I have a 32gb usb stick formatted in ntfs. CHKDSK finds no errors. NTFS-3G is installed. Another external drive external hdd drive mounts normally. But this usb stick is not detected in the system in any way.
hostnamectl
Static hostname: vadim-bmax
Icon name: computer-convertible
Chassis: convertible
Machine ID: f774c5bbc9dc40bea2022da28331b6cc
Boot ID: df4d99531d8d4142ad13f7ec7c335679
Kernel: Linux 6.1.80-1-MANJARO
Architecture: x86-64
Hardware Vendor: AMI
Hardware Model: INTEL
Firmware Version: 3.5_2105046
Firmware Date: Thu 2022-03-03
Firmware Age: 2y 1w
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 238,5G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
└─sda3 8:3 0 238G 0 part /
lshw
vadim-bmax
description: Computer
width: 64 bits
capabilities: smp vsyscall32
*-core
description: Motherboard
physical id: 0
*-memory
description: System memory
physical id: 0
*-cpu
product: Intel(R) Celeron(R) N5100 @ 1.10GHz
vendor: Intel Corp.
physical id: 1
bus info: cpu@0
version: 6.156.0
capacity: 2800MHz
width: 64 bits
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm 3dnowprefetch cpuid_fault epb cat_l2 cdp_l2 ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust smep erms rdt_a rdseed smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req umip waitpkg gfni rdpid movdiri movdir64b md_clear flush_l1d arch_capabilities cpufreq
configuration: microcode=603979812
*-pci
description: Host bridge
product: Intel Corporation
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 33MHz
*-display
description: VGA compatible controller
product: JasperLake [UHD Graphics]
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 01
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 resolution=1920,1080
resources: iomemory:600-5ff iomemory:400-3ff irq:130 memory:6000000000-6000ffffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff
*-generic:0
description: Signal processing controller
product: Dynamic Tuning service
physical id: 4
bus info: pci@0000:00:04.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: cap_list
configuration: driver=proc_thermal latency=0
resources: iomemory:600-5ff irq:16 memory:6001110000-600111ffff
*-generic:1 UNCLAIMED
description: System peripheral
physical id: 8
bus info: pci@0000:00:08.0
version: 00
width: 64 bits
clock: 33MHz
configuration: latency=0
resources: iomemory:600-5ff memory:6001131000-6001131fff
*-usb
description: USB controller
product: Jasper Lake USB 3.1 xHCI Host Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: xhci cap_list
configuration: driver=xhci_hcd latency=0
resources: iomemory:600-5ff irq:124 memory:6001100000-600110ffff
*-memory UNCLAIMED
description: RAM memory
product: Jasper Lake Shared SRAM
physical id: 14.2
bus info: pci@0000:00:14.2
version: 01
width: 64 bits
clock: 33MHz (30.3ns)
resources: iomemory:600-5ff iomemory:600-5ff memory:6001124000-6001125fff memory:6001130000-6001130fff
*-generic:2
description: MMC Host
product: Jasper Lake SD Controller
physical id: 14.5
bus info: pci@0000:00:14.5
logical name: mmc0
version: 01
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list
configuration: driver=sdhci-pci latency=0
resources: iomemory:600-5ff irq:19 memory:600112f000-600112ffff
*-serial:0
description: Serial bus controller
product: Jasper Lake Serial IO I2C Host Controller #0
physical id: 15
bus info: pci@0000:00:15.0
version: 01
width: 64 bits
clock: 33MHz
configuration: driver=intel-lpss latency=0
resources: irq:16 memory:4010000000-4010000fff
*-serial:1
product: Jasper Lake Serial IO I2C Host Controller #1
physical id: 15.1
bus info: pci@0000:00:15.1
version: 01
width: 64 bits
clock: 33MHz
resources: irq:17 memory:4010001000-4010001fff
*-serial:2
product: Jasper Lake Serial IO I2C Host Controller #2
physical id: 15.2
bus info: pci@0000:00:15.2
version: 01
width: 64 bits
clock: 33MHz
resources: iomemory:400-3ff irq:18 memory:4010002000-4010002fff
*-serial:3
product: Jasper Lake Serial IO I2C Host Controller #3
physical id: 15.3
bus info: pci@0000:00:15.3
version: 01
width: 64 bits
clock: 33MHz
resources: irq:19 memory:4010003000-4010003fff
*-communication:0
description: Communication controller
product: Management Engine Interface
physical id: 16
bus info: pci@0000:00:16.0
version: 01
width: 64 bits
clock: 33MHz
configuration: driver=mei_me latency=0
resources: iomemory:600-5ff irq:126 memory:600112a000-600112afff
*-sata
description: SATA controller
product: Jasper Lake SATA AHCI Controller
physical id: 17
bus info: pci@0000:00:17.0
version: 01
width: 32 bits
clock: 66MHz
capabilities: sata ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:123 memory:7fd00000-7fd01fff memory:7fd03000-7fd030ff ioport:4090(size=8) ioport:4080(size=4) ioport:4060(size=32) memory:7fd02000-7fd027ff
*-serial:4
product: Jasper Lake Serial IO I2C Host Controller #4
physical id: 19
bus info: pci@0000:00:19.0
version: 01
width: 64 bits
clock: 33MHz
resources: irq:32 memory:4010004000-4010004fff
*-pci
description: PCI bridge
product: Jasper Lake PCIe Root Port #2
physical id: 1c
bus info: pci@0000:00:1c.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pci normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:122 ioport:3000(size=4096) memory:7fc00000-7fcfffff
*-network
description: Wireless interface
product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0
version: 00
serial: 2c:d2:6b:98:2a:70
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtw_8821ce driverversion=6.1.80-1-MANJARO firmware=N/A ip=192.168.0.114 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:131 ioport:3000(size=256) memory:7fc00000-7fc0ffff
*-communication:1
product: Jasper Lake Serial IO UART Controller #0
physical id: 1e
bus info: pci@0000:00:1e.0
version: 01
width: 64 bits
clock: 33MHz
resources: irq:20 memory:4010005000-4010005fff
*-serial:5
product: Jasper Lake Serial IO SPI Controller #1
physical id: 1e.3
bus info: pci@0000:00:1e.3
version: 01
width: 64 bits
clock: 33MHz
resources: irq:23 memory:4010006000-4010006fff
*-isa
description: ISA bridge
product: Jasper Lake eSPI Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
*-pnp00:00
product: Motherboard registers
physical id: 0
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device INT3f0d
vendor: Interphase Corporation
physical id: 1
capabilities: pnp
*-pnp00:02
physical id: 2
capabilities: pnp
*-pnp00:03
product: IBM Enhanced keyboard controller (101/2-key)
physical id: 3
capabilities: pnp
configuration: driver=i8042 kbd
*-pnp00:04
physical id: 4
capabilities: pnp
*-pnp00:05
physical id: 5
capabilities: pnp
*-pnp00:06
physical id: 6
capabilities: pnp
*-multimedia
description: Multimedia audio controller
product: Jasper Lake HD Audio
physical id: 1f.3
bus info: pci@0000:00:1f.3
logical name: card0
logical name: /dev/snd/controlC0
logical name: /dev/snd/hwC0D2
logical name: /dev/snd/pcmC0D0c
logical name: /dev/snd/pcmC0D0p
logical name: /dev/snd/pcmC0D5p
logical name: /dev/snd/pcmC0D6p
logical name: /dev/snd/pcmC0D7p
version: 01
width: 64 bits
clock: 33MHz
configuration: driver=sof-audio-pci-intel-icl latency=32
resources: iomemory:600-5ff iomemory:600-5ff irq:132 memory:6001120000-6001123fff memory:6001000000-60010fffff
*-serial:6
description: SMBus
product: Jasper Lake SMBus
physical id: 1f.4
bus info: pci@0000:00:1f.4
version: 01
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: iomemory:600-5ff irq:16 memory:6001126000-60011260ff ioport:efa0(size=32)
*-serial:7
product: Jasper Lake SPI Controller
physical id: 1f.5
bus info: pci@0000:00:1f.5
version: 01
width: 32 bits
clock: 33MHz
configuration: driver=intel-spi latency=0
resources: irq:0 memory:7fd04000-7fd04fff
*-input:0
product: Lid Switch
physical id: 1
logical name: input0
logical name: /dev/input/event0
capabilities: platform
*-input:1
product: Power Button
physical id: 2
logical name: input1
logical name: /dev/input/event1
*-input:2
product: SHUNCCM2MP: SHUNCCM2MP
physical id: 3
logical name: input12
logical name: /dev/input/event11
capabilities: usb
*-input:3
product: SYNA3602:00 0911:5288 Mouse
physical id: 4
logical name: input13
logical name: /dev/input/event9
logical name: /dev/input/mouse1
capabilities: i2c
*-input:4
product: SYNA3602:00 0911:5288 Touchpad
physical id: 5
logical name: input14
logical name: /dev/input/event10
logical name: /dev/input/mouse2
capabilities: i2c
*-input:5
product: Video Bus
physical id: 6
logical name: input15
logical name: /dev/input/event12
*-input:6
product: sof-essx8336 Headset
physical id: 7
logical name: input16
logical name: /dev/input/event13
*-input:7
product: sof-essx8336 HDMI/DP,pcm=5
physical id: 8
logical name: input17
logical name: /dev/input/event14
*-input:8
product: sof-essx8336 HDMI/DP,pcm=6
physical id: 9
logical name: input18
logical name: /dev/input/event15
*-input:9
product: sof-essx8336 HDMI/DP,pcm=7
physical id: a
logical name: input19
logical name: /dev/input/event16
*-input:10
product: Sleep Button
physical id: b
logical name: input2
logical name: /dev/input/event2
*-input:11
physical id: c
logical name: input3
logical name: /dev/input/event3
*-input:12
product: AT Translated Set 2 keyboard
physical id: d
logical name: input4
logical name: /dev/input/event4
logical name: input4::capslock
logical name: input4::numlock
logical name: input4::scrolllock
capabilities: i8042
*-input:13
product: Intel HID events
physical id: e
logical name: input5
logical name: /dev/input/event5
*-input:14
product: Intel HID 5 button array
physical id: f
logical name: input6
logical name: /dev/input/event6
*-input:15
product: PC Speaker
physical id: 10
logical name: input7
logical name: /dev/input/event7
capabilities: isa
*-input:16
product: Goodix Capacitive TouchScreen
physical id: 11
logical name: input8
logical name: /dev/input/event8
logical name: /dev/input/mouse0
capabilities: i2c
lsblk --fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1
│ vfat FAT32 1836-57EF 506,3M 1% /boot/efi
└─sda3
ext4 1.0 1e4427c1-713c-4ee9-8293-e5a64b19f01e 197,9G 10% /
lsusb
Bus 001 Device 002: ID 058f:5608 Alcor Micro Corp. SHUNCCM2MP
Bus 001 Device 003: ID 0bda:c821 Realtek Semiconductor Corp. Bluetooth Radio
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
dmesg -Hw
[мар 9 15:11] microcode: microcode updated early to revision 0x24000024, date = 2022-09-02
[ +0,000000] Linux version 6.1.80-1-MANJARO (builduser@fv-az1431-120) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Fri Mar 1 18:09:53 UTC 2024
[ +0,000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=1e4427c1-713c-4ee9-8293-e5a64b19f01e rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ +0,000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ +0,000000] BIOS-provided physical RAM map:
[ +0,000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ +0,000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ +0,000000] BIOS-e820: [mem 0x0000000000100000-0x0000000071fb5fff] usable
[ +0,000000] BIOS-e820: [mem 0x0000000071fb6000-0x00000000744b5fff] reserved
[ +0,000000] BIOS-e820: [mem 0x00000000744b6000-0x0000000074735fff] ACPI data
[ +0,000000] BIOS-e820: [mem 0x0000000074736000-0x0000000074835fff] ACPI NVS
[ +0,000000] BIOS-e820: [mem 0x0000000074836000-0x0000000074dfefff] reserved
[ +0,000000] BIOS-e820: [mem 0x0000000074dff000-0x0000000074efefff] type 20
[ +0,000000] BIOS-e820: [mem 0x0000000074eff000-0x0000000074efffff] usable
[ +0,000000] BIOS-e820: [mem 0x0000000074f00000-0x000000007fbfffff] reserved
[ +0,000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ +0,000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ +0,000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ +0,000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ +0,000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ +0,000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ +0,000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ +0,000000] BIOS-e820: [mem 0x0000000100000000-0x00000002803fffff] usable
[ +0,000000] NX (Execute Disable) protection: active
[ +0,000000] efi: EFI v2.70 by American Megatrends
[ +0,000000] efi: ACPI=0x74735000 ACPI 2.0=0x74735014 TPMFinalLog=0x747e3000 SMBIOS=0x74c78000 SMBIOS 3.0=0x74c77000 MEMATTR=0x6f4b5018 ESRT=0x71043e98
[ +0,000000] SMBIOS 3.3.0 present.
