Very slow boot after updates
Hi
After some updates the system takes about 2 min to boot. It takes longer than Win10 that I dual boot on the same machine.
I have read some posts here before posting in an attempt to solve this with no success.
Here is some info:
[jesuslinux@A9410 ~]$ inxi -zav7
  Kernel: 6.6.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=b9c1fd33-2f73-4159-9a12-ed4859c31e0f rw quiet splash apparmor=1
    security=apparmor resume=UUID=4a33bf11-5d98-47c4-96d8-a5f475484937
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: HP product: HP Pavilion Notebook v: N/A
  Mobo: HP model: 81FB v: 80.21 serial: <superuser required>
    part-nu: X0K19EA#AB9 uuid: <superuser required> UEFI: American Megatrends
    v: F.32 date: 04/26/2019
  ID-1: BAT0 charge: 26.1 Wh (98.9%) condition: 26.4/26.4 Wh (100.0%)
    volts: 8.8 min: 7.7 model: Hewlett-Packard Primary type: Li-ion serial: N/A
    status: charging cycles: 237
  System RAM: total: 8 GiB available: 7.22 GiB used: 2.3 GiB (31.8%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Bottom-Slot 1 (left) type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: spec: 2133 MT/s actual: 1866 MT/s volts:
    curr: 2 min: 2 max: 2 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471A5143EB0-CPB serial: <filter>
  Device-2: Bottom-Slot 2 (right) type: DDR4 detail: synchronous unbuffered
  Info: model: AMD A9-9410 RADEON R5 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
    arch: Excavator level: v3 note: check built: 2015 process: GF 28nm
    family: 0x15 (21) model-id: 0x70 (112) stepping: 0 microcode: 0x6006705
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
    desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 1398 high: 1400 min/max: 1400/2900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1397
    bogomips: 11583
  Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
    bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
    cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
    fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca
    mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
    pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 svm svm_lock syscall tbm tce tsc tsc_scale v_vmsave_vmload
    vgif vmcb_clean vme vmmcall wdt xop xsave xsaveopt
  Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
    driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
    process: TSMC 28nm built: 2014-19 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
  Device-2: Sunplus Innovation HP Wide Vision HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:3
    chip-ID: 1bcf:2c87 class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0
    driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c6 built: 2013 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: max: 1366x768 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.5 vendor: amd mesa v: 24.1.3-manjaro1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon R5 Graphics (radeonsi stoney LLVM
    18.1.8 DRM 3.54 6.6.41-1-MANJARO) device-ID: 1002:98e4 memory: 500 MiB
    unified: no
  Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
  Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
    class-ID: 0403
  API: ALSA v: k6.6.41-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:b723
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:4 chip-ID: 0bda:b008
  Local Storage: total: 238.47 GiB used: 154.34 GiB (64.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SKC600256G
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
  Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH61
    dev-links: cdrom
  ID-1: / raw-size: 99.5 GiB size: 97.38 GiB (97.87%) used: 70.14 GiB (72.0%)
    fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
    uuid: b9c1fd33-2f73-4159-9a12-ed4859c31e0f
  ID-2: /boot/efi raw-size: 512.6 MiB size: 511.6 MiB (99.80%)
    used: 300 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: B86F-09A6
