yes, i’m using USB stick to install linux
anon33601770:
journalctl -f
[julian@manjaro ~]$ journalctl -f
-- Journal begins at Mon 2021-01-25 04:24:59 WIB. --
Jan 25 19:17:04 manjaro su[23402]: pam_unix(su:session): session closed for user root
Jan 25 19:17:04 manjaro audit[23402]: USER_END pid=23402 uid=0 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'
Jan 25 19:17:04 manjaro audit[23402]: CRED_DISP pid=23402 uid=0 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'
Jan 25 19:17:04 manjaro audit[23401]: USER_END pid=23401 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 25 19:17:04 manjaro sudo[23401]: pam_unix(sudo:session): session closed for user root
Jan 25 19:17:05 manjaro kernel: audit: type=1106 audit(1611577024.762:480): pid=23402 uid=0 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'
Jan 25 19:17:05 manjaro kernel: audit: type=1104 audit(1611577024.762:481): pid=23402 uid=0 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'
Jan 25 19:17:05 manjaro kernel: audit: type=1106 audit(1611577024.765:482): pid=23401 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=?
indent preformatted text by 4 spacesterminal=/dev/pts/2 res=success'
Jan 25 19:17:05 manjaro kernel: audit: type=1104 audit(1611577024.765:483): pid=23401 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 25 19:17:04 manjaro audit[23401]: CRED_DISP pid=23401 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 25 19:19:40 manjaro qterminal[23602]: QFSFileEngine::open: No file name specified
Jan 25 19:19:54 manjaro audit[23613]: USER_AUTH pid=23613 uid=1000 auid=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jan 25 19:19:55 manjaro kernel: audit: type=1100 audit(1611577194.588:484): pid=23613 uid=1000 auid=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jan 25 19:19:55 manjaro kernel: audit: type=1101 audit(1611577194.595:485): pid=23613 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jan 25 19:19:55 manjaro kernel: audit: type=1110 audit(1611577194.595:486): pid=23613 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jan 25 19:19:55 manjaro kernel: audit: type=1105 audit(1611577194.598:487): pid=23613 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jan 25 19:19:54 manjaro audit[23613]: USER_ACCT pid=23613 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jan 25 19:19:54 manjaro audit[23613]: CRED_REFR pid=23613 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jan 25 19:19:54 manjaro audit[23613]: USER_START pid=23613 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jan 25 19:19:54 manjaro dbus-daemon[384]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.386' (uid=0 pid=23613 comm="sudo dmesg -Hw ")
Jan 25 19:19:54 manjaro dbus-daemon[384]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 25 19:19:54 manjaro sudo[23613]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 25 19:19:54 manjaro sudo[23613]: julian : TTY=pts/1 ; PWD=/home/julian ; USER=root ; COMMAND=/usr/bin/dmesg -Hw
Jan 25 19:19:54 manjaro sudo[23613]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Jan 25 19:20:14 manjaro lxqt-panel[21835]: execAction "/usr/share/applications/pcmanfm-qt.desktop"
anon33601770:
sudo dmesg -Hw
d=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000425] audit: type=1110 audit(1611566992.707:202): pid=13103 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.005260] audit: type=1105 audit(1611566992.713:203): pid=13103 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +4.617129] audit: type=1106 audit(1611566997.331:204): pid=13103 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000162] audit: type=1104 audit(1611566997.331:205): pid=13103 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[Jan25 16:30] audit: type=1101 audit(1611567007.395:206): pid=13140 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000009] audit: type=1110 audit(1611567007.395:207): pid=13140 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.003618] audit: type=1105 audit(1611567007.399:208): pid=13140 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +14.780288] audit: type=1106 audit(1611567022.177:209): pid=13140 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000161] audit: type=1104 audit(1611567022.177:210): pid=13140 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +8.012978] audit: type=1101 audit(1611567030.189:211): pid=13176 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000009] audit: type=1110 audit(1611567030.189:212): pid=13176 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.000004] audit: type=1105 audit(1611567030.192:213): pid=13176 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +1.855216] audit: type=1106 audit(1611567032.049:214): pid=13176 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000156] audit: type=1104 audit(1611567032.049:215): pid=13176 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[Jan25 16:33] audit: type=1101 audit(1611567193.815:216): pid=13220 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.000473] audit: type=1110 audit(1611567193.815:217): pid=13220 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.003675] audit: type=1105 audit(1611567193.819:218): pid=13220 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +5.366996] audit: type=1106 audit(1611567199.186:219): pid=13220 uid=1000 aui
d=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.000398] audit: type=1104 audit(1611567199.186:220): pid=13220 uid=1000 aui
