Maybe this ist Just for my own clarification, meaning, maybe I completely misunderstood the while “NAS Thing”.
My use Case:
I want to use my (Synology) NAS as a centralized storage, meaning, keep my Data (music, Docs, Pics) Off my devices and store it on the NAS.
When I want to edit a document, for example, I do explicitly not want to download the file, edit it locally and upload it back, I want to open it from the NAS, as if this file would be in an external USB Drive (this also how I want to Access my NAS, from Nautilus, or any other App, If needed)
For Data Backup the NAS ist configured with RAID1 internally.
Ist this possible? And If so, how?
I am trying to get to this for two days now with my DS218 w/o any success.
The synology packages for my NAS only enable me to create either sync or Backup Tasks and schedules, which miss my use case as I want to keep the data off my devices in the first place.
I would say configure the NAS and automount it …
Then create symlinks in your respective directories to folders on the NAS.
(rather than actually mapping ~/Pictures itself to the remote location)
Then you should be editing ‘those’ files instead of downloading them or similar.
And it should be pretty simple while not interfering with the normal way the system works.
better, the mounts now appear directly after booting in Nautilus (in the left, overview, exactly like I wanted it!), but they do not work, only after I execute the sudo mount command as well.
I guess you could increase the timeo and retrans variables a bit.
There is also option retry such as retry=3
This is all because I assume it is some sort of race-condition, despite the _netdev option.
(the line looks ok to me, and seems to sorta work or be recognized)
Which is also to say that there is also always the systemd route.