  ID-3: /mnt/AED21046D2101565 raw-size: 129.87 GiB
    size: 129.87 GiB (100.00%) used: 84.2 GiB (64.8%) fs: ntfs dev: /dev/sda3
    maj-min: 8:3 label: N/A uuid: AED21046D2101565
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda6 maj-min: 8:6 label: N/A
    uuid: 4a33bf11-5d98-47c4-96d8-a5f475484937
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: A20F-4ADA
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda4 maj-min: 8:4 size: 500 MiB fs: ntfs label: N/A
    uuid: 101203091202F38E
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
    chip-ID: 0438:7900 class-ID: 0900
  Device-1: 1-1.3:3 info: Sunplus Innovation HP Wide Vision HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1bcf:2c87 class-ID: 0e02
  Device-2: 1-1.4:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 2-1:2 info: MOSART Semi. 2.4G Wireless Mouse type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3938:1031 class-ID: 0301
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 67.8 C mobo: N/A gpu: amdgpu temp: 67.0 C
  Fan Speeds (rpm): N/A
  Processes: 187 Power: uptime: 10m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.87 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1249 pm: pacman pkgs: 1240 libs: 380 tools: pamac,yay
    pm: flatpak pkgs: 9 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Bash
    v: 5.2.26 running-in: xfce4-terminal inxi: 3.3.35
[jesuslinux@A9410 ~]$ journalctl -b-1 -p4 --no-pager
ago 06 20:41:40 A9410 kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230628/tbfadt-615)
ago 06 20:41:40 A9410 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xddc20000-0xddc20fff flags 0x200] vs ddc20000 4000
ago 06 20:41:40 A9410 kernel: tpm_crb MSFT0101:00: can't request region for resource [mem 0xddc20000-0xddc20fff]
ago 06 20:41:40 A9410 kernel: tpm_crb: probe of MSFT0101:00 failed with error -16
ago 06 20:41:40 A9410 kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
ago 06 20:41:40 A9410 kernel: ata1.00: supports DRM functions and may not be fully accessible
ago 06 20:41:40 A9410 kernel: kfd kfd: amdgpu: STONEY  not supported in kfd
ago 06 20:41:40 A9410 kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
ago 06 20:41:40 A9410 kernel: vboxdrv: loading out-of-tree module taints kernel.
ago 06 20:41:40 A9410 kernel: VBoxNetAdp: Successfully started.
ago 06 20:41:40 A9410 kernel: VBoxNetFlt: Successfully started.
ago 06 20:41:43 A9410 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
ago 06 20:41:43 A9410 kernel: r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
ago 06 20:41:44 A9410 kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
ago 06 20:43:10 A9410 systemd[1]: dev-tpmrm0.device: Job dev-tpmrm0.device/start timed out.
ago 06 20:43:10 A9410 systemd[1]: Timed out waiting for device /dev/tpmrm0.
ago 06 20:43:10 A9410 bluetoothd[550]: src/plugin.c:init_plugin() System does not support bap plugin
ago 06 20:43:10 A9410 bluetoothd[550]: src/plugin.c:init_plugin() System does not support bass plugin
ago 06 20:43:10 A9410 bluetoothd[550]: src/plugin.c:init_plugin() System does not support mcp plugin
ago 06 20:43:10 A9410 bluetoothd[550]: src/plugin.c:init_plugin() System does not support vcp plugin
ago 06 20:43:10 A9410 bluetoothd[550]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
ago 06 20:43:10 A9410 bluetoothd[550]: src/plugin.c:init_plugin() System does not support micp plugin
ago 06 20:43:10 A9410 bluetoothd[550]: src/plugin.c:init_plugin() System does not support ccp plugin
ago 06 20:43:10 A9410 bluetoothd[550]: src/plugin.c:init_plugin() System does not support csip plugin
ago 06 20:43:10 A9410 bluetoothd[550]: src/plugin.c:init_plugin() System does not support asha plugin
ago 06 20:43:11 A9410 bluetoothd[550]: Failed to set mode: Failed (0x03)
ago 06 20:43:11 A9410 kernel: kauditd_printk_skb: 54 callbacks suppressed
ago 06 20:43:15 A9410 wpa_supplicant[675]: bgscan simple: Failed to enable signal strength monitoring
