Using Remote Desktop Connection to connect manjaro installed with xrdp faile because of "Error connecting to user session"
I want to use Remote Desktop Connection to connect Manjaro, i config manjaro like this:
yay -S xrdp
sudo pacman -S xorgxrdp
systemctl start xrdp
systemctl enable xrdp
systemctl status xrdp.service
kate /etc/X11/Xwrapper.config # add `allowed_users=anybody`
kate ~/.xinitrc # change `local dbus_args=(--sh-syntax --exit-with-session)` to ` local dbus_args=(--sh-syntax)`
systemctl restart xrdp
And then i connect manjaro in windows using Remote Desktop Connection, but i faild like this:
connecting to sesman on 127.0.0.1:3350
sesman connect ok
sending login info to session manager. Please wait...
login successful for user shy on display 10
started connecting
connecting problem, giving up
some problem
I wonder how to solve this problem, thank you!
My system is Manjaro KDE Plasma, 5.25.5
CPU:i7-12700F
GPU: RTX 3070
If i config VNC and using VNC Viewer on windows to connect VNC under mode xfce, everything is ok, but if i change xfce to plasma, VNC Viewer will see an black screen.
Has anyone solved the same problem? Or does anyone know how to fix this error?" (我有同样的问题,请问楼主问题解决了吗?或者有人知道如何修复这个错误?)
