I purchased a generic USB potentiometer (on Amazon dot com then /dp/B0DQ8M43HH), and to my surprise, nothing happens after I plug in, in dmesg, in /dev/input/by-id/, lsusb, or /proc/bus/input/devices. The annoying light does come on, but this happens the same way on multiple Manjaro installs. Works perfectly on Android. Something else I should try?
Welcome to the forum! ![]()
Output, please?
Help us help you.
Please see:
Interesting! Didnāt think it was relevant since the output didnāt change (this is just one of the machines I tested on). This is about 10 seconds after I plugged in ![]()
dmesg:
[734775.887408] hid-generic 0003:3233:8311.02C9: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[734776.073502] usb 3-2.1: new full-speed USB device number 20 using xhci_hcd
[734776.170050] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[734776.170061] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[734776.170067] usb 3-2.1: Product: USB Audio Device
[734776.170071] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[734776.538184] cmedia_hs100b 0003:0D8C:0014.02CA: Fixing CMedia HS-100B report descriptor
[734776.538291] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.02CA/input/input546
[734776.590877] cmedia_hs100b 0003:0D8C:0014.02CA: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[791923.168318] usb 3-2: USB disconnect, device number 16
[791923.168332] usb 3-2.1: USB disconnect, device number 20
[791923.242960] usb 3-2.2: USB disconnect, device number 17
[791923.481417] usb 4-2: USB disconnect, device number 66
[791923.723000] usb 3-2.4: USB disconnect, device number 19
[791946.288045] usb 4-2: new SuperSpeed USB device number 67 using xhci_hcd
[791946.307128] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[791946.307142] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[791946.307149] usb 4-2: Product: USB3.0 Hub
[791946.307155] usb 4-2: Manufacturer: GenesysLogic
[791946.333263] hub 4-2:1.0: USB hub found
[791946.333609] hub 4-2:1.0: 4 ports detected
[791946.417847] usb 3-2: new high-speed USB device number 21 using xhci_hcd
[791946.554257] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[791946.554271] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[791946.554278] usb 3-2: Product: USB2.0 Hub
[791946.554284] usb 3-2: Manufacturer: GenesysLogic
[791946.605465] hub 3-2:1.0: USB hub found
[791946.606045] hub 3-2:1.0: 4 ports detected
[791946.951176] usb 3-2.2: new full-speed USB device number 22 using xhci_hcd
[791947.050912] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[791947.050927] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[791947.050934] usb 3-2.2: Product: USB Receiver
[791947.050940] usb 3-2.2: Manufacturer: Logitech
[791947.168251] logitech-djreceiver 0003:046D:C52B.02CD: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[791947.284917] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02CD/0003:046D:4090.02CE/input/input547
[791947.285209] logitech-hidpp-device 0003:046D:4090.02CE: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[791947.295067] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02CD/0003:046D:405E.02CF/input/input548
[791947.341118] usb 3-2.4: new full-speed USB device number 23 using xhci_hcd
[791947.421478] logitech-hidpp-device 0003:046D:405E.02CF: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[791947.447614] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[791947.447625] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[791947.447630] usb 3-2.4: Product: Ducky One 3 TKL RGB
[791947.447634] usb 3-2.4: Manufacturer: Ducky
[791947.447638] usb 3-2.4: SerialNumber: DK-V1.04-201102
[791947.670392] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.02D0/input/input549
[791947.725292] hid-generic 0003:3233:8311.02D0: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[791947.733379] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.02D1/input/input550
[791947.848203] hid-generic 0003:3233:8311.02D1: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[791947.855134] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.02D2/input/input551
[791947.855453] hid-generic 0003:3233:8311.02D2: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[791947.863345] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.02D3/input/input552
[791947.918497] hid-generic 0003:3233:8311.02D3: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[791947.926348] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.02D4/input/input553
[791947.978420] hid-generic 0003:3233:8311.02D4: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[791948.171143] usb 3-2.1: new full-speed USB device number 24 using xhci_hcd
[791948.274978] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[791948.274989] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[791948.274995] usb 3-2.1: Product: USB Audio Device
[791948.274999] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[791948.658824] cmedia_hs100b 0003:0D8C:0014.02D5: Fixing CMedia HS-100B report descriptor
[791948.658961] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.02D5/input/input554
[791948.711486] cmedia_hs100b 0003:0D8C:0014.02D5: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[791955.849844] logitech-hidpp-device 0003:046D:405E.02CF: HID++ 4.5 device connected.
[792087.761655] usb 3-1: USB disconnect, device number 2
[792087.761668] usb 3-1.1: USB disconnect, device number 4
[792088.044441] usb 3-1: new high-speed USB device number 25 using xhci_hcd
[792088.175989] usb 3-1: New USB device found, idVendor=1a40, idProduct=0801, bcdDevice= 1.00
[792088.176006] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[792088.176013] usb 3-1: Product: USB 2.0 Hub
[792088.216175] hub 3-1:1.0: USB hub found
[792088.216476] hub 3-1:1.0: 4 ports detected
[792088.504493] usb 3-1.1: new full-speed USB device number 26 using xhci_hcd
[792088.630221] usb 3-1.1: New USB device found, idVendor=2d79, idProduct=0004, bcdDevice= 0.01
[792088.630236] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[792088.630243] usb 3-1.1: Product: LDR2002
[792088.630248] usb 3-1.1: Manufacturer: ę·±å³ä¹å¾ē
[792088.630253] usb 3-1.1: SerialNumber: 2022-02-22
[792336.966571] usb 3-2: USB disconnect, device number 21
[792336.966583] usb 3-2.1: USB disconnect, device number 24
[792337.034977] usb 3-2.2: USB disconnect, device number 22
[792337.271177] usb 4-2: USB disconnect, device number 67
[792337.483234] usb 3-2.4: USB disconnect, device number 23
[792347.654727] usb 3-2: new high-speed USB device number 27 using xhci_hcd
[792347.801104] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[792347.801121] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[792347.801129] usb 3-2: Product: USB2.0 Hub
[792347.801136] usb 3-2: Manufacturer: GenesysLogic
[792347.853396] hub 3-2:1.0: USB hub found
[792347.854630] hub 3-2:1.0: 4 ports detected
[792347.915533] usb 4-2: new SuperSpeed USB device number 68 using xhci_hcd
[792347.930963] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[792347.930972] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[792347.930976] usb 4-2: Product: USB3.0 Hub
[792347.930979] usb 4-2: Manufacturer: GenesysLogic
[792347.963975] hub 4-2:1.0: USB hub found
[792347.964267] hub 4-2:1.0: 4 ports detected
[792348.204454] usb 3-2.2: new full-speed USB device number 28 using xhci_hcd
[792348.304430] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[792348.304442] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[792348.304448] usb 3-2.2: Product: USB Receiver
[792348.304452] usb 3-2.2: Manufacturer: Logitech
[792348.447019] logitech-djreceiver 0003:046D:C52B.02D8: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[792348.564278] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02D8/0003:046D:4090.02D9/input/input555
[792348.564577] logitech-hidpp-device 0003:046D:4090.02D9: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[792348.577948] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02D8/0003:046D:405E.02DA/input/input556
[792348.621085] usb 3-2.4: new full-speed USB device number 29 using xhci_hcd
[792348.714697] logitech-hidpp-device 0003:046D:405E.02DA: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[792348.725450] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[792348.725459] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[792348.725463] usb 3-2.4: Product: Ducky One 3 TKL RGB
[792348.725466] usb 3-2.4: Manufacturer: Ducky
[792348.725469] usb 3-2.4: SerialNumber: DK-V1.04-201102
[792348.727704] logitech-hidpp-device 0003:046D:405E.02DA: HID++ 4.5 device connected.
[792348.949731] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.02DB/input/input557
[792349.001531] hid-generic 0003:3233:8311.02DB: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[792349.008725] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.02DC/input/input558
[792349.198019] hid-generic 0003:3233:8311.02DC: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[792349.204730] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.02DD/input/input559
[792349.204936] hid-generic 0003:3233:8311.02DD: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[792349.212689] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.02DE/input/input560
[792349.264915] hid-generic 0003:3233:8311.02DE: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[792349.271698] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.02DF/input/input561
[792349.328004] hid-generic 0003:3233:8311.02DF: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[792349.527746] usb 3-2.1: new full-speed USB device number 30 using xhci_hcd
[792349.627530] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[792349.627538] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[792349.627543] usb 3-2.1: Product: USB Audio Device
[792349.627546] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[792349.995689] cmedia_hs100b 0003:0D8C:0014.02E0: Fixing CMedia HS-100B report descriptor
[792349.995801] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.02E0/input/input562
[792350.048005] cmedia_hs100b 0003:0D8C:0014.02E0: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[792436.626157] usb 3-2: USB disconnect, device number 27
[792436.626165] usb 3-2.1: USB disconnect, device number 30
[792436.722080] usb 3-2.2: USB disconnect, device number 28
[792436.954449] usb 4-2: USB disconnect, device number 68
[792437.138218] usb 3-2.4: USB disconnect, device number 29
[792506.671546] usb 3-2: new high-speed USB device number 31 using xhci_hcd
[792506.820704] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[792506.820713] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[792506.820717] usb 3-2: Product: USB2.0 Hub
[792506.820721] usb 3-2: Manufacturer: GenesysLogic
[792506.871573] hub 3-2:1.0: USB hub found
[792506.873088] hub 3-2:1.0: 4 ports detected
[792506.935071] usb 4-2: new SuperSpeed USB device number 69 using xhci_hcd
[792506.950594] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[792506.950602] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[792506.950607] usb 4-2: Product: USB3.0 Hub
[792506.950610] usb 4-2: Manufacturer: GenesysLogic
[792506.983631] hub 4-2:1.0: USB hub found
[792506.983918] hub 4-2:1.0: 4 ports detected
[792507.224933] usb 3-2.2: new full-speed USB device number 32 using xhci_hcd
[792507.334020] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[792507.334035] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[792507.334042] usb 3-2.2: Product: USB Receiver
[792507.334048] usb 3-2.2: Manufacturer: Logitech
[792507.465376] logitech-djreceiver 0003:046D:C52B.02E3: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[792507.583357] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02E3/0003:046D:4090.02E4/input/input563
[792507.583587] logitech-hidpp-device 0003:046D:4090.02E4: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[792507.593521] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02E3/0003:046D:405E.02E5/input/input564
[792507.637848] usb 3-2.4: new full-speed USB device number 33 using xhci_hcd
[792507.751060] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[792507.751069] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[792507.751074] usb 3-2.4: Product: Ducky One 3 TKL RGB
[792507.751077] usb 3-2.4: Manufacturer: Ducky
[792507.751080] usb 3-2.4: SerialNumber: DK-V1.04-201102
[792507.768080] logitech-hidpp-device 0003:046D:405E.02E5: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[792507.787314] logitech-hidpp-device 0003:046D:405E.02E5: HID++ 4.5 device connected.
