Hi I’ve recently acquired a USB C Ethernet adapter and I can’t get it working, by that I mean I have plugged it in and it nothing is showing up on KDE network manager and I don’t really know what to do.
inxi -Fazy`
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=85bf051f-8b7d-419d-bb67-baa73ec66768 rw quiet
cryptdevice=UUID=1d6501dd-1606-4de4-a7f9-0e18af147a41:luks-1d6501dd-1606-4de4-a7f9-0e18af147a41
root=/dev/mapper/luks-1d6501dd-1606-4de4-a7f9-0e18af147a41 apparmor=1
security=apparmor
resume=/dev/mapper/luks-4838b6b8-73f2-4757-b0a9-9969348222b1
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: MEDION product: S6445 MD61321 v: 5.13_VEB_1AUOK026
serial: <filter>
Mobo: MEDION model: M15WUN v: 0.2 serial: <filter> UEFI: American Megatrends
v: 205 date: 10/12/2018
ID-1: BAT0 charge: 39.7 Wh condition: 41.0/41.6 Wh (99%) volts: 12.3/11.4
model: M153137 type: Unknown serial: <filter> status: Unknown cycles: 6
Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: B (11)
microcode: DE L2 cache: 8 MiB
bogomips: 32012
Speed: 2906 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 2906 2: 1446
3: 1382 4: 1305 5: 1163 6: 1552 7: 1776 8: 1492
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3ea0
Device-2: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-7:4 chip ID: 04f2:b5c6 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 55 size: 890x500mm (35.0x19.7")
diag: 1021mm (40.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Pegatron
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 3000 bus ID: 00:14.3 chip ID: 8086:9df0
Local Storage: total: 238.47 GiB used: 14.4 GiB (6.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Phison model: S11-256G-SSD-B3
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 61.2
ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%) used: 14.4 GiB (6.4%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-1d6501dd-1606-4de4-a7f9-0e18af147a41
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 480 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-4838b6b8-73f2-4757-b0a9-9969348222b1
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 246 Uptime: 3h 29m wakeups: 1 Memory: 7.67 GiB
used: 5.18 GiB (67.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1276 lib: 377 flatpak: 0 Shell: Bash v: 5.1.0 running in: terminator
inxi: 3.2.01
journalctl -r
-- Journal begins at Fri 2021-01-01 20:11:38 GMT, ends at Mon 2021-01-11 09:31:29 GMT. --
Jan 11 09:31:29 pcm upowerd[1069]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1->
Jan 11 09:31:29 pcm kernel: usb 1-6.2.3: SerialNumber: 0000000000000001
Jan 11 09:31:29 pcm kernel: usb 1-6.2.3: Manufacturer: VIA Technologies Inc.
Jan 11 09:31:29 pcm kernel: usb 1-6.2.3: Product: USB 2.0 BILLBOARD
Jan 11 09:31:29 pcm kernel: usb 1-6.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 11 09:31:29 pcm kernel: usb 1-6.2.3: New USB device found, idVendor=2109, idProduct=0102, bcdDevice= 7.03
Jan 11 09:31:29 pcm kernel: usb 1-6.2.3: new high-speed USB device number 17 using xhci_hcd
Jan 11 09:31:28 pcm upowerd[1069]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-6
Jan 11 09:31:28 pcm kernel: hub 1-6.2:1.0: 4 ports detected
Jan 11 09:31:28 pcm kernel: hub 1-6.2:1.0: USB hub found
Jan 11 09:31:28 pcm kernel: usb 1-6.2: Manufacturer: VIA Labs, Inc.
Jan 11 09:31:28 pcm kernel: usb 1-6.2: Product: USB2.0 Hub
Jan 11 09:31:28 pcm kernel: usb 1-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 11 09:31:28 pcm kernel: usb 1-6.2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
Jan 11 09:31:28 pcm kernel: usb 1-6.2: new high-speed USB device number 16 using xhci_hcd
Jan 11 09:31:27 pcm kernel: hub 1-6:1.0: 4 ports detected
Jan 11 09:31:27 pcm kernel: hub 1-6:1.0: USB hub found
Jan 11 09:31:27 pcm kernel: usb 1-6: Manufacturer: VIA Labs, Inc.
