Hi all.
I have been unable to find a straightforward guide regarding how to verify the SHA256 Checksum of a file that I have downloaded from the AUR. I would appreciate any assistance.
Thank you & more power to you all.
Ruziel
Hi all.
Ruziel
Hi,
Did you try the sha256sum command?
Type man sha256sum for more information.
Hi & thanks for your note. I did what you said but I cannot make sense of the output. I will look into this further. Thanks.
I have downloaded a tar.bz2 file & confirmed the sh256. I am not sure how to install it from there.
Thanks, Russ
You cannot install it.
Unpack it to see whatβs inside - there is probably a readme or install text file explaining what to do next.
The text file may contain instructions for a specific Linux version - needed dependencies et al - you need to find the Manajro equivalents before executing the instructions.
OK will do. Thanks for your input.