[ +0,000000] DMI: AMI INTEL/INTEL, BIOS 3.5_2105046 03/03/2022
[ +0,000000] tsc: Detected 1100.000 MHz processor
[ +0,000000] tsc: Detected 1113.600 MHz TSC
[ +0,000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ +0,000003] e820: remove [mem 0x000a0000-0x000fffff] usable
[ +0,000008] last_pfn = 0x280400 max_arch_pfn = 0x400000000
[ +0,000069] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ +0,000236] last_pfn = 0x74f00 max_arch_pfn = 0x400000000
[ +0,008820] esrt: Reserving ESRT space from 0x0000000071043e98 to 0x0000000071043ed0.
[ +0,000006] e820: update [mem 0x71043000-0x71043fff] usable ==> reserved
[ +0,000346] Secure boot disabled
[ +0,000001] RAMDISK: [mem 0x35297000-0x36942fff]
[ +0,000005] ACPI: Early table checksum verification disabled
[ +0,000004] ACPI: RSDP 0x0000000074735014 000024 (v02 ALASKA)
[ +0,000005] ACPI: XSDT 0x0000000074734728 0000FC (v01 ALASKA A M I 01072009 AMI 01000013)
[ +0,000007] ACPI: FACP 0x000000007472C000 000114 (v06 ALASKA A M I 01072009 AMI 01000013)
[ +0,000005] ACPI: DSDT 0x00000000746E6000 045EE0 (v02 ALASKA A M I 01072009 INTL 20191018)
[ +0,000004] ACPI: FACS 0x0000000074834000 000040
[ +0,000003] ACPI: MCFG 0x0000000074733000 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ +0,000003] ACPI: SSDT 0x000000007472D000 00592A (v02 DptfTb DptfTabl 00001000 INTL 20191018)
[ +0,000003] ACPI: FIDT 0x00000000746E5000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ +0,000003] ACPI: MSDM 0x00000000746E4000 000055 (v03 ALASKA A M I 01072009 AMI 01000013)
[ +0,000002] ACPI: SSDT 0x00000000746E1000 0025EE (v02 CpuRef CpuSsdt 00003000 INTL 20191018)
[ +0,000003] ACPI: SSDT 0x00000000746DF000 001CCD (v02 SaSsdt SaSsdt 00003000 INTL 20191018)
[ +0,000003] ACPI: SSDT 0x00000000746DB000 0032CD (v02 INTEL IgfxSsdt 00003000 INTL 20191018)
[ +0,000003] ACPI: HPET 0x00000000746DA000 000038 (v01 ALASKA A M I 01072009 AMI 01000013)
[ +0,000003] ACPI: APIC 0x00000000746D9000 00012C (v05 ALASKA A M I 01072009 AMI 01000013)
[ +0,000003] ACPI: PRAM 0x00000000746D8000 000030 (v01 ALASKA A M I 01072009 AMI 01000013)
[ +0,000003] ACPI: SSDT 0x00000000746D5000 002EEF (v02 ALASKA Jsl_Rev2 00001000 INTL 20191018)
[ +0,000002] ACPI: SSDT 0x00000000746D4000 000E06 (v02 ALASKA Ther_Rvp 00001000 INTL 20191018)
[ +0,000003] ACPI: SSDT 0x00000000746D0000 00300A (v02 INTEL xh_jslv2 00000000 INTL 20191018)
[ +0,000003] ACPI: NHLT 0x00000000746CF000 0001FB (v00 ALASKA A M I 01072009 AMI 01000013)
[ +0,000003] ACPI: LPIT 0x00000000746CE000 000094 (v01 ALASKA A M I 01072009 AMI 01000013)
[ +0,000003] ACPI: SSDT 0x00000000746CA000 002720 (v02 ALASKA PtidDevc 00001000 INTL 20191018)
[ +0,000002] ACPI: SSDT 0x00000000746C9000 000122 (v02 ALASKA TbtTypeC 00000000 INTL 20191018)
[ +0,000003] ACPI: DBGP 0x00000000746C8000 000034 (v01 ALASKA A M I 01072009 AMI 01000013)
[ +0,000003] ACPI: DBG2 0x00000000746C7000 000054 (v00 ALASKA A M I 01072009 AMI 01000013)
[ +0,000003] ACPI: SSDT 0x00000000746C5000 00118A (v02 ALASKA UsbCTabl 00001000 INTL 20191018)
[ +0,000003] ACPI: DMAR 0x00000000746C4000 000088 (v02 INTEL EDK2 00000002 01000013)
[ +0,000002] ACPI: SSDT 0x00000000746C3000 000144 (v02 Intel ADebTabl 00001000 INTL 20191018)
[ +0,000003] ACPI: BGRT 0x00000000746C2000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ +0,000003] ACPI: TPM2 0x00000000746C1000 00004C (v04 ALASKA A M I 00000001 AMI 00000000)
[ +0,000003] ACPI: WSMT 0x00000000746CD000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ +0,000003] ACPI: FPDT 0x00000000746C0000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ +0,000002] ACPI: Reserving FACP table memory at [mem 0x7472c000-0x7472c113]
[ +0,000001] ACPI: Reserving DSDT table memory at [mem 0x746e6000-0x7472bedf]
[ +0,000001] ACPI: Reserving FACS table memory at [mem 0x74834000-0x7483403f]
[ +0,000001] ACPI: Reserving MCFG table memory at [mem 0x74733000-0x7473303b]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x7472d000-0x74732929]
[ +0,000001] ACPI: Reserving FIDT table memory at [mem 0x746e5000-0x746e509b]
[ +0,000001] ACPI: Reserving MSDM table memory at [mem 0x746e4000-0x746e4054]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x746e1000-0x746e35ed]
[ +0,000000] ACPI: Reserving SSDT table memory at [mem 0x746df000-0x746e0ccc]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x746db000-0x746de2cc]
[ +0,000001] ACPI: Reserving HPET table memory at [mem 0x746da000-0x746da037]
[ +0,000001] ACPI: Reserving APIC table memory at [mem 0x746d9000-0x746d912b]
[ +0,000001] ACPI: Reserving PRAM table memory at [mem 0x746d8000-0x746d802f]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x746d5000-0x746d7eee]
[ +0,000000] ACPI: Reserving SSDT table memory at [mem 0x746d4000-0x746d4e05]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x746d0000-0x746d3009]
[ +0,000001] ACPI: Reserving NHLT table memory at [mem 0x746cf000-0x746cf1fa]
[ +0,000001] ACPI: Reserving LPIT table memory at [mem 0x746ce000-0x746ce093]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x746ca000-0x746cc71f]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x746c9000-0x746c9121]
[ +0,000001] ACPI: Reserving DBGP table memory at [mem 0x746c8000-0x746c8033]
[ +0,000000] ACPI: Reserving DBG2 table memory at [mem 0x746c7000-0x746c7053]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x746c5000-0x746c6189]
[ +0,000001] ACPI: Reserving DMAR table memory at [mem 0x746c4000-0x746c4087]
[ +0,000001] ACPI: Reserving SSDT table memory at [mem 0x746c3000-0x746c3143]
[ +0,000001] ACPI: Reserving BGRT table memory at [mem 0x746c2000-0x746c2037]
[ +0,000001] ACPI: Reserving TPM2 table memory at [mem 0x746c1000-0x746c104b]
[ +0,000001] ACPI: Reserving WSMT table memory at [mem 0x746cd000-0x746cd027]
[ +0,000001] ACPI: Reserving FPDT table memory at [mem 0x746c0000-0x746c0043]
[ +0,000221] No NUMA configuration found
[ +0,000001] Faking a node at [mem 0x0000000000000000-0x00000002803fffff]
[ +0,000005] NODE_DATA(0) allocated [mem 0x2803f6000-0x2803fafff]
[ +0,000030] Zone ranges:
[ +0,000001] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ +0,000003] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ +0,000001] Normal [mem 0x0000000100000000-0x00000002803fffff]
[ +0,000002] Device empty
[ +0,000001] Movable zone start for each node
[ +0,000001] Early memory node ranges
[ +0,000000] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ +0,000002] node 0: [mem 0x0000000000100000-0x0000000071fb5fff]
[ +0,000001] node 0: [mem 0x0000000074eff000-0x0000000074efffff]
[ +0,000001] node 0: [mem 0x0000000100000000-0x00000002803fffff]
[ +0,000002] Initmem setup node 0 [mem 0x0000000000001000-0x00000002803fffff]
[ +0,000006] On node 0, zone DMA: 1 pages in unavailable ranges
[ +0,000027] On node 0, zone DMA: 97 pages in unavailable ranges
[ +0,004220] On node 0, zone DMA32: 12105 pages in unavailable ranges
[ +0,014539] On node 0, zone Normal: 12544 pages in unavailable ranges
[ +0,000347] On node 0, zone Normal: 31744 pages in unavailable ranges
[ +0,000020] Reserving Intel graphics memory at [mem 0x7c000000-0x7fbfffff]
[ +0,000353] ACPI: PM-Timer IO Port: 0x1808
[ +0,000009] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ +0,000002] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ +0,000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ +0,000000] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ +0,000000] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ +0,000000] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ +0,000001] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ +0,000034] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ +0,000003] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ +0,000003] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ +0,000004] ACPI: Using ACPI (MADT) for SMP configuration information
[ +0,000001] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ +0,000011] e820: update [mem 0x6d227000-0x6d815fff] usable ==> reserved
[ +0,000012] TSC deadline timer available
[ +0,000002] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ +0,000020] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ +0,000002] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ +0,000002] PM: hibernation: Registered nosave memory: [mem 0x6d227000-0x6d815fff]
[ +0,000002] PM: hibernation: Registered nosave memory: [mem 0x71043000-0x71043fff]
[ +0,000002] PM: hibernation: Registered nosave memory: [mem 0x71fb6000-0x744b5fff]
[ +0,000000] PM: hibernation: Registered nosave memory: [mem 0x744b6000-0x74735fff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0x74736000-0x74835fff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0x74836000-0x74dfefff]
[ +0,000000] PM: hibernation: Registered nosave memory: [mem 0x74dff000-0x74efefff]
[ +0,000002] PM: hibernation: Registered nosave memory: [mem 0x74f00000-0x7fbfffff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0x7fc00000-0xbfffffff]
[ +0,000000] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xcfffffff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xfdffffff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ +0,000000] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ +0,000000] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed1ffff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfedfffff]
[ +0,000000] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ +0,000001] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ +0,000000] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ +0,000002] [mem 0x7fc00000-0xbfffffff] available for PCI devices
[ +0,000002] Booting paravirtualized kernel on bare hardware
[ +0,000003] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ +0,006104] setup_percpu: NR_CPUS:320 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ +0,000383] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u524288
[ +0,000007] pcpu-alloc: s225280 r8192 d28672 u524288 alloc=1*2097152
[ +0,000003] pcpu-alloc: [0] 0 1 2 3
[ +0,000026] Fallback order for Node 0: 0
[ +0,000004] Built 1 zonelists, mobility grouping on. Total pages: 2008616
[ +0,000002] Policy zone: Normal
[ +0,000001] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=1e4427c1-713c-4ee9-8293-e5a64b19f01e rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ +0,000092] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64", will be passed to user space.
[ +0,000034] random: crng init done
[ +0,001158] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ +0,000610] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ +0,000333] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ +0,000013] software IO TLB: area num 4.
[ +0,045551] Memory: 7846968K/8162644K available (16392K kernel code, 2160K rwdata, 11620K rodata, 2164K init, 5280K bss, 315416K reserved, 0K cma-reserved)
[ +0,000129] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ +0,000032] ftrace: allocating 46766 entries in 183 pages
[ +0,006935] ftrace: allocated 183 pages with 6 groups
[ +0,000106] Dynamic Preempt: full
[ +0,000034] rcu: Preemptible hierarchical RCU implementation.
[ +0,000001] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ +0,000001] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ +0,000002] Trampoline variant of Tasks RCU enabled.
[ +0,000000] Rude variant of Tasks RCU enabled.
[ +0,000001] Tracing variant of Tasks RCU enabled.
[ +0,000001] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ +0,000001] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ +0,004461] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[ +0,000269] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ +0,000201] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ +0,000030] Console: colour dummy device 80x25
[ +0,000022] printk: console [tty0] enabled
[ +0,000022] ACPI: Core revision 20220331
[ +0,000409] hpet: HPET dysfunctional in PC10. Force disabled.
[ +0,000003] APIC: Switch to symmetric I/O mode setup
[ +0,000002] DMAR: Host address width 39
[ +0,000002] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ +0,000008] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 49e2ff0505e
[ +0,000003] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ +0,000005] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ +0,000003] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fbfffff
[ +0,000003] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ +0,000001] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ +0,000001] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ +0,001821] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ +0,000006] x2apic enabled
[ +0,000027] Switched APIC routing to cluster x2apic.
[ +0,004161] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x100d48ce7a0, max_idle_ns: 440795212195 ns
[ +0,000014] Calibrating delay loop (skipped), value calculated using timer frequency.. 2228.00 BogoMIPS (lpj=3712000)
[ +0,000036] CPU0: Thermal monitoring enabled (TM1)
[ +0,000003] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ +0,000044] process: using mwait in idle threads
[ +0,000003] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ +0,000001] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ +0,000004] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ +0,000002] Spectre V2 : Mitigation: Enhanced IBRS
[ +0,000001] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ +0,000002] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ +0,000002] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ +0,000004] MMIO Stale Data: Mitigation: Clear CPU buffers
[ +0,000001] SRBDS: Vulnerable: No microcode
[ +0,000005] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ +0,000001] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ +0,000002] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'compacted' format.
[ +0,003217] Freeing SMP alternatives memory: 40K
[ +0,000000] pid_max: default: 32768 minimum: 301
[ +0,000000] LSM: Security Framework initializing
[ +0,000000] landlock: Up and running.
[ +0,000000] Yama: becoming mindful.
[ +0,000000] LSM support for eBPF active
[ +0,000000] AppArmor: AppArmor initialized
[ +0,000000] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ +0,000000] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ +0,000000] smpboot: CPU0: Intel(R) Celeron(R) N5100 @ 1.10GHz (family: 0x6, model: 0x9c, stepping: 0x0)
[ +0,000000] cblist_init_generic: Setting adjustable number of callback queues.
[ +0,000000] cblist_init_generic: Setting shift to 2 and lim to 1.
[ +0,000000] Performance Events: PEBS fmt4+-baseline, PEBS-via-PT, AnyThread deprecated, Tremont events, 32-deep LBR, full-width counters, Intel PMU driver.
[ +0,000000] ... version: 5
[ +0,000000] ... bit width: 48
[ +0,000000] ... generic registers: 4
[ +0,000000] ... value mask: 0000ffffffffffff
[ +0,000000] ... max period: 00007fffffffffff
[ +0,000000] ... fixed-purpose events: 3
[ +0,000000] ... event mask: 000000070000000f
[ +0,000000] signal: max sigframe size: 1520
[ +0,000000] Estimated ratio of average max frequency by base frequency (times 1024): 2606
[ +0,000000] rcu: Hierarchical SRCU implementation.
[ +0,000000] rcu: Max phase no-delay instances is 1000.
[ +0,000000] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ +0,000000] smp: Bringing up secondary CPUs ...
