The mouse cursor is not locked in the center of the screen so when I press any menu that requires the mouse, it takes a second or two to locate the mouse, it is BAD in stressful situations.
I have accepted the bug as “a thing that will probably be fixed down the line” but now I have died to many times because of not finding the mouse when pressing tab hence not being able to click hp pot in time. Why is this happening? Could it be a KDE thing or something?
The cursor should be locked in the center until menu is accessed.
Not sure if the behavior is present in other games, I mostly play strategy games and such.
Running game natively without proton from steam (steam-runtime)
Tried with both x11 and wayland, same behaviour.
inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 6.1.31-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=700d034d-b99a-482b-880b-9060acf3a6b3 rw rootflags=subvol=@
nvidia_drm.modeset=1 quiet splash udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: X670 AORUS ELITE AX v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F8d
date: 05/05/2023
System RAM: available: 31.09 GiB used: 5.45 GiB (17.5%)
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3068 high: 4700 min/max: 3000/5733 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3057 2: 3000
3: 3000 4: 3000 5: 3000 6: 3000 7: 4700 8: 3000 9: 3000 10: 3000 11: 2883
12: 3000 13: 3000 14: 3000 15: 3000 16: 3000 17: 3000 18: 3000 19: 3000
20: 3000 21: 3000 22: 3000 23: 3000 24: 3000 bogomips: 225274
Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
gfni ht hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku
pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good
sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: eVga.com. driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2204 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Asus VX279
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2
size: 621x341mm (24.45x13.43") diag: 690mm (27.2") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3090/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 15:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.31-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0f:00.0
chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:5 chip-ID: 0e8d:0616
Local Storage: total: 4.09 TiB used: 1.45 TiB (35.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 48.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD30EFRX-68EUZN0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 128 GiB size: 128 GiB (100.00%) used: 47.11 GiB (36.8%)
fs: btrfs dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 700d034d-b99a-482b-880b-9060acf3a6b3
used: 608 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: AC73-C072
ID-3: /home raw-size: 104.53 GiB size: 104.53 GiB (100.00%)
used: 9.4 GiB (9.0%) fs: btrfs dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: 2a875645-5701-4450-bd08-adf1f966a07c
ID-4: /media/diverse raw-size: N/A size: 3.56 TiB used: 1.72 TiB (48.5%)
fs: cifs dev: /dev/diverse
ID-5: /media/fil-fitt raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
used: 1.27 TiB (46.7%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: Lilla Fil-fitt disken uuid: CE8C0EC38C0EA655
ID-6: /media/games raw-size: 250 GiB size: 245.02 GiB (98.01%)
used: 123.07 GiB (50.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: Games uuid: ccfef3ee-65e0-45e4-aac2-4604ad2e696d
ID-7: /var/cache raw-size: 128 GiB size: 128 GiB (100.00%)
used: 47.11 GiB (36.8%) fs: btrfs dev: /dev/sda7 maj-min: 8:7 label: N/A
ID-8: /var/log raw-size: 128 GiB size: 128 GiB (100.00%)
ID-1: swap-1 type: partition size: 32 GiB used: 256 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 5ae8fbf5-a704-41ea-be6d-bf26b38325ed
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 480 GiB fs: ntfs label: Games
uuid: 68A4C531A4C50294
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 201.5 GiB fs: ext4 label: backup
uuid: 2b1e42bb-fe37-4fa1-991e-aab694b6b16f
ID-4: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: WIN-BOOT
uuid: 5483-0EFB
ID-5: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
ID-6: /dev/sda3 maj-min: 8:3 size: 200 GiB fs: ntfs label: windows
uuid: 6654845D5484323B
ID-7: /dev/sda4 maj-min: 8:4 size: 633 MiB fs: ntfs label: windows-extra
uuid: E61A49731A4941B3
ID-8: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Areson USB Device type: mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: e0ff:0005 class-ID: 0300
Device-2: 3-3:3 info: Microsoft Sidewinder X4 type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 045e:0768 class-ID: 0300
Device-3: 3-6:4 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-4: 3-7:5 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 9-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-11: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 59.8 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 444 Uptime: 3h 15m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1384 libs: 388 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.27
