USB-Laufwerk mountet nicht
Ein externes USB-Laufwerk WD Elements HDD 1 TB wird in Nautilus nicht mehr angezeigt und nicht gemountet. Nur lsusb zeigt sie
❯ inxi -zv8
  Kernel: 6.6.143-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=fd23435f-372e-4944-b086-a25067a45439 rw quiet splash apparmor=1
    security=apparmor resume=UUID=680b2613-37f4-49f9-8b46-434d27253737
    udev.log_priority=3
  Desktop: GNOME v: 50.2 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 50.1 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: Precision 7520 v: N/A
  Mobo: Dell model: 0NP5CM v: A00 serial: <superuser required> part-nu: 07B0
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.40.0
    date: 01/23/2025
  ID-1: BAT0 charge: 35.6 Wh (100%) condition: 35.6/72 Wh (49.4%) temp: 26.8 C
    volts: 12.28 min: 11.1 model: Samsung SDI DELL GR5D387 type: Li-poly
    serial: <filter> charging: status: full cycles: N/A
  System RAM: total: 32 GiB available: 31.2 GiB used: 3 GiB (9.6%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: DIMM B type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: 01980000802C
    part-no: K821PJ-MIB serial: <filter>
  Device-2: DIMM D type: no module installed
  Device-3: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM C type: no module installed
  Info: model: Intel Core i7-6920HQ bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/3800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 46419
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb
    ibpb_exit_to_user ibrs ida intel_pt invpcid lahf_lm lm mca mce md_clear
    mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake-H GT2 [HD Graphics 530] vendor: Dell driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
    active: DP-3,eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
  Device-2: NVIDIA GM206GLM [Quadro M2200 Mobile] vendor: Dell driver: N/A
    alternate: nouveau, nvidia_drm, nvidia non-free: 550-580.xx+ status: current
    (as of 2025-11; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1436 class-ID: 0300
  Device-3: Realtek Integrated Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5 chip-ID: 0bda:5650
  Display: wayland server: X.org v: 1.21.1.23 with: Xwayland v: 24.1.12
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-3 model: Philips 190CW serial: <filter> built: 2007
    res: 1440x900 dpi: 91 gamma: 1.2 chroma: red: x: 0.639 y: 0.341 green:
    x: 0.298 y: 0.616 blue: x: 0.145 y: 0.067 white: x: 0.314 y: 0.329
    size: 408x255mm (16.06x10.04") diag: 472mm (18.6") ratio: 16:10
    modes: 1440x900, 1152x864, 1024x768, 832x624, 800x600, 640x480, 720x400
  Monitor-2: eDP-1 model: BOE Display 0x06f1 built: 2016 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.655 y: 0.341 green: x: 0.318 y: 0.631
    blue: x: 0.153 y: 0.063 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.2-arch1.2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
    device-ID: 8086:191b memory: 30.47 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: Intel HM175/QM175/CM238 HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a171 class-ID: 0403
  Device-2: NVIDIA GM206 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:0fba class-ID: 0403
  API: ALSA v: k6.6.143-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  Local Storage: total: 476.94 GiB used: 395.18 GiB (82.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM981 NVMe 512GB
    lanes: 4 tech: SSD serial: <filter> fw-rev: EXA73D1Q temp: 29.9 C
    scheme: GPT
  ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 51.01 GiB (88.9%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: system
    uuid: fd23435f-372e-4944-b086-a25067a45439
    used: 10.2 MiB (3.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: A1F5-20DA
  ID-3: /home raw-size: 384.45 GiB size: 377.35 GiB (98.15%)
    used: 344.16 GiB (91.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: home uuid: 4cdbecbf-e7cb-4884-931d-55c156add0bb
  ID-1: swap-1 type: partition size: 33.59 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: swap
    uuid: 680b2613-37f4-49f9-8b46-434d27253737
  Device-1: 1-4:2 info: USB Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 30fa:0300 class-ID: 0301
  Device-2: 1-10:4 info: Broadcom BCM5880 Secure Applications Processor
    Smartcard reader type: smart card driver: N/A interfaces: 2 rev: 1.1
    chip-ID: 0a5c:5832 class-ID: 0b00 serial: <filter>
  Device-3: 1-11:5 info: Realtek Integrated Webcam_HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:5650 class-ID: 0e02
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  System Temperatures: cpu: 0.0 C pch: 43.5 C mobo: 42.0 C
  Fan Speeds (rpm): cpu: 1998 fan-2: 2128
  Packages: pm: pacman pkgs: 2068 libs: 540 tools: gnome-software, octopi,
    pamac, yay pm: flatpak pkgs: 0
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://mirrors2.manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 274
  1: cpu: 9.3% command: firefox pid: 3706 mem: 553.1 MiB (1.7%)
  2: cpu: 7.5% command: gnome-shell pid: 2139 mem: 326.7 MiB (1.0%)
  3: cpu: 6.9% command: gnome-terminal-server pid: 7227 mem: 63.7 MiB (0.1%)
  4: cpu: 6.7% command: firefox pid: 4309 mem: 314.4 MiB (0.9%)
  5: cpu: 5.6% command: zsh pid: 7421 mem: 9.04 MiB (0.0%)
  Memory top: 5 of 274
  1: mem: 553.1 MiB (1.7%) command: firefox pid: 3706 cpu: 9.3%
  2: mem: 326.7 MiB (1.0%) command: gnome-shell pid: 2139 cpu: 7.5%
  3: mem: 314.4 MiB (0.9%) command: firefox pid: 4309 cpu: 6.7%
  4: mem: 299.1 MiB (0.9%) command: firefox pid: 4356 cpu: 0.9%
  5: mem: 228.4 MiB (0.7%) command: xdg-desktop-portal-gnome pid: 2609
    cpu: 0.0%
  Processes: 274 Power: uptime: 21m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.44 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Zsh v: 5.9.1
    running-in: gnome-terminal inxi: 3.3.40
und dmesg
 sudo dmesg
[sudo] Passwort für mo:
[    0.000000] Linux version 6.6.143-1-MANJARO (builduser@runnervm7b5n9) (gcc (GCC) 16.1.1 20260430, GNU ld (GNU Binutils) 2.46.0) #1 SMP PREEMPT_DYNAMIC Fri Jun 19 13:56:37 UTC 2026
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=fd23435f-372e-4944-b086-a25067a45439 rw quiet splash apparmor=1 security=apparmor resume=UUID=680b2613-37f4-49f9-8b46-434d27253737 udev.log_priority=3
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000682ddfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000682de000-0x00000000682defff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000682df000-0x00000000682dffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000682e0000-0x00000000780c2fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000780c3000-0x000000007847ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000078480000-0x00000000784cbfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000784cc000-0x0000000078e40fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000078e41000-0x00000000795fefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000795ff000-0x00000000795fffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000079600000-0x000000007f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000087e7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] e820: update [mem 0x6231a018-0x62347257] usable ==> usable
[    0.000000] e820: update [mem 0x62309018-0x62319057] usable ==> usable
[    0.000000] e820: update [mem 0x622f8018-0x62308457] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] reserve setup_data: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000059000-0x000000000009efff] usable
[    0.000000] reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x00000000622f8017] usable
[    0.000000] reserve setup_data: [mem 0x00000000622f8018-0x0000000062308457] usable
[    0.000000] reserve setup_data: [mem 0x0000000062308458-0x0000000062309017] usable
[    0.000000] reserve setup_data: [mem 0x0000000062309018-0x0000000062319057] usable
[    0.000000] reserve setup_data: [mem 0x0000000062319058-0x000000006231a017] usable
[    0.000000] reserve setup_data: [mem 0x000000006231a018-0x0000000062347257] usable
[    0.000000] reserve setup_data: [mem 0x0000000062347258-0x00000000682ddfff] usable
[    0.000000] reserve setup_data: [mem 0x00000000682de000-0x00000000682defff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x00000000682df000-0x00000000682dffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000682e0000-0x00000000780c2fff] usable
[    0.000000] reserve setup_data: [mem 0x00000000780c3000-0x000000007847ffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000078480000-0x00000000784cbfff] ACPI data
[    0.000000] reserve setup_data: [mem 0x00000000784cc000-0x0000000078e40fff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x0000000078e41000-0x00000000795fefff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000795ff000-0x00000000795fffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000079600000-0x000000007f7fffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000087e7fffff] usable
[    0.000000] efi: EFI v2.6 by American Megatrends
[    0.000000] efi: ACPI=0x7848f000 ACPI 2.0=0x7848f000 SMBIOS=0x79364000 SMBIOS 3.0=0x79363000 ESRT=0x7927e018 MEMATTR=0x75923018 INITRD=0x68397e98
[    0.000000] efi: Remove mem37: MMIO range=[0xf0000000-0xf7ffffff] (128MB) from e820 map
[    0.000000] e820: remove [mem 0xf0000000-0xf7ffffff] reserved
[    0.000000] efi: Not removing mem38: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[    0.000000] efi: Not removing mem39: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem40: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[    0.000000] efi: Remove mem41: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[    0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[    0.000000] SMBIOS 3.0.0 present.
[    0.000000] DMI: Dell Inc. Precision 7520/0NP5CM, BIOS 1.40.0 01/23/2025
[    0.000000] tsc: Detected 2900.000 MHz processor
[    0.000000] tsc: Detected 2899.886 MHz TSC
[    0.000985] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000989] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001000] last_pfn = 0x87e800 max_arch_pfn = 0x400000000
[    0.001005] MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variable MTRRs
[    0.001008] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001302] last_pfn = 0x79600 max_arch_pfn = 0x400000000
[    0.010604] found SMP MP-table at [mem 0x000fcec0-0x000fcecf]
[    0.010618] esrt: Reserving ESRT space from 0x000000007927e018 to 0x000000007927e050.
[    0.010628] Using GB pages for direct mapping
[    0.011434] Secure boot disabled
[    0.011435] RAMDISK: [mem 0x62348000-0x647fffff]
[    0.011579] ACPI: Early table checksum verification disabled
[    0.011583] ACPI: RSDP 0x000000007848F000 000024 (v02 DELL  )
[    0.011588] ACPI: XSDT 0x000000007848F0C8 00010C (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.011595] ACPI: FACP 0x00000000784B8730 00010C (v05 DELL   CBX3     01072009 AMI  00010013)
[    0.011602] ACPI: DSDT 0x000000007848F260 0294CE (v02 DELL   CBX3     01072009 INTL 20160422)
[    0.011606] ACPI: FACS 0x0000000078E3EE80 000040
[    0.011610] ACPI: APIC 0x00000000784B8840 0000BC (v03 DELL   CBX3     01072009 AMI  00010013)
[    0.011614] ACPI: FPDT 0x00000000784B8900 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.011617] ACPI: FIDT 0x00000000784B8948 0000AC (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.011621] ACPI: MCFG 0x00000000784B89F8 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
[    0.011625] ACPI: HPET 0x00000000784B8A38 000038 (v01 DELL   CBX3     01072009 AMI. 0005000B)
[    0.011629] ACPI: SSDT 0x00000000784B8A70 000644 (v01 SataRe SataTabl 00001000 INTL 20160422)
[    0.011633] ACPI: SSDT 0x00000000784B90B8 0012FE (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
[    0.011637] ACPI: SSDT 0x00000000784BA3B8 002AD6 (v02 PegSsd PegSsdt  00001000 INTL 20160422)
[    0.011640] ACPI: HPET 0x00000000784BCE90 000038 (v01 INTEL  SKL      00000001 MSFT 0000005F)
[    0.011644] ACPI: SSDT 0x00000000784BCEC8 000BA3 (v02 INTEL  xh_rvp11 00000000 INTL 20160422)
[    0.011648] ACPI: UEFI 0x00000000784BDA70 000042 (v01                 00000000      00000000)
[    0.011652] ACPI: SSDT 0x00000000784BDAB8 000EDE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
[    0.011656] ACPI: LPIT 0x00000000784BE998 000094 (v01 INTEL  SKL      00000000 MSFT 0000005F)
[    0.011660] ACPI: SSDT 0x00000000784BEA30 000141 (v02 INTEL  HdaDsp   00000000 INTL 20160422)
[    0.011664] ACPI: SSDT 0x00000000784BEB78 00029F (v02 INTEL  sensrhub 00000000 INTL 20160422)
[    0.011668] ACPI: SSDT 0x00000000784BEE18 003002 (v02 INTEL  PtidDevc 00001000 INTL 20160422)
[    0.011672] ACPI: SSDT 0x00000000784C1E20 000517 (v02 INTEL  TbtTypeC 00000000 INTL 20160422)
[    0.011675] ACPI: DBGP 0x00000000784C2338 000034 (v01 INTEL           00000002 MSFT 0000005F)
[    0.011679] ACPI: DBG2 0x00000000784C2370 000054 (v00 INTEL           00000002 MSFT 0000005F)
[    0.011683] ACPI: SSDT 0x00000000784C23C8 0007AC (v02 INTEL  UsbCTabl 00001000 INTL 20160422)
[    0.011687] ACPI: SSDT 0x00000000784C2B78 005394 (v02 DptfTa DptfTabl 00001000 INTL 20160422)
[    0.011691] ACPI: MSDM 0x00000000784C7F10 000055 (v03 DELL   CBX3     06222004 AMI  00010013)
[    0.011694] ACPI: SLIC 0x00000000784C7F68 000176 (v03 DELL   CBX3     01072009 MSFT 00010013)
[    0.011698] ACPI: SSDT 0x00000000784C80E0 0000AE (v02 SgRef  SgPeg    00001000 INTL 20160422)
[    0.011702] ACPI: DMAR 0x00000000784C8190 0000F0 (v01 INTEL  SKL      00000001 INTL 00000001)
[    0.011706] ACPI: SSDT 0x00000000784C8280 001D85 (v01 OptRef OptTabl  00001000 INTL 20160422)
[    0.011710] ACPI: ASF! 0x00000000784CA008 0000A0 (v32 INTEL   HCG     00000001 TFSM 000F4240)
[    0.011714] ACPI: BGRT 0x00000000784CA0A8 000038 (v00 \xf3\xee              01072009 AMI  00010013)
[    0.011717] ACPI: Reserving FACP table memory at [mem 0x784b8730-0x784b883b]
[    0.011719] ACPI: Reserving DSDT table memory at [mem 0x7848f260-0x784b872d]
[    0.011720] ACPI: Reserving FACS table memory at [mem 0x78e3ee80-0x78e3eebf]
[    0.011721] ACPI: Reserving APIC table memory at [mem 0x784b8840-0x784b88fb]
[    0.011722] ACPI: Reserving FPDT table memory at [mem 0x784b8900-0x784b8943]
[    0.011723] ACPI: Reserving FIDT table memory at [mem 0x784b8948-0x784b89f3]
[    0.011724] ACPI: Reserving MCFG table memory at [mem 0x784b89f8-0x784b8a33]
[    0.011725] ACPI: Reserving HPET table memory at [mem 0x784b8a38-0x784b8a6f]
[    0.011725] ACPI: Reserving SSDT table memory at [mem 0x784b8a70-0x784b90b3]
[    0.011726] ACPI: Reserving SSDT table memory at [mem 0x784b90b8-0x784ba3b5]
[    0.011727] ACPI: Reserving SSDT table memory at [mem 0x784ba3b8-0x784bce8d]
[    0.011728] ACPI: Reserving HPET table memory at [mem 0x784bce90-0x784bcec7]
[    0.011729] ACPI: Reserving SSDT table memory at [mem 0x784bcec8-0x784bda6a]
[    0.011730] ACPI: Reserving UEFI table memory at [mem 0x784bda70-0x784bdab1]
[    0.011731] ACPI: Reserving SSDT table memory at [mem 0x784bdab8-0x784be995]
[    0.011732] ACPI: Reserving LPIT table memory at [mem 0x784be998-0x784bea2b]
[    0.011733] ACPI: Reserving SSDT table memory at [mem 0x784bea30-0x784beb70]
[    0.011734] ACPI: Reserving SSDT table memory at [mem 0x784beb78-0x784bee16]
[    0.011735] ACPI: Reserving SSDT table memory at [mem 0x784bee18-0x784c1e19]
[    0.011736] ACPI: Reserving SSDT table memory at [mem 0x784c1e20-0x784c2336]
[    0.011736] ACPI: Reserving DBGP table memory at [mem 0x784c2338-0x784c236b]
[    0.011737] ACPI: Reserving DBG2 table memory at [mem 0x784c2370-0x784c23c3]
[    0.011738] ACPI: Reserving SSDT table memory at [mem 0x784c23c8-0x784c2b73]
[    0.011739] ACPI: Reserving SSDT table memory at [mem 0x784c2b78-0x784c7f0b]
[    0.011740] ACPI: Reserving MSDM table memory at [mem 0x784c7f10-0x784c7f64]
[    0.011741] ACPI: Reserving SLIC table memory at [mem 0x784c7f68-0x784c80dd]
[    0.011742] ACPI: Reserving SSDT table memory at [mem 0x784c80e0-0x784c818d]
[    0.011743] ACPI: Reserving DMAR table memory at [mem 0x784c8190-0x784c827f]
[    0.011744] ACPI: Reserving SSDT table memory at [mem 0x784c8280-0x784ca004]
[    0.011745] ACPI: Reserving ASF! table memory at [mem 0x784ca008-0x784ca0a7]
[    0.011746] ACPI: Reserving BGRT table memory at [mem 0x784ca0a8-0x784ca0df]
[    0.011876] No NUMA configuration found
[    0.011877] Faking a node at [mem 0x0000000000000000-0x000000087e7fffff]
[    0.011881] NODE_DATA(0) allocated [mem 0x87e7fb000-0x87e7fffff]
[    0.011943] Zone ranges:
[    0.011943]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.011946]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.011948]   Normal   [mem 0x0000000100000000-0x000000087e7fffff]
[    0.011949]   Device   empty
[    0.011951] Movable zone start for each node
[    0.011951] Early memory node ranges
[    0.011952]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.011954]   node   0: [mem 0x0000000000059000-0x000000000009efff]
[    0.011955]   node   0: [mem 0x0000000000100000-0x00000000682ddfff]
[    0.011956]   node   0: [mem 0x00000000682e0000-0x00000000780c2fff]
[    0.011957]   node   0: [mem 0x00000000795ff000-0x00000000795fffff]
[    0.011958]   node   0: [mem 0x0000000100000000-0x000000087e7fffff]
[    0.011963] Initmem setup node 0 [mem 0x0000000000001000-0x000000087e7fffff]
[    0.011967] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.011969] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.011992] On node 0, zone DMA: 97 pages in unavailable ranges
[    0.014761] On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.014815] On node 0, zone DMA32: 5436 pages in unavailable ranges
[    0.060420] On node 0, zone Normal: 27136 pages in unavailable ranges
[    0.060483] On node 0, zone Normal: 6144 pages in unavailable ranges
[    0.060510] Reserving Intel graphics memory at [mem 0x7b800000-0x7f7fffff]
[    0.061273] ACPI: PM-Timer IO Port: 0x1808
[    0.061282] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.061284] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.061285] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.061286] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.061287] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.061287] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.061288] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.061289] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.061316] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.061319] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.061321] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.061327] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.061328] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.061336] e820: update [mem 0x73e88000-0x73f10fff] usable ==> reserved
[    0.061351] TSC deadline timer available
[    0.061352] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.061372] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.061374] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.061376] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.061379] PM: hibernation: Registered nosave memory: [mem 0x682de000-0x682dffff]
[    0.061381] PM: hibernation: Registered nosave memory: [mem 0x73e88000-0x73f10fff]
[    0.061383] PM: hibernation: Registered nosave memory: [mem 0x780c3000-0x795fefff]
[    0.061385] PM: hibernation: Registered nosave memory: [mem 0x79600000-0xffffffff]
[    0.061386] [mem 0x7f800000-0xfdffffff] available for PCI devices
[    0.061388] Booting paravirtualized kernel on bare hardware
[    0.061390] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.069235] setup_percpu: NR_CPUS:320 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[    0.069591] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[    0.069598] pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
[    0.069601] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.069622] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=fd23435f-372e-4944-b086-a25067a45439 rw quiet splash apparmor=1 security=apparmor resume=UUID=680b2613-37f4-49f9-8b46-434d27253737 udev.log_priority=3
[    0.069740] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.069778] random: crng init done
[    0.072517] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.073899] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.074029] Fallback order for Node 0: 0
[    0.074032] Built 1 zonelists, mobility grouping on.  Total pages: 8219166
[    0.074034] Policy zone: Normal
[    0.074244] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.074253] software IO TLB: area num 8.