ago 06 20:43:15 A9410 dbus-broker-launch[545]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
ago 06 20:43:18 A9410 dbus-broker-launch[545]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
ago 06 20:43:18 A9410 dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
ago 06 20:43:18 A9410 dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
ago 06 20:43:18 A9410 dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
ago 06 20:43:18 A9410 dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
ago 06 20:43:18 A9410 dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
ago 06 20:43:18 A9410 dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
ago 06 20:43:28 A9410 lightdm[793]: gkr-pam: unable to locate daemon control file
ago 06 20:43:28 A9410 systemd-xdg-autostart-generator[817]: Configuration file /home/jesuslinux/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
ago 06 20:43:28 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
ago 06 20:43:28 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
ago 06 20:43:28 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
ago 06 20:43:28 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
ago 06 20:43:28 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
ago 06 20:43:28 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
ago 06 20:43:30 A9410 wireplumber[920]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
ago 06 20:43:32 A9410 tumblerd[1006]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
ago 06 20:49:34 A9410 sudo[1698]: jesuslinux : a password is required ; TTY=pts/0 ; PWD=/home/jesuslinux ; USER=root ; COMMAND=/sbin/file -s /dev/sda2
ago 06 20:57:00 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
ago 06 20:57:00 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
ago 06 20:57:00 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
ago 06 20:57:00 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
ago 06 20:57:00 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
ago 06 20:57:00 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
ago 06 20:57:01 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
ago 06 20:57:01 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
ago 06 20:57:01 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
ago 06 20:57:01 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
ago 06 20:57:01 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
ago 06 20:57:01 A9410 dbus-broker-launch[830]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
ago 06 20:57:18 A9410 systemd-xdg-autostart-generator[5995]: Configuration file /home/jesuslinux/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
ago 06 21:08:16 A9410 systemd[810]: dbus-:1.11-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
ago 06 21:08:16 A9410 systemd[810]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
ago 06 21:08:16 A9410 systemd[810]: xfce4-notifyd.service: Failed with result 'exit-code'.
ago 06 21:08:16 A9410 dbus-broker[546]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.40.
ago 06 21:08:16 A9410 dbus-broker-launch[545]: Activation request for 'org.bluez' failed.
ago 06 21:08:16 A9410 wireplumber[920]: pw.core: 0x55d543f7a9b0: leaked proxy 0x55d543eb16d0 id:12
ago 06 21:08:17 A9410 dbus-broker-launch[545]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
ago 06 21:08:17 A9410 NetworkManager[547]: <warn>  [1722974897.1302] dispatcher: (10) failed (after 0.055 sec): Could not activate remote peer 'org.freedesktop.nm_dispatcher': activation request failed: unit is invalid
[jesuslinux@A9410 ~]$ systemd-analyze blame
4.340s apparmor.service
2.079s plymouth-quit.service
2.069s plymouth-quit-wait.service
1.792s NetworkManager.service
1.669s dev-sda7.device
 622ms snapd.service
 503ms ldconfig.service
 441ms systemd-tmpfiles-setup.service
 419ms systemd-udev-trigger.service
 356ms upower.service
 333ms user@1000.service