[792507.968357] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.02E6/input/input565
[792508.021455] hid-generic 0003:3233:8311.02E6: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[792508.028340] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.02E7/input/input566
[792508.184641] hid-generic 0003:3233:8311.02E7: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[792508.191292] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.02E8/input/input567
[792508.191483] hid-generic 0003:3233:8311.02E8: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[792508.199353] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.02E9/input/input568
[792508.251269] hid-generic 0003:3233:8311.02E9: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[792508.258280] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.02EA/input/input569
[792508.311274] hid-generic 0003:3233:8311.02EA: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[792508.497724] usb 3-2.1: new full-speed USB device number 34 using xhci_hcd
[792508.594112] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[792508.594121] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[792508.594127] usb 3-2.1: Product: USB Audio Device
[792508.594131] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[792508.949240] cmedia_hs100b 0003:0D8C:0014.02EB: Fixing CMedia HS-100B report descriptor
[792508.949345] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.02EB/input/input570
[792509.001270] cmedia_hs100b 0003:0D8C:0014.02EB: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[792547.963742] usb 3-2: USB disconnect, device number 31
[792547.963756] usb 3-2.1: USB disconnect, device number 34
[792548.058494] usb 3-2.2: USB disconnect, device number 32
[792548.291104] usb 4-2: USB disconnect, device number 69
[792548.474326] usb 3-2.4: USB disconnect, device number 33
[793765.034315] usb 3-2: new high-speed USB device number 35 using xhci_hcd
[793765.177757] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[793765.177772] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[793765.177778] usb 3-2: Product: USB2.0 Hub
[793765.177784] usb 3-2: Manufacturer: GenesysLogic
[793765.240900] hub 3-2:1.0: USB hub found
[793765.242145] hub 3-2:1.0: 4 ports detected
[793765.303017] usb 4-2: new SuperSpeed USB device number 70 using xhci_hcd
[793765.317828] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[793765.317841] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[793765.317848] usb 4-2: Product: USB3.0 Hub
[793765.317853] usb 4-2: Manufacturer: GenesysLogic
[793765.335457] hub 4-2:1.0: USB hub found
[793765.335744] hub 4-2:1.0: 4 ports detected
[793765.597669] usb 3-2.2: new full-speed USB device number 36 using xhci_hcd
[793765.703937] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[793765.703949] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[793765.703954] usb 3-2.2: Product: USB Receiver
[793765.703958] usb 3-2.2: Manufacturer: Logitech
[793765.835111] logitech-djreceiver 0003:046D:C52B.02EE: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[793765.955335] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02EE/0003:046D:4090.02EF/input/input571
[793765.955742] logitech-hidpp-device 0003:046D:4090.02EF: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[793765.965538] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02EE/0003:046D:405E.02F0/input/input572
[793766.017656] usb 3-2.4: new full-speed USB device number 37 using xhci_hcd
[793766.084551] logitech-hidpp-device 0003:046D:405E.02F0: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[793766.123943] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[793766.123952] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[793766.123956] usb 3-2.4: Product: Ducky One 3 TKL RGB
[793766.123960] usb 3-2.4: Manufacturer: Ducky
[793766.123963] usb 3-2.4: SerialNumber: DK-V1.04-201102
[793766.336227] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.02F1/input/input573
[793766.391797] hid-generic 0003:3233:8311.02F1: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[793766.399305] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.02F2/input/input574
[793766.538038] hid-generic 0003:3233:8311.02F2: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[793766.545273] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.02F3/input/input575
[793766.545770] hid-generic 0003:3233:8311.02F3: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[793766.553462] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.02F4/input/input576
[793766.604983] hid-generic 0003:3233:8311.02F4: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[793766.612194] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.02F5/input/input577
[793766.664684] hid-generic 0003:3233:8311.02F5: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[793766.857599] usb 3-2.1: new full-speed USB device number 38 using xhci_hcd
[793766.958013] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[793766.958022] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[793766.958026] usb 3-2.1: Product: USB Audio Device
[793766.958030] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[793767.322166] cmedia_hs100b 0003:0D8C:0014.02F6: Fixing CMedia HS-100B report descriptor
[793767.322292] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.02F6/input/input578
[793767.378123] cmedia_hs100b 0003:0D8C:0014.02F6: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[793772.667764] logitech-hidpp-device 0003:046D:405E.02F0: HID++ 4.5 device connected.
[794182.220915] usb 3-2: USB disconnect, device number 35
[794182.220926] usb 3-2.1: USB disconnect, device number 38
[794182.327696] usb 3-2.2: USB disconnect, device number 36
[794182.560923] usb 4-2: USB disconnect, device number 70
[794182.775551] usb 3-2.4: USB disconnect, device number 37
[794240.094222] usb 3-2: new high-speed USB device number 39 using xhci_hcd
[794240.248288] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[794240.248297] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[794240.248302] usb 3-2: Product: USB2.0 Hub
[794240.248305] usb 3-2: Manufacturer: GenesysLogic
[794240.284450] hub 3-2:1.0: USB hub found
[794240.286058] hub 3-2:1.0: 4 ports detected
[794240.357691] usb 4-2: new SuperSpeed USB device number 71 using xhci_hcd
[794240.373689] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[794240.373700] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[794240.373704] usb 4-2: Product: USB3.0 Hub
[794240.373709] usb 4-2: Manufacturer: GenesysLogic
[794240.396220] hub 4-2:1.0: USB hub found
[794240.396506] hub 4-2:1.0: 4 ports detected
[794240.634220] usb 3-2.2: new full-speed USB device number 40 using xhci_hcd
[794240.733734] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[794240.733743] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[794240.733748] usb 3-2.2: Product: USB Receiver
[794240.733752] usb 3-2.2: Manufacturer: Logitech
[794240.879079] logitech-djreceiver 0003:046D:C52B.02F9: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[794240.994700] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02F9/0003:046D:4090.02FA/input/input579
[794240.994925] logitech-hidpp-device 0003:046D:4090.02FA: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[794241.004296] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.02F9/0003:046D:405E.02FB/input/input580
[794241.050890] usb 3-2.4: new full-speed USB device number 41 using xhci_hcd
[794241.141168] logitech-hidpp-device 0003:046D:405E.02FB: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[794241.150770] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[794241.150780] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[794241.150785] usb 3-2.4: Product: Ducky One 3 TKL RGB
[794241.150790] usb 3-2.4: Manufacturer: Ducky
[794241.150793] usb 3-2.4: SerialNumber: DK-V1.04-201102
[794241.381053] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.02FC/input/input581
[794241.434480] hid-generic 0003:3233:8311.02FC: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[794241.441051] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.02FD/input/input582
[794241.587740] hid-generic 0003:3233:8311.02FD: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[794241.595063] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.02FE/input/input583
[794241.595272] hid-generic 0003:3233:8311.02FE: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[794241.603003] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.02FF/input/input584
[794241.654388] hid-generic 0003:3233:8311.02FF: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[794241.661021] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0300/input/input585
[794241.714365] hid-generic 0003:3233:8311.0300: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[794241.878090] logitech-hidpp-device 0003:046D:405E.02FB: HID++ 4.5 device connected.
[794241.907552] usb 3-2.1: new full-speed USB device number 42 using xhci_hcd
[794242.002823] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[794242.002826] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[794242.002831] usb 3-2.1: Product: USB Audio Device
[794242.002835] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[794242.361994] cmedia_hs100b 0003:0D8C:0014.0301: Fixing CMedia HS-100B report descriptor
[794242.362125] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0301/input/input586
[794242.414428] cmedia_hs100b 0003:0D8C:0014.0301: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[794956.952906] usb 3-2: USB disconnect, device number 39
[794956.952915] usb 3-2.1: USB disconnect, device number 42
[794957.042474] usb 3-2.2: USB disconnect, device number 40
[794957.274191] usb 4-2: USB disconnect, device number 71
[794957.458276] usb 3-2.4: USB disconnect, device number 41
[795098.550922] usb 4-2: new SuperSpeed USB device number 72 using xhci_hcd
[795098.569102] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[795098.569109] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795098.569114] usb 4-2: Product: USB3.0 Hub
[795098.569118] usb 4-2: Manufacturer: GenesysLogic
[795098.589365] hub 4-2:1.0: USB hub found
[795098.589643] hub 4-2:1.0: 4 ports detected
[795098.680802] usb 3-2: new high-speed USB device number 43 using xhci_hcd
[795098.823957] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[795098.823968] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795098.823972] usb 3-2: Product: USB2.0 Hub
[795098.823976] usb 3-2: Manufacturer: GenesysLogic
[795098.877495] hub 3-2:1.0: USB hub found
[795098.878230] hub 3-2:1.0: 4 ports detected
[795099.220809] usb 3-2.2: new full-speed USB device number 44 using xhci_hcd
[795099.320924] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[795099.320934] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795099.320939] usb 3-2.2: Product: USB Receiver
[795099.320943] usb 3-2.2: Manufacturer: Logitech
[795099.440408] logitech-djreceiver 0003:046D:C52B.0304: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[795099.559100] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0304/0003:046D:4090.0305/input/input587
[795099.559283] logitech-hidpp-device 0003:046D:4090.0305: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[795099.569446] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0304/0003:046D:405E.0306/input/input588
[795099.610801] usb 3-2.4: new full-speed USB device number 45 using xhci_hcd
[795099.711954] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[795099.711964] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[795099.711969] usb 3-2.4: Product: Ducky One 3 TKL RGB
[795099.711973] usb 3-2.4: Manufacturer: Ducky
[795099.711977] usb 3-2.4: SerialNumber: DK-V1.04-201102
[795099.751126] logitech-hidpp-device 0003:046D:405E.0306: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[795099.765221] logitech-hidpp-device 0003:046D:405E.0306: HID++ 4.5 device connected.