[ +0,000000] x86: Booting SMP configuration:
[ +0,000000] .... node #0, CPUs: #1 #2 #3
[ +0,004979] smp: Brought up 1 node, 4 CPUs
[ +0,000000] smpboot: Max logical packages: 1
[ +0,000000] smpboot: Total of 4 processors activated (8912.00 BogoMIPS)
[ +0,000000] devtmpfs: initialized
[ +0,000000] x86/mm: Memory block size: 128MB
[ +0,000000] ACPI: PM: Registering ACPI NVS region [mem 0x74736000-0x74835fff] (1048576 bytes)
[ +0,000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ +0,000000] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ +0,001744] pinctrl core: initialized pinctrl subsystem
[ +0,000218] PM: RTC time: 12:00:00, date: 2024-03-09
[ +0,000610] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ +0,000240] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ +0,000142] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ +0,000152] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ +0,000038] audit: initializing netlink subsys (disabled)
[ +0,000079] audit: type=2000 audit(1709985600.009:1): state=initialized audit_enabled=0 res=1
[ +0,000108] thermal_sys: Registered thermal governor 'fair_share'
[ +0,000002] thermal_sys: Registered thermal governor 'bang_bang'
[ +0,000001] thermal_sys: Registered thermal governor 'step_wise'
[ +0,000001] thermal_sys: Registered thermal governor 'user_space'
[ +0,000000] thermal_sys: Registered thermal governor 'power_allocator'
[ +0,000015] cpuidle: using governor ladder
[ +0,000005] cpuidle: using governor menu
[ +0,000048] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ +0,000000] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[ +0,000000] PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved in E820
[ +0,000000] PCI: Using configuration type 1 for base access
[ +0,000000] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ +0,001847] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ +0,004251] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ +0,000000] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ +0,000092] ACPI: Added _OSI(Module Device)
[ +0,000000] ACPI: Added _OSI(Processor Device)
[ +0,000000] ACPI: Added _OSI(3.0 _SCP Extensions)
[ +0,000000] ACPI: Added _OSI(Processor Aggregator Device)
[ +0,090043] ACPI: 12 ACPI AML tables successfully acquired and loaded
[ +0,008949] ACPI: Dynamic OEM Table Load:
[ +0,000010] ACPI: SSDT 0xFFFF8F758027F200 0001B8 (v02 PmRef Cpu0Psd 00003000 INTL 20191018)
[ +0,000966] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ +0,001762] ACPI: Dynamic OEM Table Load:
[ +0,000007] ACPI: SSDT 0xFFFF8F75802CE400 000394 (v02 PmRef Cpu0Cst 00003001 INTL 20191018)
[ +0,001102] ACPI: Dynamic OEM Table Load:
[ +0,000006] ACPI: SSDT 0xFFFF8F75802CC000 000227 (v02 PmRef Cpu0Ist 00003000 INTL 20191018)
[ +0,001122] ACPI: Dynamic OEM Table Load:
[ +0,000005] ACPI: SSDT 0xFFFF8F758027F800 00013A (v02 PmRef Cpu0Hwp 00003000 INTL 20191018)
[ +0,001335] ACPI: Dynamic OEM Table Load:
[ +0,000007] ACPI: SSDT 0xFFFF8F7580185000 0008E7 (v02 PmRef ApIst 00003000 INTL 20191018)
[ +0,001313] ACPI: Dynamic OEM Table Load:
[ +0,000006] ACPI: SSDT 0xFFFF8F758136A800 00048A (v02 PmRef ApHwp 00003000 INTL 20191018)
[ +0,001189] ACPI: Dynamic OEM Table Load:
[ +0,000006] ACPI: SSDT 0xFFFF8F758136D000 0004D2 (v02 PmRef ApPsd 00003000 INTL 20191018)
[ +0,001184] ACPI: Dynamic OEM Table Load:
[ +0,000006] ACPI: SSDT 0xFFFF8F7581369800 00048A (v02 PmRef ApCst 00003000 INTL 20191018)
[ +0,003270] ACPI: EC: EC started
[ +0,000002] ACPI: EC: interrupt blocked
[ +0,002263] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ +0,000003] ACPI: \_SB_.PC00.LPCB.H_EC: Boot DSDT EC used to handle transactions
[ +0,000001] ACPI: Interpreter enabled
[ +0,000051] ACPI: PM: (supports S0 S3 S4 S5)
[ +0,000002] ACPI: Using IOAPIC for interrupt routing
[ +0,000053] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ +0,000002] PCI: Using E820 reservations for host bridge windows
[ +0,001309] ACPI: Enabled 6 GPEs in block 00 to 7F
[ +0,004956] ACPI: PM: Power Resource [PXP]
[ +0,000653] ACPI: PM: Power Resource [PXP]
[ +0,001068] ACPI: PM: Power Resource [PXP]
[ +0,012662] ACPI: PM: Power Resource [PAUD]
[ +0,003260] ACPI: PM: Power Resource [PXTC]
[ +0,001580] ACPI: PM: Power Resource [PXTC]
[ +0,093527] ACPI: PM: Power Resource [WRST]
[ +0,006682] ACPI: PM: Power Resource [FN00]
[ +0,000036] ACPI: PM: Power Resource [FN01]
[ +0,000034] ACPI: PM: Power Resource [FN02]
[ +0,000035] ACPI: PM: Power Resource [FN03]
[ +0,000033] ACPI: PM: Power Resource [FN04]
[ +0,000558] ACPI: PM: Power Resource [PIN]
[ +0,000370] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[ +0,000009] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ +0,002544] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ +0,001606] PCI host bridge to bus 0000:00
[ +0,000003] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ +0,000003] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ +0,000002] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ +0,000002] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[ +0,000001] pci_bus 0000:00: root bus resource [mem 0x7fc00000-0xbfffffff window]
[ +0,000002] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ +0,000002] pci_bus 0000:00: root bus resource [bus 00-fe]
[ +0,013988] pci 0000:00:00.0: [8086:4e12] type 00 class 0x060000
[ +0,000156] pci 0000:00:02.0: [8086:4e61] type 00 class 0x030000
[ +0,000012] pci 0000:00:02.0: reg 0x10: [mem 0x6000000000-0x6000ffffff 64bit]
[ +0,000007] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[ +0,000006] pci 0000:00:02.0: reg 0x20: [io 0x4000-0x403f]
[ +0,000019] pci 0000:00:02.0: BAR 2: assigned to efifb
[ +0,000002] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[ +0,000004] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ +0,000206] pci 0000:00:04.0: [8086:4e03] type 00 class 0x118000
[ +0,000017] pci 0000:00:04.0: reg 0x10: [mem 0x6001110000-0x600111ffff 64bit]
[ +0,000336] pci 0000:00:08.0: [8086:4e11] type 00 class 0x088000
[ +0,000010] pci 0000:00:08.0: reg 0x10: [mem 0x6001131000-0x6001131fff 64bit]
[ +0,000138] pci 0000:00:14.0: [8086:4ded] type 00 class 0x0c0330
[ +0,001594] pci 0000:00:14.0: reg 0x10: [mem 0x6001100000-0x600110ffff 64bit]
[ +0,000000] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ +0,000455] pci 0000:00:14.2: [8086:4def] type 00 class 0x050000
[ +0,000021] pci 0000:00:14.2: reg 0x10: [mem 0x6001124000-0x6001125fff 64bit]
[ +0,000014] pci 0000:00:14.2: reg 0x18: [mem 0x6001130000-0x6001130fff 64bit]
[ +0,000114] pci 0000:00:14.5: [8086:4df8] type 00 class 0x080501
[ +0,000024] pci 0000:00:14.5: reg 0x10: [mem 0x600112f000-0x600112ffff 64bit]
[ +0,000457] pci 0000:00:15.0: [8086:4de8] type 00 class 0x0c8000
[ +0,000058] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ +0,000489] pci 0000:00:15.1: [8086:4de9] type 00 class 0x0c8000
[ +0,000058] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ +0,000472] pci 0000:00:15.2: [8086:4dea] type 00 class 0x0c8000
[ +0,000058] pci 0000:00:15.2: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ +0,000487] pci 0000:00:15.3: [8086:4deb] type 00 class 0x0c8000
[ +0,000057] pci 0000:00:15.3: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ +0,000433] pci 0000:00:16.0: [8086:4de0] type 00 class 0x078000
[ +0,000024] pci 0000:00:16.0: reg 0x10: [mem 0x600112a000-0x600112afff 64bit]
[ +0,000089] pci 0000:00:16.0: PME# supported from D3hot
[ +0,000563] pci 0000:00:17.0: [8086:4dd3] type 00 class 0x010601
[ +0,000018] pci 0000:00:17.0: reg 0x10: [mem 0x7fd00000-0x7fd01fff]
[ +0,000010] pci 0000:00:17.0: reg 0x14: [mem 0x7fd03000-0x7fd030ff]
[ +0,000010] pci 0000:00:17.0: reg 0x18: [io 0x4090-0x4097]
[ +0,000010] pci 0000:00:17.0: reg 0x1c: [io 0x4080-0x4083]
[ +0,000009] pci 0000:00:17.0: reg 0x20: [io 0x4060-0x407f]
[ +0,000010] pci 0000:00:17.0: reg 0x24: [mem 0x7fd02000-0x7fd027ff]
[ +0,000052] pci 0000:00:17.0: PME# supported from D3hot
[ +0,000659] pci 0000:00:19.0: [8086:4dc5] type 00 class 0x0c8000
[ +0,000060] pci 0000:00:19.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ +0,001955] pci 0000:00:1c.0: [8086:4db9] type 01 class 0x060400
[ +0,000000] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ +0,000000] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[ +0,000000] pci 0000:00:1e.0: [8086:4da8] type 00 class 0x078000
[ +0,000000] pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ +0,000222] pci 0000:00:1e.3: [8086:4dab] type 00 class 0x0c8000
[ +0,000057] pci 0000:00:1e.3: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ +0,000420] pci 0000:00:1f.0: [8086:4d87] type 00 class 0x060100
[ +0,000382] pci 0000:00:1f.3: [8086:4dc8] type 00 class 0x040100
[ +0,000038] pci 0000:00:1f.3: reg 0x10: [mem 0x6001120000-0x6001123fff 64bit]
[ +0,000047] pci 0000:00:1f.3: reg 0x20: [mem 0x6001000000-0x60010fffff 64bit]
[ +0,000092] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ +0,000603] pci 0000:00:1f.4: [8086:4da3] type 00 class 0x0c0500
[ +0,000031] pci 0000:00:1f.4: reg 0x10: [mem 0x6001126000-0x60011260ff 64bit]
[ +0,000035] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ +0,000294] pci 0000:00:1f.5: [8086:4da4] type 00 class 0x0c8000
[ +0,000019] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ +0,000194] pci 0000:01:00.0: [10ec:c821] type 00 class 0x028000
[ +0,000038] pci 0000:01:00.0: reg 0x10: [io 0x3000-0x30ff]
[ +0,000047] pci 0000:01:00.0: reg 0x18: [mem 0x7fc00000-0x7fc0ffff 64bit]
[ +0,000224] pci 0000:01:00.0: supports D1 D2
[ +0,000001] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ +0,000386] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ +0,000005] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ +0,000003] pci 0000:00:1c.0: bridge window [mem 0x7fc00000-0x7fcfffff]
[ +0,003132] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ +0,000107] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ +0,000106] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ +0,000104] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ +0,000107] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ +0,000105] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ +0,000105] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ +0,000106] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ +0,014207] ACPI: EC: interrupt unblocked
[ +0,000002] ACPI: EC: event unblocked
[ +0,000019] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ +0,000001] ACPI: EC: GPE=0x6e
[ +0,000002] ACPI: \_SB_.PC00.LPCB.H_EC: Boot DSDT EC initialization complete
[ +0,000002] ACPI: \_SB_.PC00.LPCB.H_EC: EC: Used to handle transactions and events
[ +0,000117] iommu: Default domain type: Translated
[ +0,000000] iommu: DMA domain TLB invalidation policy: lazy mode
[ +0,000000] SCSI subsystem initialized
[ +0,000000] libata version 3.00 loaded.