[    0.152014] Memory: 32621456K/33399164K available (18432K kernel code, 2149K rwdata, 13132K rodata, 3512K init, 4548K bss, 777452K reserved, 0K cma-reserved)
[    0.152286] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.152299] Kernel/User page tables isolation: enabled
[    0.152331] ftrace: allocating 49431 entries in 194 pages
[    0.162294] ftrace: allocated 194 pages with 3 groups
[    0.162377] Dynamic Preempt: full
[    0.162428] rcu: Preemptible hierarchical RCU implementation.
[    0.162428] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[    0.162430] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.162431] 	Trampoline variant of Tasks RCU enabled.
[    0.162431] 	Rude variant of Tasks RCU enabled.
[    0.162432] 	Tracing variant of Tasks RCU enabled.
[    0.162433] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.162434] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.166595] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[    0.166819] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.167092] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.167137] spurious 8259A interrupt: IRQ7.
[    0.167168] Console: colour dummy device 80x25
[    0.167171] printk: console [tty0] enabled
[    0.167226] ACPI: Core revision 20230628
[    0.167450] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.167503] APIC: Switch to symmetric I/O mode setup
[    0.167505] DMAR: Host address width 39
[    0.167506] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.167513] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
[    0.167516] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.167520] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.167522] DMAR: RMRR base: 0x0000007819b000 end: 0x000000781bafff
[    0.167524] DMAR: RMRR base: 0x0000007b000000 end: 0x0000007f7fffff
[    0.167526] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[    0.167527] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[    0.167529] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.167530] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.167532] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.169134] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.169136] x2apic enabled
[    0.169207] APIC: Switched APIC routing to: cluster x2apic
[    0.173022] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x29ccd767b87, max_idle_ns: 440795223720 ns
[    0.173028] Calibrating delay loop (skipped), value calculated using timer frequency.. 5802.42 BogoMIPS (lpj=9666286)
[    0.173055] x86/cpu: SGX disabled by BIOS.
[    0.173061] CPU0: Thermal monitoring enabled (TM1)
[    0.173114] process: using mwait in idle threads
[    0.173117] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.173118] Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
[    0.173125] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.173128] Spectre V2 : Mitigation: IBRS
[    0.173129] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
[    0.173130] RETBleed: Mitigation: IBRS
[    0.173132] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.173133] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.173135] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.173143] MDS: Mitigation: Clear CPU buffers
[    0.173144] TAA: Mitigation: TSX disabled
[    0.173145] MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.173150] SRBDS: Mitigation: Microcode
[    0.173152] GDS: Vulnerable: No microcode
[    0.173153] VMSCAPE: Mitigation: IBPB before exit to userspace
[    0.173159] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.173161] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.173163] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.173164] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.173165] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.173167] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.173170] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.173172] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.173173] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.176359] Freeing SMP alternatives memory: 40K
[    0.176359] pid_max: default: 32768 minimum: 301
[    0.176359] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor,integrity
[    0.176359] landlock: Up and running.
[    0.176359] Yama: becoming mindful.
[    0.176359] LSM support for eBPF active
[    0.176359] AppArmor: AppArmor initialized
[    0.176359] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.176359] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.176359] smpboot: CPU0: Intel(R) Core(TM) i7-6920HQ CPU @ 2.90GHz (family: 0x6, model: 0x5e, stepping: 0x3)
[    0.176359] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.176359] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.176359] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.176359] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.176359] ... version:                4
[    0.176359] ... bit width:              48
[    0.176359] ... generic registers:      4
[    0.176359] ... value mask:             0000ffffffffffff
[    0.176359] ... max period:             00007fffffffffff
[    0.176359] ... fixed-purpose events:   3
[    0.176359] ... event mask:             000000070000000f
[    0.176359] signal: max sigframe size: 2032
[    0.176359] Estimated ratio of average max frequency by base frequency (times 1024): 1200
[    0.176359] rcu: Hierarchical SRCU implementation.
[    0.176359] rcu: 	Max phase no-delay instances is 1000.
[    0.176359] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.176359] smp: Bringing up secondary CPUs ...
[    0.176359] smpboot: x86: Booting SMP configuration:
[    0.176359] .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
[    0.176807] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.176807] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.176807] VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
[    0.176807] smp: Brought up 1 node, 8 CPUs
[    0.176807] smpboot: Max logical packages: 1
[    0.176807] smpboot: Total of 8 processors activated (46416.43 BogoMIPS)
[    0.180670] devtmpfs: initialized
[    0.180670] x86/mm: Memory block size: 128MB
[    0.183849] ACPI: PM: Registering ACPI NVS region [mem 0x682de000-0x682defff] (4096 bytes)
[    0.183849] ACPI: PM: Registering ACPI NVS region [mem 0x784cc000-0x78e40fff] (9916416 bytes)
[    0.183849] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.183849] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.183849] pinctrl core: initialized pinctrl subsystem
[    0.183849] PM: RTC time: 12:47:25, date: 2026-06-29
[    0.184200] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.184697] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.184974] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.185245] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.185272] audit: initializing netlink subsys (disabled)
[    0.185291] audit: type=2000 audit(1782737245.009:1): state=initialized audit_enabled=0 res=1
[    0.185291] thermal_sys: Registered thermal governor 'fair_share'
[    0.185291] thermal_sys: Registered thermal governor 'bang_bang'
[    0.185291] thermal_sys: Registered thermal governor 'step_wise'
[    0.185291] thermal_sys: Registered thermal governor 'user_space'
[    0.185291] thermal_sys: Registered thermal governor 'power_allocator'
[    0.185291] cpuidle: using governor ladder
[    0.185291] cpuidle: using governor menu
[    0.188093] efi: Freeing EFI boot services memory: 46956K
[    0.188097] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.188099] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.188202] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.188217] PCI: Using configuration type 1 for base access
[    0.188588] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.188596] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.188596] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.188596] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.188596] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.188596] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.188596] ACPI: Added _OSI(Module Device)
[    0.188596] ACPI: Added _OSI(Processor Device)
[    0.188596] ACPI: Added _OSI(Processor Aggregator Device)
[    0.257785] ACPI: 14 ACPI AML tables successfully acquired and loaded
[    0.266649] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.277586] ACPI: Dynamic OEM Table Load:
[    0.277595] ACPI: SSDT 0xFFFF888100FD3000 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.280702] ACPI: Dynamic OEM Table Load:
[    0.280710] ACPI: SSDT 0xFFFF888100FE5000 000672 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.283907] ACPI: Dynamic OEM Table Load:
[    0.283915] ACPI: SSDT 0xFFFF888100FE0800 00065C (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.286582] ACPI: Dynamic OEM Table Load:
[    0.286589] ACPI: SSDT 0xFFFF888101C07200 00018A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.294371] ACPI: _OSC evaluated successfully for all CPUs
[    0.294659] ACPI: EC: EC started
[    0.294660] ACPI: EC: interrupt blocked
[    0.306709] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.306712] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
[    0.306715] ACPI: Interpreter enabled
[    0.306771] ACPI: PM: (supports S0 S3 S4 S5)
[    0.306773] ACPI: Using IOAPIC for interrupt routing
[    0.309355] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.309356] PCI: Ignoring E820 reservations for host bridge windows
[    0.310425] ACPI: Enabled 8 GPEs in block 00 to 7F
[    0.313520] ACPI: \_SB_.PCI0.PEG0.PG00: New power resource
[    0.447526] ACPI: \_SB_.PCI0.PEG1.PG01: New power resource
[    0.448086] ACPI: \_SB_.PCI0.PEG2.PG02: New power resource
[    0.453719] ACPI: \_SB_.PCI0.RP09.PXSX.WRST: New power resource
[    0.454212] ACPI: \_SB_.PCI0.RP10.PXSX.WRST: New power resource
[    0.454703] ACPI: \_SB_.PCI0.RP11.PXSX.WRST: New power resource
[    0.455196] ACPI: \_SB_.PCI0.RP12.PXSX.WRST: New power resource
[    0.455684] ACPI: \_SB_.PCI0.RP13.PXSX.WRST: New power resource
[    0.456174] ACPI: \_SB_.PCI0.RP01.PXSX.WRST: New power resource
[    0.456675] ACPI: \_SB_.PCI0.RP02.PXSX.WRST: New power resource
[    0.457166] ACPI: \_SB_.PCI0.RP03.PXSX.WRST: New power resource
[    0.457664] ACPI: \_SB_.PCI0.RP04.PXSX.WRST: New power resource
[    0.458157] ACPI: \_SB_.PCI0.RP05.PXSX.WRST: New power resource
[    0.459385] ACPI: \_SB_.PCI0.RP06.PXSX.WRST: New power resource
[    0.459883] ACPI: \_SB_.PCI0.RP07.PXSX.WRST: New power resource
[    0.460371] ACPI: \_SB_.PCI0.RP08.PXSX.WRST: New power resource
[    0.460861] ACPI: \_SB_.PCI0.RP17.PXSX.WRST: New power resource
[    0.461348] ACPI: \_SB_.PCI0.RP18.PXSX.WRST: New power resource
[    0.461837] ACPI: \_SB_.PCI0.RP19.PXSX.WRST: New power resource
[    0.462322] ACPI: \_SB_.PCI0.RP20.PXSX.WRST: New power resource
[    0.464375] ACPI: \_SB_.PCI0.RP14.PXSX.WRST: New power resource
[    0.464864] ACPI: \_SB_.PCI0.RP15.PXSX.WRST: New power resource
[    0.465359] ACPI: \_SB_.PCI0.RP16.PXSX.WRST: New power resource
[    0.497533] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
[    0.497543] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.498405] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    0.499870] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[    0.499873] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.501516] PCI host bridge to bus 0000:00
[    0.501519] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.501522] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.501524] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.501526] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xefffffff window]
[    0.501528] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.501530] pci_bus 0000:00: root bus resource [bus 00-7e]
[    0.501556] pci 0000:00:00.0: [8086:1910] type 00 class 0x060000
[    0.501675] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.501713] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.501717] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.501720] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
[    0.501729] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.501768] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.502375] pci 0000:00:02.0: [8086:191b] type 00 class 0x030000
[    0.502398] pci 0000:00:02.0: BAR 0 [mem 0xeb000000-0xebffffff 64bit]
[    0.502415] pci 0000:00:02.0: BAR 2 [mem 0x80000000-0x8fffffff 64bit pref]
[    0.502426] pci 0000:00:02.0: BAR 4 [io  0xf000-0xf03f]
[    0.502461] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.502466] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.502707] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.502727] pci 0000:00:04.0: BAR 0 [mem 0xed440000-0xed447fff 64bit]
[    0.503224] pci 0000:00:14.0: [8086:a12f] type 00 class 0x0c0330
[    0.503265] pci 0000:00:14.0: BAR 0 [mem 0xed430000-0xed43ffff 64bit]
[    0.503403] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.504430] pci 0000:00:14.2: [8086:a131] type 00 class 0x118000
[    0.504469] pci 0000:00:14.2: BAR 0 [mem 0xed459000-0xed459fff 64bit]
[    0.504808] pci 0000:00:15.0: [8086:a160] type 00 class 0x118000
[    0.505005] pci 0000:00:15.0: BAR 0 [mem 0xed458000-0xed458fff 64bit]
[    0.506270] pci 0000:00:15.1: [8086:a161] type 00 class 0x118000
[    0.506474] pci 0000:00:15.1: BAR 0 [mem 0xed457000-0xed457fff 64bit]
[    0.507668] pci 0000:00:16.0: [8086:a13a] type 00 class 0x078000
[    0.507697] pci 0000:00:16.0: BAR 0 [mem 0xed456000-0xed456fff 64bit]
[    0.507790] pci 0000:00:16.0: PME# supported from D3hot
[    0.508226] pci 0000:00:16.3: [8086:a13d] type 00 class 0x070002
[    0.508251] pci 0000:00:16.3: BAR 0 [io  0xf0a0-0xf0a7]
[    0.508264] pci 0000:00:16.3: BAR 1 [mem 0xed455000-0xed455fff]
[    0.508432] pci 0000:00:17.0: [8086:a102] type 00 class 0x010601
[    0.508464] pci 0000:00:17.0: BAR 0 [mem 0xed450000-0xed451fff]
[    0.508482] pci 0000:00:17.0: BAR 1 [mem 0xed454000-0xed4540ff]
[    0.508501] pci 0000:00:17.0: BAR 2 [io  0xf090-0xf097]
[    0.508519] pci 0000:00:17.0: BAR 3 [io  0xf080-0xf083]
[    0.508533] pci 0000:00:17.0: BAR 4 [io  0xf060-0xf07f]
[    0.508551] pci 0000:00:17.0: BAR 5 [mem 0xed453000-0xed4537ff]
[    0.508623] pci 0000:00:17.0: PME# supported from D3hot
[    0.509072] pci 0000:00:1c.0: [8086:a111] type 01 class 0x060400
[    0.509133] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.509142] pci 0000:00:1c.0:   bridge window [mem 0xed300000-0xed3fffff]
[    0.509234] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.510179] pci 0000:00:1c.2: [8086:a112] type 01 class 0x060400
[    0.510246] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.510256] pci 0000:00:1c.2:   bridge window [mem 0xed200000-0xed2fffff]
[    0.510364] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.511323] pci 0000:00:1c.4: [8086:a114] type 01 class 0x060400
[    0.511390] pci 0000:00:1c.4: PCI bridge to [bus 04-3c]
[    0.511396] pci 0000:00:1c.4:   bridge window [mem 0xd4000000-0xea0fffff]
[    0.511412] pci 0000:00:1c.4:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.511516] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.512458] pci 0000:00:1d.0: [8086:a118] type 01 class 0x060400
[    0.512518] pci 0000:00:1d.0: PCI bridge to [bus 3d]
[    0.512524] pci 0000:00:1d.0:   bridge window [mem 0xed100000-0xed1fffff]
[    0.512630] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.513635] pci 0000:00:1f.0: [8086:a154] type 00 class 0x060100
[    0.514277] pci 0000:00:1f.2: [8086:a121] type 00 class 0x058000
[    0.514307] pci 0000:00:1f.2: BAR 0 [mem 0xed44c000-0xed44ffff]
[    0.514775] pci 0000:00:1f.3: [8086:a171] type 00 class 0x040300
[    0.514815] pci 0000:00:1f.3: BAR 0 [mem 0xed448000-0xed44bfff 64bit]
[    0.514876] pci 0000:00:1f.3: BAR 4 [mem 0xed420000-0xed42ffff 64bit]
[    0.514944] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.515902] pci 0000:00:1f.4: [8086:a123] type 00 class 0x0c0500
[    0.515970] pci 0000:00:1f.4: BAR 0 [mem 0xed452000-0xed4520ff 64bit]
[    0.516056] pci 0000:00:1f.4: BAR 4 [io  0xf040-0xf05f]
[    0.516507] pci 0000:00:1f.6: [8086:15e3] type 00 class 0x020000
[    0.516539] pci 0000:00:1f.6: BAR 0 [mem 0xed400000-0xed41ffff]
[    0.516696] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.517129] pci 0000:01:00.0: [10de:1436] type 00 class 0x030000
[    0.517154] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00ffffff]
[    0.517175] pci 0000:01:00.0: BAR 1 [mem 0x00000000-0x0fffffff 64bit pref]
[    0.517197] pci 0000:01:00.0: BAR 3 [mem 0x00000000-0x01ffffff 64bit pref]
[    0.517209] pci 0000:01:00.0: BAR 5 [io  0x0000-0x007f]
[    0.517221] pci 0000:01:00.0: ROM [mem 0x00000000-0x0007ffff pref]
[    0.517233] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
[    0.517266] pci 0000:01:00.0: Enabling HDA controller
[    0.518265] pci 0000:01:00.1: [10de:0fba] type 00 class 0x040300
[    0.518291] pci 0000:01:00.1: BAR 0 [mem 0x00000000-0x00003fff]
[    0.518364] pci 0000:01:00.1: Max Payload Size set to 256 (was 128, max 256)
[    0.518511] pci 0000:00:01.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[    0.526382] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.527008] pci 0000:02:00.0: [8086:24fd] type 00 class 0x028000
[    0.527614] pci 0000:02:00.0: BAR 0 [mem 0xed300000-0xed301fff 64bit]
[    0.529307] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.531527] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.531756] pci 0000:03:00.0: [10ec:525a] type 00 class 0xff0000
[    0.531840] pci 0000:03:00.0: BAR 1 [mem 0xed200000-0xed200fff]
[    0.532212] pci 0000:03:00.0: supports D1 D2
[    0.532214] pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.533135] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.533318] pci 0000:00:1c.4: PCI bridge to [bus 04-3c]
[    0.533674] pci 0000:3d:00.0: [144d:a808] type 00 class 0x010802
[    0.533716] pci 0000:3d:00.0: BAR 0 [mem 0xed100000-0xed103fff 64bit]
[    0.534818] pci 0000:00:1d.0: PCI bridge to [bus 3d]
[    0.542888] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[    0.542978] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[    0.543070] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[    0.543157] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[    0.543243] ACPI: PCI: Interrupt link LNKE configured for IRQ 11
[    0.543329] ACPI: PCI: Interrupt link LNKF configured for IRQ 11
[    0.543416] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[    0.543501] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[    0.554190] ACPI: EC: interrupt unblocked
[    0.554192] ACPI: EC: event unblocked
[    0.554198] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.554200] ACPI: EC: GPE=0x14
[    0.554202] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC initialization complete
[    0.554204] ACPI: \_SB_.PCI0.LPCB.ECDV: EC: Used to handle transactions and events
[    0.554333] iommu: Default domain type: Translated
[    0.554333] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.554333] SCSI subsystem initialized
[    0.554333] libata version 3.00 loaded.