[795099.942281] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0307/input/input589
[795099.994360] hid-generic 0003:3233:8311.0307: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[795100.001227] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0308/input/input590
[795100.144233] hid-generic 0003:3233:8311.0308: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[795100.151209] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0309/input/input591
[795100.151396] hid-generic 0003:3233:8311.0309: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[795100.159170] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.030A/input/input592
[795100.214306] hid-generic 0003:3233:8311.030A: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[795100.221206] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.030B/input/input593
[795100.274292] hid-generic 0003:3233:8311.030B: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[795100.464137] usb 3-2.1: new full-speed USB device number 46 using xhci_hcd
[795100.561006] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[795100.561015] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795100.561019] usb 3-2.1: Product: USB Audio Device
[795100.561023] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[795100.918185] cmedia_hs100b 0003:0D8C:0014.030C: Fixing CMedia HS-100B report descriptor
[795100.918315] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.030C/input/input594
[795100.971017] cmedia_hs100b 0003:0D8C:0014.030C: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[795184.707051] usb 3-2: USB disconnect, device number 43
[795184.707062] usb 3-2.1: USB disconnect, device number 46
[795184.804297] usb 3-2.2: USB disconnect, device number 44
[795185.037506] usb 4-2: USB disconnect, device number 72
[795185.252135] usb 3-2.4: USB disconnect, device number 45
[795245.090777] usb 3-2: new high-speed USB device number 47 using xhci_hcd
[795245.240862] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[795245.240872] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795245.240886] usb 3-2: Product: USB2.0 Hub
[795245.240890] usb 3-2: Manufacturer: GenesysLogic
[795245.289005] hub 3-2:1.0: USB hub found
[795245.290586] hub 3-2:1.0: 4 ports detected
[795245.352208] usb 4-2: new SuperSpeed USB device number 73 using xhci_hcd
[795245.366788] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[795245.366797] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795245.366801] usb 4-2: Product: USB3.0 Hub
[795245.366805] usb 4-2: Manufacturer: GenesysLogic
[795245.384723] hub 4-2:1.0: USB hub found
[795245.385001] hub 4-2:1.0: 4 ports detected
[795245.644121] usb 3-2.2: new full-speed USB device number 48 using xhci_hcd
[795245.744174] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[795245.744185] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795245.744190] usb 3-2.2: Product: USB Receiver
[795245.744194] usb 3-2.2: Manufacturer: Logitech
[795245.883686] logitech-djreceiver 0003:046D:C52B.030F: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[795246.001423] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.030F/0003:046D:4090.0310/input/input595
[795246.001636] logitech-hidpp-device 0003:046D:4090.0310: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[795246.012124] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.030F/0003:046D:405E.0311/input/input596
[795246.057636] usb 3-2.4: new full-speed USB device number 49 using xhci_hcd
[795246.157210] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[795246.157220] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[795246.157225] usb 3-2.4: Product: Ducky One 3 TKL RGB
[795246.157229] usb 3-2.4: Manufacturer: Ducky
[795246.157233] usb 3-2.4: SerialNumber: DK-V1.04-201102
[795246.178126] logitech-hidpp-device 0003:046D:405E.0311: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[795246.385502] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0312/input/input597
[795246.437993] hid-generic 0003:3233:8311.0312: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[795246.445507] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0313/input/input598
[795246.581164] hid-generic 0003:3233:8311.0313: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[795246.588472] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0314/input/input599
[795246.588867] hid-generic 0003:3233:8311.0314: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[795246.596479] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0315/input/input600
[795246.654413] hid-generic 0003:3233:8311.0315: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[795246.661488] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0316/input/input601
[795246.714410] hid-generic 0003:3233:8311.0316: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[795246.910775] usb 3-2.1: new full-speed USB device number 50 using xhci_hcd
[795247.010264] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[795247.010264] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795247.010268] usb 3-2.1: Product: USB Audio Device
[795247.010272] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[795247.380433] cmedia_hs100b 0003:0D8C:0014.0317: Fixing CMedia HS-100B report descriptor
[795247.380573] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0317/input/input602
[795247.434294] cmedia_hs100b 0003:0D8C:0014.0317: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[795277.800912] logitech-hidpp-device 0003:046D:405E.0311: HID++ 4.5 device connected.
[795296.520791] usb 3-2: USB disconnect, device number 47
[795296.520800] usb 3-2.1: USB disconnect, device number 50
[795296.620418] usb 3-2.2: USB disconnect, device number 48
[795296.854151] usb 4-2: USB disconnect, device number 73
[795297.004325] usb 3-2.4: USB disconnect, device number 49
[795359.474100] usb 3-2: new high-speed USB device number 51 using xhci_hcd
[795359.617016] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[795359.617026] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795359.617030] usb 3-2: Product: USB2.0 Hub
[795359.617034] usb 3-2: Manufacturer: GenesysLogic
[795359.666555] hub 3-2:1.0: USB hub found
[795359.668162] hub 3-2:1.0: 4 ports detected
[795359.729031] usb 4-2: new SuperSpeed USB device number 74 using xhci_hcd
[795359.748834] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[795359.748844] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795359.748849] usb 4-2: Product: USB3.0 Hub
[795359.748853] usb 4-2: Manufacturer: GenesysLogic
[795359.777522] hub 4-2:1.0: USB hub found
[795359.777814] hub 4-2:1.0: 4 ports detected
[795360.017446] usb 3-2.2: new full-speed USB device number 52 using xhci_hcd
[795360.116973] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[795360.116984] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795360.116989] usb 3-2.2: Product: USB Receiver
[795360.116993] usb 3-2.2: Manufacturer: Logitech
[795360.260459] logitech-djreceiver 0003:046D:C52B.031A: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[795360.377335] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.031A/0003:046D:4090.031B/input/input603
[795360.381442] logitech-hidpp-device 0003:046D:4090.031B: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[795360.391526] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.031A/0003:046D:405E.031C/input/input604
[795360.430830] usb 3-2.4: new full-speed USB device number 53 using xhci_hcd
[795360.530003] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[795360.530013] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[795360.530018] usb 3-2.4: Product: Ducky One 3 TKL RGB
[795360.530022] usb 3-2.4: Manufacturer: Ducky
[795360.530026] usb 3-2.4: SerialNumber: DK-V1.04-201102
[795360.564360] logitech-hidpp-device 0003:046D:405E.031C: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[795360.583275] logitech-hidpp-device 0003:046D:405E.031C: HID++ 4.5 device connected.
[795360.762348] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.031D/input/input605
[795360.817677] hid-generic 0003:3233:8311.031D: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[795360.824328] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.031E/input/input606
[795360.960994] hid-generic 0003:3233:8311.031E: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[795360.968329] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.031F/input/input607
[795360.968528] hid-generic 0003:3233:8311.031F: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[795360.976247] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0320/input/input608
[795361.027625] hid-generic 0003:3233:8311.0320: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[795361.034263] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0321/input/input609
[795361.087697] hid-generic 0003:3233:8311.0321: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[795361.284137] usb 3-2.1: new full-speed USB device number 54 using xhci_hcd
[795361.381073] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[795361.381082] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795361.381087] usb 3-2.1: Product: USB Audio Device
[795361.381091] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[795361.779341] cmedia_hs100b 0003:0D8C:0014.0322: Fixing CMedia HS-100B report descriptor
[795361.779540] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0322/input/input610
[795361.831169] cmedia_hs100b 0003:0D8C:0014.0322: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[795375.071036] usb 3-2: USB disconnect, device number 51
[795375.071046] usb 3-2.1: USB disconnect, device number 54
[795375.186538] usb 3-2.2: USB disconnect, device number 52
[795375.421835] usb 4-2: USB disconnect, device number 74
[795375.570593] usb 3-2.4: USB disconnect, device number 53
[795520.917423] usb 3-2: new high-speed USB device number 55 using xhci_hcd
[795521.059861] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[795521.059871] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795521.059877] usb 3-2: Product: USB2.0 Hub
[795521.059881] usb 3-2: Manufacturer: GenesysLogic
[795521.118950] hub 3-2:1.0: USB hub found
[795521.120290] hub 3-2:1.0: 4 ports detected
[795521.181474] usb 4-2: new SuperSpeed USB device number 75 using xhci_hcd
[795521.198601] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[795521.198611] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795521.198617] usb 4-2: Product: USB3.0 Hub
[795521.198620] usb 4-2: Manufacturer: GenesysLogic
[795521.230091] hub 4-2:1.0: USB hub found
[795521.230386] hub 4-2:1.0: 4 ports detected
[795521.470756] usb 3-2.2: new full-speed USB device number 56 using xhci_hcd
[795521.570524] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[795521.570534] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795521.570539] usb 3-2.2: Product: USB Receiver
[795521.570543] usb 3-2.2: Manufacturer: Logitech
[795521.712925] logitech-djreceiver 0003:046D:C52B.0325: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[795521.827778] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0325/0003:046D:4090.0326/input/input611
[795521.827953] logitech-hidpp-device 0003:046D:4090.0326: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[795521.841958] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0325/0003:046D:405E.0327/input/input612
[795521.884106] usb 3-2.4: new full-speed USB device number 57 using xhci_hcd
[795521.994448] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[795521.994458] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[795521.994463] usb 3-2.4: Product: Ducky One 3 TKL RGB
[795521.994467] usb 3-2.4: Manufacturer: Ducky
[795521.994471] usb 3-2.4: SerialNumber: DK-V1.04-201102
[795522.014458] logitech-hidpp-device 0003:046D:405E.0327: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[795522.214726] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0328/input/input613
[795522.270974] hid-generic 0003:3233:8311.0328: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[795522.277739] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0329/input/input614
[795522.434170] hid-generic 0003:3233:8311.0329: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[795522.440673] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.032A/input/input615
[795522.440871] hid-generic 0003:3233:8311.032A: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[795522.448663] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.032B/input/input616
[795522.500928] hid-generic 0003:3233:8311.032B: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[795522.507684] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.032C/input/input617
[795522.560929] hid-generic 0003:3233:8311.032C: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[795522.760754] usb 3-2.1: new full-speed USB device number 58 using xhci_hcd
[795522.867510] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[795522.867519] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[795522.867523] usb 3-2.1: Product: USB Audio Device
[795522.867527] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[795523.234687] cmedia_hs100b 0003:0D8C:0014.032D: Fixing CMedia HS-100B report descriptor
[795523.234820] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.032D/input/input618
[795523.287605] cmedia_hs100b 0003:0D8C:0014.032D: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[795648.213423] logitech-hidpp-device 0003:046D:405E.0327: HID++ 4.5 device connected.
[795927.674874] iwlwifi 0000:02:00.0 wlo1: entered promiscuous mode
[795928.040553] iwlwifi 0000:02:00.0 wlo1: left promiscuous mode
[796122.491093] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[796122.524510] JFS: nTxBlock = 8192, nTxLock = 65536
[796415.419877] usb 3-2: USB disconnect, device number 55
[796415.419886] usb 3-2.1: USB disconnect, device number 58
[796415.491622] usb 3-2.2: USB disconnect, device number 56
[796415.724991] usb 4-2: USB disconnect, device number 75
[796415.971586] usb 3-2.4: USB disconnect, device number 57
[796438.880666] usb 3-2: new high-speed USB device number 59 using xhci_hcd
[796439.026324] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[796439.026333] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[796439.026338] usb 3-2: Product: USB2.0 Hub
[796439.026342] usb 3-2: Manufacturer: GenesysLogic
[796439.078461] hub 3-2:1.0: USB hub found
[796439.080080] hub 3-2:1.0: 4 ports detected
[796439.141310] usb 4-2: new SuperSpeed USB device number 76 using xhci_hcd
[796439.156793] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[796439.156801] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[796439.156805] usb 4-2: Product: USB3.0 Hub
[796439.156809] usb 4-2: Manufacturer: GenesysLogic
[796439.189890] hub 4-2:1.0: USB hub found
[796439.190184] hub 4-2:1.0: 4 ports detected
[796439.440672] usb 3-2.2: new full-speed USB device number 60 using xhci_hcd
[796439.540263] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[796439.540274] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[796439.540280] usb 3-2.2: Product: USB Receiver
[796439.540284] usb 3-2.2: Manufacturer: Logitech
[796439.672614] logitech-djreceiver 0003:046D:C52B.0330: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[796439.789968] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0330/0003:046D:4090.0331/input/input619
[796439.790207] logitech-hidpp-device 0003:046D:4090.0331: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[796439.800276] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0330/0003:046D:405E.0332/input/input620
[796439.847328] usb 3-2.4: new full-speed USB device number 61 using xhci_hcd
[796439.950264] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[796439.950275] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[796439.950281] usb 3-2.4: Product: Ducky One 3 TKL RGB
[796439.950285] usb 3-2.4: Manufacturer: Ducky
[796439.950289] usb 3-2.4: SerialNumber: DK-V1.04-201102
[796439.961024] logitech-hidpp-device 0003:046D:405E.0332: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[796439.973536] logitech-hidpp-device 0003:046D:405E.0332: HID++ 4.5 device connected.
