Thanks in advance for the help ![]()
When I boot, audio is very quiet. I set PC volume to 120%, turn the speakers up to 90%, and can faintly hear my 90s lofi beats youtube video. If I suspend the computer, then wake it, the lofi beats permuate my soul and shake my house; it is super loud. I can return the PC volume to 50% or so, with the speakers at 25%.
I would like to make it so the audio functions correctly when the system turns on, rather than requiring me to boot, suspend, and resume.
The fact that the volume fixes after the PC has suspended was only realized today; I feel like it is a vital clue, but I have no idea where to look next.
Audio devices:
lspci | grep -i audio
00:1f.3 Audio device: Intel Corporation Comet Lake PCH cAVS
01:00.1 Audio device: NVIDIA Corporation GA102 High Definition Audio Controller (rev a1)
The issue is with the āIntel Corporation Comet Lake PCH cAVSā device; HDMI works as advertised. Headphones also work as expected, even if plugged into the onboard audio. Itās only the rear line out that has this issue.
I have reason to believe this isnāt just a Manjaro issue; I had the same problem with my previous install, OpenSUSE
Things Iāve tried:
- Going into aslamixer and making sure all channels are up
- This is what is recommended in basically every post I can find; dozens of them
- Using pavucontrol to do the same thing
- Using hdajackretask to change the line out to be registered as a āheadphoneā
Iām in a dual boot environment, and the audio on the other operating system is always loud enough.
Other outputs that might be helpful:
sudo dmesg | grep -C 2 -i audio
[ 2.984908] snd_hda_intel 0000:01:00.1: enabling device (0100 -> 0102)
[ 2.984950] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 2.984953] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 2.989349] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[ 2.989351] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.024061] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:046D:C539.0003/input/input12
[ 3.032423] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
[ 3.042238] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1220: line_outs=1 (0x1b/0x0/0x0/0x0/0x0) type:line
[ 3.042242] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.042243] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x14/0x0/0x0/0x0/0x0)
[ 3.042244] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 3.042245] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 3.042245] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 3.042247] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 3.042247] snd_hda_codec_realtek hdaudioC0D0: Mic=0x1a
[ 3.042248] snd_hda_codec_realtek hdaudioC0D0: Line=0x15
[ 3.053531] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
[ 3.053598] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 4.558007] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
[ 4.636064] usb 1-10: set resolution quirk: cval->res = 384
[ 4.636153] usbcore: registered new interface driver snd-usb-audio
[ 4.945985] Bluetooth: hci0: Waiting for firmware download to complete
[ 4.946155] Bluetooth: hci0: Firmware loaded in 1583261 usecs
sudo lsmod | grep -iE 'snd|intel'
btintel 57344 1 btusb
snd_usb_audio 466944 2
snd_usbmidi_lib 49152 1 snd_usb_audio
bluetooth 1097728 32 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
snd_ump 36864 1 snd_usb_audio
snd_rawmidi 53248 2 snd_usbmidi_lib,snd_ump
snd_seq_device 16384 2 snd_ump,snd_rawmidi
mc 90112 5 videodev,snd_usb_audio,videobuf2_v4l2,uvcvideo,videobuf2_common
intel_rapl_msr 20480 0
intel_rapl_common 45056 1 intel_rapl_msr
snd_sof_pci_intel_cnl 12288 0
intel_tcc_cooling 12288 0
snd_sof_intel_hda_common 249856 1 snd_sof_pci_intel_cnl
intel_powerclamp 20480 0
soundwire_intel 81920 1 snd_sof_intel_hda_common
snd_sof_intel_hda_mlink 36864 2 soundwire_intel,snd_sof_intel_hda_common
soundwire_cadence 45056 1 soundwire_intel
snd_sof_intel_hda 24576 1 snd_sof_intel_hda_common
kvm_intel 425984 0
snd_sof_pci 24576 2 snd_sof_intel_hda_common,snd_sof_pci_intel_cnl
snd_sof_xtensa_dsp 16384 1 snd_sof_intel_hda_common
snd_sof 425984 3 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_hda
kvm 1376256 1 kvm_intel
snd_sof_utils 16384 1 snd_sof
