UT2004 64-bit fails to launch under Wayland on Manjaro Linux
Hi everyone,
I recently switched my Manjaro system from the stable branch to the testing branch, which also involved upgrading the kernel to 6.17.0-rc7-1. Everything else remained largely the same. Prior to this change, on the stable branch with the previous kernel, UT2004 64-bit ran fine under Wayland without crashes.
System information:
  • OS: Manjaro Linux (testing branch, rolling)
  • Kernel: 6.17.0-rc7-1-MANJARO
  • Desktop environment: KDE Plasma 6.4.5 (Wayland session)
  • KWin: 6.4.5-3
  • Mesa: 25.2.3-2
  • OpenGL: 4.6 (Compatibility Profile)
  • GPU: AMD Radeon RX 5500 XT (radeonsi, navi14)
  • SDL packages:
    • sdl12-compat 1.2.68-2
    • sdl2-compat 2.32.56-2
    • sdl3 3.2.22-1
    • lib32-sdl12-compat 1.2.68-2
    • lib32-sdl2-compat 2.32.56-1
    • lib32-sdl3 3.2.20-1
  • Wayland-related packages:
    • wayland 1.24.0-1
    • wayland-utils 1.2.0-2
    • xorg-xwayland 24.1.8-1
    • kwayland 6.4.5-1
    • kwayland-integration 6.4.5-1
    • kwayland5 5.116.0-1
    • lib32-wayland 1.23.1-1
    • qt5-wayland 5.15.17+kde+r57-1
    • qt6-wayland 6.9.2-1
  • Audio: PulseAudio running on PipeWire 1.4.8
Issue:
After switching to the testing branch and the new kernel, launching the 64-bit UT2004 executable under Wayland shows a brief icon and throbber but then disappears, without starting the game.
Workaround:
The game runs correctly when forcing SDL to use X11:
export SDL_VIDEODRIVER=x11
./ut2004-bin-linux-amd64
Without SDL_VIDEODRIVER=x11, the game crashes with a segmentation fault.
Crash log (GDB backtrace):
Thread 1 "ut2004-bin-linu" received signal SIGSEGV, Segmentation fault.
0x0000000000000000 in ?? ()
#0  0x0000000000000000 in ?? ()
#1  0x0000000000d25999 in UOpenGLRenderDevice::SetRes(UViewport*, int, int, int, int, int) ()
#2  0x0000000000d1e1d5 in USDLViewport::TryRenderDevice(wchar_t const*, int, int, int) ()
#3  0x0000000000d1cd81 in USDLViewport::OpenWindow(unsigned long, int, int, int, int, int) ()
#4  0x000000000067e403 in UGameEngine::Init() ()
#5  0x0000000000533c14 in ?? ()
#6  0x000000000052eef8 in main ()
    inxi -zv8
  Kernel: 6.17.0-rc7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64
    root=UUID=056bd6a9-c464-4351-83f3-fae7ba0af99a rw rootflags=subvol=@
    quiet splash resume=UUID=2fb0f355-cde7-4eb9-9259-9822d28c5af2
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.18.0
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
    UEFI: American Megatrends v: 5002 date: 01/13/2025
  ID-1: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
    model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
    serial: <filter> charging: status: charging cycles: N/A
  System RAM: total: 32 GiB available: 31.25 GiB used: 7.39 GiB (23.7%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F4-3200C14-8GFX serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201030
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3854 min/max: 556/4854 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3854 2: 3854 3: 3854
    4: 3854 5: 3854 6: 3854 7: 3854 8: 3854 9: 3854 10: 3854 11: 3854 12: 3854
    13: 3854 14: 3854 15: 3854 16: 3854 bogomips: 121597
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 14 [Radeon RX 5500/5500M /
    Pro 5500M] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-1
    code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2
    bus-ID: 0d:00.0 chip-ID: 1002:7340 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 5760x3360 display-ID: 0
  Monitor-1: DP-3 pos: top-right model: LG (GoldStar) 27GN950
    serial: <filter> built: 2021 res: mode: 3840x2160 hz: 144 scale: 140% (1.4)
    to: 2743x1543 dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green:
    x: 0.267 y: 0.686 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: HDMI-A-1 pos: bottom-l model: Idek Iiyama PLE2607WS
    serial: <filter> built: 2008 res: mode: 1920x1200 hz: 60 scale: 160% (1.6)
    to: 1200x1920 dpi: 89 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.282 y: 0.600 blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 550x344mm (21.65x13.54") diag: 649mm (25.5") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi
    navi14 LLVM 20.1.8 DRM 3.64 6.17.0-rc7-1-MANJARO) device-ID: 1002:7340
    memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 5 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv v: 25.2.3-arch1.2
    device-ID: 1002:7340 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio vendor: ASRock
    bus-ID: 0d:00.1 chip-ID: 1002:ab38 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.17.0-rc7-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
    vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 05:00.0 chip-ID: 1d6a:11b1
    class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  IF-ID-1: wg0-mullvad state: unknown speed: 10000 Mbps duplex: full
    mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
  Device-2: Microsoft Nano Transceiver v1.0 for Bluetooth
    driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 3-3.4:8 chip-ID: 045e:0745 class-ID: 0300
  Local Storage: total: 8.3 TiB used: 1.4 TiB (16.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 47.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 990 PRO 4TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 48.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B1Q scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-1: / raw-size: 2.59 TiB size: 2.59 TiB (100.00%) used: 62.86 GiB (2.4%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:4 label: N/A
    uuid: 056bd6a9-c464-4351-83f3-fae7ba0af99a
    used: 632 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: N/A
    uuid: 5BFB-F55D
  ID-3: /home raw-size: 3.49 TiB size: 3.44 TiB (98.40%)
    used: 1.26 TiB (36.7%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:5
    label: N/A uuid: 1763d5a3-375c-4e17-a4cf-f96bde772b42
  ID-4: /run/media/jorgecpd/41fd8083-4e6d-43c6-b78e-8c11b36d8410
    raw-size: 117.19 GiB size: 114.79 GiB (97.95%) used: 77.6 GiB (67.6%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 41fd8083-4e6d-43c6-b78e-8c11b36d8410
  ID-5: /var/cache raw-size: 2.59 TiB size: 2.59 TiB (100.00%)
    used: 62.86 GiB (2.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:4
    label: N/A uuid: 056bd6a9-c464-4351-83f3-fae7ba0af99a
  ID-6: /var/log raw-size: 2.59 TiB size: 2.59 TiB (100.00%)
  ID-1: swap-1 type: partition size: 63.5 GiB used: 85.9 MiB (0.1%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:3 label: Swap
    uuid: 2fb0f355-cde7-4eb9-9259-9822d28c5af2
  ID-1: /dev/nvme1n1p2 maj-min: 259:6 size: 150 GiB fs: btrfs label: snapshots
    backup syst\xc3\xa8me uuid: e51dc2b8-8026-4865-99e5-09216373f6af
  ID-2: /dev/sda2 maj-min: 8:2 size: 2.05 GiB fs: vfat label: N/A
    uuid: B6FE-6408
  ID-3: /dev/sdb1 maj-min: 8:17 size: 868 MiB fs: vfat label: N/A
    uuid: A567-7EF7
  ID-4: /dev/sdb2 maj-min: 8:18 size: 930.66 GiB fs: ext4 label: N/A
    uuid: f18e7382-b9e7-4ab1-84ec-8fc5127f31d3
  Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-5.3:4 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Device-2: 1-5.4:5 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:1872 class-ID: 0300
    serial: <filter>
  Device-3: 1-6:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-2.1:10 info: Advanced Card Systems ACR38 SmartCard Reader
    type: smart card driver: N/A interfaces: 1 rev: 1.1
    chip-ID: 072f:90cc class-ID: 0b00
  Hub-6: 3-2.2:5 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
    rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
  Device-1: 3-2.2.2:7 info: Logitech G502 LIGHTSPEED Wireless Gaming Mouse
    type: mouse,keyboard,HID driver: logitech-hidpp-device,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 498mA
    chip-ID: 046d:c08d class-ID: 0300 serial: <filter>
  Device-2: 3-2.2.4:11 info: LG USA Monitor Controls
    type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 043e:9a8a class-ID: 0a00 serial: <filter>
  Hub-7: 3-3:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
  Device-1: 3-3.1:6 info: Logitech Lightspeed Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c539 class-ID: 0300
  Device-2: 3-3.4:8 info: Microsoft Nano Transceiver v1.0 for Bluetooth
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-10: 4-2.2:4 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
    rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    chip-ID: 0451:8140 class-ID: 0900
  Hub-11: 4-3:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
  Hub-12: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-13: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 41.0 C mobo: 38.0 C gpu: amdgpu temp: 50.0 C
    mem: 0.0 C
  Fan Speeds (rpm): cpu: 688 gpu: amdgpu fan: 1475
  Packages: pm: pacman pkgs: 1646 libs: 429 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://manjaro.kurdy.org/testing/$repo/$arch
    2: https://mirror.komelt.dev/manjaro/testing/$repo/$arch
    3: https://mirror.raiolanetworks.com/manjaro/testing/$repo/$arch
    4: https://mirrors.up.pt/pub/manjaro/testing/$repo/$arch
    5: https://mirrors2.manjaro.org/testing/$repo/$arch
    6: http://ftp.uni-kl.de/pub/linux/manjaro/testing/$repo/$arch
    7: https://manjaro.ynh.ovh/testing/$repo/$arch
    8: https://mirror.ibakerserver.pt/manjaro/testing/$repo/$arch
    9: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    10: https://mirror.futureweb.be/manjaro/testing/$repo/$arch
    11: https://manjaro.syxpi.fr/manjaro/testing/$repo/$arch
    12: https://mirror.init7.net/manjaro/testing/$repo/$arch
    13: https://mirror.koddos.net/manjaro/testing/$repo/$arch
    14: https://ftp.free.org/mirrors/repo.manjaro.org/repos/testing/$repo/$arch
    15: https://manjaro.mirrors.lavatech.top/testing/$repo/$arch
    16: https://ipng.mm.fcix.net/manjaro/testing/$repo/$arch
    17: https://mirror.alpix.eu/manjaro/testing/$repo/$arch
    18: https://mirror.bouwhuis.network/manjaro/testing/$repo/$arch
    19: https://ftp.snt.utwente.nl/pub/linux/manjaro/testing/$repo/$arch
    20: https://mirrors.eric.ovh/manjaro/testing/$repo/$arch
    21: https://ask4.mm.fcix.net/manjaro/testing/$repo/$arch
    22: https://mirror.alwyzon.net/manjaro/testing/$repo/$arch
    23: https://mirror.netcologne.de/manjaro/testing/$repo/$arch
    24: https://manjaro.mirror.wearetriple.com/testing/$repo/$arch
    25: https://mirror.23m.com/manjaro/testing/$repo/$arch
    26: https://mirror.it4i.cz/manjaro/testing/$repo/$arch
    27: https://ftp.belnet.be/mirrors/manjaro/repos/testing/$repo/$arch
    28: https://mirror.vinehost.net/manjaro/testing/$repo/$arch
    29: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/testing/$repo/$arch
    30: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/testing/$repo/$arch
    31: https://ftp.gwdg.de/pub/linux/manjaro/testing/$repo/$arch
    32: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/testing/$repo/$arch
    33: https://mirror.easyname.at/manjaro/testing/$repo/$arch
    34: https://mirror1.sox.rs/manjaro/testing/$repo/$arch
    35: https://mirrors.nic.cz/manjaro/testing/$repo/$arch
    36: https://manjaro.mirror.garr.it/manjaro/testing/$repo/$arch
    37: https://ftp.tu-chemnitz.de/pub/linux/manjaro/testing/$repo/$arch
    38: https://ftp.halifax.rwth-aachen.de/manjaro/testing/$repo/$arch
    39: https://mirrors.dotsrc.org/manjaro/testing/$repo/$arch
    40: https://mirror.telepoint.bg/manjaro/testing/$repo/$arch
    41: https://mirror.datacenter.by/pub/mirrors/manjaro/testing/$repo/$arch
    42: https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
    43: https://quantum-mirror.hu/mirrors/pub/manjaro/testing/$repo/$arch
    44: https://mirrors.cicku.me/manjaro/testing/$repo/$arch
    45: https://cofractal-ewr.mm.fcix.net/manjaro/testing/$repo/$arch
    46: https://mirror.mobinhost.com/manjaro/testing/$repo/$arch
    47: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
    48: https://mirror.dkm.cz/manjaro/testing/$repo/$arch
    49: https://fosszone.csd.auth.gr/manjaro/testing/$repo/$arch
    50: https://ftp.linux.org.tr/manjaro/testing/$repo/$arch
    51: https://mirror.hostiko.network/manjaro/testing/$repo/$arch
    52: https://manjaro.mirrors.uk2.net/testing/$repo/$arch
    53: https://ct.mirror.garr.it/mirrors/manjaro/testing/$repo/$arch
    54: https://ba.mirror.garr.it/mirrors/manjaro/testing/$repo/$arch
    55: https://mirror.xenyth.net/manjaro/testing/$repo/$arch
    56: https://ftp.psnc.pl/linux/manjaro/testing/$repo/$arch
    57: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