Jan 11 09:31:27 pcm kernel: usb 1-6: Product: USB2.0 Hub
Jan 11 09:31:27 pcm kernel: usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 11 09:31:27 pcm kernel: usb 1-6: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
Jan 11 09:31:27 pcm kernel: usb 1-6: new high-speed USB device number 15 using xhci_hcd
Jan 11 09:31:27 pcm kwin_x11[922]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connect>
Jan 11 09:31:16 pcm kernel: usb 1-6.2.3: USB disconnect, device number 14
Jan 11 09:31:16 pcm kernel: usb 1-6.2: USB disconnect, device number 13
Jan 11 09:31:16 pcm kernel: usb 1-6: USB disconnect, device number 12
dmesg | grep usb
[ 0.473987] usbcore: registered new interface driver usbfs
[ 0.473987] usbcore: registered new interface driver hub
[ 0.473987] usbcore: registered new device driver usb
[ 0.890374] usbcore: registered new interface driver usbserial_generic
[ 0.890379] usbserial: USB Serial support registered for generic
[ 1.410666] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.410667] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.410668] usb usb1: Product: xHCI Host Controller
[ 1.410669] usb usb1: Manufacturer: Linux 5.9.16-1-MANJARO xhci-hcd
[ 1.410670] usb usb1: SerialNumber: 0000:00:14.0
[ 1.412558] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 1.412559] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.412560] usb usb2: Product: xHCI Host Controller
[ 1.412561] usb usb2: Manufacturer: Linux 5.9.16-1-MANJARO xhci-hcd
[ 1.412562] usb usb2: SerialNumber: 0000:00:14.0
[ 1.413341] usb: port power management may be unreliable
[ 1.741572] usb 1-3: new full-speed USB device number 2 using xhci_hcd
[ 1.884170] usb 1-3: New USB device found, idVendor=25a8, idProduct=0901, bcdDevice=10.01
[ 1.884171] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.884172] usb 1-3: Product: Smart 509 dongle
[ 1.884173] usb 1-3: Manufacturer: Smart
[ 1.892924] usbcore: registered new interface driver usbhid
[ 1.892924] usbhid: USB HID core driver
[ 1.894212] input: Smart Smart 509 dongle as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:25A8:0901.0001/input/input5
[ 1.948257] hid-generic 0003:25A8:0901.0001: input,hidraw0: USB HID v1.01 Keyboard [Smart Smart 509 dongle] on usb-0000:00:14.0-3/input0
[ 1.948336] input: Smart Smart 509 dongle as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:25A8:0901.0002/input/input6
[ 1.948355] hid-generic 0003:25A8:0901.0002: input,hidraw1: USB HID v1.01 Mouse [Smart Smart 509 dongle] on usb-0000:00:14.0-3/input1
[ 1.951643] input: Smart Smart 509 dongle System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.2/0003:25A8:0901.0003/input/input7
[ 2.008239] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[ 2.008265] input: Smart Smart 509 dongle Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.2/0003:25A8:0901.0003/input/input8
[ 2.008425] hid-generic 0003:25A8:0901.0003: input,hiddev0,hidraw2: USB HID v1.01 Device [Smart Smart 509 dongle] on usb-0000:00:14.0-3/input2
[ 2.148802] usb 1-5: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[ 2.148803] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.148804] usb 1-5: Product: USB2.0-CRW
[ 2.148805] usb 1-5: Manufacturer: Generic
[ 2.148805] usb 1-5: SerialNumber: 20100201396000000
[ 2.153344] usbcore: registered new interface driver rtsx_usb
[ 2.271600] usb 1-7: new high-speed USB device number 4 using xhci_hcd
[ 2.444568] usb 1-7: New USB device found, idVendor=04f2, idProduct=b5c6, bcdDevice=10.32
[ 2.444569] usb 1-7: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.444570] usb 1-7: Product: USB2.0 HD UVC WebCam
[ 2.444571] usb 1-7: Manufacturer: Chicony Electronics Co.,Ltd.
[ 2.444571] usb 1-7: SerialNumber: 200901010001
[ 2.568226] usb 1-10: new full-speed USB device number 5 using xhci_hcd
[ 2.709475] usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 2.709476] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 12.108545] usbcore: registered new interface driver btusb
[ 12.162053] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/input/input25
[ 12.162120] usbcore: registered new interface driver uvcvideo
[ 54.388323] usb 1-6: new high-speed USB device number 6 using xhci_hcd
[ 54.530540] usb 1-6: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
[ 54.530547] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 54.530552] usb 1-6: Product: USB2.0 Hub
[ 54.530556] usb 1-6: Manufacturer: VIA Labs, Inc.
[ 55.248300] usb 1-6.2: new high-speed USB device number 7 using xhci_hcd
[ 55.391584] usb 1-6.2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
[ 55.391591] usb 1-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 55.391596] usb 1-6.2: Product: USB2.0 Hub
[ 55.391599] usb 1-6.2: Manufacturer: VIA Labs, Inc.
