Hey,
I’m switching from Win10 to Manjaro KDE.
Everything is up-and-coming, except my much used iPod.
It seems the newer ones (gen 5 and up) are not supported anymore…?
iTunes doesn’t seem to sync either under Wine.
Is there a workaround to get music synced on my iPod Nano 7 generation?
Tomek
2
If you want use iTunes you can use this or this script.
dingus
3
Does the first option work with iPod syncing? I see the second option states on the site that it does not
