Very laggy UI and high system usage
I recently installed Manjaro KDE 21.0.2,.
At installation, I faced no problem and the OS was pretty smooth but with each boot I found the system becoming slower. I did customise a bit here and there but I tried to make sure it didn’t have any other unnecessary background processes, but with all done the system just becomes too laggy and slow after inputs and most of the interface just becomes an outline when called upon
  Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=01a33e17-66de-489f-a806-62508a022814 rw quiet apparmor=1
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
  Type: Laptop System: HP product: HP Laptop 15g-dr0xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 84A7 v: 80.31 serial: <filter> UEFI: Insyde v: F.07
  date: 11/21/2018
  ID-1: BAT1 charge: 32.7 Wh (100.0%) condition: 32.7/41.0 Wh (79.7%)
  volts: 12.8 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
  serial: <filter> status: Full
  Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: E0 cache: L2: 6 MiB
  bogomips: 28800
  Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 798
  4: 793 5: 800 6: 800 7: 797 8: 793
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard
  driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:174e class-ID: 0302
  Device-3: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
  type: USB driver: uvcvideo bus-ID: 1-5:4 chip-ID: 05c8:03c7 class-ID: 0e02
  serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
  display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.1
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.25 running: yes
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: rtl8821ce v: N/A
  modules: rtw88_8821ce,8821ce port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:c821
  class-ID: 0280
  Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
  v: 0.8 bus-ID: 1-6:5 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
  Local Storage: total: 946.42 GiB used: 242.17 GiB (25.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  rotation: 5400 rpm serial: <filter> rev: RSM7 scheme: GPT
  ID-2: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Switch
  size: 14.91 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1.27 scheme: MBR
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 21.14 GiB (21.6%)
  fs: ext4 dev: /dev/sda5 maj-min: 8:5
  ID-2: /boot/efi raw-size: 476 MiB size: 475.1 MiB (99.80%)
  used: 436 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 618.05 GiB size: 607.28 GiB (98.26%)
  used: 167.52 GiB (27.6%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
  ID-1: swap-1 type: partition size: 7.45 GiB used: 739.6 MiB (9.7%)
  priority: -2 dev: /dev/sda4 maj-min: 8:4
  System Temperatures: cpu: 57.0 C mobo: 29.8 C
  Processes: 250 Uptime: 1h 26m wakeups: 1 Memory: 7.57 GiB
  used: 5.37 GiB (71.0%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 clang: 11.1.0 Packages: 1381 pacman: 1365 lib: 364 flatpak: 0
  snap: 16 Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.0
:+1: Welcome to Manjaro! :+1:
You’re a heavy user on a light machine.
Please:
  • Reboot
  • provide the output of:
    free --human
    swapon
  • Use your machine
  • Provide the same information above yet again the moment the lagginess starts on top of the below:
    for szFile in /proc/*/status ; do
      awk '/VmSwap|Name/{printf $2 "\t" $3}END{ print "" }' "$szFile"
    done | sort --key 2 --numeric --reverse | head --lines=20
:thinking:
