Thanks for the answer and the debug command, here is the full log after clicking the restart button :
mars 08 10:20:54 florian sudo[92426]: pam_unix(sudo:session): session opened for user root(uid=0) by florianp(uid=1000)
mars 08 10:20:54 florian sudo[92426]: pam_unix(sudo:session): session closed for user root
mars 08 10:21:09 florian sudo[92570]: florianp : TTY=pts/2 ; PWD=/home/florianp/Documents/pro/Obat ; USER=root ; COMMAND=/usr/bin/usermod -aG docker florianp
mars 08 10:21:09 florian sudo[92570]: pam_unix(sudo:session): session opened for user root(uid=0) by florianp(uid=1000)
mars 08 10:21:09 florian sudo[92570]: pam_unix(sudo:session): session closed for user root
mars 08 10:21:19 florian su[92631]: (to root) florianp on pts/2
mars 08 10:21:19 florian su[92631]: pam_unix(su:session): session opened for user root(uid=0) by florianp(uid=1000)
mars 08 10:21:19 florian su[92631]: pam_unix(su:session): session closed for user root
mars 08 10:21:32 florian plasmashell[971]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
mars 08 10:21:32 florian plasmashell[971]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mars 08 10:21:34 florian systemd[773]: Created slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
mars 08 10:21:34 florian systemd[773]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service.
mars 08 10:21:34 florian ksmserver-logout-greeter[92742]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
mars 08 10:21:36 florian systemd[773]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
mars 08 10:21:36 florian systemd[773]: Started dbus-:1.2-org.kde.Shutdown@0.service.
mars 08 10:21:36 florian systemd[773]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:36 florian systemd[773]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian plasmashell[971]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:125: TypeError: Cannot read property 'compactRepresentationItem' of null
mars 08 10:21:37 florian systemd-logind[584]: The system will reboot now!
mars 08 10:21:37 florian systemd-logind[584]: System is rebooting.
mars 08 10:21:37 florian sddm-helper[767]: Signal received: SIGTERM
mars 08 10:21:37 florian systemd[1]: Stopping Session 2 of User florianp...
mars 08 10:21:37 florian sddm[666]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
mars 08 10:21:37 florian sddm[666]: Auth: sddm-helper (--socket /tmp/sddm-auth-f62cf02a-6a60-4e2b-8325-98652a47a97b --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user florianp) crashed (exit code 1)
mars 08 10:21:37 florian sddm[666]: Auth: sddm-helper exited with 1
mars 08 10:21:37 florian systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
mars 08 10:21:37 florian plasmashell[971]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55dab18c9a80) QQmlContext(0x55daaeac8ca0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
mars 08 10:21:37 florian kaccess[1155]: The X11 connection broke (error 1). Did the X11 server die?
mars 08 10:21:37 florian chrome[1297]: The X11 connection broke: I/O error (code 1)
mars 08 10:21:37 florian plasmashell[1302]: XIO: fatal IO error 25 (Inappropriate ioctl for device) on X server ":1"
mars 08 10:21:37 florian plasmashell[1302]: after 1496 requests (1496 known processed) with 0 events remaining.
mars 08 10:21:37 florian plasmashell[1302]: [1344:1344:0308/102137.295208:ERROR:connection.cc(61)] X connection error received.
mars 08 10:21:37 florian plasmashell[1302]: [1344:1408:0308/102137.295260:ERROR:connection.cc(61)] X connection error received.
mars 08 10:21:37 florian plasmashell[6899]: [6899:0308/102137.296127:ERROR:connection.cc(46)] X connection error received.
mars 08 10:21:37 florian systemd[773]: app-kaccess@autostart.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: app-kaccess@autostart.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: app-kaccess@autostart.service: Consumed 1.130s CPU time, 28.3M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian kded5[901]: Service ":1.69" unregistered
mars 08 10:21:37 florian systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
mars 08 10:21:37 florian kwin_wayland[815]: QtDBus: cannot relay signals from parent QObject(0x558ea7de5970 "") unless they are emitted in the object's thread QThread(0x558ea7c09968 "libinput-connection"). Current thread is QThread(0x558ea7b8db60 "").
mars 08 10:21:37 florian systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
mars 08 10:21:37 florian kded5[901]: Service ":1.59" unregistered
mars 08 10:21:37 florian systemd[773]: app-slack-e6161e8f234c42a68cc76d8938473b94.scope: Consumed 1min 10.474s CPU time, 547.2M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian plasmashell[971]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian baloorunner[1918]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian pamac-tray-plasma[1158]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian polkit-kde-authentication-agent-1[994]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian kdeconnectd[1137]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian msm_kde_notifier[1136]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian pamac-manager[2096]: Lost connection to Wayland compositor.
mars 08 10:21:37 florian kactivitymanagerd[992]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian konsole[23321]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian org_kde_powerdevil[995]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian kate[82604]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian xdg-desktop-portal-kde[996]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian konsole[88971]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian dolphin[17791]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian systemsettings[1933]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian kded5[901]: The Wayland connection broke. Did the Wayland compositor die?