 284ms polkit.service
 283ms udisks2.service
 253ms systemd-journald.service
 231ms modprobe@fuse.service
 223ms systemd-journal-flush.service
 219ms systemd-remount-fs.service
 219ms systemd-modules-load.service
 215ms systemd-logind.service
 214ms modprobe@drm.service
 214ms ModemManager.service
 214ms systemd-udev-load-credentials.service
 203ms lvm2-monitor.service
 202ms dev-hugepages.mount
 197ms dev-mqueue.mount
 197ms modprobe@configfs.service
 197ms kmod-static-nodes.service
 196ms sys-kernel-debug.mount
 195ms sys-kernel-tracing.mount
 184ms systemd-timesyncd.service
 166ms systemd-tmpfiles-setup-dev-early.service
 156ms systemd-hostnamed.service
 152ms systemd-udevd.service
 149ms mnt-AED21046D2101565.mount
 131ms systemd-tmpfiles-clean.service
 125ms systemd-vconsole-setup.service
 119ms systemd-fsck@dev-disk-by\x2duuid-B86F\x2d09A6.service
 114ms avahi-daemon.service
 107ms systemd-update-utmp.service
 103ms snapd.apparmor.service
 102ms colord.service
  96ms alsa-restore.service
  95ms systemd-rfkill.service
  94ms systemd-backlight@backlight:amdgpu_bl1.service
  93ms cups.service
  88ms bluetooth.service
  87ms dev-disk-by\x2duuid-4a33bf11\x2d5d98\x2d47c4\x2d96d8\x2da5f475484937.swap
  86ms plymouth-start.service
  84ms boot-efi.mount
  81ms accounts-daemon.service
  81ms systemd-tmpfiles-setup-dev.service
  79ms systemd-journal-catalog-update.service
  77ms systemd-sysctl.service
  76ms systemd-update-done.service
  73ms systemd-random-seed.service
  70ms systemd-sysusers.service
  67ms sys-fs-fuse-connections.mount
  67ms plymouth-read-write.service
  62ms tmp.mount
  62ms ufw.service
  59ms wpa_supplicant.service
  58ms pamac-daemon.service
  55ms sys-kernel-config.mount
  47ms user-runtime-dir@1000.service
  47ms modprobe@dm_mod.service
  44ms systemd-user-sessions.service
  43ms dbus-broker.service
  41ms rtkit-daemon.service
  41ms lightdm.service
  40ms modprobe@loop.service
  26ms proc-sys-fs-binfmt_misc.mount
  24ms snapd.socket
lines 45-72/72 (END)
Startup finished in 6.830s (firmware) + 3.903s (loader) + 9.256s (kernel) + 1min 35.870s (userspace) = 1min 55.861s
graphical.target reached after 1min 35.869s in userspace.
Any help on this?
TIA
A lot of suspects in this log. Start with disabling tpm (ftpm) in the uefi settings.
Is it a clean log where you booted, then shutdown when you reached the desktop (finished starting the computer then shutdown)?
I see some potential issues here:
You seem to have a problem with something called Tumbler
//EDIT: seems like this issue, where people “fixed” it by disabling the device in system [SOLVED] Boot process slowdown because of /dev/tpmrm0 start job. / Newbie Corner / Arch Linux Forums
systemctl mask dev-tpmrm0.device
Note the quotes around “fixed”, because to me it doesn’t solve the issue, it is a workaround to have normal boot time at best.
Ok, I tried this:
Rebooted, went to BIOS settings and in the TPM option was “Enabled” and I set it to “Hidden”
I never touched this settings before.
Posting results:
Startup finished in 8.062s (firmware) + 5.153s (loader) + 9.272s (kernel) + 12.043s (userspace) = 34.531s
graphical.target reached after 12.040s in userspace.
4.346s apparmor.service
3.858s plymouth-quit-wait.service
3.818s plymouth-quit.service
1.854s dev-sda7.device
1.787s NetworkManager.service
 628ms snapd.service
 539ms systemd-tmpfiles-setup.service
 489ms systemd-udev-trigger.service
 432ms ldconfig.service
 405ms upower.service
 374ms udisks2.service
 342ms user@1000.service
 272ms colord.service
 271ms plymouth-read-write.service
 256ms systemd-journal-flush.service
 238ms systemd-modules-load.service
 230ms ModemManager.service
 215ms systemd-backlight@backlight:amdgpu_bl1.service
 208ms polkit.service
 206ms systemd-journald.service
 202ms systemd-timesyncd.service
 196ms lvm2-monitor.service
 194ms systemd-udev-load-credentials.service
 192ms modprobe@fuse.service
 188ms modprobe@drm.service