[796440.173588] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0333/input/input621
[796440.224355] hid-generic 0003:3233:8311.0333: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[796440.231591] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0334/input/input622
[796440.367705] hid-generic 0003:3233:8311.0334: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[796440.374608] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0335/input/input623
[796440.375028] hid-generic 0003:3233:8311.0335: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[796440.382604] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0336/input/input624
[796440.434309] hid-generic 0003:3233:8311.0336: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[796440.441718] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0337/input/input625
[796440.494311] hid-generic 0003:3233:8311.0337: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[796440.683995] usb 3-2.1: new full-speed USB device number 62 using xhci_hcd
[796440.784357] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[796440.784366] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[796440.784371] usb 3-2.1: Product: USB Audio Device
[796440.784375] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[796441.161522] cmedia_hs100b 0003:0D8C:0014.0338: Fixing CMedia HS-100B report descriptor
[796441.161653] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0338/input/input626
[796441.217492] cmedia_hs100b 0003:0D8C:0014.0338: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[796485.434387] usb 3-2: USB disconnect, device number 59
[796485.434396] usb 3-2.1: USB disconnect, device number 62
[796485.513363] usb 3-2.2: USB disconnect, device number 60
[796485.744039] usb 4-2: USB disconnect, device number 76
[796485.961604] usb 3-2.4: USB disconnect, device number 61
[796495.577334] usb 3-2: new high-speed USB device number 63 using xhci_hcd
[796495.720055] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[796495.720065] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[796495.720070] usb 3-2: Product: USB2.0 Hub
[796495.720074] usb 3-2: Manufacturer: GenesysLogic
[796495.754849] hub 3-2:1.0: USB hub found
[796495.756433] hub 3-2:1.0: 4 ports detected
[796495.827452] usb 4-2: new SuperSpeed USB device number 77 using xhci_hcd
[796495.843378] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[796495.843389] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[796495.843394] usb 4-2: Product: USB3.0 Hub
[796495.843399] usb 4-2: Manufacturer: GenesysLogic
[796495.866666] hub 4-2:1.0: USB hub found
[796495.866947] hub 4-2:1.0: 4 ports detected
[796496.107325] usb 3-2.2: new full-speed USB device number 64 using xhci_hcd
[796496.206990] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[796496.207001] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[796496.207006] usb 3-2.2: Product: USB Receiver
[796496.207010] usb 3-2.2: Manufacturer: Logitech
[796496.349478] logitech-djreceiver 0003:046D:C52B.033B: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[796496.464348] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.033B/0003:046D:4090.033C/input/input627
[796496.465383] logitech-hidpp-device 0003:046D:4090.033C: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[796496.474526] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.033B/0003:046D:405E.033D/input/input628
[796496.523997] usb 3-2.4: new full-speed USB device number 65 using xhci_hcd
[796496.620877] logitech-hidpp-device 0003:046D:405E.033D: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[796496.622995] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[796496.623004] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[796496.623008] usb 3-2.4: Product: Ducky One 3 TKL RGB
[796496.623012] usb 3-2.4: Manufacturer: Ducky
[796496.623016] usb 3-2.4: SerialNumber: DK-V1.04-201102
[796496.634281] logitech-hidpp-device 0003:046D:405E.033D: HID++ 4.5 device connected.
[796496.851316] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.033E/input/input629
[796496.904321] hid-generic 0003:3233:8311.033E: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[796496.914261] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.033F/input/input630
[796497.074176] hid-generic 0003:3233:8311.033F: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[796497.081304] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0340/input/input631
[796497.081497] hid-generic 0003:3233:8311.0340: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[796497.090870] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0341/input/input632
[796497.144271] hid-generic 0003:3233:8311.0341: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[796497.151291] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0342/input/input633
[796497.204263] hid-generic 0003:3233:8311.0342: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[796497.393994] usb 3-2.1: new full-speed USB device number 66 using xhci_hcd
[796497.504100] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[796497.504109] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[796497.504114] usb 3-2.1: Product: USB Audio Device
[796497.504118] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[796497.865339] cmedia_hs100b 0003:0D8C:0014.0343: Fixing CMedia HS-100B report descriptor
[796497.865539] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0343/input/input634
[796497.917623] cmedia_hs100b 0003:0D8C:0014.0343: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[796499.554166] usb 3-2: USB disconnect, device number 63
[796499.554175] usb 3-2.1: USB disconnect, device number 66
[796499.658904] usb 3-2.2: USB disconnect, device number 64
[796499.890718] usb 4-2: USB disconnect, device number 77
[796500.170721] usb 3-2.4: USB disconnect, device number 65
[796516.212200] wlo1: Connection to AP 2a:a4:3c:7d:01:00 lost
[796516.397518] wlo1: Connection to AP 00:00:00:00:00:00 lost
[796519.471315] wlo1: authenticate with 2a:a4:3c:7d:01:00 (local address=c8:5e:a9:67:32:e3)
[796519.472031] wlo1: send auth to 2a:a4:3c:7d:01:00 (try 1/3)
[796519.477100] wlo1: authenticated
[796519.477321] wlo1: associate with 2a:a4:3c:7d:01:00 (try 1/3)
[796519.481289] wlo1: RX AssocResp from 2a:a4:3c:7d:01:00 (capab=0x431 status=0 aid=2)
[796519.487129] wlo1: associated
[797402.380574] usb 3-2: new high-speed USB device number 67 using xhci_hcd
[797402.523078] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[797402.523088] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[797402.523093] usb 3-2: Product: USB2.0 Hub
[797402.523097] usb 3-2: Manufacturer: GenesysLogic
[797402.580614] hub 3-2:1.0: USB hub found
[797402.582212] hub 3-2:1.0: 4 ports detected
[797402.643066] usb 4-2: new SuperSpeed USB device number 78 using xhci_hcd
[797402.657366] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[797402.657375] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[797402.657380] usb 4-2: Product: USB3.0 Hub
[797402.657384] usb 4-2: Manufacturer: GenesysLogic
[797402.675551] hub 4-2:1.0: USB hub found
[797402.675847] hub 4-2:1.0: 4 ports detected
[797402.930579] usb 3-2.2: new full-speed USB device number 68 using xhci_hcd
[797403.030009] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[797403.030019] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[797403.030024] usb 3-2.2: Product: USB Receiver
[797403.030028] usb 3-2.2: Manufacturer: Logitech
[797403.174343] logitech-djreceiver 0003:046D:C52B.0346: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[797403.291379] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0346/0003:046D:4090.0347/input/input635
[797403.291542] logitech-hidpp-device 0003:046D:4090.0347: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[797403.301564] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0346/0003:046D:405E.0348/input/input636
[797403.347236] usb 3-2.4: new full-speed USB device number 69 using xhci_hcd
[797403.437610] logitech-hidpp-device 0003:046D:405E.0348: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[797403.449023] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[797403.449032] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[797403.449037] usb 3-2.4: Product: Ducky One 3 TKL RGB
[797403.449040] usb 3-2.4: Manufacturer: Ducky
[797403.449043] usb 3-2.4: SerialNumber: DK-V1.04-201102
[797403.676488] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0349/input/input637
[797403.728273] hid-generic 0003:3233:8311.0349: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[797403.735331] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.034A/input/input638
[797403.890782] hid-generic 0003:3233:8311.034A: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[797403.898323] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.034B/input/input639
[797403.898480] hid-generic 0003:3233:8311.034B: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[797403.906290] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.034C/input/input640
[797403.964036] hid-generic 0003:3233:8311.034C: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[797403.971289] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.034D/input/input641
[797404.024038] hid-generic 0003:3233:8311.034D: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[797404.217238] usb 3-2.1: new full-speed USB device number 70 using xhci_hcd
[797404.313118] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[797404.313128] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[797404.313133] usb 3-2.1: Product: USB Audio Device
[797404.313137] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[797404.695272] cmedia_hs100b 0003:0D8C:0014.034E: Fixing CMedia HS-100B report descriptor
[797404.695401] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.034E/input/input642
[797404.747417] cmedia_hs100b 0003:0D8C:0014.034E: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[797410.867879] logitech-hidpp-device 0003:046D:405E.0348: HID++ 4.5 device connected.
[797705.220863] usb 3-2: USB disconnect, device number 67
[797705.220870] usb 3-2.1: USB disconnect, device number 70
[797705.323350] usb 3-2.2: USB disconnect, device number 68
[797705.557253] usb 4-2: USB disconnect, device number 78
[797705.771103] usb 3-2.4: USB disconnect, device number 69
[798268.997150] usb 3-2: new high-speed USB device number 71 using xhci_hcd
[798269.139953] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[798269.139963] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[798269.139967] usb 3-2: Product: USB2.0 Hub
[798269.139971] usb 3-2: Manufacturer: GenesysLogic
[798269.176073] hub 3-2:1.0: USB hub found
[798269.177722] hub 3-2:1.0: 4 ports detected
[798269.247259] usb 4-2: new SuperSpeed USB device number 79 using xhci_hcd
[798269.263225] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[798269.263225] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[798269.263225] usb 4-2: Product: USB3.0 Hub
[798269.263228] usb 4-2: Manufacturer: GenesysLogic
[798269.287765] hub 4-2:1.0: USB hub found
[798269.288044] hub 4-2:1.0: 4 ports detected
[798269.527149] usb 3-2.2: new full-speed USB device number 72 using xhci_hcd
[798269.633152] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[798269.633152] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[798269.633156] usb 3-2.2: Product: USB Receiver
[798269.633160] usb 3-2.2: Manufacturer: Logitech
[798269.770500] logitech-djreceiver 0003:046D:C52B.0351: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[798269.887534] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0351/0003:046D:4090.0352/input/input643
[798269.887763] logitech-hidpp-device 0003:046D:4090.0352: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[798269.897722] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0351/0003:046D:405E.0353/input/input644
[798269.947137] usb 3-2.4: new full-speed USB device number 73 using xhci_hcd
[798270.034045] logitech-hidpp-device 0003:046D:405E.0353: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[798270.052176] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[798270.052186] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[798270.052190] usb 3-2.4: Product: Ducky One 3 TKL RGB
[798270.052194] usb 3-2.4: Manufacturer: Ducky
[798270.052198] usb 3-2.4: SerialNumber: DK-V1.04-201102
[798270.272472] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0354/input/input645
[798270.324057] hid-generic 0003:3233:8311.0354: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[798270.331449] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0355/input/input646
[798270.477368] hid-generic 0003:3233:8311.0355: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[798270.484456] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0356/input/input647
[798270.484652] hid-generic 0003:3233:8311.0356: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[798270.492424] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0357/input/input648
[798270.543997] hid-generic 0003:3233:8311.0357: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[798270.551458] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0358/input/input649
[798270.604088] hid-generic 0003:3233:8311.0358: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[798270.793828] usb 3-2.1: new full-speed USB device number 74 using xhci_hcd
[798270.890260] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[798270.890268] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[798270.890273] usb 3-2.1: Product: USB Audio Device
[798270.890277] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[798271.257460] cmedia_hs100b 0003:0D8C:0014.0359: Fixing CMedia HS-100B report descriptor
[798271.257596] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0359/input/input650
[798271.316212] cmedia_hs100b 0003:0D8C:0014.0359: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[798276.691965] logitech-hidpp-device 0003:046D:405E.0353: HID++ 4.5 device connected.
[798433.119072] usb 3-2: USB disconnect, device number 71
[798433.119082] usb 3-2.1: USB disconnect, device number 74
[798433.252777] usb 3-2.2: USB disconnect, device number 72
[798433.483849] usb 4-2: USB disconnect, device number 79
[798433.732567] usb 3-2.4: USB disconnect, device number 73
[799424.803701] usb 3-2: new high-speed USB device number 75 using xhci_hcd
[799424.947141] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[799424.947150] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799424.947154] usb 3-2: Product: USB2.0 Hub
[799424.947157] usb 3-2: Manufacturer: GenesysLogic
[799424.980913] hub 3-2:1.0: USB hub found
[799424.982279] hub 3-2:1.0: 4 ports detected
[799425.053833] usb 4-2: new SuperSpeed USB device number 80 using xhci_hcd
[799425.069843] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[799425.069853] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799425.069858] usb 4-2: Product: USB3.0 Hub
[799425.069862] usb 4-2: Manufacturer: GenesysLogic
[799425.092422] hub 4-2:1.0: USB hub found
[799425.092699] hub 4-2:1.0: 4 ports detected
[799425.330364] usb 3-2.2: new full-speed USB device number 76 using xhci_hcd
[799425.429952] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[799425.429962] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799425.429967] usb 3-2.2: Product: USB Receiver
[799425.429971] usb 3-2.2: Manufacturer: Logitech
[799425.574317] logitech-djreceiver 0003:046D:C52B.035C: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[799425.690319] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.035C/0003:046D:4090.035D/input/input651
[799425.690535] logitech-hidpp-device 0003:046D:4090.035D: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[799425.700504] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.035C/0003:046D:405E.035E/input/input652
[799425.747043] usb 3-2.4: new full-speed USB device number 77 using xhci_hcd
[799425.813860] usb 3-2.4: Device not responding to setup address.
[799425.847618] logitech-hidpp-device 0003:046D:405E.035E: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[799425.862236] logitech-hidpp-device 0003:046D:405E.035E: HID++ 4.5 device connected.
[799426.020452] usb 3-2.4: Device not responding to setup address.
[799426.223698] usb 3-2.4: device not accepting address 77, error -71
[799426.224062] usb 3-2.4: WARN: invalid context state for evaluate context command.
[799426.290373] usb 3-2.4: new full-speed USB device number 78 using xhci_hcd
[799426.363691] usb 3-2.4: Device not responding to setup address.
[799426.567117] usb 3-2.4: Device not responding to setup address.
[799426.770360] usb 3-2.4: device not accepting address 78, error -71
[799426.770827] usb 3-2.4: WARN: invalid context state for evaluate context command.
[799426.770891] usb 3-2-port4: attempt power cycle
[799427.347065] usb 3-2.4: new full-speed USB device number 79 using xhci_hcd
[799427.383112] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[799427.383121] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[799427.383126] usb 3-2.4: Product: Ducky One 3 TKL RGB
[799427.383130] usb 3-2.4: Manufacturer: Ducky
[799427.383134] usb 3-2.4: SerialNumber: DK-V1.04-201102
[799427.613400] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.035F/input/input653
[799427.663979] hid-generic 0003:3233:8311.035F: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[799427.671369] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0360/input/input654
[799427.803945] hid-generic 0003:3233:8311.0360: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[799427.811423] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0361/input/input655
[799427.811636] hid-generic 0003:3233:8311.0361: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[799427.819344] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0362/input/input656
[799427.870579] hid-generic 0003:3233:8311.0362: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[799427.878330] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0363/input/input657
[799427.930683] hid-generic 0003:3233:8311.0363: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[799428.120397] usb 3-2.1: new full-speed USB device number 80 using xhci_hcd
[799428.220179] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[799428.220189] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799428.220193] usb 3-2.1: Product: USB Audio Device
[799428.220198] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[799428.597333] cmedia_hs100b 0003:0D8C:0014.0364: Fixing CMedia HS-100B report descriptor
[799428.597471] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0364/input/input658
[799428.650566] cmedia_hs100b 0003:0D8C:0014.0364: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[799467.140371] usb 3-2: USB disconnect, device number 75
[799467.140381] usb 3-2.1: USB disconnect, device number 80
[799467.255980] usb 3-2.2: USB disconnect, device number 76
[799467.487079] usb 4-2: USB disconnect, device number 80
[799467.703867] usb 3-2.4: USB disconnect, device number 79
[799532.210492] usb 4-2: new SuperSpeed USB device number 81 using xhci_hcd
[799532.228649] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[799532.228657] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799532.228661] usb 4-2: Product: USB3.0 Hub
[799532.228665] usb 4-2: Manufacturer: GenesysLogic
[799532.252973] hub 4-2:1.0: USB hub found
[799532.253261] hub 4-2:1.0: 4 ports detected
[799532.340361] usb 3-2: new high-speed USB device number 81 using xhci_hcd
[799532.480259] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[799532.480269] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799532.480274] usb 3-2: Product: USB2.0 Hub
[799532.480278] usb 3-2: Manufacturer: GenesysLogic
[799532.541035] hub 3-2:1.0: USB hub found
[799532.541776] hub 3-2:1.0: 4 ports detected
[799532.883685] usb 3-2.2: new full-speed USB device number 82 using xhci_hcd
[799532.983476] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[799532.983485] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799532.983490] usb 3-2.2: Product: USB Receiver
[799532.983494] usb 3-2.2: Manufacturer: Logitech
[799533.102792] logitech-djreceiver 0003:046D:C52B.0367: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[799533.220474] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0367/0003:046D:4090.0368/input/input659
[799533.220657] logitech-hidpp-device 0003:046D:4090.0368: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[799533.231014] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0367/0003:046D:405E.0369/input/input660
[799533.273699] usb 3-2.4: new full-speed USB device number 83 using xhci_hcd
[799533.375493] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[799533.375500] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[799533.375505] usb 3-2.4: Product: Ducky One 3 TKL RGB
[799533.375509] usb 3-2.4: Manufacturer: Ducky
[799533.375512] usb 3-2.4: SerialNumber: DK-V1.04-201102
[799533.410714] logitech-hidpp-device 0003:046D:405E.0369: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[799533.428757] logitech-hidpp-device 0003:046D:405E.0369: HID++ 4.5 device connected.
[799533.604798] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.036A/input/input661
[799533.657326] hid-generic 0003:3233:8311.036A: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[799533.664796] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.036B/input/input662
[799533.810588] hid-generic 0003:3233:8311.036B: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[799533.817782] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.036C/input/input663
[799533.817990] hid-generic 0003:3233:8311.036C: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[799533.825796] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.036D/input/input664
[799533.877229] hid-generic 0003:3233:8311.036D: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[799533.883830] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.036E/input/input665
[799533.937227] hid-generic 0003:3233:8311.036E: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[799534.130369] usb 3-2.1: new full-speed USB device number 84 using xhci_hcd
[799534.226570] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[799534.226580] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799534.226585] usb 3-2.1: Product: USB Audio Device
[799534.226589] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[799534.597755] cmedia_hs100b 0003:0D8C:0014.036F: Fixing CMedia HS-100B report descriptor
[799534.597888] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.036F/input/input666
[799534.653874] cmedia_hs100b 0003:0D8C:0014.036F: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[799540.168060] usb 3-2: USB disconnect, device number 81
[799540.168069] usb 3-2.1: USB disconnect, device number 84
[799540.253408] usb 3-2.2: USB disconnect, device number 82
[799540.483722] usb 4-2: USB disconnect, device number 81
[799540.701532] usb 3-2.4: USB disconnect, device number 83
[799661.213819] usb 4-2: new SuperSpeed USB device number 82 using xhci_hcd
[799661.232335] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[799661.232344] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799661.232349] usb 4-2: Product: USB3.0 Hub
[799661.232354] usb 4-2: Manufacturer: GenesysLogic
[799661.255146] hub 4-2:1.0: USB hub found
[799661.255429] hub 4-2:1.0: 4 ports detected
[799661.343679] usb 3-2: new high-speed USB device number 85 using xhci_hcd
[799661.480246] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[799661.480255] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799661.480261] usb 3-2: Product: USB2.0 Hub
[799661.480265] usb 3-2: Manufacturer: GenesysLogic
[799661.543148] hub 3-2:1.0: USB hub found
[799661.544112] hub 3-2:1.0: 4 ports detected
[799661.887035] usb 3-2.2: new full-speed USB device number 86 using xhci_hcd
[799661.986679] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[799661.986690] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799661.986695] usb 3-2.2: Product: USB Receiver
[799661.986699] usb 3-2.2: Manufacturer: Logitech
[799662.106050] logitech-djreceiver 0003:046D:C52B.0372: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[799662.223046] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0372/0003:046D:4090.0373/input/input667
[799662.223212] logitech-hidpp-device 0003:046D:4090.0373: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[799662.231240] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0372/0003:046D:405E.0374/input/input668
[799662.277014] usb 3-2.4: new full-speed USB device number 87 using xhci_hcd
[799662.383703] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[799662.383714] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[799662.383719] usb 3-2.4: Product: Ducky One 3 TKL RGB
[799662.383723] usb 3-2.4: Manufacturer: Ducky
[799662.383727] usb 3-2.4: SerialNumber: DK-V1.04-201102
[799662.393711] logitech-hidpp-device 0003:046D:405E.0374: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[799662.410954] logitech-hidpp-device 0003:046D:405E.0374: HID++ 4.5 device connected.
[799662.608286] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0375/input/input669
[799662.660589] hid-generic 0003:3233:8311.0375: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[799662.668142] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0376/input/input670
[799662.807501] hid-generic 0003:3233:8311.0376: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[799662.815026] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0377/input/input671
[799662.815461] hid-generic 0003:3233:8311.0377: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[799662.822982] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0378/input/input672
[799662.877307] hid-generic 0003:3233:8311.0378: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[799662.883981] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0379/input/input673
[799662.940524] hid-generic 0003:3233:8311.0379: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[799663.130341] usb 3-2.1: new full-speed USB device number 88 using xhci_hcd
[799663.230778] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[799663.230788] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799663.230793] usb 3-2.1: Product: USB Audio Device
[799663.230797] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[799663.594935] cmedia_hs100b 0003:0D8C:0014.037A: Fixing CMedia HS-100B report descriptor
[799663.595071] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.037A/input/input674
[799663.647182] cmedia_hs100b 0003:0D8C:0014.037A: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[799675.487022] usb 3-2: USB disconnect, device number 85
[799675.487030] usb 3-2.1: USB disconnect, device number 88
[799675.592351] usb 3-2.2: USB disconnect, device number 86
[799675.823715] usb 4-2: USB disconnect, device number 82
[799676.103989] usb 3-2.4: USB disconnect, device number 87
[799814.056998] usb 3-2: new high-speed USB device number 89 using xhci_hcd
[799814.200327] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[799814.200343] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799814.200348] usb 3-2: Product: USB2.0 Hub
[799814.200352] usb 3-2: Manufacturer: GenesysLogic
[799814.259115] hub 3-2:1.0: USB hub found
[799814.260935] hub 3-2:1.0: 4 ports detected
[799814.322797] usb 4-2: new SuperSpeed USB device number 83 using xhci_hcd
[799814.337018] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[799814.337027] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799814.337033] usb 4-2: Product: USB3.0 Hub
[799814.337037] usb 4-2: Manufacturer: GenesysLogic
[799814.355425] hub 4-2:1.0: USB hub found
[799814.355723] hub 4-2:1.0: 4 ports detected
[799814.610336] usb 3-2.2: new full-speed USB device number 90 using xhci_hcd
[799814.713751] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[799814.713759] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799814.713764] usb 3-2.2: Product: USB Receiver
[799814.713768] usb 3-2.2: Manufacturer: Logitech
[799814.854061] logitech-djreceiver 0003:046D:C52B.037D: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[799814.971275] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.037D/0003:046D:4090.037E/input/input675
[799814.973027] logitech-hidpp-device 0003:046D:4090.037E: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[799814.981291] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.037D/0003:046D:405E.037F/input/input676
[799815.027000] usb 3-2.4: new full-speed USB device number 91 using xhci_hcd
[799815.126892] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[799815.126903] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[799815.126908] usb 3-2.4: Product: Ducky One 3 TKL RGB
[799815.126912] usb 3-2.4: Manufacturer: Ducky
[799815.126916] usb 3-2.4: SerialNumber: DK-V1.04-201102
[799815.157253] logitech-hidpp-device 0003:046D:405E.037F: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[799815.171048] logitech-hidpp-device 0003:046D:405E.037F: HID++ 4.5 device connected.
[799815.356178] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0380/input/input677
[799815.407350] hid-generic 0003:3233:8311.0380: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[799815.414093] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0381/input/input678
[799815.560491] hid-generic 0003:3233:8311.0381: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[799815.567102] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0382/input/input679
[799815.567560] hid-generic 0003:3233:8311.0382: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[799815.575047] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0383/input/input680
[799815.627248] hid-generic 0003:3233:8311.0383: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[799815.634077] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.0384/input/input681
[799815.687318] hid-generic 0003:3233:8311.0384: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[799815.886999] usb 3-2.1: new full-speed USB device number 92 using xhci_hcd
[799815.989817] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[799815.989826] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[799815.989830] usb 3-2.1: Product: USB Audio Device
[799815.989833] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[799816.370013] cmedia_hs100b 0003:0D8C:0014.0385: Fixing CMedia HS-100B report descriptor
[799816.370145] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0385/input/input682
[799816.420576] cmedia_hs100b 0003:0D8C:0014.0385: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[799843.140320] usb 3-2: USB disconnect, device number 89
[799843.140341] usb 3-2.1: USB disconnect, device number 92
[799843.253518] usb 3-2.2: USB disconnect, device number 90
[799843.487021] usb 4-2: USB disconnect, device number 83
[799843.734037] usb 3-2.4: USB disconnect, device number 91
[800104.506980] usb 3-2: new high-speed USB device number 93 using xhci_hcd
[800104.650234] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[800104.650242] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[800104.650247] usb 3-2: Product: USB2.0 Hub
[800104.650251] usb 3-2: Manufacturer: GenesysLogic
[800104.714451] hub 3-2:1.0: USB hub found
[800104.715995] hub 3-2:1.0: 4 ports detected
[800104.777726] usb 4-2: new SuperSpeed USB device number 84 using xhci_hcd
[800104.793287] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[800104.793296] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[800104.793301] usb 4-2: Product: USB3.0 Hub
[800104.793305] usb 4-2: Manufacturer: GenesysLogic
[800104.826226] hub 4-2:1.0: USB hub found
[800104.826521] hub 4-2:1.0: 4 ports detected
[800105.070315] usb 3-2.2: new full-speed USB device number 94 using xhci_hcd
[800105.183663] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[800105.183672] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[800105.183677] usb 3-2.2: Product: USB Receiver
[800105.183681] usb 3-2.2: Manufacturer: Logitech
[800105.308013] logitech-djreceiver 0003:046D:C52B.0388: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[800105.427098] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0388/0003:046D:4090.0389/input/input683
[800105.427289] logitech-hidpp-device 0003:046D:4090.0389: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[800105.438217] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0388/0003:046D:405E.038A/input/input684
[800105.480314] usb 3-2.4: new full-speed USB device number 95 using xhci_hcd
[800105.579681] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[800105.579691] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[800105.579696] usb 3-2.4: Product: Ducky One 3 TKL RGB
[800105.579700] usb 3-2.4: Manufacturer: Ducky
[800105.579704] usb 3-2.4: SerialNumber: DK-V1.04-201102
[800105.590440] logitech-hidpp-device 0003:046D:405E.038A: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[800105.605947] logitech-hidpp-device 0003:046D:405E.038A: HID++ 4.5 device connected.
[800105.811001] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.038B/input/input685
[800105.863936] hid-generic 0003:3233:8311.038B: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[800105.870987] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.038C/input/input686
[800106.033821] hid-generic 0003:3233:8311.038C: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[800106.040954] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.038D/input/input687
[800106.041140] hid-generic 0003:3233:8311.038D: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[800106.048908] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.038E/input/input688
[800106.103851] hid-generic 0003:3233:8311.038E: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[800106.110964] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.038F/input/input689
[800106.163806] hid-generic 0003:3233:8311.038F: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[800106.360305] usb 3-2.1: new full-speed USB device number 96 using xhci_hcd
[800106.456773] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[800106.456782] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[800106.456787] usb 3-2.1: Product: USB Audio Device
[800106.456791] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[800106.824937] cmedia_hs100b 0003:0D8C:0014.0390: Fixing CMedia HS-100B report descriptor
[800106.825068] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.0390/input/input690
[800106.877096] cmedia_hs100b 0003:0D8C:0014.0390: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[800269.845692] usb 3-2: USB disconnect, device number 93
[800269.845701] usb 3-2.1: USB disconnect, device number 96
[800269.974958] usb 3-2.2: USB disconnect, device number 94
[800270.080327] usb 4-2: USB disconnect, device number 84
[800270.423270] usb 3-2.4: USB disconnect, device number 95
[800282.563615] usb 3-2: new high-speed USB device number 97 using xhci_hcd
[800282.706901] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[800282.706910] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[800282.706915] usb 3-2: Product: USB2.0 Hub
[800282.706935] usb 3-2: Manufacturer: GenesysLogic
[800282.744471] hub 3-2:1.0: USB hub found
[800282.746031] hub 3-2:1.0: 4 ports detected
[800282.813731] usb 4-2: new SuperSpeed USB device number 85 using xhci_hcd
[800282.829770] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[800282.829780] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[800282.829784] usb 4-2: Product: USB3.0 Hub
[800282.829789] usb 4-2: Manufacturer: GenesysLogic
[800282.856537] hub 4-2:1.0: USB hub found
[800282.856836] hub 4-2:1.0: 4 ports detected
[800283.100284] usb 3-2.2: new full-speed USB device number 98 using xhci_hcd
[800283.199712] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[800283.199722] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[800283.199727] usb 3-2.2: Product: USB Receiver
[800283.199731] usb 3-2.2: Manufacturer: Logitech
[800283.338066] logitech-djreceiver 0003:046D:C52B.0393: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[800283.464474] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0393/0003:046D:4090.0394/input/input691
[800283.464682] logitech-hidpp-device 0003:046D:4090.0394: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[800283.474228] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.0393/0003:046D:405E.0395/input/input692
[800283.516956] usb 3-2.4: new full-speed USB device number 99 using xhci_hcd
[800283.587159] logitech-hidpp-device 0003:046D:405E.0395: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[800283.605971] logitech-hidpp-device 0003:046D:405E.0395: HID++ 4.5 device connected.
[800283.621735] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[800283.621745] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[800283.621750] usb 3-2.4: Product: Ducky One 3 TKL RGB
[800283.621754] usb 3-2.4: Manufacturer: Ducky
[800283.621758] usb 3-2.4: SerialNumber: DK-V1.04-201102
[800283.840004] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.0396/input/input693
[800283.891544] hid-generic 0003:3233:8311.0396: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[800283.899033] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.0397/input/input694
[800284.020523] hid-generic 0003:3233:8311.0397: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[800284.030029] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.0398/input/input695
[800284.030234] hid-generic 0003:3233:8311.0398: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[800284.042464] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.0399/input/input696
[800284.093836] hid-generic 0003:3233:8311.0399: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[800284.101023] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.039A/input/input697
[800284.154076] hid-generic 0003:3233:8311.039A: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[800284.363611] usb 3-2.1: new full-speed USB device number 100 using xhci_hcd
[800284.463802] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[800284.463812] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[800284.463817] usb 3-2.1: Product: USB Audio Device
[800284.463821] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[800284.824961] cmedia_hs100b 0003:0D8C:0014.039B: Fixing CMedia HS-100B report descriptor
[800284.825098] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.039B/input/input698
[800284.877285] cmedia_hs100b 0003:0D8C:0014.039B: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[800297.406151] usb 3-2: USB disconnect, device number 97
[800297.406175] usb 3-2.1: USB disconnect, device number 100
[800297.497253] usb 3-2.2: USB disconnect, device number 98
[800297.730434] usb 4-2: USB disconnect, device number 85
[800297.913851] usb 3-2.4: USB disconnect, device number 99
[803000.373355] usb 3-2: new high-speed USB device number 101 using xhci_hcd
[803000.519739] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[803000.519749] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[803000.519754] usb 3-2: Product: USB2.0 Hub
[803000.519758] usb 3-2: Manufacturer: GenesysLogic
[803000.580175] hub 3-2:1.0: USB hub found
[803000.581736] hub 3-2:1.0: 4 ports detected
[803000.643100] usb 4-2: new SuperSpeed USB device number 86 using xhci_hcd
[803000.656185] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[803000.656195] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[803000.656200] usb 4-2: Product: USB3.0 Hub
[803000.656204] usb 4-2: Manufacturer: GenesysLogic
[803000.675633] hub 4-2:1.0: USB hub found
[803000.675929] hub 4-2:1.0: 4 ports detected
[803000.936680] usb 3-2.2: new full-speed USB device number 102 using xhci_hcd
[803001.040024] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[803001.040034] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[803001.040038] usb 3-2.2: Product: USB Receiver
[803001.040042] usb 3-2.2: Manufacturer: Logitech
[803001.174623] logitech-djreceiver 0003:046D:C52B.039E: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[803001.292732] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.039E/0003:046D:4090.039F/input/input699
[803001.293125] logitech-hidpp-device 0003:046D:4090.039F: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[803001.301538] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.039E/0003:046D:405E.03A0/input/input700
[803001.346683] usb 3-2.4: new full-speed USB device number 103 using xhci_hcd
[803001.420303] logitech-hidpp-device 0003:046D:405E.03A0: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[803001.446062] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[803001.446073] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[803001.446078] usb 3-2.4: Product: Ducky One 3 TKL RGB
[803001.446082] usb 3-2.4: Manufacturer: Ducky
[803001.446085] usb 3-2.4: SerialNumber: DK-V1.04-201102
[803001.676381] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.03A1/input/input701
[803001.726963] hid-generic 0003:3233:8311.03A1: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[803001.734332] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.03A2/input/input702
[803001.876892] hid-generic 0003:3233:8311.03A2: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[803001.885336] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.03A3/input/input703
[803001.885542] hid-generic 0003:3233:8311.03A3: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[803001.893293] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.03A4/input/input704
[803001.946882] hid-generic 0003:3233:8311.03A4: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[803001.954335] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.03A5/input/input705
[803002.006877] hid-generic 0003:3233:8311.03A5: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[803002.200017] usb 3-2.1: new full-speed USB device number 104 using xhci_hcd
[803002.300100] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[803002.300110] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[803002.300114] usb 3-2.1: Product: USB Audio Device
[803002.300118] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[803002.661346] cmedia_hs100b 0003:0D8C:0014.03A6: Fixing CMedia HS-100B report descriptor
[803002.661594] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.03A6/input/input706
[803002.713571] cmedia_hs100b 0003:0D8C:0014.03A6: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[803008.891720] logitech-hidpp-device 0003:046D:405E.03A0: HID++ 4.5 device connected.