mars 08 10:21:37 florian systemd[773]: plasma-baloorunner.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: plasma-baloorunner.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: plasma-kded.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: plasma-polkit-agent.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: plasma-polkit-agent.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: plasma-polkit-agent.service: Consumed 1.297s CPU time, 40.3M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: plasma-kactivitymanagerd.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: app-msm_kde_notifier@autostart.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: app-msm_kde_notifier@autostart.service: Consumed 5.364s CPU time, 30.0M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: plasma-kded.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: plasma-kded.service: Consumed 12.686s CPU time, 106.3M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: plasma-powerdevil.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: plasma-powerdevil.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: plasma-powerdevil.service: Consumed 12.225s CPU time, 66.8M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[1]: Removed slice Slice /system/getty.
mars 08 10:21:37 florian systemd[773]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: plasma-xdg-desktop-portal-kde.service: Consumed 1.194s CPU time, 31.6M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: Stopped target plasma-workspace-wayland.target.
mars 08 10:21:37 florian systemd[773]: Stopped target KDE Plasma Workspace.
mars 08 10:21:37 florian systemd[773]: Stopped KDE Window Manager.
mars 08 10:21:37 florian systemd[773]: plasma-kwin_wayland.service: Consumed 11min 46.947s CPU time, 1.3G memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: Stopped target Startup of XDG autostart applications.
mars 08 10:21:37 florian systemd[773]: Stopping Geoclue Demo agent...
mars 08 10:21:37 florian systemd[773]: Stopping KDE Connect...
mars 08 10:21:37 florian systemd[773]: Stopping Update Notifier Tray Icon...
mars 08 10:21:37 florian systemd[773]: Stopping Accessibility services bus...
mars 08 10:21:37 florian systemd[773]: Stopped KDE PolicyKit Authentication Agent.
mars 08 10:21:37 florian systemd[773]: Stopped Powerdevil.
mars 08 10:21:37 florian systemd[773]: Stopped target KDE Plasma Workspace Core.
mars 08 10:21:37 florian systemd[773]: Stopping KDE Plasma Workspace...
mars 08 10:21:37 florian dbus-broker[1395]: Dispatched 1937 messages @ 3(±7)μs / message.
mars 08 10:21:37 florian systemd[773]: Stopping Portal service...
mars 08 10:21:37 florian systemd[773]: Stopping flatpak document portal service...
mars 08 10:21:37 florian systemd[773]: Stopping sandboxed app permission store...
mars 08 10:21:37 florian systemd[773]: Stopping Baloo File Indexer Daemon...
mars 08 10:21:37 florian systemd[773]: Stopped sandboxed app permission store.
mars 08 10:21:37 florian systemd[773]: app-org.kde.kdeconnect.daemon@autostart.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: Stopped KDE Connect.
mars 08 10:21:37 florian systemd[773]: app-org.kde.kdeconnect.daemon@autostart.service: Consumed 1.755s CPU time, 35.1M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: Stopped Geoclue Demo agent.
mars 08 10:21:37 florian systemd[773]: app-org.kde.dolphin-b845b287dfa6435e83b9cfe6edb44283.scope: Consumed 4.723s CPU time, 106.5M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: app-systemsettings-16d1b4988b2f4092ab566351a9b328b0.scope: Consumed 4.540s CPU time, 218.7M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: app-org.kde.kate-efd72430c51d4a7583af11e5a510625f.scope: Consumed 1.895s CPU time, 63.3M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[1]: Removed slice Slice /system/modprobe.
mars 08 10:21:37 florian systemd[1]: Stopped target Bluetooth Support.
mars 08 10:21:37 florian systemd[1]: Stopped target Graphical Interface.
mars 08 10:21:37 florian systemd[1]: Stopped target Multi-User System.
mars 08 10:21:37 florian systemd[1]: Stopped target Login Prompts.
mars 08 10:21:37 florian systemd[1]: Stopped target Sound Card.
mars 08 10:21:37 florian systemd[1]: Stopped target Timer Units.
mars 08 10:21:37 florian systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
mars 08 10:21:37 florian systemd[1]: fstrim.timer: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Discard unused filesystem blocks once a week.
mars 08 10:21:37 florian systemd[1]: logrotate.timer: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Daily rotation of log files.
mars 08 10:21:37 florian systemd[1]: man-db.timer: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Daily man-db regeneration.
mars 08 10:21:37 florian systemd[1]: pamac-cleancache.timer: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Monthly clean packages cache.
mars 08 10:21:37 florian systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Generate mirrorlist weekly.
mars 08 10:21:37 florian systemd[1]: shadow.timer: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Daily verification of password and group files.
mars 08 10:21:37 florian systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Daily Cleanup of Temporary Directories.
mars 08 10:21:37 florian systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Closed LVM2 poll daemon socket.
mars 08 10:21:37 florian systemd[1]: systemd-rfkill.socket: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
mars 08 10:21:37 florian ModemManager[620]: <msg> caught signal, shutting down...
mars 08 10:21:37 florian systemd[1]: Stopping Modem Manager...
mars 08 10:21:37 florian systemd[773]: Stopped Portal service.
