USB Ports and Bluetooth randomly do not turn on/activate on boot
Hello, I am encountering a frustrating issue where sometime (more often than not) at boot my usb 2.0 ports and bluetooth card don’t activate on boot. Like no power is going into the mouse, and unable to reactivate bluetooth with the toggle in the system settings, as if there is no bluetooth installed in the computer. Sometimes it fixes itself if I restart, but randomly both stop working sometimes when turning on the computer. Ive encountered this issue on both kernel 6.6 and 6.8
Ive noticed the USB ports turn off (by observing the mouse’s light) only when linux itself starts booting up. Whenever I boot into bios instead of linux, the usb ports work fine every time.
So from my best guess this is an issue with the linux kernel with my hardware, is there a grub boot command that can guarantee the usb ports and bluetooth will turn on when manjaro boots up?
Broken boot:
  Kernel: 6.8.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.8-x86_64
    root=UUID=16a5b737-4ccf-47f6-bd98-93a3431cce43 rw rootflags=subvol=@ quiet
    splash udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: ASRock model: B650M Pro RS WiFi serial: N/A
    uuid: 3e006b9c-db03-0000-0000-000000000000 UEFI: American Megatrends LLC.
    v: 2.08 date: 03/01/2024
  System RAM: total: 32 GiB available: 30.48 GiB used: 2.25 GiB (7.4%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 6000 MT/s actual: 5200 MT/s volts:
    curr: 1.1 min: 1.1 max: 1.1 width (bits): data: 64 total: 64
    manufacturer: N/A part-no: UD5-6000 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Message: No PCI Slot data found.
  Info: model: AMD Ryzen 5 7600 socket: AM5 bits: 64 type: MT MCP arch: Zen 4
    gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 400 min/max: 400/5170 base/boost: 3800/5150 scaling:
    driver: amd-pstate-epp governor: powersave volts: 1.3 V ext-clock: 100 MHz
    cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
    10: 400 11: 400 12: 400 bogomips: 91067
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
    gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv
    lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes
    vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1
    xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
  Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
    Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:747e class-ID: 0300
  Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-2
    bus-ID: 10:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 43.0 C
  Display: server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
    s-diag: 1165mm (45.88")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Beyond TV serial: <filter>
    built: 2020 res: 3840x2160 hz: 60 dpi: 81 gamma: 1.2 chroma: red: x: 0.678
    y: 0.310 green: x: 0.271 y: 0.659 blue: x: 0.153 y: 0.055 white: x: 0.314
    y: 0.329 size: 1209x680mm (47.6x26.77") diag: 1387mm (54.6") ratio: 16:9
    modes: 3840x2160, 4096x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1600x900, 1280x1024, 1440x900, 1280x960, 1280x800, 1280x720,
    1024x768, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93 6: parse_edid:
    unhandled CEA mode 118
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
    drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 17.0.6 DRM 3.57 6.8.7-1-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 24.0.6-manjaro1.1
    device-ID: 1002:747e surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 24.0.6-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
  Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30
    class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1
    chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.8.7-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.5 status: n/a (root, process) with:
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0
    chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
  IF: enp8s0 state: down mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 0e8d:0616
  Local Storage: total: 7.36 TiB used: 5.08 TiB (69.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD FX900 Pro 4TB
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3.A.J.CR temp: 40.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 91 hrs cycles: 109
    read-units: 5,981,513 [3.06 TB] written-units: 7,625,524 [3.90 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 4TB
    family: based SSDs size: 3.64 TiB block-size: physical: 512 B logical: 512 B
    type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 sata: 3.2
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0209 drive-rev: RVT04B6Q
    temp: 24 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 271d 9h cycles: 1783
    written: 27.15 TiB
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BU40N rev: A101
    dev-links: cdrom
  ID-1: / raw-size: 3.73 TiB size: 3.73 TiB (100.00%) used: 1.75 TiB (47.1%)
    fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 16a5b737-4ccf-47f6-bd98-93a3431cce43
    used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 5A4A-F91D
  ID-3: /home raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
    used: 1.75 TiB (47.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 16a5b737-4ccf-47f6-bd98-93a3431cce43
  ID-4: /mnt/sda1 raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    used: 3.33 TiB (91.5%) fs: btrfs block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: 4TB SATA uuid: 9abeced5-7707-44b8-8e84-4a5242acb8b6
  ID-5: /swap raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
  ID-6: /var/cache raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
  ID-7: /var/log raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 16.1 MiB (3.1%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-4:2 info: Logitech Media Keyboard K200 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c31d class-ID: 0300
  Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.3:5 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3000 class-ID: 0301
  Device-2: 1-8:4 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Device-1: 2-6:2 info: JMicron / USA JMS578 SATA 6Gb/s type: mass storage
    driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 152d:0578 class-ID: 0806
    serial: <filter>
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 7-1:2 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Hub-9: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 47.2 C mobo: 32.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 43.0 C mem: 57.0 C fan: 5 watts: 11.00
    device: amdgpu temp: 44.0 C
  Packages: pm: pacman pkgs: 1425 libs: 434 tools: pamac
    1: https://coresite.mm.fcix.net/manjaro/unstable/$repo/$arch
    2: https://manjaro.kurdy.org/unstable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
    4: https://mirrors.ucr.ac.cr/manjaro/unstable/$repo/$arch
    5: https://manjaro.ynh.ovh/unstable/$repo/$arch
    6: https://ftpmirror1.infania.net/mirror/manjaro/unstable/$repo/$arch
    7: http://manjaro.mirrors.theom.nz/manjaro/unstable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/unstable/$repo/$arch
Processes:
  CPU top: 5 of 383
  1: cpu: 40.2% command: baloo_file pid: 825 mem: 22.5 MiB (0.0%)
  2: cpu: 7.7% command: plasmashell pid: 922 mem: 334.5 MiB (1.0%)
  3: cpu: 3.2% command: org_kde_powerdevil pid: 1003 mem: 94.6 MiB (0.3%)
  4: cpu: 3.0% command: kwin_x11 pid: 876 mem: 207.8 MiB (0.6%)
  5: cpu: 2.6% command: konsole pid: 1450 mem: 153.0 MiB (0.4%)
  Memory top: 5 of 383
  1: mem: 334.5 MiB (1.0%) command: plasmashell pid: 922 cpu: 7.7%
  2: mem: 207.8 MiB (0.6%) command: kwin_x11 pid: 876 cpu: 3.0%
  3: mem: 153.0 MiB (0.4%) command: konsole pid: 1450 cpu: 2.6%
  4: mem: 142.9 MiB (0.4%) command: Xorg pid: 655 cpu: 2.0%
  5: mem: 115.3 MiB (0.3%) command: kded6 pid: 875 cpu: 1.0%
  Processes: 383 Power: uptime: 0m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
    default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
Working Boot
  System RAM: total: 32 GiB available: 30.48 GiB used: 2.07 GiB (6.8%)
  Speed (MHz): avg: 664 high: 3569 min/max: 400/5170 base/boost: 3800/5150
    scaling: driver: amd-pstate-epp governor: powersave volts: 1.3 V
    ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 3569 10: 400 11: 400 12: 400 bogomips: 91073
    affected
    bus-ID: 10:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 33.0 C
    class-ID: 0403
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3.A.J.CR temp: 25.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 91 hrs cycles: 107
    read-units: 5,923,453 [3.03 TB] written-units: 7,623,225 [3.90 TB]
    temp: 22 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 271d 9h cycles: 1781
    written: 27.15 TiB
    dev-links: cdrom
  ID-1: swap-1 type: file size: 512 MiB used: 45.1 MiB (8.8%) priority: -2
  Device-2: 1-7.4:6 info: Logitech Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Device-3: 1-8:4 info: MediaTek Wireless_Device type: bluetooth
    serial: <filter>
    serial: <filter>
  System Temperatures: cpu: 36.6 C mobo: 24.0 C
  GPU: device: amdgpu temp: 27.0 C mem: 43.0 C fan: 4 watts: 12.00
    device: amdgpu temp: 33.0 C
Processes:
  CPU top: 5 of 358
  1: cpu: 100% command: ps pid: 2149 mem: 4.23 MiB (0.0%)
  2: cpu: 20.4% command: baloo_file pid: 869 mem: 21.6 MiB (0.0%)
  3: cpu: 8.0% command: baloo_file_extractor pid: 1888 mem: 127.2 MiB (0.4%)
  4: cpu: 3.6% command: plasmashell pid: 985 mem: 325.4 MiB (1.0%)
  5: cpu: 2.8% command: konsole pid: 2045 mem: 161.1 MiB (0.5%)
  Memory top: 5 of 358
  1: mem: 325.4 MiB (1.0%) command: plasmashell pid: 985 cpu: 3.6%
  2: mem: 210.4 MiB (0.6%) command: kwin_x11 pid: 917 cpu: 2.3%
  3: mem: 161.1 MiB (0.5%) command: konsole pid: 2045 cpu: 2.8%
  4: mem: 151.3 MiB (0.4%) command: Xorg pid: 699 cpu: 2.3%
  5: mem: 127.2 MiB (0.4%) command: baloo_file_extractor pid: 1888 cpu: 8.0%
  Processes: 358 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    tool: systemctl
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
sudo inxi --verbosity=8 --filter --width
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Broken boot:
    affected
    class-ID: 0403
    scheme: GPT
    written: 27.15 TiB
    dev-links: cdrom
    serial: <filter>
    serial: <filter>
Processes:
  CPU top: 5 of 383
    tool: systemctl
Working Boot
    affected
    class-ID: 0403
    scheme: GPT
    written: 27.15 TiB
    dev-links: cdrom
    serial: <filter>
    serial: <filter>
Processes:
  CPU top: 5 of 358
    tool: systemctl
Thank you for responding, Ive added the inxi results. Please let me know what you see.
Hi andreas85,
I don’t mean to pry, but have you had a chance to look at the terminal output? Is there another terminal output you need?
From the inxi output, your USB devices are detected whether working or not. I suggest you might have an issue due to an intermittant or loose cable, or perhaps low quality hub.
That’s my only guess. Cheers.
Speculation:
When entering the bios there is more time for the hardware to get initialized properly.
If fastboot is enabled, disable it to check if this makes a difference.
Hi Hanzel,
Thank you for the suggestion, but Ive already disabled fastboot, and Im still encountering the issue.
To clarify my earlier bios statement, when I boot and go into bios directly, the usb hub is detected and powers on every time (The mouse light is on and detected) However, sometimes when exiting from the bios and booting into linux the usb hub turns off/deactivates (power turns off in the mouse/no power is going to the usb ports)
So far the only solution is to reboot the computer until the usb ports and bluetooth work correctly. Sometimes I turn on the computer and it works the first try. Sometimes I have to reboot once, twice, or even three times before it works. I don’t see a pattern, my only theory is something do to with the linux itself/software issue. Like I need to find a grub command line variable or some other linux related tweak to guarantee it working every boot.
hi soundofthunder,
Thank you for the suggestion I didn’t notices loose cables. Also the bluetooth itself is integrated into the wifi card, and if the Bluetooth is down, so is the usb ports despite being two completely different devices. I believe it is a software issue.
Interestingly I don’t have any problems with the wifi, despite bluetooth also coming from the wifi card.
Have you tried other kernels? 6.1 perhaps?
Check that you have the latest stable BIOS:
I notice there is v2.02 released on 2023/11/21 to ‘Optimize USB port compatibility’, and a later v2.10 released on 2024/3/26.
Note: Avoid using any of the Beta BIOS versions.
Kernel 6.1 is too old for my GPU, can’t use it. Before starting this thread I already tried a bios upgrade already in an attempt to fix this issue. I don’t remember which version of bios I had when I bought it, but I upgraded to 2.08 to try and fix it. Didn’t work.
Per your suggestion, I now tried 2.10, and for some reason my bios screen kept dropping in and out connection with the display, so I rolled back to 2.08 and that stopped.
Regardless, I doubt this is a bios issue, when Im in bios mode (2.08) the front usb hub and bluetooth is detected correctly every time (mouse light is on). Only issues start linux starts booting up. So for example, I turn on the computer and go directly to bios. The usb ports and bluetooth are working, mouse has power. Once I exit bios and start booting linux the mouse can suddenly turn off, and when logging in bluetooth is not on as well. Its always both devices at the same time when I encounter this issue. But this issue happens randomly and only during boot. If it boots correctly into Manjaro, the usb ports and bluetooth stay on for the duration of the session.
Your mainboard may be too new for Linux generally. Other possibilities include that you have a hardware fault (intermittant), or BIOS misconfiguration. It’s not uncommon to find issues with low-end mainboards, however, none of these conditions are something we can generally help with.
This is within the realm of the posible.
I notice that you’re using KDE Plasma 6.0.4. - this is not released to Stable yet, so I have to presume you’re using either the Unstable or Testing branch. If this is true, then you might be better served by indicating that in requests for help. Perhaps there is something useful to be found in recent Unstable Update Announcement threads.
Thank you for the suggestions, it is true I am on the unstable branch but I was also encountering this issue on the stable branch as well. And when I mention software, I believe there is a bug in the kernel or grub or boot sequence somewhere, not so much KDE, as when I monitor this issue the usb power loss happens well before the kde log in screen shows up.
My theory is I need a variable for the GRUB command line to make it ensure the devices stay on/activate during boot.
Well, KDE’s Plasma 6 does seem a major focus at the moment, but that’s not the exclusive focus - it’s possible for issues to be present with any part of the release, whether it be kernels, GRUB 2, or a host of other likely culprits.
However, the reason I suggest it’s likely not software related (in the vague sense) is based loosely on the observation that others are not experiencing a similar issue. Occam’s razor comes into play, where the simplest possibility becomes the most likely; the issue is specific to you.
That said, and because you’re on Unstable, it’s not possible (for me) to absolutely support either stance. Though, again, it does seem more likely to be hardware related, especially considering it works; albeit not all the time. Sorry I have nothing definitive. Cheers.
Thank you to everyone who posted so far, but I am still encountering this issue. If anyone else new or old has suggestions or a solutions, please let me know.