[    0.554333] ACPI: bus type USB registered
[    0.554333] usbcore: registered new interface driver usbfs
[    0.554333] usbcore: registered new interface driver hub
[    0.554333] usbcore: registered new device driver usb
[    0.554333] pps_core: LinuxPPS API ver. 1 registered
[    0.554333] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.554333] PTP clock support registered
[    0.554333] EDAC MC: Ver: 3.0.0
[    0.556586] efivars: Registered efivars operations
[    0.557255] NetLabel: Initializing
[    0.557255] NetLabel:  domain hash size = 128
[    0.557255] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.557255] NetLabel:  unlabeled traffic allowed by default
[    0.557255] mctp: management component transport protocol core
[    0.557255] NET: Registered PF_MCTP protocol family
[    0.557255] PCI: Using ACPI for IRQ routing
[    0.569106] PCI: pci_cache_line_size set to 64 bytes
[    0.569896] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.569899] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.569901] e820: reserve RAM buffer [mem 0x622f8018-0x63ffffff]
[    0.569903] e820: reserve RAM buffer [mem 0x62309018-0x63ffffff]
[    0.569904] e820: reserve RAM buffer [mem 0x6231a018-0x63ffffff]
[    0.569905] e820: reserve RAM buffer [mem 0x682de000-0x6bffffff]
[    0.569907] e820: reserve RAM buffer [mem 0x73e88000-0x73ffffff]
[    0.569908] e820: reserve RAM buffer [mem 0x780c3000-0x7bffffff]
[    0.569910] e820: reserve RAM buffer [mem 0x79600000-0x7bffffff]
[    0.569911] e820: reserve RAM buffer [mem 0x87e800000-0x87fffffff]
[    0.569971] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.569971] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.569971] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.569971] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.569971] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.569971] vgaarb: loaded
[    0.569971] clocksource: Switched to clocksource tsc-early
[    0.570652] VFS: Disk quotas dquot_6.6.0
[    0.570668] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.570717] AppArmor: AppArmor Filesystem Enabled
[    0.570749] pnp: PnP ACPI init
[    0.571042] pnp 00:00: disabling [io  0x002e-0x002f] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.571046] pnp 00:00: disabling [io  0x004e-0x004f] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.571049] pnp 00:00: disabling [io  0x0061] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.571051] pnp 00:00: disabling [io  0x0063] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.571053] pnp 00:00: disabling [io  0x0065] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.571055] pnp 00:00: disabling [io  0x0067] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.571057] pnp 00:00: disabling [io  0x0070] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.571086] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.571089] system 00:00: [io  0xffff] has been reserved
[    0.571091] system 00:00: [io  0xffff] has been reserved
[    0.571093] system 00:00: [io  0xffff] has been reserved
[    0.571095] system 00:00: [io  0x1800-0x18fe] could not be reserved
[    0.571097] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.571239] system 00:01: [io  0x0800-0x087f] has been reserved
[    0.573684] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.573688] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.573691] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.573693] system 00:06: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.573695] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.573697] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.573700] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.573702] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.573704] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.573708] system 00:06: [mem 0xeffe0000-0xefffffff] has been reserved
[    0.573773] system 00:07: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.573776] system 00:07: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.573779] system 00:07: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.573781] system 00:07: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.573783] system 00:07: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.573786] system 00:07: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.573788] system 00:07: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.574266] system 00:08: [io  0xff00-0xfffe] has been reserved
[    0.576246] system 00:09: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.576250] system 00:09: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.576252] system 00:09: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.584740] pnp: PnP ACPI: found 10 devices
[    0.590632] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.590707] NET: Registered PF_INET protocol family
[    0.590872] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.594299] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.594340] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.594473] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.594842] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.595155] TCP: Hash tables configured (established 262144 bind 65536)
[    0.595281] MPTCP token hash table entries: 32768 (order: 8, 786432 bytes, linear)
[    0.595449] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.595538] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.595630] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.595637] NET: Registered PF_XDP protocol family
[    0.595646] pci 0000:00:1c.4: bridge window [io  0x1000-0x0fff] to [bus 04-3c] add_size 1000
[    0.595657] pci 0000:00:1c.4: bridge window [io  0x2000-0x2fff]: assigned
[    0.595662] pci 0000:01:00.0: BAR 1 [mem 0xc0000000-0xcfffffff 64bit pref]: assigned
[    0.595682] pci 0000:01:00.0: BAR 3 [mem 0xd0000000-0xd1ffffff 64bit pref]: assigned
[    0.595700] pci 0000:01:00.0: BAR 0 [mem 0xec000000-0xecffffff]: assigned
[    0.595707] pci 0000:01:00.0: ROM [mem 0xed000000-0xed07ffff pref]: assigned
[    0.595709] pci 0000:01:00.1: BAR 0 [mem 0xed080000-0xed083fff]: assigned
[    0.595716] pci 0000:01:00.0: BAR 5 [io  0xe000-0xe07f]: assigned
[    0.595723] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.595725] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.595733] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
[    0.595739] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.595751] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.595761] pci 0000:00:1c.0:   bridge window [mem 0xed300000-0xed3fffff]
[    0.595782] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.595793] pci 0000:00:1c.2:   bridge window [mem 0xed200000-0xed2fffff]
[    0.595813] pci 0000:00:1c.4: PCI bridge to [bus 04-3c]
[    0.595818] pci 0000:00:1c.4:   bridge window [io  0x2000-0x2fff]
[    0.595829] pci 0000:00:1c.4:   bridge window [mem 0xd4000000-0xea0fffff]
[    0.595836] pci 0000:00:1c.4:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.595851] pci 0000:00:1d.0: PCI bridge to [bus 3d]
[    0.595863] pci 0000:00:1d.0:   bridge window [mem 0xed100000-0xed1fffff]
[    0.595884] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.595886] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.595888] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.595890] pci_bus 0000:00: resource 7 [mem 0x7f800000-0xefffffff window]
[    0.595892] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[    0.595894] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.595895] pci_bus 0000:01: resource 1 [mem 0xec000000-0xed0fffff]
[    0.595897] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.595899] pci_bus 0000:02: resource 1 [mem 0xed300000-0xed3fffff]
[    0.595901] pci_bus 0000:03: resource 1 [mem 0xed200000-0xed2fffff]
[    0.595902] pci_bus 0000:04: resource 0 [io  0x2000-0x2fff]
[    0.595904] pci_bus 0000:04: resource 1 [mem 0xd4000000-0xea0fffff]
[    0.595906] pci_bus 0000:04: resource 2 [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.595907] pci_bus 0000:3d: resource 1 [mem 0xed100000-0xed1fffff]
[    0.597850] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    0.597888] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.598334] PCI: CLS 0 bytes, default 64
[    0.598384] pci 0000:00:1f.1: [8086:a120] type 00 class 0x058000
[    0.598453] pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
[    0.598736] DMAR: ACPI device "device:7a" under DMAR at fed91000 as 00:15.0
[    0.598740] DMAR: ACPI device "device:7b" under DMAR at fed91000 as 00:15.1
[    0.598753] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.598754] software IO TLB: mapped [mem 0x000000006fe88000-0x0000000073e88000] (64MB)
[    0.598781] Trying to unpack rootfs image as initramfs...
[    0.603311] Initialise system trusted keyrings
[    0.603324] Key type blacklist registered
[    0.603374] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[    0.603387] zbud: loaded
[    0.603659] integrity: Platform Keyring initialized
[    0.603662] integrity: Machine keyring initialized
[    0.619494] Key type asymmetric registered
[    0.619498] Asymmetric key parser 'x509' registered
[    0.619524] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.619577] io scheduler mq-deadline registered
[    0.619578] io scheduler kyber registered
[    0.619590] io scheduler bfq registered
[    0.623507] pcieport 0000:00:1c.0: AER: enabled with IRQ 123
[    0.623832] pcieport 0000:00:1c.2: AER: enabled with IRQ 124
[    0.624153] pcieport 0000:00:1c.4: AER: enabled with IRQ 125
[    0.624472] pcieport 0000:00:1d.0: AER: enabled with IRQ 126
[    0.624605] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.626623] ACPI: AC: AC Adapter [AC] (on-line)
[    0.626707] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    0.636164] ACPI: button: Lid Switch [LID0]
[    0.636225] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.636348] ACPI: button: Power Button [PBTN]
[    0.636393] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[    0.636419] ACPI: button: Sleep Button [SBTN]
[    0.636458] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    0.636578] ACPI: button: Power Button [PWRF]
[    0.639298] thermal LNXTHERM:00: registered as thermal_zone0
[    0.639301] ACPI: thermal: Thermal Zone [THM] (25 C)
[    0.639576] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.641828] serial 0000:00:16.3: enabling device (0000 -> 0003)
[    0.643015] 0000:00:16.3: ttyS4 at I/O 0xf0a0 (irq = 19, base_baud = 115200) is a 16550A
[    0.643825] hpet_acpi_add: no address or irqs in _CRS
[    0.643884] Non-volatile memory driver v1.3
[    0.643886] Linux agpgart interface v0.103
[    0.643931] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    0.643998] ACPI: bus type drm_connector registered
[    0.645790] ahci 0000:00:17.0: version 3.0
[    0.646777] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[    0.646891] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 3 ports 6 Gbps 0x1a impl SATA mode
[    0.646895] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm led clo only pio slum part ems sxs deso sadm sds apst
[    0.666722] scsi host0: ahci
[    0.667022] scsi host1: ahci
[    0.667282] scsi host2: ahci
[    0.667400] scsi host3: ahci
[    0.667666] scsi host4: ahci
[    0.667705] ata1: DUMMY
[    0.667707] ata2: SATA max UDMA/133 abar m2048@0xed453000 port 0xed453180 irq 127
[    0.667709] ata3: DUMMY
[    0.667711] ata4: SATA max UDMA/133 abar m2048@0xed453000 port 0xed453280 irq 127
[    0.667713] ata5: SATA max UDMA/133 abar m2048@0xed453000 port 0xed453300 irq 127
[    0.667843] usbcore: registered new interface driver usbserial_generic
[    0.667849] usbserial: USB Serial support registered for generic
[    0.668027] rtc_cmos 00:02: RTC can wake from S4
[    0.668771] rtc_cmos 00:02: registered as rtc0
[    0.668963] rtc_cmos 00:02: setting system clock to 2026-06-29T12:47:25 UTC (1782737245)
[    0.669019] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram
[    0.672913] intel_pstate: Intel P-state driver initializing
[    0.673414] intel_pstate: HWP enabled
[    0.674106] ledtrig-cpu: registered to indicate activity on CPUs
[    0.674607] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[    0.675294] fbcon: Deferring console take-over
[    0.675296] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.675349] hid: raw HID events driver (C) Jiri Kosina
[    0.675406] resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
[    0.675410] caller get_primary_reg_base+0x4d/0xa0 mapping multiple BARs
[    0.675425] intel_pmc_core INT33A1:00:  initialized
[    0.675556] drop_monitor: Initializing network drop monitor service
[    0.684203] ACPI: battery: Slot [BAT0] (battery present)
[    0.687602] Initializing XFRM netlink socket
[    0.687630] NET: Registered PF_INET6 protocol family
[    0.726653] Freeing initrd memory: 37600K
[    0.734401] Segment Routing with IPv6
[    0.734404] RPL Segment Routing with IPv6
[    0.734429] In-situ OAM (IOAM) with IPv6
[    0.734455] NET: Registered PF_PACKET protocol family
[    0.735535] microcode: Current revision: 0x000000f0
[    0.735924] microcode: Microcode Update Driver: v2.2.
[    0.735929] IPI shorthand broadcast: enabled
[    0.737533] sched_clock: Marking stable (730001394, 6079871)->(781533367, -45452102)
[    0.737764] registered taskstats version 1
[    0.738535] Loading compiled-in X.509 certificates
[    0.740750] Loaded X.509 cert 'Build time autogenerated kernel key: 820581c157c08c28edf553270c9ce7a1598a9cb4'
[    0.742401] zswap: loaded using pool zstd/zsmalloc
[    0.744170] Key type .fscrypt registered
[    0.744171] Key type fscrypt-provisioning registered
[    0.744201] AppArmor: AppArmor sha1 policy hashing enabled
[    0.744507] integrity: Loading X.509 certificate: UEFI:db
[    0.744538] integrity: Loaded X.509 cert 'Dell Inc. UEFI DB: 5ddb772dc880660055ba0bc131886bb630a639e7'
[    0.744539] integrity: Loading X.509 certificate: UEFI:db
[    0.744554] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    0.744555] integrity: Loading X.509 certificate: UEFI:db
[    0.744567] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    0.745196] PM:   Magic number: 14:687:785
[    0.745243] serial 0000:00:16.3: hash matches
[    0.748809] RAS: Correctable Errors collector initialized.
[    0.997904] ata2: SATA link down (SStatus 0 SControl 300)
[    1.311099] ata4: SATA link down (SStatus 4 SControl 300)
[    1.612890] tsc: Refined TSC clocksource calibration: 2904.006 MHz
[    1.612908] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x29dc0b74fd3, max_idle_ns: 440795242287 ns
[    1.612997] clocksource: Switched to clocksource tsc
[    1.619559] ata5: SATA link down (SStatus 4 SControl 300)
[    1.619804] clk: Disabling unused clocks
[    1.623853] Freeing unused decrypted memory: 2028K
[    1.625574] Freeing unused kernel image (initmem) memory: 3512K
[    1.625693] Write protecting the kernel read-only data: 32768k
[    1.626131] Freeing unused kernel image (rodata/data gap) memory: 1204K
[    1.665387] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.665398] rodata_test: all tests were successful
[    1.665399] x86/mm: Checking user space page tables
[    1.701740] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.701743] Run /init as init process
[    1.701744]   with arguments:
[    1.701745]     /init
[    1.701746]     splash
[    1.701747]   with environment:
[    1.701747]     HOME=/
[    1.701748]     TERM=linux
[    2.156291] wmi_bus wmi_bus-PNP0C14:03: WQBC data block query control method not found
[    2.165615] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    2.166252] i8042: Warning: Keylock active
[    2.168850] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.168910] serio: i8042 AUX port at 0x60,0x64 irq 12
[    2.179892] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    2.179902] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    2.181032] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000001109810
[    2.181549] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    2.181552] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    2.181555] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    2.181603] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    2.181606] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.181608] usb usb1: Product: xHCI Host Controller
[    2.181610] usb usb1: Manufacturer: Linux 6.6.143-1-MANJARO xhci-hcd
[    2.181612] usb usb1: SerialNumber: 0000:00:14.0
[    2.181978] hub 1-0:1.0: USB hub found
[    2.182014] hub 1-0:1.0: 16 ports detected
[    2.186693] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    2.186931] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    2.187242] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[    2.187246] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.187248] usb usb2: Product: xHCI Host Controller
[    2.187250] usb usb2: Manufacturer: Linux 6.6.143-1-MANJARO xhci-hcd
[    2.187251] usb usb2: SerialNumber: 0000:00:14.0
[    2.187782] hub 2-0:1.0: USB hub found
[    2.187809] hub 2-0:1.0: 10 ports detected
[    2.189121] rtsx_pci 0000:03:00.0: enabling device (0000 -> 0002)
[    2.214957] nvme nvme0: pci function 0000:3d:00.0
[    2.218370] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    2.218649] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    2.222647] nvme nvme0: Shutdown timeout set to 8 seconds
[    2.232585] nvme nvme0: 8/0/0 default/read/poll queues
[    2.237412]  nvme0n1: p1 p2 p3 p4
[    2.260411] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    2.439501] usb 1-4: new low-speed USB device number 2 using xhci_hcd
[    2.582685] usb 1-4: New USB device found, idVendor=30fa, idProduct=0300, bcdDevice= 1.00
[    2.582688] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.582690] usb 1-4: Product: USB Optical Mouse
[    2.662073] input: USB Optical Mouse  as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:30FA:0300.0001/input/input6
[    2.662143] hid-generic 0003:30FA:0300.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse ] on usb-0000:00:14.0-4/input0
[    2.662185] usbcore: registered new interface driver usbhid
[    2.662187] usbhid: USB HID core driver
[    2.706303] usb 1-6: new full-speed USB device number 3 using xhci_hcd
[    2.723273] i915 0000:00:02.0: vgaarb: deactivate vga console
[    2.725754] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[    2.726405] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[    2.767109] i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
[    2.767130] i915 0000:00:02.0: [drm] [ENCODER:117:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
[    2.767140] i915 0000:00:02.0: [drm] [ENCODER:127:DDI D/PHY D] is disabled/in DSI mode with an ungated DDI clock, gate it
[    2.847981] usb 1-6: New USB device found, idVendor=8087, idProduct=0a2b, bcdDevice= 0.10
[    2.847994] usb 1-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.973093] usb 1-10: new full-speed USB device number 4 using xhci_hcd
[    3.115324] usb 1-10: New USB device found, idVendor=0a5c, idProduct=5832, bcdDevice= 1.01
[    3.115337] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.115343] usb 1-10: Product: 5880
[    3.115348] usb 1-10: Manufacturer: Broadcom Corp
[    3.115352] usb 1-10: SerialNumber: 0123456789ABCD
[    3.243093] usb 1-11: new high-speed USB device number 5 using xhci_hcd
[    3.415039] usb 1-11: New USB device found, idVendor=0bda, idProduct=5650, bcdDevice=60.06
[    3.415052] usb 1-11: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    3.415058] usb 1-11: Product: Integrated Webcam_HD
[    3.415063] usb 1-11: Manufacturer: CN0K49W1LOG0087AA80XA01
[    3.415067] usb 1-11: SerialNumber: 200901010001
[    4.267206] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
[    4.272248] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    4.274771] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
[    4.274830] ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[    4.274883] ACPI: video: Video Device [PEGP] (multi-head: yes  rom: yes  post: no)
[    4.274918] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0a/LNXVIDEO:01/input/input8
[    4.313930] fbcon: i915drmfb (fb0) is primary device
[    4.313931] fbcon: Deferring console take-over
[    4.313933] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    4.705856] PM: Image not found (code -22)
[    4.888646] EXT4-fs (nvme0n1p2): mounted filesystem fd23435f-372e-4944-b086-a25067a45439 r/w with ordered data mode. Quota mode: none.
[    5.709900] systemd[1]: systemd 260.2-2-manjaro running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP +LIBARCHIVE)
[    5.709931] systemd[1]: Detected architecture x86-64.
[    5.722132] systemd[1]: Hostname set to <kranich>.
[    6.243006] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    6.564196] systemd[1]: Queued start job for default target Graphical Interface.
[    6.593250] systemd[1]: Created slice CUPS Slice.
[    6.594270] systemd[1]: Created slice Slice /system/dirmngr.
[    6.595168] systemd[1]: Created slice Slice /system/getty.
[    6.596073] systemd[1]: Created slice Slice /system/gpg-agent.
[    6.597020] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    6.597931] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    6.598826] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    6.599797] systemd[1]: Created slice Slice /system/keyboxd.
[    6.600702] systemd[1]: Created slice Slice /system/modprobe.
[    6.601620] systemd[1]: Created slice Slice /system/systemd-fsck.
[    6.602252] systemd[1]: Created slice User and Session Slice.
[    6.602460] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.602959] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.603022] systemd[1]: Expecting device /dev/disk/by-uuid/4cdbecbf-e7cb-4884-931d-55c156add0bb...
[    6.603049] systemd[1]: Expecting device /dev/disk/by-uuid/680b2613-37f4-49f9-8b46-434d27253737...
[    6.603071] systemd[1]: Expecting device /dev/disk/by-uuid/A1F5-20DA...
[    6.603112] systemd[1]: Reached target Login Prompts.
[    6.603152] systemd[1]: Reached target Image Downloads.
[    6.603182] systemd[1]: Reached target Local Integrity Protected Volumes.
[    6.603242] systemd[1]: Reached target Remote File Systems.
[    6.603273] systemd[1]: Reached target Slice Units.
[    6.603349] systemd[1]: Reached target Local Verity Protected Volumes.
[    6.603579] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    6.603833] systemd[1]: Listening on LVM2 poll daemon socket.
[    6.606337] systemd[1]: Listening on Query the User Interactively for a Password.
[    6.609354] systemd[1]: Listening on Process Core Dump Socket.
[    6.611232] systemd[1]: Listening on Credential Encryption/Decryption.
[    6.613421] systemd[1]: Listening on Factory Reset Management.
[    6.613668] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.613889] systemd[1]: Listening on Journal Sockets.
[    6.615982] systemd[1]: Listening on Console Output Muting Service Socket.
[    6.616074] systemd[1]: TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[    6.616156] systemd[1]: Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[    6.617489] systemd[1]: Listening on Disk Repartitioning Service Socket.
[    6.617648] systemd[1]: Listening on udev Control Socket.
[    6.617757] systemd[1]: Listening on udev Kernel Socket.
[    6.617888] systemd[1]: Listening on udev Varlink Socket.
[    6.619456] systemd[1]: Mounting Huge Pages File System...
[    6.620692] systemd[1]: Mounting POSIX Message Queue File System...
[    6.621980] systemd[1]: Mounting Kernel Debug File System...
[    6.623172] systemd[1]: Mounting Kernel Trace File System...
[    6.625321] systemd[1]: Starting Create List of Static Device Nodes...
[    6.626839] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    6.626886] systemd[1]: Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[    6.628232] systemd[1]: Mounting Kernel Configuration File System...
[    6.628275] systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[    6.630014] systemd[1]: Starting Load Kernel Module fuse...
[    6.630148] systemd[1]: File System Check on Root Device skipped, unmet condition check ConditionPathIsReadWrite=!/
[    6.630214] systemd[1]: Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[    6.632354] systemd[1]: Starting Load Kernel Modules...
[    6.632387] systemd[1]: TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    6.633869] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.633952] systemd[1]: Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    6.638638] systemd[1]: Starting Load udev Rules from Credentials...
[    6.639920] systemd[1]: Starting Coldplug All udev Devices...
[    6.641189] systemd[1]: Starting Virtual Console Setup...
[    6.645024] systemd[1]: Mounted Huge Pages File System.
[    6.645215] systemd[1]: Mounted POSIX Message Queue File System.
[    6.645402] systemd[1]: Mounted Kernel Debug File System.
[    6.645602] systemd[1]: Mounted Kernel Trace File System.
[    6.654806] i2c_dev: i2c /dev entries driver
[    6.654877] fuse: init (API version 7.39)
[    6.662163] device-mapper: uevent: version 1.0.3
[    6.662242] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    6.666443] EXT4-fs (nvme0n1p2): re-mounted fd23435f-372e-4944-b086-a25067a45439.
[    6.676442] systemd[1]: Finished Create List of Static Device Nodes.
[    6.679609] systemd[1]: Mounted Kernel Configuration File System.
[    6.679821] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    6.709795] systemd[1]: Finished Load Kernel Module fuse.
[    6.753082] systemd[1]: Finished Remount Root and Kernel File Systems.
[    6.783081] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    6.799831] systemd[1]: Finished Load udev Rules from Credentials.
[    6.833184] systemd[1]: Finished Virtual Console Setup.
[    6.834967] systemd[1]: Mounting FUSE Control File System...
[    6.836230] nvidia: loading out-of-tree module taints kernel.
[    6.836238] nvidia: module license 'NVIDIA' taints kernel.
[    6.836239] Disabling lock debugging due to kernel taint
[    6.836242] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    6.836243] nvidia: module license taints kernel.
[    6.842496] systemd[1]: Rebuild Hardware Database skipped, no trigger condition checks were met.
[    6.866953] systemd[1]: Starting Load/Save OS Random Seed...
[    6.868220] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    6.868243] systemd[1]: TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    6.868278] systemd[1]: TPM PCR NvPCR Initialization Separator skipped, unmet condition check ConditionSecurity=measured-uki
[    6.868305] systemd[1]: TPM NvPCR Product ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    6.870996] systemd[1]: Mounted FUSE Control File System.
[    6.902968] systemd[1]: Finished Load/Save OS Random Seed.
[    6.959719] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    6.960741] systemd[1]: Starting Create System Users...
[    7.039740] systemd[1]: Finished Create System Users.
[    7.042578] systemd[1]: Starting Journal Log Access Socket...
[    7.057858] systemd[1]: Starting Network Time Synchronization...
[    7.058827] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.060491] systemd[1]: Listening on Journal Log Access Socket.
[    7.069329] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 370 ((systemd-times))
[    7.106435] systemd[1]: Finished Create Static Device Nodes in /dev.
[    7.106589] systemd[1]: Reached target Preparation for Local File Systems.
[    7.106663] systemd[1]: Entropy Daemon based on the HAVEGE algorithm skipped, unmet condition check ConditionVersion=<5.6
[    7.109231] systemd[1]: Starting Journal Service...
[    7.109294] systemd[1]: Repartition Root Disk skipped, no trigger condition checks were met.
[    7.110810] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    7.127877] systemd-journald[374]: Collecting audit messages is disabled.
[    7.219642] systemd[1]: Finished Coldplug All udev Devices.
[    7.219976] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    7.220292] systemd[1]: Started Journal Service.
[    7.258529] systemd-journald[374]: Received client request to flush runtime journal.
[    7.476448] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[    7.476456] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
               NVRM:  supported through the NVIDIA 580.xx Legacy drivers. Please
               NVRM:  visit http://www.nvidia.com/object/unix.html for more
               NVRM:  information.  The 610.43.02 NVIDIA driver will ignore
               NVRM:  this GPU.  Continuing probe...
[    7.483827] NVRM: No NVIDIA GPU found.
[    7.489394] nvidia-nvlink: Unregistered Nvlink Core, major device number 510
[    7.609120] input: Intel HID events as /devices/platform/INT33D5:00/input/input9
[    7.612260] mousedev: PS/2 mouse device common for all mice
[    7.612822] intel-hid INT33D5:00: platform supports 5 button array
[    7.613775] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input10
[    7.620372] Consider using thermal netlink events interface
[    7.624047] parport_pc 00:05: [io  0x0378-0x037b]
[    7.639263] parport_pc 00:05: activated
[    7.639267] parport_pc 00:05: reported by Plug and Play ACPI
[    7.679654] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    7.691893] Adding 35225860k swap on /dev/nvme0n1p4.  Priority:-2 extents:1 across:35225860k SS
[    7.738016] mc: Linux media interface: v0.10
[    7.806053] e1000e: Intel(R) PRO/1000 Network Driver
[    7.806056] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    7.812966] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    7.823221] ACPI: battery: new extension: Dell DDV Battery Extension
[    7.824152] input: PC Speaker as /devices/platform/pcspkr/input/input11
[    7.893499] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.893735] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.893893] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    7.925787] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[    7.935173] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[    7.952822] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    7.952838] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    7.952839] RAPL PMU: hw unit of domain package 2^-14 Joules
[    7.952840] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    7.952841] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    7.963229] Intel(R) Wireless WiFi driver for Linux
[    7.963593] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[    7.970301] iwlwifi 0000:02:00.0: Detected crf-id 0xbadcafe, cnv-id 0x10 wfpm id 0x80000000
[    7.970360] iwlwifi 0000:02:00.0: PCI dev 24fd/0050, rev=0x230, rfid=0xd55555d5
[    7.971622] cryptd: max_cpu_qlen set to 1000
[    7.971718] input: Dell WMI hotkeys as /devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input13
[    7.972261] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    7.972291] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    7.989210] i801_smbus 0000:00:1f.4: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[    7.989214] i2c i2c-9: 2/4 memory slots populated (from DMI)
[    7.989836] i2c i2c-9: Successfully instantiated SPD at 0x50
[    7.990685] i2c i2c-9: Successfully instantiated SPD at 0x52
[    7.997573] EXT4-fs (nvme0n1p3): mounted filesystem 4cdbecbf-e7cb-4884-931d-55c156add0bb r/w with ordered data mode. Quota mode: none.
[    8.000557] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) e4:b9:7a:35:f8:65
[    8.000567] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[    8.000627] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[    8.003317] iwlwifi 0000:02:00.0: loaded firmware version 36.c8e8e144.0 8265-36.ucode op_mode iwlmvm
[    8.019780] Bluetooth: Core ver 2.22
[    8.019912] NET: Registered PF_BLUETOOTH protocol family
[    8.019914] Bluetooth: HCI device and connection manager initialized
[    8.019918] Bluetooth: HCI socket layer initialized
[    8.019920] Bluetooth: L2CAP socket layer initialized
[    8.019925] Bluetooth: SCO socket layer initialized
[    8.173802] e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
[    8.524461] AVX2 version of gcm_enc/dec engaged.
[    8.524596] AES CTR mode by8 optimization enabled
[    8.530226] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[    8.536343] videodev: Linux video capture interface: v2.00
[    8.537545] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[    8.537563] NVRM: No NVIDIA GPU found.
[    8.537840] intel_rapl_common: Found RAPL domain package
[    8.537841] intel_rapl_common: Found RAPL domain core
[    8.537842] intel_rapl_common: Found RAPL domain uncore
[    8.537843] intel_rapl_common: Found RAPL domain dram
[    8.538624] ppdev: user-space parallel port driver
[    8.539981] ee1004 9-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[    8.540003] ee1004 9-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[    8.547446] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[    8.599430] input: DualPoint Stick as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL07B0:01/0018:044E:120B.0002/input/input15
[    8.599571] input: DLL07B0:01 044E:120B as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL07B0:01/0018:044E:120B.0002/input/input14
[    8.599676] hid-alps 0018:044E:120B.0002: input,hidraw1: I2C HID v1.00 Mouse [DLL07B0:01 044E:120B] on i2c-DLL07B0:01
[    8.601886] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input12
[    8.629101] iTCO_vendor_support: vendor-support=0
[    8.654789] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[    8.659208] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[    8.659555] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    8.665586] intel_rapl_common: Found RAPL domain package
[    8.665588] intel_rapl_common: Found RAPL domain dram
[    8.697265] dell_laptop: Using i8042 filter function for receiving events
[    8.697266] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[    8.697361] thermal thermal_zone10: failed to read out thermal zone (-61)
[    8.716067] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    8.716524] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[    8.716661] snd_hda_intel 0000:01:00.1: Disabling MSI
[    8.716670] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    8.717526] usb 1-11: Found UVC 1.00 device Integrated Webcam_HD (0bda:5650)
[    8.725590] usbcore: registered new interface driver btusb
[    8.726549] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[    8.727874] Bluetooth: hci0: Device revision is 16
[    8.727877] Bluetooth: hci0: Secure boot is enabled
[    8.727879] Bluetooth: hci0: OTP lock is enabled
[    8.727880] Bluetooth: hci0: API lock is enabled
[    8.727881] Bluetooth: hci0: Debug lock is disabled
[    8.727882] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    8.735589] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[    8.737929] usbcore: registered new interface driver uvcvideo
[    8.761614] usb 1-6: USB disconnect, device number 3
[    8.762333] Bluetooth: hci0: Failed to send firmware signature (-19)
[    8.762343] Bluetooth: hci0: sending frame failed (-19)
[    8.762360] Bluetooth: hci0: FW download error recovery failed (-19)
[    8.762380] Bluetooth: hci0: sending frame failed (-19)
[    8.762383] Bluetooth: hci0: Reading supported features failed (-19)
[    8.762385] Bluetooth: hci0: Error reading debug features
[    8.762386] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[    8.770916] iwlwifi 0000:02:00.0: base HW address: 64:5d:86:e4:f9:e4, OTP minor version: 0x4
[    8.771808] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3254: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:line
[    8.771813] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=1 (0x14/0x0/0x0/0x0/0x0)
[    8.771816] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    8.771818] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    8.771820] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    8.771821] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    8.771823] snd_hda_codec_realtek hdaudioC0D0:      Dock Mic=0x18
[    8.828576] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[    8.828652] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[    8.828724] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[    8.828782] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[    8.872878] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    8.880424] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[    8.889217] intel_tcc_cooling: Programmable TCC Offset detected
[    9.476255] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[    9.477913] input: HDA Intel PCH Dock Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    9.477956] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    9.477990] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[    9.478023] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[    9.478057] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[    9.478089] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[    9.485436] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[    9.485442] NVRM: No NVIDIA GPU found.
[    9.488661] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[    9.533740] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    9.533742] Bluetooth: BNEP filters: protocol multicast
[    9.533745] Bluetooth: BNEP socket layer initialized
[    9.703988] NET: Registered PF_QIPCRTR protocol family
[   10.086674] iwlwifi 0000:02:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
[   14.083278] wlp2s0: authenticate with 94:4a:0c:9d:0a:4b
[   14.083292] wlp2s0: 80 MHz not supported, disabling VHT
[   14.092776] wlp2s0: send auth to 94:4a:0c:9d:0a:4b (try 1/3)
[   14.099571] wlp2s0: authenticated
[   14.106086] wlp2s0: associate with 94:4a:0c:9d:0a:4b (try 1/3)
[   14.110500] wlp2s0: RX AssocResp from 94:4a:0c:9d:0a:4b (capab=0x1411 status=0 aid=2)
[   14.113784] wlp2s0: associated
[   14.186617] wlp2s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 94:4a:0c:9d:0a:4b
[   14.937972] gnome-shell[724]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[   15.593013] rfkill: input handler disabled
[   17.051900] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   17.051906] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   17.059316] NVRM: No NVIDIA GPU found.
[   17.060596] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   17.897315] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   17.897322] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   17.903737] NVRM: No NVIDIA GPU found.
[   17.905361] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   19.670432] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   19.670438] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   19.676756] NVRM: No NVIDIA GPU found.
[   19.678499] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   20.489533] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   20.489538] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   20.495776] NVRM: No NVIDIA GPU found.
[   20.497160] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   21.312420] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   21.312426] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   21.318853] NVRM: No NVIDIA GPU found.
[   21.320416] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   22.088019] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   22.088026] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   22.094423] NVRM: No NVIDIA GPU found.
[   22.096170] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   22.892531] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   22.892537] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   22.901481] NVRM: No NVIDIA GPU found.
[   22.903545] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   23.678393] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   23.678398] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   23.684835] NVRM: No NVIDIA GPU found.
[   23.686564] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   24.433267] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   24.433273] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   24.439566] NVRM: No NVIDIA GPU found.
[   24.441183] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  101.531276] rfkill: input handler enabled
[  103.675416] rfkill: input handler disabled
[  103.999669] block nvme0n1: No UUID available providing old NGUID
[  104.999009] warning: `gnome-shell' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[  106.816505] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  106.816512] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  106.824156] NVRM: No NVIDIA GPU found.
[  106.826069] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  107.864452] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  107.864459] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  107.871127] NVRM: No NVIDIA GPU found.
[  107.872488] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  108.717297] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  108.717303] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  108.723814] NVRM: No NVIDIA GPU found.
[  108.725094] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  110.156223] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  110.156229] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  110.164264] NVRM: No NVIDIA GPU found.
[  110.166047] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  110.991614] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  110.991620] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  110.998041] NVRM: No NVIDIA GPU found.
[  110.999690] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  924.391162] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  924.391169] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  924.397533] NVRM: No NVIDIA GPU found.
[  924.399166] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  925.258084] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  925.258090] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  925.264404] NVRM: No NVIDIA GPU found.
[  925.266103] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  940.421407] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  940.421413] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  940.427895] NVRM: No NVIDIA GPU found.
[  940.429537] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[  941.219440] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[  941.219445] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[  941.225853] NVRM: No NVIDIA GPU found.
[  941.227611] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1281.962915] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1281.962920] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1281.971979] NVRM: No NVIDIA GPU found.
[ 1281.974120] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1283.924590] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1283.924596] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1283.930980] NVRM: No NVIDIA GPU found.
[ 1283.932655] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1284.708363] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1284.708371] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1284.715703] NVRM: No NVIDIA GPU found.
[ 1284.717353] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1285.534190] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1285.534197] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1285.540354] NVRM: No NVIDIA GPU found.
[ 1285.541818] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1286.344123] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1286.344129] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1286.350727] NVRM: No NVIDIA GPU found.
[ 1286.352472] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1391.810845] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 1391.828725] usb 2-1: New USB device found, idVendor=1058, idProduct=25a2, bcdDevice=10.21
[ 1391.828741] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1391.828747] usb 2-1: Product: Elements 25A2
[ 1391.828753] usb 2-1: Manufacturer: Western Digital
[ 1391.828757] usb 2-1: SerialNumber: 57584D314134384134373946
[ 1391.871978] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 1391.872099] scsi host5: usb-storage 2-1:1.0
[ 1391.872172] usbcore: registered new interface driver usb-storage
[ 1391.876135] usbcore: registered new interface driver uas
[ 1392.894624] scsi 5:0:0:0: Direct-Access     WD       Elements 25A2    1021 PQ: 0 ANSI: 6
[ 1392.894782] sd 5:0:0:0: Attached scsi generic sg0 type 0
[ 1392.895972] sd 5:0:0:0: [sda] Spinning up disk...
[ 1393.907364] ...ready
[ 1396.043439] sd 5:0:0:0: [sda] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[ 1396.044578] sd 5:0:0:0: [sda] Write Protect is off
[ 1396.044589] sd 5:0:0:0: [sda] Mode Sense: 47 00 10 08
[ 1396.045356] sd 5:0:0:0: [sda] No Caching mode page found
[ 1396.045366] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 1396.060750]  sda: sda1
[ 1396.060895] sd 5:0:0:0: [sda] Attached SCSI disk
[ 1434.237817] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1434.237824] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1434.244447] NVRM: No NVIDIA GPU found.
[ 1434.246760] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1435.088973] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1435.088978] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1435.096060] NVRM: No NVIDIA GPU found.
[ 1435.097743] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1446.843399] ntfs3: Enabled Linux POSIX ACLs support
[ 1446.843402] ntfs3: Read-only LZX/Xpress compression included
[ 1446.845055] ntfs3: sda1: It is recommened to use chkdsk.
[ 1447.226710] ntfs3: sda1: volume is dirty and "force" flag is not set!
In “Laufwerke” taucht sie nicht auf, auch nicht bei fdisk -l, parted -l und blkid.
Parallel wird auch ein USB-Stick nicht angezeigt, den ich immer viel benutzt habe. Er taucht nicht einmal in lsusb auf, und dmesg zeigt einen fortlaufenden Wechsel der Device-Nr.:
[22743.313734] usb 1-2: USB disconnect, device number 19
[22756.097392] usb 1-1: new high-speed USB device number 21 using xhci_hcd
[22759.763837] usb 1-1: new high-speed USB device number 22 using xhci_hcd
[22759.935716] usb 1-1: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.41
[22759.935732] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[22759.935739] usb 1-1: Product: Mass Storage Device
[22759.935744] usb 1-1: Manufacturer: JetFlash
[22759.935749] usb 1-1: SerialNumber: BEY9I7ND
[22913.486285] usb 1-1: USB disconnect, device number 22
[22946.976406] usb 1-1: new high-speed USB device number 23 using xhci_hcd
[22947.148329] usb 1-1: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.41
[22947.148345] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[22947.148352] usb 1-1: Product: Mass Storage Device
[22947.148358] usb 1-1: Manufacturer: JetFlash
[22947.148363] usb 1-1: SerialNumber: BEY9I7ND
[23591.957626] usb 1-1: USB disconnect, device number 23
[23655.438614] usb 1-1: new high-speed USB device number 24 using xhci_hcd
[23655.613554] usb 1-1: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.41
[23655.613570] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[23655.613577] usb 1-1: Product: Mass Storage Device
[23655.613582] usb 1-1: Manufacturer: JetFlash
[23655.613587] usb 1-1: SerialNumber: BEY9I7ND
[23890.390132] usb 1-1: USB disconnect, device number 24
[24402.344906] usb 1-2: new high-speed USB device number 25 using xhci_hcd
[24402.508277] usb 1-2: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.41
[24402.508293] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[24402.508300] usb 1-2: Product: Mass Storage Device
[24402.508306] usb 1-2: Manufacturer: JetFlash
[24402.508310] usb 1-2: SerialNumber: BEY9I7ND
[24466.536611] usb 1-2: USB disconnect, device number 25
[25227.881246] usb 1-2: new high-speed USB device number 26 using xhci_hcd
[25228.044342] usb 1-2: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.41
[25228.044361] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[25228.044368] usb 1-2: Product: Mass Storage Device
[25228.044374] usb 1-2: Manufacturer: JetFlash
[25228.044378] usb 1-2: SerialNumber: BEY9I7ND
[26006.231006] usb 1-2: USB disconnect, device number 26
Ein anderes externes USB-Laufwerk (Seagate, 1 TB, HDD) funktioniert tadellos.
Fehlen Infos? Was kann ich tun?
Als mir das passiert ist, war USBGuard im weg, dann der aktive USB-HUB. Bei letzterem musste ich den PC komplett ausmachen und den USB-Hub stromlos.
Deine Festplatte ist auch ziemlich voll. Nich das er was zwischen speichern will und abbricht.
Ich kann hierbei zwar nicht weiterhelfen, aber bitte verwende Code-Tags anstelle von Quote-Tags, wenn du Code oder Logs einfügst. Nutze dazu die </>Schaltfläche oder setze drei Backticks in einer eigenen Zeile davor und danach.
Danke, @pwx.
Vielleicht hat das schon etwas verändert: Die Platte taucht in Nautilus auf, ich kriege die Fehlermeldung
Zugreifen auf ‘MO’ nicht möglich
Error mounting sstem-managed device /dev/sda1: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error
Jetzt taucht sie auch bei fdisk -l auf:
❯ sudo fdisk -l
Festplatte /dev/nvme0n1: 476,94 GiB, 512110190592 Bytes, 1000215216 Sektoren
Festplattenmodell: PM981 NVMe Samsung 512GB
Einheiten: Sektoren von 1 * 512 = 512 Bytes
Sektorgröße (logisch/physikalisch): 512 Bytes / 512 Bytes
E/A-Größe (minimal/optimal): 512 Bytes / 512 Bytes
Festplattenbezeichnungstyp: gpt
Festplattenbezeichner: B316CC56-F1A7-4EF0-BFD4-0EF83366F009
Gerät             Anfang       Ende  Sektoren  Größe Typ
/dev/nvme0n1p1      2048     616447    614400   300M EFI-System
/dev/nvme0n1p2    616448  123496447 122880000  58,6G Linux-Dateisystem
/dev/nvme0n1p3 123496448  929755135 806258688 384,5G Linux-Dateisystem
/dev/nvme0n1p4 929755136 1000206866  70451731  33,6G Linux Swap
Festplatte /dev/sda: 931,48 GiB, 1000170586112 Bytes, 1953458176 Sektoren
Festplattenmodell: Elements 25A2
Festplattenbezeichner: 94A1AD9D-E802-4FAA-B560-652F88E50FC8
/dev/sda1    2048 1953456127 1953454080 931,5G Microsoft Basisdaten
Was mache ich nun damit?
Das sieht jetzt nach zwei getrennten Baustellen aus: Die WD-Platte wird als /dev/sda1 erkannt, aber NTFS ist als „dirty“ markiert. Wenn dort wichtige Daten liegen, würde ich nicht mit force mounten. Am saubersten: einmal an Windows hängen und chkdsk /f auf dem Laufwerk laufen lassen, danach sauber auswerfen. Falls kein Windows greifbar ist, kann sudo ntfsfix /dev/sda1 manchmal den Linux-Mount wieder erlauben, ersetzt aber kein echtes chkdsk. Beim JetFlash-Stick mit ständigem Disconnect würde ich zuerst anderen USB-Port/kein Hub/anderes Kabel testen; wenn er weiter verschwindet, ist das eher Strom/Hardware als Nautilus.
Danke, @giulia_privacy408 !
Ich versuche es mit chkdsk /f unter Windows 7 (ich hoffe, 7 ist ausreichend).
Ja, auf dem Laufwerk liegen sehr wichtige Daten – wenn ich das richtig lesen, habe ich nicht mit force gemountet, oder?
Den Stick habe ich schon mit Win7 geprüft und korrigieren lassen, ich versuche es auch noch einmal mit chkdsk /f …
@giulia_privacy408
Auf dem Laufwerk hat chkdsk /f einen frühen Sektor korrigiert, und sie wird jetzt erkannt und gemountet. Allerdings schreibgeschützt – wie ändere ich das?
NTFS scheint jetzt nicht mehr ‘dirty’ zu sein. Aber da steht auch Write Protect is off:
❯ sudo dmesg
[sudo] Passwort für mo:
[    0.000000] Linux version 6.6.143-1-MANJARO (builduser@runnervm7b5n9) (gcc (GCC) 16.1.1 20260430, GNU ld (GNU Binutils) 2.46.0) #1 SMP PREEMPT_DYNAMIC Fri Jun 19 13:56:37 UTC 2026
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=fd23435f-372e-4944-b086-a25067a45439 rw quiet splash apparmor=1 security=apparmor resume=UUID=680b2613-37f4-49f9-8b46-434d27253737 udev.log_priority=3
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000682ddfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000682de000-0x00000000682defff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000682df000-0x00000000682dffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000682e0000-0x00000000780c2fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000780c3000-0x000000007847ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000078480000-0x00000000784cbfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000784cc000-0x0000000078e40fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000078e41000-0x00000000795fefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000795ff000-0x00000000795fffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000079600000-0x000000007f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000087e7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] e820: update [mem 0x6231a018-0x62347257] usable ==> usable
[    0.000000] e820: update [mem 0x62309018-0x62319057] usable ==> usable
[    0.000000] e820: update [mem 0x622f8018-0x62308457] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] reserve setup_data: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000059000-0x000000000009efff] usable
[    0.000000] reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x00000000622f8017] usable
[    0.000000] reserve setup_data: [mem 0x00000000622f8018-0x0000000062308457] usable
[    0.000000] reserve setup_data: [mem 0x0000000062308458-0x0000000062309017] usable
[    0.000000] reserve setup_data: [mem 0x0000000062309018-0x0000000062319057] usable
[    0.000000] reserve setup_data: [mem 0x0000000062319058-0x000000006231a017] usable
[    0.000000] reserve setup_data: [mem 0x000000006231a018-0x0000000062347257] usable
[    0.000000] reserve setup_data: [mem 0x0000000062347258-0x00000000682ddfff] usable
[    0.000000] reserve setup_data: [mem 0x00000000682de000-0x00000000682defff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x00000000682df000-0x00000000682dffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000682e0000-0x00000000780c2fff] usable
[    0.000000] reserve setup_data: [mem 0x00000000780c3000-0x000000007847ffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000078480000-0x00000000784cbfff] ACPI data
[    0.000000] reserve setup_data: [mem 0x00000000784cc000-0x0000000078e40fff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x0000000078e41000-0x00000000795fefff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000795ff000-0x00000000795fffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000079600000-0x000000007f7fffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000087e7fffff] usable
[    0.000000] efi: EFI v2.6 by American Megatrends
[    0.000000] efi: ACPI=0x7848f000 ACPI 2.0=0x7848f000 SMBIOS=0x79364000 SMBIOS 3.0=0x79363000 ESRT=0x7927e018 MEMATTR=0x75923018 INITRD=0x68397e98
[    0.000000] efi: Remove mem37: MMIO range=[0xf0000000-0xf7ffffff] (128MB) from e820 map
[    0.000000] e820: remove [mem 0xf0000000-0xf7ffffff] reserved
[    0.000000] efi: Not removing mem38: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[    0.000000] efi: Not removing mem39: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem40: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[    0.000000] efi: Remove mem41: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[    0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[    0.000000] SMBIOS 3.0.0 present.
[    0.000000] DMI: Dell Inc. Precision 7520/0NP5CM, BIOS 1.40.0 01/23/2025
[    0.000000] tsc: Detected 2900.000 MHz processor
[    0.000000] tsc: Detected 2899.886 MHz TSC
[    0.000985] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000988] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001000] last_pfn = 0x87e800 max_arch_pfn = 0x400000000
[    0.001005] MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variable MTRRs
[    0.001008] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001312] last_pfn = 0x79600 max_arch_pfn = 0x400000000
[    0.010609] found SMP MP-table at [mem 0x000fcec0-0x000fcecf]
[    0.010624] esrt: Reserving ESRT space from 0x000000007927e018 to 0x000000007927e050.
[    0.010634] Using GB pages for direct mapping
[    0.011442] Secure boot disabled
[    0.011443] RAMDISK: [mem 0x62348000-0x647fffff]
[    0.011585] ACPI: Early table checksum verification disabled
[    0.011589] ACPI: RSDP 0x000000007848F000 000024 (v02 DELL  )
[    0.011595] ACPI: XSDT 0x000000007848F0C8 00010C (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.011602] ACPI: FACP 0x00000000784B8730 00010C (v05 DELL   CBX3     01072009 AMI  00010013)
[    0.011609] ACPI: DSDT 0x000000007848F260 0294CE (v02 DELL   CBX3     01072009 INTL 20160422)
[    0.011613] ACPI: FACS 0x0000000078E3EE80 000040
[    0.011617] ACPI: APIC 0x00000000784B8840 0000BC (v03 DELL   CBX3     01072009 AMI  00010013)
[    0.011621] ACPI: FPDT 0x00000000784B8900 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.011625] ACPI: FIDT 0x00000000784B8948 0000AC (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.011628] ACPI: MCFG 0x00000000784B89F8 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
[    0.011632] ACPI: HPET 0x00000000784B8A38 000038 (v01 DELL   CBX3     01072009 AMI. 0005000B)
[    0.011636] ACPI: SSDT 0x00000000784B8A70 000644 (v01 SataRe SataTabl 00001000 INTL 20160422)
[    0.011640] ACPI: SSDT 0x00000000784B90B8 0012FE (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
[    0.011644] ACPI: SSDT 0x00000000784BA3B8 002AD6 (v02 PegSsd PegSsdt  00001000 INTL 20160422)
[    0.011648] ACPI: HPET 0x00000000784BCE90 000038 (v01 INTEL  SKL      00000001 MSFT 0000005F)
[    0.011652] ACPI: SSDT 0x00000000784BCEC8 000BA3 (v02 INTEL  xh_rvp11 00000000 INTL 20160422)
[    0.011656] ACPI: UEFI 0x00000000784BDA70 000042 (v01                 00000000      00000000)
[    0.011660] ACPI: SSDT 0x00000000784BDAB8 000EDE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
[    0.011664] ACPI: LPIT 0x00000000784BE998 000094 (v01 INTEL  SKL      00000000 MSFT 0000005F)
[    0.011668] ACPI: SSDT 0x00000000784BEA30 000141 (v02 INTEL  HdaDsp   00000000 INTL 20160422)
[    0.011672] ACPI: SSDT 0x00000000784BEB78 00029F (v02 INTEL  sensrhub 00000000 INTL 20160422)
[    0.011675] ACPI: SSDT 0x00000000784BEE18 003002 (v02 INTEL  PtidDevc 00001000 INTL 20160422)
[    0.011679] ACPI: SSDT 0x00000000784C1E20 000517 (v02 INTEL  TbtTypeC 00000000 INTL 20160422)
[    0.011683] ACPI: DBGP 0x00000000784C2338 000034 (v01 INTEL           00000002 MSFT 0000005F)
[    0.011687] ACPI: DBG2 0x00000000784C2370 000054 (v00 INTEL           00000002 MSFT 0000005F)
[    0.011691] ACPI: SSDT 0x00000000784C23C8 0007AC (v02 INTEL  UsbCTabl 00001000 INTL 20160422)
[    0.011694] ACPI: SSDT 0x00000000784C2B78 005394 (v02 DptfTa DptfTabl 00001000 INTL 20160422)
[    0.011698] ACPI: MSDM 0x00000000784C7F10 000055 (v03 DELL   CBX3     06222004 AMI  00010013)
[    0.011702] ACPI: SLIC 0x00000000784C7F68 000176 (v03 DELL   CBX3     01072009 MSFT 00010013)
[    0.011706] ACPI: SSDT 0x00000000784C80E0 0000AE (v02 SgRef  SgPeg    00001000 INTL 20160422)
[    0.011710] ACPI: DMAR 0x00000000784C8190 0000F0 (v01 INTEL  SKL      00000001 INTL 00000001)
[    0.011714] ACPI: SSDT 0x00000000784C8280 001D85 (v01 OptRef OptTabl  00001000 INTL 20160422)
[    0.011718] ACPI: ASF! 0x00000000784CA008 0000A0 (v32 INTEL   HCG     00000001 TFSM 000F4240)
[    0.011722] ACPI: BGRT 0x00000000784CA0A8 000038 (v00 \xf3\xee              01072009 AMI  00010013)
[    0.011725] ACPI: Reserving FACP table memory at [mem 0x784b8730-0x784b883b]
[    0.011727] ACPI: Reserving DSDT table memory at [mem 0x7848f260-0x784b872d]
[    0.011728] ACPI: Reserving FACS table memory at [mem 0x78e3ee80-0x78e3eebf]
[    0.011729] ACPI: Reserving APIC table memory at [mem 0x784b8840-0x784b88fb]
[    0.011730] ACPI: Reserving FPDT table memory at [mem 0x784b8900-0x784b8943]
[    0.011731] ACPI: Reserving FIDT table memory at [mem 0x784b8948-0x784b89f3]
[    0.011731] ACPI: Reserving MCFG table memory at [mem 0x784b89f8-0x784b8a33]
[    0.011732] ACPI: Reserving HPET table memory at [mem 0x784b8a38-0x784b8a6f]
[    0.011733] ACPI: Reserving SSDT table memory at [mem 0x784b8a70-0x784b90b3]
[    0.011734] ACPI: Reserving SSDT table memory at [mem 0x784b90b8-0x784ba3b5]
[    0.011735] ACPI: Reserving SSDT table memory at [mem 0x784ba3b8-0x784bce8d]
[    0.011736] ACPI: Reserving HPET table memory at [mem 0x784bce90-0x784bcec7]
[    0.011737] ACPI: Reserving SSDT table memory at [mem 0x784bcec8-0x784bda6a]
[    0.011738] ACPI: Reserving UEFI table memory at [mem 0x784bda70-0x784bdab1]
[    0.011739] ACPI: Reserving SSDT table memory at [mem 0x784bdab8-0x784be995]
[    0.011740] ACPI: Reserving LPIT table memory at [mem 0x784be998-0x784bea2b]
[    0.011740] ACPI: Reserving SSDT table memory at [mem 0x784bea30-0x784beb70]
[    0.011741] ACPI: Reserving SSDT table memory at [mem 0x784beb78-0x784bee16]
[    0.011742] ACPI: Reserving SSDT table memory at [mem 0x784bee18-0x784c1e19]
[    0.011743] ACPI: Reserving SSDT table memory at [mem 0x784c1e20-0x784c2336]
[    0.011744] ACPI: Reserving DBGP table memory at [mem 0x784c2338-0x784c236b]
[    0.011745] ACPI: Reserving DBG2 table memory at [mem 0x784c2370-0x784c23c3]
[    0.011746] ACPI: Reserving SSDT table memory at [mem 0x784c23c8-0x784c2b73]
[    0.011747] ACPI: Reserving SSDT table memory at [mem 0x784c2b78-0x784c7f0b]
[    0.011748] ACPI: Reserving MSDM table memory at [mem 0x784c7f10-0x784c7f64]
[    0.011749] ACPI: Reserving SLIC table memory at [mem 0x784c7f68-0x784c80dd]
[    0.011750] ACPI: Reserving SSDT table memory at [mem 0x784c80e0-0x784c818d]
[    0.011750] ACPI: Reserving DMAR table memory at [mem 0x784c8190-0x784c827f]
[    0.011751] ACPI: Reserving SSDT table memory at [mem 0x784c8280-0x784ca004]
[    0.011752] ACPI: Reserving ASF! table memory at [mem 0x784ca008-0x784ca0a7]
[    0.011753] ACPI: Reserving BGRT table memory at [mem 0x784ca0a8-0x784ca0df]
[    0.011884] No NUMA configuration found
[    0.011885] Faking a node at [mem 0x0000000000000000-0x000000087e7fffff]
[    0.011889] NODE_DATA(0) allocated [mem 0x87e7fb000-0x87e7fffff]
[    0.011944] Zone ranges:
[    0.011945]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.011947]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.011949]   Normal   [mem 0x0000000100000000-0x000000087e7fffff]
[    0.011951]   Device   empty
[    0.011952] Movable zone start for each node
[    0.011953] Early memory node ranges
[    0.011953]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.011955]   node   0: [mem 0x0000000000059000-0x000000000009efff]
[    0.011956]   node   0: [mem 0x0000000000100000-0x00000000682ddfff]
[    0.011958]   node   0: [mem 0x00000000682e0000-0x00000000780c2fff]
[    0.011959]   node   0: [mem 0x00000000795ff000-0x00000000795fffff]
[    0.011960]   node   0: [mem 0x0000000100000000-0x000000087e7fffff]
[    0.011964] Initmem setup node 0 [mem 0x0000000000001000-0x000000087e7fffff]
[    0.011969] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.011971] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.011993] On node 0, zone DMA: 97 pages in unavailable ranges
[    0.014775] On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.014830] On node 0, zone DMA32: 5436 pages in unavailable ranges
[    0.060425] On node 0, zone Normal: 27136 pages in unavailable ranges
[    0.060489] On node 0, zone Normal: 6144 pages in unavailable ranges
[    0.060516] Reserving Intel graphics memory at [mem 0x7b800000-0x7f7fffff]
[    0.061277] ACPI: PM-Timer IO Port: 0x1808
[    0.061286] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.061288] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.061289] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.061290] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.061291] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.061292] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.061293] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.061294] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.061321] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.061324] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.061326] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.061331] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.061333] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.061341] e820: update [mem 0x73e88000-0x73f10fff] usable ==> reserved
[    0.061356] TSC deadline timer available
[    0.061357] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.061376] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.061379] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.061381] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.061383] PM: hibernation: Registered nosave memory: [mem 0x682de000-0x682dffff]
[    0.061385] PM: hibernation: Registered nosave memory: [mem 0x73e88000-0x73f10fff]
[    0.061387] PM: hibernation: Registered nosave memory: [mem 0x780c3000-0x795fefff]
[    0.061389] PM: hibernation: Registered nosave memory: [mem 0x79600000-0xffffffff]
[    0.061390] [mem 0x7f800000-0xfdffffff] available for PCI devices
[    0.061392] Booting paravirtualized kernel on bare hardware
[    0.061394] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.069260] setup_percpu: NR_CPUS:320 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[    0.069615] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[    0.069623] pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
[    0.069625] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.069646] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=fd23435f-372e-4944-b086-a25067a45439 rw quiet splash apparmor=1 security=apparmor resume=UUID=680b2613-37f4-49f9-8b46-434d27253737 udev.log_priority=3
[    0.069765] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.069803] random: crng init done
[    0.072555] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.073933] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.074063] Fallback order for Node 0: 0
[    0.074066] Built 1 zonelists, mobility grouping on.  Total pages: 8219166
[    0.074067] Policy zone: Normal
[    0.074271] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.074279] software IO TLB: area num 8.
[    0.152060] Memory: 32621456K/33399164K available (18432K kernel code, 2149K rwdata, 13132K rodata, 3512K init, 4548K bss, 777452K reserved, 0K cma-reserved)
[    0.152329] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.152342] Kernel/User page tables isolation: enabled
[    0.152374] ftrace: allocating 49431 entries in 194 pages
[    0.162320] ftrace: allocated 194 pages with 3 groups
[    0.162402] Dynamic Preempt: full
[    0.162452] rcu: Preemptible hierarchical RCU implementation.
[    0.162453] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[    0.162454] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.162456] 	Trampoline variant of Tasks RCU enabled.
[    0.162456] 	Rude variant of Tasks RCU enabled.
[    0.162457] 	Tracing variant of Tasks RCU enabled.
[    0.162457] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.162458] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.166624] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[    0.166852] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.167128] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.167167] Console: colour dummy device 80x25
[    0.167170] printk: console [tty0] enabled
[    0.167225] ACPI: Core revision 20230628
[    0.167451] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.167505] APIC: Switch to symmetric I/O mode setup
[    0.167507] DMAR: Host address width 39
[    0.167508] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.167515] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
[    0.167518] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.167523] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.167525] DMAR: RMRR base: 0x0000007819b000 end: 0x000000781bafff
[    0.167527] DMAR: RMRR base: 0x0000007b000000 end: 0x0000007f7fffff
[    0.167528] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[    0.167530] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[    0.167532] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.167533] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.167534] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.169135] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.169137] x2apic enabled
[    0.169210] APIC: Switched APIC routing to: cluster x2apic
[    0.172999] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x29ccd767b87, max_idle_ns: 440795223720 ns
[    0.173005] Calibrating delay loop (skipped), value calculated using timer frequency.. 5802.42 BogoMIPS (lpj=9666286)
[    0.173032] x86/cpu: SGX disabled by BIOS.
[    0.173038] CPU0: Thermal monitoring enabled (TM1)
[    0.173090] process: using mwait in idle threads
[    0.173093] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.173094] Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
[    0.173101] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.173105] Spectre V2 : Mitigation: IBRS
[    0.173106] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
[    0.173107] RETBleed: Mitigation: IBRS
[    0.173109] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.173110] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.173113] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.173119] MDS: Mitigation: Clear CPU buffers
[    0.173120] TAA: Mitigation: TSX disabled
[    0.173121] MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.173125] SRBDS: Mitigation: Microcode
[    0.173126] GDS: Vulnerable: No microcode
[    0.173128] VMSCAPE: Mitigation: IBPB before exit to userspace
[    0.173134] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.173136] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.173137] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.173139] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.173140] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.173142] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.173144] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.173146] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.173148] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.176336] Freeing SMP alternatives memory: 40K
[    0.176336] pid_max: default: 32768 minimum: 301
[    0.176336] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor,integrity
[    0.176336] landlock: Up and running.
[    0.176336] Yama: becoming mindful.
[    0.176336] LSM support for eBPF active
[    0.176336] AppArmor: AppArmor initialized
[    0.176336] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.176336] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.176336] smpboot: CPU0: Intel(R) Core(TM) i7-6920HQ CPU @ 2.90GHz (family: 0x6, model: 0x5e, stepping: 0x3)
[    0.176336] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.176336] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.176336] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.176336] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.176336] ... version:                4
[    0.176336] ... bit width:              48
[    0.176336] ... generic registers:      4
[    0.176336] ... value mask:             0000ffffffffffff
[    0.176336] ... max period:             00007fffffffffff
[    0.176336] ... fixed-purpose events:   3
[    0.176336] ... event mask:             000000070000000f
[    0.176336] signal: max sigframe size: 2032
[    0.176336] Estimated ratio of average max frequency by base frequency (times 1024): 1200
[    0.176336] rcu: Hierarchical SRCU implementation.
[    0.176336] rcu: 	Max phase no-delay instances is 1000.
[    0.176336] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.176336] smp: Bringing up secondary CPUs ...