mars 08 10:21:37 florian systemd[773]: xdg-desktop-portal.service: Consumed 1.840s CPU time, 11.9M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[773]: app-pamac\x2dtray\x2dplasma@autostart.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: Stopped Update Notifier Tray Icon.
mars 08 10:21:37 florian systemd[773]: app-pamac\x2dtray\x2dplasma@autostart.service: Consumed 36.659s CPU time, 721.2M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[1]: Stopping Save/Restore Sound Card State...
mars 08 10:21:37 florian bluetoothd[582]: Terminating
mars 08 10:21:37 florian systemd[1]: Stopping Bluetooth service...
mars 08 10:21:37 florian systemd[773]: app-google\x2dchrome-2d367b6bc61346f887580678b3a9ba91.scope: Consumed 54min 44.642s CPU time, 4.6G memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[1]: Stopping Thunderbolt system service...
mars 08 10:21:37 florian systemd[1]: Stopping Command Scheduler...
mars 08 10:21:37 florian systemd[773]: Stopped Accessibility services bus.
mars 08 10:21:37 florian systemd[1]: Stopping CUPS Scheduler...
mars 08 10:21:37 florian systemd[773]: Stopped Baloo File Indexer Daemon.
mars 08 10:21:37 florian dockerd[87926]: time="2024-03-08T10:21:37.559164857+01:00" level=info msg="Processing signal 'terminated'"
mars 08 10:21:37 florian crond[641]: (CRON) INFO (Shutting down)
mars 08 10:21:37 florian systemd[1]: Stopping Docker Application Container Engine...
mars 08 10:21:37 florian systemd[773]: app-org.kde.konsole-636a5a251302446da0a4ad0c3e605c45.scope: Consumed 4.628s CPU time.
mars 08 10:21:37 florian systemd[773]: Stopped target Current graphical user session.
mars 08 10:21:37 florian systemd[773]: Stopped target Session services which should run early before the graphical session is brought up.
mars 08 10:21:37 florian dockerd[87926]: time="2024-03-08T10:21:37.560686444+01:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
mars 08 10:21:37 florian dockerd[87926]: time="2024-03-08T10:21:37.561084284+01:00" level=info msg="Daemon shutdown complete"
mars 08 10:21:37 florian systemd[1]: Starting Generate shutdown-ramfs...
mars 08 10:21:37 florian systemd[1]: Stopping Pamac Daemon...
mars 08 10:21:37 florian systemd[1]: plymouth-quit-wait.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Hold until boot process finishes up.
mars 08 10:21:37 florian systemd[773]: plasma-plasmashell.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: plasma-plasmashell.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[1]: Stopping Power Profiles daemon...
mars 08 10:21:37 florian systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
mars 08 10:21:37 florian wireplumber[1061]: 0x5603113091d8: error 24
mars 08 10:21:37 florian systemd[1]: Stopping Simple Desktop Display Manager...
mars 08 10:21:37 florian bluetoothd[582]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
mars 08 10:21:37 florian systemd[773]: Stopped KDE Plasma Workspace.
mars 08 10:21:37 florian systemd[773]: plasma-plasmashell.service: Consumed 11min 51.338s CPU time, 1.9G memory peak, 0B memory swap peak.
mars 08 10:21:37 florian sddm[666]: Signal received: SIGTERM
mars 08 10:21:37 florian systemd[1]: Stopping Load/Save OS Random Seed...
mars 08 10:21:37 florian ModemManager[620]: <msg> ModemManager is shut down
mars 08 10:21:37 florian systemd[1]: Stopping Disk Manager...
mars 08 10:21:37 florian sddm[666]: Socket server stopping...
mars 08 10:21:37 florian sddm[666]: Socket server stopped.
mars 08 10:21:37 florian sddm[666]: Display server stopping...
mars 08 10:21:37 florian systemd[1]: Stopping Daemon for power management...
mars 08 10:21:37 florian NetworkManager[580]: <info> [1709889697.5663] modem-manager: ModemManager no longer available
mars 08 10:21:37 florian wireplumber[1061]: (bluez_output.14_3F_A6_DB_11_B8.1-82) running -> error (Received error event)
mars 08 10:21:37 florian wireplumber[1061]: Failure in Bluetooth audio transport /org/bluez/hci0/dev_14_3F_A6_DB_11_B8/sep5/fd2
mars 08 10:21:37 florian systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Unmounted /run/user/1000/doc.
mars 08 10:21:37 florian systemd[1]: ModemManager.service: Deactivated successfully.
mars 08 10:21:37 florian pipewire[1060]: pw.node: (bluez_output.14_3F_A6_DB_11_B8.1-82) idle -> error (Received error event)
mars 08 10:21:37 florian systemd[773]: Stopped flatpak document portal service.
mars 08 10:21:37 florian sddm[666]: Display server stopped.
mars 08 10:21:37 florian sddm[666]: Running display stop script ("/usr/share/sddm/scripts/Xstop")
mars 08 10:21:37 florian udisksd[720]: udisks daemon version 2.10.1 exiting
mars 08 10:21:37 florian systemd[1]: Stopped Modem Manager.