 186ms systemd-remount-fs.service
 181ms systemd-logind.service
 178ms kmod-static-nodes.service
 176ms systemd-tmpfiles-setup-dev-early.service
 168ms modprobe@configfs.service
 167ms mnt-AED21046D2101565.mount
 160ms dev-hugepages.mount
 159ms systemd-udevd.service
 156ms dev-mqueue.mount
 154ms sys-kernel-debug.mount
 153ms sys-kernel-tracing.mount
 147ms bluetooth.service
 144ms systemd-fsck@dev-disk-by\x2duuid-B86F\x2d09A6.service
 126ms systemd-hostnamed.service
 110ms systemd-journal-catalog-update.service
 109ms boot-efi.mount
 108ms snapd.apparmor.service
  96ms accounts-daemon.service
  95ms cups.service
  91ms sys-fs-fuse-connections.mount
  90ms systemd-update-done.service
  89ms systemd-sysctl.service
  86ms systemd-rfkill.service
  85ms plymouth-start.service
  82ms modprobe@loop.service
  82ms systemd-vconsole-setup.service
  76ms systemd-random-seed.service
  73ms dev-disk-by\x2duuid-4a33bf11\x2d5d98\x2d47c4\x2d96d8\x2da5f475484937.swap
  72ms ufw.service
  71ms sys-kernel-config.mount
  66ms systemd-tmpfiles-setup-dev.service
  64ms modprobe@dm_mod.service
  64ms avahi-daemon.service
  56ms systemd-update-utmp.service
  53ms user-runtime-dir@1000.service
  52ms alsa-restore.service
  52ms wpa_supplicant.service
  50ms tmp.mount
  40ms dbus-broker.service
  39ms rtkit-daemon.service
  33ms systemd-user-sessions.service
  32ms lightdm.service
  31ms proc-sys-fs-binfmt_misc.mount
  12ms snapd.socket
lines 43-70/70 (END)
[jesuslinux@A9410 ~]$ journalctl -b0 -p4 --no-pager
ago 06 21:57:56 A9410 kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230628/tbfadt-615)
ago 06 21:57:56 A9410 kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
ago 06 21:57:56 A9410 kernel: ata1.00: supports DRM functions and may not be fully accessible
ago 06 21:57:56 A9410 kernel: kfd kfd: amdgpu: STONEY  not supported in kfd
ago 06 21:57:56 A9410 kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
ago 06 21:57:56 A9410 kernel: vboxdrv: loading out-of-tree module taints kernel.
ago 06 21:57:56 A9410 kernel: VBoxNetAdp: Successfully started.
ago 06 21:57:56 A9410 kernel: VBoxNetFlt: Successfully started.
ago 06 21:57:58 A9410 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
ago 06 21:57:59 A9410 kernel: r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
ago 06 21:58:00 A9410 kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
ago 06 21:58:00 A9410 bluetoothd[561]: src/plugin.c:init_plugin() System does not support bap plugin
ago 06 21:58:00 A9410 bluetoothd[561]: src/plugin.c:init_plugin() System does not support bass plugin
ago 06 21:58:00 A9410 bluetoothd[561]: src/plugin.c:init_plugin() System does not support mcp plugin
ago 06 21:58:00 A9410 bluetoothd[561]: src/plugin.c:init_plugin() System does not support vcp plugin
ago 06 21:58:00 A9410 bluetoothd[561]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
ago 06 21:58:00 A9410 bluetoothd[561]: src/plugin.c:init_plugin() System does not support micp plugin
ago 06 21:58:00 A9410 bluetoothd[561]: src/plugin.c:init_plugin() System does not support ccp plugin
ago 06 21:58:00 A9410 bluetoothd[561]: src/plugin.c:init_plugin() System does not support csip plugin
ago 06 21:58:00 A9410 bluetoothd[561]: src/plugin.c:init_plugin() System does not support asha plugin
ago 06 21:58:01 A9410 bluetoothd[561]: Failed to set mode: Failed (0x03)
ago 06 21:58:04 A9410 wpa_supplicant[660]: bgscan simple: Failed to enable signal strength monitoring
ago 06 21:58:04 A9410 dbus-broker-launch[556]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
ago 06 21:58:08 A9410 dbus-broker-launch[556]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
ago 06 21:58:08 A9410 dbus-broker-launch[738]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
ago 06 21:58:08 A9410 dbus-broker-launch[738]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
ago 06 21:58:08 A9410 dbus-broker-launch[738]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
