Jugger
20 January 2024 22:24
1
I recently started using Linux and chose Manjaro to start, however I am facing a problem regarding the internet network, networkmanager does not allow me to change the adapter speed to anything higher than 10Mbit/s and if I change the network it simply disconnects and does not work more, there must be some configuration that I’m missing.
Moderator edit: Type below the hidden template
defaults are usually o.k.
if they are not - and you can’t figure out the reason, asking other people to help instead -
give them something to work with.
like:
information on your system and hardware …
inxi -Fazy
for example
Jugger
20 January 2024 22:56
3
oh right, here it is
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=19897015-69c1-44f7-9e3c-72ce65fc3242 rw quiet apparmor=1
security=apparmor resume=UUID=ce1ab132-e638-4a82-80cb-82894dcbf06d
udev.log_priority=3
Desktop: i3 v: 4.23 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K/BR v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3803
date: 01/22/2018
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2353 high: 3600 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2837 2: 2570
3: 3600 4: 2200 5: 1771 6: 2092 7: 2191 8: 2185 9: 2195 10: 2195 11: 2200
12: 2200 bogomips: 86257
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 545.29.06
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 08:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X org v: 1.21.1.10 compositor: Picom v: git-b700a
driver: X: loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3040x1050 s-size: <missing: xdpyinfo>
Monitor-1: DVI-D-0 pos: primary,right res: 1360x768 hz: 60 dpi: 100
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
Monitor-2: HDMI-0 pos: left res: 1680x1050 hz: 60 dpi: 81
size: 526x296mm (20.71x11.65") diag: 604mm (23.76") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
memory: 5.86 GiB
Device-1: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp6s0 state: up speed: 10 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2
chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 104
Local Storage: total: 670.7 GiB used: 48.18 GiB (7.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA1000M8240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: E8FK11.L temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 480GB
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
ID-1: / raw-size: 214.47 GiB size: 210.05 GiB (97.94%)
used: 48.18 GiB (22.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 256 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 33%
Processes: 283 Uptime: 1h 5m wakeups: 0 Memory: total: 8 GiB
available: 7.69 GiB used: 3.99 GiB (51.9%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1087 libs: 324 tools: pamac,yay Shell: Bash
v: 5.2.21 running-in: urxvtd inxi: 3.3.31
Moderator edit: Please use proper formatting: [HowTo] Post command output and file content as formatted text
please look at the recommended introductory posts
formatting terminal output for readability is mentioned - and is easy as well
like this, for example:
udev.log_priority=3
serial: UEFI: American Megatrends v: 3803
date: 01/22/2018
desc: 2x8 MiB
memory: 5.86 GiB
class-ID: 0403
class-ID: 0200
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.1
lanes: 2 tech: SSD serial: fw-rev: E8FK11.L temp: 36.9 C
scheme: GPT
tech: SSD serial: fw-rev: 04RL scheme: GPT
What do you do?
and
Unless you KNOW it is not the cable that causes the issue - try a different cable.
Jugger
20 January 2024 23:24
5
it’s definitely not the cable, it was working normally before installing Manjaro.
I believe it is some network configuration that hangs at 10mbit/s, is there any file that has any configuration related to this?
I’m searching but I’m having a little trouble finding it.
Please ignore any typing errors, I don’t speak English and I’m using the translator
anon33601770:
What do you do?
perhaps there is an alternate driver for your network card
How do you know that?
cscs
20 January 2024 23:27
7
Jugger:
6.5.13-7-MANJARO
EOL kernel.
Out of date BIOS.
Placa-mãe AMD AM4 uATX com DDR4 3200MHz, 32 Gb/s M.2, HDMI, SATA 6Gb/s, USB 3.0
So are we talking about this ethernet connection?
Jugger
20 January 2024 23:30
8
I used Windows, and it worked normally
Jugger
20 January 2024 23:34
9
yes, that’s the connection
Windows drivers are available and work - might not be the case for a Linux environment.
Hardware problem. Either cable or router or 6 years out-of-date BIOS.
That chipset is very common on AMD motherboards including my own and it works perfectly out-of-the box at 1000 Mbps.
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Wollie
21 January 2024 09:18
12
cscs:
Jugger:
6.5.13-7-MANJARO
EOL kernel.
As @cscs mentioned already: First install an up-to-date kernel, such as 6.6 incl. headers:
sudo mhwd-kernel -i linux66
sudo pacman -S linux66-headers
Then fully update your system by
sudo pacman-mirrors -f && sudo pacman -Syyu
Then reboot.
If the issue persists you could try another driver:
sudo mhwd -i pci linux66-r8168
sudo tee /etc/modprobe.d/blacklist-r8169.conf <<< 'blacklist r8169'
and reboot.