[ +0,000000] ACPI: bus type USB registered
[ +0,000000] usbcore: registered new interface driver usbfs
[ +0,000000] usbcore: registered new interface driver hub
[ +0,000000] usbcore: registered new device driver usb
[ +0,000000] pps_core: LinuxPPS API ver. 1 registered
[ +0,000000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ +0,000000] PTP clock support registered
[ +0,000000] EDAC MC: Ver: 3.0.0
[ +0,002002] Registered efivars operations
[ +0,000192] NetLabel: Initializing
[ +0,000002] NetLabel: domain hash size = 128
[ +0,000001] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ +0,000016] NetLabel: unlabeled traffic allowed by default
[ +0,000005] mctp: management component transport protocol core
[ +0,000001] NET: Registered PF_MCTP protocol family
[ +0,000005] PCI: Using ACPI for IRQ routing
[ +0,018491] PCI: pci_cache_line_size set to 64 bytes
[ +0,000160] pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[ +0,000164] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ +0,000002] e820: reserve RAM buffer [mem 0x6d227000-0x6fffffff]
[ +0,000001] e820: reserve RAM buffer [mem 0x71043000-0x73ffffff]
[ +0,000001] e820: reserve RAM buffer [mem 0x71fb6000-0x73ffffff]
[ +0,000002] e820: reserve RAM buffer [mem 0x74f00000-0x77ffffff]
[ +0,000000] e820: reserve RAM buffer [mem 0x280400000-0x283ffffff]
[ +0,000955] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ +0,000000] pci 0000:00:02.0: vgaarb: bridge control possible
[ +0,000000] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ +0,000000] vgaarb: loaded
[ +0,000990] clocksource: Switched to clocksource tsc-early
[ +0,000154] VFS: Disk quotas dquot_6.6.0
[ +0,000013] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ +0,000113] AppArmor: AppArmor Filesystem Enabled
[ +0,000053] pnp: PnP ACPI init
[ +0,000251] system 00:00: [io 0x0680-0x069f] has been reserved
[ +0,000000] system 00:00: [io 0x164e-0x164f] has been reserved
[ +0,000040] system 00:01: [io 0x1854-0x1857] has been reserved
[ +0,000822] system 00:02: [mem 0xfea80000-0xfeafffff] has been reserved
[ +0,000003] system 00:02: [mem 0xfeda0000-0xfeda0fff] has been reserved
[ +0,000002] system 00:02: [mem 0xfeda1000-0xfeda1fff] has been reserved
[ +0,000002] system 00:02: [mem 0xc0000000-0xcfffffff] has been reserved
[ +0,000002] system 00:02: [mem 0xfed20000-0xfed7ffff] could not be reserved
[ +0,000002] system 00:02: [mem 0xfed90000-0xfed93fff] could not be reserved
[ +0,000002] system 00:02: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ +0,000001] system 00:02: [mem 0xfee00000-0xfeefffff] could not be reserved
[ +0,001237] system 00:04: [io 0x1800-0x18fe] could not be reserved
[ +0,000004] system 00:04: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ +0,000002] system 00:04: [mem 0xfe04c000-0xfe04ffff] has been reserved
[ +0,000002] system 00:04: [mem 0xfe050000-0xfe0affff] has been reserved
[ +0,000002] system 00:04: [mem 0xfe0d0000-0xfe0fffff] has been reserved
[ +0,000002] system 00:04: [mem 0xfe200000-0xfe7fffff] has been reserved
[ +0,000002] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ +0,000001] system 00:04: [mem 0xfd000000-0xfd68ffff] has been reserved
[ +0,000002] system 00:04: [mem 0xfd6b0000-0xfd6cffff] has been reserved
[ +0,000002] system 00:04: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ +0,000400] system 00:05: [io 0x2000-0x20fe] has been reserved
[ +0,000589] pnp: PnP ACPI: found 7 devices
[ +0,005797] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ +0,000114] NET: Registered PF_INET protocol family
[ +0,000159] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ +0,002108] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ +0,000068] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ +0,000083] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ +0,000353] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ +0,000177] TCP: Hash tables configured (established 65536 bind 65536)
[ +0,000122] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ +0,000039] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ +0,000031] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ +0,000046] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ +0,000008] NET: Registered PF_XDP protocol family
[ +0,000019] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000004] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffe0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000005] pci 0000:00:15.0: BAR 0: assigned [mem 0x4010000000-0x4010000fff 64bit]
[ +0,000058] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000002] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffe0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000003] pci 0000:00:15.1: BAR 0: assigned [mem 0x4010001000-0x4010001fff 64bit]
[ +0,000047] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000003] pci 0000:00:15.2: BAR 0: assigned [mem 0x4010002000-0x4010002fff 64bit]
[ +0,000046] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000003] pci 0000:00:15.3: BAR 0: assigned [mem 0x4010003000-0x4010003fff 64bit]
[ +0,000001] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffe0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000003] pci 0000:00:19.0: BAR 0: assigned [mem 0x4010004000-0x4010004fff 64bit]
[ +0,000044] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000002] pci 0000:00:1e.0: BAR 0: assigned [mem 0x4010005000-0x4010005fff 64bit]
[ +0,000002] pci 0000:00:1e.3: BAR 0: assigned [mem 0x4010006000-0x4010006fff 64bit]
[ +0,000047] clipped [mem size 0x00020000] to [mem size 0xfffffffffffc0000] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000002] clipped [mem size 0x00010000] to [mem size 0xffffffffffff0000] for e820 entry [mem 0x0009f000-0x000fffff]
[ +0,000003] pci 0000:00:1f.5: BAR 0: assigned [mem 0x7fd04000-0x7fd04fff]
[ +0,000011] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ +0,000003] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ +0,000005] pci 0000:00:1c.0: bridge window [mem 0x7fc00000-0x7fcfffff]
[ +0,000009] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ +0,000002] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ +0,000001] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ +0,000002] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000fffff window]
[ +0,000001] pci_bus 0000:00: resource 8 [mem 0x7fc00000-0xbfffffff window]
[ +0,000001] pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
[ +0,000002] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ +0,000002] pci_bus 0000:01: resource 1 [mem 0x7fc00000-0x7fcfffff]
[ +0,000750] PCI: CLS 64 bytes, default 64
[ +0,000025] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ +0,000001] software IO TLB: mapped [mem 0x0000000069227000-0x000000006d227000] (64MB)
[ +0,000075] Trying to unpack rootfs image as initramfs...
[ +0,000001] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x100d48ce7a0, max_idle_ns: 440795212195 ns
[ +0,000021] clocksource: Switched to clocksource tsc
[ +0,000033] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ +0,000751] Initialise system trusted keyrings
[ +0,000016] Key type blacklist registered
[ +0,000069] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ +0,001336] zbud: loaded
[ +0,000343] integrity: Platform Keyring initialized
[ +0,000004] integrity: Machine keyring initialized
[ +0,009468] Key type asymmetric registered
[ +0,000002] Asymmetric key parser 'x509' registered
[ +0,226912] Freeing initrd memory: 23216K
[ +0,003069] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ +0,000036] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ +0,000059] io scheduler mq-deadline registered
[ +0,000003] io scheduler kyber registered
[ +0,000046] io scheduler bfq registered
[ +0,002763] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[ +0,000075] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[ +0,000046] pcieport 0000:00:1c.0: DPC: enabled with IRQ 122
[ +0,000001] pcieport 0000:00:1c.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ +0,000127] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ +0,000294] Monitor-Mwait will be used to enter C-1 state
[ +0,000009] Monitor-Mwait will be used to enter C-2 state
[ +0,000006] Monitor-Mwait will be used to enter C-3 state
[ +0,000005] ACPI: \_SB_.PR00: Found 3 idle states
[ +0,000678] ACPI: AC: AC Adapter [ADP1] (off-line)
[ +0,000040] sysfs: cannot create duplicate filename '/class/power_supply/ADP1'
[ +0,000002] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 6.1.80-1-MANJARO #1 0cce29bc6ef66b86fcbcaa18ac1334cf1f1430e4
[ +0,000004] Hardware name: AMI INTEL/INTEL, BIOS 3.5_2105046 03/03/2022
[ +0,000001] Call Trace:
[ +0,000003] <TASK>
[ +0,000003] dump_stack_lvl+0x48/0x60
[ +0,000007] sysfs_warn_dup.cold+0x17/0x23
[ +0,000004] sysfs_do_create_link_sd+0xcf/0xe0
[ +0,000005] device_add+0x2d1/0x8c0
[ +0,000004] __power_supply_register+0x25a/0x3e0
[ +0,000004] acpi_ac_add+0x125/0x160
[ +0,000004] acpi_device_probe+0x47/0x160
[ +0,000004] really_probe+0xdb/0x380
[ +0,000002] ? pm_runtime_barrier+0x54/0x90
[ +0,000004] __driver_probe_device+0x78/0x120
[ +0,000002] driver_probe_device+0x1f/0x90
[ +0,000002] __driver_attach+0xd2/0x1c0
[ +0,000003] ? __device_attach_driver+0x110/0x110
[ +0,000002] bus_for_each_dev+0x88/0xd0
[ +0,000002] bus_add_driver+0x1b2/0x200
[ +0,000002] driver_register+0x8d/0xe0
[ +0,000003] acpi_ac_init+0x3c/0x48
[ +0,000005] ? ac_only_quirk+0x1a/0x1a
[ +0,000002] do_one_initcall+0x5a/0x230
[ +0,000005] kernel_init_freeable+0x1f0/0x22d
[ +0,000004] ? rest_init+0xd0/0xd0
[ +0,000003] kernel_init+0x1a/0x130
[ +0,000002] ret_from_fork+0x1f/0x30
[ +0,000004] </TASK>
[ +0,000008] ac: probe of ACPI0003:01 failed with error -17
[ +0,000045] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:08/PNP0C09:00/PNP0C0D:00/input/input0
