USB Mixer: low microphone output
Hey everyone,
I’m having trouble with the mic output of my Behringer Xenyx 302usb audio mixer (shows up as “USB Audio CODEC”). I’ve been using it for years with Windows paired with a HyperX Cloud headset (the 1st gen analog one) and it works flawlessly.
However on Linux (had the same issue with Ubuntu) the microphone output level is unusably low. I’ve tried different settings in the pavucontrol tool with no success so far.
I hope someone can point me the right way. For now I’ll run the mic through onboard audio.
Here’s some system information for good measure:
~ >>> inxi -Fazy
  Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=25674c6a-7406-416e-a08d-f2217dcdef8e rw quiet apparmor=1
  Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
  Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 4023 date: 08/20/2018
  Topology: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen
  family: 17 (23) model-id: 1 stepping: 1 microcode: 8001137
  L2 cache: 4096 KiB
  bogomips: 95850
  Speed: 2392 MHz min/max: 1550/3000 MHz boost: enabled Core speeds (MHz):
  1: 1556 2: 1964 3: 1422 4: 1419 5: 3203 6: 3193 7: 1277 8: 1278 9: 3178
  10: 2830 11: 1420 12: 1423 13: 2334 14: 1894 15: 3193 16: 3193
  disabled, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 08:00.0
  chip ID: 1002:67df
  Display: wayland server: X.org 1.20.9 compositor: gnome-shell driver: amdgpu
  note: display driver n/a - try sudo/root display ID: 0
  resolution: <xdpyinfo missing>
  OpenGL: renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.38.0
  5.8.16-2-MANJARO LLVM 10.0.1)
  v: 4.6 Mesa 20.1.8 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 08:00.1
  chip ID: 1002:aaf0
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 0a:00.3 chip ID: 1022:1457
  Device-3: Texas Instruments PCM2902 Audio Codec type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1:2 chip ID: 08bb:2902
  Sound Server: ALSA v: k5.8.16-2-MANJARO
  vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 04:00.0
  chip ID: 10ec:8168
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 5.06 TiB used: 2.81 TiB (55.4%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 500GB size: 465.76 GiB
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: 2B7QCXE7 scheme: GPT
  ID-2: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 023 scheme: GPT
  ID-3: /dev/sdb type: USB vendor: Seagate model: Expansion Desk
  size: 3.64 TiB block size: physical: 4096 B logical: 512 B serial: <filter>
  rev: 9401 scheme: GPT
  ID-4: /dev/sdc type: USB vendor: Kingston model: DataTraveler 3.0
  size: 57.62 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  scheme: MBR
  ID-5: /dev/sdd type: USB vendor: Generic model: Flash Disk size: 1.91 GiB
  block size: physical: 512 B logical: 512 B serial: <filter> rev: 8.07
  scheme: MBR
  ID-1: / raw size: 180.00 GiB size: 176.17 GiB (97.88%)
  used: 17.82 GiB (10.1%) fs: ext4 dev: /dev/nvme0n1p2
  System Temperatures: cpu: 26.9 C mobo: N/A gpu: amdgpu temp: 36 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 894
  Processes: 377 Uptime: 23m Memory: 31.36 GiB used: 3.17 GiB (10.1%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1285 pacman: 1274
  lib: 340 flatpak: 11 Shell: Zsh v: 5.8 running in: tilix inxi: 3.1.05
~ >>> pacmd list-cards
3 card(s) available.
	index: 0
	driver: <module-alsa-card.c>
	owner module: 6
	properties:
		alsa.card = "0"
		alsa.card_name = "HDA ATI HDMI"
		alsa.long_card_name = "HDA ATI HDMI at 0xfe860000 irq 58"
		device.bus_path = "pci-0000:08:00.1"
		sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card0"
		device.bus = "pci"
		device.vendor.id = "1002"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
		device.product.id = "aaf0"
		device.product.name = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]"
		device.string = "0"
		device.description = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	profiles:
		output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: unknown)
		off: Off (priority 0, available: unknown)
	active profile: <output:hdmi-stereo-extra3>
	sinks:
		alsa_output.pci-0000_08_00.1.hdmi-stereo-extra3/#0: Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 4)
	sources:
		alsa_output.pci-0000_08_00.1.hdmi-stereo-extra3.monitor/#0: Monitor of Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 4)
	ports:
		hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
			properties:
		hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
			properties:
		hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
			properties:
		hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: yes)
			properties:
				device.product.name = "W2261"
	index: 1
	owner module: 7
	properties:
		alsa.card = "2"
		alsa.card_name = "USB Audio CODEC"
		alsa.long_card_name = "Burr-Brown from TI USB Audio CODEC at usb-0000:09:00.3-1, full speed"
		alsa.driver_name = "snd_usb_audio"
		device.bus_path = "pci-0000:09:00.3-usb-0:1:1.0"
		sysfs.path = "/devices/pci0000:00/0000:00:07.1/0000:09:00.3/usb3/3-1/3-1:1.0/sound/card2"
		udev.id = "usb-Burr-Brown_from_TI_USB_Audio_CODEC-00"
		device.bus = "usb"
		device.vendor.id = "08bb"
		device.vendor.name = "Texas Instruments"
		device.product.id = "2902"
		device.product.name = "PCM2902 Audio Codec"
		device.serial = "Burr-Brown_from_TI_USB_Audio_CODEC"
		device.string = "2"
		device.description = "PCM2902 Audio Codec"
		device.icon_name = "audio-card-usb"
	profiles:
		input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
		input:iec958-stereo: Digital Stereo (IEC958) Input (priority 55, available: unknown)
		output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
		output:analog-stereo+input:iec958-stereo: Analog Stereo Output + Digital Stereo (IEC958) Input (priority 6555, available: unknown)
		output:iec958-stereo: Digital Stereo (IEC958) Output (priority 5500, available: unknown)
		output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5565, available: unknown)
		output:iec958-stereo+input:iec958-stereo: Digital Stereo Duplex (IEC958) (priority 5555, available: unknown)
	active profile: <output:iec958-stereo+input:iec958-stereo>
	sinks:
		alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.iec958-stereo/#3: PCM2902 Audio Codec Digital Stereo (IEC958)
	sources:
		alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.iec958-stereo.monitor/#4: Monitor of PCM2902 Audio Codec Digital Stereo (IEC958)
		alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.iec958-stereo/#5: PCM2902 Audio Codec Digital Stereo (IEC958)
	ports:
		analog-input: Analog Input (priority 10000, latency offset 0 usec, available: unknown)
			properties:
		iec958-stereo-input: Digital Input (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
			properties:
		analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
			properties:
		iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
			properties:
	index: 2
	owner module: 8
	properties:
		alsa.card = "1"
		alsa.card_name = "HD-Audio Generic"
		alsa.long_card_name = "HD-Audio Generic at 0xfe700000 irq 60"
		device.bus_path = "pci-0000:0a:00.3"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:0a:00.3/sound/card1"
		device.bus = "pci"
		device.vendor.id = "1022"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
		device.product.id = "1457"
		device.product.name = "Family 17h (Models 00h-0fh) HD Audio Controller"
		device.string = "1"
		device.description = "Family 17h (Models 00h-0fh) HD Audio Controller"
	profiles:
		input:analog-stereo: Analog Stereo Input (priority 65, available: no)
		output:analog-stereo: Analog Stereo Output (priority 6500, available: no)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: no)
		output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5565, available: no)
	active profile: <output:iec958-stereo>
	sinks:
		alsa_output.pci-0000_0a_00.3.iec958-stereo/#2: Family 17h (Models 00h-0fh) HD Audio Controller Digital Stereo (IEC958)
	sources:
		alsa_output.pci-0000_0a_00.3.iec958-stereo.monitor/#2: Monitor of Family 17h (Models 00h-0fh) HD Audio Controller Digital Stereo (IEC958)
	ports:
		analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: no)
			properties:
		analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
			properties:
		analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
			properties:
		analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: no)
			properties:
		analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
			properties:
			properties:
I believe you can increase the microphone input volume over 100% in other sound applications. You could try downloading the mate or cinnamon sound settings program that should let you increase the microphone volume. I hope this helps.
Thanks for your suggestions. I’ve already tried PulseEffects over the weekend and got some acceptable results. Sadly it’s just a software workaround. I was hoping for a proper fix.
It seems I’m going to have to go full Windows VM anyway. I’ll have to use my employers windows-only conferencing software and that won’t work with wine.
I assume the HyperX headset is connected to the 3.5mm jack sockets using a splitter cable
The headset appears to have an electret type microphone that requires some dc power from the microphone socket to work correctly (usually between 3.5v - 5v)
‘output level is unusably low’ would suggest that the microphone may not be getting power to the microphone when used in Linux
the only way to confirm this would be to use a multimeter to see if any dc voltage is present
the headset microphone may work better if it is plugged in to a microphone socket on the motherboard using the onboard audio
I suggest you try that to confirm the mic can work normally under Linux
there are battery power packs available that could power the microphone,
but it may be cheaper to get another USB device that can supply power to the microphone
or get a microphone with an XLR connection that can use the phantom power from the XLR socket
Update: I have contacted Behringer and we worked out that everything works as intended and Windows must be doing software amplification to boost up the microphone volume.
The chip used is a Cool Audio V2902. Apparently a clone of TI’s PCM2902. Either of those chips don’t offer input level control. So Windows must be emulating the feature via software. That is the part I didn’t realize.
@nikgnomic I measured the voltage on the audio jack and it’s ~4v as you expected. 15v on the XLR. A bot low for condenser mics. But this is not pro-grade audio interface anyway.
Anyway since Windows is using software to boost the signal, PulseEffects is the easiest solution for me.
