Hello,
I noticed that my brand new Logitech Signature M650 bluetooth mouse breaks the connectivity of the wifi. The problem appears to be Manjaro specific as wifi works fine with this particular mouse at the same hardware with the Windows 10 and the latest Ubuntu (live USB mode).
I also tested in the live mode with the clean Manjaro XFCE USB stick and the problem is the same so I guess it is not due the possible corruption of my system.
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=35a59ed2-a05a-4f63-8a2e-8a729b8db541 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: N76VM v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: N76VM v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: N76VM.215 date: 07/08/2013
ID-1: BAT0 charge: 19.9 Wh (95.2%) condition: 20.9/57.7 Wh (36.2%)
volts: 11.1 min: 11.1 model: ASUSTeK N56--52 type: Li-ion serial: N/A
status: not charging cycles: 577
RAM: total: 15.51 GiB used: 8.87 GiB (57.2%)
Info: model: Intel Core i7-3610QM bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1462 high: 3300 min/max: 1200/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1197 2: 1200 3: 1200
4: 1197 5: 3300 6: 1200 7: 1200 8: 1205 bogomips: 36734
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166
class-ID: 0300
Device-2: NVIDIA GF108M [GeForce GT 620M/630M/635M/640M LE] vendor: ASUSTeK
driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: series: 390.xx+
status: legacy-active (EOL~late 2022) arch: Fermi code: GF1xx
process: 40/28nm built: 2010-16 pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:0de9 class-ID: 0300
Device-3: Suyin UVC HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.3:4
chip-ID: 064e:d213 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: LVDS-1 mapped: LVDS1 model: Chi Mei Opto 0x1720 built: 2011
res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2 size: 380x210mm (14.96x8.27")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.2 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0887
class-ID: 0280
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK N56VZ
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 04:00.0 chip-ID: 1969:1091 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 1-1.1:3 chip-ID: 8087:07da class-ID: e001
Local Storage: total: 1.13 TiB used: 735.57 GiB (63.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 96R9 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DS8A8SH rev: KAA2
dev-links: cdrom
ID-1: / raw-size: 98.37 GiB size: 96.27 GiB (97.86%) used: 58.19 GiB (60.4%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 35a59ed2-a05a-4f63-8a2e-8a729b8db541
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 25.5 MiB (13.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: E2AB-97A0
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 677.35 GiB (74.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: hima
uuid: 611670a0-a4f7-42f1-86d1-aaff3d328716
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 99.28 GiB fs: ntfs label: OS
uuid: 508CDD998CDD79C4
ID-3: /dev/sda4 maj-min: 8:4 size: 611 MiB fs: ntfs label: N/A
uuid: F246E97746E93D4B
ID-4: /dev/sda5 maj-min: 8:5 size: 25 GiB fs: ntfs label: Recovery
uuid: AC7A43BA7A438056
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Intel Centrino Bluetooth Wireless Transceiver
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-2: 1-1.3:4 info: Suyin UVC HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 064e:d213
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
Processes: 266 Uptime: 1d 3h 41m wakeups: 2 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1813 pm: dpkg pkgs: 0 pm: pacman pkgs: 1801 libs: 450
tools: pacaur,pamac,yay pm: flatpak pkgs: 6 pm: snap pkgs: 6 Shell: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.24
And when the new mouse is turned on, in the dmesg I got:
[89811.085755] input: Logi M650 Mouse as /devices/virtual/misc/uhid/0005:046D:B02A.0004/input/input33
[89811.086016] hid-generic 0005:046D:B02A.0004: input,hidraw1: BLUETOOTH HID v0.13 Mouse [Logi M650] on 68:5d:43:5a:d3:35
[89823.541469] wlp3s0: deauthenticated from aa:bb:cc:dd:ee:ff (Reason: 6=CLASS2_FRAME_FROM_NONAUTH_STA)
[89823.697143] wlp3s0: authenticate with aa:bb:cc:dd:ee:ff
[89823.698483] wlp3s0: send auth to aa:bb:cc:dd:ee:ff (try 1/3)
[89823.707839] wlp3s0: authenticated
[89823.708099] wlp3s0: waiting for beacon from aa:bb:cc:dd:ee:ff
[89823.737066] wlp3s0: associate with aa:bb:cc:dd:ee:ff (try 1/3)
[89823.745353] wlp3s0: RX AssocResp from aa:bb:cc:dd:ee:ff (capab=0x431 status=0 aid=1)
[89823.766845] wlp3s0: associated
[89827.610816] wlp3s0: deauthenticated from aa:bb:cc:dd:ee:ff (Reason: 6=CLASS2_FRAME_FROM_NONAUTH_STA)
[89827.727918] wlp3s0: authenticate with aa:bb:cc:dd:ee:ff
[89827.730091] wlp3s0: send auth to aa:bb:cc:dd:ee:ff (try 1/3)
[89827.737636] wlp3s0: authenticated
[89827.737953] wlp3s0: waiting for beacon from aa:bb:cc:dd:ee:ff
[89827.830410] wlp3s0: associate with aa:bb:cc:dd:ee:ff (try 1/3)
[89827.838304] wlp3s0: RX AssocResp from aa:bb:cc:dd:ee:ff (capab=0x431 status=0 aid=1)
[89827.842629] wlp3s0: associated
[89832.414671] wlp3s0: deauthenticated from aa:bb:cc:dd:ee:ff (Reason: 6=CLASS2_FRAME_FROM_NONAUTH_STA)
[89832.521416] wlp3s0: authenticate with aa:bb:cc:dd:ee:ff
[89832.523668] wlp3s0: send auth to aa:bb:cc:dd:ee:ff (try 1/3)
[89832.536377] wlp3s0: authenticated
[89832.536662] wlp3s0: waiting for beacon from aa:bb:cc:dd:ee:ff
[89832.643628] wlp3s0: associate with aa:bb:cc:dd:ee:ff (try 1/3)
[89832.652504] wlp3s0: RX AssocResp from aa:bb:cc:dd:ee:ff (capab=0x431 status=0 aid=1)
[89832.656821] wlp3s0: associated
As soon as I turn off the Logitech M650 mouse, the wifi connectivity returns. My old lousy Dacota mouse works without interfering to the wifi, but bluetooth is somewhat unstable (the reason I purchased M650). Using the mouse with the USB dongle causes no problem, but I want all possible USB ports not occupied. That’s why bluetooth mouse.
This seems a bug to me or am I missing something? Any ideas?