[    0.176336] smpboot: x86: Booting SMP configuration:
[    0.176336] .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
[    0.176819] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.176819] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.176819] VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
[    0.176819] smp: Brought up 1 node, 8 CPUs
[    0.176819] smpboot: Max logical packages: 1
[    0.176819] smpboot: Total of 8 processors activated (46416.43 BogoMIPS)
[    0.180676] devtmpfs: initialized
[    0.180676] x86/mm: Memory block size: 128MB
[    0.183839] ACPI: PM: Registering ACPI NVS region [mem 0x682de000-0x682defff] (4096 bytes)
[    0.183839] ACPI: PM: Registering ACPI NVS region [mem 0x784cc000-0x78e40fff] (9916416 bytes)
[    0.183839] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.183839] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.183839] pinctrl core: initialized pinctrl subsystem
[    0.183839] PM: RTC time: 19:12:10, date: 2026-06-29
[    0.184186] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.184688] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.184959] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.185235] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.185262] audit: initializing netlink subsys (disabled)
[    0.185281] audit: type=2000 audit(1782760330.009:1): state=initialized audit_enabled=0 res=1
[    0.185281] thermal_sys: Registered thermal governor 'fair_share'
[    0.185281] thermal_sys: Registered thermal governor 'bang_bang'
[    0.185281] thermal_sys: Registered thermal governor 'step_wise'
[    0.185281] thermal_sys: Registered thermal governor 'user_space'
[    0.185281] thermal_sys: Registered thermal governor 'power_allocator'
[    0.185281] cpuidle: using governor ladder
[    0.186351] cpuidle: using governor menu
[    0.188040] efi: Freeing EFI boot services memory: 46956K
[    0.188044] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.188045] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.188149] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.188163] PCI: Using configuration type 1 for base access
[    0.188533] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.188542] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.196349] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.196351] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.196353] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.196355] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.196538] ACPI: Added _OSI(Module Device)
[    0.196538] ACPI: Added _OSI(Processor Device)
[    0.196538] ACPI: Added _OSI(Processor Aggregator Device)
[    0.259854] ACPI: 14 ACPI AML tables successfully acquired and loaded
[    0.271576] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.284024] ACPI: Dynamic OEM Table Load:
[    0.284034] ACPI: SSDT 0xFFFF8881011FD400 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.286193] ACPI: Dynamic OEM Table Load:
[    0.286200] ACPI: SSDT 0xFFFF8881011F6800 000672 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.289379] ACPI: Dynamic OEM Table Load:
[    0.289387] ACPI: SSDT 0xFFFF8881011F3800 00065C (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.292018] ACPI: Dynamic OEM Table Load:
[    0.292025] ACPI: SSDT 0xFFFF888101E2A400 00018A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.300073] ACPI: _OSC evaluated successfully for all CPUs
[    0.300363] ACPI: EC: EC started
[    0.300365] ACPI: EC: interrupt blocked
[    0.311841] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.311845] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
[    0.311847] ACPI: Interpreter enabled
[    0.311901] ACPI: PM: (supports S0 S3 S4 S5)
[    0.311904] ACPI: Using IOAPIC for interrupt routing
[    0.314506] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.314508] PCI: Ignoring E820 reservations for host bridge windows
[    0.315546] ACPI: Enabled 8 GPEs in block 00 to 7F
[    0.318608] ACPI: \_SB_.PCI0.PEG0.PG00: New power resource
[    0.473997] ACPI: \_SB_.PCI0.PEG1.PG01: New power resource
[    0.474549] ACPI: \_SB_.PCI0.PEG2.PG02: New power resource
[    0.480138] ACPI: \_SB_.PCI0.RP09.PXSX.WRST: New power resource
[    0.480621] ACPI: \_SB_.PCI0.RP10.PXSX.WRST: New power resource
[    0.481103] ACPI: \_SB_.PCI0.RP11.PXSX.WRST: New power resource
[    0.481585] ACPI: \_SB_.PCI0.RP12.PXSX.WRST: New power resource
[    0.482060] ACPI: \_SB_.PCI0.RP13.PXSX.WRST: New power resource
[    0.482533] ACPI: \_SB_.PCI0.RP01.PXSX.WRST: New power resource
[    0.483032] ACPI: \_SB_.PCI0.RP02.PXSX.WRST: New power resource
[    0.483516] ACPI: \_SB_.PCI0.RP03.PXSX.WRST: New power resource
[    0.483999] ACPI: \_SB_.PCI0.RP04.PXSX.WRST: New power resource
[    0.484474] ACPI: \_SB_.PCI0.RP05.PXSX.WRST: New power resource
[    0.485696] ACPI: \_SB_.PCI0.RP06.PXSX.WRST: New power resource
[    0.486179] ACPI: \_SB_.PCI0.RP07.PXSX.WRST: New power resource
[    0.486671] ACPI: \_SB_.PCI0.RP08.PXSX.WRST: New power resource
[    0.487154] ACPI: \_SB_.PCI0.RP17.PXSX.WRST: New power resource
[    0.487636] ACPI: \_SB_.PCI0.RP18.PXSX.WRST: New power resource
[    0.488122] ACPI: \_SB_.PCI0.RP19.PXSX.WRST: New power resource
[    0.488599] ACPI: \_SB_.PCI0.RP20.PXSX.WRST: New power resource
[    0.490628] ACPI: \_SB_.PCI0.RP14.PXSX.WRST: New power resource
[    0.491105] ACPI: \_SB_.PCI0.RP15.PXSX.WRST: New power resource
[    0.491583] ACPI: \_SB_.PCI0.RP16.PXSX.WRST: New power resource
[    0.523000] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
[    0.523025] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.523883] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    0.525553] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[    0.525556] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.527196] PCI host bridge to bus 0000:00
[    0.527199] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.527202] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.527204] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.527206] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xefffffff window]
[    0.527208] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.527209] pci_bus 0000:00: root bus resource [bus 00-7e]
[    0.527235] pci 0000:00:00.0: [8086:1910] type 00 class 0x060000
[    0.527350] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.527388] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.527392] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.527395] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
[    0.527405] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.527443] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.528049] pci 0000:00:02.0: [8086:191b] type 00 class 0x030000
[    0.528072] pci 0000:00:02.0: BAR 0 [mem 0xeb000000-0xebffffff 64bit]
[    0.528088] pci 0000:00:02.0: BAR 2 [mem 0x80000000-0x8fffffff 64bit pref]
[    0.528099] pci 0000:00:02.0: BAR 4 [io  0xf000-0xf03f]
[    0.528134] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.528140] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.528383] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.528402] pci 0000:00:04.0: BAR 0 [mem 0xed440000-0xed447fff 64bit]
[    0.528864] pci 0000:00:14.0: [8086:a12f] type 00 class 0x0c0330
[    0.528905] pci 0000:00:14.0: BAR 0 [mem 0xed430000-0xed43ffff 64bit]
[    0.529042] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.530063] pci 0000:00:14.2: [8086:a131] type 00 class 0x118000
[    0.530101] pci 0000:00:14.2: BAR 0 [mem 0xed459000-0xed459fff 64bit]
[    0.530433] pci 0000:00:15.0: [8086:a160] type 00 class 0x118000
[    0.530642] pci 0000:00:15.0: BAR 0 [mem 0xed458000-0xed458fff 64bit]
[    0.531903] pci 0000:00:15.1: [8086:a161] type 00 class 0x118000
[    0.532112] pci 0000:00:15.1: BAR 0 [mem 0xed457000-0xed457fff 64bit]
[    0.533359] pci 0000:00:16.0: [8086:a13a] type 00 class 0x078000
[    0.533388] pci 0000:00:16.0: BAR 0 [mem 0xed456000-0xed456fff 64bit]
[    0.533478] pci 0000:00:16.0: PME# supported from D3hot
[    0.533912] pci 0000:00:16.3: [8086:a13d] type 00 class 0x070002
[    0.533938] pci 0000:00:16.3: BAR 0 [io  0xf0a0-0xf0a7]
[    0.533950] pci 0000:00:16.3: BAR 1 [mem 0xed455000-0xed455fff]
[    0.534121] pci 0000:00:17.0: [8086:a102] type 00 class 0x010601
[    0.534152] pci 0000:00:17.0: BAR 0 [mem 0xed450000-0xed451fff]
[    0.534171] pci 0000:00:17.0: BAR 1 [mem 0xed454000-0xed4540ff]
[    0.534189] pci 0000:00:17.0: BAR 2 [io  0xf090-0xf097]
[    0.534208] pci 0000:00:17.0: BAR 3 [io  0xf080-0xf083]
[    0.534221] pci 0000:00:17.0: BAR 4 [io  0xf060-0xf07f]
[    0.534239] pci 0000:00:17.0: BAR 5 [mem 0xed453000-0xed4537ff]
[    0.534312] pci 0000:00:17.0: PME# supported from D3hot
[    0.534756] pci 0000:00:1c.0: [8086:a111] type 01 class 0x060400
[    0.534816] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.534826] pci 0000:00:1c.0:   bridge window [mem 0xed300000-0xed3fffff]
[    0.534920] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.535858] pci 0000:00:1c.2: [8086:a112] type 01 class 0x060400
[    0.535925] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.535935] pci 0000:00:1c.2:   bridge window [mem 0xed200000-0xed2fffff]
[    0.536046] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.536993] pci 0000:00:1c.4: [8086:a114] type 01 class 0x060400
[    0.537060] pci 0000:00:1c.4: PCI bridge to [bus 04-3c]
[    0.537070] pci 0000:00:1c.4:   bridge window [mem 0xd4000000-0xea0fffff]
[    0.537084] pci 0000:00:1c.4:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.537189] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.538133] pci 0000:00:1d.0: [8086:a118] type 01 class 0x060400
[    0.538194] pci 0000:00:1d.0: PCI bridge to [bus 3d]
[    0.538203] pci 0000:00:1d.0:   bridge window [mem 0xed100000-0xed1fffff]
[    0.538300] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.539258] pci 0000:00:1f.0: [8086:a154] type 00 class 0x060100
[    0.539887] pci 0000:00:1f.2: [8086:a121] type 00 class 0x058000
[    0.539918] pci 0000:00:1f.2: BAR 0 [mem 0xed44c000-0xed44ffff]
[    0.540385] pci 0000:00:1f.3: [8086:a171] type 00 class 0x040300
[    0.540426] pci 0000:00:1f.3: BAR 0 [mem 0xed448000-0xed44bfff 64bit]
[    0.540487] pci 0000:00:1f.3: BAR 4 [mem 0xed420000-0xed42ffff 64bit]
[    0.540554] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.541487] pci 0000:00:1f.4: [8086:a123] type 00 class 0x0c0500
[    0.541555] pci 0000:00:1f.4: BAR 0 [mem 0xed452000-0xed4520ff 64bit]
[    0.541639] pci 0000:00:1f.4: BAR 4 [io  0xf040-0xf05f]
[    0.542079] pci 0000:00:1f.6: [8086:15e3] type 00 class 0x020000
[    0.542110] pci 0000:00:1f.6: BAR 0 [mem 0xed400000-0xed41ffff]
[    0.542267] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.542699] pci 0000:01:00.0: [10de:1436] type 00 class 0x030000
[    0.542725] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00ffffff]
[    0.542746] pci 0000:01:00.0: BAR 1 [mem 0x00000000-0x0fffffff 64bit pref]
[    0.542768] pci 0000:01:00.0: BAR 3 [mem 0x00000000-0x01ffffff 64bit pref]
[    0.542779] pci 0000:01:00.0: BAR 5 [io  0x0000-0x007f]
[    0.542791] pci 0000:01:00.0: ROM [mem 0x00000000-0x0007ffff pref]
[    0.542803] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
[    0.542836] pci 0000:01:00.0: Enabling HDA controller
[    0.543853] pci 0000:01:00.1: [10de:0fba] type 00 class 0x040300
[    0.543879] pci 0000:01:00.1: BAR 0 [mem 0x00000000-0x00003fff]
[    0.543952] pci 0000:01:00.1: Max Payload Size set to 256 (was 128, max 256)
[    0.544096] pci 0000:00:01.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[    0.553060] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.553685] pci 0000:02:00.0: [8086:24fd] type 00 class 0x028000
[    0.554291] pci 0000:02:00.0: BAR 0 [mem 0xed300000-0xed301fff 64bit]
[    0.555986] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.558075] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.558308] pci 0000:03:00.0: [10ec:525a] type 00 class 0xff0000
[    0.558391] pci 0000:03:00.0: BAR 1 [mem 0xed200000-0xed200fff]
[    0.558784] pci 0000:03:00.0: supports D1 D2
[    0.558785] pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.559710] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.559890] pci 0000:00:1c.4: PCI bridge to [bus 04-3c]
[    0.560246] pci 0000:3d:00.0: [144d:a808] type 00 class 0x010802
[    0.560288] pci 0000:3d:00.0: BAR 0 [mem 0xed100000-0xed103fff 64bit]
[    0.561382] pci 0000:00:1d.0: PCI bridge to [bus 3d]
[    0.569309] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[    0.569399] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[    0.569486] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[    0.569573] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[    0.569660] ACPI: PCI: Interrupt link LNKE configured for IRQ 11
[    0.569750] ACPI: PCI: Interrupt link LNKF configured for IRQ 11
[    0.569837] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[    0.569924] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[    0.576741] ACPI: EC: interrupt unblocked
[    0.576743] ACPI: EC: event unblocked
[    0.576750] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.576752] ACPI: EC: GPE=0x14
[    0.576753] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC initialization complete
[    0.576756] ACPI: \_SB_.PCI0.LPCB.ECDV: EC: Used to handle transactions and events
[    0.576892] iommu: Default domain type: Translated
[    0.576892] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.576892] SCSI subsystem initialized
[    0.576892] libata version 3.00 loaded.
[    0.576892] ACPI: bus type USB registered
[    0.576892] usbcore: registered new interface driver usbfs
[    0.576892] usbcore: registered new interface driver hub
[    0.576892] usbcore: registered new device driver usb
[    0.576892] pps_core: LinuxPPS API ver. 1 registered
[    0.576892] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.576892] PTP clock support registered
[    0.576892] EDAC MC: Ver: 3.0.0
[    0.577365] efivars: Registered efivars operations
[    0.577365] NetLabel: Initializing
[    0.577365] NetLabel:  domain hash size = 128
[    0.577365] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.577365] NetLabel:  unlabeled traffic allowed by default
[    0.577365] mctp: management component transport protocol core
[    0.577365] NET: Registered PF_MCTP protocol family
[    0.577365] PCI: Using ACPI for IRQ routing
[    0.591248] PCI: pci_cache_line_size set to 64 bytes
[    0.592236] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.592249] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.592250] e820: reserve RAM buffer [mem 0x622f8018-0x63ffffff]
[    0.592252] e820: reserve RAM buffer [mem 0x62309018-0x63ffffff]
[    0.592254] e820: reserve RAM buffer [mem 0x6231a018-0x63ffffff]
[    0.592255] e820: reserve RAM buffer [mem 0x682de000-0x6bffffff]
[    0.592256] e820: reserve RAM buffer [mem 0x73e88000-0x73ffffff]
[    0.592258] e820: reserve RAM buffer [mem 0x780c3000-0x7bffffff]
[    0.592259] e820: reserve RAM buffer [mem 0x79600000-0x7bffffff]
[    0.592261] e820: reserve RAM buffer [mem 0x87e800000-0x87fffffff]
[    0.592314] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.592314] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.592314] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.592314] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.592314] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.592314] vgaarb: loaded
[    0.592314] clocksource: Switched to clocksource tsc-early
[    0.592314] VFS: Disk quotas dquot_6.6.0
[    0.592314] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.592314] AppArmor: AppArmor Filesystem Enabled
[    0.592314] pnp: PnP ACPI init
[    0.592314] pnp 00:00: disabling [io  0x002e-0x002f] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.592314] pnp 00:00: disabling [io  0x004e-0x004f] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.592314] pnp 00:00: disabling [io  0x0061] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.592314] pnp 00:00: disabling [io  0x0063] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.592314] pnp 00:00: disabling [io  0x0065] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.592314] pnp 00:00: disabling [io  0x0067] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.592314] pnp 00:00: disabling [io  0x0070] because it overlaps 0000:01:00.0 BAR 5 [io  0x0000-0x007f]
[    0.592314] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.592314] system 00:00: [io  0xffff] has been reserved
[    0.592314] system 00:00: [io  0x1800-0x18fe] could not be reserved
[    0.592314] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.592314] system 00:01: [io  0x0800-0x087f] has been reserved
[    0.593626] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.593630] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.593633] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.593635] system 00:06: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.593637] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.593639] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.593642] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.593644] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.593646] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.593650] system 00:06: [mem 0xeffe0000-0xefffffff] has been reserved
[    0.593715] system 00:07: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.593718] system 00:07: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.593721] system 00:07: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.593723] system 00:07: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.593725] system 00:07: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.593728] system 00:07: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.593730] system 00:07: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.594186] system 00:08: [io  0xff00-0xfffe] has been reserved
[    0.596096] system 00:09: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.596099] system 00:09: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.596102] system 00:09: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.604598] pnp: PnP ACPI: found 10 devices
[    0.610791] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.610865] NET: Registered PF_INET protocol family
[    0.611025] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.614484] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.614531] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.614661] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.615034] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.615348] TCP: Hash tables configured (established 262144 bind 65536)
[    0.615477] MPTCP token hash table entries: 32768 (order: 8, 786432 bytes, linear)
[    0.615636] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.615724] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.615815] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.615822] NET: Registered PF_XDP protocol family
[    0.615839] pci 0000:00:1c.4: bridge window [io  0x1000-0x0fff] to [bus 04-3c] add_size 1000
[    0.615850] pci 0000:00:1c.4: bridge window [io  0x2000-0x2fff]: assigned
[    0.615855] pci 0000:01:00.0: BAR 1 [mem 0xc0000000-0xcfffffff 64bit pref]: assigned
[    0.615875] pci 0000:01:00.0: BAR 3 [mem 0xd0000000-0xd1ffffff 64bit pref]: assigned
[    0.615893] pci 0000:01:00.0: BAR 0 [mem 0xec000000-0xecffffff]: assigned
[    0.615900] pci 0000:01:00.0: ROM [mem 0xed000000-0xed07ffff pref]: assigned
[    0.615902] pci 0000:01:00.1: BAR 0 [mem 0xed080000-0xed083fff]: assigned
[    0.615908] pci 0000:01:00.0: BAR 5 [io  0xe000-0xe07f]: assigned
[    0.615915] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.615917] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.615925] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
[    0.615931] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.615943] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.615954] pci 0000:00:1c.0:   bridge window [mem 0xed300000-0xed3fffff]
[    0.615974] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.615985] pci 0000:00:1c.2:   bridge window [mem 0xed200000-0xed2fffff]
[    0.616005] pci 0000:00:1c.4: PCI bridge to [bus 04-3c]
[    0.616010] pci 0000:00:1c.4:   bridge window [io  0x2000-0x2fff]
[    0.616021] pci 0000:00:1c.4:   bridge window [mem 0xd4000000-0xea0fffff]
[    0.616044] pci 0000:00:1c.4:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.616059] pci 0000:00:1d.0: PCI bridge to [bus 3d]
[    0.616072] pci 0000:00:1d.0:   bridge window [mem 0xed100000-0xed1fffff]
[    0.616093] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.616095] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.616097] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.616099] pci_bus 0000:00: resource 7 [mem 0x7f800000-0xefffffff window]
[    0.616100] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[    0.616102] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.616104] pci_bus 0000:01: resource 1 [mem 0xec000000-0xed0fffff]
[    0.616106] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.616108] pci_bus 0000:02: resource 1 [mem 0xed300000-0xed3fffff]
[    0.616110] pci_bus 0000:03: resource 1 [mem 0xed200000-0xed2fffff]
[    0.616111] pci_bus 0000:04: resource 0 [io  0x2000-0x2fff]
[    0.616113] pci_bus 0000:04: resource 1 [mem 0xd4000000-0xea0fffff]
[    0.616115] pci_bus 0000:04: resource 2 [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.616117] pci_bus 0000:3d: resource 1 [mem 0xed100000-0xed1fffff]
[    0.617996] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    0.618041] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.618478] PCI: CLS 0 bytes, default 64
[    0.618530] pci 0000:00:1f.1: [8086:a120] type 00 class 0x058000
[    0.618599] pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
[    0.618876] DMAR: ACPI device "device:7a" under DMAR at fed91000 as 00:15.0
[    0.618881] DMAR: ACPI device "device:7b" under DMAR at fed91000 as 00:15.1
[    0.618893] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.618894] software IO TLB: mapped [mem 0x000000006fe88000-0x0000000073e88000] (64MB)
[    0.618934] Trying to unpack rootfs image as initramfs...
[    0.623750] Initialise system trusted keyrings
[    0.623769] Key type blacklist registered
[    0.623816] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[    0.623828] zbud: loaded
[    0.624084] integrity: Platform Keyring initialized
[    0.624088] integrity: Machine keyring initialized
[    0.642430] Key type asymmetric registered
[    0.642434] Asymmetric key parser 'x509' registered
[    0.642465] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.642514] io scheduler mq-deadline registered
[    0.642516] io scheduler kyber registered
[    0.642532] io scheduler bfq registered
[    0.643511] pcieport 0000:00:1c.0: AER: enabled with IRQ 123
[    0.643923] pcieport 0000:00:1c.2: AER: enabled with IRQ 124
[    0.644300] pcieport 0000:00:1c.4: AER: enabled with IRQ 125
[    0.644699] pcieport 0000:00:1d.0: AER: enabled with IRQ 126
[    0.644867] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.648185] ACPI: AC: AC Adapter [AC] (on-line)
[    0.648268] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    0.648392] ACPI: button: Lid Switch [LID0]
[    0.648437] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.648560] ACPI: button: Power Button [PBTN]
[    0.648605] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[    0.648629] ACPI: button: Sleep Button [SBTN]
[    0.648663] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    0.648786] ACPI: button: Power Button [PWRF]
[    0.651446] thermal LNXTHERM:00: registered as thermal_zone0
[    0.651449] ACPI: thermal: Thermal Zone [THM] (25 C)
[    0.651634] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.655332] serial 0000:00:16.3: enabling device (0000 -> 0003)
[    0.656741] 0000:00:16.3: ttyS4 at I/O 0xf0a0 (irq = 19, base_baud = 115200) is a 16550A
[    0.658258] hpet_acpi_add: no address or irqs in _CRS
[    0.658321] Non-volatile memory driver v1.3
[    0.658323] Linux agpgart interface v0.103
[    0.658372] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    0.658813] ACPI: bus type drm_connector registered
[    0.664152] ahci 0000:00:17.0: version 3.0
[    0.665576] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[    0.665609] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 3 ports 6 Gbps 0x1a impl SATA mode
[    0.665614] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm led clo only pio slum part ems sxs deso sadm sds apst
[    0.685105] scsi host0: ahci
[    0.685377] scsi host1: ahci
[    0.685631] scsi host2: ahci
[    0.685828] scsi host3: ahci
[    0.685982] scsi host4: ahci
[    0.686042] ata1: DUMMY
[    0.686048] ata2: SATA max UDMA/133 abar m2048@0xed453000 port 0xed453180 irq 127
[    0.686050] ata3: DUMMY
[    0.686052] ata4: SATA max UDMA/133 abar m2048@0xed453000 port 0xed453280 irq 127
[    0.686055] ata5: SATA max UDMA/133 abar m2048@0xed453000 port 0xed453300 irq 127
[    0.686217] usbcore: registered new interface driver usbserial_generic
[    0.686224] usbserial: USB Serial support registered for generic
[    0.686374] rtc_cmos 00:02: RTC can wake from S4
[    0.687115] rtc_cmos 00:02: registered as rtc0
[    0.687246] rtc_cmos 00:02: setting system clock to 2026-06-29T19:12:11 UTC (1782760331)
[    0.687284] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram
[    0.687758] intel_pstate: Intel P-state driver initializing
[    0.688554] intel_pstate: HWP enabled
[    0.689067] ledtrig-cpu: registered to indicate activity on CPUs
[    0.689813] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[    0.690531] fbcon: Deferring console take-over
[    0.690534] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.690579] hid: raw HID events driver (C) Jiri Kosina
[    0.690638] resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
[    0.690641] caller get_primary_reg_base+0x4d/0xa0 mapping multiple BARs
[    0.690657] intel_pmc_core INT33A1:00:  initialized
[    0.690790] drop_monitor: Initializing network drop monitor service
[    0.699468] ACPI: battery: Slot [BAT0] (battery present)
[    0.703018] Initializing XFRM netlink socket
[    0.703046] NET: Registered PF_INET6 protocol family
[    0.740256] Freeing initrd memory: 37600K
[    0.748031] Segment Routing with IPv6
[    0.748033] RPL Segment Routing with IPv6
[    0.748057] In-situ OAM (IOAM) with IPv6
[    0.748080] NET: Registered PF_PACKET protocol family
[    0.748783] microcode: Current revision: 0x000000f0
[    0.749169] microcode: Microcode Update Driver: v2.2.
[    0.749173] IPI shorthand broadcast: enabled
[    0.750755] sched_clock: Marking stable (743334680, 6024824)->(797051530, -47692026)
[    0.750966] registered taskstats version 1
[    0.751711] Loading compiled-in X.509 certificates
[    0.753926] Loaded X.509 cert 'Build time autogenerated kernel key: 820581c157c08c28edf553270c9ce7a1598a9cb4'
[    0.755578] zswap: loaded using pool zstd/zsmalloc
[    0.757400] Key type .fscrypt registered
[    0.757401] Key type fscrypt-provisioning registered
[    0.757431] AppArmor: AppArmor sha1 policy hashing enabled
[    0.757730] integrity: Loading X.509 certificate: UEFI:db
[    0.757762] integrity: Loaded X.509 cert 'Dell Inc. UEFI DB: 5ddb772dc880660055ba0bc131886bb630a639e7'
[    0.757763] integrity: Loading X.509 certificate: UEFI:db
[    0.757777] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    0.757778] integrity: Loading X.509 certificate: UEFI:db
[    0.757790] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    0.758524] PM:   Magic number: 14:364:244
[    0.758568] pci_express 0000:00:1d.0:pcie010: hash matches
[    0.758594] acpi device:5a: hash matches
[    0.762288] RAS: Correctable Errors collector initialized.
[    1.014370] ata2: SATA link down (SStatus 0 SControl 300)
[    1.322815] ata4: SATA link down (SStatus 4 SControl 300)
[    1.632825] ata5: SATA link down (SStatus 4 SControl 300)
[    1.633120] clk: Disabling unused clocks
[    1.637148] Freeing unused decrypted memory: 2028K
[    1.638773] Freeing unused kernel image (initmem) memory: 3512K
[    1.638864] Write protecting the kernel read-only data: 32768k
[    1.639350] Freeing unused kernel image (rodata/data gap) memory: 1204K
[    1.639371] tsc: Refined TSC clocksource calibration: 2903.999 MHz
[    1.639376] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x29dc050a48e, max_idle_ns: 440795325698 ns
[    1.639430] clocksource: Switched to clocksource tsc
[    1.679488] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.679491] rodata_test: all tests were successful
[    1.679492] x86/mm: Checking user space page tables
[    1.715875] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.715878] Run /init as init process
[    1.715879]   with arguments:
[    1.715880]     /init
[    1.715881]     splash
[    1.715881]   with environment:
[    1.715882]     HOME=/
[    1.715883]     TERM=linux
[    2.171237] wmi_bus wmi_bus-PNP0C14:03: WQBC data block query control method not found
[    2.171774] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    2.171782] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    2.172897] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000001109810
[    2.173357] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    2.173360] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    2.173362] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    2.173404] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    2.173407] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.173409] usb usb1: Product: xHCI Host Controller
[    2.173410] usb usb1: Manufacturer: Linux 6.6.143-1-MANJARO xhci-hcd
[    2.173411] usb usb1: SerialNumber: 0000:00:14.0
[    2.173587] hub 1-0:1.0: USB hub found
[    2.173622] hub 1-0:1.0: 16 ports detected
[    2.175475] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    2.175763] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    2.201999] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[    2.202004] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.202006] usb usb2: Product: xHCI Host Controller
[    2.202008] usb usb2: Manufacturer: Linux 6.6.143-1-MANJARO xhci-hcd
[    2.202010] usb usb2: SerialNumber: 0000:00:14.0
[    2.202147] hub 2-0:1.0: USB hub found
[    2.202198] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    2.202252] hub 2-0:1.0: 10 ports detected
[    2.202939] i8042: Warning: Keylock active
[    2.205654] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.205691] serio: i8042 AUX port at 0x60,0x64 irq 12
[    2.208852] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    2.209417] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    2.224681] rtsx_pci 0000:03:00.0: enabling device (0000 -> 0002)
[    2.250991] nvme nvme0: pci function 0000:3d:00.0
[    2.256629] nvme nvme0: Shutdown timeout set to 8 seconds
[    2.265513] nvme nvme0: 8/0/0 default/read/poll queues
[    2.269840]  nvme0n1: p1 p2 p3 p4
[    2.286918] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    2.456080] usb 1-4: new low-speed USB device number 2 using xhci_hcd
[    2.599522] usb 1-4: New USB device found, idVendor=30fa, idProduct=0300, bcdDevice= 1.00
[    2.599525] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.599527] usb 1-4: Product: USB Optical Mouse
[    2.656713] input: USB Optical Mouse  as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:30FA:0300.0001/input/input6
[    2.656764] hid-generic 0003:30FA:0300.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse ] on usb-0000:00:14.0-4/input0
[    2.656785] usbcore: registered new interface driver usbhid
[    2.656787] usbhid: USB HID core driver
[    2.693278] i915 0000:00:02.0: vgaarb: deactivate vga console
[    2.695701] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[    2.696159] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[    2.726206] usb 1-6: new full-speed USB device number 3 using xhci_hcd
[    2.736835] i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
[    2.736843] i915 0000:00:02.0: [drm] [ENCODER:117:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
[    2.736848] i915 0000:00:02.0: [drm] [ENCODER:127:DDI D/PHY D] is disabled/in DSI mode with an ungated DDI clock, gate it
[    2.868988] usb 1-6: New USB device found, idVendor=8087, idProduct=0a2b, bcdDevice= 0.10
[    2.869002] usb 1-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.996177] usb 1-10: new full-speed USB device number 4 using xhci_hcd
[    3.139115] usb 1-10: New USB device found, idVendor=0a5c, idProduct=5832, bcdDevice= 1.01
[    3.139129] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.139135] usb 1-10: Product: 5880
[    3.139139] usb 1-10: Manufacturer: Broadcom Corp
[    3.139144] usb 1-10: SerialNumber: 0123456789ABCD
[    3.269686] usb 1-11: new high-speed USB device number 5 using xhci_hcd
[    3.442418] usb 1-11: New USB device found, idVendor=0bda, idProduct=5650, bcdDevice=60.06
[    3.442432] usb 1-11: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    3.442438] usb 1-11: Product: Integrated Webcam_HD
[    3.442443] usb 1-11: Manufacturer: CN0K49W1LOG0087AA80XA01
[    3.442447] usb 1-11: SerialNumber: 200901010001
[    4.266574] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
[    4.272180] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    4.274752] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
[    4.274904] ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[    4.274963] ACPI: video: Video Device [PEGP] (multi-head: yes  rom: yes  post: no)
[    4.274997] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0a/LNXVIDEO:01/input/input8
[    4.314456] fbcon: i915drmfb (fb0) is primary device
[    4.314458] fbcon: Deferring console take-over
[    4.314461] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    4.671695] PM: Image not found (code -22)
[    4.843376] EXT4-fs (nvme0n1p2): mounted filesystem fd23435f-372e-4944-b086-a25067a45439 r/w with ordered data mode. Quota mode: none.
[    5.625092] systemd[1]: systemd 260.2-2-manjaro running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP +LIBARCHIVE)
[    5.625123] systemd[1]: Detected architecture x86-64.
[    5.636898] systemd[1]: Hostname set to <kranich>.
[    6.142956] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    6.432884] systemd[1]: Queued start job for default target Graphical Interface.
[    6.467349] systemd[1]: Created slice CUPS Slice.
[    6.468718] systemd[1]: Created slice Slice /system/dirmngr.
[    6.469935] systemd[1]: Created slice Slice /system/getty.
[    6.470842] systemd[1]: Created slice Slice /system/gpg-agent.
[    6.471756] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    6.472657] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    6.473617] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    6.474510] systemd[1]: Created slice Slice /system/keyboxd.
[    6.475406] systemd[1]: Created slice Slice /system/modprobe.
[    6.476327] systemd[1]: Created slice Slice /system/systemd-fsck.
[    6.476959] systemd[1]: Created slice User and Session Slice.
[    6.477162] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.477649] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.477709] systemd[1]: Expecting device /dev/disk/by-uuid/4cdbecbf-e7cb-4884-931d-55c156add0bb...
[    6.477733] systemd[1]: Expecting device /dev/disk/by-uuid/680b2613-37f4-49f9-8b46-434d27253737...
[    6.477752] systemd[1]: Expecting device /dev/disk/by-uuid/A1F5-20DA...
[    6.477798] systemd[1]: Reached target Login Prompts.
[    6.477837] systemd[1]: Reached target Image Downloads.
[    6.477869] systemd[1]: Reached target Local Integrity Protected Volumes.
[    6.477924] systemd[1]: Reached target Remote File Systems.
[    6.477959] systemd[1]: Reached target Slice Units.
[    6.478030] systemd[1]: Reached target Local Verity Protected Volumes.
[    6.478262] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    6.478521] systemd[1]: Listening on LVM2 poll daemon socket.
[    6.480846] systemd[1]: Listening on Query the User Interactively for a Password.
[    6.483775] systemd[1]: Listening on Process Core Dump Socket.
[    6.485393] systemd[1]: Listening on Credential Encryption/Decryption.
[    6.487191] systemd[1]: Listening on Factory Reset Management.
[    6.487419] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.487636] systemd[1]: Listening on Journal Sockets.
[    6.489726] systemd[1]: Listening on Console Output Muting Service Socket.
[    6.489799] systemd[1]: TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[    6.489827] systemd[1]: Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[    6.490919] systemd[1]: Listening on Disk Repartitioning Service Socket.
[    6.491060] systemd[1]: Listening on udev Control Socket.
[    6.491159] systemd[1]: Listening on udev Kernel Socket.
[    6.491289] systemd[1]: Listening on udev Varlink Socket.
[    6.492849] systemd[1]: Mounting Huge Pages File System...
[    6.494083] systemd[1]: Mounting POSIX Message Queue File System...
[    6.495253] systemd[1]: Mounting Kernel Debug File System...
[    6.496367] systemd[1]: Mounting Kernel Trace File System...
[    6.498171] systemd[1]: Starting Create List of Static Device Nodes...
[    6.499692] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    6.499748] systemd[1]: Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[    6.500907] systemd[1]: Mounting Kernel Configuration File System...
[    6.500952] systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[    6.502346] systemd[1]: Starting Load Kernel Module fuse...
[    6.502473] systemd[1]: File System Check on Root Device skipped, unmet condition check ConditionPathIsReadWrite=!/
[    6.502553] systemd[1]: Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[    6.507851] systemd[1]: Starting Load Kernel Modules...
[    6.507886] systemd[1]: TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    6.509014] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.509093] systemd[1]: Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    6.510348] systemd[1]: Starting Load udev Rules from Credentials...
[    6.511406] systemd[1]: Starting Coldplug All udev Devices...
[    6.512657] systemd[1]: Starting Virtual Console Setup...
[    6.516986] systemd[1]: Mounted Huge Pages File System.
[    6.517164] systemd[1]: Mounted POSIX Message Queue File System.
[    6.517342] systemd[1]: Mounted Kernel Debug File System.
[    6.517512] systemd[1]: Mounted Kernel Trace File System.
[    6.526573] fuse: init (API version 7.39)
[    6.530199] i2c_dev: i2c /dev entries driver
[    6.535842] device-mapper: uevent: version 1.0.3
[    6.535906] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    6.543038] systemd[1]: Finished Create List of Static Device Nodes.
[    6.546242] systemd[1]: Mounted Kernel Configuration File System.
[    6.546358] EXT4-fs (nvme0n1p2): re-mounted fd23435f-372e-4944-b086-a25067a45439.
[    6.546530] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    6.582982] systemd[1]: Finished Load Kernel Module fuse.
[    6.613015] systemd[1]: Finished Remount Root and Kernel File Systems.
[    6.636420] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    6.653143] systemd[1]: Finished Load udev Rules from Credentials.
[    6.696546] systemd[1]: Finished Virtual Console Setup.
[    6.702082] nvidia: loading out-of-tree module taints kernel.
[    6.702090] nvidia: module license 'NVIDIA' taints kernel.
[    6.702091] Disabling lock debugging due to kernel taint
[    6.702094] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    6.702095] nvidia: module license taints kernel.
[    6.704456] systemd[1]: Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
[    6.705419] systemd[1]: Starting Load/Save OS Random Seed...
[    6.706638] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    6.706664] systemd[1]: TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    6.706696] systemd[1]: TPM PCR NvPCR Initialization Separator skipped, unmet condition check ConditionSecurity=measured-uki
[    6.706726] systemd[1]: TPM NvPCR Product ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    6.786285] systemd[1]: Finished Load/Save OS Random Seed.
[    6.836543] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    6.836713] systemd[1]: Create System Users skipped, no trigger condition checks were met.
[    6.838244] systemd[1]: Starting Journal Log Access Socket...
[    6.870707] systemd[1]: Starting Network Time Synchronization...
[    6.871566] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.873443] systemd[1]: Listening on Journal Log Access Socket.
[    6.882120] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 360 ((systemd-times))
[    6.936269] systemd[1]: Finished Create Static Device Nodes in /dev.
[    6.936441] systemd[1]: Reached target Preparation for Local File Systems.
[    6.936484] systemd[1]: Entropy Daemon based on the HAVEGE algorithm skipped, unmet condition check ConditionVersion=<5.6
[    6.938190] systemd[1]: Starting Journal Service...
[    6.938241] systemd[1]: Repartition Root Disk skipped, no trigger condition checks were met.
[    6.939188] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    6.992925] systemd-journald[364]: Collecting audit messages is disabled.
[    7.046288] systemd[1]: Finished Coldplug All udev Devices.
[    7.069218] systemd[1]: Started Journal Service.
[    7.118507] systemd-journald[364]: Received client request to flush runtime journal.
[    7.326579] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[    7.326589] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
               NVRM:  supported through the NVIDIA 580.xx Legacy drivers. Please
               NVRM:  visit http://www.nvidia.com/object/unix.html for more
               NVRM:  information.  The 610.43.02 NVIDIA driver will ignore
               NVRM:  this GPU.  Continuing probe...
[    7.350982] NVRM: No NVIDIA GPU found.
[    7.354141] nvidia-nvlink: Unregistered Nvlink Core, major device number 510
[    7.459660] mousedev: PS/2 mouse device common for all mice
[    7.460924] input: Intel HID events as /devices/platform/INT33D5:00/input/input9
[    7.461051] intel-hid INT33D5:00: platform supports 5 button array
[    7.461095] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input10
[    7.461565] Consider using thermal netlink events interface
[    7.504473] parport_pc 00:05: [io  0x0378-0x037b]
[    7.507796] parport_pc 00:05: activated
[    7.507799] parport_pc 00:05: reported by Plug and Play ACPI
[    7.645405] Adding 35225860k swap on /dev/nvme0n1p4.  Priority:-2 extents:1 across:35225860k SS
[    7.673607] mc: Linux media interface: v0.10
[    7.694238] e1000e: Intel(R) PRO/1000 Network Driver
[    7.694241] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    7.694483] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    7.707842] ACPI: battery: new extension: Dell DDV Battery Extension
[    7.714665] input: PC Speaker as /devices/platform/pcspkr/input/input11
[    7.804952] EXT4-fs (nvme0n1p3): mounted filesystem 4cdbecbf-e7cb-4884-931d-55c156add0bb r/w with ordered data mode. Quota mode: none.
[    7.821902] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[    7.827469] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[    7.827475] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    7.828443] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    7.828475] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    7.843994] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    7.843997] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    7.843999] RAPL PMU: hw unit of domain package 2^-14 Joules
[    7.844000] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    7.844000] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    7.850688] i801_smbus 0000:00:1f.4: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[    7.850693] i2c i2c-9: 2/4 memory slots populated (from DMI)
[    7.852776] i2c i2c-9: Successfully instantiated SPD at 0x50
[    7.853423] i2c i2c-9: Successfully instantiated SPD at 0x52
[    7.897851] input: Dell WMI hotkeys as /devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input13
[    7.914683] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) e4:b9:7a:35:f8:65
[    7.914693] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[    7.914751] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[    7.939896] cryptd: max_cpu_qlen set to 1000
[    7.944793] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.946412] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.946631] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    7.985413] Bluetooth: Core ver 2.22
[    7.985431] NET: Registered PF_BLUETOOTH protocol family
[    7.985432] Bluetooth: HCI device and connection manager initialized
[    7.985435] Bluetooth: HCI socket layer initialized
[    7.985437] Bluetooth: L2CAP socket layer initialized
[    7.985441] Bluetooth: SCO socket layer initialized
[    7.996955] videodev: Linux video capture interface: v2.00
[    8.106220] e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
[    8.478973] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input12
[    8.580728] Intel(R) Wireless WiFi driver for Linux
[    8.581085] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[    8.583291] ppdev: user-space parallel port driver
[    8.583987] AVX2 version of gcm_enc/dec engaged.
[    8.584172] AES CTR mode by8 optimization enabled
[    8.585219] intel_rapl_common: Found RAPL domain package
[    8.585222] intel_rapl_common: Found RAPL domain core
[    8.585223] intel_rapl_common: Found RAPL domain uncore
[    8.585224] intel_rapl_common: Found RAPL domain dram
[    8.588512] iTCO_vendor_support: vendor-support=0
[    8.591459] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[    8.591716] iwlwifi 0000:02:00.0: Detected crf-id 0xbadcafe, cnv-id 0x10 wfpm id 0x80000000
[    8.591777] iwlwifi 0000:02:00.0: PCI dev 24fd/0050, rev=0x230, rfid=0xd55555d5
[    8.592031] ee1004 9-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[    8.600436] usb 1-6: USB disconnect, device number 3
[    8.600482] ee1004 9-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[    8.603778] dell_laptop: Using i8042 filter function for receiving events
[    8.605782] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[    8.605787] NVRM: No NVIDIA GPU found.
[    8.607652] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[    8.611187] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[    8.611387] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    8.612630] input: DualPoint Stick as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL07B0:01/0018:044E:120B.0002/input/input15
[    8.612730] input: DLL07B0:01 044E:120B as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL07B0:01/0018:044E:120B.0002/input/input14
[    8.613426] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[    8.617276] hid-alps 0018:044E:120B.0002: input,hidraw1: I2C HID v1.00 Mouse [DLL07B0:01 044E:120B] on i2c-DLL07B0:01
[    8.628994] iwlwifi 0000:02:00.0: loaded firmware version 36.c8e8e144.0 8265-36.ucode op_mode iwlmvm
[    8.634367] usbcore: registered new interface driver btusb
[    8.634831] intel_rapl_common: Found RAPL domain package
[    8.634833] intel_rapl_common: Found RAPL domain dram
[    8.636496] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    8.637550] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[    8.637637] snd_hda_intel 0000:01:00.1: Disabling MSI
[    8.637645] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    8.642353] usb 1-11: Found UVC 1.00 device Integrated Webcam_HD (0bda:5650)
[    8.710587] usbcore: registered new interface driver uvcvideo
[    8.783358] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3254: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:line
[    8.783364] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=1 (0x14/0x0/0x0/0x0/0x0)
[    8.783367] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    8.783369] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    8.783370] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    8.783372] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    8.783374] snd_hda_codec_realtek hdaudioC0D0:      Dock Mic=0x18
[    8.807705] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[    8.807802] thermal thermal_zone10: failed to read out thermal zone (-61)
[    8.829391] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[    8.832756] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[    8.832832] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[    8.832890] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[    8.870751] iwlwifi 0000:02:00.0: base HW address: 64:5d:86:e4:f9:e4, OTP minor version: 0x4
[    8.881628] NET: Registered PF_QIPCRTR protocol family
[    8.932442] intel_tcc_cooling: Programmable TCC Offset detected
[    9.163043] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    9.170925] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[    9.424494] iwlwifi 0000:02:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
[    9.578449] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[    9.581206] input: HDA Intel PCH Dock Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    9.581269] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    9.581323] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[    9.581404] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[    9.581459] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[    9.581518] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[    9.585745] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[    9.585751] NVRM: No NVIDIA GPU found.
[    9.589203] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   13.402456] wlp2s0: authenticate with 94:4a:0c:9d:0a:4b
[   13.402471] wlp2s0: 80 MHz not supported, disabling VHT
[   13.415529] wlp2s0: send auth to 94:4a:0c:9d:0a:4b (try 1/3)
[   13.423354] wlp2s0: authenticated
[   13.426076] wlp2s0: associate with 94:4a:0c:9d:0a:4b (try 1/3)
[   13.430316] wlp2s0: RX AssocResp from 94:4a:0c:9d:0a:4b (capab=0x1411 status=0 aid=3)
[   13.433697] wlp2s0: associated
[   13.593136] wlp2s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 94:4a:0c:9d:0a:4b
[   14.920510] gnome-shell[706]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[   15.608788] rfkill: input handler disabled
[   17.109267] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   17.109273] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   17.116137] NVRM: No NVIDIA GPU found.
[   17.117678] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   17.950520] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   17.950526] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   17.957096] NVRM: No NVIDIA GPU found.
[   17.958737] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   19.062291] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe B (start=879 end=880) time 756 us, min 894, max 899, scanline start 868, end 910
[   19.741336] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   19.741342] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   19.747865] NVRM: No NVIDIA GPU found.
[   19.749315] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   20.581905] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   20.581911] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   20.588641] NVRM: No NVIDIA GPU found.
[   20.590344] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   21.374899] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   21.374905] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   21.381273] NVRM: No NVIDIA GPU found.
[   21.382974] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   22.199166] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   22.199172] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   22.205521] NVRM: No NVIDIA GPU found.
[   22.206975] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   22.998345] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   22.998351] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   23.004615] NVRM: No NVIDIA GPU found.
[   23.006099] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   23.791173] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   23.791179] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   23.797625] NVRM: No NVIDIA GPU found.
[   23.799047] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   24.577436] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   24.577444] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   24.584024] NVRM: No NVIDIA GPU found.
[   24.585951] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   25.316960] rfkill: input handler enabled
[   27.354722] rfkill: input handler disabled
[   27.710096] block nvme0n1: No UUID available providing old NGUID
[   28.366435] warning: `gnome-shell' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[   30.383599] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   30.383608] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   30.392061] NVRM: No NVIDIA GPU found.
[   30.393814] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   31.282646] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   31.282653] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   31.292558] NVRM: No NVIDIA GPU found.
[   31.294713] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   32.172997] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   32.173013] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   32.179599] NVRM: No NVIDIA GPU found.
[   32.180957] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   33.649944] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   33.649950] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   33.656660] NVRM: No NVIDIA GPU found.
[   33.658146] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[   34.484573] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[   34.484580] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[   34.491024] NVRM: No NVIDIA GPU found.
[   34.492599] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1024.827103] usb 1-2: new high-speed USB device number 6 using xhci_hcd
[ 1025.289237] usb 1-2: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.41
[ 1025.289252] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1025.289259] usb 1-2: Product: Mass Storage Device
[ 1025.289264] usb 1-2: Manufacturer: JetFlash
[ 1025.289269] usb 1-2: SerialNumber: BEY9I7ND
[ 1025.334079] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 1025.334170] usb-storage 1-2:1.0: Quirks match for vid 058f pid 6387: 400
[ 1025.334238] scsi host5: usb-storage 1-2:1.0
[ 1025.334322] usbcore: registered new interface driver usb-storage
[ 1025.338204] usbcore: registered new interface driver uas
[ 1026.367235] scsi 5:0:0:0: Direct-Access     JetFlash TS2GJFV10        8.07 PQ: 0 ANSI: 2
[ 1026.367488] sd 5:0:0:0: Attached scsi generic sg0 type 0
[ 1026.368329] sd 5:0:0:0: [sda] 4005888 512-byte logical blocks: (2.05 GB/1.91 GiB)
[ 1026.368485] sd 5:0:0:0: [sda] Write Protect is off
[ 1026.368489] sd 5:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 1026.368648] sd 5:0:0:0: [sda] No Caching mode page found
[ 1026.368651] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 1026.370841]  sda: sda1
[ 1026.370952] sd 5:0:0:0: [sda] Attached SCSI removable disk
[ 1034.112553] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1034.112559] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1034.119216] NVRM: No NVIDIA GPU found.
[ 1034.120831] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1034.958367] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 1034.958373] NVRM: The NVIDIA Quadro M2200 GPU installed in this system is
[ 1034.964782] NVRM: No NVIDIA GPU found.
[ 1034.966231] nvidia-nvlink: Unregistered Nvlink Core, major device number 508
[ 1108.521694]  sda: sda1
[ 1108.577142]  sda: sda1
[ 1114.072962] usb 1-2: USB disconnect, device number 6
[ 1122.566727] usb 1-2: new high-speed USB device number 7 using xhci_hcd
[ 1122.712386] usb 1-2: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.41
[ 1122.712407] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1122.712414] usb 1-2: Product: Mass Storage Device
[ 1122.712419] usb 1-2: Manufacturer: JetFlash
[ 1122.712424] usb 1-2: SerialNumber: BEY9I7ND
[ 1122.715264] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 1122.715617] usb-storage 1-2:1.0: Quirks match for vid 058f pid 6387: 400
[ 1122.715787] scsi host5: usb-storage 1-2:1.0
[ 1123.727706] scsi 5:0:0:0: Direct-Access     JetFlash TS2GJFV10        8.07 PQ: 0 ANSI: 2
[ 1123.728338] sd 5:0:0:0: Attached scsi generic sg0 type 0
[ 1123.729696] sd 5:0:0:0: [sda] 4005888 512-byte logical blocks: (2.05 GB/1.91 GiB)
[ 1123.730020] sd 5:0:0:0: [sda] Write Protect is off
[ 1123.730032] sd 5:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 1123.730256] sd 5:0:0:0: [sda] No Caching mode page found
[ 1123.730266] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 1123.733560]  sda: sda1
[ 1123.733682] sd 5:0:0:0: [sda] Attached SCSI removable disk
[ 1132.049385]  sda: sda1
[ 1132.107865]  sda: sda1
[ 1137.217486] usb 1-2: USB disconnect, device number 7
[ 1535.909173] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 1535.926717] usb 2-1: New USB device found, idVendor=1058, idProduct=25a2, bcdDevice=10.21
[ 1535.926732] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1535.926740] usb 2-1: Product: Elements 25A2
[ 1535.926745] usb 2-1: Manufacturer: Western Digital
[ 1535.926750] usb 2-1: SerialNumber: 57584D314134384134373946
[ 1535.929641] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 1535.930321] scsi host5: usb-storage 2-1:1.0
[ 1536.946800] scsi 5:0:0:0: Direct-Access     WD       Elements 25A2    1021 PQ: 0 ANSI: 6
[ 1536.947444] sd 5:0:0:0: Attached scsi generic sg0 type 0
[ 1536.948930] sd 5:0:0:0: [sda] Spinning up disk...
[ 1537.958882] ...ready
[ 1540.091925] sd 5:0:0:0: [sda] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[ 1540.092903] sd 5:0:0:0: [sda] Write Protect is off
[ 1540.092914] sd 5:0:0:0: [sda] Mode Sense: 47 00 10 08
[ 1540.093684] sd 5:0:0:0: [sda] No Caching mode page found
[ 1540.093694] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 1540.107456]  sda: sda1
[ 1540.107788] sd 5:0:0:0: [sda] Attached SCSI disk
[ 1553.882696] ntfs3: Enabled Linux POSIX ACLs support
[ 1553.882698] ntfs3: Read-only LZX/Xpress compression included
[ 1839.031329] usb 2-1: USB disconnect, device number 2
[ 3646.844718] wlp2s0: deauthenticating from 94:4a:0c:9d:0a:4b by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3647.680435] PM: suspend entry (deep)
[ 3647.687598] Filesystems sync: 0.007 seconds
[ 3647.723280] Freezing user space processes
[ 3647.726074] Freezing user space processes completed (elapsed 0.002 seconds)
[ 3647.726080] OOM killer disabled.
[ 3647.726081] Freezing remaining freezable tasks
[ 3647.727356] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ 3647.727433] printk: Suspending console(s) (use no_console_suspend to debug)
[ 3647.747526] e1000e: EEE TX LPI TIMER: 00000011
[ 3647.953175] ACPI: EC: interrupt blocked
[ 3648.168353] ACPI: PM: Preparing to enter system sleep state S3
[ 3648.175274] ACPI: EC: event blocked
[ 3648.175275] ACPI: EC: EC stopped
[ 3648.175275] ACPI: PM: Saving platform NVS memory
[ 3648.175376] Disabling non-boot CPUs ...
[ 3648.176712] smpboot: CPU 1 is now offline
[ 3648.178829] smpboot: CPU 2 is now offline
[ 3648.180651] smpboot: CPU 3 is now offline
[ 3648.182652] smpboot: CPU 4 is now offline
[ 3648.184250] smpboot: CPU 5 is now offline
[ 3648.185901] smpboot: CPU 6 is now offline
[ 3648.187502] smpboot: CPU 7 is now offline
[ 3648.189499] ACPI: PM: Low-level resume complete
[ 3648.189552] ACPI: EC: EC started
[ 3648.189553] ACPI: PM: Restoring platform NVS memory
[ 3648.190382] Enabling non-boot CPUs ...
[ 3648.190526] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 3648.191496] CPU1 is up
[ 3648.191648] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 3648.192364] CPU2 is up
[ 3648.192478] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 3648.193203] CPU3 is up
[ 3648.193347] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 3648.194397] CPU4 is up
[ 3648.194549] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 3648.195292] CPU5 is up
[ 3648.195460] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 3648.196212] CPU6 is up
[ 3648.196346] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 3648.197185] CPU7 is up
[ 3648.199900] ACPI: PM: Waking up from system sleep state S3
[ 3648.524439] ACPI: EC: interrupt unblocked
[ 3649.800912] pci 0000:01:00.0: Enabling HDA controller
[ 3649.803750] ACPI: EC: event unblocked
[ 3649.897326] i915 0000:00:02.0: [drm] [ENCODER:94:DDI A/PHY A] is disabled/in DSI mode with an ungated DDI clock, gate it
[ 3649.897340] i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
[ 3649.897351] i915 0000:00:02.0: [drm] [ENCODER:117:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
[ 3649.897360] i915 0000:00:02.0: [drm] [ENCODER:127:DDI D/PHY D] is disabled/in DSI mode with an ungated DDI clock, gate it
[ 3649.904316] nvme nvme0: Shutdown timeout set to 8 seconds
[ 3649.915977] nvme nvme0: 8/0/0 default/read/poll queues
[ 3650.252286] i2c_hid_acpi i2c-DLL07B0:01: i2c_hid_get_input: incomplete report (83/65369)
[ 3650.276642] ata2: SATA link down (SStatus 0 SControl 300)
[ 3650.277348] ata4: SATA link down (SStatus 4 SControl 300)
[ 3650.277382] ata5: SATA link down (SStatus 4 SControl 300)
[ 3650.337339] usb 1-4: reset low-speed USB device number 2 using xhci_hcd
[ 3650.767043] usb 1-11: reset high-speed USB device number 5 using xhci_hcd
[ 3651.030849] usb 1-10: reset full-speed USB device number 4 using xhci_hcd
[ 3651.181801] OOM killer enabled.
[ 3651.181807] Restarting tasks ...
[ 3651.185519] acpi PNP0501:00: Still not present
[ 3651.186538] done.
[ 3651.186555] random: crng reseeded on system resumption
[ 3651.243891] PM: suspend exit
[ 3651.365100] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Down
[ 3655.496983] wlp2s0: authenticate with 94:4a:0c:9d:0a:4b
[ 3655.496996] wlp2s0: 80 MHz not supported, disabling VHT
[ 3655.509555] wlp2s0: send auth to 94:4a:0c:9d:0a:4b (try 1/3)
[ 3655.516747] wlp2s0: authenticated
[ 3655.523768] wlp2s0: associate with 94:4a:0c:9d:0a:4b (try 1/3)
[ 3655.532927] wlp2s0: RX AssocResp from 94:4a:0c:9d:0a:4b (capab=0x1411 status=0 aid=3)
[ 3655.538017] wlp2s0: associated
[ 3655.632044] wlp2s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 94:4a:0c:9d:0a:4b
[ 3671.230685] usb 2-1: new SuperSpeed USB device number 3 using xhci_hcd
[ 3671.248695] usb 2-1: New USB device found, idVendor=1058, idProduct=25a2, bcdDevice=10.21
[ 3671.248709] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3671.248716] usb 2-1: Product: Elements 25A2
[ 3671.248722] usb 2-1: Manufacturer: Western Digital
[ 3671.248727] usb 2-1: SerialNumber: 57584D314134384134373946
[ 3671.254365] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 3671.254995] scsi host5: usb-storage 2-1:1.0
[ 3672.281574] scsi 5:0:0:0: Direct-Access     WD       Elements 25A2    1021 PQ: 0 ANSI: 6
[ 3672.281914] sd 5:0:0:0: Attached scsi generic sg0 type 0
[ 3672.283305] sd 5:0:0:0: [sda] Spinning up disk...
[ 3673.293703] ...ready
[ 3675.429669] sd 5:0:0:0: [sda] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[ 3675.430543] sd 5:0:0:0: [sda] Write Protect is off
[ 3675.430555] sd 5:0:0:0: [sda] Mode Sense: 47 00 10 08
[ 3675.431237] sd 5:0:0:0: [sda] No Caching mode page found
[ 3675.431247] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 3675.450869]  sda: sda1
[ 3675.450974] sd 5:0:0:0: [sda] Attached SCSI disk
Auch der Stick funktioniert wieder einwandfrei, inkl. Schreiben.
Vielen vielen Dank, @giulia_privacy408 !
@weingeist
Danke für den Hinweis, @weingeist ! Ich habe der Root-Partition durch pacman -Scc Luft verschafft. Was könnte ich noch tun?
Hallo!
Dich von Windows 7 verabschieden. Windows 7 hat seine letzten Updates am 14. Januar 2020 bekommen und ist insofern jetzt nicht mehr als sicheres Betriebssystem zu sehen.
Gerade dann steht jetzt eine Neuinstallation an.
Schöne Grüße!
Sorry, @kmonster , das war meinerseits mißverständlich formuliert. Windows7 habe ich auf einem Uralt-Rechner und habe ich jetzt nur herangezogen, um wie von @giulia_privacy408 empfohlen chkdsk /f auf dem externen Laufwerk auszuführen (korrigiert wurde Sektor 128 oder so). Auf meinem Arbeitsrechner läuft ausschließlich Manjaro, und das externe Laufwerk ist noch NTFS, weil die ersten Daten darauf von einem Windows-Menschen kamen. Ich nehme diese Geschichte zum Anlaß, ein weiteres externes Laufwerk zu besorgen und dort die Daten auf ext4-Basis zu sichern.
"Was könnte ich noch tun?” bezog sich auf @weingeist s Hinweis, Platz zu schaffen – gibt es weitere naheliegende Möglichkeiten Platz auf der Systempartition zu schaffen außer pacman -Scc?
Ich weiß ja nicht was du alles installiert oder was da alles drauf liegt.
Das ist mein root
Disk (/): 13.94 GiB / 62.44 GiB (22%) - ext4
Hast du timeshift laufen ? und wenn ja, wo werden die snapshots gespeichert ?
Flatpak ?
Filelight könnte auch helfen der Sache auf den Grund zu gehen.
Edit: Sorry Filelight ist KDE, ich sehe gerade du nutzt Gnome.
Danke, @weingeist ! Wow, ja, das ist ein Unterschied! Das wirst Du aber wohl handverlesen haben.
Gnome bringt ja auch eine App Festplattenbelegung … /usr/lib (v.a. Lazarus, gcc, Python) und /usr/share (texmf) sind hier die Schwergewichte, ferner /var/log
Kann Filelight (müßte ich doch installieren können) ‘nachträglich’ analysieren, was ich in den letzten zwei Jahren NICHT genutzt habe?
Hallo moo,
Das ist doch schon mal ein guter Kandidat. Wenn Du keine Pascal-Programme schreibst kann Lazarus bestimmt weg.
viele Grüsse gosia
Ja, super, danke, @gosia !
Abschließende Frage: Wie ich am sichersten und sinnvollsten wieder dauerhaft Schreibzugriff auf die externe Festplatte haben? Hat chkdsk beim Reparieren die Rechte geändert? Muß ich also auf der Platte/an den Daten etwas ändern (chown), oder geht es hier ums Mounten?
Festplatte im Dateimanager immer aushängen, bevor man es abklemmt.
Nein. Das ist ein Sicherheitsfeature, um Daten nicht zu beschädigen.
Bei NTFS werden die Rechte per Overlay beim Einhängen gesetzt.
Danke für die Antwort, @megavolt !
Das tat und tue ich immer, besonders bei den externen Festplatten mit wichtigen Daten.
Aber jetzt ist ja trotzdem der Fall, daß die Daten auf der Platte einschließlich Verzeichnisse schreibgeschützt sind, so daß ich nichts mehr dort speichern kann.
Ich habe ein Verzeichnis mit chown geändert, aber ist das der sinnvollste und sicherste Weg?
Oh … was heißt das jetzt für mich? Eine dritte Lösung?
ok
Wenn das Dateisystem beschädigt ist, oder einfach nur ein “Dirty Bit” gesetzt wurde, dann wird bei NTFS3 Treiber komplett blockiert und bei ntfs-3g ignoriert, aber es wird schreibgeschützt eingehängt.
Wenn das so funktioniert, dann kann es keine Sicherheitsvorkehrung sein, denn das Laufwerk wird beim Einhängen komplett schreibgeschützt sein und kann nur beim erneuten korrekten Einhängen schreibbar werden.
Das ist eine Erklärung. Es werden kein Rechte unter Linux im Dateisystem NTFS gespeichert. Es wird alles komplett beim Einhängen mit Parameter gesetzt.
Ahh, danke für die Erklärungen, ich fange an zu verstehen.
Tatsächlich bleibt es auch bei weiterem Aus- und Einhängen dabei: in das mit chown meinem Nutzernamen als Eigentümer zugeordnete Verzeichnis kann ich etwas kopieren, die anderen bleiben schreibgeschützt. Das dürfte ja eigentlich nicht passieren, wenn die Rechte bei jedem Einhängen neu gesetzt werden.
Aber … Ohhh, habe jetzt in Laufwerke bei den Einhängoptionen “Vorgabe der Benutzersitzung” aktiviert, und jetzt habe ich nicht nur die Besitzerrechte für das Laufwerk und das eine Verzeichnis, sondern auch für alle anderen Verzeichnisse. (Für Leute wie mich: Nautilus > Laufwerk: Eigenschaften > Mit ‘Laufwerke’ öffnen > Partitionierungseinstellungen > Einhängeoptionen bearbeiten > “Vorgabe der Benutzersitzung” an.)
