I recently replaced chromeos with manjaro on my chromebook and I’ve been enjoying it so far. However I’ve noticed that my wifi speeds are significantly lower. I haven’t done a speed test in chromeos, but I’ve run a speed test on a separate laptop and got 200-400mbps. On this chromebook I’ve only got up to 20. I’ve looked through similar threads but couldn’t find a solution. Any help is appreciated!!! Thanks
System info
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=756e7689-5c99-431a-adce-177951efb212 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: GOOGLE product: Setzer v: 1.0
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: GOOGLE model: Setzer v: 1.0 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.19.1 date: 01/29/2023
ID-1: BAT0 charge: 29.2 Wh (74.1%) condition: 39.4/43.7 Wh (90.0%) volts: 7.7
min: 7.7 model: 333-1C- DR02043 type: Li-ion serial: <filter>
status: discharging cycles: 244
RAM: total: 3.78 GiB used: 2.31 GiB (61.2%)
Info: model: Intel Celeron N3060 bits: 64 type: MCP arch: Airmont level: v2
built: 2015-17 process: Intel 14nm family: 6 model-id: 0x4C (76) stepping: 4
microcode: 0x411
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1960 high: 2081 min/max: 480/2480 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2081 2: 1840
bogomips: 6402
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics driver: i915 v: kernel arch: Gen-8 process: Intel 14nm
built: 2014-15 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:22b1 class-ID: 0300
Device-2: Chicony HP Truevision HD type: USB driver: uvcvideo bus-ID: 1-4:2
chip-ID: 04f2:b50c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x405c built: 2015 res: 1366x768
hz: 60 dpi: 136 gamma: 1.2 size: 256x144mm (10.08x5.67") diag: 294mm (11.6")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel HD Graphics 400 (BSW)
direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:2284 class-ID: 0403
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-5:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 14.68 GiB used: 10.77 GiB (73.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Hynix model: HAG4a2
size: 14.68 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-1: / raw-size: 14.37 GiB size: 14.05 GiB (97.72%) used: 10.77 GiB (76.7%)
fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: N/A
uuid: 756e7689-5c99-431a-adce-177951efb212
used: 312 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1 label: N/A
uuid: EBFD-79AF
ID-1: /dev/mmcblk0boot0 maj-min: 179:8 size: 4 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/mmcblk0boot1 maj-min: 179:16 size: 4 MiB
fs: <superuser required> label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
Device-1: 1-4:2 info: Chicony HP Truevision HD type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b50c
class-ID: 0e02
Device-2: 1-5:3 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 160 Uptime: 3h 0m wakeups: 10872 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1129 libs: 313 tools: pamac Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