mars 08 10:21:37 florian systemd[1]: cups.service: Deactivated successfully.
mars 08 10:21:37 florian mkinitcpio[92841]: ==> Starting build: 'none'
mars 08 10:21:37 florian mkinitcpio[92841]: -> Running build hook: [sd-shutdown]
mars 08 10:21:37 florian systemd[1]: Stopped CUPS Scheduler.
mars 08 10:21:37 florian systemd[1]: bolt.service: Deactivated successfully.
mars 08 10:21:37 florian bluetoothd[582]: No matching connection for device
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/aptx_hd
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_hd
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/aac
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aac
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_ll_1
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_ll_0
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/faststream
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/faststream_duplex
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/opus_05
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/opus_05
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/opus_05_duplex
mars 08 10:21:37 florian bluetoothd[582]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/opus_05_duplex
mars 08 10:21:37 florian bluetoothd[582]: Battery Provider Manager destroyed
mars 08 10:21:37 florian bluetoothd[582]: Stopping SDP server
mars 08 10:21:37 florian bluetoothd[582]: Exit
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Main process exited, code=exited, status=1/FAILURE
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Failed with result 'exit-code'.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 58609 (makepkg) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 89193 (fakeroot) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 89201 (faked) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 89208 (bash) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 89920 (make) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 89960 (make) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91747 (g++-12) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91748 (collect2) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91749 (ld) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91750 (lto-wrapper) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91760 (g++-12) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91761 (collect2) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91762 (ld) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91763 (lto-wrapper) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91799 (make) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 91833 (make) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 92739 (g++-12) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 92740 (lto1-ltrans) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 92745 (g++-12) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Unit process 92746 (lto1-ltrans) remains running after unit stopped.
mars 08 10:21:37 florian systemd[773]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Consumed 1h 42min 16.477s CPU time, 6.2G memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[1]: Stopped Thunderbolt system service.
mars 08 10:21:37 florian systemd[1]: bluetooth.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Bluetooth service.
mars 08 10:21:37 florian systemd[1]: cronie.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Command Scheduler.
mars 08 10:21:37 florian systemd[1]: sddm.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Simple Desktop Display Manager.
mars 08 10:21:37 florian systemd[1]: udisks2.service: Deactivated successfully.
mars 08 10:21:37 florian mkinitcpio[92841]: ==> Build complete.
mars 08 10:21:37 florian systemd[1]: Stopped Disk Manager.
mars 08 10:21:37 florian systemd[1]: upower.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Daemon for power management.
mars 08 10:21:37 florian systemd[1]: upower.service: Consumed 12.556s CPU time, 9.8M memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[1]: rtkit-daemon.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
mars 08 10:21:37 florian systemd[1]: power-profiles-daemon.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Power Profiles daemon.
mars 08 10:21:37 florian systemd[1]: pamac-daemon.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Pamac Daemon.
mars 08 10:21:37 florian systemd[1]: pamac-daemon.service: Consumed 16.482s CPU time, 2.2G memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[1]: docker.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[773]: app-firefox-d48cba79da4242c08dc0057c30f572d1.scope: Consumed 34.903s CPU time, 1.1G memory peak, 0B memory swap peak.
mars 08 10:21:37 florian systemd[1]: Stopped Docker Application Container Engine.
mars 08 10:21:37 florian systemd[1]: alsa-restore.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Stopped Save/Restore Sound Card State.
mars 08 10:21:37 florian systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
mars 08 10:21:37 florian systemd[1]: Finished Generate shutdown-ramfs.
mars 08 10:21:37 florian systemd[1]: systemd-random-seed.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped Load/Save OS Random Seed.
mars 08 10:21:38 florian systemd[1]: session-2.scope: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped Session 2 of User florianp.
mars 08 10:21:38 florian systemd-logind[584]: Session 2 logged out. Waiting for processes to exit.
mars 08 10:21:38 florian systemd[1]: Stopped target Network is Online.
mars 08 10:21:38 florian systemd[1]: Stopped target System Time Set.
mars 08 10:21:38 florian systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped Network Manager Wait Online.
mars 08 10:21:38 florian systemd[1]: Stopping containerd container runtime...
mars 08 10:21:38 florian systemd[1]: plymouth-quit.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped Terminate Plymouth Boot Screen.
mars 08 10:21:38 florian containerd[87909]: time="2024-03-08T10:21:38.064953116+01:00" level=info msg="Stop CRI service"
mars 08 10:21:38 florian containerd[87909]: time="2024-03-08T10:21:38.065173017+01:00" level=info msg="Stop CRI service"
mars 08 10:21:38 florian systemd[1]: Starting Show Plymouth Reboot Screen...
mars 08 10:21:38 florian systemd[1]: Stopping Authorization Manager...
mars 08 10:21:38 florian systemd[1]: Stopping User Login Management...
mars 08 10:21:38 florian systemd[1]: Stopping User Manager for UID 1000...
mars 08 10:21:38 florian systemd[1]: containerd.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[773]: Activating special unit Exit the Session...
mars 08 10:21:38 florian systemd[773]: Stopping Konsole - Terminal...