[ +0,002471] ACPI: button: Lid Switch [LID0]
[ +0,000048] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ +0,000158] ACPI: button: Power Button [PWRB]
[ +0,000033] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ +0,000016] ACPI: button: Sleep Button [SLPB]
[ +0,000027] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ +0,000078] ACPI: button: Power Button [PWRF]
[ +0,001166] thermal LNXTHERM:00: registered as thermal_zone0
[ +0,000003] ACPI: thermal: Thermal Zone [TZ00] (0 C)
[ +0,000184] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ +0,002459] hpet_acpi_add: no address or irqs in _CRS
[ +0,000050] Non-volatile memory driver v1.3
[ +0,000001] Linux agpgart interface v0.103
[ +0,008648] ACPI: battery: Slot [BAT0] (battery present)
[ +0,000598] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ +0,000039] ACPI: bus type drm_connector registered
[ +0,000434] ahci 0000:00:17.0: version 3.0
[ +0,000297] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ +0,000004] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds
[ +0,000242] scsi host0: ahci
[ +0,000119] scsi host1: ahci
[ +0,000037] ata1: SATA max UDMA/133 abar m2048@0x7fd02000 port 0x7fd02100 irq 123
[ +0,000004] ata2: SATA max UDMA/133 abar m2048@0x7fd02000 port 0x7fd02180 irq 123
[ +0,000100] usbcore: registered new interface driver usbserial_generic
[ +0,000005] usbserial: USB Serial support registered for generic
[ +0,000100] rtc_cmos rtc_cmos: RTC can wake from S4
[ +0,000711] rtc_cmos rtc_cmos: registered as rtc0
[ +0,000266] rtc_cmos rtc_cmos: setting system clock to 2024-03-09T12:00:01 UTC (1709985601)
[ +0,000030] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ +0,000072] intel_pstate: Intel P-state driver initializing
[ +0,000186] intel_pstate: HWP enabled
[ +0,000021] ledtrig-cpu: registered to indicate activity on CPUs
[ +0,000323] efifb: probing for efifb
[ +0,000019] efifb: showing boot graphics
[ +0,004440] efifb: framebuffer at 0x4000000000, using 8128k, total 8128k
[ +0,000006] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ +0,000001] efifb: scrolling: redraw
[ +0,000001] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ +0,000072] fbcon: Deferring console take-over
[ +0,000001] fb0: EFI VGA frame buffer device
[ +0,000041] hid: raw HID events driver (C) Jiri Kosina
[ +0,000084] intel_pmc_core INT33A1:00: initialized
[ +0,000154] drop_monitor: Initializing network drop monitor service
[ +0,010941] Initializing XFRM netlink socket
[ +0,000115] NET: Registered PF_INET6 protocol family
[ +0,004028] Segment Routing with IPv6
[ +0,000005] RPL Segment Routing with IPv6
[ +0,000015] In-situ OAM (IOAM) with IPv6
[ +0,000034] NET: Registered PF_PACKET protocol family
[ +0,000278] microcode: sig=0x906c0, pf=0x1, revision=0x24000024
[ +0,000066] microcode: Microcode Update Driver: v2.2.
[ +0,000274] resctrl: L2 allocation detected
[ +0,000007] IPI shorthand broadcast: enabled
[ +0,000028] sched_clock: Marking stable (727027541, 6600295)->(759810681, -26182845)
[ +0,000177] registered taskstats version 1
[ +0,000074] Loading compiled-in X.509 certificates
[ +0,004572] Loaded X.509 cert 'Build time autogenerated kernel key: 6e2566bdbfd00b2663d4bb0f7e459bb05a537a10'
[ +0,001094] zswap: loaded using pool zstd/z3fold
[ +0,000565] Key type .fscrypt registered
[ +0,000001] Key type fscrypt-provisioning registered
[ +0,000043] AppArmor: AppArmor sha1 policy hashing enabled
[ +0,001679] PM: Magic number: 0:889:25
[ +0,000112] memory memory65: hash matches
[ +0,000112] RAS: Correctable Errors collector initialized.
[ +0,283495] ata2: SATA link down (SStatus 4 SControl 300)
[ +0,334480] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ +0,000341] ata1.00: ATA-9: Netac SSD 256GB, HCS1A25E, max UDMA/133
[ +0,001683] ata1.00: 500118192 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ +0,008277] ata1.00: configured for UDMA/133
[ +0,000570] scsi 0:0:0:0: Direct-Access ATA Netac SSD 256GB A25E PQ: 0 ANSI: 5
[ +0,002627] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[ +0,000141] sd 0:0:0:0: [sda] Write Protect is off
[ +0,000010] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ +0,000231] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ +0,000343] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ +0,005573] sda: sda1 sda3
[ +0,000418] sd 0:0:0:0: [sda] Attached SCSI disk
[ +0,003370] Freeing unused decrypted memory: 2036K
[ +0,001161] Freeing unused kernel image (initmem) memory: 2164K
[ +0,015342] Write protecting the kernel read-only data: 30720k
[ +0,001586] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ +0,000436] Freeing unused kernel image (rodata/data gap) memory: 668K
[ +0,014804] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ +0,000005] rodata_test: all tests were successful
[ +0,000008] Run /init as init process
[ +0,000001] with arguments:
[ +0,000002] /init
[ +0,000001] splash
[ +0,000001] with environment:
[ +0,000001] HOME=/
[ +0,000001] TERM=linux
[ +0,000001] BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64
[ +0,168428] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ +0,000006] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ +0,008413] serio: i8042 KBD port at 0x60,0x64 irq 1
[ +0,017677] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ +0,000012] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ +0,001135] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x110 quirks 0x0000000000009810
[ +0,002001] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ +0,000008] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ +0,000005] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ +0,000069] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ +0,000003] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0,000002] usb usb1: Product: xHCI Host Controller
[ +0,000002] usb usb1: Manufacturer: Linux 6.1.80-1-MANJARO xhci-hcd
[ +0,000001] usb usb1: SerialNumber: 0000:00:14.0
[ +0,000157] hub 1-0:1.0: USB hub found
[ +0,000018] hub 1-0:1.0: 8 ports detected
[ +0,006307] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ +0,000008] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0,000002] usb usb2: Product: xHCI Host Controller
[ +0,000002] usb usb2: Manufacturer: Linux 6.1.80-1-MANJARO xhci-hcd
[ +0,000001] usb usb2: SerialNumber: 0000:00:14.0
[ +0,000503] hub 2-0:1.0: USB hub found
[ +0,000019] hub 2-0:1.0: 6 ports detected
[ +0,003775] sdhci: Secure Digital Host Controller Interface driver
[ +0,000003] sdhci: Copyright(c) Pierre Ossman
[ +0,012745] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ +0,001941] sdhci-pci 0000:00:14.5: SDHCI controller found [8086:4df8] (rev 1)
[ +0,001216] mmc0: SDHCI controller on PCI [0000:00:14.5] using ADMA 64-bit
[ +0,145601] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
[ +0,089514] usb 1-5: new high-speed USB device number 2 using xhci_hcd
[ +0,166308] systemd[1]: systemd 255.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ +0,000008] systemd[1]: Detected architecture x86-64.
[ +0,002793] systemd[1]: Hostname set to <vadim-bmax>.
[ +0,077274] usb 1-5: New USB device found, idVendor=058f, idProduct=5608, bcdDevice=18.10
[ +0,000008] usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ +0,000002] usb 1-5: Product: SHUNCCM2MP
[ +0,000001] usb 1-5: Manufacturer: Alcor Micro, Corp.
[ +0,127090] usb 1-8: new full-speed USB device number 3 using xhci_hcd
[ +0,141531] usb 1-8: New USB device found, idVendor=0bda, idProduct=c821, bcdDevice= 1.10
[ +0,000020] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0,000007] usb 1-8: Product: Bluetooth Radio
[ +0,000004] usb 1-8: Manufacturer: Realtek
[ +0,000005] usb 1-8: SerialNumber: 00e04c000001
[ +0,181953] systemd[1]: bpf-lsm: LSM BPF program attached
[ +0,483361] systemd[1]: Queued start job for default target Graphical Interface.
[ +0,036878] systemd[1]: Created slice Slice /system/dirmngr.
[ +0,001092] systemd[1]: Created slice Slice /system/getty.
[ +0,000902] systemd[1]: Created slice Slice /system/gpg-agent.
[ +0,000939] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ +0,000997] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ +0,000902] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ +0,000868] systemd[1]: Created slice Slice /system/keyboxd.
[ +0,000762] systemd[1]: Created slice Slice /system/modprobe.
[ +0,000732] systemd[1]: Created slice Slice /system/systemd-fsck.
[ +0,000549] systemd[1]: Created slice User and Session Slice.
[ +0,000179] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ +0,000463] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ +0,000058] systemd[1]: Expecting device /dev/disk/by-uuid/1836-57EF...
[ +0,000035] systemd[1]: Reached target Login Prompts.
[ +0,000049] systemd[1]: Reached target Local Integrity Protected Volumes.
[ +0,000043] systemd[1]: Reached target Remote File Systems.
[ +0,000025] systemd[1]: Reached target Slice Units.
[ +0,000028] systemd[1]: Reached target Mounting snaps.
[ +0,000020] systemd[1]: Reached target Mounted snaps.
[ +0,000032] systemd[1]: Reached target Swaps.
[ +0,000040] systemd[1]: Reached target Local Verity Protected Volumes.
[ +0,000136] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ +0,000788] systemd[1]: Listening on LVM2 poll daemon socket.
[ +0,002622] systemd[1]: Listening on Process Core Dump Socket.
[ +0,000189] systemd[1]: Listening on Journal Socket (/dev/log).
[ +0,000166] systemd[1]: Listening on Journal Socket.
[ +0,000074] systemd[1]: TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ +0,000698] systemd[1]: Listening on udev Control Socket.
[ +0,000159] systemd[1]: Listening on udev Kernel Socket.
[ +0,002070] systemd[1]: Mounting Huge Pages File System...
[ +0,000858] systemd[1]: Mounting POSIX Message Queue File System...