    58: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    59: https://manjaro.grena.ge/testing/$repo/$arch
    60: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
    61: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    62: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
    63: https://manjarolinux-mirror.cloud.mu/testing/$repo/$arch
    64: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    65: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    66: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
    67: https://ziply.mm.fcix.net/manjaro/testing/$repo/$arch
    68: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
    69: https://mirrors.gigenet.com/manjaro/testing/$repo/$arch
    70: https://edgeuno-bog2.mm.fcix.net/manjaro/testing/$repo/$arch
    71: https://mirror.csclub.uwaterloo.ca/manjaro/testing/$repo/$arch
    72: https://mnvoip.mm.fcix.net/manjaro/testing/$repo/$arch
    73: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    74: https://mirror.xeonbd.com/manjaro/testing/$repo/$arch
    75: https://manjaro.ipacct.com/manjaro/testing/$repo/$arch
    76: https://mirror.freedif.org/Manjaro/testing/$repo/$arch
    77: https://mirror.dc.uz/manjaro/testing/$repo/$arch
    78: https://mirrors.atlas.net.co/manjaro/testing/$repo/$arch
    79: https://manjaro.mirror.liquidtelecom.com/testing/$repo/$arch
    80: https://distrohub.kyiv.ua/manjaro/testing/$repo/$arch
    81: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/testing/$repo/$arch
    82: https://mirror.meowsmp.net/manjaro/testing/$repo/$arch
    83: https://repo.ialab.dsu.edu/manjaro/testing/$repo/$arch
    84: https://mirrors.sonic.net/manjaro/testing/$repo/$arch
    85: https://gsl-syd.mm.fcix.net/manjaro/testing/$repo/$arch
    86: https://muug.ca/mirror/manjaro/testing/$repo/$arch
    87: https://manjaro.c3sl.ufpr.br/testing/$repo/$arch
    88: https://linorg.usp.br/manjaro/testing/$repo/$arch
    89: https://mirrors.xtom.jp/manjaro/testing/$repo/$arch
    90: https://mirror.kamtv.ru/manjaro/testing/$repo/$arch
    91: https://mirrors.ocf.berkeley.edu/manjaro/testing/$repo/$arch
    92: https://mirror.fcix.net/manjaro/testing/$repo/$arch
    93: https://ftpmirror1.infania.net/mirror/manjaro/testing/$repo/$arch
    94: https://mirrors.ucr.ac.cr/manjaro/testing/$repo/$arch
    95: https://kartolo.sby.datautama.net.id/manjaro/testing/$repo/$arch
    96: https://ftp.caliu.cat/pub/distribucions/manjaro/testing/$repo/$arch
    97: https://ftp.riken.jp/Linux/manjaro/testing/$repo/$arch
    98: http://ossmirror.mycloud.services/os/linux/manjaro/testing/$repo/$arch
    99: https://mirror.phoepsilonix.love/manjaro/testing/$repo/$arch
    100: https://mirror.aarnet.edu.au/pub/manjaro/testing/$repo/$arch
    101: https://mirror.2degrees.nz/manjaro/testing/$repo/$arch
    102: https://bd.mirror.vanehost.com/Manjaro/testing/$repo/$arch
    103: https://repo.iut.ac.ir/repo/manjaro/testing/$repo/$arch
    104: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/testing/$repo/$arch
    105: https://mirror.kku.ac.th/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 434
  1: cpu: 7.6% command: firefox pid: 8113 mem: 884.2 MiB (2.7%)
  2: cpu: 5.3% command: mullvad-daemon pid: 860 mem: 63.6 MiB (0.1%)
  3: cpu: 3.5% command: firefox pid: 8911 mem: 686.5 MiB (2.1%)
  4: cpu: 2.7% command: kwin_wayland pid: 1124 mem: 679.2 MiB (2.1%)
  5: cpu: 2.7% command: firefox pid: 8693 mem: 526.2 MiB (1.6%)
  Memory top: 5 of 434
  1: mem: 1766.7 MiB (5.5%) command: qbittorrent pid: 1941 cpu: 2.4%
  2: mem: 1354.7 MiB (4.2%) command: pamac-manager pid: 22281 cpu: 1.8%
  3: mem: 1159.0 MiB (3.6%) command: gdb pid: 18488 cpu: 0.4%
  4: mem: 884.2 MiB (2.7%) command: firefox pid: 8113 cpu: 7.6%
  5: mem: 722.4 MiB (2.2%) command: plasmashell pid: 1384 cpu: 0.4%
  Processes: 434 Power: uptime: 1h 54m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.3 running-in: konsole inxi: 3.3.39
Starting with 6.4.5 KWin was split into two branches, KWin and KWin_X11. I suspect you are finding that an X11 dependant program requires the environmental variable to be set before being called is the normal condition.
Just modify the .desktop to do so.
Abandoned topic (60+ days)