mars 08 10:21:38 florian systemd[773]: Removed slice Slice /app/dbus-:1.2-org.freedesktop.Notifications.
mars 08 10:21:38 florian systemd[773]: Removed slice Slice /app/dbus-:1.2-org.kde.KSplash.
mars 08 10:21:38 florian systemd[773]: Removed slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
mars 08 10:21:38 florian systemd[773]: Removed slice Slice /app/dbus-:1.2-org.manjaro.pamac.manager.
mars 08 10:21:38 florian systemd[773]: app-dbus\x2d:1.2\x2dorg.manjaro.pamac.manager.slice: Consumed 1h 42min 17.352s CPU time, 6.2G memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[773]: Removed slice User Background Tasks Slice.
mars 08 10:21:38 florian systemd[773]: background.slice: Consumed 19.743s CPU time, 755.7M memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[773]: Stopped target Bluetooth.
mars 08 10:21:38 florian systemd[773]: Stopped target Main User Target.
mars 08 10:21:38 florian systemd[773]: Stopped target Sound Card.
mars 08 10:21:38 florian systemd[773]: Stopping dbus-:1.2-org.kde.Shutdown@0.service...
mars 08 10:21:38 florian systemd[773]: Stopping dbus-:1.55-org.a11y.atspi.Registry@0.service...
mars 08 10:21:38 florian systemd[773]: Stopping User preferences database...
mars 08 10:21:38 florian systemd[773]: Stopping GnuPG network certificate management daemon...
mars 08 10:21:38 florian systemd[773]: Stopping GnuPG cryptographic agent and passphrase cache...
mars 08 10:21:38 florian systemd[773]: Stopping GnuPG public key management service...
mars 08 10:21:38 florian systemd[773]: Stopping PipeWire PulseAudio...
mars 08 10:21:38 florian dirmngr[19371]: SIGTERM received - shutting down ...
mars 08 10:21:38 florian gpg-agent[19381]: SIGTERM received - shutting down ...
mars 08 10:21:38 florian gpg-agent[19381]: gpg-agent (GnuPG) 2.4.4 stopped
mars 08 10:21:38 florian systemd[773]: Stopping SSH key agent...
mars 08 10:21:38 florian keyboxd[19367]: SIGTERM received - shutting down ...
mars 08 10:21:38 florian gpg-agent[19383]: scdaemon[19383]: DBG: SIGCONT received - breaking select
mars 08 10:21:38 florian gpg-agent[19383]: scdaemon[19383]: SIGTERM received - still 0 running threads
mars 08 10:21:38 florian gpg-agent[19383]: scdaemon[19383]: scdaemon (GnuPG) 2.4.4 stopped
mars 08 10:21:38 florian systemd[773]: Stopped User preferences database.
mars 08 10:21:38 florian keyboxd[19367]: keyboxd (GnuPG) 2.4.4 stopped
mars 08 10:21:38 florian systemd[773]: Stopped PipeWire PulseAudio.
mars 08 10:21:38 florian systemd[773]: pipewire-pulse.service: Consumed 53.046s CPU time, 26.2M memory peak, 0B memory swap peak.
mars 08 10:21:38 florian dirmngr[19371]: dirmngr (GnuPG) 2.4.4 stopped
mars 08 10:21:38 florian systemd[773]: Stopped dbus-:1.55-org.a11y.atspi.Registry@0.service.
mars 08 10:21:38 florian systemd[773]: Stopped GnuPG public key management service.
mars 08 10:21:38 florian systemd[773]: Stopped GnuPG network certificate management daemon.
mars 08 10:21:38 florian systemd[773]: Stopped GnuPG cryptographic agent and passphrase cache.
mars 08 10:21:38 florian systemd[773]: ssh-agent.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
mars 08 10:21:38 florian systemd[773]: ssh-agent.service: Failed with result 'exit-code'.
mars 08 10:21:38 florian systemd[773]: Stopped SSH key agent.
mars 08 10:21:38 florian systemd[773]: Stopped dbus-:1.2-org.kde.Shutdown@0.service.
mars 08 10:21:38 florian systemd[773]: Stopped Konsole - Terminal.
mars 08 10:21:38 florian systemd[773]: app-org.kde.konsole-a6a0da94030e49da83c1534e200d7877.scope: Consumed 19.427s CPU time, 182.7M memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[773]: Removed slice Slice /app/dbus-:1.2-org.kde.Shutdown.
mars 08 10:21:38 florian systemd[773]: Removed slice Slice /app/dbus-:1.55-org.a11y.atspi.Registry.
mars 08 10:21:38 florian systemd[773]: Stopping Multimedia Service Session Manager...
mars 08 10:21:38 florian systemd[1]: Stopped containerd container runtime.
mars 08 10:21:38 florian systemd[1]: containerd.service: Consumed 1.115s CPU time.
mars 08 10:21:38 florian systemd[1]: polkit.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped Authorization Manager.
mars 08 10:21:38 florian systemd[1]: polkit.service: Consumed 1.954s CPU time, 11.5M memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[1]: Received SIGRTMIN+20 from PID 93031 (plymouthd).
