I’m not sure what’s going on. The microphone worked fine a while ago, and then it just stopped working. I don’t remember if I did anything or if it was due to upgrade of a system component.
I have Manjaro running on my laptop and there the webcam microphone works fine.
IMO everything looks fine, there’s no reason for it to show up, but not produce any sound. I’m not sure how to continue debugging this, any help would be appreciated. Here are some potentially useful command outputs:
sudo dmesg | grep "snd\|usb"
[ 2818.446382] usb 3-1.1: USB disconnect, device number 11
[ 2818.446631] usb 3-1.1: cannot submit urb (err = -19)
[ 2818.452387] usb 3-1.1: cannot submit urb 0, error -19: no device
[ 2925.957929] usb 1-3: new high-speed USB device number 6 using xhci_hcd
[ 2928.571881] usb 1-3: New USB device found, idVendor=046d, idProduct=085c, bcdDevice= 0.16
[ 2928.571886] usb 1-3: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 2928.571887] usb 1-3: Product: C922 Pro Stream Webcam
[ 2928.571888] usb 1-3: SerialNumber: *****
[ 2928.579922] usb 1-3: Found UVC 1.00 device C922 Pro Stream Webcam (046d:085c)
[ 2928.639023] input: C922 Pro Stream Webcam as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-3/1-3:1.0/input/input41
[ 2950.259577] usb 1-3: USB disconnect, device number 6
[ 2950.260251] usb 1-3: cannot submit urb (err = -19)
[ 2950.261691] usb 1-3: cannot submit urb 0, error -19: no device
[ 2977.883160] usb 3-1.1: new high-speed USB device number 12 using xhci_hcd
[ 2980.362071] usb 3-1.1: New USB device found, idVendor=046d, idProduct=085c, bcdDevice= 0.16
[ 2980.362075] usb 3-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 2980.362076] usb 3-1.1: Product: C922 Pro Stream Webcam
[ 2980.362077] usb 3-1.1: SerialNumber: ******
[ 2980.396858] usb 3-1.1: Found UVC 1.00 device C922 Pro Stream Webcam (046d:085c)
[ 2980.403838] input: C922 Pro Stream Webcam as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb3/3-1/3-1.1/3-1.1:1.0/input/input42
arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: Generic [HD-Audio Generic], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: Generic [HD-Audio Generic], device 2: ALC1220 Alt Analog [ALC1220 Alt Analog]
Subdevices: 1/1
card 2: Webcam [C922 Pro Stream Webcam], device 0: USB Audio [USB Audio]
Subdevices: 1/1
pactl list sources
Source #45
State: SUSPENDED
Description: Monitor of GP104 High Definition Audio Controller Digital Stereo (HDMI)
Driver: PipeWire
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: yes
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor of Sink: alsa_output.pci-0000_06_00.1.hdmi-stereo
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:0:hdmi:0:playback"
api.alsa.path = "hdmi:0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
device.routes = "1"
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "monitor"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "HDMI 0"
alsa.id = "HDMI 0"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "3"
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xfc080000 irq 95"
device.profile.name = "hdmi-stereo"
device.profile.description = "Digital Stereo (HDMI)"
card.profile.device = "7"
device.id = "41"
factory.name = "api.alsa.pcm.sink"
priority.driver = "696"
priority.session = "696"
media.class = "Audio/Sink"
node.nick = "HDA NVidia"
node.name = "alsa_output.pci-0000_06_00.1.hdmi-stereo"
device.description = "GP104 High Definition Audio Controller Digital Stereo (HDMI)"
device.icon_name = "audio-card-hdmi"
device.bus = "pci"
device.bus_path = "pci-0000:06:00.1"
node.pause-on-idle = "false"
factory.id = "18"
client.id = "33"
clock.quantum-limit = "8192"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "47"
object.serial = "45"
node.max-latency = "16384/48000"
Formats:
pcm
Source #47
State: IDLE
Name: alsa_output.usb-iFi__by_AMR__iFi__by_AMR__HD_USB_Audio_0003-00.analog-stereo.monitor
Description: Monitor of iFi (by AMR) HD USB Audio Analog Stereo
Driver: PipeWire
Sample Specification: s32le 2ch 384000Hz
Mute: yes
balance 0.00
Monitor of Sink: alsa_output.usb-iFi__by_AMR__iFi__by_AMR__HD_USB_Audio_0003-00.analog-stereo
Properties:
object.path = "alsa:pcm:3:front:3:playback"
api.alsa.path = "front:3"
api.alsa.pcm.card = "3"
device.routes = "1"
