My USB Microphone is not being detected by the system. I looked at some solution’s on this from and one thread suggested i install manjaro-pipewire but that dint do anything to fix the problem
i have looked at other thread as well but non of the solutions seem to be working
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=acf68866-ae11-4412-b818-3899f71da029 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: PC Specialist product: NH5xAx v: N/A
serial: <superuser required> Chassis: Notebook type: 10
Mobo: CLEVO model: NH5xAx serial: <superuser required> UEFI: Insyde
v: 1.07.07TPCS date: 06/03/2020
ID-1: BAT0 charge: 54.2 Wh (100.0%) condition: 54.2/62.1 Wh (87.2%)
volts: 12.4 min: 10.9 model: Notebook BAT type: Li-ion serial: <filter>
status: full
RAM: total: 15.58 GiB used: 5.17 GiB (33.2%)
RAM Report:
Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2619 high: 3583 min/max: 2200/3906 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2922 2: 3583
3: 2053 4: 2051 5: 2664 6: 3582 7: 2052 8: 2047 bogomips: 57516
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 07:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 5-4:2
chip-ID: 04f2:b685 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: nvidia gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 pos: right res: 1920x1080 hz: 144 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: CLEVO/KAPOK
bus-ID: 07:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: CLEVO/KAPOK
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JBL Quantum One type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:8 chip-ID: 0ecb:203a
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:7 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 2.29 TiB used: 408.51 GiB (17.5%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 model: 512GB PCS PCIe M.2 SSD
lanes: 4 type: SSD serial: <filter> rev: T0707A0L temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
used: 408.51 GiB (43.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: acf68866-ae11-4412-b818-3899f71da029
used: 596 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: C91D-FCC4
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-4: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-5: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 100 MiB fs: vfat label: N/A
uuid: 30A8-8F2A
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 476.23 GiB fs: ntfs label: N/A
uuid: F200AA4B00AA171F
ID-4: /dev/nvme1n1p4 maj-min: 259:7 size: 611 MiB fs: ntfs label: N/A
uuid: 9AE60CFCE60CDB01
ID-5: /dev/sda1 maj-min: 8:1 size: 931.5 GiB fs: ntfs label: HDD
uuid: 5C4682E84682C26E
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-1.1:4 info: ROYUAN 2.4G Wireless Device type: Keyboard
power: 100mA chip-ID: 006f:fd10 class-ID: 0301
Device-2: 1-1.2:6 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Device-3: 1-2:8 info: JBL Quantum One type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 0ecb:203a class-ID: 0300
serial: <filter>
Device-4: 1-7:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00a8
class-ID: ff00 serial: <filter>
Device-5: 1-10:7 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-1:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-4:2 info: Chicony USB2.0 Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b685
class-ID: 0e02
Hub-8: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 369 Uptime: 19m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1435 pacman: 1410 lib: 369
flatpak: 14 snap: 11 Shell: Zsh v: 5.8.1 running-in: gnome-terminal
inxi: 3.3.14
sound card info
Card #44
Driver: alsa
Owner Module: n/a
Properties:
device.enum.api = "udev"
device.api = "alsa"
media.class = "Audio/Device"
api.alsa.path = "hw:0"
api.alsa.card = "0"
api.alsa.card.name = "HDA NVidia"
api.alsa.card.longname = "HDA NVidia at 0xf4000000 irq 156"
device.plugged.usec = "6340159"
device.bus_path = "pci-0000:07:00.1"
device.sysfs.path = "/sys/devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0"
device.bus = "pci"
device.subsystem = "sound"
device.vendor.id = "4318"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "6891"
device.product.name = "TU116 High Definition Audio Controller"
device.name = "alsa_card.pci-0000_07_00.1"
device.description = "TU116 High Definition Audio Controller"
device.nick = "HDA NVidia"
device.icon_name = "audio-card-pci"
api.alsa.use-acp = "true"
api.acp.auto-port = "false"
factory.id = "14"
client.id = "31"
object.id = "43"
object.serial = "44"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xf4000000 irq 156"
device.string = "0"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 6, sources: 0, priority: 1, available: yes)
Active Profile: output:hdmi-stereo
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
device.product.name = "MSI MAG272C
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-surround-extra4, output:hdmi-surround71-extra4
hdmi-output-5: HDMI / DisplayPort 6 (type: HDMI, priority: 5400, latency offset: 0 usec, availability group: Legacy 6, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 6"
card.profile.port = "5"
Part of profile(s): output:hdmi-stereo-extra5, output:hdmi-surround-extra5, output:hdmi-surround71-extra5
Card #45
Driver: alsa
Owner Module: n/a
Properties:
device.api = "alsa"
api.alsa.path = "hw:1"
api.alsa.card = "1"
api.alsa.card.name = "HD-Audio Generic"
api.alsa.card.longname = "HD-Audio Generic at 0xf2500000 irq 158"
device.plugged.usec = "6370195"
device.bus_path = "pci-0000:09:00.4"
device.sysfs.path = "/sys/devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1"
device.bus = "pci"
device.vendor.id = "4130"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "5255"
device.product.name = "Starship/Matisse HD Audio Controller"
device.name = "alsa_card.pci-0000_09_00.4"
device.description = "Starship/Matisse HD Audio Controller"
device.nick = "HD-Audio Generic"
api.dbus.ReserveDevice1 = "Audio1"
factory.id = "14"
client.id = "31"
object.id = "44"
object.serial = "45"
object.path = "alsa:pcm:1"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xf2500000 irq 158"
device.string = "1"
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability group: Legacy 2, availability unknown)
Properties:
port.type = "mic"
analog-input-headset-mic: Headset Microphone (type: Headset, priority: 8800, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "headset"
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 4, availability unknown)
Properties:
port.type = "speaker"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "headphones"
Card #291
Driver: alsa
Owner Module: n/a
Properties:
device.api = "alsa"
api.alsa.path = "hw:2"
api.alsa.card = "2"
api.alsa.card.name = "JBL Quantum One"
api.alsa.card.longname = "JBL JBL Quantum One at usb-0000:02:00.0-2, full speed"
device.plugged.usec = "951492129"
device.bus_path = "pci-0000:02:00.0-usb-0:2:1.0"
device.sysfs.path = "/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-2/1-2:1.0/sound/card2"
device.bus-id = "usb-JBL_JBL_Quantum_One_20190706.1-00"
device.bus = "usb"
device.vendor.id = "3787"
device.vendor.name = "JBL"
device.product.id = "8250"
device.product.name = "JBL Quantum One"
device.serial = "JBL_JBL_Quantum_One_20190706.1"
device.name = "alsa_card.usb-JBL_JBL_Quantum_One_20190706.1-00"
device.description = "JBL Quantum One"
device.nick = "JBL Quantum One"
device.icon_name = "audio-card-usb"
api.dbus.ReserveDevice1 = "Audio2"
factory.id = "14"
client.id = "31"
object.id = "50"
object.serial = "291"
object.path = "alsa:pcm:2"
alsa.card = "2"
alsa.card_name = "JBL Quantum One"
alsa.long_card_name = "JBL JBL Quantum One at usb-0000:02:00.0-2, full speed"
alsa.driver_name = "snd_usb_audio"
device.string = "2"
Profiles:
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
pro-audio: Pro Audio (sinks: 2, sources: 1, priority: 1, available: yes)
Active Profile: output:iec958-stereo
Ports:
analog-output: Analog Output (type: Analog, priority: 9900, latency offset: 0 usec, availability unknown)
Properties:
port.type = "analog"
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
Part of profile(s): output:iec958-stereo
