Hi folks,
I have this very annoying issue whereby my dual-boot setup freezes at the Manjaro GRUB bootloader screen. The timer is stuck on 5 seconds and the keyboard is unresponsive.
I initially thought it was to do with my external display which is connected to a USB-C/HDMI hub however, further troubleshooting has confirmed that this isn’t the issue.
I can confirm 100% that the issue occurs when I have an active USB device connected to any port on my laptop (x2 USB-C and x1 USB=A).
I’m guessing this has something to do with my laptop BIOS. The BIOS has an option to disabled BIOS, but there are no options to enable Legacy USB. When I detach the USB devices, the laptop will boot to GRUB just fine. Oddly, if I tap F9 which brings up the BIOS bootloader, I can then select Manjaro from the list and it will then load the Manjaro GRUB with the USB devices attached, so it works this way.
I still can’t work out why it is freezing like this. I use an external monitor and usually don’t even open the lid of my laptop but now I have to otherwise I won’t be able to boot into Manjaro.
- Is there a fix somewhere I am overlooking, maybe in the BIOS?
- Is there some way to disable GRUB completely and force my laptop to use the BIOS bootloader screen (F9 on startup). This allows me to select Windows/Manjaro and it will boot just fine with USB devices connected.
- Is there something in GRUB I can try disabling that would help? Here is my GRUB config
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
Eventually I want to get rid of Windows completely, but even when I do, this will still be an issue. I would really appreciate your help with this. Thank you!
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5c7e6414-c04a-474b-8dcc-d95acc04d8dd rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: HP product: HP Spectre x360 Convertible 13-aw0xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 86F9 v: 87.74 serial: <superuser required> UEFI: AMI
v: F.28 date: 03/04/2021
ID-1: BAT0 charge: 60.0 Wh (100.0%) condition: 60.0/60.8 Wh (98.7%)
volts: 17.3 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: Full cycles: 13
Device-1: hid-0018:04F3:29F9.0001-battery model: ELAN2514:00 04F3:29F9
serial: N/A charge: N/A status: N/A
Device-2: sony_controller_battery_84:17:66:83:74:b6 model: N/A serial: N/A
charge: N/A status: Full
RAM: total: 7.45 GiB used: 3.71 GiB (49.9%)
RAM Report:
Info: model: Intel Core i5-1035G4 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1300 high: 1301 min/max: 400/3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1301 2: 1300 3: 1300
4: 1301 5: 1301 6: 1300 7: 1301 8: 1300 bogomips: 23968
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Plus Graphics G4 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a5a class-ID: 0300
Device-2: Chicony HP True Vision HD Camera type: USB driver: uvcvideo
bus-ID: 3-5:3 chip-ID: 04f2:b6a4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
bus-ID: 3-10:7 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 3060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 465.76 GiB used: 48.69 GiB (10.5%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234100WD temp: 34.9 C scheme: GPT
ID-1: / raw-size: 120.86 GiB size: 118.4 GiB (97.97%)
used: 14.78 GiB (12.5%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: 5c7e6414-c04a-474b-8dcc-d95acc04d8dd
used: 31.5 MiB (32.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: E40C-7643
ID-3: /run/timeshift/backup raw-size: 97.66 GiB size: 95.12 GiB (97.41%)
used: 33.88 GiB (35.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: ffa3e941-d94c-40f3-a409-43d7e9e4f157
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 246.53 GiB fs: ntfs label: N/A
uuid: E2B8B43EB8B41351
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 611 MiB fs: ntfs label: N/A
uuid: E430B86C30B846F8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 2-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-5: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-2.2:4 info: Sony DualShock 4 [CUH-ZCT1x] type: HID
driver: sony,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 054c:05c4 class-ID: 0300
Hub-6: 3-2.3:77 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-2.3.1:78 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
Device-2: 3-2.3.2:79 info: Microdia Redragon Mitra RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
Hub-7: 3-2.4:6 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-2.4.1:8 info: Realtek BillBoard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.1 speed: 12 Mb/s power: 200mA
chip-ID: 0bda:2171 class-ID: 1100 serial: <filter>
Device-2: 3-5:3 info: Chicony HP True Vision HD Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 3-9:5 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00c9
class-ID: ff00 serial: <filter>
Device-4: 3-10:7 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-8: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 288 Uptime: 1h 46m wakeups: 34 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1242
pacman: 1239 lib: 338 flatpak: 3 Shell: Zsh v: 5.8 default: Bash v: 5.1.12
running-in: konsole inxi: 3.3.11