d=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[Jan25 16:37] audit: type=1100 audit(1611567440.080:221): pid=13326 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 re
s=success'[ +0.003951] audit: type=1101 audit(1611567440.083:222): pid=13326 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000441] audit: type=1110 audit(1611567440.083:223): pid=13326 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.005611] audit: type=1105 audit(1611567440.090:224): pid=13326 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.766801] audit: type=1106 audit(1611567440.856:225): pid=13326 uid=1000 aui
d=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.000007] audit: type=1104 audit(1611567440.856:226): pid=13326 uid=1000 aui
[ +16.407768] audit: type=1101 audit(1611567457.264:227): pid=13329 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000619] audit: type=1110 audit(1611567457.264:228): pid=13329 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.004923] audit: type=1105 audit(1611567457.271:229): pid=13329 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.031647] audit: type=1106 audit(1611567457.301:230): pid=13329 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success
'[ +0.000009] audit: type=1104 audit(1611567457.301:231): pid=13329 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +21.910308] audit: type=1101 audit(1611567479.211:232): pid=13333 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.000008] audit: type=1110 audit(1611567479.211:233): pid=13333 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.005186] audit: type=1105 audit(1611567479.218:234): pid=13333 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[Jan25 16:38] audit: type=1106 audit(1611567480.928:235): pid=13333 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success
'[ +0.000656] audit: type=1104 audit(1611567480.928:236): pid=13333 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +5.795839] audit: type=1101 audit(1611567486.725:237): pid=13339 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.002097] audit: type=1110 audit(1611567486.725:238): pid=13339 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.002884] audit: type=1105 audit(1611567486.732:239): pid=13339 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +1.635230] audit: type=1106 audit(1611567488.365:240): pid=13339 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success
'[ +0.000006] audit: type=1104 audit(1611567488.365:241): pid=13339 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +4.717701] audit: type=1101 audit(1611567493.082:242): pid=13345 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.000009] audit: type=1110 audit(1611567493.085:243): pid=13345 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.004722] audit: type=1105 audit(1611567493.089:244): pid=13345 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +1.736712] audit: type=1106 audit(1611567494.825:245): pid=13345 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success
'[ +0.001751] audit: type=1104 audit(1611567494.829:246): pid=13345 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[Jan25 16:43] audit: type=1103 audit(1611567784.215:247): pid=13486 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="l
ightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'[ +0.062310] audit: type=1130 audit(1611567784.275:248): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.077548] audit: type=1101 audit(1611567784.355:249): pid=13490 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.000142] audit: type=1103 audit(1611567784.355:250): pid=13490 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ +0.000244] audit: type=1006 audit(1611567784.355:251): pid=13490 uid=0 old-auid=4294967295 auid=971 tty=(none) old-ses=4294967295 ses=4 res=1[ +0.004563] audit: type=1105 audit(1611567784.358:252): pid=13490 uid=0 auid=9
71 ses=4 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.536434] audit: type=1130 audit(1611567784.891:253): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.014079] audit: type=1105 audit(1611567784.908:254): pid=13486 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix,pam_systemd
acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[ +5.489677] audit: type=1100 audit(1611567790.398:255): pid=13540 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="julian" exe="/usr/bin/light
dm" hostname=? addr=? terminal=:1 res=success'[ +0.060662] audit: type=1101 audit(1611567790.458:256): pid=13540 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam
_permit,pam_time acct="julian" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'[ +0.021665] audit: type=1110 audit(1611567790.481:257): pid=13540 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pa
m_permit,pam_faillock,pam_gnome_keyring acct="julian" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'[ +0.568775] audit: type=1106 audit(1611567791.048:258): pid=13486 uid=0 auid=4
294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'[ +0.000015] audit: type=1104 audit(1611567791.048:259): pid=13486 uid=0 auid=4
294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'[ +10.205360] audit: type=1131 audit(1611567801.255:260): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.054724] audit: type=1131 audit(1611567801.308:261): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib
/systemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 16:45] audit: type=1100 audit(1611567903.161:262): pid=13605 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 re
s=success'[ +0.003625] audit: type=1101 audit(1611567903.164:263): pid=13605 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.000368] audit: type=1110 audit(1611567903.164:264): pid=13605 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.003370] audit: type=1105 audit(1611567903.168:265): pid=13605 uid=1000 aui
d=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +1.547101] audit: type=1106 audit(1611567904.714:266): pid=13605 uid=1000 aui
d=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.000905] audit: type=1104 audit(1611567904.714:267): pid=13605 uid=1000 aui
d=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +20.630687] audit: type=1101 audit(1611567925.345:268): pid=13610 uid=1000 aui
d=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.001772] audit: type=1110 audit(1611567925.348:269): pid=13610 uid=1000 aui
[ +0.005402] audit: type=1105 audit(1611567925.351:270): pid=13610 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +1.385036] audit: type=1106 audit(1611567926.738:271): pid=13610 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000517] audit: type=1104 audit(1611567926.738:272): pid=13610 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +7.206811] audit: type=1101 audit(1611567933.942:273): pid=13617 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000008] audit: type=1110 audit(1611567933.942:274): pid=13617 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res
=success'[ +0.001597] audit: type=1105 audit(1611567933.948:275): pid=13617 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +6.685424] audit: type=1106 audit(1611567940.632:276): pid=13617 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +0.000765] audit: type=1104 audit(1611567940.635:277): pid=13617 uid=1000 aui
[ +3.073443] audit: type=1101 audit(1611567943.709:278): pid=13649 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.001006] audit: type=1110 audit(1611567943.709:279): pid=13649 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.004513] audit: type=1105 audit(1611567943.712:280): pid=13649 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'[ +9.073103] audit: type=1106 audit(1611567952.785:281): pid=13649 uid=1000 aui
[ +0.000007] audit: type=1104 audit(1611567952.785:282): pid=13649 uid=1000 aui
[Jan25 16:52] audit: type=1130 audit(1611568335.747:283): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +10.517502] audit: type=1131 audit(1611568346.264:284): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[Jan25 16:56] audit: type=1100 audit(1611568585.516:285): pid=14141 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ +0.003168] audit: type=1101 audit(1611568585.519:286): pid=14141 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[Jan25 17:01] proc: Bad value for 'hidepid'[ +0.274631] audit: type=1130 audit(1611568908.663:287): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/sy
stemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 17:02] audit: type=1131 audit(1611568938.724:288): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/sy
stemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 17:03] audit: type=1100 audit(1611569034.212:289): pid=14562 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_fai
llock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.009431] audit: type=1101 audit(1611569034.222:290): pid=14562 uid=1000 aui
d=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000905] audit: type=1110 audit(1611569034.222:291): pid=14562 uid=1000 aui
d=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.003625] audit: type=1105 audit(1611569034.229:292): pid=14562 uid=1000 aui
d=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +2.783262] audit: type=1106 audit(1611569037.012:293): pid=14562 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000439] audit: type=1104 audit(1611569037.012:294): pid=14562 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[Jan25 17:20] audit: type=1130 audit(1611570017.553:295): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +10.710136] audit: type=1131 audit(1611570028.265:296): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/us
r/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 17:24] audit: type=1131 audit(1611570253.507:297): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd
/systemd" hostname=? addr=? terminal=? res=success'[Jan25 17:29] audit: type=1130 audit(1611570563.980:298): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[Jan25 17:30] audit: type=1100 audit(1611570601.268:299): pid=15872 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ +0.007369] audit: type=1101 audit(1611570601.274:300): pid=15872 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal
=? res=success'[Jan25 17:31] audit: type=1131 audit(1611570661.188:301): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[Jan25 17:47] audit: type=1130 audit(1611571652.796:302): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +10.466397] audit: type=1131 audit(1611571663.262:303): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 17:57] audit: type=1100 audit(1611572250.007:304): pid=17367 uid=1000 aui
d=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'[ +0.004650] audit: type=1101 audit(1611572250.010:305): pid=17367 uid=1000 aui