[803063.346676] usb 3-2: USB disconnect, device number 101
[803063.346685] usb 3-2.1: USB disconnect, device number 104
[803063.463119] usb 3-2.2: USB disconnect, device number 102
[803063.696708] usb 4-2: USB disconnect, device number 86
[803063.975198] usb 3-2.4: USB disconnect, device number 103
[804333.839876] usb 3-2: new high-speed USB device number 105 using xhci_hcd
[804333.985439] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[804333.985449] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[804333.985453] usb 3-2: Product: USB2.0 Hub
[804333.985457] usb 3-2: Manufacturer: GenesysLogic
[804334.046983] hub 3-2:1.0: USB hub found
[804334.048565] hub 3-2:1.0: 4 ports detected
[804334.110552] usb 4-2: new SuperSpeed USB device number 87 using xhci_hcd
[804334.126100] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[804334.126110] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[804334.126115] usb 4-2: Product: USB3.0 Hub
[804334.126119] usb 4-2: Manufacturer: GenesysLogic
[804334.159049] hub 4-2:1.0: USB hub found
[804334.159339] hub 4-2:1.0: 4 ports detected
[804334.399876] usb 3-2.2: new full-speed USB device number 106 using xhci_hcd
[804334.509458] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[804334.509465] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[804334.509470] usb 3-2.2: Product: USB Receiver
[804334.509473] usb 3-2.2: Manufacturer: Logitech
[804334.641977] logitech-djreceiver 0003:046D:C52B.03A9: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[804334.756846] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03A9/0003:046D:4090.03AA/input/input707
[804334.757080] logitech-hidpp-device 0003:046D:4090.03AA: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[804334.767004] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03A9/0003:046D:405E.03AB/input/input708
[804334.813208] usb 3-2.4: new full-speed USB device number 107 using xhci_hcd
[804334.913441] logitech-hidpp-device 0003:046D:405E.03AB: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[804334.917505] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[804334.917513] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[804334.917518] usb 3-2.4: Product: Ducky One 3 TKL RGB
[804334.917522] usb 3-2.4: Manufacturer: Ducky
[804334.917526] usb 3-2.4: SerialNumber: DK-V1.04-201102
[804335.143801] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.03AC/input/input709
[804335.196907] hid-generic 0003:3233:8311.03AC: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[804335.203812] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.03AD/input/input710
[804335.346809] hid-generic 0003:3233:8311.03AD: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[804335.353783] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.03AE/input/input711
[804335.354184] hid-generic 0003:3233:8311.03AE: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[804335.361794] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.03AF/input/input712
[804335.413470] hid-generic 0003:3233:8311.03AF: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[804335.420862] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.03B0/input/input713
[804335.473379] hid-generic 0003:3233:8311.03B0: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[804335.669888] usb 3-2.1: new full-speed USB device number 108 using xhci_hcd
[804335.765556] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[804335.765564] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[804335.765568] usb 3-2.1: Product: USB Audio Device
[804335.765572] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[804336.127753] cmedia_hs100b 0003:0D8C:0014.03B1: Fixing CMedia HS-100B report descriptor
[804336.127888] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.03B1/input/input714
[804336.180015] cmedia_hs100b 0003:0D8C:0014.03B1: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[804342.349289] logitech-hidpp-device 0003:046D:405E.03AB: HID++ 4.5 device connected.
[804401.775109] usb 3-2: USB disconnect, device number 105
[804401.775131] usb 3-2.1: USB disconnect, device number 108
[804401.859657] usb 3-2.2: USB disconnect, device number 106
[804402.093320] usb 4-2: USB disconnect, device number 87
[804402.275663] usb 3-2.4: USB disconnect, device number 107
[806469.902993] usb 3-2: new high-speed USB device number 109 using xhci_hcd
[806470.046172] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[806470.046180] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[806470.046185] usb 3-2: Product: USB2.0 Hub
[806470.046189] usb 3-2: Manufacturer: GenesysLogic
[806470.084998] hub 3-2:1.0: USB hub found
[806470.086543] hub 3-2:1.0: 4 ports detected
[806470.153108] usb 4-2: new SuperSpeed USB device number 88 using xhci_hcd
[806470.169115] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[806470.169125] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[806470.169130] usb 4-2: Product: USB3.0 Hub
[806470.169134] usb 4-2: Manufacturer: GenesysLogic
[806470.196347] hub 4-2:1.0: USB hub found
[806470.196620] hub 4-2:1.0: 4 ports detected
[806470.436333] usb 3-2.2: new full-speed USB device number 110 using xhci_hcd
[806470.536469] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[806470.536478] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[806470.536483] usb 3-2.2: Product: USB Receiver
[806470.536487] usb 3-2.2: Manufacturer: Logitech
[806470.680960] logitech-djreceiver 0003:046D:C52B.03B4: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[806470.797869] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03B4/0003:046D:4090.03B5/input/input715
[806470.798079] logitech-hidpp-device 0003:046D:4090.03B5: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[806470.808062] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03B4/0003:046D:405E.03B6/input/input716
[806470.856344] usb 3-2.4: new full-speed USB device number 111 using xhci_hcd
[806470.936616] logitech-hidpp-device 0003:046D:405E.03B6: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[806470.955479] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[806470.955490] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[806470.955495] usb 3-2.4: Product: Ducky One 3 TKL RGB
[806470.955499] usb 3-2.4: Manufacturer: Ducky
[806470.955502] usb 3-2.4: SerialNumber: DK-V1.04-201102
[806470.955738] logitech-hidpp-device 0003:046D:405E.03B6: HID++ 4.5 device connected.
[806471.179807] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.03B7/input/input717
[806471.233285] hid-generic 0003:3233:8311.03B7: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[806471.240792] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.03B8/input/input718
[806471.386551] hid-generic 0003:3233:8311.03B8: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[806471.393781] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.03B9/input/input719
[806471.393955] hid-generic 0003:3233:8311.03B9: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[806471.403937] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.03BA/input/input720
[806471.456516] hid-generic 0003:3233:8311.03BA: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[806471.463782] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.03BB/input/input721
[806471.516576] hid-generic 0003:3233:8311.03BB: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[806471.702993] usb 3-2.1: new full-speed USB device number 112 using xhci_hcd
[806471.799572] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[806471.799572] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[806471.799572] usb 3-2.1: Product: USB Audio Device
[806471.799575] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[806472.167759] cmedia_hs100b 0003:0D8C:0014.03BC: Fixing CMedia HS-100B report descriptor
[806472.167894] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.03BC/input/input722
[806472.219804] cmedia_hs100b 0003:0D8C:0014.03BC: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[807661.429556] usb 3-2: USB disconnect, device number 109
[807661.429565] usb 3-2.1: USB disconnect, device number 112
[807661.544428] usb 3-2.2: USB disconnect, device number 110
[807661.659581] usb 4-2: USB disconnect, device number 88
[807662.024252] usb 3-2.4: USB disconnect, device number 111
[807686.366210] usb 3-2: new high-speed USB device number 113 using xhci_hcd
[807686.509028] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[807686.509036] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[807686.509041] usb 3-2: Product: USB2.0 Hub
[807686.509045] usb 3-2: Manufacturer: GenesysLogic
[807686.576364] hub 3-2:1.0: USB hub found
[807686.577411] hub 3-2:1.0: 4 ports detected
[807686.636210] usb 4-2: new SuperSpeed USB device number 89 using xhci_hcd
[807686.652544] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[807686.652554] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[807686.652559] usb 4-2: Product: USB3.0 Hub
[807686.652563] usb 4-2: Manufacturer: GenesysLogic
[807686.682729] hub 4-2:1.0: USB hub found
[807686.683024] hub 4-2:1.0: 4 ports detected
[807686.922871] usb 3-2.2: new full-speed USB device number 114 using xhci_hcd
[807687.039090] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[807687.039101] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[807687.039106] usb 3-2.2: Product: USB Receiver
[807687.039110] usb 3-2.2: Manufacturer: Logitech
[807687.165442] logitech-djreceiver 0003:046D:C52B.03BF: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[807687.280457] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03BF/0003:046D:4090.03C0/input/input723
[807687.280637] logitech-hidpp-device 0003:046D:4090.03C0: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[807687.290614] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03BF/0003:046D:405E.03C1/input/input724
[807687.336333] usb 3-2.4: new full-speed USB device number 115 using xhci_hcd
[807687.402981] usb 3-2.4: Device not responding to setup address.
[807687.419834] logitech-hidpp-device 0003:046D:405E.03C1: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[807687.434384] logitech-hidpp-device 0003:046D:405E.03C1: HID++ 4.5 device connected.
[807687.606289] usb 3-2.4: Device not responding to setup address.
[807687.809536] usb 3-2.4: device not accepting address 115, error -71
[807687.809779] usb 3-2.4: WARN: invalid context state for evaluate context command.
[807687.876215] usb 3-2.4: new full-speed USB device number 116 using xhci_hcd
[807687.978146] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[807687.978157] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[807687.978162] usb 3-2.4: Product: Ducky One 3 TKL RGB
[807687.978166] usb 3-2.4: Manufacturer: Ducky
[807687.978170] usb 3-2.4: SerialNumber: DK-V1.04-201102
[807688.211509] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.03C2/input/input725
[807688.263099] hid-generic 0003:3233:8311.03C2: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[807688.270507] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.03C3/input/input726
[807688.416414] hid-generic 0003:3233:8311.03C3: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[807688.423614] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.03C4/input/input727
[807688.424366] hid-generic 0003:3233:8311.03C4: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[807688.431464] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.03C5/input/input728
[807688.483034] hid-generic 0003:3233:8311.03C5: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[807688.490421] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.03C6/input/input729
[807688.543695] hid-generic 0003:3233:8311.03C6: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[807688.746213] usb 3-2.1: new full-speed USB device number 117 using xhci_hcd
[807688.849230] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[807688.849240] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[807688.849245] usb 3-2.1: Product: USB Audio Device
[807688.849249] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[807689.227394] cmedia_hs100b 0003:0D8C:0014.03C7: Fixing CMedia HS-100B report descriptor
[807689.227530] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.03C7/input/input730
[807689.283116] cmedia_hs100b 0003:0D8C:0014.03C7: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[808306.907429] wlo1: deauthenticating from 2a:a4:3c:7d:01:00 by local choice (Reason: 3=DEAUTH_LEAVING)
[808307.875908] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:2 (0x1001)
[808307.875925] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:1 (0x1001)
[808307.875932] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:4 (0x1001)
[808307.875937] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:6 (0x1001)
[808307.875942] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:7 (0x1001)
[808307.875947] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:8 (0x1001)
[808307.875952] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:3 (0x1001)
[808307.875957] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:9 (0x1001)
[808307.875962] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:10 (0x1001)
[808307.875968] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade rev:0 func:12 (0x1001)
[808311.255125] wlo1: authenticate with 2a:a4:3c:7d:01:00 (local address=c8:5e:a9:67:32:e3)
[808311.255859] wlo1: send auth to 2a:a4:3c:7d:01:00 (try 1/3)
[808311.289834] wlo1: authenticated
[808311.292815] wlo1: associate with 2a:a4:3c:7d:01:00 (try 1/3)
[808311.296815] wlo1: RX AssocResp from 2a:a4:3c:7d:01:00 (capab=0x431 status=0 aid=2)
[808311.303240] wlo1: associated
[808822.959236] usb 3-2: USB disconnect, device number 113
[808822.959245] usb 3-2.1: USB disconnect, device number 117
[808823.073569] usb 3-2.2: USB disconnect, device number 114
[808823.312803] usb 4-2: USB disconnect, device number 89
[808823.617854] usb 3-2.4: USB disconnect, device number 116
[808915.660612] usb 3-2: new high-speed USB device number 118 using xhci_hcd
[808915.801873] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[808915.801882] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[808915.801886] usb 3-2: Product: USB2.0 Hub
[808915.801890] usb 3-2: Manufacturer: GenesysLogic
[808915.848655] hub 3-2:1.0: USB hub found
[808915.850259] hub 3-2:1.0: 4 ports detected
[808915.911104] usb 4-2: new SuperSpeed USB device number 90 using xhci_hcd
[808915.926323] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[808915.926332] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[808915.926337] usb 4-2: Product: USB3.0 Hub
[808915.926341] usb 4-2: Manufacturer: GenesysLogic
[808915.959687] hub 4-2:1.0: USB hub found
[808915.959977] hub 4-2:1.0: 4 ports detected
[808916.202753] usb 3-2.2: new full-speed USB device number 119 using xhci_hcd
[808916.303047] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[808916.303055] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[808916.303060] usb 3-2.2: Product: USB Receiver
[808916.303065] usb 3-2.2: Manufacturer: Logitech
[808916.442404] logitech-djreceiver 0003:046D:C52B.03CA: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[808916.557420] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03CA/0003:046D:4090.03CB/input/input731
[808916.557785] logitech-hidpp-device 0003:046D:4090.03CB: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[808916.567575] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03CA/0003:046D:405E.03CC/input/input732
[808916.612758] usb 3-2.4: new full-speed USB device number 120 using xhci_hcd
[808916.679558] usb 3-2.4: Device not responding to setup address.
[808916.736324] logitech-hidpp-device 0003:046D:405E.03CC: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[808916.889516] usb 3-2.4: Device not responding to setup address.
[808917.092750] usb 3-2.4: device not accepting address 120, error -71
[808917.093505] usb 3-2.4: WARN: invalid context state for evaluate context command.
[808917.159414] usb 3-2.4: new full-speed USB device number 121 using xhci_hcd
[808917.262076] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[808917.262084] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[808917.262088] usb 3-2.4: Product: Ducky One 3 TKL RGB
[808917.262092] usb 3-2.4: Manufacturer: Ducky
[808917.262096] usb 3-2.4: SerialNumber: DK-V1.04-201102
[808917.335339] logitech-hidpp-device 0003:046D:405E.03CC: HID++ 4.5 device connected.
[808917.487369] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.03CD/input/input733
[808917.542958] hid-generic 0003:3233:8311.03CD: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[808917.550349] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.03CE/input/input734
[808917.709623] hid-generic 0003:3233:8311.03CE: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[808917.716359] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.03CF/input/input735
[808917.716523] hid-generic 0003:3233:8311.03CF: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[808917.724319] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.03D0/input/input736
[808917.779585] hid-generic 0003:3233:8311.03D0: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[808917.786331] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.03D1/input/input737
[808917.842884] hid-generic 0003:3233:8311.03D1: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[808918.032750] usb 3-2.1: new full-speed USB device number 122 using xhci_hcd
[808918.129167] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[808918.129177] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[808918.129182] usb 3-2.1: Product: USB Audio Device
[808918.129186] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[808918.497327] cmedia_hs100b 0003:0D8C:0014.03D2: Fixing CMedia HS-100B report descriptor
[808918.497461] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.03D2/input/input738
[808918.549547] cmedia_hs100b 0003:0D8C:0014.03D2: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
[808938.702914] usb 3-2: USB disconnect, device number 118
[808938.702923] usb 3-2.1: USB disconnect, device number 122
[808938.792902] usb 3-2.2: USB disconnect, device number 119
[808939.026123] usb 4-2: USB disconnect, device number 90
[808939.272923] usb 3-2.4: USB disconnect, device number 121
[809502.329353] usb 3-2: new high-speed USB device number 123 using xhci_hcd
[809502.481710] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[809502.481720] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[809502.481725] usb 3-2: Product: USB2.0 Hub
[809502.481729] usb 3-2: Manufacturer: GenesysLogic
[809502.544465] hub 3-2:1.0: USB hub found
[809502.546107] hub 3-2:1.0: 4 ports detected
[809502.607205] usb 4-2: new SuperSpeed USB device number 91 using xhci_hcd
[809502.625420] usb 4-2: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
[809502.625441] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[809502.625441] usb 4-2: Product: USB3.0 Hub
[809502.625441] usb 4-2: Manufacturer: GenesysLogic
[809502.655734] hub 4-2:1.0: USB hub found
[809502.656042] hub 4-2:1.0: 4 ports detected
[809502.892707] usb 3-2.2: new full-speed USB device number 124 using xhci_hcd
[809502.992164] usb 3-2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[809502.992177] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[809502.992182] usb 3-2.2: Product: USB Receiver
[809502.992186] usb 3-2.2: Manufacturer: Logitech
[809503.138489] logitech-djreceiver 0003:046D:C52B.03D5: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-2.2/input2
[809503.255549] input: Logitech MX Anywhere 3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03D5/0003:046D:4090.03D6/input/input739
[809503.256601] logitech-hidpp-device 0003:046D:4090.03D6: input,hidraw1: USB HID v1.11 Mouse [Logitech MX Anywhere 3] on usb-0000:04:00.4-2.2/input2:1
[809503.265687] input: Logitech M720 Triathlon as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.2/3-2.2:1.2/0003:046D:C52B.03D5/0003:046D:405E.03D7/input/input740
[809503.309538] usb 3-2.4: new full-speed USB device number 125 using xhci_hcd
[809503.396447] logitech-hidpp-device 0003:046D:405E.03D7: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-0000:04:00.4-2.2/input2:2
[809503.407183] usb 3-2.4: New USB device found, idVendor=3233, idProduct=8311, bcdDevice= 0.00
[809503.407192] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[809503.407197] usb 3-2.4: Product: Ducky One 3 TKL RGB
[809503.407202] usb 3-2.4: Manufacturer: Ducky
[809503.407205] usb 3-2.4: SerialNumber: DK-V1.04-201102
[809503.413446] logitech-hidpp-device 0003:046D:405E.03D7: HID++ 4.5 device connected.
[809503.640684] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.0/0003:3233:8311.03D8/input/input741
[809503.692987] hid-generic 0003:3233:8311.03D8: input,hidraw3: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input0
[809503.700487] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.1/0003:3233:8311.03D9/input/input742
[809503.862880] hid-generic 0003:3233:8311.03D9: input,hidraw4: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input1
[809503.869497] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.2/0003:3233:8311.03DA/input/input743
[809503.869654] hid-generic 0003:3233:8311.03DA: input,hidraw5: USB HID v1.10 Mouse [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input2
[809503.877579] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.3/0003:3233:8311.03DB/input/input744
[809503.929623] hid-generic 0003:3233:8311.03DB: input,hidraw6: USB HID v1.10 Keyboard [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input3
[809503.936439] input: Ducky Ducky One 3 TKL RGB as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.4/3-2.4:1.4/0003:3233:8311.03DC/input/input745
[809503.989502] hid-generic 0003:3233:8311.03DC: input,hidraw7: USB HID v1.10 Device [Ducky Ducky One 3 TKL RGB] on usb-0000:04:00.4-2.4/input4
[809504.186021] usb 3-2.1: new full-speed USB device number 126 using xhci_hcd
[809504.289227] usb 3-2.1: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= 1.00
[809504.289235] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[809504.289240] usb 3-2.1: Product: USB Audio Device
[809504.289244] usb 3-2.1: Manufacturer: C-Media Electronics Inc.
[809504.653427] cmedia_hs100b 0003:0D8C:0014.03DD: Fixing CMedia HS-100B report descriptor
[809504.653559] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2.1/3-2.1:1.3/0003:0D8C:0014.03DD/input/input746
[809504.706175] cmedia_hs100b 0003:0D8C:0014.03DD: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:04:00.4-2.1/input3
lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 003: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 003 Device 025: ID 1a40:0801 Terminus Technology Inc. USB 2.0 Hub
Bus 003 Device 026: ID 2d79:0004 ę·±å³ä¹å¾ē LDR2002
Bus 003 Device 123: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 124: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 003 Device 125: ID 3233:8311 Ducky Ducky One 3 TKL RGB
Bus 003 Device 126: ID 0d8c:0014 C-Media Electronics, Inc. Audio Adapter (Unitek Y-247A)
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 091: ID 05e3:0612 Genesys Logic, Inc. Hub
Assistant edit: I beautified your posted output a bit for better readability
I beautified your above posted output a bit for better readability
sudo dmesg -w
for following the messages as they come in,
so you only get to see what happens after you plug in the device
or:
journalctl -f
for the same effect
Thanks, I didnāt realize how to do the beautification thing. Tried both commands, absolutely nothing happens. Different USB cables (one type c-c one a-c), different computers. Iād think it was broken if it wasnāt for working perfectly on Android. I just USB booted Debian to the same effect. Maybe this just wasnāt meant to be, Iāll have to find another cheap pot to try; Iād still be willing to try anything recommended, I just donāt know of anything further to even try.
Either you copy/paste the terminal output,
highlight it, all of it, if it not already is,
and click the </> button in the top row of the edit window
or you put three backticks ā ```
in one separate line before and after the whole output
then it looks very much like the terminal output that you saw
To be perfectly clear:
you open a terminal,
type:
journalctl -f
hit Enter
and then you plug in/unplug your device - to see, in that terminal, what the system sees happening while you do that
same for
sudo dmesg -w
Absolutely. Thanks for clarity, but yeah, tried both just to be thorough.
⦠if the system, for whatever reason, sees nothing ⦠it wonāt/canāt do anything
It canāt respond to ⦠nothing happening (from itās perspective).
It looks like one of your devices may be causing interference
The message repeats over and over and againā¦
Working with Andriod
obviously it is not working with a generic Linux kernel.
Yeah, I wish that was it! I have a USB switch on that computer that I switch back and forth between another computer; what youāre seeing is normal behavior. Probably should just close this thread. I figured maybe I was doing something wrong. Something that just happens to work on the ancient kernels of Android, but seems that there is some misbehavior in the case of this pot. Iāll try again with another brand if I can find one cheap enough. Thanks for all the replies.
As a side note, if someone wants to hack on it to find out whatās going on, PM me and Iāll to ship it to you gratis (sorry US only). You can keep it, either way.
TL4 edit - do not ever post your email address - use PM instead.
Thread closed as per OPās request. (Hope you find something suitable! And it can be re-opened if you wish).
