Using the same official KDE installer I used for my desktop, I applied it to my laptop. First boot in and I’m stuck in shell. Updated the installer and the same problem occurred. This is a system that previously used Windows 10 on it and I’ve disabled secure boot. I cannot hold shift to go into grub and use init=bin/bash, although I would love to find a way to do this and grab my usb timeshare drive and fix everything.
The USB drives I used were both different, one with Ventoy and the other purely the KDE version installer
Noob question, but when you say “At the file”, Do you mean ~/etc/mkinitcpio.conf before I do the mkinitcpio -P command? Because when I do, it says that it’s not a directory which of course not, it’s a text file.
This is a whole block of instruction, they are numbered if you look at it. So basically:
Replace MODULES=() with MODULES=(vmd) in the file /etc/mkinitcpio.conf
Also ~ character stand for your home folder, so I guess you made a typo when writing “Do you mean ~/etc/mkinitcpio.conf” (note the out of place ~ character you put before the file path)
I will quote myself again in case you completely didn’t read it. You wrote MODULES=(vmd) in your terminal, this was not what was instructed. Edit the file.
We should move this back into my topic about this, however thank you for the clarification on using nano. With it I successfully change the file details and… I am still stuck in shell. Should I change the Binaries, Files, Hooks, or Compressions in any way as well since this hasn’t worked?
I should say that the Module wasn’t blank like you had it however, it was filled with MODULES=(piix ide_disk reiserfs). If I need to add the vmd on top of that, let me know.
Did you remove the pound (#) character at the beginning of this line? If you did, set it back. If you didn’t, then the line is commented and it won’t have any effect generating the initramfs.
Right below that line, there should be an empty MODULES=() directive. That’s where you add the vmd module mentioned above.
Once you have done that, run sudo mkinitcpio -P. That should do the trick.
This is the entire Module part in mkinitcpio.conf is:
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=""
Are you saying I should add the vmd to MODULES="vmd"?
Okay, I should have realized anything beginning with # was a comment, but this is a lesson learned.
Thank you all for your time and effort. It now boots up properly.
I changed solution to megavolt’s post as my last reply was the solution to your non understanding of editing the config file, his reply was the solution to the thread.