[ 56.101628] usb 1-6.2.3: new high-speed USB device number 8 using xhci_hcd
[ 56.262964] usb 1-6.2.3: New USB device found, idVendor=2109, idProduct=0102, bcdDevice= 7.03
[ 56.262973] usb 1-6.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 56.262977] usb 1-6.2.3: Product: USB 2.0 BILLBOARD
[ 56.262982] usb 1-6.2.3: Manufacturer: VIA Technologies Inc.
[ 56.262986] usb 1-6.2.3: SerialNumber: 0000000000000001
[10657.300910] usb 1-6: USB disconnect, device number 6
[10657.300917] usb 1-6.2: USB disconnect, device number 7
[10657.300922] usb 1-6.2.3: USB disconnect, device number 8
[10677.298507] usb usb2-port1: over-current condition
[10677.298578] usb usb1-port1: over-current condition
[10686.345061] usb 1-6: new high-speed USB device number 9 using xhci_hcd
[10686.488447] usb 1-6: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
[10686.488456] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[10686.488463] usb 1-6: Product: USB2.0 Hub
[10686.488468] usb 1-6: Manufacturer: VIA Labs, Inc.
[10687.198640] usb 1-6.2: new high-speed USB device number 10 using xhci_hcd
[10687.348009] usb 1-6.2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
[10687.348017] usb 1-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[10687.348021] usb 1-6.2: Product: USB2.0 Hub
[10687.348025] usb 1-6.2: Manufacturer: VIA Labs, Inc.
[10688.078393] usb 1-6.2.3: new high-speed USB device number 11 using xhci_hcd
[10688.238627] usb 1-6.2.3: New USB device found, idVendor=2109, idProduct=0102, bcdDevice= 7.03
[10688.238635] usb 1-6.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[10688.238640] usb 1-6.2.3: Product: USB 2.0 BILLBOARD
[10688.238644] usb 1-6.2.3: Manufacturer: VIA Technologies Inc.
[10688.238649] usb 1-6.2.3: SerialNumber: 0000000000000001
[11690.499944] usb 1-6: USB disconnect, device number 9
[11690.499953] usb 1-6.2: USB disconnect, device number 10
[11690.499957] usb 1-6.2.3: USB disconnect, device number 11
[11705.948194] usb 1-6: new high-speed USB device number 12 using xhci_hcd
[11706.090266] usb 1-6: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
[11706.090275] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[11706.090282] usb 1-6: Product: USB2.0 Hub
[11706.090287] usb 1-6: Manufacturer: VIA Labs, Inc.
[11706.821443] usb 1-6.2: new high-speed USB device number 13 using xhci_hcd
[11706.963447] usb 1-6.2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
[11706.963457] usb 1-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[11706.963462] usb 1-6.2: Product: USB2.0 Hub
[11706.963468] usb 1-6.2: Manufacturer: VIA Labs, Inc.
[11707.671452] usb 1-6.2.3: new high-speed USB device number 14 using xhci_hcd
[11707.835488] usb 1-6.2.3: New USB device found, idVendor=2109, idProduct=0102, bcdDevice= 7.03
[11707.835496] usb 1-6.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[11707.835501] usb 1-6.2.3: Product: USB 2.0 BILLBOARD
[11707.835505] usb 1-6.2.3: Manufacturer: VIA Technologies Inc.
[11707.835508] usb 1-6.2.3: SerialNumber: 0000000000000001
[12484.869110] usb 1-6: USB disconnect, device number 12
[12484.869115] usb 1-6.2: USB disconnect, device number 13
[12484.869117] usb 1-6.2.3: USB disconnect, device number 14
[12495.677939] usb 1-6: new high-speed USB device number 15 using xhci_hcd
[12495.823158] usb 1-6: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
[12495.823167] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[12495.823172] usb 1-6: Product: USB2.0 Hub
[12495.823176] usb 1-6: Manufacturer: VIA Labs, Inc.
[12496.551287] usb 1-6.2: new high-speed USB device number 16 using xhci_hcd
[12496.692864] usb 1-6.2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.13
[12496.692869] usb 1-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[12496.692871] usb 1-6.2: Product: USB2.0 Hub
[12496.692873] usb 1-6.2: Manufacturer: VIA Labs, Inc.
[12497.409364] usb 1-6.2.3: new high-speed USB device number 17 using xhci_hcd
[12497.570962] usb 1-6.2.3: New USB device found, idVendor=2109, idProduct=0102, bcdDevice= 7.03
[12497.570969] usb 1-6.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[12497.570973] usb 1-6.2.3: Product: USB 2.0 BILLBOARD
[12497.570976] usb 1-6.2.3: Manufacturer: VIA Technologies Inc.
[12497.570979] usb 1-6.2.3: SerialNumber: 0000000000000001
It is an Advent amhbcpd19
