Hi,
This happened recently.
Boot is over 1 minute now after entering LUKS password?
Boot drive is a LUKS encrypted 2TB M.2 drive.
Any help with fixing the above would be appreciated.
Thanks!
Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
root=UUID=e6904fb9-88c7-445f-92eb-bd71124dfe33 rw quiet
cryptdevice=UUID=ea95b186-2441-4a26-bc26-1445436021f6:luks-ea95b186-2441-4a26-bc26-1445436021f6
root=/dev/mapper/luks-ea95b186-2441-4a26-bc26-1445436021f6 splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5021 date: 09/29/2024
System RAM: total: 64 GiB available: 62.7 GiB used: 7.88 GiB (12.6%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2E3200C16 serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1754 min/max: 550/4853 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1754 2: 1754 3: 1754
4: 1754 5: 1754 6: 1754 7: 1754 8: 1754 9: 1754 10: 1754 11: 1754 12: 1754
13: 1754 14: 1754 15: 1754 16: 1754 bogomips: 121365
stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
xtopology
affected
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 570.133.07
alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as
of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0a:00.0 chip-ID: 10de:2504
class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 161 s-size: 303x170mm (11.93x6.69")
s-diag: 347mm (13.68")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled
model: LG (GoldStar) Ultra HD serial: <filter> built: 2023 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 81 gamma: 1.2 chroma: red:
x: 0.655 y: 0.333 green: x: 0.306 y: 0.639 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 600x340mm (23.62x13.39") diag: 690mm (27.2")
ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080, 1600x900, 1280x1024,
1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 93 4: parse_edid:
unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 570.133.07
device-ID: 10de:2504 surfaces: xcb,xlib
Device-1: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0a:00.1 chip-ID: 10de:228e class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.14.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
driver: r8168 v: 8.055.00-NAPI modules: r8169 pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8168 v: 8.055.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp6s0 state: down mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
chip-ID: 8087:0025 class-ID: e001
Device-1: luks-ea95b186-2441-4a26-bc26-1445436021f6 maj-min: 253:0
type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 1.82 TiB
Local Storage: total: 12.73 TiB used: 1.57 TiB (12.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST12000VN0008-2YS101
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.57 TiB (87.6%)
fs: ext4 dev: /dev/dm-0 maj-min: 253:0
mapped: luks-ea95b186-2441-4a26-bc26-1445436021f6 label: N/A
uuid: e6904fb9-88c7-445f-92eb-bd71124dfe33
used: 480 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 7687-2945
Hub-2: 1-5:2 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Device-2: 3-6:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: USB Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1
chip-ID: 30fa:0400 class-ID: 0301
Device-2: 5-2:3 info: China Resource Semico USB Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
chip-ID: 1a2c:4094 class-ID: 0300
Hub-7: 5-4:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
Hub-8: 5-4.1:5 info: Hitachi ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 045b:0209
Hub-9: 5-4.3:6 info: Hitachi ports: 4 rev: 2.1
Hub-10: 5-4.3.1:7 info: Hitachi ports: 4 rev: 2.1
Device-1: 5-4.3.4:8 info: Brother Industries DCP-L2550DW series
type: printer driver: usblp interfaces: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 04f9:0424 class-ID: 0701 serial: <filter>
Hub-11: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-12: 6-4:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
Hub-13: 6-4.1:3 info: Hitachi ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210
Hub-14: 6-4.3:4 info: Hitachi ports: 4 rev: 3.0
Hub-15: 6-4.3.1:5 info: Hitachi ports: 4 rev: 3.0
System Temperatures: cpu: 49.2 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: 1626 pm: pacman pkgs: 1585 libs: 512 tools: pamac pm: rpm pkgs: 0
pm: flatpak pkgs: 41
1: http://manjaro.grena.ge/stable/$repo/$arch
2: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
3: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
4: http://mirror.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.23m.com/manjaro/stable/$repo/$arch
6: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
7: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
8: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 473
1: cpu: 12.7% command: Xorg pid: 994 mem: 195.0 MiB (0.3%)
2: cpu: 10.2% command: nxplayer.bin pid: 3774 mem: 180.6 MiB (0.2%)
3: cpu: 6.6% command: konsole pid: 32666 mem: 196.4 MiB (0.3%)
4: cpu: 2.3% command: firefox pid: 1908 mem: 876.3 MiB (1.3%)
5: cpu: 2.3% command: zsh pid: 32676 mem: 11.2 MiB (0.0%)
Memory top: 5 of 473
1: mem: 876.3 MiB (1.3%) command: firefox pid: 1908 cpu: 2.3%
2: mem: 610.8 MiB (0.9%) command: firefox pid: 2080 cpu: 1.5%
3: mem: 558.6 MiB (0.8%) command: kwin_x11 pid: 1176 cpu: 1.0%
4: mem: 552.3 MiB (0.8%) command: steamwebhelper pid: 4540 cpu: 1.4%
5: mem: 543.9 MiB (0.8%) command: plasmashell pid: 1203 cpu: 0.7%
Processes: 473 Power: uptime: 2h 49m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.05 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.38
