So, afaik, Manjaro has its mirror, which delays Pacman packages by a week or two. Is it possible to switch to the bleeding edge, non-delayed ones?
Yes
Nope! Mirrors don’t do that. What you are talking about is called a Branch (Mirror is different). By default branch is set to Stable. You can switch to Testing and Unstable by:
sudo pacman-mirrors --api --set-branch {branch}
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
Note - Bleeding edge software comes with it’s own pros and cons (i prefer testing btw). Also please do your research before creating a topic:
The closest thing will be to switch to unstable - which is the entry point for all packages.
Not all packages are snapped from Arch repo. Several arch specific packages is not available.
Unstable is also entry point for all packages built specifically for Manjaro including
- kernel
- modules
- proprietary graphics
- Manjaro specific applications
It is usually a very stable experience - occationally packages break and such breakage is usually fixed within a very short timespan.
Thanks, that is exactly what I was looking for! Sorry for posting this. I didn’t know how to phrase it correctly, so google would help me!
Some explanations and more:
