Good morning everyone, technical question? From Ubuntu, I create USB LIVE with the Systemback ISO file, the whole process of my Updated System to later be able to restore it, is it possible to use SystemBack in Manjaro? Some alternative? Thanks
Hi @Eddy168, and welcome!
I’ve never heard of SystemBack until now, so I can’t comment on that.
However, from what I see quickly, you might not need it to create a custom ISO. Have a look here: Build Manjaro ISOs with buildiso - Manjaro
Hope this helps!
Thanks, but I want to create Live USB of my personalized and stable Manjaro with everything I require, to restore in case of any problem, I look for the appropriate application or procedure.
I understand and that’s why I made the suggestion.
There several ways to do it, you could use clonezilla or equivalent, it has all features you mentioned
Systemback appears to have ended in 2018/2019
- DEVELOPMENT AND SUPPORT ENDED *
