Hi,
I have a problem with loading pages in browsers and loading repositories in pamac in Manjaro. I have fast internet and fast laptop. Duration of pages loading is from 15 to 45 sec. Has someone the same problem or has someone resolution? Thanks.
Are you sure? Doesnât sound like it via your description. Loading web pages and repositories are completely different things and connect to various different servers. Have you done a speed test while this occurs?
I tried different network with 100 Mbit/s connection and all was without problems. That means that problem is somewhere in my home network or at my operator.
Connection by ethernet gives the same results, unfortunatelly.
Yes. Exactly. Ctrl+F5 doesnt work. Problem is probably in my home network or at the operator.
Results:
ping 8.8.8.8 -4 -c300
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=241 time=12.6 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=241 time=12.7 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=241 time=12.4 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=241 time=12.9 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=241 time=12.9 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=241 time=12.6 ms
64 bytes from 8.8.8.8: icmp_seq=7 ttl=241 time=12.8 ms
64 bytes from 8.8.8.8: icmp_seq=8 ttl=241 time=12.4 ms
64 bytes from 8.8.8.8: icmp_seq=9 ttl=241 time=12.7 ms
64 bytes from 8.8.8.8: icmp_seq=10 ttl=241 time=13.1 ms
64 bytes from 8.8.8.8: icmp_seq=11 ttl=241 time=12.7 ms
64 bytes from 8.8.8.8: icmp_seq=12 ttl=241 time=20.4 ms
64 bytes from 8.8.8.8: icmp_seq=13 ttl=241 time=12.3 ms
ping 8.8.8.8 -6 -c300
ping: 8.8.8.8: Trieda adries nie je podporovanĂĄ poÄĂtaÄom
Do not ever touch mirrors without forcing resync of databases ⌠and do not resync db without updating ⌠so âŚ
(here we will use geoip which will try to find things locally and sort)
sudo pacman-mirrors -g && sudo pacman -Syyu
Again ⌠the point is ⌠dont use pacman-mirrors without at least âpacman -Syyuâ
(maybe âSyyuuâ if you want to accept downgrades)
No it doesnât. Please people stop writing that all over the forum again and again. It DOESNâT select the 5 fastest mirror. No it DOESNâT (It is not against you but I see even old timers here saying that often).
-f, --fasttrack [NUMBER]
Generates a random mirrorlist for the users current selected branch, mirrors are randomly selected from the users current mirror pool, either a
custom pool or the default pool, the randomly selected mirrors are ranked by their current access time. The higher number the higher possibility
of a fast mirror. If a number is given the resulting mirrorlist contains that number of servers.
yup ⌠5 random ⌠use -f0 or -f if you want an actual speed ranking ⌠but its global, so you have to load all of them. â-f5â is just 5 random working mirrors, and you get the fastest of those.
If you change the wording a little, then you are right: This will select5fastest of 5 mirrors
Generates a random mirrorlist for the users current selected branch, mirrors are randomly selected from the users current mirror pool, eiâ
ther a custom pool or the default pool, the randomly selected mirrors are ranked by their current access time. The higher number the highâ
er possibility of a fast mirror. If a number is given the resulting mirrorlist contains that number of servers.
that is true, it will sort the 5 randomly selected mirror by their âaccess timeâ or actually the speed result from the test it does, not simply access time or ping (or sort 5 random mirror picked from your current custom mirror pool if you have at least 5 in your custom mirror pool).
As the manual says the bigger the number, the higher the chance to have one of the fastest mirror possible. If you donât put a number it will sort them all then you will have the fastest speed for the mirror as already pointed by cscs
