I have a USB Blue Snowball. The mic works fine, the cable is good and it’s been tested in multiple USB ports.
It will show up in lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 0d8c:0005 C-Media Electronics, Inc. Blue Snowball
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 1058:25e1 Western Digital Technologies, Inc. My Passport (WD20NMVW)
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1b1c:1b2e Corsair Corsair Corsair Gaming M65 Pro RGB Mouse
Bus 001 Device 002: ID 0951:16d2 Kingston Technology HX-KB4BL1-US [HYPERX Alloy FPS Pro]
But not in Pulse or Alsamixer.
pacmd list-sources
* index: 0
driver: <module-alsa-card.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1030
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 0 KiB
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
monitor_of: 0
card: 1 <alsa_card.pci-0000_0b_00.4>
module: 7
properties:
device.description = "Monitor of Starship/Matisse HD Audio Controller Analog Stereo"
device.class = "monitor"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfc400000 irq 74"
device.bus_path = "pci-0000:0b:00.4"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1487"
device.product.name = "Starship/Matisse HD Audio Controller"
device.string = "1"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
pacmd list-sinks
1 sink(s) available.
* index: 0
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 18350 / 28% / -33.17 dB, front-right: 18350 / 28% / -33.17 dB
balance 0.00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
Stereo
used by: 0
linked by: 2
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC887-VD Analog"
alsa.id = "ALC887-VD Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
device.string = "front:1"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Starship/Matisse HD Audio Controller Analog Stereo"
ports:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: yes)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-lineout>
pulseaudio-ctl
pulseaudio-ctl v1.67
/usr/bin/pulseaudio-ctl {up,down,mute,mute-input,set,atmost,full-status} [n]
Where up and down adjust volume in ±5 % increments
Where up and down [n] adjust volume in ±n % increments
Where mute toggles the mute status on/off
Where mute-input toggles the input status on/off
Where set set the volume to [n] %
Where atmost only takes effect if current volume is higher than [n]
Where full-status prints volume level, sink and source mute state to stdout
Optionally, redefine an upper threshold in /home/leto/.config/pulseaudio-ctl/config
Volume level : 28 %
Is sink muted : no
Is source muted : no
Detected sink : 0
Detected source : 0
pacmd dump
### Configuration dump generated at Thu Apr 15 15:53:55 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_09_00.1" card_name="alsa_card.pci-0000_09_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_0b_00.4" card_name="alsa_card.pci-0000_0b_00.4" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0.0 xauthority=/home/leto/.Xauthority
load-module module-x11-xsmp display=:0.0 xauthority=/home/leto/.Xauthority session_manager=local/omega:@/tmp/.ICE-unix/928,unix/omega:/tmp/.ICE-unix/928
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_0b_00.4.analog-stereo 0x47ae
set-sink-mute alsa_output.pci-0000_0b_00.4.analog-stereo no
suspend-sink alsa_output.pci-0000_0b_00.4.analog-stereo yes
set-source-volume alsa_output.pci-0000_0b_00.4.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_0b_00.4.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_0b_00.4.analog-stereo.monitor yes
set-card-profile alsa_card.pci-0000_09_00.1 off
set-card-profile alsa_card.pci-0000_0b_00.4 output:analog-stereo
set-default-sink alsa_output.pci-0000_0b_00.4.analog-stereo
set-default-source alsa_output.pci-0000_0b_00.4.analog-stereo.monitor
### EOF
If anyone has any idea, it would be greatly appreciated. I’ve been trying a lot of searches and youtube videos and none of them seem to have an applicable solution, or at the least, one I understand.
