I have read:
https://forums.developer.nvidia.com/t/nvidia-470-gdm-wayland-fail-to-start-when-a-monitor-is-plugged-in/182515/20
https://github.com/NVIDIA/egl-wayland/issues/45
[Marc-barbier]
[Nov 11]
I have good news and bad new my friends.
The good :
Since the release of the latest Xwayland version you no longer need egl-wayland to have good performance in XWayland. So you can remove egl-wayland from your system and get a working wayland based system without the crashes.
removing egl-wayland fixes the crashes when plugging in a monitor
KDE plasma works perfectly
The Bad:
if you have a monitor plugged in to the nvidia gpu it will display nothing in sway, Weston, gnome
if you start a game with prime-run (or the env vars for prime-offload) gnome will crash.
It seemed that: egl-wayland which causes the crash was required by nvidia driver. but the newest driver no longer needs it.
And I do installed the newest nvidia driver:
NVIDIA Driver Version: 510.60.02
NVML Version:11.510.60.02
However when I tried to remove egl-wayland:
could not satisfy dependencies:
- removing egl-wayland breaks dependency 'egl-wayland' required by nvidia-utils
So, to solve the crash, Should i remove egl-wayland? and how?
I would appreciate it if you could help me!
youll need to remove first nvidia, then uninstall the egl wayland, install nvidia again, reboot
or you can just start your session with x11 instead of wayland… in the login menu select x11
I have tried your solution.when I removed nvidia prime driver the egl-wayland was removed the same time. and after I installed nvidia prime driver. and start up with wayland. the egl-wayland backed again.
xorg does perform normal no matter egl-wayland installed or not (maybe egl will not be invoked in xorg). but gnome’s animation on xorg is stuttering. that’s why i want to change to wayland.
thanks, anyway
provide formated output of:
inxi --admin --verbosity=7 --filter --width
mhwd -l
mhwd -li
inxi --admin --verbosity=7 --filter --width:
Kernel: 5.10.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=063ff766-cf53-4ab3-8ec4-b566ccc310ca rw crashkernel=auto rhgb
quiet amd_iommu=on iommu=pt vfio-pci.ids=10de:1f99 kvm.ignore_msrs=1
video=vesafb:off,efifb:off quiet udev.log_priority=3 nvidia-drm.modeset=1
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: 1: GDM
v: 41.3 2: LightDM v: 1.30.0 note: stopped Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 82B6 v: Lenovo Legion R7000 2020
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion R7000 2020
Mobo: LENOVO model: LNVNB161216 v: SDK0L77769 WIN
serial: <superuser required> UEFI: LENOVO v: EUCN31WW date: 01/01/2021
ID-1: BAT0 charge: 50.8 Wh (95.0%) condition: 53.5/60.0 Wh (89.1%)
volts: 16.9 min: 15.4 model: Celxpert L19C4PC0 type: Li-poly
serial: <filter> status: N/A cycles: 151
RAM: total: 15.01 GiB used: 5.71 GiB (38.1%)
RAM Report:
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1874 high: 2815 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2815 2: 2757
3: 1744 4: 1831 5: 1719 6: 1826 7: 1500 8: 1528 9: 1827 10: 1779 11: 1510
12: 1656 bogomips: 71897
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt
Device-1: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 510.60.02
alternate: nouveau pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
gpu: nvidia,amdgpu d-rect: 4480x1440 display-ID: 0
Monitor-1: HDMI-1 pos: right model: SAM C27H71x res: 2560x1440 hz: 60
dpi: 108 scale: 1 size: 600x340mm (23.62x13.39") diag: 690mm (27.15")
modes: N/A
Monitor-2: eDP-2 pos: primary,left model: BOE 0x0900 res: 1920x1080 hz: 60
dpi: 143 scale: 1 size: 340x190mm (13.39x7.48") diag: 389mm (15.33")
modes: N/A
Message: Wayland GBM/EGL data currently not available.
