I am attempting to use an Alesis Vortex to play music. It works fine on the Windows side of my PC. In addition, I have an Alesis Qmini that works as expected on both Windows and Linux. But with the Vortex on Linux, in qpwgraph, I can only see outputs to it, not inputs from it. These are the only nodes for the Vortex:
amidi -l shows the following:
Dir Device Name
O hw:2,0,0 Vortex MIDI 1
So I can tell it’s probably an issue with ALSA or further up the chain. To my knowledge, the DIR column should say IO, not just O.
The relevant section of lsusb -v is as follows:
lsusb -v output
Bus 003 Device 007: ID 13b2:0079 Alesis Vortex
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 [unknown]
bDeviceSubClass 0 [unknown]
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x13b2 Alesis
idProduct 0x0079 Vortex
bcdDevice 2.00
iManufacturer 1 Alesis
iProduct 2 Vortex
iSerial 3 Ver01.20
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0065
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 0
iInterface 0
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 0x0009
bInCollection 1
baInterfaceNr(0) 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceSubClass 3 MIDI Streaming
iInterface 0
MIDIStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bcdADC 1.00
wTotalLength 0x003a
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (MIDI_IN_JACK)
bJackType 1 Embedded
bJackID 1
iJack 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (MIDI_OUT_JACK)
bJackType 2 External
bJackID 2
bNrInputPins 1
baSourceID( 0) 1
BaSourcePin( 0) 1
iJack 0
bLength 6
bDescriptorType 36
bJackID 3
iJack 0
bLength 9
bDescriptorType 36
bJackID 4
bNrInputPins 1
baSourceID( 0) 3
BaSourcePin( 0) 1
iJack 0
Endpoint Descriptor:
bLength 9
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bRefresh 0
bSynchAddress 0
MIDIStreaming Endpoint Descriptor:
bLength 5
bDescriptorType 37
bDescriptorSubtype 1 (Invalid)
bNumEmbMIDIJack 1
baAssocJackID( 0) 1
bLength 9
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bRefresh 0
bSynchAddress 0
bLength 5
bDescriptorType 37
bNumEmbMIDIJack 2
baAssocJackID( 0) 4
baAssocJackID( 1) 85
Device Status: 0x0000
(Bus Powered)
When I plug it into the computer, dmesg produces the following:
[ 1542.854107] usb 3-9.3: new full-speed USB device number 9 using xhci_hcd
[ 1542.962725] usb 3-9.3: New USB device found, idVendor=13b2, idProduct=0079, bcdDevice= 2.00
[ 1542.962738] usb 3-9.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1542.962745] usb 3-9.3: Product: Vortex
[ 1542.962749] usb 3-9.3: Manufacturer: Alesis
[ 1542.962752] usb 3-9.3: SerialNumber: Ver01.20
[ 1542.968372] usb 3-9.3: Quirk or no altest; falling back to MIDI 1.0
I’m not sure what else to look into or what else to try. I’ve tried using a newer kernel, but 6.11 has the same issue and 6.12 can’t even get to the login screen (which is a different issue entirely). Any help or pointers would be appreciated!
