Hello, I know this is my first post here so hello.
Basically I wanted to install virtualbox and run a windows 10 vm for a few programs that dont run through wine. Whenever I open virtualbox (through konsole) I get an error "WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (5.10.42-1-MANJARO) or it failed to
load. Please recompile the kernel module and install it by
sudo /sbin/vboxconfig
You will not be able to start VMs until this problem is fixed.
But whenever I try to run “sudo /sbin/vboxconfig” like it tells me to, it says “sudo: /sbin/vboxconfig: command not found.”
The offical manjaro wiki page that I was using to install virtualbox does not have this error mentioned in it so I dont know what its deal is.
Please help
-chimp
