After the latest stable update, my system is experiencing very high CPU temperature (over 100 C) and is very sluggish see photo below. Actually I was writing this post from my desktop which has a problem and it shuts down unexpectedly probably because of the high temperature. Can you please help?
Host: desktop Kernel: 6.6.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11
wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550M GAMING
serial: <superuser required> UEFI: American Megatrends LLC. v: F15c
date: 05/12/2022
Info: 12-core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP smt: enabled
arch: Zen 3+ rev: 2 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
Speed (MHz): avg: 614 high: 2200 min/max: 2200/4950 boost: enabled cores:
1: 546 2: 546 3: 546 4: 546 5: 546 6: 546 7: 546 8: 546 9: 545 10: 545
11: 543 12: 546 13: 546 14: 2200 15: 546 16: 546 17: 546 18: 545 19: 546
20: 546 21: 546 22: 546 23: 545 24: 546 bogomips: 177349
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: XFX
driver: amdgpu v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-3,HDMI-A-1 empty: DP-2 bus-ID: 08:00.0 chip-ID: 1002:73ef
class-ID: 0300
Device-2: Owon USB CAMERA driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-2:2 chip-ID: 5345:336b
class-ID: 0102 serial: USB CAMERA
Device-3: Elgato Systems GmbH Cam Link 4K
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 bus-ID: 4-4:2 chip-ID: 0fd9:0066 class-ID: 0102
serial: 0006419AB1000
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 6440x4440 display-ID: 0
Monitor-1: DP-1 pos: middle-c res: 3440x1440 size: N/A modes: N/A
Monitor-2: DP-3 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: top-right res: 1080x1920 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6650 XT (navi23 LLVM
16.0.6 DRM 3.54 6.6.7-1-MANJARO) device-ID: 1002:73ef display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 4 surfaces: xcb,xlib,wayland device: 0
type: discrete-gpu hw: amd driver: mesa radv device-ID: 1002:73ef
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Owon USB CAMERA driver: snd-usb-audio,uvcvideo type: USB
Device-4: Elgato Systems GmbH Cam Link 4K
API: ALSA v: k6.6.7-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: speed: 5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: 4c:44:5b:86:fd:71
vendor: Gigabyte driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: d8:5e:d3:32:cd:96
speed: 12 Mb/s lanes: 1 bus-ID: 1-7:3 chip-ID: 8087:0029 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: 4C:44:5B:86:FD:75 bt-v: 5.2
lmp-v: 11
Local Storage: total: 4.55 TiB used: 1.69 TiB (37.1%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P2SSD8 size: 931.51 GiB
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: 2225E63DF9BA fw-rev: P2CR048
temp: 45.9 C scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST4000DM004-2U9104 size: 3.64 TiB
speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: WW60G8YF fw-rev: 0001
scheme: GPT
ID-1: / size: 915.53 GiB used: 799.87 GiB (87.4%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 99.5 C mobo: 29.0 C gpu: amdgpu temp: 49.0 C
mem: 46.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 465 Uptime: 0m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 3.05 GiB (9.8%) Init: systemd v: 254
default: graphical Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1791
pm: pacman pkgs: 1771 pm: flatpak pkgs: 20 Shell: Bash v: 5.2.21
running-in: konsole inxi: 3.3.31
Kobold
16 December 2023 08:01
2
Maybe close all applications and check your temperature again.
Which CPU cooler are you using?
Heat problems is mainly a issue related to your cooling… besides some AVX Benches that i know.
All in all it should not be a Linux problem, better check RPM on your CPU FAN or check if your vcore is right in Bios. You can also check your Thermal Paste or try undervolting your CPU.
With no applications open after just booting in, the temperature goes to 110 C and the system shuts down.
Here is a photo of the CPU, it has a ID-COOLING ZoomFlow 240 XT 240mm Addressable RGB AIO CPU Liquid Cooler
It’s weird how 5 min after the unexpected shut down, the lights in the desktop are still on.
Kobold
16 December 2023 08:14
4
Uff watercooling, my experience is very limited in this case, i only know there is sometimes air inside the waterstream and the other solutions i mentioned above.
Olli
16 December 2023 08:19
5
there is no information of any scaling-governor installed and used. you should install one
https://wiki.archlinux.org/title/Scaling_governor
I’ve tried to enable ondemand
sudo cpupower frequency-set -g ondemand
[sudo] password for geo:
Setting cpu: 0
Setting cpu: 1
Setting cpu: 2
Setting cpu: 3
Setting cpu: 4
Setting cpu: 5
Setting cpu: 6
Setting cpu: 7
Setting cpu: 8
Setting cpu: 9
Setting cpu: 10
Setting cpu: 11
Setting cpu: 12
Setting cpu: 13
Setting cpu: 14
Setting cpu: 15
Setting cpu: 16
Setting cpu: 17
Setting cpu: 18
Setting cpu: 19
Setting cpu: 20
Setting cpu: 21
Setting cpu: 22
Setting cpu: 23
Following CPUs are offline:
24-31
cpupower set operation was not performed on them
First of all why is CPU 24 offline?
Also, inxi is still not showing any governors.
date: 05/12/2022
Speed (MHz): avg: 2225 high: 2800 min/max: 2200/4950 boost: enabled cores:
1: 2200 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200
10: 2800 11: 2200 12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 2200
18: 2200 19: 2200 20: 2200 21: 2200 22: 2200 23: 2200 24: 2200
bogomips: 177351
class-ID: 0300
type: oss-emulator
lmp-v: 11
temp: 34.9 C scheme: GPT
scheme: GPT
ID-1: / size: 915.53 GiB used: 799.91 GiB (87.4%) fs: ext4
dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
file: /swapfile
System Temperatures: cpu: 72.9 C mobo: 25.0 C gpu: amdgpu temp: 50.0 C
mem: 48.0 C
Processes: 460 Uptime: 5m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 4.21 GiB (13.5%) Init: systemd v: 254
You’ll notice that the cores/CPUs are numbered cpu 0 to cpu 23 , not 1-23 as humans count. So there are 24 cores/CPUs there.
Please provide the output of:
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
…and:
systemctl status cpupower.service
…and:
sudo cpupower -c all frequency-info | grep -i "available cpufreq governors\|hardware limit\|current policy"
Edit:
Your output is quite significantly different than mine:
Info: model: Intel Core i7-8700 socket: LGA1151 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4600 base/boost: 4300/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 800 12: 800 bogomips: 76831
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
So do me a flavour, and please also provide the output of:
My guess is that the water-cooling pump has failed. There’s no way that system should be hitting shutdown temps regardless of cpu governor.
To confirm or rule out this guess, boot into bios and observe temperature there.
try to boot with these option
“amd-pstate=passive”
and see return for
sudo cpupower frequency-info ( if possible )
i guess trouble on your watercooler or failed contact between cpu and cooling