mars 08 10:21:38 florian dbus-broker-launch[578]: Activation request for 'org.bluez' failed.
mars 08 10:21:38 florian systemd-logind[584]: Removed session 2.
mars 08 10:21:38 florian wireplumber[1061]: stopped by signal: Terminated
mars 08 10:21:38 florian wireplumber[1061]: disconnected from pipewire
mars 08 10:21:38 florian systemd[773]: Stopped Multimedia Service Session Manager.
mars 08 10:21:38 florian systemd[773]: wireplumber.service: Consumed 30.995s CPU time, 19.8M memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[773]: Stopping PipeWire Multimedia Service...
mars 08 10:21:38 florian systemd[773]: Stopped PipeWire Multimedia Service.
mars 08 10:21:38 florian systemd[773]: pipewire.service: Consumed 26.701s CPU time, 15.3M memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[773]: Stopped target Basic System.
mars 08 10:21:38 florian systemd[773]: Stopped target Paths.
mars 08 10:21:38 florian systemd[773]: Stopped target Sockets.
mars 08 10:21:38 florian systemd[773]: Stopped target Timers.
mars 08 10:21:38 florian systemd[773]: Closed GnuPG network certificate management daemon.
mars 08 10:21:38 florian systemd[773]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
mars 08 10:21:38 florian systemd[773]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
mars 08 10:21:38 florian systemd[773]: Closed GnuPG cryptographic agent (ssh-agent emulation).
mars 08 10:21:38 florian systemd[773]: Closed GnuPG cryptographic agent and passphrase cache.
mars 08 10:21:38 florian systemd[773]: Closed GnuPG public key management service.
mars 08 10:21:38 florian systemd[773]: Closed p11-kit server.
mars 08 10:21:38 florian systemd[773]: Closed PipeWire PulseAudio.
mars 08 10:21:38 florian systemd[773]: Closed PipeWire Multimedia System Sockets.
mars 08 10:21:38 florian dbus-broker[803]: Dispatched 24199 messages @ 6(±9)μs / message.
mars 08 10:21:38 florian systemd[773]: Stopping D-Bus User Message Bus...
mars 08 10:21:38 florian systemd[773]: Stopped D-Bus User Message Bus.
mars 08 10:21:38 florian systemd[773]: dbus-broker.service: Consumed 1.182s CPU time, 4.2M memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[773]: Removed slice User Core Session Slice.
mars 08 10:21:38 florian systemd[773]: session.slice: Consumed 25min 47.431s CPU time, 3.2G memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[773]: Closed D-Bus User Message Bus Socket.
mars 08 10:21:38 florian systemd[773]: Removed slice User Application Slice.
mars 08 10:21:38 florian systemd[773]: app.slice: Consumed 2h 40min 29.197s CPU time, 11.6G memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[773]: Reached target Shutdown.
mars 08 10:21:38 florian systemd[773]: Finished Exit the Session.
mars 08 10:21:38 florian systemd[773]: Reached target Exit the Session.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 58609 (makepkg) with signal SIGKILL.
mars 08 10:21:38 florian (sd-pam)[775]: pam_unix(systemd-user:session): session closed for user florianp
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 89193 (fakeroot) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 89201 (faked) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 89208 (bash) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 89920 (make) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 89960 (make) with signal SIGKILL.
mars 08 10:21:38 florian (sd-pam)[775]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[florianp] ruser=[<unknown>] rhost=[<unknown>]
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91747 (g++-12) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91748 (collect2) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91749 (ld) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91750 (lto-wrapper) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91760 (g++-12) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91761 (collect2) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91762 (ld) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91763 (lto-wrapper) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91799 (make) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 91833 (make) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 92965 (g++-12) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 92966 (lto1-ltrans) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 92971 (g++-12) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Killing process 92972 (lto1-ltrans) with signal SIGKILL.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped User Manager for UID 1000.
mars 08 10:21:38 florian systemd[1]: user@1000.service: Consumed 3h 6min 37.842s CPU time, 13.9G memory peak, 0B memory swap peak.
mars 08 10:21:38 florian systemd[1]: systemd-logind.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped User Login Management.
mars 08 10:21:38 florian systemd[1]: Stopping Permit User Sessions...
mars 08 10:21:38 florian systemd[1]: Stopping User Runtime Directory /run/user/1000...
mars 08 10:21:38 florian systemd[1]: systemd-user-sessions.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped Permit User Sessions.
mars 08 10:21:38 florian systemd[1]: run-user-1000.mount: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Unmounted /run/user/1000.
mars 08 10:21:38 florian systemd[1]: Started Show Plymouth Reboot Screen.
mars 08 10:21:38 florian systemd[1]: Stopped target Network.
mars 08 10:21:38 florian systemd[1]: Stopped target Remote File Systems.
mars 08 10:21:38 florian systemd[1]: Stopping Network Manager...
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5432] caught SIGTERM, shutting down normally.
mars 08 10:21:38 florian systemd[1]: Starting Tell Plymouth To Jump To initramfs...
mars 08 10:21:38 florian systemd[1]: Stopping WPA supplicant...
