio: device removed
[  1032.186] (II) event15 - Kingston HyperX Alloy Core RGB: device removed
[  1032.213] (II) event16 - Kingston HyperX Alloy Core RGB Mouse: device removed
[  1032.276] (II) event17 - Kingston HyperX Alloy Core RGB System Control: device removed
[  1032.306] (II) event19 - Kingston HyperX Alloy Core RGB Keyboard: device removed
[  1032.339] (II) event20 - Kingston HyperX Pulsefire Core: device removed
[  1032.386] (II) event4  - Eee PC WMI hotkeys: device removed
[  1032.459] (II) event18 - Kingston HyperX Alloy Core RGB Consumer Control: device removed
[  1032.503] (II) event21 - Kingston HyperX Pulsefire Core Keyboard: device removed
[  1401.461] (II) UnloadModule: "libinput"
[  1401.462] (II) UnloadModule: "libinput"
[  1401.470] (II) NVIDIA(GPU-0): Deleting GPU-0
[  1401.471] (II) Server terminated successfully (0). Closing log file.
I also did some poking around and there is something related to sddm but I think its related to Xorg not starting (or seeming to crash as to what I think the blip of the screen is)
Your kernel is EOL and I would very mcuh expect it to cause problems.
I am surprised you were able to install the drivers at all.
Anyhoo … please install and boot into a supported kernel and remove EOL ones like 6.5
I have same problem with 550 nvidia driver.
For now use 470 until it repair.
If you have the ‘same problem’ then you too should remove your EOL kernels.
I have 6.6, 6.7 and 6.8 installed - the problem is the same in all of them.
UPD - I’m using Unstable Branch*
I looked at all the mhwd-nvidia packages - pay attention to the package size of the latest driver - maybe this is the problem?
