Very slow bluetooth transfer speed on Intel AX200
Hi,
bluetooth is not working when was off and I want to switch it on. I have to unblock bluetooth by command:
rfkill unblock all
Than I have to enable and start bluetooth by commands:
sudo systemctl enable bluetooth
sudo systemctl start bluetooth
When I switch off bluetooth and restart PC, I have to repeat it. But the main problem is transfer speed, which is from 4 kB/s to 21 kB/s. Do you have some idea, how to resolve this problem?
inxi --full --verbosity=7 --filter --no-host:
  Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
  Type: Laptop System: HP product: HP ProBook 455 G7 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8730 v: KBC Version 13.1F.00 serial: <filter> UEFI: HP
  v: S79 Ver. 01.03.01 date: 10/23/2020
  ID-1: BAT0 charge: 36.6 Wh (83.6%) condition: 43.8/45.0 Wh (97.3%)
  volts: 12.5 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
  serial: <filter> status: Unknown cycles: 1
  Device-1: hidpp_battery_0
  model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
  charge: 100% (should be ignored) rechargeable: yes status: Discharging
  RAM: total: 15.04 GiB used: 5.78 GiB (38.4%)
  RAM Report:
  Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
  type: MCP arch: Zen 2 rev: 1 cache: L2: 4 MiB bogomips: 31945
  Speed: 1400 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
  1: 1400 2: 1733 3: 1488 4: 1608 5: 1397 6: 1397 7: 1397 8: 1397
  f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
  pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
  rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
  sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
  tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt
  Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
  Integrated Webcam
  type: USB driver: uvcvideo bus-ID: 3-4:3 chip-ID: 05c8:03cb class-ID: 0e02
  Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
  loaded: amdgpu note: n/a (using device driver) - try sudo/root
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.1-2-MANJARO LLVM 11.1.0)
  v: 4.6 Mesa 21.0.3 direct render: Yes
  Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Hewlett-Packard driver: N/A bus-ID: 05:00.5 chip-ID: 1022:15e2
  class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3
  class-ID: 0403
  Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
  Sound Server-3: PulseAudio v: 14.2 running: no
  Sound Server-4: PipeWire v: 0.3.26 running: yes
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
  bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-3:2 chip-ID: 8087:0029 class-ID: e001
  Local Storage: total: 1.38 TiB used: 474.2 GiB (33.7%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB
  speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: HPS1
  scheme: GPT
  ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
  speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 4B6Q
  ID-1: / size: 459.43 GiB used: 25.28 GiB (5.5%) fs: ext4
  dev: /dev/nvme0n1p2 label: N/A uuid: 086090ee-dcbf-4491-989d-952951bbebd8
  ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
  dev: /dev/nvme0n1p1 label: NO_LABEL uuid: 99AA-19EF
  ID-3: /mnt/eaa0326f-291a-412d-86aa-25faded3b30c size: 915.82 GiB
  used: 448.91 GiB (49.0%) fs: ext4 dev: /dev/sda
  label: \xc3\x9alo\xc5\xbeisko uuid: eaa0326f-291a-412d-86aa-25faded3b30c
  dev: /dev/nvme0n1p3 label: N/A uuid: 06ef5d9d-0800-4244-92ae-c969e1dd156e
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 1-3:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Device-2: 1-4:3 info: Synaptics type: <vendor specific> driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00df
  class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-3:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c53f class-ID: 0300
  Device-2: 3-4:3 info: Cheng Uei Precision Industry (Foxlink) HP Wide
  Vision HD Integrated Webcam
  type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
  power: 500mA chip-ID: 05c8:03cb class-ID: 0e02
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1
  System Temperatures: cpu: 55.0 C mobo: 0.0 C gpu: amdgpu temp: 44.0 C
  Processes: 303 Uptime: 1h 43m wakeups: 4 Init: systemd v: 247 Compilers:
  gcc: 10.2.0 Packages: 1231 pacman: 1224 flatpak: 4 snap: 3 Shell: Zsh
  v: 5.8 running-in: gnome-terminal inxi: 3.3.04
sudo /usr/lib/bluetooth/bluetoothd -n -d
bluetoothd[13413]: Bluetooth daemon 5.58
bluetoothd[13413]: src/main.c:parse_config() parsing /etc/bluetooth/main.conf
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “DiscoverableTimeout” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “AlwaysPairable” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “PairableTimeout” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “Privacy” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “JustWorksRepairing” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “TemporaryTimeout” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “Name” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “Class” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “DeviceID” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “ReverseServiceDiscovery” in group “General”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “Cache” in group “GATT”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “KeySize” in group “GATT”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “ExchangeMTU” in group “GATT”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “Channels” in group “GATT”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “SessionMode” in group “AVDTP”