device.api = "alsa"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.device = "0"
alsa.card = "3"
alsa.card_name = "iFi (by AMR) HD USB Audio"
alsa.long_card_name = "iFi (by AMR) iFi (by AMR) HD USB Audio at usb-0000:08:00.3-1.2, high speed"
alsa.driver_name = "snd_usb_audio"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
card.profile.device = "1"
device.id = "43"
priority.driver = "817"
priority.session = "817"
node.nick = "iFi (by AMR) HD USB Audio"
node.name = "alsa_output.usb-iFi__by_AMR__iFi__by_AMR__HD_USB_Audio_0003-00.analog-stereo"
device.description = "iFi (by AMR) HD USB Audio Analog Stereo"
device.icon_name = "audio-card-analog"
device.bus = "usb"
device.bus_path = "pci-0000:08:00.3-usb-0:1.2:1.0"
audio.format = "S32LE"
audio.rate = "384000"
factory.id = "18"
client.id = "33"
object.id = "49"
object.serial = "47"
node.max-latency = "65536/384000"
Formats:
pcm
Source #367
State: SUSPENDED
Description: C922 Pro Stream Webcam Analog Stereo
Driver: PipeWire
Sample Specification: s16le 2ch 32000Hz
Mute: yes
Volume: front-left: 65534 / 100% / -0.00 dB, front-right: 65534 / 100% / -0.00 dB
balance 0.00
Base Volume: 9619 / 15% / -50.00 dB
Monitor of Sink: n/a
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:2:front:2:capture"
api.alsa.path = "front:2"
api.alsa.pcm.card = "2"
api.alsa.pcm.stream = "capture"
device.routes = "1"
device.api = "alsa"
device.class = "sound"
alsa.device = "0"
alsa.card = "2"
alsa.card_name = "C922 Pro Stream Webcam"
alsa.long_card_name = "C922 Pro Stream Webcam at usb-0000:08:00.3-1.1, high speed"
card.profile.device = "0"
device.id = "45"
factory.name = "api.alsa.pcm.source"
priority.driver = "1881"
priority.session = "1881"
media.class = "Audio/Source"
node.nick = "C922 Pro Stream Webcam"
node.name = "alsa_input.usb-046d_C922_Pro_Stream_Webcam_3FEA4E2F-02.analog-stereo"
device.description = "C922 Pro Stream Webcam Analog Stereo"
device.icon_name = "audio-input-microphone-analog"
device.bus = "usb"
device.bus_path = "pci-0000:08:00.3-usb-0:1.1:1.2"
device.form_factor = "webcam"
factory.id = "18"
client.id = "33"
factory.mode = "split"
object.id = "56"
object.serial = "367"
node.max-latency = "131072/32000"
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, availability unknown)
Active Port: analog-input-mic
Formats:
pcm
Source #624
State: SUSPENDED
Description: Monitor of Starship/Matisse HD Audio Controller Analog Stereo
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Mute: yes
balance 0.00
Monitor of Sink: alsa_output.pci-0000_08_00.4.analog-stereo
Properties:
object.path = "alsa:pcm:1:front:1:playback"
api.alsa.path = "front:1"
api.alsa.pcm.card = "1"
device.routes = "2"
device.api = "alsa"
alsa.name = "ALC1220 Analog"
alsa.id = "ALC1220 Analog"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfc400000 irq 97"
card.profile.device = "5"
device.id = "44"
priority.driver = "945"
priority.session = "945"
node.nick = "HD-Audio Generic"
node.name = "alsa_output.pci-0000_08_00.4.analog-stereo"
device.description = "Starship/Matisse HD Audio Controller Analog Stereo"
device.bus = "pci"
device.bus_path = "pci-0000:08:00.4"
factory.id = "18"
client.id = "33"
object.id = "61"
object.serial = "624"
Formats:
pcm
Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=acb5c2ba-2f7c-4305-b8be-6a3cac221c3c rw quiet splash
udev.log_priority=3 resume=UUID=0a84ab5a-add6-405a-b848-0770a61904bc
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop System: Gigabyte product: B550 AORUS PRO V2 v: N/A serial: N/A
Mobo: Gigabyte model: B550 AORUS PRO V2 v: x.x serial: N/A
UEFI: American Megatrends LLC. v: F13g date: 03/25/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
status: Discharging
RAM: total: 31.35 GiB used: 8.24 GiB (26.3%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: No Module Installed
Device-2: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: G.Skill part-no: F4-3600C17-16GTZKW
serial: N/A
Device-3: DIMM 0 size: No Module Installed
Device-4: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
serial: N/A
Info: model: AMD Ryzen 9 5900X socket: AM4 bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2475 high: 3700 min/max: 2200/4950 boost: enabled
base/boost: 3700/4950 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2800 12: 2200
13: 2200 14: 3700 15: 2200 16: 2200 17: 3700 18: 2200 19: 2200 20: 2200