[ +0,000814] systemd[1]: Mounting Kernel Debug File System...
[ +0,000782] systemd[1]: Mounting Kernel Trace File System...
[ +0,001001] systemd[1]: Starting Load AppArmor profiles...
[ +0,006569] systemd[1]: Starting Create List of Static Device Nodes...
[ +0,002208] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ +0,001035] systemd[1]: Starting Load Kernel Module configfs...
[ +0,001448] systemd[1]: Starting Load Kernel Module dm_mod...
[ +0,003334] systemd[1]: Starting Load Kernel Module drm...
[ +0,001105] systemd[1]: Starting Load Kernel Module fuse...
[ +0,004063] systemd[1]: Starting Load Kernel Module loop...
[ +0,000206] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ +0,004697] systemd[1]: Starting Load Kernel Modules...
[ +0,000029] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ +0,001559] systemd[1]: Starting Remount Root and Kernel File Systems...
[ +0,000071] systemd[1]: TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ +0,001264] systemd[1]: Starting Coldplug All udev Devices...
[ +0,003045] systemd[1]: Starting Virtual Console Setup...
[ +0,001644] systemd[1]: Mounted Huge Pages File System.
[ +0,000278] systemd[1]: Mounted POSIX Message Queue File System.
[ +0,000168] systemd[1]: Mounted Kernel Debug File System.
[ +0,000153] systemd[1]: Mounted Kernel Trace File System.
[ +0,015637] loop: module loaded
[ +0,010583] fuse: init (API version 7.37)
[ +0,000364] systemd[1]: Finished Create List of Static Device Nodes.
[ +0,000498] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ +0,001169] EXT4-fs (sda3): re-mounted. Quota mode: none.
[ +0,002053] device-mapper: uevent: version 1.0.3
[ +0,000087] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ +0,007331] systemd[1]: Finished Load Kernel Module configfs.
[ +0,001064] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ +0,018897] systemd[1]: Finished Load Kernel Module dm_mod.
[ +0,000369] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ +0,016380] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ +0,006605] systemd[1]: Finished Load Kernel Module drm.
[ +0,000381] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ +0,016218] systemd[1]: Finished Load Kernel Module fuse.
[ +0,000386] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ +0,016310] systemd[1]: Finished Load Kernel Module loop.
[ +0,036864] systemd[1]: Finished Load Kernel Modules.
[ +0,017360] audit: type=1400 audit(1709985604.100:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=266 comm="apparmor_parser"
[ +0,000595] audit: type=1400 audit(1709985604.100:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=265 comm="apparmor_parser"
[ +0,000950] audit: type=1400 audit(1709985604.100:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=266 comm="apparmor_parser"
[ +0,011092] systemd[1]: Finished Remount Root and Kernel File Systems.
[ +0,020084] audit: type=1400 audit(1709985604.133:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=264 comm="apparmor_parser"
[ +0,009864] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ +0,002618] audit: type=1400 audit(1709985604.143:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=267 comm="apparmor_parser"
[ +0,025833] audit: type=1400 audit(1709985604.170:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=270 comm="apparmor_parser"
[ +0,000552] audit: type=1400 audit(1709985604.170:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=269 comm="apparmor_parser"
[ +0,000974] systemd[1]: Finished Coldplug All udev Devices.
[ +0,025628] audit: type=1400 audit(1709985604.196:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=271 comm="apparmor_parser"
[ +0,000052] audit: type=1400 audit(1709985604.196:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=274 comm="apparmor_parser"
[ +0,010998] systemd[1]: Finished Virtual Console Setup.
[ +0,029928] systemd[1]: Mounting FUSE Control File System...
[ +0,001263] systemd[1]: Mounting Kernel Configuration File System...
[ +0,004137] systemd[1]: Starting Rebuild Hardware Database...
[ +0,004710] systemd[1]: Starting Load/Save OS Random Seed...
[ +0,000097] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ +0,003222] systemd[1]: Starting Apply Kernel Variables...
[ +0,013237] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ +0,000035] systemd[1]: TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ +0,000913] systemd[1]: Mounted FUSE Control File System.
[ +0,000185] systemd[1]: Mounted Kernel Configuration File System.
[ +0,055502] systemd[1]: Finished Load/Save OS Random Seed.
[ +0,016767] systemd[1]: Finished Apply Kernel Variables.
[ +0,036682] systemd[1]: Starting CLI Netfilter Manager...
[ +0,060058] systemd[1]: Finished CLI Netfilter Manager.
[ +0,040182] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ +0,039827] systemd[1]: Starting Create System Users...
[ +0,106507] systemd[1]: Finished Create System Users.
[ +0,030085] systemd[1]: Starting Create Static Device Nodes in /dev...
[ +0,053318] systemd[1]: Finished Create Static Device Nodes in /dev.
[ +0,000255] systemd[1]: Reached target Preparation for Local File Systems.
[ +0,039717] systemd[1]: Mounting /tmp...
[ +0,000068] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ +0,000100] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ +0,008672] systemd[1]: Starting Journal Service...
[ +0,001649] systemd[1]: Mounted /tmp.
[ +0,037901] systemd-journald[312]: Collecting audit messages is disabled.
[ +0,049441] systemd[1]: Started Journal Service.
[ +0,056399] systemd-journald[312]: Received client request to flush runtime journal.
[ +0,064382] systemd-journald[312]: /var/log/journal/f774c5bbc9dc40bea2022da28331b6cc/system.journal: Journal file uses a different sequence number ID, rotating.
[ +0,000013] systemd-journald[312]: Rotating system journal.
[ +0,719387] Consider using thermal netlink events interface
[ +0,035173] input: Intel HID events as /devices/platform/INTC1051:00/input/input5
[ +0,001688] intel-hid INTC1051:00: platform supports 5 button array
[ +0,000047] input: Intel HID 5 button array as /devices/platform/INTC1051:00/input/input6
[ +0,072190] mc: Linux media interface: v0.10
[ +0,048924] videodev: Linux video capture interface: v2.00
[ +0,163219] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[ +0,000642] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ +0,022254] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ +0,090091] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ +0,010398] intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
[ +0,001157] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ +0,062317] Bluetooth: Core ver 2.22
[ +0,000123] NET: Registered PF_BLUETOOTH protocol family
[ +0,000003] Bluetooth: HCI device and connection manager initialized
[ +0,000006] Bluetooth: HCI socket layer initialized
[ +0,000003] Bluetooth: L2CAP socket layer initialized
[ +0,000006] Bluetooth: SCO socket layer initialized
[ +0,003461] intel-lpss 0000:00:15.2: enabling device (0004 -> 0006)
[ +0,001383] idma64 idma64.2: Found Intel integrated DMA 64-bit
[ +0,012145] kxcjk1013 i2c-KIOX010A:00: mounting matrix not found: using identity...
[ +0,000010] kxcjk1013 i2c-KIOX010A:00: supply vdd not found, using dummy regulator
[ +0,000042] kxcjk1013 i2c-KIOX010A:00: supply vddio not found, using dummy regulator
[ +0,019351] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ +0,000415] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ +0,000248] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ +0,044660] Goodix-TS i2c-GDIX1001:00: supply AVDD28 not found, using dummy regulator
[ +0,000114] Goodix-TS i2c-GDIX1001:00: supply VDDIO not found, using dummy regulator
[ +0,002337] Goodix-TS i2c-GDIX1001:00: ID 9110, version: 3003
[ +0,017877] input: Goodix Capacitive TouchScreen as /devices/pci0000:00/0000:00:15.2/i2c_designware.2/i2c-2/i2c-GDIX1001:00/input/input8
[ +0,014767] intel-lpss 0000:00:15.3: enabling device (0004 -> 0006)
[ +0,000777] idma64 idma64.3: Found Intel integrated DMA 64-bit
[ +0,018650] kxcjk1013 i2c-KIOX020A:00: mounting matrix not found: using identity...
[ +0,000013] kxcjk1013 i2c-KIOX020A:00: supply vdd not found, using dummy regulator
[ +0,000058] kxcjk1013 i2c-KIOX020A:00: supply vddio not found, using dummy regulator
[ +0,029843] i2c_hid_acpi i2c-SYNA3602:00: i2c_hid_get_input: incomplete report (32/49344)
[ +0,001443] i2c_hid_acpi i2c-SYNA3602:00: i2c_hid_get_input: incomplete report (32/49344)
[ +0,000404] input: SYNA3602:00 0911:5288 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3602:00/0018:0911:5288.0001/input/input10
[ +0,000133] input: SYNA3602:00 0911:5288 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3602:00/0018:0911:5288.0001/input/input11
[ +0,000069] hid-generic 0018:0911:5288.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA3602:00 0911:5288] on i2c-SYNA3602:00
[ +0,000682] i2c_hid_acpi i2c-SYNA3602:00: i2c_hid_get_input: incomplete report (32/49344)
[ +0,001293] i2c_hid_acpi i2c-SYNA3602:00: i2c_hid_get_input: incomplete report (32/49344)
[ +0,007181] cryptd: max_cpu_qlen set to 1000
[ +0,032241] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ +0,000078] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ +0,003317] spi-nor spi0.0: unrecognized JEDEC id bytes: a1 28 18 a1 28 18
[ +0,007151] i2c i2c-4: 1/2 memory slots populated (from DMI)
[ +0,025456] SSE version of gcm_enc/dec engaged.