bluetoothd[13413]: src/main.c:parse_config() Key file does not have key “StreamMode” in group “AVDTP”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “PageScanType” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “PageScanInterval” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “PageScanWindow” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanType” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanInterval” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanWindow” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “LinkSupervisionTimeout” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “PageTimeout” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “MinSniffInterval” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “MaxSniffInterval” in group “BR”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “MinAdvertisementInterval” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “MaxAdvertisementInterval” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “MultiAdvertisementRotationInterval” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalAutoConnect” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowAutoConnect” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalSuspend” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowSuspend” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalDiscovery” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowDiscovery” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalAdvMonitor” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowAdvMonitor” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalConnect” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowConnect” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “MinConnectionInterval” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “MaxConnectionInterval” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ConnectionLatency” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “ConnectionSupervisionTimeout” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “Autoconnecttimeout” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “AdvMonAllowlistScanDuration” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “AdvMonNoFilterScanDuration” in group “LE”
bluetoothd[13413]: src/main.c:parse_mode_config() Key file does not have key “EnableAdvMonInterleaveScan” in group “LE”
D-Bus setup failed: Name already in use
bluetoothd[13413]: src/main.c:main() Unable to get on D-Bus
lspci -knn | grep Net
02:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
lsmod | grep btusb
btusb                  69632  0
btrtl                  28672  1 btusb
btbcm                  20480  1 btusb
btintel                32768  1 btusb
bluetooth             724992  45 btrtl,btintel,btbcm,bnep,btusb,rfcomm
rfkill list
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
dmesg | grep iwlw
[    3.557614] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[    3.565629] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[    3.565644] iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[    3.566037] iwlwifi 0000:02:00.0: loaded firmware version 62.49eeb572.0 cc-a0-62.ucode op_mode iwlmvm
[    3.766660] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[    4.002650] iwlwifi 0000:02:00.0: base HW address: 08:5b:d6:a8:87:1b
[    4.553843] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
Welcome to the forum! :wave:
When pasting terminal output, add three backticks ` above and below the text:
text
That must’ve been a lot of work framing each line with a single backtick. That’s usually just for single words or phrases/commands :point_right: like this :point_left: I’ve fixed it for you this time. :wink:
If you click the orange pencil icon at the top right of the post, you can see the edits.
I have the same AX200 chipset with the same firmware loaded and haven’t had any issues with Bluetooth lately, so I’m not sure why you’re experiencing issues.
What’s the output of:
systemctl status bluetooth
Thank you very much for editing and tips. :slightly_smiling_face:
Here is the output:
bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
     Active: active (running) since Sat 2021-05-08 11:16:46 CEST; 37min ago
       Docs: man:bluetoothd(8)
   Main PID: 770 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 18443)
     Memory: 2.2M
     CGroup: /system.slice/bluetooth.service
             └─770 /usr/lib/bluetooth/bluetoothd
máj 08 11:16:46 majo-pc bluetoothd[770]: Starting SDP server
máj 08 11:16:46 majo-pc bluetoothd[770]: Bluetooth management interface 1.19 initialized
máj 08 11:16:48 majo-pc bluetoothd[770]: Endpoint registered: sender=:1.43 path=/MediaEndpoint/A2DPSource/ldac
máj 08 11:16:48 majo-pc bluetoothd[770]: Endpoint registered: sender=:1.43 path=/MediaEndpoint/A2DPSink/aptx_hd
máj 08 11:16:48 majo-pc bluetoothd[770]: Endpoint registered: sender=:1.43 path=/MediaEndpoint/A2DPSource/aptx_hd
máj 08 11:16:48 majo-pc bluetoothd[770]: Endpoint registered: sender=:1.43 path=/MediaEndpoint/A2DPSource/aac
máj 08 11:16:48 majo-pc bluetoothd[770]: Endpoint registered: sender=:1.43 path=/MediaEndpoint/A2DPSink/sbc
máj 08 11:16:48 majo-pc bluetoothd[770]: Endpoint registered: sender=:1.43 path=/MediaEndpoint/A2DPSource/sbc
The output looks normal.
BlueTooth file transfer has never been fast or reliable in my experience, I never use it. What type of files are you transferring and from what? USB or network would be much faster.
Yes, bluetooth transfer is not very fast. But standard 5.0 should be go a lot of faster than few kB/s. I dont use bluetooth for transferring files very much too. But I like all components in my pc working.
