Variety Wallpaper Changer not changing on startup
When I start my system Variety loads but doesn’t change the wallpaper.
I have it set to change on startup.
If I log out and log back in it works just fine.
Here is my system:
[demo@Manjaro ~]$ inxi -Fazy
  Kernel: 6.4.16-5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
    root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 info: latte-dock
    wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
    v: N/A serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
    v: F.29 date: 11/02/2022
  ID-1: BAT0 charge: 61.2 Wh (90.1%) condition: 67.9/67.9 Wh (100.0%)
    volts: 12.5 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
    status: not charging cycles: 214
  Device-1: hid-0018:04F3:2992.0003-battery model: ELAN2514:00 04F3:2992
    serial: N/A charge: N/A status: N/A
  Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xF8
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 743 high: 1816 min/max: 400/4900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1816 2: 1228 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 906 bogomips: 36812
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
    ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
    class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
    speed: 8 GT/s bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 220 s-size: 443x249mm (17.44x9.80")
    s-diag: 508mm (20.01")
  Monitor-1: eDP-1 model: AU Optronics 0x30eb built: 2017 res: 3840x2160
    hz: 60 dpi: 284 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 3840x2160
  API: EGL Message: No EGL data available.
  API: OpenGL v: 4.6 vendor: intel mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
    es-v: 3.2 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9b41 memory: 14.9 GiB unified: yes
  API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce MX250 driver: nvidia v: 535.113.01 device-ID: 10de:1d13
    surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD Graphics
    (CML GT2) driver: mesa intel v: 23.1.9-manjaro1.1 device-ID: 8086:9b41
    surfaces: xcb,xlib
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
  API: ALSA v: k6.4.16-5-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  Local Storage: total: 931.51 GiB used: 274.71 GiB (29.5%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 163 GiB size: 160.13 GiB (98.24%) used: 59.51 GiB (37.2%)
    fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
  ID-2: /boot/efi raw-size: 499 MiB size: 498 MiB (99.80%)
    used: 415.6 MiB (83.4%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 410.57 GiB size: 403.06 GiB (98.17%)
    used: 214.8 GiB (53.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  System Temperatures: cpu: 55.0 C pch: 52.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 287 Uptime: 6m wakeups: 27759 Memory: total: 16 GiB note: est.
  available: 15.26 GiB used: 4.58 GiB (30.0%) Init: systemd v: 254
  Packages: 1851 pm: pacman pkgs: 1843 libs: 468 tools: pacaur,pamac,pikaur,yay
  pm: rpm pkgs: 0 pm: flatpak pkgs: 8 Shell: Bash v: 5.1.16
  running-in: alacritty inxi: 3.3.30
OK I don’t get it .
Now I rebooted and it is working as expected.
I didn’t change anything.
Can we keep this open for a while to see if it happens again.
Thanks
Or is there any logs I can check?
I tried
sudo dmesg | grep variety
but it didn’t bring up anything
KDE has its own wallpaper-changing capability. Snoop around under “Appearance” in “System Settings”. The reboot was probably required for Variety. It’s been a long time since I used it, but I’m much more comfortable with the comparative simplicity of Plasma’s own offerings. Cheers.