[ +0,073861] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[ +0,000419] intel-lpss 0000:00:19.0: enabling device (0004 -> 0006)
[ +0,120250] usb 1-5: Found UVC 1.00 device SHUNCCM2MP (058f:5608)
[ +0,003179] ov13858: probe of i2c-OVTID858:01 failed with error -22
[ +0,028426] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[ +0,009549] idma64 idma64.5: Found Intel integrated DMA 64-bit
[ +0,004515] input: SHUNCCM2MP: SHUNCCM2MP as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input12
[ +0,007022] usbcore: registered new interface driver uvcvideo
[ +0,011891] intel-lpss 0000:00:1e.3: enabling device (0004 -> 0006)
[ +0,000715] idma64 idma64.6: Found Intel integrated DMA 64-bit
[ +0,335790] mousedev: PS/2 mouse device common for all mice
[ +0,000771] usbcore: registered new interface driver btusb
[ +0,000644] intel_rapl_common: Found RAPL domain package
[ +0,000004] intel_rapl_common: Found RAPL domain core
[ +0,000002] intel_rapl_common: Found RAPL domain uncore
[ +0,000002] intel_rapl_common: Found RAPL domain psys
[ +0,000004] iTCO_vendor_support: vendor-support=0
[ +0,000827] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[ +0,000553] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ +0,000005] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[ +0,010719] rtw_8821ce 0000:01:00.0: enabling device (0000 -> 0003)
[ +0,003228] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[ +0,002345] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[ +0,001288] rtw_8821ce 0000:01:00.0: Firmware version 24.11.0, H2C version 12
[ +0,007259] i915 0000:00:02.0: vgaarb: deactivate vga console
[ +0,000142] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[ +0,004625] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ +0,007266] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/icl_dmc_ver1_09.bin (v1.9)
[ +0,009884] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ +0,015344] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ +0,001577] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ +0,067255] input: SYNA3602:00 0911:5288 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3602:00/0018:0911:5288.0001/input/input13
[ +0,010817] loop0: detected capacity change from 0 to 8
[ +0,005324] rtw_8821ce 0000:01:00.0 wlp1s0: renamed from wlan0
[ +0,000727] dw-apb-uart.5: ttyS4 at MMIO 0x4010005000 (irq = 20, base_baud = 7500000) is a 16550A
[ +0,023566] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ +0,043728] input: SYNA3602:00 0911:5288 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3602:00/0018:0911:5288.0001/input/input14
[ +0,000179] hid-multitouch 0018:0911:5288.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA3602:00 0911:5288] on i2c-SYNA3602:00
[ +0,020120] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ +0,002466] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ +0,000538] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input15
[ +0,001916] fbcon: i915drmfb (fb0) is primary device
[ +0,000005] fbcon: Deferring console take-over
[ +0,000004] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ +0,021700] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ +0,000008] Bluetooth: BNEP filters: protocol multicast
[ +0,000007] Bluetooth: BNEP socket layer initialized
[ +0,033650] NET: Registered PF_QIPCRTR protocol family
[ +0,182381] kauditd_printk_skb: 57 callbacks suppressed
[ +0,000005] audit: type=1400 audit(1709985607.513:68): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=589 comm="apparmor_parser"
[ +0,003405] audit: type=1400 audit(1709985607.516:69): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=589 comm="apparmor_parser"
[ +0,001528] Bluetooth: hci0: RTL: fw version 0x75b8f098
[ +0,075396] Bluetooth: MGMT ver 1.22
[ +0,012812] sof-audio-pci-intel-icl 0000:00:1f.3: enabling device (0000 -> 0002)
[ +0,000248] sof-audio-pci-intel-icl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ +0,000156] sof-audio-pci-intel-icl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ +0,001272] NET: Registered PF_ALG protocol family
[ +0,005465] sof-audio-pci-intel-icl 0000:00:1f.3: use msi interrupt mode
[ +0,048307] sof-audio-pci-intel-icl 0000:00:1f.3: NHLT_DEVICE_I2S detected, ssp_mask 0x2
[ +0,000012] sof-audio-pci-intel-icl 0000:00:1f.3: Overriding topology with MCLK mask 0x1 from NHLT
[ +0,000003] sof-audio-pci-intel-icl 0000:00:1f.3: hda codecs found, mask 4
[ +0,007121] sof-audio-pci-intel-icl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ +0,000009] sof-audio-pci-intel-icl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ +0,000008] sof-audio-pci-intel-icl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ +0,053808] typec port0: bound usb1-port4 (ops connector_ops)
[ +0,000014] typec port0: bound usb2-port1 (ops connector_ops)
[ +0,062145] sof-audio-pci-intel-icl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ +0,000006] sof-audio-pci-intel-icl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ +0,019360] sof-essx8336 sof-essx8336: quirk mask 0x1
[ +0,000008] sof-essx8336 sof-essx8336: quirk SSP1
[ +0,002954] sof-audio-pci-intel-icl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
[ +0,000146] sof-essx8336 sof-essx8336: ASoC: Parent card not yet available, widget card binding deferred
[ +0,014294] es8316 i2c-ESSX8336:00: assuming static mclk
[ +0,064902] sof-essx8336 sof-essx8336: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ +0,014254] input: sof-essx8336 Headset as /devices/pci0000:00/0000:00:1f.3/sof-essx8336/sound/card0/input16
[ +0,000054] input: sof-essx8336 HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/sof-essx8336/sound/card0/input17
[ +0,000039] input: sof-essx8336 HDMI/DP,pcm=6 as /devices/pci0000:00/0000:00:1f.3/sof-essx8336/sound/card0/input18
[ +0,000039] input: sof-essx8336 HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sof-essx8336/sound/card0/input19
[ +1,016983] typec port1: bound usb1-port3 (ops connector_ops)
[ +0,000030] typec port1: bound usb2-port2 (ops connector_ops)
[ +4,619340] wlp1s0: authenticate with 60:e3:27:82:8f:9c
[ +0,507232] wlp1s0: send auth to 60:e3:27:82:8f:9c (try 1/3)
[ +0,005915] wlp1s0: authenticated
[ +0,000716] wlp1s0: associate with 60:e3:27:82:8f:9c (try 1/3)
[ +0,007582] wlp1s0: RX AssocResp from 60:e3:27:82:8f:9c (capab=0x431 status=0 aid=4)
[ +0,000420] wlp1s0: associated
[ +0,072164] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[ +0,738590] rfkill: input handler disabled
[мар 9 15:12] systemd-journald[312]: /var/log/journal/f774c5bbc9dc40bea2022da28331b6cc/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[ +0,476698] rfkill: input handler enabled
[ +2,789814] rfkill: input handler disabled
[ +3,209424] Bluetooth: RFCOMM TTY layer initialized
[ +0,000017] Bluetooth: RFCOMM socket layer initialized
[ +0,000005] Bluetooth: RFCOMM ver 1.11
[мар 9 15:23] wlp1s0: deauthenticating from 60:e3:27:82:8f:9c by local choice (Reason: 3=DEAUTH_LEAVING)
[ +4,264538] ACPI: button: The lid device is not compliant to SW_LID.
[ +0,461523] PM: suspend entry (deep)
[ +0,060514] Filesystems sync: 0.060 seconds
[ +0,000723] Freezing user space processes
[ +0,178212] Freezing user space processes completed (elapsed 0.178 seconds)
[ +0,000023] OOM killer disabled.
[ +0,000004] Freezing remaining freezable tasks
[ +0,001552] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ +0,000153] printk: Suspending console(s) (use no_console_suspend to debug)
[ +0,044416] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ +0,002056] ata1.00: Entering standby power mode
[ +0,346343] ACPI: EC: interrupt blocked
[ +0,057865] ACPI: PM: Preparing to enter system sleep state S3
[ +0,002448] ACPI: EC: event blocked
[ +0,000003] ACPI: EC: EC stopped
[ +0,000002] ACPI: PM: Saving platform NVS memory
[ +0,000051] Disabling non-boot CPUs ...
[ +0,002108] smpboot: CPU 1 is now offline
[ +0,003237] smpboot: CPU 2 is now offline
[ +0,002425] smpboot: CPU 3 is now offline
[ +0,003600] ACPI: PM: Low-level resume complete
[ +0,000064] ACPI: EC: EC started
[ +0,000001] ACPI: PM: Restoring platform NVS memory
[ +0,001004] Enabling non-boot CPUs ...
[ +0,000241] x86: Booting SMP configuration:
[ +0,000001] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ +0,000910] CPU1 is up
[ +0,000215] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ +0,000972] CPU2 is up
[ +0,000206] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ +0,000999] CPU3 is up
[ +0,000347] ACPI: PM: Waking up from system sleep state S3
[ +0,006045] ACPI: EC: interrupt unblocked
[ +0,153124] ACPI: EC: event unblocked
[ +0,366556] usb 1-8: reset full-speed USB device number 3 using xhci_hcd
[ +0,009889] ata2: SATA link down (SStatus 4 SControl 300)
[ +0,626540] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ +0,000025] ata1.00: Entering active power mode
[ +0,006758] ata1.00: configured for UDMA/133
[ +0,027353] OOM killer enabled.
[ +0,000008] Restarting tasks ...
[ +0,011720] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ +0,002647] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[ +0,000936] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ +0,000032] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[ +0,000035] Bluetooth: hci0: RTL: cfg_sz 10, total sz 34926
[ +0,004265] done.
[ +0,000016] random: crng reseeded on system resumption
[ +0,023706] PM: suspend exit
[ +0,436194] Bluetooth: hci0: RTL: fw version 0x75b8f098
[ +0,080018] Bluetooth: MGMT ver 1.22
[мар 9 15:24] wlp1s0: authenticate with 60:e3:27:82:8f:9c
[ +0,508082] wlp1s0: send auth to 60:e3:27:82:8f:9c (try 1/3)
[ +0,001944] wlp1s0: authenticated
[ +0,004733] wlp1s0: associate with 60:e3:27:82:8f:9c (try 1/3)
[ +0,004354] wlp1s0: RX AssocResp from 60:e3:27:82:8f:9c (capab=0x431 status=0 aid=1)
[ +0,000431] wlp1s0: associated
[ +0,045423] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[мар 9 15:27] rtw_8821ce 0000:01:00.0: timed out to flush queue 1
[ +9,536867] rtw_8821ce 0000:01:00.0: timed out to flush queue 1
[ +15,090253] rtw_8821ce 0000:01:00.0: timed out to flush queue 1
[ +4,746695] rtw_8821ce 0000:01:00.0: timed out to flush queue 1
Sometimes after i plug in the flash stick i get this in terminal:
dmesg --follow-new
ucsi_acpi USBC000:00: GET_CONNECTOR_STATUS failed (-5)
or
[ 1534.222184] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-110)
Please help
Thanks
