Very weird dependencies conflict
During pamac update I get conflicting dependencies that I have not idea what they are. I can’t even google what they could be:
Mod edit: screenshot removed
Usually I disable conflicting packages to go on, but I have no idea which ones to disable among over 660 packages of today’s update…
Please post error message as text.
This sounds like a very similar issue to another thread.
The fix was to do the update via pacman first:
sudo pacman -Syu
That should identify the conflicting packages so that you can uninstall one before running the update again. In the above thread the conflict was:
tlp-1.7.0-1 and power-profiles-daemon-0.23-2 are in conflict
Removing tlp allowed their update to proceed.
@Wollie:
Resolving dependencies...
Checking inter-conflicts...
Error: unresolvable package conflicts detected
Error: Failed to prepare transaction:
conflicting dependencies:
- x!�9t and a
             ��Ch�I�vgz are in conflict
Oh, thanks, that helped!! It was tlp.