d=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'[ +0.000437] audit: type=1110 audit(1611572250.010:306): pid=17367 uid=1000 aui
d=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'[ +0.004427] audit: type=1105 audit(1611572250.017:307): pid=17367 uid=1000 aui
d=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'[ +0.157286] audit: type=1100 audit(1611572250.173:308): pid=17368 uid=0 auid=1
000 ses=2 msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/3 res=success'[ +0.000603] audit: type=1101 audit(1611572250.173:309): pid=17368 uid=0 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su"
hostname=manjaro addr=? terminal=pts/3 res=success'[ +0.001301] audit: type=1103 audit(1611572250.173:310): pid=17368 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/3 res=success'
[ +0.000245] audit: type=1105 audit(1611572250.173:311): pid=17368 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/3 res=success'[Jan25 18:03] audit: type=1130 audit(1611572608.356:312): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +26.247126] audit: type=1100 audit(1611572634.605:313): pid=17658 uid=1000 aui
d=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'[ +0.010005] audit: type=1101 audit(1611572634.615:314): pid=17658 uid=1000 aui
[Jan25 18:05] audit: type=1131 audit(1611572725.028:315): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[Jan25 18:09] proc: Bad value for 'hidepid'[ +0.133705] audit: type=1130 audit(1611572985.687:316): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/sy
stemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 18:10] audit: type=1131 audit(1611573015.713:317): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/sy
stemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 18:11] audit: type=1130 audit(1611573080.766:318): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[Jan25 18:14] audit: type=1100 audit(1611573287.808:319): pid=18440 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ +0.003899] audit: type=1101 audit(1611573287.811:320): pid=18440 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal
=? res=success'[Jan25 18:15] audit: type=1130 audit(1611573317.668:321): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +10.593892] audit: type=1131 audit(1611573328.261:322): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 18:17] audit: type=1131 audit(1611573443.353:323): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +6.258881] audit: type=1106 audit(1611573449.613:324): pid=17368 uid=0 auid=1
000 ses=2 msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/3 res=success'[ +0.000008] audit: type=1104 audit(1611573449.613:325): pid=17368 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su"
hostname=manjaro addr=? terminal=pts/3 res=success'[ +0.000996] audit: type=1106 audit(1611573449.613:326): pid=17367 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success
'[ +0.001602] audit: type=1104 audit(1611573449.616:327): pid=17367 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock a
[Jan25 18:20] audit: type=1100 audit(1611573615.972:328): pid=18742 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 re
s=success'[ +0.007599] audit: type=1101 audit(1611573615.978:329): pid=18742 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000009] audit: type=1110 audit(1611573615.978:330): pid=18742 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
'[ +0.005480] audit: type=1105 audit(1611573615.985:331): pid=18742 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.027043] audit: type=1106 audit(1611573616.012:332): pid=18742 uid=1000 aui
d=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000121] audit: type=1104 audit(1611573616.012:333): pid=18742 uid=1000 aui
[ +5.892207] audit: type=1101 audit(1611573621.905:334): pid=18745 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000446] audit: type=1110 audit(1611573621.905:335): pid=18745 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res
=success'[ +0.003990] audit: type=1105 audit(1611573621.908:336): pid=18745 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +1.386923] audit: type=1106 audit(1611573623.295:337): pid=18745 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000429] audit: type=1104 audit(1611573623.295:338): pid=18745 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +5.688463] audit: type=1101 audit(1611573628.985:339): pid=18750 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.001191] audit: type=1110 audit(1611573628.985:340): pid=18750 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.004462] audit: type=1105 audit(1611573628.992:341): pid=18750 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +7.275139] audit: type=1106 audit(1611573636.265:342): pid=18750 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
'[ +0.000007] audit: type=1104 audit(1611573636.265:343): pid=18750 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
=success'
[Jan25 18:22] audit: type=1100 audit(1611573729.457:344): pid=18790 uid=1000 aui
[ +0.003331] audit: type=1101 audit(1611573729.461:345): pid=18790 uid=1000 aui
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000446] audit: type=1110 audit(1611573729.461:346): pid=18790 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.005743] audit: type=1105 audit(1611573729.467:347): pid=18790 uid=1000 aui
d=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +4.883232] audit: type=1130 audit(1611573734.351:348): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=run-u269 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.000067] audit: type=1131 audit(1611573734.351:349): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=run-u269 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 18:24] audit: type=1130 audit(1611573849.546:350): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +32.259102] audit: type=1100 audit(1611573881.809:351): pid=18871 uid=1000 aui
d=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'[ +0.009006] audit: type=1101 audit(1611573881.816:352): pid=18871 uid=1000 aui
d=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'[Jan25 18:25] audit: type=1130 audit(1611573938.456:353): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=run-u278 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ +0.147213] audit: type=1106 audit(1611573938.606:354): pid=18790 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
'[ +0.000141] audit: type=1104 audit(1611573938.606:355): pid=18790 uid=1000 aui
[Jan25 18:27] audit: type=1113 audit(1611574067.607:356): pid=818 uid=0 auid=1000 ses=2 msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=manjaro addr=? terminal=/dev/tty7 res=success'
[ +0.135314] audit: type=1106 audit(1611574067.741:357): pid=818 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,p
am_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="julian" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ +0.015452] audit: type=1104 audit(1611574067.757:358): pid=818 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_fail
lock,pam_gnome_keyring acct="julian" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ +0.603436] audit: type=1130 audit(1611574068.361:359): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/us
r/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.158638] wlp2s0: deauthenticating from 0c:9d:92:9f:d4:ca by local choice (R
eason: 3=DEAUTH_LEAVING)[ +6.602518] audit: type=1103 audit(1611574075.120:360): pid=21208 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="l
ightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'[ +0.081259] audit: type=1130 audit(1611574075.200:361): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib
/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.093098] audit: type=1101 audit(1611574075.294:362): pid=21212 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam
terminal=? res=success'[ +0.001415] audit: type=1103 audit(1611574075.297:363): pid=21212 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ +0.000009] audit: type=1006 audit(1611574075.297:364): pid=21212 uid=0 old-auid=4294967295 auid=971 tty=(none) old-ses=4294967295 ses=5 res=1[ +0.010783] audit: type=1105 audit(1611574075.307:365): pid=21212 uid=0 auid=971 ses=5 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit
,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.459470] audit: type=1130 audit(1611574075.764:366): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.009594] audit: type=1105 audit(1611574075.777:367): pid=21208 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix,pam_systemd
acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'[ +2.467453] audit: type=1131 audit(1611574078.244:368): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/us
r/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 18:28] audit: type=1100 audit(1611574081.313:369): pid=21255 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="julian" exe="/usr/bin/light
dm" hostname=? addr=? terminal=:0 res=success'[ +0.006209] audit: type=1101 audit(1611574081.320:370): pid=21255 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam
_permit,pam_time acct="julian" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'[ +0.238344] audit: type=1106 audit(1611574081.557:371): pid=21208 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd
acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'[ +0.001399] audit: type=1104 audit(1611574081.560:372): pid=21208 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="l
ightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'[ +0.026248] audit: type=1103 audit(1611574081.587:373): pid=21255 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pa
m_permit,pam_faillock,pam_gnome_keyring acct="julian" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'[ +0.000945] audit: type=1006 audit(1611574081.587:374): pid=21255 uid=0 old-au
id=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=6 res=1[ +0.260610] audit: type=1105 audit(1611574081.847:375): pid=21255 uid=0 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="julian"
exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'[ +0.228247] audit: type=1112 audit(1611574082.077:376): pid=21255 uid=0 auid=1000 ses=6 msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=manjaro addr=? t
erminal=/dev/tty7 res=success'[ +0.858209] wlp2s0: authenticate with 0c:9d:92:9f:d4:ca[ +0.023023] wlp2s0: send auth to 0c:9d:92:9f:d4:ca (try 1/3)[ +0.039656] wlp2s0: authenticated
[ +0.002279] wlp2s0: associate with 0c:9d:92:9f:d4:ca (try 1/3)[ +0.007480] wlp2s0: RX AssocResp from 0c:9d:92:9f:d4:ca (capab=0x1431 status=0 aid=10)[ +0.000161] wlp2s0: associated
[ +0.074734] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready[ +2.115169] audit: type=1130 audit(1611574085.197:377): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/us
r/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +6.733296] audit: type=1131 audit(1611574091.926:378): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.020631] audit: type=1131 audit(1611574091.950:379): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +3.290596] audit: type=1131 audit(1611574095.240:380): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.918531] audit: type=1130 audit(1611574096.160:381): pid=1 uid=0 auid=42949
67295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +29.837038] audit: type=1131 audit(1611574125.999:382): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/sy
stemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 18:31] audit: type=1100 audit(1611574291.407:383): pid=21774 uid=1000 auid=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_fai
llock acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'[ +0.007123] audit: type=1101 audit(1611574291.413:384): pid=21774 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'[Jan25 18:32] lxqt-panel[21318]: segfault at 8 ip 00007fdefc02da24 sp 00007ffdbb
eb3920 error 4 in libQt5Widgets.so.5.15.2[7fdefbea3000+3b0000] [ +0.000041] Code: 63 50 48 89 54 24 10 48 89 44 24 18 48 c7 04 24 00 00 00 00 48 c7 44 24 08 00 00 00 00 e8 e4 ec e7 ff 48 89 e7 e8 dc ec e7 ff <49> 8b 44 24 08 48 89 98 b8 02 00 00 4c 89 6b 08 4c 89 6b 10 48 8b
[ +0.000508] audit: type=1701 audit(1611574333.312:385): auid=1000 uid=1000 gid=1000 ses=6 pid=21318 comm="lxqt-panel" exe="/usr/bin/lxqt-panel" sig=11 res=1[ +0.112573] audit: type=1130 audit(1611574333.425:386): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-21828-0 comm="systemd" exe="/u
sr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +4.924554] audit: type=1131 audit(1611574338.349:387): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-21828-0 comm="systemd" exe="/u
sr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.079520] traps: pasystray[21339] trap int3 ip:7f4cac6bb294 sp:7ffdbf8b1380 error:0 in libglib-2.0.so.0.6600.4[7f4cac67b000+8c000][ +0.000088] audit: type=1701 audit(1611574338.429:388): auid=1000 uid=1000 gid
=1000 ses=6 pid=21339 comm="pasystray" exe="/usr/bin/pasystray" sig=5 res=1[ +0.015012] traps: pamac-tray[21335] trap int3 ip:7f66bc8dd294 sp:7ffd3e27a7b0 error:0 in libglib-2.0.so.0.6600.4[7f66bc89d000+8c000]
[ +0.000138] audit: type=1701 audit(1611574338.445:389): auid=1000 uid=1000 gid=1000 ses=6 pid=21335 comm="pamac-tray" exe="/usr/bin/pamac-tray" sig=5 res=1[ +0.000378] traps: nm-applet[21328] trap int3 ip:7f42b9c53294 sp:7ffcf0c5f7a0 error:0 in libglib-2.0.so.0.6600.4[7f42b9c13000+8c000]
[ +0.000048] audit: type=1701 audit(1611574338.445:390): auid=1000 uid=1000 gid=1000 ses=6 pid=21328 comm="nm-applet" exe="/usr/bin/nm-applet" sig=5 res=1[ +0.089085] audit: type=1130 audit(1611574338.535:391): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-21836-0 comm="systemd" exe="/u
sr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.063412] audit: type=1130 audit(1611574338.599:392): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@2-21837-0 comm="systemd" exe="/u
sr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[ +0.020285] audit: type=1130 audit(1611574338.619:393): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@3-21838-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[Jan25 18:34] kauditd_printk_skb: 3 callbacks suppressed[ +0.000013] audit: type=1100 audit(1611574447.936:397): pid=21996 uid=1000 auid=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_fai
llock acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'[ +0.006166] audit: type=1101 audit(1611574447.942:398): pid=21996 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'[ +3.116949] audit: type=1131 audit(1611574451.059:399): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd
/systemd" hostname=? addr=? terminal=? res=success'[ +8.633891] audit: type=1100 audit(1611574459.695:400): pid=22008 uid=1000 auid=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_fai
llock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.004458] audit: type=1101 audit(1611574459.702:401): pid=22008 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000586] audit: type=1110 audit(1611574459.702:402): pid=22008 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.005829] audit: type=1105 audit(1611574459.709:403): pid=22008 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.031512] audit: type=1106 audit(1611574459.739:404): pid=22008 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
'[ +0.000007] audit: type=1104 audit(1611574459.739:405): pid=22008 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +10.060230] audit: type=1101 audit(1611574469.799:406): pid=22011 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +3.440173] audit: type=1101 audit(1611574473.239:407): pid=22012 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.001593] audit: type=1110 audit(1611574473.242:408): pid=22012 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res
=success'[ +0.004961] audit: type=1105 audit(1611574473.245:409): pid=22012 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.630961] audit: type=1106 audit(1611574473.875:410): pid=22012 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
'[ +0.000170] audit: type=1104 audit(1611574473.875:411): pid=22012 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res
