Hi,
I have just found out that I have an executable file called [ (open-square-bracket), which appears to come from coreutils 8.32-1:
$ pacman -Qo /usr/bin/\[
/usr/bin/[ is owned by coreutils 8.32-1
Is that intentional?
Hi,
Yes and it is the same as test
check out
man test
And both [ and test are also internal commands in bash, but the POSIX specification demands that they be also available as separate executables, in case one were to use a shell where they are not internal.