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5446] device (wlp0s20f3): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
mars 08 10:21:38 florian dbus-broker-launch[578]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
mars 08 10:21:38 florian NetworkManager[580]: <warn> [1709889698.5469] dispatcher: (58) failed (after 0.002 sec): Could not activate remote peer: activation request failed: unit is invalid.
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5470] device (wlp0s20f3): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5474] dhcp4 (wlp0s20f3): canceled DHCP transaction
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5475] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5475] dhcp4 (wlp0s20f3): state changed no lease
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5477] dhcp6 (wlp0s20f3): canceled DHCP transaction
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5477] dhcp6 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.5478] dhcp6 (wlp0s20f3): state changed no lease
mars 08 10:21:38 florian wpa_supplicant[660]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all
mars 08 10:21:38 florian wpa_supplicant[660]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0
mars 08 10:21:38 florian systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
mars 08 10:21:38 florian systemd[1]: Stopped User Runtime Directory /run/user/1000.
mars 08 10:21:38 florian systemd[1]: Removed slice User Slice of UID 1000.
mars 08 10:21:38 florian systemd[1]: user-1000.slice: Consumed 3h 6min 38.150s CPU time, 14.0G memory peak, 0B memory swap peak.
mars 08 10:21:38 florian wpa_supplicant[660]: p2p-dev-wlp0s20: CTRL-EVENT-TERMINATING
mars 08 10:21:38 florian systemd[1]: Finished Tell Plymouth To Jump To initramfs.
mars 08 10:21:38 florian kernel: wlp0s20f3: deauthenticating from 50:6f:0c:26:53:84 by local choice (Reason: 3=DEAUTH_LEAVING)
mars 08 10:21:38 florian wpa_supplicant[660]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=50:6f:0c:26:53:84 reason=3 locally_generated=1
mars 08 10:21:38 florian wpa_supplicant[660]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.9344] manager: NetworkManager state is now CONNECTED_LOCAL
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.9347] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
mars 08 10:21:38 florian NetworkManager[580]: <info> [1709889698.9453] exiting (success)
mars 08 10:21:38 florian systemd[1]: NetworkManager.service: Deactivated successfully.
mars 08 10:21:38 florian wpa_supplicant[660]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
mars 08 10:21:38 florian wpa_supplicant[660]: wlp0s20f3: CTRL-EVENT-TERMINATING
mars 08 10:21:39 florian systemd[1]: Stopped Network Manager.
mars 08 10:21:39 florian systemd[1]: NetworkManager.service: Consumed 4.531s CPU time, 21.2M memory peak, 0B memory swap peak.
mars 08 10:21:39 florian systemd[1]: wpa_supplicant.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped WPA supplicant.
mars 08 10:21:39 florian systemd[1]: Stopped target Basic System.
mars 08 10:21:39 florian systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
mars 08 10:21:39 florian systemd[1]: Stopped target Path Units.
mars 08 10:21:39 florian systemd[1]: cups.path: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped CUPS Scheduler.
mars 08 10:21:39 florian systemd[1]: Stopped target Slice Units.
mars 08 10:21:39 florian systemd[1]: Removed slice User and Session Slice.
mars 08 10:21:39 florian systemd[1]: user.slice: Consumed 3h 6min 40.084s CPU time, 14.1G memory peak, 0B memory swap peak.
mars 08 10:21:39 florian systemd[1]: Stopped target Socket Units.
mars 08 10:21:39 florian systemd[1]: cups.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed CUPS Scheduler.
mars 08 10:21:39 florian systemd[1]: dirmngr@etc-pacman.d-gnupg.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
mars 08 10:21:39 florian systemd[1]: Removed slice Slice /system/dirmngr.
mars 08 10:21:39 florian systemd[1]: docker.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed Docker Socket for the API.
mars 08 10:21:39 florian systemd[1]: gpg-agent-browser@etc-pacman.d-gnupg.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
mars 08 10:21:39 florian systemd[1]: Removed slice Slice /system/gpg-agent-browser.
mars 08 10:21:39 florian systemd[1]: gpg-agent-extra@etc-pacman.d-gnupg.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
mars 08 10:21:39 florian systemd[1]: Removed slice Slice /system/gpg-agent-extra.
mars 08 10:21:39 florian systemd[1]: gpg-agent-ssh@etc-pacman.d-gnupg.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
mars 08 10:21:39 florian systemd[1]: Removed slice Slice /system/gpg-agent-ssh.
mars 08 10:21:39 florian systemd[1]: gpg-agent@etc-pacman.d-gnupg.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
mars 08 10:21:39 florian systemd[1]: Removed slice Slice /system/gpg-agent.
mars 08 10:21:39 florian systemd[1]: keyboxd@etc-pacman.d-gnupg.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed GnuPG public key management service for /etc/pacman.d/gnupg.
mars 08 10:21:39 florian systemd[1]: Removed slice Slice /system/keyboxd.
mars 08 10:21:39 florian dbus-broker[579]: Dispatched 46204 messages @ 6(±9)μs / message.
mars 08 10:21:39 florian systemd[1]: Stopping D-Bus System Message Bus...
