After the last Manjaro update and the last Viber update currently (21.8.0.11).
Voice messages no can no longer be played-back with the error in pic related.
Despite there are no audio being playedback, and this also made the “ringing” from incoming calls to be silent.
I tried changing the setting of the audio playback device but it didn’t solve it.
Any idea? or if someone had run into the same issue?
Hi @phelgm,
I see it is an AUR package:
$ pamac search viber
viber 21.8.0.11-1 AUR
Proprietary cross-platform IM and VoIP software
And AUR packages have to be rebuilt after every update:
pamac build viber
Not using it nor able to hear, I’m not able to offer anything else, so I hope it helps!
This will not present a problem in this case, because it just takes the viber.deb Debian/Ubuntu package and unpacks it … no compilation involved.
re the use and (mal)function of the flatpak I have no recommendation or idea - never in my life have I used flatpaks ![]()
Main download link on viber.com is for Appimage
Appimage starts up OK but I do not want to scan the QR code to verify my phone just to check if audio is working
UPDATE
After the last update, to version 23.2.0.3, the AUR version started working back while the flatpak version still show the same error.
I guess it’s issue with runtime packages, since reverting to pre 21 everything work back.