=success'[ +9.747858] audit: type=1101 audit(1611574483.625:412): pid=22015 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000682] audit: type=1110 audit(1611574483.625:413): pid=22015 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res
=success'[ +0.004628] audit: type=1105 audit(1611574483.628:414): pid=22015 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +1.085966] audit: type=1106 audit(1611574484.715:415): pid=22015 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
'[ +0.000257] audit: type=1104 audit(1611574484.715:416): pid=22015 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res
=success'[ +7.865494] audit: type=1101 audit(1611574492.578:417): pid=22022 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000007] audit: type=1110 audit(1611574492.578:418): pid=22022 uid=1000 aui
d=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000005] audit: type=1105 audit(1611574492.581:419): pid=22022 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.626714] audit: type=1106 audit(1611574493.208:420): pid=22022 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000009] audit: type=1104 audit(1611574493.208:421): pid=22022 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res
=success'[Jan25 18:35] audit: type=1101 audit(1611574504.288:422): pid=22025 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.001615] audit: type=1110 audit(1611574504.291:423): pid=22025 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.003819] audit: type=1105 audit(1611574504.294:424): pid=22025 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.037593] audit: type=1106 audit(1611574504.331:425): pid=22025 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000183] audit: type=1104 audit(1611574504.331:426): pid=22025 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +7.185840] audit: type=1101 audit(1611574511.518:427): pid=22027 uid=1000 aui
d=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000640] audit: type=1110 audit(1611574511.518:428): pid=22027 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.009594] audit: type=1105 audit(1611574511.528:429): pid=22027 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +1.950568] audit: type=1106 audit(1611574513.478:430): pid=22027 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000204] audit: type=1104 audit(1611574513.478:431): pid=22027 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +11.408282] audit: type=1101 audit(1611574524.887:432): pid=22033 uid=1000 aui
d=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000503] audit: type=1110 audit(1611574524.887:433): pid=22033 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.004646] audit: type=1105 audit(1611574524.891:434): pid=22033 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +1.853136] audit: type=1106 audit(1611574526.744:435): pid=22033 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit a
cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.000250] audit: type=1104 audit(1611574526.744:436): pid=22033 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +17.867511] audit: type=1101 audit(1611574544.614:437): pid=22039 uid=1000 aui
d=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.001212] audit: type=1110 audit(1611574544.614:438): pid=22039 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.006887] audit: type=1105 audit(1611574544.620:439): pid=22039 uid=1000 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit ac
ct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.030161] audit: type=1106 audit(1611574544.650:440): pid=22039 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
'[ +0.000009] audit: type=1104 audit(1611574544.650:441): pid=22039 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +3.296506] audit: type=1101 audit(1611574547.947:442): pid=22043 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="
julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.001206] audit: type=1110 audit(1611574547.947:443): pid=22043 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_fa
illock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +0.006152] audit: type=1105 audit(1611574547.953:444): pid=22043 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'[ +1.792354] audit: type=1106 audit(1611574549.747:445): pid=22043 uid=1000 aui
[ +0.000199] audit: type=1104 audit(1611574549.747:446): pid=22043 uid=1000 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res
=success'[Jan25 18:48] audit: type=1130 audit(1611575289.493:447): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd
/systemd" hostname=? addr=? terminal=? res=success'[ +3.904354] audit: type=1100 audit(1611575293.397:448): pid=22331 uid=1000 auid=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_fai
[ +0.005373] audit: type=1101 audit(1611575293.403:449): pid=22331 uid=1000 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal
=? res=success'[Jan25 18:57] proc: Bad value for 'hidepid'[ +0.316775] audit: type=1130 audit(1611575824.832:450): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/sy
stemd/systemd" hostname=? addr=? terminal=? res=success'[ +30.064144] audit: type=1131 audit(1611575854.899:451): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +6.366292] proc: Bad value for 'hidepid'[ +0.194986] audit: type=1130 audit(1611575861.459:452): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/sy
stemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 18:58] audit: type=1130 audit(1611575883.458:453): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +8.058732] audit: type=1131 audit(1611575891.518:454): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +1.727471] audit: type=1131 audit(1611575893.245:455): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'[Jan25 19:01] audit: type=1100 audit(1611576072.839:456): pid=22996 uid=1000 aui
d=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.004427] audit: type=1101 audit(1611576072.842:457): pid=22996 uid=1000 aui
d=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.000471] audit: type=1110 audit(1611576072.842:458): pid=22996 uid=1000 aui
d=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.003565] audit: type=1105 audit(1611576072.846:459): pid=22996 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.086569] audit: type=1106 audit(1611576072.932:460): pid=22996 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.000407] audit: type=1104 audit(1611576072.932:461): pid=22996 uid=1000 aui
d=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +10.194219] audit: type=1101 audit(1611576083.129:462): pid=22998 uid=1000 aui
d=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.001452] audit: type=1110 audit(1611576083.129:463): pid=22998 uid=1000 aui
d=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.004890] audit: type=1105 audit(1611576083.136:464): pid=22998 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.025871] audit: type=1106 audit(1611576083.159:465): pid=22998 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.000008] audit: type=1104 audit(1611576083.159:466): pid=22998 uid=1000 aui
d=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +2.518079] audit: type=1101 audit(1611576085.679:467): pid=23000 uid=1000 aui
d=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.000982] audit: type=1110 audit(1611576085.679:468): pid=23000 uid=1000 aui
d=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.011323] audit: type=1105 audit(1611576085.692:469): pid=23000 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +3.705331] audit: type=1106 audit(1611576089.393:470): pid=23000 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.000007] audit: type=1104 audit(1611576089.396:471): pid=23000 uid=1000 aui
d=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[Jan25 19:10] audit: type=1100 audit(1611576605.256:472): pid=23401 uid=1000 aui
d=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.014335] audit: type=1101 audit(1611576605.269:473): pid=23401 uid=1000 aui
d=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.000008] audit: type=1110 audit(1611576605.269:474): pid=23401 uid=1000 aui
d=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.001219] audit: type=1105 audit(1611576605.272:475): pid=23401 uid=1000 aui
d=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'[ +0.125966] audit: type=1100 audit(1611576605.399:476): pid=23402 uid=0 auid=1
000 ses=6 msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'[ +0.000391] audit: type=1101 audit(1611576605.399:477): pid=23402 uid=0 auid=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su"
hostname=manjaro addr=? terminal=pts/2 res=success'[ +0.000843] audit: type=1103 audit(1611576605.399:478): pid=23402 uid=0 auid=1000 ses=6 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'
[ +0.000224] audit: type=1105 audit(1611576605.399:479): pid=23402 uid=0 auid=1000 ses=6 msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'
[Jan25 19:17] audit: type=1106 audit(1611577024.762:480): pid=23402 uid=0 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'[ +0.000007] audit: type=1104 audit(1611577024.762:481): pid=23402 uid=0 auid=1
000 ses=6 msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=manjaro addr=? terminal=pts/2 res=success'cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success
[ +0.000704] audit: type=1106 audit(1611577024.765:482): pid=23401 uid=1000 auid=1000 ses=6 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit ad=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +5.345324] audit: type=1106 audit(1611566979.008:199): pid=13066 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000250] audit: type=1104 audit(1611566979.008:200): pid=13066 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success
'cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ +0.000903] audit: type=1104 audit(1611577024.765:483): pid=23401 uid=1000 aud=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=succes'
[Jan25 19:19] audit: type=1100 audit(1611577194.588:484): pid=23613 uid=1000 aud=1000 ses=6 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_fallock acct="julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 rs=success'
[ +0.007478] audit: type=1101 audit(1611577194.595:485): pid=23613 uid=1000 aud=1000 ses=6 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=julian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ +0.000395] audit: type=1110 audit(1611577194.595:486): pid=23613 uid=1000 aud=1000 ses=6 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock cct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=succes'
[ +0.003594] audit: type=1105 audit(1611577194.598:487): pid=23613 uid=1000 aud=1000 ses=6 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit act="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
