I have fresh Manjaro xfce 22.0.5 install (from just 2h ago), installed VeraCrypt from the GUI Software store, and created a new file container. Not hidden, ext4, Linux only use.
After formatting I got an error (can’t really remember) … end of data … not enough data … or something like that.
Tried formatting again, then got a pop-up with an error message
Broken Pipe - VeraCrypt::File::Write:384
On my other system (Manjaron - cinnamon - installed about a year ago with 5.15 kernel , just upgraded to 6.1), I am pretty installed it from the GUI Software Installer and never had any problems …
$ sudo inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=26d28c5f-d963-425f-9806-a810b3668471 rw quiet splash
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Unknown Mobo: ZOTAC model: ZBOX-CI323NANO v: XX serial: <filter>
UEFI-[Legacy]: American Megatrends v: B301P024 date: 05/07/2018
RAM: total: 15.54 GiB used: 2.03 GiB (13.1%)
Array-1: capacity: 16 GiB note: est. slots: 2 EC: None
Device-1: A1_DIMM0 type: DDR3 detail: N/A size: 8 GiB speed: 1600 MT/s
volts: curr: 1.35 min: 1.35 max: 1.5 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: KHX1600C9S3L/8G serial: <filter>
Device-2: A1_DIMM1 type: DDR3 detail: N/A size: 8 GiB speed: 1600 MT/s
Info: model: Intel Celeron N3150 socket: BGA1155 bits: 64 type: MCP
arch: Airmont level: v2 built: 2015-17 process: Intel 14nm family: 6
model-id: 0x4C (76) stepping: 3 microcode: 0x368
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 660 high: 1200 min/max: 480/2080 base/boost: 1600/2400
scaling: driver: intel_cpufreq governor: schedutil volts: 1.2 V
ext-clock: 80 MHz cores: 1: 480 2: 1200 3: 480 4: 480 bogomips: 12805
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics vendor: ZOTAC driver: i915 v: kernel arch: Gen-8
process: Intel 14nm built: 2014-15 ports: active: HDMI-A-3 empty: DP-1,
DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b1 class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-4:2 chip-ID: 046d:085e
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-3 mapped: HDMI-3 model: Dell P2217H serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x267mm (18.74x10.51") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel
bus-ID: 1-4:2 bus-ID: 00:1b.0 chip-ID: 046d:085e chip-ID: 8086:2284
class-ID: 0102 serial: <filter> class-ID: 0403
API: ALSA v: k6.1.21-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
tools: pacat,pactl,pavucontrol
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: ens1 state: down mac: <filter>
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b3 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
IF-ID-1: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-5.2:5 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 465.76 GiB used: 7.68 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 Series
type: SSD serial: <filter> rev: 9B0Q scheme: MBR
ID-1: / raw-size: 218.86 GiB size: 214.37 GiB (97.95%) used: 7.68 GiB (3.6%)
fs: ext4 block-size: 4096 B dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 26d28c5f-d963-425f-9806-a810b3668471
ID-1: /dev/sda1 maj-min: 8:1 size: 15.24 GiB fs: ext4 label: N/A
uuid: ec6f3699-be20-49de-a117-4c53a2e44ea9
ID-2: /dev/sda2 maj-min: 8:2 size: 218.86 GiB fs: ext4 label: N/A
uuid: e2c29aa9-d0a7-4356-9abf-a307c2cfc628
ID-3: /dev/sda3 maj-min: 8:3 size: 12.8 GiB fs: ext4 label: N/A
uuid: 116c8097-bbb0-4bd9-abd2-cddb13d91968
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
Device-1: 1-4:2 info: Logitech BRIO Ultra HD Webcam type: Video,Audio
driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 046d:085e class-ID: 0102 serial: <filter>
Hub-2: 1-5:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-5.1:4 info: Realtek 3-in-1 (SD/SDHC/SDXC) Card Reader
type: Mass Storage driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0bda:0153 class-ID: 0806 serial: <filter>
Device-2: 1-5.2:5 info: Intel Bluetooth wireless interface type: Bluetooth
Device-3: 1-5.3:6 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:0001 class-ID: 0300
Device-4: 1-5.4:7 info: Dell Universal Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 413c:2514 class-ID: 0300
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 204 Uptime: 39m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 942 libs: 295 tools: pamac Shell: Bash (sudo) v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.26
Kobold
15 November 2023 03:18
4
Straight after newest stable update from today, my Veracrypt shows error messages when i mount a drive, Not Enough Data and after repeated password, Broken Pipe error message.
I restarted Veracrypt and lucky its working for now… but there is something wrong with Veracrypt in the official repos!
systemd-coredump[17265]: [🡕] Process 17230 (veracrypt) of user 1000 dumped core.
Stack trace of thread 17230:
#0 0x00007f6ede4ac83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f6ede45c668 raise (libc.so.6 + 0x3e668)
#2 0x00007f6ede4444b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f6ede6dd3b2 _ZSt21__glibcxx_assert_failPKciS0_S0_ (libstdc++.so.6 + 0xdd3b2)
#4 0x00005609b2c64762 n/a (veracrypt + 0x1c7762)
#5 0x00005609b2b85a94 n/a (veracrypt + 0xe8a94)
#6 0x00007f6ede445cd0 n/a (libc.so.6 + 0x27cd0)
#7 0x00007f6ede445d8a __libc_start_main (libc.so.6 + 0x27d8a)
#8 0x00005609b2b8c775 n/a (veracrypt + 0xef775)
░░ Subject: Process 17230 (veracrypt) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 17230 (veracrypt) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
raguse
15 November 2023 06:12
5
@Kobold I had something similar, the disk unmounted itself all the time after a few seconds.
Solved it by going to >Settings>Mount Options>Uncheck Truecrypt mode and Mount volumes as read-only.
Somehow these settings got changed for me.
Please try.
Kobold
15 November 2023 08:12
6
Hmmm, i don’t have this issue at all. Why do you think its similar to mine, do you see this same errors?
I never use Truecrypt and i never had Truecrypt mode activated.
My mount volume is also not read only, i still have full access…
But I’am little bid worried, that my mount point becomes corrupted after time.
raguse
15 November 2023 08:44
7
It might not be the same issue as mine. My settings file got corrupted last time and even I used correct settings, every time I started the program the settings were back. So what I had to do was to go to settings and save the config file after adjusting the settings back.
Kobold
16 November 2023 05:31
8
I could unmount and mount it yesterday without an error and today there was also no error after Password.
It looks to me, there was just a temporary issue… maybe a corrupted settings file after the new stable update.
Actually, I just found out what my problem (likely) was.
I installed “some updates” (which likely contained some libs or other system files).
… then tried to mount a VC file … and got the error.
However, after a reboot everything was fine.
It might have been something else, but other than in this case I never had any problems with VC.
syncing system related files - kernel et.al - always requires a restart - there is no hot kernel reload with Manjaro.
