5.10.23-1-MANJARO; inxi
it happened a few days ago, that the USB HDDs filesystem was not cleanly dismounted and USB device descriptor read/8, error -110 appeared: “$ errno 110” shows “Connection timed out”.
The USB based ethernet adapter device was also gone (unavailable to OS) and reconnecting USB not helped. After reset the computer, all is fine. So i am wondering what can be done about this?
Found this in dmesg
in short:
INFO: task zeitgeist-datah:2468 blocked for more than 122 seconds.
Tainted: P W OE 5.10.23-1-MANJARO #1
task:zeitgeist-datah state:D stack: 0 pid: 2468 ppid: 2206 flags:0x00000080
Call Trace:
