I have just installed new GPU (RX6800) and an new case to fit it, and my USB headphones stopped working entirely.
I have read a bunch of similar issues but I could not get to the end of the issue.
This is the output of inxi -Fazy
on my system:
inxi -Fazy
Kernel: 6.1.69-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ffc28760-325a-44d1-8874-4ba787e6b683 rw quiet splash apparmor=1
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
Type: Desktop Mobo: Micro-Star model: A320M-A PRO MAX (MS-7C52) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.80
date: 12/07/2020
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 3921 high: 4075 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3853 2: 4075
3: 3561 4: 4074 5: 4047 6: 4050 7: 3681 8: 4074 9: 3423 10: 4075 11: 4074
12: 4073 bogomips: 86433
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 2b:00.0
chip-ID: 1002:73bf class-ID: 0300
Device-2: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3
chip-ID: 1b3f:2247 class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung S24F350
serial: <filter> built: 2017 res: 1920x1080 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (navi21 LLVM
16.0.6 DRM 3.49 6.1.69-1-MANJARO) device-ID: 1002:73bf memory: 15.62 GiB
unified: no
API: Vulkan v: 1.3.274 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 (RADV NAVI21) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:73bf surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2b:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.1.69-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.29 TiB used: 1.21 TiB (36.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD30EZRX-22D8PB0
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BC142
tech: HDD rpm: 7200 serial: <filter> fw-rev: JC4B scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WDS120G1G0A-00SS50 size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1000
scheme: GPT
ID-1: / raw-size: 111.79 GiB size: 109.47 GiB (97.93%)
used: 48.12 GiB (44.0%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
used: 304 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 465.47 GiB size: 457.97 GiB (98.39%)
used: 362.19 GiB (79.1%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 78.1 C mobo: N/A gpu: amdgpu temp: 56.0 C
mem: 50.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 364 Uptime: 16m wakeups: 0 Memory: total: 32 GiB
available: 31.29 GiB used: 5 GiB (16.0%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1519 libs: 482 tools: gnome-software,pamac,yay
Shell: Bash v: 5.2.21 running-in: gnome-terminal inxi: 3.3.31