ago 06 21:58:08 A9410 dbus-broker-launch[738]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
ago 06 21:58:08 A9410 dbus-broker-launch[738]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
ago 06 21:58:08 A9410 dbus-broker-launch[738]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
ago 06 22:01:18 A9410 lightdm[770]: gkr-pam: unable to locate daemon control file
ago 06 22:01:18 A9410 systemd-xdg-autostart-generator[807]: Configuration file /home/jesuslinux/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
ago 06 22:01:18 A9410 dbus-broker-launch[820]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
ago 06 22:01:18 A9410 dbus-broker-launch[820]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
ago 06 22:01:18 A9410 dbus-broker-launch[820]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
ago 06 22:01:18 A9410 dbus-broker-launch[820]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
ago 06 22:01:18 A9410 dbus-broker-launch[820]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
ago 06 22:01:18 A9410 dbus-broker-launch[820]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
ago 06 22:01:20 A9410 wireplumber[909]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
ago 06 22:01:21 A9410 tumblerd[994]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Yep, after the tpm that strange sudo would be my second most important suspect. What is this script, why is there sudo at boot time…
Tumbler…is in my second group of suspects. It makes thumbnails. It often complains about unknown file types, it has a couple plugins by default but not for everything . Normally is with low nice (priority) but it can sometimes also make problems. But that would be more like high cpu.
As said, i do not think it is the big issue.
Can be disabled as a service or with config file in home. But start with the big things.
P.s. so did disabling tpm helped? Cause it is a known common issue in recent time on amd, with recent kernels.
My third suspect from your last log will be the vbox module. The rest is more or less “normal”.
Yep basically the issue is the same as in the linked thread on Arch forum above, or this one [SOLVED] Login screen delayed by tpm device issue at boot / Newbie Corner / Arch Linux Forums
To me still not a fix as you disabled a feature to workaround an issue. But if it’s good for you then I guess it will do :smiley:
Disabling TPM did the trick. He has normal boot time now apparently.
After setting the TPM option in the BIOS to “Hidden” the boot time went from about 1m55 to 35 secs.
Still don’t know why I’m getting those errors with tumbler plugin…
It tries to load something that doesn’t seem to exist. Just try to Google it and see if you can find relevant answers.
//EDIT: install the libgepub dependency for Tumbler?
Probably wants to make previews of your ebooks and cannot. Can’t say more, i am on a phone right now. The solution is either to install some optional dependency for the filetype (search for the .so file with sudo pacman -Fyx) ot to disable indexingv for that filetype.
About tpm…Linus Torvalds had a long tirade in his typical style recently. I think he wants it completely disabled in kernel 6.10 and basically called amd idiots for this implementation:)
So I installed the dependency for Tumbler.
I still get all this stuff after reboot:
ago 06 23:21:05 A9410 kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230628/tbfadt-615)
ago 06 23:21:05 A9410 kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
ago 06 23:21:05 A9410 kernel: ata1.00: supports DRM functions and may not be fully accessible
ago 06 23:21:05 A9410 kernel: kfd kfd: amdgpu: STONEY  not supported in kfd
ago 06 23:21:05 A9410 kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
ago 06 23:21:05 A9410 kernel: vboxdrv: loading out-of-tree module taints kernel.
ago 06 23:21:05 A9410 kernel: VBoxNetAdp: Successfully started.
ago 06 23:21:05 A9410 kernel: VBoxNetFlt: Successfully started.