mars 08 10:21:39 florian systemd[1]: dbus-broker.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped D-Bus System Message Bus.
mars 08 10:21:39 florian systemd[1]: dbus-broker.service: Consumed 2.196s CPU time, 7.4M memory peak, 0B memory swap peak.
mars 08 10:21:39 florian systemd[1]: dbus.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed D-Bus System Message Bus Socket.
mars 08 10:21:39 florian systemd[1]: Stopped target System Initialization.
mars 08 10:21:39 florian systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
mars 08 10:21:39 florian systemd[1]: Stopped target Local Encrypted Volumes.
mars 08 10:21:39 florian systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
mars 08 10:21:39 florian systemd[1]: Stopped target Local Integrity Protected Volumes.
mars 08 10:21:39 florian systemd[1]: Stopped target Local Verity Protected Volumes.
mars 08 10:21:39 florian systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:intel_backlight...
mars 08 10:21:39 florian systemd[1]: Stopping Load/Save Screen Backlight Brightness of leds:dell::kbd_backlight...
mars 08 10:21:39 florian systemd[1]: systemd-sysctl.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Apply Kernel Variables.
mars 08 10:21:39 florian systemd[1]: systemd-coredump.socket: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Closed Process Core Dump Socket.
mars 08 10:21:39 florian systemd[1]: systemd-modules-load.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Load Kernel Modules.
mars 08 10:21:39 florian systemd[1]: Stopping Network Time Synchronization...
mars 08 10:21:39 florian systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
mars 08 10:21:39 florian systemd[1]: systemd-backlight@backlight:intel_backlight.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:intel_backlight.
mars 08 10:21:39 florian systemd[1]: systemd-timesyncd.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Network Time Synchronization.
mars 08 10:21:39 florian systemd[1]: systemd-backlight@leds:dell::kbd_backlight.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Load/Save Screen Backlight Brightness of leds:dell::kbd_backlight.
mars 08 10:21:39 florian systemd[1]: Removed slice Slice /system/systemd-backlight.
mars 08 10:21:39 florian systemd[1]: systemd-update-utmp.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
mars 08 10:21:39 florian systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Create Volatile Files and Directories.
mars 08 10:21:39 florian systemd[1]: Stopped target Local File Systems.
mars 08 10:21:39 florian systemd[1]: Unmounting /boot/efi...
mars 08 10:21:39 florian systemd[1]: Unmounting /tmp...
mars 08 10:21:39 florian systemd[1]: boot-efi.mount: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Unmounted /boot/efi.
mars 08 10:21:39 florian systemd[1]: systemd-fsck@dev-disk-by\x2duuid-7605\x2dBB24.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped File System Check on /dev/disk/by-uuid/7605-BB24.
mars 08 10:21:39 florian systemd[1]: Removed slice Slice /system/systemd-fsck.
mars 08 10:21:39 florian systemd[1]: tmp.mount: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Unmounted /tmp.
mars 08 10:21:39 florian systemd[1]: Stopped target Preparation for Local File Systems.
mars 08 10:21:39 florian systemd[1]: Stopped target Swaps.
mars 08 10:21:39 florian systemd[1]: Reached target Unmount All Filesystems.
mars 08 10:21:39 florian systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
mars 08 10:21:39 florian systemd[1]: systemd-remount-fs.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Remount Root and Kernel File Systems.
mars 08 10:21:39 florian systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Create Static Device Nodes in /dev.
mars 08 10:21:39 florian systemd[1]: systemd-tmpfiles-setup-dev-early.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Create Static Device Nodes in /dev gracefully.
mars 08 10:21:39 florian systemd[1]: lvm2-monitor.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
mars 08 10:21:39 florian systemd[1]: Reached target System Shutdown.
mars 08 10:21:39 florian systemd[1]: Reached target Late Shutdown Services.
mars 08 10:21:39 florian systemd[1]: systemd-reboot.service: Deactivated successfully.
mars 08 10:21:39 florian systemd[1]: Finished System Reboot.
mars 08 10:21:39 florian systemd[1]: Reached target System Reboot.
mars 08 10:21:39 florian systemd[1]: Shutting down.
mars 08 10:21:39 florian systemd[1]: Using hardware watchdog 'iTCO_wdt', version 6, device /dev/watchdog0
mars 08 10:21:39 florian systemd[1]: Watchdog running with a timeout of 10min.
mars 08 10:21:39 florian kernel: watchdog: watchdog0: watchdog did not stop!
mars 08 10:21:39 florian systemd-shutdown[1]: Using hardware watchdog 'iTCO_wdt', version 6, device /dev/watchdog0
mars 08 10:21:39 florian systemd-shutdown[1]: Watchdog running with a timeout of 10min.
mars 08 10:21:39 florian systemd-shutdown[1]: Syncing filesystems and block devices.
mars 08 10:21:39 florian systemd-shutdown[1]: Sending SIGTERM to remaining processes...
mars 08 10:21:39 florian systemd-journald[283]: Received SIGTERM from PID 1 (systemd-shutdow).
mars 08 10:21:39 florian systemd-journald[283]: Journal stopped
