Which programs use the Templates and Public directories listed in XDG user directories? Will those programs break if I remove Templates or Public? Is Public configured to be ‘shared’ or visible to other users locally/remotely by xdg-user-dirs or another program?
On KDE from memory if you delete these folders it does not recreate when you login. I remove these folders, on every KDE install I made. I think it uses the home folder itself when you delete them.
You can delete them. But they’ll come back if you run xdg-user-dirs-update
What I got:
$ cat /etc/xdg/user-dirs.defaults
# Default settings for user directories
# The values are relative pathnames from the home directory and
# will be translated on a per-path-element basis into the users locale
DESKTOP=desktop
DOWNLOAD=dl
#TEMPLATES=templates
#PUBLICSHARE=public
DOCUMENTS=docs
MUSIC=music
PICTURES=pics
VIDEOS=vids
# Another alternative is:
#MUSIC=Documents/Music
#PICTURES=Documents/Pictures
#VIDEOS=Documents/Videos
$ xdg-user-dirs-update --force
$ cd; rm -rf Desktop Downloads Templates Public Documents Music Pictures Videos
Then edit Each of those links in Dolphin manually to point to the new folder.
I asked 3 questions above, I’m really only concerned about one question:
I’d like to know which programs use TEMPLATES and PUBLICSHARE. There’s got to be something that uses TEMPLATES in KDE.
