The Archwiki states that /efi
shall be used instead of /boot/efi
(/boot
if using EFISTUB but doesn’t apply to Manjaro) EFI system partition - ArchWiki gpt-generator, bootctl, nspawn: EFI mount point handling updates by poettering · Pull Request #3757 · systemd/systemd · GitHub
Well, Manjaro uses grub
and not systemd-boot
by default and it works fine with grub. If you really need it, run the grub-install
command with these parameters: --boot-directory=/boot
and --efi-directory=/efi
and you are done. Yes, you also have to change /etc/fstab
I personally don`t see any real benefit in changing the default behavior
Well, there probably isn’t much or any benefit but just to align more to the “upstream” Arch standards.
And BTW, --boot-directory is /boot by default.
I don’t think it says that at all. It lists typical mountpoints and there is a tip stating that /efi
replaces /boot/efi
with a link to a github comment that is specific to systemd-boot.
The Arch wiki is a great resource but it is a community maintained wiki, not a gospel of Arch standards. Arch is rarely prescriptive in that manner. I don’t think that mounting the ESP to /efi
would make Manjaro more aligned with Arch.
Using /boot/efi
when using grub is the most common approach. While it certainly could be moved to /efi
, I am not sure I understand the point in making that change.