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.109-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: utun state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:4
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 942.7 GiB used: 222.77 GiB (23.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512TDV
lanes: 4 type: SSD serial: <filter> rev: 3009P4LN temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Acer model: SSDSWIFT715500G
type: SSD serial: <filter> rev: 4A0 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
used: 222.71 GiB (47.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 063ff766-cf53-4ab3-8ec4-b566ccc310ca
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 58.2 MiB (22.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 751E-C585
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 475.04 GiB fs: ntfs
label: Windows-SSD uuid: 9A20C00E20BFEF7F
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 660 MiB fs: ntfs label: N/A
uuid: 647675F37675C678
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: 16A2C0C4A2C0AA17
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: Dell KB216 Wired Keyboard type: Keyboard,HID
power: 100mA chip-ID: 413c:2113 class-ID: 0300
Device-2: 1-3:3 info: Syntek Integrated Camera type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-2:3 info: E-Signal USB Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 260d:1010 class-ID: 0300
Device-2: 3-3:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-3: 3-4:5 info: Integrated Express ITE Device(8910) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c100 class-ID: 0301
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
System Temperatures: cpu: 42.1 C mobo: N/A gpu: amdgpu temp: 39.0 C
Processes: 390 Uptime: 20m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1567 lib: 448
Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.15
mhwd -l:
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:1f99) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-prime 2021.12.18 false PCI
video-hybrid-amd-nvidia-470xx-prime 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:05:00.0 (0300:1002:1636) Display controller ATI Technologies Inc:
mhwd -li
> Installed PCI configs:
you dont even have installed nvidia drivers:
install drivers:
sudo mhwd -i pci video-hybrid-amd-nvidia-prime
sudo mhwd -i pci video-modesetting
reboot and check
base: Arch Linux
RAM: total: 15.01 GiB used: 2.45 GiB (16.3%)
RAM Report:
desc: 2x4 MiB
Speed (MHz): avg: 1700 high: 3024 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1683 2: 1573
3: 1502 4: 1476 5: 3024 6: 1740 7: 1449 8: 1480 9: 1493 10: 1422 11: 1811
12: 1758 bogomips: 71880
alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-2 model: BOE 0x0900 res: 1920x1080 hz: 60 dpi: 143 scale: 1
size: 340x190mm (13.39x7.48") diag: 389mm (15.33") modes: N/A
Local Storage: total: 942.7 GiB used: 223.34 GiB (23.7%)
lanes: 4 type: SSD serial: <filter> rev: 3009P4LN temp: 36.9 C scheme: GPT
used: 223.28 GiB (48.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
class-ID: e001
System Temperatures: cpu: 44.8 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 364 Uptime: 1m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1574 lib: 450
check the crashing/ freezing now… and if you really dont need the ‘egl-wayland’ open add/remove software and click mark as explicitly installed, reboot and try to uninstall it… if you didnt get any nvidia dependency issues, reboot again after uninstalling it, and check the freezing/crashing
have reboot and tried for several times. there still shows:
``` :rofl:
i tried uninstall the egl-wayland on manjaro KDE, and get the same nvidia dependency issue… lets wait till someone more competent replies…
BR-1
22 April 2022 10:05
12
I’m having problems (intel/nvidia & gnome/wayland) when connecting external monitors as well, but mostly black screens.
I recently tried Feodra workstation 36 (beta) and my external monitor just worked there (although it didn’t quite feel like 60fps). It had gnome 42 wayland and used nouveau, so I’m hoping these issues get better with gnome 42, or alternatively nouveau could be an option.
Hello @DannyLiu
I guess there is no way to remove egl-wayland without removing nvidia-utils. The only way would be getting the PKGBUILD remove egl-wayland from the dependencies and package it yourself.
Not recommended, but you can remove them:
pamac list --files egl-wayland | xargs rm -Rf {}
I am not responsible for any damage. Your are on your own here.
I have run pamac list --files egl-wayland | xargs rm -Rf {} . Fortunately the system didn’t crash . But the freeze problem didn’t be solved either. Maybe we should wait Nvidia official to fix it. And I will continue to use X11 for now (although it is stuttering . Thanks
and did you check that you actually have uninstalled the egl-wayland? just to be sure
I have tried to remove egl-wayland the way you mentioned. But it always shows dependency problems. and for @megavolt 's solution, it still freeze when I plugin the secondary monitor after running :
Maybe there are more problems beyond egl-wayland dependency. Because I have meet too many problems with Nvidia graphic card in Linux. And for now, I have two solutions:
Using nvidia proprietary driver and login with X11
Using Wayland without proprietary driver