ago 06 23:21:07 A9410 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
ago 06 23:21:08 A9410 kernel: r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
ago 06 23:21:09 A9410 kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
ago 06 23:21:09 A9410 bluetoothd[560]: src/plugin.c:init_plugin() System does not support bap plugin
ago 06 23:21:09 A9410 bluetoothd[560]: src/plugin.c:init_plugin() System does not support bass plugin
ago 06 23:21:09 A9410 bluetoothd[560]: src/plugin.c:init_plugin() System does not support mcp plugin
ago 06 23:21:09 A9410 bluetoothd[560]: src/plugin.c:init_plugin() System does not support vcp plugin
ago 06 23:21:09 A9410 bluetoothd[560]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
ago 06 23:21:09 A9410 bluetoothd[560]: src/plugin.c:init_plugin() System does not support micp plugin
ago 06 23:21:09 A9410 bluetoothd[560]: src/plugin.c:init_plugin() System does not support ccp plugin
ago 06 23:21:09 A9410 bluetoothd[560]: src/plugin.c:init_plugin() System does not support csip plugin
ago 06 23:21:09 A9410 bluetoothd[560]: src/plugin.c:init_plugin() System does not support asha plugin
ago 06 23:21:10 A9410 bluetoothd[560]: Failed to set mode: Failed (0x03)
ago 06 23:21:13 A9410 wpa_supplicant[658]: bgscan simple: Failed to enable signal strength monitoring
ago 06 23:21:13 A9410 dbus-broker-launch[553]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
ago 06 23:21:16 A9410 dbus-broker-launch[553]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
ago 06 23:21:17 A9410 dbus-broker-launch[737]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
ago 06 23:21:17 A9410 dbus-broker-launch[737]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
ago 06 23:21:17 A9410 dbus-broker-launch[737]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
ago 06 23:21:17 A9410 dbus-broker-launch[737]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
ago 06 23:21:17 A9410 dbus-broker-launch[737]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
ago 06 23:21:17 A9410 dbus-broker-launch[737]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
ago 06 23:21:34 A9410 lightdm[777]: gkr-pam: unable to locate daemon control file
ago 06 23:21:34 A9410 systemd-xdg-autostart-generator[795]: Configuration file /home/jesuslinux/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
ago 06 23:21:34 A9410 dbus-broker-launch[808]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
ago 06 23:21:34 A9410 dbus-broker-launch[808]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
ago 06 23:21:34 A9410 dbus-broker-launch[808]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
ago 06 23:21:34 A9410 dbus-broker-launch[808]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
ago 06 23:21:34 A9410 dbus-broker-launch[808]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
ago 06 23:21:34 A9410 dbus-broker-launch[808]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
ago 06 23:21:36 A9410 wireplumber[897]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
ago 06 23:21:33 A9410 gvfsd-trash[1164]: GFileInfo created without standard::name
ago 06 23:21:33 A9410 gvfsd-trash[1164]: file ../glib/gio/gfileinfo.c: line 1698 (g_file_info_get_name): should not be reached
Is there something I should worry about?
Or let it go?
And you don’t have the error in log now.
For the other messages in the log, I don’t know, I usually see these ACPI BIOS warnings on laptops (may or may not be fixed by updating the BIOS or changing kernel), the sp5100-tco thing you could blacklist that, lot of bluetooth related stuff but I don’t use that so I don’t know, same for WIFI, not sure what those dbus-broker errors are, I see you have an autostart script that is executable but should not, you have a Wireplumber error, GVFS error.
All these messages could be “normal” though, doesn’t seem critical to me if everything works on your end.
If it ain’t broke, don’t fix it. But you could Google the messages or part of them to try to find threads about them and go from there.
I think everything is ok now. I am no amd user so i do not know about the 4 amd lines, and also the gvfs trash is new to me. Pretty much everything else i have had and researched upon and is not important.
  • acpi - that is the OEM firmware to blame, nothing can be done and is just warning
  • tco is not important if you are not running a server, embedded system like raspberry pi, ups, etc, its a watchdog, it can be disabled but not worth the effort to bother on a desktop or laptop, just ignore
  • bluetooth…well this is firmware again, nothing to be done here, if it works ignore it, if not…you cannot fix on your side.
  • “not named after” is a xfce bug…they should fix it with update before it becomes deprecated and a real problem, again not user fixable and for now is just a warning
  • gkr pam is also ignorable in 99% of the cases
  • xdg-autostart - well that is something actually for manjaro to fix. It looks useless to me and a remnant of a past workaround, but someone tried to remove it and reported unbootable system, so i would not touch it :slight_smile:
p.s one of the articles about ftpm