soundwire_generic_allocation 12288 1 soundwire_intel
soundwire_bus 139264 3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
snd_soc_skl 241664 0
snd_soc_hdac_hda 28672 2 snd_sof_intel_hda_common,snd_soc_skl
snd_hda_ext_core 36864 5 snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda_mlink,snd_soc_skl,snd_sof_intel_hda
snd_soc_sst_ipc 20480 1 snd_soc_skl
snd_soc_sst_dsp 45056 1 snd_soc_skl
ghash_clmulni_intel 16384 0
snd_hda_codec_realtek 200704 1
snd_soc_acpi_intel_match 94208 3 snd_sof_intel_hda_common,snd_soc_skl,snd_sof_pci_intel_cnl
snd_hda_codec_generic 114688 1 snd_hda_codec_realtek
snd_soc_acpi 16384 3 snd_soc_acpi_intel_match,snd_sof_intel_hda_common,snd_soc_skl
ledtrig_audio 12288 1 snd_hda_codec_generic
snd_soc_core 462848 5 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl
aesni_intel 360448 10
snd_hda_codec_hdmi 94208 1
crypto_simd 16384 1 aesni_intel
snd_compress 28672 1 snd_soc_core
cryptd 28672 3 crypto_simd,ghash_clmulni_intel
ac97_bus 12288 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_hda_intel 65536 4
snd_intel_dspcfg 40960 4 snd_hda_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_skl
snd_intel_sdw_acpi 16384 2 snd_sof_intel_hda_common,snd_intel_dspcfg
snd_hda_codec 225280 7 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
intel_pmc_bxt 16384 1 iTCO_wdt
snd_hda_core 151552 10 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
intel_cstate 20480 0
snd_hwdep 20480 2 snd_usb_audio,snd_hda_codec
snd_pcm 204800 13 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_soc_core,snd_sof_utils,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
snd_timer 53248 1 snd_pcm
snd 155648 28 snd_hda_codec_generic,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_ump,snd_pcm,snd_rawmidi
intel_uncore 258048 0
soundcore 16384 1 snd
intel_pch_thermal 20480 0
crc32c_intel 16384 3
spi_intel_pci 12288 0
spi_intel 36864 1 spi_intel_pci
dmesg after suspending and resuming:
sudo dmesg | tail -n 105
[ 35.447618] systemd-journald[433]: Time jumped backwards, rotating.
[ 174.728732] rfkill: input handler enabled
[ 175.882076] logitech-hidpp-device 0003:046D:4085.0008: HID++ 4.2 device connected.
[ 175.994657] rfkill: input handler disabled
[ 176.058519] block nvme0n1: No UUID available providing old NGUID
[ 177.820229] Bluetooth: RFCOMM TTY layer initialized
[ 177.820235] Bluetooth: RFCOMM socket layer initialized
[ 177.820236] Bluetooth: RFCOMM ver 1.11
[ 228.718736] wlo1: deauthenticating from ----- by local choice (Reason: 3=DEAUTH_LEAVING)
[ 232.027367] PM: suspend entry (deep)
[ 232.033586] Filesystems sync: 0.006 seconds
[ 232.365082] rfkill: input handler enabled
[ 232.503461] Freezing user space processes
[ 232.505915] Freezing user space processes completed (elapsed 0.002 seconds)
[ 232.505917] OOM killer disabled.
[ 232.505918] Freezing remaining freezable tasks
[ 232.507196] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ 232.507238] printk: Suspending console(s) (use no_console_suspend to debug)
[ 232.548276] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 232.548642] ata1.00: Entering standby power mode
[ 233.256428] ACPI: PM: Preparing to enter system sleep state S3
[ 234.479885] ACPI: PM: Saving platform NVS memory
[ 234.480029] Disabling non-boot CPUs ...
[ 234.482734] smpboot: CPU 1 is now offline
[ 234.487037] smpboot: CPU 2 is now offline
[ 234.491209] smpboot: CPU 3 is now offline
[ 234.495340] smpboot: CPU 4 is now offline
[ 234.499435] smpboot: CPU 5 is now offline
[ 234.503493] smpboot: CPU 6 is now offline
[ 234.507552] smpboot: CPU 7 is now offline
[ 234.511682] smpboot: CPU 8 is now offline
[ 234.514888] smpboot: CPU 9 is now offline
[ 234.516581] smpboot: CPU 10 is now offline
[ 234.518145] smpboot: CPU 11 is now offline
[ 234.519724] smpboot: CPU 12 is now offline
[ 234.521260] smpboot: CPU 13 is now offline
[ 234.522852] smpboot: CPU 14 is now offline
[ 234.524375] smpboot: CPU 15 is now offline
[ 234.525976] smpboot: CPU 16 is now offline
[ 234.527499] smpboot: CPU 17 is now offline
[ 234.529070] smpboot: CPU 18 is now offline
[ 234.530584] smpboot: CPU 19 is now offline
[ 234.535611] ACPI: PM: Low-level resume complete
[ 234.535677] ACPI: PM: Restoring platform NVS memory
[ 234.536610] Enabling non-boot CPUs ...