21: 2200 22: 3700 23: 2200 24: 2200 bogomips: 177316
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 06:00.0
chip-ID: 10de:1b82 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.1:12 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 7840x2560 s-dpi: 96 s-size: 2074x677mm (81.7x26.7")
s-diag: 2182mm (85.9")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 52
size: 1872x1053mm (73.7x41.5") diag: 2148mm (84.6")
Monitor-2: DP-0 res: 1440x2560 hz: 60
Monitor-3: DP-4 res: 2560x1440 dpi: 65024 size: 1x1mm (0.0x0.0")
diag: 1mm (0.1")
OpenGL: renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: XMOS iFi (by AMR) HD USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.2:10 chip-ID: 20b1:3008
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.45 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-1.4.4:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp8s0f3u1u4u4 state: down mac: <filter>
IF-ID-1: br-1c458e6e5417 state: down mac: <filter>
IF-ID-2: br-491da69cf0bc state: down mac: <filter>
IF-ID-3: br-7f59711dfc34 state: down mac: <filter>
IF-ID-4: br-9b1e440f16e2 state: down mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
IF-ID-6: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
driver: btusb v: 0.8 bus-ID: 3-1.4.2:7 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.79 TiB used: 310.01 GiB (10.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 42B9T6TB temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: A-Data model: SX8200PNP
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 32B3T8EA temp: 31.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 47.13 GiB (48.2%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:4 label: N/A
uuid: acb5c2ba-2f7c-4305-b8be-6a3cac221c3c
ID-2: /boot raw-size: 250 MiB size: 236.1 MiB (94.44%)
used: 110.9 MiB (47.0%) fs: ext4 block-size: 1024 B dev: /dev/nvme0n1p1
maj-min: 259:2 label: N/A uuid: aa33bcfa-a60e-451a-aea1-de24032645ee
ID-3: /boot/efi raw-size: 250 MiB size: 246.1 MiB (98.46%)
used: 274 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
maj-min: 259:3 label: N/A uuid: 3F6A-4E8C
ID-4: /home raw-size: 1.73 TiB size: 1.71 TiB (98.37%)
used: 262.77 GiB (15.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:5 label: N/A uuid: b8ff9dae-a914-4f31-8a30-879d2ff3d93e
ID-5: /mnt/foxtrot raw-size: N/A size: 7.14 TiB used: 4.18 TiB (58.4%)
fs: cifs dev: /dev/foxtrot
Kernel: swappiness: 5 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 32 GiB used: 1.2 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:6 label: N/A
uuid: 0a84ab5a-add6-405a-b848-0770a61904bc
ID-1: /dev/nvme1n1p1 maj-min: 259:7 size: 100 MiB fs: vfat label: N/A
uuid: 08BF-8DFA
ID-2: /dev/nvme1n1p2 maj-min: 259:8 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:9 size: 953.26 GiB fs: ntfs label: N/A
uuid: AAC0C56EC0C540F5
ID-4: /dev/nvme1n1p4 maj-min: 259:10 size: 505 MiB fs: ntfs label: N/A
uuid: A678D84C78D81D3D
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6.4:4 info: Drop Preonic type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 03a8:a649 class-ID: 0300
Device-2: 1-7:3 info: Integrated Express ITE Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:5702 class-ID: 0300
Hub-3: 1-10:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 3-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 3-1.1:12 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-2: 3-1.2:10 info: XMOS iFi (by AMR) HD USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 20b1:3008 class-ID: 0300 serial: <filter>
Device-3: 3-1.3:5 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-7: 3-1.4:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-1.4.2:7
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 4-1:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-10: 4-1.4:3 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 4-1.4.4:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 256mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): cpu: 541 fan-2: 0 fan-3: 490 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 1.70 vbat: 1.62
Processes: 493 Uptime: 1h 27m wakeups: 2 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1579
pacman: 1540 lib: 405 flatpak: 39 Shell: Zsh (sudo) v: 5.8 default: Bash
v: 5.1.16 running-in: tmux: inxi: 3.3.12