[ 234.536762] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 234.540273] CPU1 is up
[ 234.540403] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 234.543853] CPU2 is up
[ 234.543970] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 234.547280] CPU3 is up
[ 234.547389] smpboot: Booting Node 0 Processor 4 APIC 0x8
[ 234.550636] CPU4 is up
[ 234.550735] smpboot: Booting Node 0 Processor 5 APIC 0xa
[ 234.553956] CPU5 is up
[ 234.554056] smpboot: Booting Node 0 Processor 6 APIC 0xc
[ 234.557294] CPU6 is up
[ 234.557390] smpboot: Booting Node 0 Processor 7 APIC 0xe
[ 234.560645] CPU7 is up
[ 234.560737] smpboot: Booting Node 0 Processor 8 APIC 0x10
[ 234.563989] CPU8 is up
[ 234.564079] smpboot: Booting Node 0 Processor 9 APIC 0x12
[ 234.567329] CPU9 is up
[ 234.567417] smpboot: Booting Node 0 Processor 10 APIC 0x1
[ 234.568304] CPU10 is up
[ 234.568400] smpboot: Booting Node 0 Processor 11 APIC 0x3
[ 234.569171] CPU11 is up
[ 234.569261] smpboot: Booting Node 0 Processor 12 APIC 0x5
[ 234.570019] CPU12 is up
[ 234.570106] smpboot: Booting Node 0 Processor 13 APIC 0x7
[ 234.570877] CPU13 is up
[ 234.570964] smpboot: Booting Node 0 Processor 14 APIC 0x9
[ 234.571734] CPU14 is up
[ 234.571823] smpboot: Booting Node 0 Processor 15 APIC 0xb
[ 234.572597] CPU15 is up
[ 234.572683] smpboot: Booting Node 0 Processor 16 APIC 0xd
[ 234.573485] CPU16 is up
[ 234.573572] smpboot: Booting Node 0 Processor 17 APIC 0xf
[ 234.574400] CPU17 is up
[ 234.574481] smpboot: Booting Node 0 Processor 18 APIC 0x11
[ 234.575329] CPU18 is up
[ 234.575411] smpboot: Booting Node 0 Processor 19 APIC 0x13
[ 234.576287] CPU19 is up
[ 234.582221] ACPI: PM: Waking up from system sleep state S3
[ 234.615980] nvme nvme1: 20/0/0 default/read/poll queues
[ 234.621198] nvme nvme0: 20/0/0 default/read/poll queues
[ 234.930465] ata3: SATA link down (SStatus 4 SControl 300)
[ 235.300090] OOM killer enabled.
[ 235.300094] Restarting tasks ... done.
[ 235.301929] random: crng reseeded on system resumption
[ 235.310407] PM: suspend exit
[ 235.590945] rfkill: input handler disabled
[ 235.616940] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 235.813838] r8169 0000:03:00.0 enp3s0: Link is Down
[ 238.050472] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 238.050484] ata1.00: Entering active power mode
[ 238.085485] sd 0:0:0:0: [sda] Starting disk
[ 238.108912] ata1.00: configured for UDMA/100
[ 238.809357] wlo1: authenticate with ----
[ 238.814681] wlo1: send auth to --- (try 1/3)
[ 238.843664] wlo1: authenticated
[ 238.846933] wlo1: associate with --- (try 1/3)
[ 238.850859] wlo1: RX AssocResp from --- (capab=0x1511 status=0 aid=8)
[ 238.858741] wlo1: associated
cat /proc/cpuinfo ī² ā
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 165
model name : Intel(R) Core(TM) i9-10850K CPU @ 3.60GHz
stepping : 5
microcode : 0xf8
cpu MHz : 800.050
cache size : 20480 KB
physical id : 0
siblings : 20
core id : 0
cpu cores : 10
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp vnmi pku ospke md_clear flush_l1d arch_capabilities
vmx flags : vnmi preemption_timer posted_intr invvpid ept_x_only ept_ad ept_1gb flexpriority apicv tsc_offset vtpr mtf vapic ept vpid unrestricted_guest vapic_reg vid ple shadow_vmcs pml ept_mode_based_exec
bugs : spectre_v1 spectre_v2 spec_store_bypass swapgs itlb_multihit srbds mmio_stale_data retbleed eibrs_pbrsb gds
bogomips : 7202.00
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
<snip>
sudo dmidecode -t 2
# dmidecode 3.5
Getting SMBIOS data from sysfs.
SMBIOS 3.2.0 present.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: HP
Product Name: 8703
Version: 00
Serial Number: <snip>
Asset Tag:
Features:
Board is a hosting board
Board is removable
Board is replaceable
Location In Chassis:
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
